MA0805CG103J500
MA0805CG103J500
    MERITEK
    贴片电容(MLCC) 0805 10nF ±5% 50V C0G (NP0)
MA0805CG103J500 数据手册
Multilayer Ceramic Chip Capacitors Voltage ≤ 50VDC MA Series FEATURE  A wide selection of sized is available (0201 to 2225)  High capacitance in given case size  Capacitor with lead-free termination (pure Tin)  RoHS and HALOGEN compliant.  Application: DC to DC converter. General digital circuit. Power supply bypass capacitors. Consumer electronics. telecommunication PART NUMBERING SYSTEM MA 1812 XR 102 C 250 (1) (2) (3) No (4) Item (1) Meritek Series (2) Size (3) Dielectric (4) Capacitance (5) Tolerance (6) Code Description Series Reference Multilayer Ceramic Chip Capacitors Low voltage type, ≤ 50Vdc 1812 inch (4532 mm) See dimension table for available size below XR XR: X7R CG: C0G(NP0), XF: X5R, YV: Y5V 102 102: 10x102pF = 1000pF 103: 10x103pF, 4R7: 4.7pF C: ±0.50 pF See capacitor tolerance ref. table below MA 1812 C Rated Voltage (6) (5) 250 0 4R0: 4VDC, 6R3:6.3VDC, 500:50VDC 250: 25x10 VDC=25VDC DIMENSIONS Thickness Size Inch (mm) L (mm) W (mm) 0201 (0603) 0.60±0.05 0.30±0.05 0.15±0.05 0402 (1005) 1.00+0.15/-1.0 0.50+0.15/-1.0 0.25+0.05/-0.10 0603 (1608) 1.60±0.20 0.80±0.15 0.40±0.15 0805 (2012) 2.10±0.20 1.25±0.20 1206 (3216) 3.30±0.30 1.60+0.30/-0.10 1210 (3225) 3.30±0.40 2.50±0.30 1808 (4520) 4.60±0.50 2.00±0.20 1812 (4532) 4.60±0.50 3.20±0.30 1825 (4563) 4.60±0.50 6.30±0.40 0.75±0.35 2220 (5750) 5.70±0.50 5.00±0.40 0.85±0.35 2225 (5763) 5.70±0.50 6.30±0.40 0.85±0.35 T (mm) code See Thickness Specification Reference Table below MB min (mm) 0.50±0.20 0.60±0.20 0.75±0.35 0.75±0.35 0.75±0.35 CAPACITANCE TOLERANCE REFERENCE Code Description Code Description Code Description A ±0.05 pF G B ±0.10 pF H C ±0.25 pF I D ±0.50 pF J F ±1 % K ±2 % L 0%~10% Z -20%~80% ±3 % M ±20 % X +10% ~ +20% -10%~0% N -5%~10% - - ±5 % P ±0.02 pF - - ±10 % Q ±0.03 pF - - Meritek Electronics Corporation | www.meritekusa.com Code Description Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors MA Series Voltage ≤ 50VDC THICKNESS SPECIFICATION REFERENCE Code Thickness (mm) Code Thickness (mm) Code Thickness (mm) A 0.60 ± 0.10 I 1.25 ± 0.20 Q 0.50 + 0.02/-0.05 B 0.8 + 0.15/-0.10 J 1.15 ± 0.15 R 3.10 ± 0.30 C 1.25 ± 0.10 K 0.50 ± 0.20 S 0.80 ± 0.07 D 1.40 ± 0.15 L 0.30 ± 0.03 T 0.85 ± 0.10 E 1.60 ± 0.20 M 0.95 ± 0.10 U 0.50 ± 0.10 F 2.00 ± 0.20 N 0.50 ± 0.05 V 0.20 ± 0.02 G 2.50 ± 0.30 O 3.50 ± 0.20 X 0.80 ± 0.10 H 2.80 ± 0.30 P 1.60 +0.3/-0.10 Z 0.25 ± 0.03 ELECTRICAL CHARACTERISTICS Properties Characteristics Dielectric C0G(NP0) X7R X5R Y5V Chip Size 0201, 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 0201, 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 0201, 0402, 0603 0402, 0603, 0805, 1206, 1210, 1812 10V,16V, 25V, 50V 6.3V, 10V, 16V, 25V, 50V 4V, 6.3V, 10V, 16V, 25V, 50V 6.3V, 10V, 16V, 25V, 50V 0.1pF ~ 390nF 100pF ~ 820nF 100pF ~ 820nF 10nF ~ 680nF Rated Voltage Capacitance Range Capacitance Tolerance Dissipation Factor Insulation Resistance See Capacitance Tolerance Reference Table Above Cap1000pF, 25°C at ambient temperature 3. X7R: Apply 1.0±0.2Vrms, 1.0kHz±10%, at 25°C ambient temperature. 4. Y5V: Apply 1.0±0.2Vrms, 1.0kHz±10%, at 20°C ambient temperature. Meritek Electronics Corporation | www.meritekusa.com Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors MA Series Voltage ≤ 50VDC CAPACITANCE RANGE - C0G (NP0) Dielectric (0201~1206) Dimension Cap(pF) code 0.1 0R1 0.2 0R2 0.3 0R3 0.4 0R4 0.5 0R5 1 1R0 1.2 1R2 1.5 1R5 1.8 1R8 2.2 2R2 2.7 2R7 3.3 3R3 3.9 3R9 4.7 4R7 5.6 5R6 6.8 6R8 8.2 8R2 10 100 12 120 15 150 18 180 22 220 27 270 33 330 39 390 47 470 56 560 68 680 82 820 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1000 102 1200 122 1500 152 1800 182 2200 222 2700 272 3300 332 3900 392 4700 472 5600 562 6800 682 8200 822 10000 103 12000 123 15000 153 18000 183 22000 223 27000 273 33000 333 39000 393 47000 473 56000 563 68000 683 82000 823 100000 104 10V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 0201 25V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 50V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 10V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 0402 16V 25V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 50V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 10V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B Meritek Electronics Corporation | www.meritekusa.com 0603 16V 25V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B 50V 10V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T T C C 0805 16V 25V A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T T C C A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T T C C 50V A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T T C C 10V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M C C T T T T T T J J J E E E 1206 16V 25V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M C C T T T T T T J J J E E E X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M C C T T T T T T J J J E E E 50V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M C C T T T T T T J J J E E E Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors MA Series Voltage ≤ 50VDC CAPACITANCE RANGE - C0G (NP0) Dielectric (1210~2225) Dimension Cap(pF) code 2.2 2R2 2.7 2R7 3.3 3R3 3.9 3R9 4.7 4R7 5.6 5R6 6.8 6R8 8.2 8R2 10 100 12 120 15 150 18 180 22 22 27 27 33 33 39 39 47 47 56 56 68 68 82 82 100 100 120 120 150 150 180 180 220 220 270 270 330 330 390 390 470 470 560 560 680 681 820 821 1000 102 1200 122 1500 152 1800 182 2200 222 2700 272 3300 332 3900 392 4700 472 5600 562 6800 682 8200 822 10000 103 12000 123 15000 153 18000 183 22000 223 27000 273 33000 333 39000 393 47000 473 56000 563 68000 683 82000 823 100000 104 120000 124 150000 154 180000 184 220000 224 270000 274 1210 10V 16V 25V 50V M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C C M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C C M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C C M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C C E E E E E F F G G G G 1808 50V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F F Meritek Electronics Corporation | www.meritekusa.com 1812 10V 16V 25V 50V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C F F G G G G 1825 50V 2220 50V 2225 50V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F G G E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F G G G G G E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors MA Series Voltage ≤ 50VDC CAPACITANCE RANGE - X7R Dielectric (0201~1206) Dimension 0201 0402 0603 0805 1206 Cap(pF) Code 10V 16V 25V 50V 10V 16V 25V 50V 10V 16V 25V 50V 10V 16V 25V 50V 100 101 L L L L N N N N S S S S X X X X 120 121 L L L L N N N N S S S S X X X X 150 151 L L L L N N N N S S S S X X X X X X X X 180 181 L L L L N N N N S S S S X X X X X X X X 220 221 L L L L N N N N S S S S X X X X X X X X 270 271 L L L L N N N N S S S S X X X X X X X X 330 331 L L L L N N N N S S S S X X X X X X X X 390 391 L L L L N N N N S S S S X X X X X X X X 470 471 L L L L N N N N S S S S X X X X X X X X 560 561 L L L L N N N N S S S S X X X X X X X X 680 681 L L L L N N N N S S S S X X X X X X X X 820 821 L L L L N N N N S S S S X X X X X X X X 1000 102 L L L L N N N N S S S S X X X X X X X X 1200 122 L L L N N N N S S S S X X X X X X X X 1500 152 L L L N N N N S S S S X X X X X X X X 1800 182 L L N N N N S S S S X X X X X X X X 2200 222 L L N N N N S S S S X X X X X X X X 2700 272 L L N N N N S S S S X X X X X X X X 3300 332 L L N N N N S S S S X X X X X X X X 3900 392 L L N N N N S S S S X X X X X X X X 4700 472 L L N N N N S S S S X X X X X X X X 5600 562 L N N N N S S S S X X X X X X X X 6800 682 L N N N N S S S S X X X X X X X X 8200 822 L N N N N S S S S X X X X X X X X 10000 103 L N N N N S S S S X X X X X X X X 12000 123 N N N S S S S X X X X X X X X 15000 153 N N N S S S S X X X X X X X X 18000 183 N N N S S S S X X X X X X X X 22000 223 N N N S S S S X X X X X X X X 27000 273 N N N S S S S X X X X X X X X 33000 333 N N N S S S B X X X X X X X X 39000 393 N N N S S S B X X X X X X X X 47000 473 N N N N S S S B X X X X X X X X 56000 563 N N N N S S S B X X X X X X X X 68000 683 N N N S S S B X X X X X X X X 82000 823 N N S S S B X X X X X X X X 100000 104 N N S S S B X X X X X X X X 120000 124 S S B X X X C X X X X 150000 154 S S B C C C C M M M M 180000 184 S S B C C C C M M M M 220000 224 S S B C C C C M M M M 270000 274 B B B C C C I M M M C 330000 334 B B B C C C I M M M C 390000 394 B B B C C C I M M J P 470000 474 B B B C C C I J J J P 560000 564 B B C C C J J J P 680000 684 B B C C C J J J P 820000 824 B B C C C J J J P L L N N N N N N N N Meritek Electronics Corporation | www.meritekusa.com B B 10V 16V 25V 50V X X Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors Voltage ≤ 50VDC MA Series CAPACITANCE RANGE - X7R Dielectric (1210~2225) Dimension 1210 1825 2220 2225 50V 50V 50V C F F F C F F F C C F F F C C C F F F C C C C F F F C C C C C F F F M C C C C C F F F M M C C C C C F F F M M M C C C C C F F F M M M M E C C C C F F F 682 M M M M E C C C C F F F 8200 822 M M M M E C C C C F F F 10000 103 M M M M E C C C C F F F 12000 123 M M M M E C C C C F F F 15000 153 M M M M E C C C C F F F 18000 183 M M M M E C C C C F F F 22000 223 M M M M E C C C C F F F 27000 273 M M M M E C C C C F F F 33000 333 M M M M E C C C C F F F 39000 393 M M M M E C C C C F F F 47000 473 M M M M E C C C C F F F 56000 563 M M M M E C C C C F F F 68000 683 M M M M E C C C C F F F 82000 823 M M M M E C C C C F F F 100000 104 M M M M E C C C C F F F 120000 124 M M M M E C C C C F F F 150000 154 M M M M E C C C C F F F 180000 184 M M M M E C C C C F F F 220000 224 M M M M E C C C C F F F 270000 274 M M M M F C C C C F F F 330000 334 M M M C F C C C C F F F 390000 394 M M M C F C C C C F F F 470000 474 M M M C F C C C C F F F 560000 564 C C C C F C C C C F F F 680000 684 C C C C F C C C F F F F 820000 824 C C C C F C C C F F F F 10V 16V 1808 25V 50V 50V 1812 Cap(pF) Code 10V 16V 25V 50V 100 101 120 121 150 151 180 181 220 221 M C 270 271 M C C 330 331 M C C 390 391 M C C 470 471 M C C 560 561 M C C 680 681 M C C 820 821 M C 1000 102 M M M M C C C C 1200 122 M M M M C C C C 1500 152 M M M M C C C 1800 182 M M M M C C 2200 222 M M M M C 2700 272 M M M M 3300 332 M M M 3900 392 M M 4700 472 M 5600 562 6800 C C Meritek Electronics Corporation | www.meritekusa.com C Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors MA Series Voltage ≤ 50VDC CAPACITANCE RANGE - X5R Dielectric (0201~0603) Dimension 0201 Cap (nF) Code 0.10 6.3V 10V 0402 16V 25V 50V 101 L L L 0.12 121 L L L 0.15 151 L L L 0.18 181 L L L 0.22 221 L L L 0.27 271 L L L 0.33 331 L L L 0.47 471 L L L 0.56 561 L L L 0.68 681 L L L 0.82 821 L L L 1.0 102 L L L L 1.5 152 L L 2.2 222 L L 3.3 332 L L 4.7 472 L L 6.8 682 L 10 103 L L 27 273 L L N 33 333 L L N 39 393 L L N 47 473 L L 56 563 L L N N 68 683 L L N N 82 823 L L N N N 100 104 L L N N 150 154 N N 220 224 N N 270 274 330 334 390 394 470 474 680 684 820 824 L L 6.3V 10V 0603 16V 25V 50V N N N N N N N 6.3V 10V 16V 25V 50V B L N L L L S N B B B B B B B B B B B B B B B B B B B B B B B N N L N N N N N B K K K B CAPACITANCE RANGE - Y5V Dielectric (0402~1812) Dimension 0402 0603 Cap Code 10V 16V 25V 50V 6.3V 10V 16V 25V (nF) 10 103 N N N N S S S 0805 50V 10V 16V 1206 25V 50V 10V 16V 25V 1210 50V 10V 16V 25V 1812 50V 10V 16V 25V 50V S A A A A X X X X 15 153 N N N N S S S S A A A A X X X X 22 223 N N N N S S S S A A A A X X X X 33 333 N N N N S S S S A A A A X X X X 47 473 N N N S S S S A A A A X X X X 68 683 N N N S S S S A A A A X X X X 100 104 N N N S S S S A A A A X X X X M M M M C C C C 150 154 N N S S S S A A A A X X X X M M M M C C C C 220 224 N N S S S S S A A A A X X X X M M M M C C C C 330 334 N N S S S S B X X X X X X X X M M M M C C C C 470 474 N N S S S B B X X X X/C X X X X M M M M C C C C 680 684 N S S B B X X C C X X X X M M M M C C C C Meritek Electronics Corporation | www.meritekusa.com Rev. 7f 02/18/19 Multilayer Ceramic Chip Capacitors Voltage ≤ 50VDC MA Series RELIABILITY TEST CONDITIONS AND REQUIREMENTS Item Visual and Dimensions Capacitance Test Condition --Class I: NP0 Cap≤1000pF 1.0±0.2Vrms, 1MHz±10% Cap>1000pF 1.0±0.2Vrms, 1KHz±10% Class II: X7R,X7E, X5R,Y5V Cap≤10μF, 1.0±0.2Vrms, 1kHz±10% Cap>10μF, 0.5±0.2Vrms, 120Hz±20% Test condition: 0.5±0.2Vrms,1KHz±10% X7R: 0603≧225(10V), 0805=106(6.3V&10V) X5R: 01R5≧103, 0201≧224 (6.3V), 0402≧475 (6.3V), 0402≧225(10V), 0603=106 (6.3V), 0603≧475(10V) Requirements  No remarkable defect.  Dimensions to confirm to individual specification sheet.  Shall not exceed the limits given in the detailed spec.  NP0: Cap≥30pF, Q≥1000; Cap
MA0805CG103J500
物料型号: - 型号遵循特定的编码规则,例如“102 C250 MA 1812 XR”,其中每个部分代表不同的特性,如系列、尺寸、介质类型、电容值、公差和额定电压。
器件简介: - MA系列是多层陶瓷片式电容器,适用于多种电压范围,最高可达50VDC。 - 提供多种尺寸选择,从0201到2225不等。 - 具有高电容值、无铅端子(纯锡)的电容器,符合RoHS和无卤素标准。
引脚分配: - 文档中没有提供具体的引脚分配图,但通常这类电容器是表面贴装的,具有两个端子用于连接电路。
参数特性: - 电容值范围从0.1pF到820nF。 - 电容公差、介质类型(如X7R、X5R、Y5V)、额定电压等参数根据不同的应用需求有不同的选项。
功能详解: - 电容器广泛应用于DC-DC转换器、数字电路、电源旁路电容、消费电子、电信等领域。
应用信息: - 电容器适用于需要高电容值和小型化解决方案的应用场合。
封装信息: - 提供了详细的尺寸信息,包括英寸和毫米两种单位,以及厚度规格代码。
MA0805CG103J500 价格&库存
很抱歉,暂时无法提供与“MA0805CG103J500”相匹配的价格&库存,您可以联系我们找货
