76HPSB06GWRT
76HPSB06GWRT
    GRAYHILLINC.
    插件
    开关 DIP 琴键式 STYLE 6位 30伏
76HPSB06GWRT 数据手册
Surface Mount DIP Switches SERIES 76HP Side Actuated PIANO-DIP ® FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Easily Accessed when PC Boards are Racked • Reliable Spring and Ball Contact DIP Switches DIMENSIONS In inches (and millimeters) LENGTH ± .010 (0,25 SEE ORDER INFO .380 ± .010 (9,65 ± 0,25) Recommended PC Pad Dimensions` .305 ± .010 (7,75 ± 0,25) .100 ± .005 (2,54 ± 0,13) TYP. .023 .055 ± .010 (5,84) (1,40 ± 0,25) REF. .025 (0,64) R. .303 ± .015 (7,70 ± 0,38) .424 ± .015 (10,77 ± 0,38) TYP. .530 (13,46) TYP. .280 (7,11) TYP. CC LL .012 ± .001 (0,30 ± 0,03) TYP. .070 (1,78) TYP. .100 (2,54) TYP. CC LL CIRCUITRY As viewed from the top of the switch in the positions shown in the drawing. Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) Thermal Shock Resistance: Per specification; no failures; passes contact resistance Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures SPECIFICATIONS Electrical Ratings Make-and-break Current Rating: 2 ,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: I nitial: 30 mohms maximum; After Life: 100 mohms maximum (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms Dielectric Strength: Minimum voltage (AC RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Carry Rating: 5 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1 megahertz Environmental Ratings Meets all requirements of MIL- S-83504. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: P er MIL-STD-202, Method 106 over nickel barrier. Base Contacts: Copper alloy, gold-plated, over nickel barrier. Terminals: Copper alloy, matte tin plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) Tape Seal: Not available with Tape Seal. TAPE AND REEL PACKAGING Meets requirements of EIA 481-2 or EIA 481-3 13 INCH DIAMETER REEL Soldering Information Solderability: Per MIL-STD-202, Method 208 Tested to EIA Standard RS-448-2. Resistance to Soldering Heat: Per MIL-S83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed with all actuators in the closed (on) position as shipped. CONDUCTIVE PLASTIC EMBOSSED TAPE DIRECTION OF FEED 16mm 76HPSB 08GW XXXX OPEN 76HPSB 08GW XXXX OPEN 76HPSB 08GW XXXX OPEN 16 & 24mm TAPE Mechanical Ratings Mechanical Life: 2,000 operations per switch position Vibration Resistance: Per Method 204, Test Materials and Finishes Shorting Member: B rass, gold-plated 76HPSB08GW 76HPSB08GW 76HPSB08GW OPEN OPEN OPEN ORDERING INFORMATION: Tape and Reel Packaging No. of Positions* 2 4 6 8 10 Length (inches) 0.280" 0.480" 0.680" 0.880" 1.080" Length (metric) 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm Carrier Width Dim. A 24 mm 24 mm 32 mm 44 mm 44 mm (500 switches per reel) Part Number 76HPSB02GWRT 76HPSB04GWRT 76HPSB06GWRT 76HPSB08GWRT 76HPSB10GWRT 16mm PIN ONE LOCATION COVER TAPE DIM. A (SEE ORDER INFO.) * For other lengths, contact Grayhill, Inc. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com XXXX XXXX XXXX 32, 44 & 56mm TAPE DIP 8
76HPSB06GWRT 价格&库存
很抱歉,暂时无法提供与“76HPSB06GWRT”相匹配的价格&库存,您可以联系我们找货
76HPSB06GWRT
  • 1+70.538971+9.10519
  • 10+58.6265310+7.56753
  • 25+54.3019225+7.00931
  • 100+48.49238100+6.25941
  • 250+45.19627250+5.83395
库存:726
76HPSB06GWRT
  • 500+42.99585500+5.54992
  • 1000+41.041041000+5.29759
  • 1500+40.006511500+5.16405
库存:726
76HPSB06GWRT
    • 1+52.35840
    • 200+20.89800
    • 500+20.19600
    • 1000+19.85040
