KTF251B154M32NLT00
KTF251B154M32NLT00
    NCC(贵弥功)
    贴片电容(MLCC) 1210 150nF ±20% 250V X7R
KTF251B154M32NLT00 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS NTS Series / NTF RoHS2 Compliant Series Temperature cycle : 1000 cycles ◆FEATURES 1. Large capacitance by small size. 2. Excellent noise absorption. 3. High permissible ripple current capability. 4. NTF: Temperature cycle : 1000 cycles. ◆APPLICATIONS 1. Smoothing circuit of DC-DC converters. 2. On-board power supplies. 3. Voltage regulators for computers. 3. Noise suppressor for various kinds of equipments. 4. High reliability equipments. ◆CONSTRUCTION Ceramic Dielectric Termination (Tin Plating) Internal Electrode ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55 to +125℃ 25, 50, 100, 250, 500Vdc 0.010 to 47µF M (±20%) : Standard, K (±10%) X7R See No.5 on the following table ◆SPECIFICATIONS No. 1 Items Withstand Voltage Specification No abnormality. Test Condition Rated voltage Withstand voltage Less than 250V 250% of rated voltage More than 250V Less than 500V More than 500V 100V + 150% of rated voltage 130% of rated voltage Shall be applied for 5 seconds. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. 3 Rated Capacitance Within specified tolerance. Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. Temperature 4 5 Dissipation Factor Rated Ripple Current CR>10µF CR≦10µF 5.0% maximum. See STANDARD RATINGS 25±2℃ Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms 10kHz∼1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 13 CAT. No. E1002W MULTILAYER CERAMIC CHIP CAPACITORS NTS Series / NTF Series ◆SPECIFICATIONS No. 6 Items Adhesion Specification Test Condition No visible damage. Substrate 5N (0.51kgf) for 10±1 seconds Capacitor 7 Bend strength of the face plating Appearance : No visible damage. ΔC/C : ±15% The substrate shall be bend at a rate of 1mm/s for 5 seconds. Press Press bar Capacitor Substrate Bending capability* 45±2mm 45±2mm Support *Bending capability NTS : 1mm NTF : 1mm or 2mm 8 Solderability Min. 75% of surface of the termination shall be covered with new solder 9 Resistance to Soldering Heat Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Solder Solder Temperature Dipping Time Pb Free 245±5℃ 2±0.5sec. Preheating Condition : Step 1 2 Temperature 100±10℃ 200±10℃ Time 2min. 2min. Solder Temperature : 260±5℃ Dipping Time : 2±0.5 seconds 10 Temperature Cycle Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Step 1 2 3 4 Temperature (℃) Min. Category temperature ±3 Room temperature Max. Category temperature ±3 Room temperature (min.) 30±3 3 max. 30±3 3 max. For above temperature cycle. NTS : For 5 cycles NTF : For 1000 cycles 11 Humidity Load Life Appearance : No abnormality. ΔC/C : ±15% D.F. : 10% maximum I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500±24 0 hours 12 Endurance Appearance : No abnormality. ΔC/C : ±15% D.F. : 10% maximum I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 125±3℃ Voltage : Rated voltage Time : 1000±48 0 hours *CR : Rated Capacitance(µF) Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 14 CAT. No. E1002W MULTILAYER CERAMIC CHIP CAPACITORS NTS Series ◆STANDARD RATINGS Rated voltage Rated Capacitance (Vdc) (µF) 25 50 100 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 3.3 4.7 6.8 6.8 Dimensions(mm) L W Tmax. a Maximum ripple current (Arms) 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 0.8±0.5 2.0 1.0±0.5 3.0 5.7±0.4 5.0±0.4 7.5±0.5 6.3±0.5 2.8 3.0 4.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 7.5±0.5 6.3±0.5 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 0.6±0.3 1.0 0.8±0.5 2.0 1.0±0.5 3.0 4.5±0.4 3.2±0.4 3.2±0.5 5.7±0.4 5.0±0.4 7.5±0.5 6.3±0.5 2.8 3.2 2.8 3.2 3.5 Part Number Taping Quantity per reel (pcs. / reel) KTS250B105M31N0T00 KTS250B155M31N0T00 KTS250B225M31N0T00 KTS250B335M32N0T00 KTS250B475M32N0T00 KTS250B685M32N0T00 KTS250B106M43N0T00 KTS250B156M43N0T00 KTS250B226M55N0T00 KTS250B336M55N0T00 KTS250B476M76N0T00 KTS500B334M31N0T00 KTS500B474M31N0T00 KTS500B684M31N0T00 KTS500B105M31N0T00 KTS500B155M32N0T00 KTS500B225M32N0T00 KTS500B335M32N0T00 KTS500B475M43N0T00 KTS500B685M43N0T00 KTS500B106M55N0T00 KTS500B156M55N0T00 KTS500B226M76N0T00 KTS101B104M31N0T00 KTS101B154M31N0T00 KTS101B224M31N0T00 KTS101B334M31N0T00 KTS101B474M31N0T00 KTS101B684M31N0T00 KTS101B105M32N0T00 KTS101B155M32N0T00 KTS101B225M32N0T00 KTS101B155M43N0T00 KTS101B225M43N0T00 KTS101B335M43J0T00 KTS101B475M43E0T00 KTS101B335M55N0T00 KTS101B475M55N0T00 KTS101B685M55F0T00 KTS101B685M76N0T00 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 300 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 300 3,000 3,000 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 800 800 800 300 ※Please consult with us when you consider the rating other than a standard table. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 15 CAT. No. E1002W MULTILAYER CERAMIC CHIP CAPACITORS NTS Series ◆STANDARD RATINGS Dimensions(mm) Rated voltage Rated Capacitance (Vdc) (µF) 0.01 0.022 0.033 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 1.5 2.2 0.47 0.56 0.68 1.0 1.2 250 500 L W Tmax. a Maximum ripple current (Arms) 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 1.0±0.5 3.0 0.8±0.5 1.5 1.0±0.5 2.0 7.5±0.5 6.3±0.5 5.7±0.4 5.0±0.4 7.5±0.5 6.3±0.5 3.5 5.0 2.7 3.0 2.5 3.2 3.5 Part Number Taping Quantity per reel (pcs. / reel) KTS251B103M31N0T00 KTS251B223M31N0T00 KTS251B333M31N0T00 KTS251B473M31N0T00 KTS251B683M31N0T00 KTS251B104M31N0T00 KTS251B154M32N0T00 KTS251B224M32N0T00 KTS251B334M32N0T00 KTS251B474M43N0T00 KTS251B684M43N0T00 KTS251B105M55N0T00 KTS251B155M55N0T00 KTS251B155M76N0T00 KTS251B225M76N0T00 KTS501B474M55N0T00 KTS501B564M55N0T00 KTS501B684M76N0T00 KTS501B105M76N0T00 KTS501B125M76N0T00 3,000 3,000 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 300 300 800 800 500 300 300 ※Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆DIMENSIONS 18 Size Code Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Size Code Code JIS T 1 K TS 101 B 225 M 32 N0 T 00 3216 1206 43 4532 1812 32 55 76 3225 5750 7563 L EIA 31 1210 2220 W ◆PART NUMBERING SYSTEM a 3025 Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 16 CAT. No. E1002W MULTILAYER CERAMIC CHIP CAPACITORS NTF Series ◆STANDARD RATINGS Dimensions(mm) Rated voltage Rated Capacitance (Vdc) (µF) 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 15 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 4.7 6.8 0.033 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 0.47 0.56 25 50 100 250 500 L W Tmax. a Maximum ripple current (Arms) 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 3.0 1.0±0.4 2.0 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 1.0±0.4 2.0 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 0.7±0.2 1.0 1.0±0.4 2.0 3.2±0.4 4.5±0.4 3.2±0.5 2.8 3.2 2.8 3.2 5.7±0.4 5.0±0.4 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 1.0±0.4 2.0 5.0±0.4 2.7 3.0 1.0±0.4 1.5 5.7±0.4 Part Number Taping Quantity per reel (pcs. / reel) KTF250B105M31NLT00 KTF250B155M31NLT00 KTF250B225M31NLT00 KTF250B335M32NHT00 KTF250B475M32NHT00 KTF250B685M32NHT00 KTF250B106M43NHT00 KTF250B156M43NHT00 KTF250B226M55NHT00 KTF250B336M55NHT00 KTF500B334M31NLT00 KTF500B474M31NLT00 KTF500B684M31NLT00 KTF500B105M31NLT00 KTF500B155M32NHT00 KTF500B225M32NHT00 KTF500B335M32NHT00 KTF500B475M43NHT00 KTF500B685M43NHT00 KTF500B106M55NHT00 KTF500B156M55NHT00 KTF101B104M31NLT00 KTF101B154M31NLT00 KTF101B224M31NLT00 KTF101B334M31NLT00 KTF101B474M31NLT00 KTF101B684M31NLT00 KTF101B105M32NHT00 KTF101B155M32NHT00 KTF101B225M32NHT00 KTF101B155M43NHT00 KTF101B225M43NHT00 KTF101B335M43JHT00 KTF101B475M43EHT00 KTF101B475M55NHT00 KTF101B685M55FHT00 KTF251B333M31NLT00 KTF251B473M31NLT00 KTF251B683M31NLT00 KTF251B104M31NLT00 KTF251B154M32NLT00 KTF251B224M32NLT00 KTF251B334M32NLT00 KTF251B474M43NLT00 KTF251B684M43NLT00 KTF251B105M55NLT00 KTF251B155M55NLT00 KTF501B474M55NLT00 KTF501B564M55NLT00 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 3,000 3,000 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 800 800 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 800 800 ※Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆DIMENSIONS 18 Size Code Supplement code Taping code Terminal code (Bending NL:1mm, NH:2mm) Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Size Code Code JIS T 1 K T F 1 0 1 B 2 2 5 M 3 2 NH T 0 0 3216 1206 43 4532 1812 32 55 76 3225 5750 7563 L EIA 31 1210 2220 W ◆PART NUMBERING SYSTEM a 3025 Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 17 CAT. No. E1002W
KTF251B154M32NLT00
物料型号:文档中列出了多个型号,例如KTS250B105M31NOT00、KTF250B105M31NLT00等。
器件简介:这些电容器具有小尺寸大容量、优秀的噪声吸收能力、高允许纹波电流能力等特点。NTF系列特别强调了1000次的温度循环特性。
引脚分配:文档中没有明确指出具体的引脚分配,但提到了电容器的端子为锡镀层。
参数特性: - 工作温度范围:-55°C至+125°C - 额定电压范围:25Vdc至500Vdc - 额定电容范围:0.01μF至47μF - 电容公差:标准为M(±20%),K为±10% - 温度特性:X7R - 额定纹波电流:见下表(文档中提供了详细的测试条件和结果)
功能详解:这些电容器适用于多种电路,包括DC-DC转换器的平滑电路、板载电源、计算机的电压调节器、各种设备的噪声抑制器以及高可靠性设备。
应用信息:电容器适用于平滑电路、板载电源、电压调节器、噪声抑制和高可靠性设备。
封装信息:封装尺寸从1206(3216)到3025(7563)不等,具体尺寸根据型号而变化。
KTF251B154M32NLT00 价格&库存
很抱歉,暂时无法提供与“KTF251B154M32NLT00”相匹配的价格&库存,您可以联系我们找货
