FTC1210X7R631-473KNE
    VENKEL
FTC1210X7R631-473KNE 数据手册
FTC SERIES FLEX TERMINATION CAPACITORS FEATURES: • Utilize a conductive Polymer termination to allow the capacitor to withstand high bending stresses • 3mm minimum bending strength specification • Capacitance range: 0.1pF to 47uF • Voltage range: 6.3V to 3000V DC • Terminations: 100% matte Tin (Sn) • Ceramic monolithic structure provides excellent reliability PART NUMBER STRUCTURE FTC 1206 X7R 500 Series Size 0402 0603 0805 1206 1210 1808 1812 2220 Temperature Characteristic (Dielectric) C0G X7R X5R Y5V Rated Voltage 1st two digits are significant followed by number of zeroes. 6R3 = 6.3 VDC 100 = 10 VDC 160 = 16 VDC 250 = 25 VDC 500 = 50 VDC 101 = 100 VDC 201 = 200 VDC 251 = 250 VDC 401 = 400 VDC 451 = 450 VDC 501 = 500 VDC 631 = 630 VDC 102 = 1000 VDC 152 = 1500 VDC 202 = 2000 VDC 302 = 3000 VDC - 106 K N E Capacitance (picofarads) 1st two digits are significant, followed by number of zeroes. R denotes decimal e.g: 101 = 10x101 = 100pF 104 = 10x104 = 100nF 6R8 = 6.8pF Tolerance * B = ±0.1pF * C = ±0.25pF * D = ±0.5pF F ±1% G = ±2% J = ±5% K = ±10% M = ±20% Z = -20/+80% *F  or values below 10pF only. Termination N = 100% Matte Tin over Nickel over a conductive Polymer Packaging E = Embossed Tape (7” reel) Example P/N: FTC1206X7R500-106KNE P = Paper Tape (7” reel) Standard termination finish is 100% matte Tin (Sn) over Nickel. DIMENSIONS Unit: inches (mm) L w T E/B E/B STRUCTURE T E/B 0.020 ± 0.002 (0.5 ± 0.05) See Specific Value 0.004 (min.) (0.10) 0.063 ± 0.006 (1.6 ± 0.15) 0.031 ± 0.0046 (0.8 ± 0.15) See Specific Value 0.008 (min.) (0.20) 0805 0.08 ± 0.008 (2.0 ± 0.20) 0.050 ± 0.008 (1.25 ± 0.20) See Specific Value 0.020 ± 0.010 (0.508 ± 0.254) 1206 0.126 ± 0.008 (3.2 ± 0.20) 0.063 ± 0.008 (1.6 ± 0.20) See Specific Value 0.020 ± 0.010 (0.508 ± 0.254) 1210 0.126 ± 0.008 (3.2 ± 0.20) 0.098 ± 0.008 (2.50 ± 0.20) See Specific Value 0.020 ± 0.010 (0.508 ± 0.254) 1808 0.18 +0.024/-0.16 (4.50 +0.6/-0.4) 0.0812 ± 0.010 (2.03 ±0.25) See Specific Value 0.020 ± 0.010 (0.50 ± 0.25) 1812 0.177 ± 0.012 (4.495 ± 0.30) 0.126 ± 0.012 (3.20 ± 0.30) See Specific Value 0.024 ± 0.015 (0.6096 ± 0.381) 2220 0.225 ± 0.02 (5.70 ± 0.50) 0.200 ± 0.016 (5.00 ± 0.40) See Specific Value 0.034 ± 0.014 (0.85 ± 0.35) SIZE L W 0402 0.040 ± 0.002 (1.0 ± 0.05) 0603 6 2 4 3 5 1 Ceramic Body (dielectric) 4 2 Inner Electrode 5 Nickel Plating 3 Inner Termination 6 100% Matte Tin (Sn) Silver Polymer 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 1 FTC SERIES FLEX TERMINATION CAPACITORS ELECTRICAL SPECIFICATION & RANGE NP0/C0G Typical Capacitance Change vs. Temperature 15% 10% 5% -5% -10% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C Ageing: None Temperature Coefficient: 0 ±30PPM/°C Withstanding Voltage: >2.5 times VDCW Temperature Voltage Coefficient: 0 ±30PPM/°C Insulation Resistance: >1000Ω-F or 100GΩ, for values ≤ 0.047uF (whichever is less at 25°C, WDCV). For Capacitance values > 0.047uF, the 500 Ω-F rule applies. (The IR at 125°C is 10% of the value at 25°C) 0% -15% Operating Temperature Range: -55°C to +125°C 125˚C Capacitance Tolerance: B,C,D,F,G,J,K Dissipation Factor: 0.1% max X7R Typical Capacitance Change vs. Temperature 15% Operating Temperature Range: -55°C to +125°C 10% D.F.≤ ≥100V ≤2.5% Temperature Coefficient: 0 ±15%∆°C MAX. 5% Temperature Voltage Coefficient: X7R not applicable 0% -5% -10% -15% Rated Voltage -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C 125˚C Insulation Resistance: >100Ω-F or 1GΩ, whichever is less at 25°C, VDCW. (10,000Ω at 125°C) 50V ≤2.5% 35V ≤3.5% Capacitance Tolerance: J,K,M 25V Rated Voltage 1206≥0.47μF ≤5% 0805›0.1μF; 0603≥0.068μF; 1206>1μF; 1210≥2.2μF ≤10% 0805›0.22μF; 1210≥3.3μF ≤5% 201≥0.01μF; 1210≥4.7μF ≤10% 0402≥0.012μF; 0603>0.1μF; 0805≥1μF; 1206≥2.2μF; 1210≥10μF ≤10% 0603≥1μF; 0805≥2.2μFF; 1206≥2.2μF; 1210≥10μF ≤5% 201≥0.01μF; 0805≥1μF; 1210≥10μF ≤7% 0603≥0.33μF ≤10% 201≥0.01μF; 0402≥0.10μF & (0402/X7R≥0.056μF); 0603≥0.47μF; 0805≥2.2μF;1206≥4.7μF;1210≥22μF ≤12.5% 0402≥0.47μF ≤5% 201≥0.01μF; 0402≥0.33μF; 0603≥0.15μF; 0805≥0.68μF; 1206≥2.2μF; 1210≥4.7μF ≤10% 201≥0.01μF; (201/X7R≥0.022μF); 0402≥0.22μF; 0603≥0.68μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥22μF ≤10% 201≥0.012μF; 0402≥0.33μF(0402/X7R≥0.22μF); 0603≥0.33μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥22μF; 01R5 ≤3.5% Insulation Resistance 100V: All X7R; 1210≥3.3μF 50V: 0402>0.01μF; 0603≥1μF; 0805≥1μF; 1206≥4.7μF; 1210≥4.7μF 16V ≤3.5% 35V:0603≥1μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF 25V:0402≥0.22μF; 0603≥2.2μF; 0805≥2.2μF; 1206≥10μF;1210≥10μF 1GΩ or 100Ω-F Whichever is smaller 16V: 0402≥0.22μF; 0603≥1μF; 0805≥2.2μF; 1206≥10μF; 1210≥47μF 10V: 0402≥0.47μF; 0603≥0.47μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥47μF 6.3V ; 4V ; Size 1812 10V 6.3V 4V Email: sales@venkel.com ≤3% ≤3% 0201(50V); 0603≥0.047μF; 0805≥0.18μF; 1206≥0.47μF Ageing: 2.5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Exception of D.F.≤ | Phone: 512.794.0081 | ≤5% ≤15% 201≥0.1μF; 0402≥1μF ≤15% 201≥0.1μF; 0402≥1μF(0402/X6S≥0.47μF); 0603≥10μF; 0805≥4.7μF; 1206≥47μF; 1210≥100μF ≤20% 0402≥2.2μF - - ≤10% ≤15% Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 2 FTC SERIES FLEX TERMINATION CAPACITORS ELECTRICAL SPECIFICATION & RANGE X5R Typical Capacitance Change vs. Temperature 15% Operating Temperature Range: -55°C to +85°C Temperature Coefficient: 0 ±15%∆°C MAX. Temperature Voltage Coefficient: X5R not applicable Insulation Resistance: >100Ω-F or 1GΩ, whichever is less at 25°C, VDCW. (10,000 Ω at 125°C) Ageing: 2.5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: K,M 10% 5% 0% -5% -10% -15% -55°C -25°C 0°C 25°C 50°C 75°C 100°C 125°C Rated Voltage ≥100V 50V 35V 25V Rated Voltage D.F.≤ ≤2.5% ≤2.5% ≤3.5% Exception of D.F.≤ ≤3% 1206≥0.47μF ≤5% 0805›0.1μF; 0603≥0.068μF; 1206>1μF; 1210≥2.2μF ≤10% 0805›0.22μF; 1210≥3.3μF ≤3% 0201(50V); 0603≥0.047μF; 0805≥0.18μF; 1206≥0.47μF ≤5% 201≥0.01μF; 1210≥4.7μF ≤10% 0402≥0.012μF; 0603>0.1μF; 0805≥1μF; 1206≥2.2μF; 1210≥10μF ≤10% 0603≥1μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF ≤5% 201≥0.01μF; 0805≥1μF; 1210≥10μF ≤7% 0603≥0.33μF ≤10% 201≥0.01μF; 0402≥0.10μF & (0402/X7R≥0.056μF); 0603≥0.47μF; 0805≥2.2μF;1206≥4.7μF;1210≥22μF ≤3.5% ≤12.5% 0402≥0.47μF ≤5% 201≥0.01μF; 0402≥0.33μF; 0603≥0.15μF; 0805≥0.68μF; 1206≥2.2μF; 1210≥4.7μF ≤10% 201≥0.01μF; (201/X7R≥0.022μF); 0402≥0.22μF; 0603≥0.68μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥22μF ≤10% 201≥0.012μF; 0402≥0.33μF(0402/X7R≥0.22μF); 0603≥0.33μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥22μF; 01R5 Insulation Resistance 100V: All X7R; 1210≥3.3μF 16V 50V: 0402>0.01μF; 0603≥1μF; 0805≥1μF; 1206≥4.7μF; 1210≥4.7μF ≤3.5% 35V:0603≥1μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF 25V:0402≥0.22μF; 0603≥2.2μF; 0805≥2.2μF; 1206≥10μF;1210≥10μF 1GΩ or 100Ω-F Whichever is smaller 10V ≤5% 16V: 0402≥0.22μF; 0603≥1μF; 0805≥2.2μF; 1206≥10μF; 1210≥47μF 10V: 0402≥0.47μF; 0603≥0.47μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥47μF 6.3V ; 4V ; Size 1812 6.3V ≤10% 4V ≤15% ≤15% 201≥0.1μF; 0402≥1μF ≤15% 201≥0.1μF; 0402≥1μF(0402/X6S≥0.47μF); 0603≥10μF; 0805≥4.7μF; 1206≥47μF; 1210≥100μF ≤20% 0402≥2.2μF - - Y5V Typical Capacitance Change vs. Temperature 40% Operating Temperature Range: -30°C to +85°C Temperature Coefficient: +22% - 82%∆°C MAX. Insulation Resistance: >100Ω-F or 1GΩ, whichever is less at 25°C, WDCV. (The IR at 125°C is 10% of the value at 25°C) 20% 0% -20% -40% -60% -80% -100% -55˚C -25˚C 0˚C 25˚C 50C 75˚C 100˚C 125˚C Ageing: 7% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: M,Z Rated Voltage ≥50V Rated Voltage Insulation Resistance 100V: All X7R; 1210≥3.3μF 50V: 0402>0.01μF; 0603≥1μF; 0805≥1μF; 1206≥4.7μF; 1210≥4.7μF 35V 25V D.F.≤ 1GΩ or 100Ω-F Whichever is smaller 16V: 0402≥0.22μF; 0603≥1μF; 0805≥2.2μF; 1206≥10μF; 1210≥47μF 10V: 0402≥0.47μF; 0603≥0.47μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥47μF 6.3V ; 4V ; Size 1812 Email: sales@venkel.com | Phone: 512.794.0081 | 16V (C 1000pF, 25°C Note: To ensure proper capacitance readings, the voltage level must be held constant. The HP4284 and Agilent E4980 has a “ALC” (Automatic Level Control) function and should be switched to the “ON” position for accurate capacitance readings. VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (0402 - 0603) Size (inches) 0.1pF 0603 10V 16V 25V 50V 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 100V 10V 16V 50V 100V 200V 250V 0R2 0.2pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0R3 0.3pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0R4 0.4pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0R5 0.5pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0R6 0.6pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0R7 0.7pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0R8 0.8pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0R9 0.9pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1.0pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1.2pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1R0 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 471 5R6 8R2 100 120 150 180 220 270 330 390 470 Values that are typically available. (Thickness in mm). 0402 VDCW (MAX) 0R1 1.5pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1.8pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 2.2pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 2.7pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 3.3pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 3.9pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 4.7pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 5.6pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 6.8pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 8.2pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 10pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 12pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 15pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 18pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 22pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 27pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 33pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 39pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 47pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 560 56pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 680 68pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 820 82pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 101 100pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 121 120pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 151 150pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 181 180pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 221 220pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 271 270pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 4 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (0402 - 0603) 0603 10V 16V 25V 50V 330pF 0.50±0.20 0.50±0.20 0.50±0.20 390pF 0.50±0.20 0.50±0.20 470pF 0.50±0.20 0.50±0.20 560pF 0.50±0.20 680pF 331 391 471 561 681 821 102 122 152 182 222 272 332 100V 10V 16V 25V 50V 100V 200V 250V 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 820pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1000pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 1200pF 0.80±0.30 0.80±0.30 0.80±0.30 1500pF 0.80±0.30 0.80±0.30 1800pF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 2200pF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 2700pF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 3300pF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 C0G (NP0) DIELECTRIC (0805) SIZE (INCHES) 0R6 0R7 0R8 0R9 1R0 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 471 5R6 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 VDCW (MAX) 0R5 Values that are typically available. (Thickness in mm). 0402 VDCW (MAX) SIZE (INCHES) Values that are typically available. (Thickness in mm). 0805 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 0.5pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 0.6pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 0.7pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 0.8pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 0.9pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.0pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.2pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.5pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.8pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 2.2pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 2.7pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 3.3pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 3.9pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 4.7pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 5.6pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 6.8pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 8.2pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 10pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 12pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 15pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 18pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 22pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 27pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 33pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 39pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 47pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 56pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 68pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 82pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.80±0.10 0.80±0.10 1.25±0.10 100pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 120pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 150pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 5 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (0805) SIZE (INCHES) 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 VDCW (MAX) 0805 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 180pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 220pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 270pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 330pF 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 0.60±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 390pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 470pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.30 1.25±0.30 1.25±0.30 560pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.30 680pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.30 1.25±0.30 820pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.30 1.25±0.30 1000pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.30 1.25±0.30 1200pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1500pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1800pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 2200pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 2700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 3300pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 3900pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 4700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 5600pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 6800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 8200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.010μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 C0G (NP0) DIELECTRIC (1206) SIZE (INCHES) 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 471 5R6 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 VDCW (MAX) 1R0 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 1206 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 1500V 2000V 1.0pF 1.2pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.5pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.8pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 2.2pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 2.7pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 3.3pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 3.9pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 4.7pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 5.6pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 6.8pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 8.2pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 10pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 12pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 15pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 18pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 22pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 27pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 33pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 39pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 47pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 0.95±0.10 56pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.25±0.10 1.25±0.10 68pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.25±0.10 1.25±0.10 82pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 100pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.25±0.10 1.25±0.10 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 6 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (1206) SIZE (INCHES) 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 VDCW (MAX) 1206 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 1500V 2000V 120pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 150pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 180pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.60±0.20 1.60±0.20 1.60±0.20 220pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.60±0.20 1.60±0.20 1.60±0.20 270pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.50 1.60±0.50 330pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.50 1.60±0.50 390pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.50 1.60±0.50 470pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 560pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 680pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 820pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1000pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1200pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1500pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1800pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 2200pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 2700pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 3300pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 3900pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 4700pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 5600pF 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 6800pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 8200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.010μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.012μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.015μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.018μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.022μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.027μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.033μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 0.039μF 1.60±0.50 1.60±0.50 1.60±0.50 1.60±0.50 C0G (NP0) DIELECTRIC (1210) SIZE (INCHES) 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 VDCW (MAX) 100 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 1210 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 1500V 2000V 10pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 12pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 15pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 18pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 22pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 27pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 33pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 39pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 47pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 56pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 68pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 82pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 100pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 120pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 150pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 1.60±0.20 180pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 1.60±0.20 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 7 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (1210) SIZE (INCHES) 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 VDCW (MAX) 1210 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 1500V 2000V 220pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 270pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.00±0.20 2.00±0.20 330pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.00±0.20 2.00±0.20 390pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.50±0.50 2.50±0.50 470pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.50±0.50 2.50±0.50 560pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 680pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 820pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1000pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1500pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 1800pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2700pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 3300pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 3900pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 4700pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 5600pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 6800pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 8200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 0.010μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 0.012μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.015μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.018μF 0.022μF 0.027μF 0.033μF 0.039μF 0.047μF C0G (NP0) DIELECTRIC (1808) SIZE (INCHES) 2R2 2R7 3R3 3R9 4R7 471 5R6 8R2 100 120 150 180 220 270 330 390 470 VDCW (MAX) 2R0 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 1808 500V 630V 1000V 1500V 2000V 3000V 2.0pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.2pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.7pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 3.3pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 3.9pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 4.7pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 5.6pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 6.8pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 8.2pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 10pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 12pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 15pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 18pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 22pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 27pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 33pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 39pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 47pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 8 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (1808) SIZE (INCHES) 1808 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 VDCW (MAX) 560 500V 630V 1000V 1500V 2000V 3000V 56pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 68pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 82pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 100pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 120pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 150pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 180pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 220pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 270pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 330pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 390pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 470pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 560pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 680pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 820pF 2.00±0.20 2.00±0.20 2.00±0.20 1.25±0.10 1.25±0.10 1000pF 2.00±0.20 2.00±0.20 2.00±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1200pF 2.00±0.20 2.00±0.20 1500pF 2.00±0.20 2.00±0.20 1.60±0.20 1800pF 2.00±0.20 2.00±0.20 2.00±0.20 2200pF 2.00±0.20 2.00±0.20 2.00±0.20 2700pF 2.00±0.20 2.00±0.20 3300pF 2.00±0.20 2.00±0.20 C0G (NP0) DIELECTRIC (2220) SIZE (INCHES) 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 VDCW (MAX) 100 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 2220 25V 50V 100V 200V 250V 500V 630V 1000V 1500V 2000V 3000V 10pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 12pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 15pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 4000V 18pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 22pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 27pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 33pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 39pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 47pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 56pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 68pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 82pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 100pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 120pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 150pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 180pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 220pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 270pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 330pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 390pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 470pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 560pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 680pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 820pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 9 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE C0G (NP0) DIELECTRIC (2220) SIZE (INCHES) 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 VDCW (MAX) 2220 25V 50V 100V 200V 250V 500V 630V 1000V 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 181 3000V 4000V 1500pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1800pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2200pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2700pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 3300pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 3900pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 4700pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 5600pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 6800pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 8200pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 10000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 12000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 15000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 18000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 22000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 27000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 33000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 39000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 47000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 56000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 68000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 82000pF 2.00±0.20 2.00±0.20 2.50±0.30 100000pF 2.50±0.30 2.50±0.30 VDCW (MAX) 121 2000V 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 SIZE (INCHES) 151 1500V 1200pF 2.50±0.30 X7R DIELECTRIC (0402, 0603) 101 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 0402 10V 16V 25V 0603 50V 100V 10V 16V 25V 50V 100V 100pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 200V 250V 120pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 150pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 180pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 220pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 270pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 330pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 390pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 470pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 560pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 680pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 820pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 1000pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 1200pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 1500pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 1800pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 2200pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 2700pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 3300pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 3900pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 4700pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 5600pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 6800pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 10 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (0402, 0603) SIZE (INCHES) 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 105 VDCW (MAX) 0402 10V 16V 0603 25V 50V 100V 10V 16V 25V 50V 100V 8200pF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.010μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.012μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.015μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.022μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.027μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.033μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.039μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.047μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.056μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.068μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.082μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.10μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.80±0.07 0.80±0.07 0.80±0.30 0.12μF 0.15μF 0.80±0.07 0.80±0.07 0.80±0.30 0.18μF 0.80±0.07 0.80±0.07 0.80±0.30 0.22μF 0.80±0.07 0.80±0.07 0.80±0.30 0.80±0.30 0.27μF 0.80±0.30 0.80±0.30 0.80±0.30 0.33μF 0.80±0.30 0.80±0.30 0.80±0.30 0.39μF 0.80±0.30 0.80±0.30 0.80±0.30 0.47μF 0.80±0.30 0.80±0.30 0.80±0.30 0.56μF 0.80±0.30 0.80±0.30 0.68μF 0.80±0.30 0.80±0.30 0.82μF 0.80±0.30 0.80±0.30 1.0μF 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 121 250V 0.80±0.30 0.80±0.30 0.80±0.30 Size (inches) Values that are typically available. (Thickness in mm). 0805 VDCW (MAX) 151 200V 0.018μF X7R DIELECTRIC (0805) 101 Values that are typically available. (Thickness in mm). 10V 16V 25V 50V 100V 200V 250V 500V 630V 1000V 100pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 120pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 150pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 180pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 220pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 270pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 330pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 390pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 470pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 560pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 680pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 820pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1000pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 0.80±0.10 1500pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 1.25±0.10 1800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 1.25±0.10 2200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 1.25±0.10 2700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 3300pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 3900pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.80±0.10 0.80±0.10 4700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 11 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (0805) SIZE (INCHES) 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 105 155 225 475 155 225 475 VDCW (MAX) 0805 10V 16V 25V 50V 100V 200V 250V 500V 630V 5600pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 6800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 8200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.010μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.012μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.015μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.018μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.022μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.027μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.033μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.039μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.047μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.056μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.068μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.082μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.10μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.12μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.30 0.15μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.30 0.18μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.30 0.22μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.30 0.27μF 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 0.33μF 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 0.39μF 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 0.47μF 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 0.56μF 1.25±0.30 1.25±0.30 1.25±0.30 0.68μF 1.25±0.30 1.25±0.30 1.25±0.30 0.82μF 1.25±0.30 1.25±0.30 1.25±0.30 1.0μF 1.25±0.30 1.25±0.30 1.25±0.30 1.5μF 1.25±0.30 1.25±0.30 1.25±0.30 2.2μF 1.25±0.30 1.25±0.30 1.25±0.30 4.7μF 1.25±0.30 1.25±0.30 1.5μF 1.25±0.30 1.25±0.30 1.25±0.30 2.2μF 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 4.7μF SIZE (INCHES) 121 151 181 221 271 331 391 471 561 681 821 102 VDCW (MAX) 1000V 1.25±0.30 X7R DIELECTRIC (1206) 101 Values that are typically available. (Thickness in mm). Values that are typically available. (Thickness in mm). 1206 10V 16V 25V 100pF 50V 100V 1000V 1500V 2000V 1.25±0.10 1.25±0.10 200V 250V 400V 450V 1.25±0.10 1.25±0.10 500V 630V 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 150pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 180pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 220pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 270pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 330pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 390pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 470pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 560pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 680pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 820pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1000pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 120pF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 12 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (1206) SIZE (INCHES) 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 105 155 225 475 106 226 VDCW (MAX) Values that are typically available. (Thickness in mm). 1206 10V 16V 25V 50V 100V 200V 250V 400V 450V 500V 630V 1000V 1500V 2000V 1200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1500pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 3300pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 3900pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 4700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 5600pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 6800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 8200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.010μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.012μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.015μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.018μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.022μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 0.027μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 0.033μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.039μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.047μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.056μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.068μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.082μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.10μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 0.12μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.15μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 0.18μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 0.22μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 0.27μF 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 0.33μF 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 0.39μF 0.95±0.10 0.95±0.10 1.15±0.15 1.60±0.50 1.60±0.20 0.47μF 1.15±0.15 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.20 0.56μF 1.15±0.15 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.50 0.68μF 1.15±0.15 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.50 0.82μF 1.15±0.15 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.50 1.0μF 1.15±0.15 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.50 1.5μF 1.15±0.15 1.15±0.15 1.60±0.50 1.15±0.15 1.15±0.15 1.60±0.50 1.60±0.50 2.2μF 4.7μF 1.60±0.50 1.60±0.50 1.60±0.50 10μF 1.60±0.50 1.60±0.50 1.60±0.50 22μF 1.60±0.50 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 13 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (1210) SIZE (INCHES) 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 105 155 VDCW (MAX) Values that are typically available. (Thickness in mm). 1210 6.3V 10V 16V 25V 50V 100V 200V 250V 400V 450V 100pF 500V 630V 1000V 1500V 2000V 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 120pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 150pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 180pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 220pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 270pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 330pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 390pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 470pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 560pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 680pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 820pF 1000pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 1200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 1500pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 1800pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2700pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 3300pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 3900pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 4700pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 5600pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 6800pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 8200pF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 0.010μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.012μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.015μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.018μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.022μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 0.027μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 0.033μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 1.60±0.20 0.039μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 0.047μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2.50±0.50 0.056μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 0.068μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 0.082μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 0.10μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 0.12v 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 2.50±0.50 2.50±0.50 0.15μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50 0.18μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50 0.22μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50 0.27μF 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50 0.33μF 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50 0.39μF 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 0.47μF 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 0.56μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 0.68μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.50±0.50 2.50±0.50 0.82μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 1.0μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 1.5μF 2.00±0.20 1.60±0.20 2.50±0.50 2.50±0.50 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 14 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (1210) SIZE (INCHES) 225 335 475 106 226 476 VDCW (MAX) 1210 6.3V 10V 2.2μF 16V 25V 50V 100V 200V 250V 400V 450V 3.3μF 2.00±0.20 1.60±0.20 2.50±0.50 4.7μF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 10μF 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 22μF 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 271 331 1000V 1500V 2000V 2.50±0.50 Values that are typically available. (Thickness in mm). 1808 VDCW (MAX) 181 630V 47μF 2.50±0.50 SIZE (INCHES) 221 500V 2.00±0.20 1.60±0.20 2.50±0.50 2.50±0.50 X7R DIELECTRIC (1808) 151 Values that are typically available. (Thickness in mm). 150pF 500V 630V 1000V 1500V 2000V 3000V 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 180pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 220pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 270pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 330pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 390pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 470pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 560pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 680pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 820pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 1000pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 1200pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 1500pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1800pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2200pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2700pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 3300pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 3900pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 4700pF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 5600pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 6800pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 8200pF 2.00±0.20 2.00±0.20 2.00±0.20 0.010μF 2.00±0.20 2.00±0.20 2.00±0.20 0.012μF 2.00±0.20 2.00±0.20 2.00±0.20 0.015μF 2.00±0.20 2.00±0.20 2.00±0.20 0.018μF 2.00±0.20 2.00±0.20 2.00±0.20 0.022μF 2.00±0.20 2.00±0.20 2.00±0.20 0.027μF 2.00±0.20 2.00±0.20 2.00±0.20 0.033μF 2.00±0.20 2.00±0.20 2.00±0.20 0.039μF 2.00±0.20 2.00±0.20 2.00±0.20 0.047μF 2.00±0.20 2.00±0.20 2.00±0.20 0.056μF 2.00±0.20 2.00±0.20 2.00±0.20 0.068μF 2.00±0.20 2.00±0.20 0.082μF 2.00±0.20 2.00±0.20 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 15 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (1812) SIZE (INCHES) 1812 VDCW (MAX) 271 10V 16V 25V 50V 100V 270pF 200V 250V 500V 630V 1000V 1500V 2000V 3000V 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 331 330pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 391 390pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 471 470pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 561 560pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 681 680pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 821 820pF 102 1000pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 122 1200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 152 1500pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 182 1800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2.50±0.50 222 2200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2.50±0.50 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 272 Values that are typically available. (Thickness in mm). 2700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 2.50±0.50 3300pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 3900pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 4700pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 5600pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 6800pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 8200pF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 0.010μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 0.012μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 0.015μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 0.018μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.022μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.027μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.033μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.039μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.047μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 0.056μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 0.068μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 0.082μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 1.25±0.10 1.25±0.10 2.50±0.50 2.50±0.50 0.10μF 1.25±0.10 0.12μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 0.15μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 184 0.18μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 224 0.22μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 274 0.27μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 334 0.33μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 394 0.39μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 474 0.47μF 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.50 1.25±0.10 2.00±0.20 2.50±0.50 2.50±0.50 564 0.56μF 1.25±0.10 1.25±0.10 1.25±0.10 684 0.68μF 1.25±0.10 1.25±0.10 1.25±0.10 824 0.82μF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 105 1.0μF 1.25±0.10 1.25±0.10 1.25±0.10 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50 155 1.5μF 2.00±0.20 225 2.2μF 2.50±0.50 2.50±0.50 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 16 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (2220) SIZE (INCHES) VDCW (MAX) 2220 25V 50V 100V 200V 250V 400V 500V 630V 1000V 1500V 2000V 3000V 4000V 100pF 121 120pF 151 150pF 181 180pF 221 220pF 271 270pF 2.00±0.20* 331 330pF 2.00±0.20* 391 390pF 2.00±0.20* 471 470pF 2.00±0.20* 561 560pF 2.00±0.20* 681 680pF 2.00±0.20* 821 820pF 2.00±0.20* 102 1000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 101 Values that are typically available. (Thickness in mm). 1200pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30* 1500pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30* 1800pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30* 2200pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 2700pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 3300pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 3900pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 4700pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 5600pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20* 6800pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.50±0.30* 8200pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.50±0.30* 10000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.50±0.30* 12000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.80±0.30* 15000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 2.80±0.30* 18000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 2.80±0.30* 22000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 27000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 33000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 39000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 47000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 563 56000pF 683 68000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 823 82000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 104 100000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 124 120000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 154 150000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 184 180000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 224 220000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 274 270000pF 334 330000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 394 390000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 474 470000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 564 560000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 684 680000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 824 820000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 105 1000000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 125 1200000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 Note: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. *Provided with surface coating. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 17 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC (2220) SIZE (INCHES) 2220 185 225 275 335 395 475 565 685 825 106 126 156 186 226 VDCW (MAX) 155 25V 50V 100V 200V 250V 400V 1500000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 1800000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 500V 630V 563 683 823 104 154 224 274 334 394 474 684 824 105 155 225 335 475 473 2000V 3000V 4000V 2700000pF 2.00±0.20 2.00±0.20 2.00±0.20 3900000pF 2.00±0.20 2.00±0.20 2.00±0.20 4700000pF 2.00±0.20 2.00±0.20 2.00±0.20 5600000pF 2.00±0.20 2.00±0.20 2.00±0.20 680000pF 2.00±0.20 2.00±0.20 2.00±0.20 8200000pF 2.50±0.30 2.50±0.30 2.50±0.30 10000000pF 2.50±0.30 2.50±0.30 2.50±0.30 12000000pF 2.80±0.30 2.80±0.30 15000000pF 2.80±0.30 2.80±0.30 18000000pF 2.80±0.30 2.80±0.30 22000000pF 2.80±0.30 2.80±0.30 0402 VDCW (MAX) 333 1500V 3300000pF 2.00±0.20 2.00±0.20 2.00±0.20 SIZE (INCHES) 393 1000V 2200000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 X5R DIELECTRIC (0402, 0603, 0805) 273 Values that are typically available. (Thickness in mm). 6.3V 10V Values that are typically available. (Thickness in mm). 0603 16V 25V 0.027μF 0.50±0.20 0.033μF 0.50±0.20 0.039μF 0.50±0.20 0.047μF 0.50±0.20 0.056μF 0.50±0.20 0.50±0.20 0.068μF 0.50±0.20 0.50±0.20 6.3V 10V 16V 0805 25V 50V 6.3V 10V 16V 25V 50V 0.082μF 0.50±0.20 0.50±0.20 0.50±0.20 0.10μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.15μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.22μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.30 0.80±0.30 0.27μF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.33μF 0.50±0.20 0.50±0.20 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.39μF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.47μF 0.50±0.20 0.50±0.20 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.68μF 0.50±0.20 0.50±0.20 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 0.82μF 0.80±0.30 0.80±0.30 0.80±0.30 1.0μF 0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30 1.5μF 0.80±0.30 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 2.2μF 0.80±0.30 0.80±0.30 0.80±0.30 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 3.3μF 0.80±0.30 1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30 4.7μF 0.80±0.30 1.25±0.30 1.25±0.30 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 18 FTC SERIES FLEX TERMINATION CAPACITORS VOLTAGE AND CAPACITANCE RANGE X5R DIELECTRIC (1206, 1210) SIZE (INCHES) 1206 274 334 394 474 684 824 105 155 225 335 475 685 106 VDCW (MAX) 224 6.3V 10V 16V 1210 25V 50V 6.3V 10V 16V 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 0.27μF 0.39μF 0.47μF 0.68μF 0.82μF 1.0μF 1.5μF 1.15±0.15 1.15±0.15 2.2μF 1.15±0.15 1.15±0.15 1.60±0.60 3.3μF 1.60±0.60 1.60±0.60 1.60±0.60 1.60±0.60 1.60±0.60 1.60±0.60 1.60±0.60 4.7μF 1.60±0.60 1.60±0.60 6.8μF 1.60±0.60 1.60±0.60 10μF 1.60±0.60 1.60±0.60 2.00±0.20 473 683 104 154 224 334 474 684 105 225 475 333 6.3V 2.00±0.20 Values that are typically available. (Thickness in mm). 0402 VDCW (MAX) 153 50V 0.33μF SIZE (INCHES) 223 25V 0.22μF Y5V DIELECTRIC (0402, 0603) 103 Values that are typically available. (Thickness in mm). 0603 10V 16V 25V 50V 10V 16V 25V 50V 0.010μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.015μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.022μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.033μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.047μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.068μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.10μF 0.50±0.20 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.15μF 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.80±0.07 0.22μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.33μF 0.50±0.20 0.50±0.20 0.80±0.07 0.80±0.07 0.80±0.07 0.47μF 0.80±0.07 0.80±0.07 0.68μF 0.80±0.07 0.80±0.30 1.0μF 0.80±0.07 0.80±0.30 2.2μF 0.80±0.07 4.7μF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 19 FTC SERIES FLEX TERMINATION CAPACITORS RELIABILITY TEST CONDITIONS & REQUIREMENTS ITEM 1. Visual and Mechanical 2. Capacitance 3. Q/ D.F. (Dissipation Factor) TEST CONDITION REQUIREMENTS * No remarkable defect. * Dimensions to conform to individual specification sheet. Class I: (NP0) C≤1000pF, 1.0±0.2Vrms, 1MHz±10% C>1000pF, 1.0±0.2Vrms, 1KHz±10% Class II: (X7R, X6S, X5R,X7S,Y5V) C≤10μF, 1.0±0.2Vrms, 1KHz±10% ** C>10µF, 0.5±0.2Vrms, 120Hz±20% ** Test condition: 0.5±0.2Vrms, 1KHz±10% X7R: 0805=106(6.3V), 0603/475(6.3V) * Shall not exceed the limits given in the detailed spec. NP0: Cap30pF, Q1000; Cap0.1µF;0603≥0.068µF;1206>1µF;1210≥2.2µF ≤10% 0805>0.22µF;1210≥3.3µF ≤3% 0201(50V);0603≥0.047µF;0805≥0.18µF;1206≥0.47µF ≤5% 0201≥0.01uF;1210≥4.7µF ≤10% 0402≥0.012µF;0603>0.1µF;0805≥1µF;1206≥2.2µF; 1210≥10µF ≤10% 0603≥1µF;0805≥2.2µF;1206≥2.2µF;1210≥10µF ≤5% 0201≥0.01µF;0805≥1µF;1210≥10µF ≤7% 0603≥0.33µF ≤10% 0201≥0.1µF;0402≥0.10µF&(0402/X7R≥0.056µF) 0603≥0.47µF;0805≥2.2µF;1206≥4.7µF;1210≥22µF ≤12.5% 16V 10V ≤5% 0201≥0.01µF;0402≥0.033µF;0603≥0.15µF; 0805≥0.68µF;1206≥2.2µF;1210≥4.7µF ≤10% 0201≥0.1uF(0201/X7R≥0.022µF);0402≥0.22uF 0603≥0.68µF;0805≥2.2µF;1206≥4.7µF;1210≥22µF ≤10% 0201≥0.012µF;0402≥0.33µF(0402/X7R≥0.22µF) 0603≥0.33µF;0805≥2.2µF;1206≥2.2µF;1210≥22µF;01R5 ≤15% 0201≥0.1µF; 0402≥1µF ≤15% 0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603≥10µF; 0805≥4.7µF;1206≥47µF;1210≥100µF ≤20% 0402≥2.2µF ≤3.5% ≤5% 6.3V ≤10% 4V ≤15% 0402≥0.47µF - _ X7R,X5R,X6S,X7S: Rated vol. D.F.≤ ≥50V ≤5% 35V ≤7% 25V ≤5% 16V (C0.01µF;06031µF;08051µF;12064 .7µF;12104.7µF 35V:0805≥2.2µF;1206≥2.2µF;1210≥10µF 25V:0402≥1µF;0603≥2.2µF;0805≥2.2µF; 1206≥10µF; 1210≥10µF 10Gor 100Ω-F whichever is smaller. 16V: 0201≥0.1µF,0402≥0.22µF;0603≥1µF; 0805≥2.2µF;1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF; 0805≥2.2µF;1206≥4.7µF;1210≥47µF 6.3V ; 4V ; Size≥1812 RATED VOLTAGE INSULATION RESISTANCE All X6S items, All X7S items 100V: 1210≥3.3µF 50V: 0402≥0.1µF; 0603≥2.2µF; 0805≥10µF;1206≥10µF 35V: 0603≥1µF; 25V: 0201≥0.1µF; 0402≥2.2µF;0603≥10µF; 0805≥10µF;1206≥22µF ≥50Ω-F. 16V: 0603≥10µF; 0402≥1µF; 0201≥0.22µF 10V: 0201>0.1µF; 0402≥1µF; 0603≥10µF; 0805≥47µF 6.3V: 0201≥0.1µF; 0603>4.7µF; 0805≥47µF;1206≥10µF 4V:0603≥22µF; 0805≥47µF; 1206≥100µF Rated voltage: 200~630V To apply rated voltage (500V max.) for 60 sec. Rated voltage: >630V To apply 500V for 60 sec. 10GΩ or 100Ω-F whichever is smaller Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 21 FTC SERIES FLEX TERMINATION CAPACITORS RELIABILITY TEST CONDITIONS & REQUIREMENTS ITEM 6. TEST CONDITION Temperature Coefficient REQUIREMENTS With no electrical load. T.C. Operating Temperature T.C. Capacitance Change NP0 -55~125°C at 25°C NP0 Within ±30ppm/°C X7R -55~125°C at 25°C X7R Within ±15% X7S -55~125°C at 25°C X7S Within ±22% X5R -55~85°C at 25°C X5R Within ±15% X6S -55~105°C at 25°C X6S Within ±22% Y5V -55~85°C at 25°C Y5V Within +30%/-80% *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24± 2 hrs at room temp. * Measurement voltage for Class II: 01005 0201 Cap≤0.01µF: 0.5V Cap0.01µF: 0.2V 0.1µF*≤Cap0.22µF;1210≥3.3µF ≤6% 0201(50V);0603≥0.047µF; 0805≥0.18µF; 1206≥0.47µF ≤10% 0201≥0.01uF;1210≥4.7µF ≤20% 0402≥0.012µF; 0603>0.1µF; 0805≥1µF; 1206≥2.2µF; 1210≥10µF ≤20% 0603≥1µF;0805 2.2F;1206≥2.2µF;1210≥10µF ≤10% 0201≥0.01µF;0805≥1µF; 1210≥10µF ≤14% 0603≥0.33µF ≤15% 0201≥0.1µF;0402≥0.10µF&(0402/ X7R≥0.056µF);0603≥0.47µF; 0805≥2.2µF;1206≥4.7µF;1210≥22µF ≤20% 0402µ0.47µF ≤10% 0603≥0.15µF;0805≥0.68µF;1206≥2.2µF;1210≥4.7µF ≤15% 0201≥0.01µF(0201/X7R≥0.022µF);0402≥0.033µF; 0603≥0.68µF;0805≥2.2µF;1206≥4.7µF; 1210≥22µF ≤15% 0201≥0.012µF; 0402≥0.33µF(0402/X7R≥0.22µF); 0603≥0.33µF;0805≥2.2µF;1206≥2.2µF; 1210≥22µF ≤20% 0201≥0.1µF ;0402≥1µF; 01R5 0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603V10µF; 0805≥4.7µF;1206≥47µF;1210≥100µF 6.3V ≤15% ≤30% 4V ≤20% - RATED VOL. D.F.≤ ≥50V ≤7.5% 35V ≤10% - Y5V: 25V ≤7.5% EXCEPTION OF D.F.≤ ≤10% 0603≥0.1µF; 0805≥0.47µF;1206≥4.7µF ≤20% 1210≥6.8µF - - ≤10% 0402≥0.047µF;0603≥0.1µF; 0805≥0.33µF;1206≥1µF; 1210≥4.7µF ≤15% 0402≥0.068µF;0603≥0.47µF;1206≥4.7µF; 1210≥22µF ≤12.5% 0402≥0.068µF; 0603≥0.68µF ≤20% 0402≥0.22µF 16V (C0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;12 10≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≥2.2µF;1210≥10µF 25V:0201≥0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 1GΩ OR 100Ω-F Whichever is smaller 16V: 0201≥0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2. 2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size1812 14. Humidity (Damp Heat) Load * Test temp.: 40±2°C * No remarkable damage. * Humidity: 90~95%RH Cap change: * Test time: 500+24/-0 hrs. NP0: ±7.5% or 0.75pF whichever is larger. *T  o apply voltage: Rated voltage (MAX. 500V) X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≤6.3V within ±25%; C≥1uF,within ±25% *B  efore initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. **10V: 0603≥4.7µF;0402≥1µF;0201≥0.1µF, within ±25%; *C  ap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. NP0: C≥30pF,Q≥200;C0.1µF, 0603≥0.068µF, 1206>1µF;1210≥2.2µF ≤20% 0805>0.22µF;1210≥3.3µF ≤6% 0201(50V);0603≥0.047µF; 0805≥0.18µF; 1206≥0.47µF ≤10% 0201≥0.01uF;1210≥4.7µF ≤20% 0402≥0.012µF; 0603>0.1µF; 0805≥1µF; 1206≥2.2µF; 1210≥10µF ≤20% 0603≥1µF;08052.2F;1206≥2.2µF;1210≥10µF ≤10% 0201≥0.01µF;0805≥1µF; 1210≥10µF ≤14% 0603≥0.33µF ≤15% 0201≥0.1µF;0402≥0.10µF&(0402/X7R≥0.056µF); 0603≥0.47µF; 0805≥2.2µF;1206≥4.7µF;1210≥22µF ≤20% 0402≥0.47µF ≤10% 0603≥0.15µF;0805≥0.68µF;1206≥2.2µF;1210≥4.7µF ≤15% 0201≥0.01µF(0201/X7R≥0.022µF);0402≥0.033µF; 0603≥0.68µF;0805≥2.2µF;1206≥4.7µF; 1210≥22µF ≤15% 0201≥0.012µF; 0402≥0.33µF(0402/X7R≥0.22µF); 0603≥0.33µF;0805≥2.2µF;1206≥2.2µF; 1210≥22µF ≤20% 0201≥0.1µF ;0402≥1µF; 01R5 0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603≥10µF; 0805≥4.7µF;1206≥47µF;1210≥100µF 6.3V ≤15% ≤30% 4V ≤20% - - Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 25 FTC SERIES FLEX TERMINATION CAPACITORS RELIABILITY TEST CONDITIONS & REQUIREMENTS ITEM 14. TEST CONDITION Humidity (Damp * Test temp.: 40±2°C Heat) Load * Humidity: 90~95%RH (continued) * Test time: 500+24/-0 hrs. REQUIREMENTS Y5V: *T  o apply voltage: Rated voltage (MAX. 500V) *B  efore initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. RATED VOL. D.F.≤ ≥50V ≤7.5% 35V ≤10% 25V ≤7.5% *C  ap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. EXCEPTION OF D.F.≤ ≤10% 0603≥0.1µF; 0805≥0.47µF;1206≥4.7µF ≤20% 1210≥6.8µF - - ≤10% 0402≥0.047µF;0603≥0.1µF; 0805≥0.33µF;1206≥1µF; 1210≥4.7µF ≤15% 0402≥0.068µF;0603≥0.47µF; 1206≥4.7µF; 1210≥22µF ≤12.5% 0402≥0.068µF; 0603≥0.68µF ≤20% 0402≥0.22µF 16V (C0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;12 10≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≥2.2µF;1210≥10µF 25V:0201≥0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 500MΩ or 100Ω-F Whichever is smaller 16V: 0201≥0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2. 2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size≥1812 Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 26 FTC SERIES FLEX TERMINATION CAPACITORS RELIABILITY TEST CONDITIONS & REQUIREMENTS ITEM 15. High Temperature Load (Endurance) TEST CONDITION REQUIREMENTS *T  est temp.: NP0, X7R/X7S: 125±3°C X6S: 105±3°C X5R, Y5V: 85±3°C * No remarkable damage. * Test time: 1000+24/-0 hrs. X7R, X5R, X6S, X7S: 10V**,within ±12.5%; ≤6.3V within ±25%; *T  o apply voltage: (1) ≤6.3V or C≥10µF: 150% of rated voltage. (2) 10V~250V: 200% of rated voltage. (3) 400V~450V: 120% of rated voltage. (4) 500V: 150% of rated voltage. (5) 630V~3000V: 120% of rated voltage. (6) 4000V: 110% of rated voltage (7) 100% of rated voltage for below range. **For life test items, using 1.0x working or rated voltage, must follow de-rating guidelines. Cap change: NP0: ±3.0% or ±0.3pF whichever is larger C≥1uF,within ±25% **10V: 0603≥4.7µF;0402≥1µF;0201≥0.1µF, within ±25%; Y5V: 10V, within ±30%; ≤6.3V, within +30/-40% Q/D.F. value: NP0: More than 30pF, Q350 10pFC0.1µF,0603≥0.068µF,1206>1µF;1210≥2.2µF ≤20% 0805>0.22µF;1210≥3.3µF ≤6% 0201(50V);0603≥0.047µF; 0805≥0.18µF; 1206≥0.47µF ≤10% 0201≥0.01uF;1210≥4.7µF ≤20% 0402≥0.012µF; 0603>0.1µF; 0805≥1µF; 1206≥2.2µF; 1210≥10µF; ≤20% 0603≥1µF;08052.2F;1206≥2.2µF;1210≥10µF ≤10% 0201≥0.01µF;0805≥1µF; 1210≥10µF ≤14% 0603≥0.33µF ≤15% 0201≥0.1µF;0402≥0.10µF&(0402/X7R≥0.056µF); 0603≥0.47µF;0805≥2.2µF;1206≥4.7µF;1210≥22µF ≤20% 402≥0.47µF ≤10% 0603≥0.15µF;0805≥0.68µF;1206≥2.2µF;1210≥4.7µF ≤15% 0201≥0.01µF(0201/X7R≥0.022µF);0402≥0.033µF; 0603≥0.68µF;0805≥2.2µF;1206≥4.7µF; 1210≥22µF; ≤15% 0201≥0.012µF; 0402≥0.33µF(0402/X7R≥0.22µF); 0603≥0.33µF;0805≥2.2µF;1206≥2.2µF; 1210≥22µF ≤20% 0201≥0.1µF ;0402≥1µF; 01R5 0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603≥10µF; 0805≥4.7µF;1206≥47µF;1210≥100µF 6.3V ≤15% ≤30% 4V ≤20% - - Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 27 FTC SERIES FLEX TERMINATION CAPACITORS RELIABILITY TEST CONDITIONS & REQUIREMENTS ITEM 15. TEST CONDITION High Temperature Load (Endurance) (continued) REQUIREMENTS *T  est temp.: NP0, X7R/X7S: 125±3°C X6S: 105±3°C X5R, Y5V: 85±3°C Y5V: RATED VOL. D.F.≤ ≥50V ≤7.5% 35V ≤10% * Test time: 1000+24/-0 hrs. *T  o apply voltage: (8)150% of rated voltage for below range. Size Dielectric 0201 0402 0603 Rated voltage Capacitance range X5R/X6S 16V,25V C=0.1µF X7R 16V C≥0.022µF X7R/X5R/ X6S 50V C>0.1µF 10~25V C≥0.22µF Y5V 16V C≥0.47µF ≤10% 0603≥0.1µF; 0805≥0.47µF;1206≥4.7µF ≤20% 1210≥6.8µF - 0402≥0.047µF;0603≥0.1µF; 0805≥0.33µF;1206≥1µF; 1210≥4.7µF ≤15% 0402≥0.068µF;0603≥0.47µF; 1206≥4.7µF; 1210≥22µF ≤12.5% 0402≥0.068µF; 0603≥0.68µF ≤20% 0402≥0.22µF ≤7.5% 16V (C0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;12 10≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≥2.2µF;1210≥10µF 25V:0201≥0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 1GΩ or 50Ω-F Whichever is smaller 16V: 0201≥0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2. 2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size≥1812 *B  efore initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. *C  ap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. Ratio [Operating Voltage / Rated Voltage (%)] ** De-rating conditions: 120 100 80 60 40 20 0 0 25 50 75 100 125 Temperature at Product (˚C) Product for 125˚C Product for 105˚C Product for 85˚C Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 04/2021-A 28 FTC SERIES FLEX TERMINATION CAPACITORS TAPE AND REEL SPECIFICATIONS T P0 P0 T E D0 E A0 P2 P2 D0 F F W 5˚ B0 W B0 D1 5˚ P1 A0 K0 P1 PAPER TAPE DIMENSIONS SIZE 0402 0603 0805 Thickness 0.80±0.07 0.50±0.20 (mm) 0.80±0.30 PLASTIC TAPE DIMENSIONS 1206 1210 1.25±0.30 1.15±0.15 1.60±0.20 1.60±0.50 1808 1812 2220 0.95±0.10 1.25±0.10 1.25±0.10 1.25±0.10 2.50±0.50 1.60±0.20 1.60±0.20 2.50±0.50 1.60±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1.40±0.15 1.60±0.20 2.00±0.20 2.50±0.50 A0 0.70±0.20 1.05±0.30
FTC1210X7R631-473KNE 价格&库存
很抱歉,暂时无法提供与“FTC1210X7R631-473KNE”相匹配的价格&库存,您可以联系我们找货
