WST2303
P-Ch MOSFET
General Description
Product Summery
The WST2303 is the highest performance trench
P-Ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the small power switching and load
switch applications.
BVDSS
RDSON
ID
-20V
65mΩ
-3.8A
Applications
The WST2303 meet the RoHS and Green
Product requirement with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Small power switching for MB/NB/UMPC/VGA
z Networking DC-DC Power System
z Load Switch
Features
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
ID@TC=25℃
±8
V
1
-3.8
A
1
Continuous Drain Current, VGS @ -4.5V
ID@TC=70℃
-2.5
A
IDM
Pulsed Drain Current2
-13
A
3
PD@TC=25℃
Total Power Dissipation
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Typ.
Max.
Unit
125
℃/W
80
℃/W
Rev:1.0 May.2019
WST2303
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
Reference to 25℃ , ID=-1mA
-0.014
V/℃
VGS=-4.5V , ID=-3A
65
80
VGS=-2.5V , ID=-2A
80
100
105
130
-0.3
-0.5
-1.0
V
2.3
mV/℃
VDS=-16V , VGS=0V , TJ=25℃
-1
VDS=-16V , VGS=0V , TJ=55℃
-5
VGS=-1.8V , ID=-1.5A
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
12.2
S
Qg
Total Gate Charge (-4.5V)
10.1
14.1
Qgs
Gate-Source Charge
1.21
1.7
Qgd
Gate-Drain Charge
2.46
3.4
Td(on)
VDS=-15V , VGS=-4.5V , ID=-3A
nC
5.6
11.2
Rise Time
VDD=-10V , VGS=-4.5V , RG=3.3Ω
32.2
58
Turn-Off Delay Time
ID=-3A
45.6
91
Fall Time
29.2
58.4
Ciss
Input Capacitance
677
948
Coss
Output Capacitance
82
115
Crss
Reverse Transfer Capacitance
73
102
Min.
Typ.
Max.
Unit
-1
A
-13
A
-1
V
29
nS
8
nC
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-3A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST2303”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.47889
- 50+0.37858
- 150+0.32842
- 国内价格
- 10+0.24355
- 100+0.19250
- 300+0.16699
- 3000+0.15744
- 6000+0.14211
- 9000+0.13449
