C0402HQN101-3R6BNP
C0402HQN101-3R6BNP
    VENKEL
    贴片电容(MLCC) 0402 3.6pF ±0.1pF 100V C0G (NP0)
C0402HQN101-3R6BNP 数据手册
HQN SERIES HIGH-Q CERAMIC CAPACITORS FEATURES: • Excellent Q and low ESR performance at high frequency • Voltage range: 25V to 500V • Capacitance range: 0.1pF to 220pF • Low power consumption • Suitable for IC decoupling application PART NUMBER STRUCTURE C 0805 HQN 201 Ceramic Capacitor Size 0201 0402 0603 0805 Series Rated Voltage 250 = 25VCDW 500 = 50VCDW 101 = 100VCDW 201 = 200VCDW 251 = 250VCDW 501 = 500VCDW — 1R0 C N P Capacitance (picofarads) 1st two digits are significant, followed by number of zeroes. (R denotes decimal) e.g: 101 = 100pF 0R5 = 0.5pF Tolerance **A = ± 0.05pF *B = ± 0.10pF *C = ± 0.25pF *D = ± 0.50pF F = ± 1% G = ± 2% J = ± 5% K = ± 10% * For cap. values below 10pF only. ** For cap. values of 8.2pF and less. Termination N = 100% matte tin (Sn) over nickel. Packaging P = paper E = Embossed Tape Example P/N: C0805HQN201-1R0CNP Standard termination finish is 100% matte Tin (Sn). DIMENSIONS Unit: inch (mm) THICKNESS SPECIFIC VALUES E/B (Max) 0.012 +/- 0.0012 (0.30 ± 0.03) All values 0.006 ± 0.002 (0.15 ± 0.05) 0.020 ± 0.002 (0.50 ± 0.05) 0.020 ± 0.002 (0.50 ± 0.05) All values 0.01 ± 0.004 (0.25 ± 0.10) 0.064 ± 0.004 (1.60 ± 0.10) 0.032 ± 0.004 (0.80 ± 0.10) 0.032 ± 0.0028 (0.80 ± 0.07) All other values 0.064 +0.006/-0.004 (1.60 +0.15/-0.10) 0.032 +0.006/-0.004 (0.80 +0.15/-0.10) 0.020 ± 0.004 (0.50 ± 0.10) 0.1pF 0.2pF 0.080 ± 0.006 (2.00 ± 0.15) 0.050 ± 0.004 (1.25 ± 0.10) 0.024 ± 0.004 (0.60 ± 0.10) 0.2pF 0.080 ± 0.008 (2.00 ± 0.20) 0.050 ± 0.008 (1.25 ± 0.20) 0.034 ± 0.004 (0.85 ± 0.10) All other values SIZE L W T (Max) 0201 0.024 ± 0.012 (0.60 ± 0.3) 0.012 ± 0.012 (0.30 ± 0.03) 0402 0.040 ± 0.002 (1.00 ± 0.05) 0603 0805 0.016 ± 0.006 (0.40 ± 0.15) 0.02 ± 0.008 (0.50 ± 0.20) ELECTRICAL SPECIFICATIONS Typical Series Resonant Frequency Frequency (GHz) 10 Temperature Coefficient: 0% ± 30PPM /°C, -55°C to +125°C 0201 0402 0603 0805 1 Quality Factor: Q > 5,000 @ 1MHz (Typical 10,000) 0201 Quality Factor: Q > 1,000 @ 1MHz (Typical 10,000) Ageing: None Insulation Resistance: 1,000 Ω-F or 100 GΩ (whichever is less at 25°C, VDCW). 50mA max. (IR at 125°C is 10% of the value at 25°C) 0.1 Dielectric Strength: 2.5 x VDCW Min., 25°C, 50 mA max 1 10 100 1000 Capacitance (pF) Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 05/2021-A 1 HQN SERIES HIGH-Q CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE Values that are typically available. All measurements in inches (mm) SIZE 0201 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R2 1R5 1R8 2R2 2R3 2R7 3R3 3R9 4R7 5R6 5R7 6R8 8R2 9R1 100 120 150 180 200 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 VDCW (MAX) 25V 0402 50V 25V 50V 10OV 0603 200V 50V 100V 200V 0805 250V 100V 200V 250V 500V 0.1pF 0.2pF 0.3pF 0.4pF 0.5pF 0.6pF 0.7pF 0.8pF 0.9pF 1.0pF 1.2pF 1.5pF 1.8pF 2.2pF 2.3pF 2.7pF 3.3pF 3.9pF 4.7pF 5.6pF 5.7pF 6.8pF 8.2pF 9.1pF 10pF 12pF 15pF 18pF 20pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF TEST PARAMETERS Test parameters for High-Q NPO Capacitors: 1MHz ± 100Hz at 1.0 ± 0.2 Vrms, 25°C, ~50% relative humidity. Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 05/2021-A 2 HQN SERIES HIGH-Q CERAMIC CAPACITORS RF PERFORMANCE CHARACTERISTICS 0201, 0402, 0603 & 0805 Maximum ESR 0.25 2.7pF ESR (ohms) 0.20 5.6pF 0402 10pF 47pF 100pf 10pF 0.10 0.05 100 300 500 800 1000 Frequency (MHz) TAPE & REEL SPECIFICATIONS REEL DIMENSIONS G B All tape and reel specifications must A be adhered to per EIA-481-1-A. D N C FULL RADIUS T TAPING SPECIFICATIONS To T D 10 Pitches Cumulative Tolerance 0.008 ( 0.2) A E F W B T Paper Embossed Top Tape P B min C A (7”) A (13”) D min N mIn G T max 8mm 0.3 (.012) 13 ± .05 (.512 ± .02) 178 ± 2.0 (7± .079) 330 ± 2.0 (13 ± .08) 20.2 (.795) 50 (1.97) 10 ± 1.5 (.394 ± 1.059) 14.9 (.587) 12mm 0.3 (.012) 13 ± .05 (.512 ± .02) 178 ± 2.0 (7± .079) 330 ± 2.0 (13 ± .08) 20.2 (.795) 50 (1.97) 10 ± 1.5 (.394 ± 1.059) 14.9 (.587) 7 IN. REEL QUANTITIES* Po Pz Unit: mm (inch) TAPE SIZE 0201* 0402* 0603 0805 Tape Size 8mm 8mm 8mm 8mm Min Qty per Reel 15,000 5000 3000 2000 Max Qty per eel 15,000 10,000 4000 5000 * Quantity dependent on thickness Center Of Cavity Direction Of Feed Unit: mm (inch) PAPER TAPE CARRIER DIMENSIONS (8mm) SIZE (inches) A B W F E P0 0201 1.37 ± 0.05 (.014 ± .002) 0.67 ± 0.05 (.026 ± .002) 8.0 ± 0.2 (.315 ± .008) 3.5 ± 0.1 (.138 ± .004) 1.75 ± 0.1 (.069 ± .004) 4.0 ± 0.1 (.157 ± .004) 0402 0.65 ± 0.1 1.10 ± 0.2 (.026 ± .004) (.043 ± .008) 8.0 ± 0.2 (.315 ± .008) 3.5 ± 0.1 (.138 ± .004) 1.75 ± 0.1 (.069 ± .004) 0603 1.10 ± 0.2 (.043 ± .008) 1.90 ± 0.2 (.075 ± .008) 8.0 ± 0.2 (.315 ± .008) 3.5 ± 0.1 (.138 ± .004) 0805 1.16 ± 0.2 2.4 ± 0.2 (.046 ± .008) (.095 ± .008) 8.0 ± 0.2 (.315 ± .008) 3.5 ± 0.1 (.138 ± .004) Email: sales@venkel.com | Phone: 512.794.0081 | t P 2.0 ± 0.05 - 0.0 1.5 ± 0.1 (.079 ± .002) (.064 ± .004) - .000 1.15 MAX (.045 MAX) 2.0 ± 0.05 (.079 ± .002) 4.0 ± 0.1 (.157 ± .004) 2.0 ± 0.05 - 0.0 1.5 ± 0.1 (.079 ± .002) (.064 ± .004) - .000 1.15 MAX (.045 MAX) 2.0 ± 0.05 (.079 ± .002) 1.75 ± 0.1 (.069 ± .004) 4.0 ± 0.1 (.157 ± .004) 2.0 ± 0.05 - 0.0 1.5 ± 0.1 (.079 ± .002) (.064 ± .004) - .000 1.15 MAX (.045 MAX) 4.0 ± 0.1 (.157 ± .004) 1.75 ± 0.1 (.069 ± .004) 4.0 ± 0.1 (.157 ± .004) 2.0 ± 0.05 - 0.0 1.5 ± 0.1 (.079 ± .002) (.064 ± .004) - .000 1.15 MAX (.045 MAX) 4.0 ± 0.1 (.157 ± .004) Toll Free: 800.950.8365 | Pz D Web: www.venkel.com Rev: 05/2021-A 3
C0402HQN101-3R6BNP
1. 物料型号:HQN系列高Q陶瓷电容器,具有不同的尺寸和电压等级。 2. 器件简介:这些电容器具有在高频下出色的Q值和低ESR性能,适用于IC去耦应用。 3. 引脚分配:文档中没有提供具体的引脚分配信息,但提到了电容器的尺寸范围从0201到0805。 4. 参数特性: - 工作电压范围:25V至500V。 - 电容范围:0.1pF至220pF。 - 低功耗。 - 符合RoHS和REACH标准,无卤素。 5. 功能详解: - 典型谐振频率图显示了不同电容值的频率响应。 - 温度系数:0% ± 30PPM/°C,工作温度范围为-55°C至+125°C。 - 品质因数Q:对于0201尺寸,Q > 5,000 @ 1MHz(典型值10,000);对于0402尺寸,Q > 1,000 @ 1MHz(典型值10,000)。 - 老化特性:无。 - 绝缘电阻:1,000 Ω-F或100 GΩ(以25°C时较小者为准)。 - 介质耐压:最小2.5 x VDCW。 6. 应用信息:适合IC去耦应用。 7. 封装信息:提供了不同尺寸的电容器的详细尺寸和厚度规格,以及胶带和卷轴规格。
C0402HQN101-3R6BNP 价格&库存
很抱歉,暂时无法提供与“C0402HQN101-3R6BNP”相匹配的价格&库存,您可以联系我们找货
