600L0R5AW200T
600L0R5AW200T
    ATC
    贴片电容(MLCC) 0402 0.5pF ±0.05pF 200V C0G (NP0)
600L0R5AW200T 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors FEATURES • • • • • Lowest ESR in Class Highest Working Voltage in Class - 200 V Capacitance Range 0.1 pF to 27 pF High Q High Self-Resonance 600 SERIES OVERVIEW APPLICATIONS Case Size EIA Case Size 600 L 0402 600 S 0603 600 F 0805 PACKAGING OPTIONS • Cellular Base Stations • Broadband Wireless Services • Satellite Communications • Subscriber-based Wireless Devices • WiFi (802.11) • Public Safety Radio LEAD-FREE COMPATIBLE COMPONENT Tape & Reel CIRCUIT APPLICATIONS ENVIRONMENTAL CHARACTERISTICS • Filter Networks • High Q Frequency Sources • Matching Networks • Tuning, Coupling, Bypass and DC Blocking ELECTRICAL SPECIFICATIONS Temperature Coefficient (TCC) 0 ± 30 PPM/ºC Capacitance Range 0.1 pF to 27 pF Operating Temperature -55ºC to +125ºC* Quality Factor Greater than 2,000 at 1 MHz Insulation Resistance (IR) Series Themal Shock 5 Cycles, -55ºC to 125ºC Moisture Resistance Mil-STD-202, Method 106 Life Test 2000 hours at 125ºC at 2X Solderability Solder Coverage > 90% of end termination Terminal Strength 2 lbs. typ., 1 lb. min. Military Approval DSCC Drawing Number 05003 105 Megohms min. @ 25ºC at rated WVDC 104 Megohms min. @ 125ºC at rated WVDC Working Voltage (WVDC) 200 V Dielectric Withstanding Voltage (DWV) 250% of rated WVDC for 5 seconds Aging Effects None Piezoelectric Effects None The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 030121 – rf microwave products – 499 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors CAPACITANCE VALUES Value (pF) Cap Code Tolerances Value (pF) Cap Code Tolerances Value (pF) Cap Code Tolerances 0.1 0R1 A, B 1.6 1R6 A, B, C, D 6.2 6R2 A, B, C, D 0.2 0R2 A, B 1.8 1R8 A, B, C, D 6.8 6R8 B, C, J, K 0.3 0R3 A, B, C 2.0 2R0 A, B, C, D 7.5 7R5 B, C, J, K 0.4 0R4 A, B, C 2.2 2R2 A, B, C, D 8.2 8R2 B, C, J, K 0.5 0R5 A, B, C 2.4 2R4 A, B, C, D 9.1 9R1 B, C, J, K 0.6 0R6 A, B, C 2.7 2R7 A, B, C, D 10 100 F, G, J, K, M 0.7 0R7 A, B, C 3.0 3R0 A, B, C, D 11 110 F, G, J, K, M 0.8 0R8 A, B, C 3.3 3R3 A, B, C, D 12 120 F, G, J, K, M 0.9 0R9 A, B, C 3.6 3R6 A, B, C, D 15 150 F, G, J, K, M 1.0 1R0 A, B, C, D 3.9 3R9 A, B. C. D 18 180 F, G, J, K, M 1.1 1R1 A, B, C, D 4.3 4R3 A, B, C, D 20 200 F, G, J, K, M 1.2 1R2 A, B, C, D 4.7 4R7 A, B, C, D 22 220 F, G, J, K, M 1.3 1R3 A, B, C, D 5.1 5R1 A, B, C, D 24 240 F, G, J, K, M 1.5 1R5 A, B, C, D 5.6 5R6 A, B, C, D 27 270 F, G, J, K, M HOW TO ORDER 600 L 100 J T 200 T Series Packaging Case Size T=Tape and Reel, 500 pcs T4K=Tape and Reel, 4000 pcs T10K = Tape and Reel, 10,000 pcs See mechanical dimensions below Capacitance Voltage Rating EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Termination Style Code Capacitance Tolerance Code Code Tol. A B C D ±0.05 pF ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% T = Tin Plated over Nickel Barrier (RoHS Compliant) TN = Tin Plated Non-Magnetic Barrier W = Tin/Lead Solder Nickel Barrier *10,000 pieces on 7'' reel or 4000 pieces on 7" reel Consult KYOCERA AVX for other options. The above part number refers to a 600L Series (case size L) 11 pF capacitor, J tolerance (±5%), 200 WVDC, with T termination (Tin Plated over Nickel Barrier, RoHS Compliant), Tape and Reel packaging. 500 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors ESR (Ohms) 1 600L ESR vs. Frequency 27 pF 15 pF 8.2 3.3 pF 1.0 pF 0.1 (Typical) 0.01 100 1000 10000 Frequency (MHz) Frequency (GHz) 600L Resonant Frequency Data ) 0.1 1.0 10.0 100.0 Capacitance (pF) ATC 600L Series Data Sheet Test Condition Description Capacitors mounted in series microstrip configuration on 10-mil thick Rogers RO4350® softboard, 22-mils wide 1/2 oz. Cu traces. FSR = lowest frequency at which S11 response, referenced at capacitor edge, crosses real axis on Smith Chart. FPR = lowest frequency at which there is a notch in S21 magnitude response. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 501 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors OUTLINE DIMENSIONS L (0402) Y L: .040 ± .004 (1.02 ± 0.1) W: .020 ± .004 (.51 ± 0.1) T: .024 max (0.60 max) Y: .010 ± .006 (0.25 ± 0.15) inches (mm) W T L SUGGESTED MOUNTING PAD DIMENSIONS Case Size L, S, and F W L T B A Case Size A Min. B Min. C Min. D Min. 0402 (1005) .0275 (0.70) .0354 (0.90) .0157 (0.40) .0866 (2.20) 0603 (1608) .0393 (1.00) .0433 (1.10) .0236 (0.60) .110 (2.80) 0805 (2012) .0590 (1.50) .0512 (1.30) .0236 (0.60) .1259 (3.20) B inches (mm) C D DESIGN KITS Kit # Kit 36T Kit 37T Kit 38T RoHS Compliant Item # Description 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0036T 16 different values, 15 pcs. min. per value 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0037T 16 different values, 15 pcs. min. per value 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0038T 8 different values, 15 pcs. min. per value Cap. Value Range (pF) 0.1 to 2.0 Cap. Value (pF) 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2, 1.5.................. ±0.1 Price $100.00 1.6, 1.8, 2.0....................................... ±0.25 0.1 to 10 1.0, 1.2, 1.5, 1.8, 2.0. 2.2, 2.4, 2.7, 3.0, 3.3.............................................. ±0.1 3.9, 4.7, 5.6, 6.8, 8.2......................... ±0.25 10...................................................... ±5% $100.00 10 to 27 10, 12, 15, 18, 20, 22, 24, 27............. ±5% $100.00 For Online Kit Orders, Catalog & Application Notes, Visit: www.avx.com 502 Tol. (pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 030821 – rf microwave products –
600L0R5AW200T
物料型号:600L系列
器件简介:这是一系列超低等效串联电阻(ESR)的NPO介质射频/微波多层陶瓷电容器(MLC),具有同类产品中最低的ESR和最高的工作电压(200V),电容范围从0.1pF到27pF。
引脚分配:文档中没有明确提供引脚分配信息,但通常这类电容器为表面贴装器件,具有两个端子用于连接。
参数特性: - 最低的ESR等级 - 最高的工作电压:200V - 电容范围:0.1pF至27pF - 高Q值 - 高自谐振频率
功能详解: - 适用于射频/微波电路,如滤波器网络、匹配网络、高Q频率源、调谐、耦合、旁路和直流阻断。
应用信息: - 移动通信基站 - 用户基无线设备 - 宽带无线服务 - WiFi (802.11) - 卫星通信 - 公共安全无线电
封装信息: - 封装选项包括0402、0603和0805尺寸。 - 提供卷带包装选项,符合RoHS标准。
环境特性: - 热冲击:5个周期,-55°C至125°C - 耐湿性:符合Mil-STD-202, 方法106 - 寿命测试:在125°C下2000小时,额定电压的2倍 - 可焊性:焊料覆盖超过端子的90% - 端子强度:典型值2磅,最小值1磅 - 军事认证:DSCC图纸编号05003
电气规格: - 温度系数(TCC):0至30PPM/°C - 工作温度:-55°C至+125°C - 品质因数:在1MHz时大于2000 - 绝缘电阻(IR):在25°C下额定直流工作电压至少为10^5兆欧,125°C下至少为10^4兆欧 - 介质耐电压(DWV):额定直流工作电压的2.5倍,持续5秒 - 老化效应:无 - 压电效应:无
订购信息:提供了详细的订购指南,包括系列、封装、电容值、公差和端子样式代码。
设计套件:提供了不同电容值范围的设计套件,包括RoHS合规性和价格信息。
600L0R5AW200T 价格&库存
很抱歉,暂时无法提供与“600L0R5AW200T”相匹配的价格&库存,您可以联系我们找货
