700B151JT300XT
700B151JT300XT
    ATC
    贴片电容(MLCC) 1111 150pF ±5% 300V C0G (NP0)
700B151JT300XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors FEATURES • • • • • • • • • GENERAL DESCRIPTION PACKAGING OPTIONS KYOCERA AVX, the industry leader, is announcing new improved ESR/ESL performance for the 700B Series RF/ Microwave Capacitors. The superior high self-resonance and zero TCC characteristic of this Series provide excellent performance over a broad range of RF and microwave applications requiring minimum drift, including RF power. Porcelain and ceramic construction provide a rugged, hermetic package. Tape & Reel • Impedance Matching • DC Blocking CIRCUIT APPLICATIONS • Timing Power Amplifiers • Filters • Oscillators • RF Power Amplifiers ENVIRONMENTAL CHARACTERISTICS Thermal Shock Mil-STD-202, Method 107, Condition A Moisture Resistance Mil-STD-202, Method 106 Low Voltage Humidity Mil-STD-202, Method 103, condition A, with 1.5 VDC applied while subjected to an environment of 85ºC with 85% relative humidity for 240 hours Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. Voltage applied. 200% of WVDC for capacitors rated at 500 volts DC or less. 120% of WVDC for capacitors rated at 1250 volts DC or less. 100% of WVDC for capacitors rated above 1250 volts DC Termination Styles Available in various surface mount and leaded styles. See Mechanical Configurations Terminal Strength Vertical Orientation Tape & Reel Cap Pac® (100 pcs) ELECTRICAL SPECIFICATIONS FUNCTIONAL APPLICATIONS • Bypass • Coupling • Tuning Case B Size (.110" x .110") Capacitance Range 0.1 pF to 5100 pF Extended WVDC up to 1500 VDC Low ESR/ESL High Q Low Noise Ultra-Stable Performance High Self-Resonance Established Reliability (QPL) Terminations for chips and pellets withstand a pull of 5 lbs. min., 15 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Temperature Coefficient (TCC) 0 ±30 PPM/°C (-55°C to +125°C) Capacitance Range 0.1 pF to 5100 pF Operating Temperature 0.1 to 200 pF: from -55°C to +175°C 220 to 5100 pF: from -55°C to +125°C Quality Factor Greater than 10,000 (1 pF to 200 pF) @ 1 MHz. Greater than 2000 (220 pF to 1000 pF) @ 1 MHz. Greater than 2000 (1100 pF to 5100 pF) @ 1 KHz. Insulation Resistance (IR) 0.1 pF to 470 pF: 106 Megohms min. @ +25°C at rated WVDC. 105 Megohms min. @ +125°C at rated WVDC. 510 pF to 5100 pF: 105 Megohms min. @ +25°C at rated WVDC. 104 Megohms min. @ +125°C at rated WVDC. Working Voltage (WVDC) See Capacitance Values table Dielectric Withstanding Voltage (DWV) 250% of WVDC for capacitors rated at 500 volts DC or less for 5 seconds. 150% of WVDC for capacitors rated at 1250 volts DC or less for 5 seconds. 120% of WVDC for capacitors rated above 1250 Volts DC for 5 seconds Aging Effects None Piezoelectric Effects None Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater Retrace Less than ±(0.02% or 0.02 pF), whichever is greater. AVX 700B Series Capacitors are designed and manufactured to meet and exceed the requirements of EIA-198, MIL-PRF-55681 and MIL-PRF-123. 518 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 072921 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors CAPACITANCE VALUES Rated Rated Rated WVDC CAP. Cap. Cap. Cap. Cap. WVDC WVDC Tol. Tol. CODE Code (pF) Code (pF) STD. EXT. STD. EXT. STD. EXT. 3R3 3.3 330 33 331 B 3R6 3.6 360 36 361 3R9 3.9 390 39 1500 391 B, C 431 4R3 4.3 B, C, 430 43 D 4R7 4.7 470 47 471 511 5R1 5.1 510 51 500 5R6 5.6 560 56 561 6R2 6.2 620 62 621 680 68 681 6R8 6.8 B, C, 7R5 7.5 750 75 751 J, K, 8R2 8.2 820 82 821 M 9R1 9.1 910 91 911 F, G, J, 500 1500 100 1000 102 500 1500 101 100 K, M 10 110 11 111 110 112 B, C, 120 12 121 120 122 D 130 13 131 130 152 300 150 15 151 150 182 160 16 F, G, J, 161 160 222 K, M 180 18 181 180 272 200 20 201 200 302 220 22 221 220 332 240 24 241 240 392 200 N/A 270 27 271 270 472 300 30 301 300 512 CAP. (pF) 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 2R4 2R7 3R0 330 360 390 430 470 510 560 620 680 750 820 910 F, G, J, 1000 K, M 1100 1200 1500 1800 2200 2700 3000 3300 3900 4700 5100 EXTENDED VOLTAGE EXT EXTENDED VOLTAGE EXTENDED VOLTAGE EXTENDED VOLTAGE EXTENDED VOLTAGE 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.4 2.7 3.0 VOLT Cap. Cap. Tol. Code (pF) TOL. RATED WVDC STD. EXT. 200 150 N/A 50 SPECIAL VALUES, TOLERANCES, DIFFERENT WVDC AND MATCHING AVAILABLE. • ENCAPSULATION OPTION AVAILABLE. PLEASE CONSULT FACTORY. Capacitance values in bold type indicate porcelain dielectric. All other capacitance values indicate ceramic dielectric. HOW TO ORDER 700 B 331 J W 500 X T Series Packaging Case Size T = Tape and Reel, 500 pc qty TV = Vertical Tape and Reel, 500 pc qty See mechanical dimensions below Please see last Column Mechanical Configuration Table for Box and Tray Options Capacitance EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Laser Marking (Optional) Capacitance Tolerance Code Termination Style Code Code Tol. B C D F G J K M ±.1 pF ±.25 pF ±.5 pF ±1% ±2% ±5% ±10% ±20% Voltage Rating Please see 2nd Column Mechanical Configuration Table The above part number refers to a 700B Series (case size B) 330 pF capacitor, J tolerance (±5%), 500 WVDC, with W termination (Tin/Lead, Solder Plated over Nickel Barrier), laser marking and Tape and Reel packaging. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 090221 – rf microwave products – 519 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors MECHANICAL CONFIGURATION Series Term. MIL-PRF& Case Code 55681 Size B 700B W Y CDR14BG T L B P 110+.025 -.010 .110 ±.015 (2.79 +0.64 -0.25) (2.79 ±0.38) W Solder Plate 700B Body Dimensions inches (mm) Length Width (L) (W) Outline W/T is a Termination Surface Case Size & Type Y CDR14BG W Pellet T L Lead and Termination Dimensions and Material Thickness Overlap (T) (Y) .102 (2.59) max. 700B T N/A B 700B CA W Solderable Nickel Barrier T L Y CDR13BG W Gold Chip T L .102 (2.59) 110+.025 -.010 .110 ±.015 (2.79 +0.64 -0.25) (2.79 ±0.38) .102 (2.59) RoHS Compliant Tin Plated over Nickel Barrier Termination 110+.025 -.010 .110 ±.015 (2.79 +0.64 -0.25) (2.79 ±0.38) .102 (2.59) RoHS Compliant Gold Plated over Nickel Barrier Termination LL MS AR W T Pkg Code T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 Width (WL) Thickness (TL) Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 TL LL WL W T L TL LL CDR22BG Length (LL) .120 (3.05) max. TL L B 700B T WL Microstrip Pkg Type W L LL CDR21BG .015 (0.38) ±.010 (0.25) Heavy Tin/Lead Coated, over Nickel Barrier Termination TL WL B 700B Tin/Lead, Solder Plated over Nickel Barrier Termination 110+.025 -.010 .110 ±.015 (2.79 +0.64 -0.25) (2.79 ±0.38) B Y Materials WL W T L .135 ±.015 (3.43 ±0.38) .250 .093 ±. 005 .004 ± .001 (6.35) (2.36 ± 0.13) (.102 ± .025) min. Axial Ribbon B 700B RR CDR24BG Radial Ribbon WL T B 700B RW W L .500 (12.7) WL W #26 AWG., .016 (.406) dia.nominal .145 ±.020 (3.68 ±0.51) • • L CDR25BG Axial Wire T L B AW T N/A .102 (2.59) max. LL LL CDR23BG Radial Wire 700B .110 ±.015 (2.79 ±0.38) LL W L LL LL T .950 min. W T L W Additional lead styles available: Narrow Microstrip (NM), Narrow Axial Ribbon (NA) and Vertical Narrow Microstrip (H). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. • • L 520 LL T W The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors MECHANICAL CONFIGURATION Series Term. & Case Code Size MIL-PRF55681 Case Size & Type B 700B WN Meets Requirements 700B PN Y L T T .110 +.035 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.89 -0.25) T .110 +.020 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.51 -0.25) Y W Non-Mag Pellet L Body Dimensions Lead and Termination inches (mm) Dimensions and Material Length Width Thickness Overlap Materials (L) (W) (T) (Y) .110 +.020 .110 ±.015 -.010 (2.79 (2.79 ±0.38) +0.51 -0.25) W Non-Mag Solder Plate B Meets Requirements Outline W/T is a Termination Surface .102 (2.59) max. .015 (0.38) ±.010 (0.25) B 700B TN Meets Requirements Y W Non-Mag Solderable Barrier L TL LL B 700B 700B 700B 700B 700B MN AN FN RN BN Meets Requirements Meets Requirements Meets Requirements Meets Requirements Meets Requirements WL T .120 (3.05) max. TL WL W T L TL LL Non-Mag Axial Ribbon B WL W .135 ±.015 (3.43 ±0.38) LL L .110 ±.015 (2.79 ±0.38) WL T TL LL WL T L LL T LL Non-Mag Axial Wire B W L L WL T W Thickness (T ) .250 (6.35) (6.35) min. .093 ± .005 (2.36 ± 0.13 .004 ± . 001 (.102 ± .025) .500 (12.7) min. .145 ±.020 (3.68 ±0.51) LL Non-Mag RadialWire Width (W ) L LL • • T L W W L L N/A .102 (2.59) max. W Length (L ) L T L W Non-Mag Radial Ribbon B T&R, 1000 or 500 pcs Tin / Lead, Solder Plated over Vertical T&R, Non-Magnetic Barrier 1000 or Termination 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Heavy Tin / Lead, Coated over Vertical T&R, Non-Magnetic Barrier 1000 or Termination 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs RoHS Compliant Vertical T&R, Tin Plated over 1000 or Non-Magnetic Barrier 500 pcs Termination Cap Pac, 100 pcs Pkg Code T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 W L LL Non-Mag Microstrip B Pkg Type .950 min. • T #26 AWG., .016 (.406) dia. nominal Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 *Capacitors with values greater than 200 pF contain a trace magnetic element that may exhibit weak magnetic properties. ** Additional lead styles available: Narrow Microstrip (DN), Narrow Axial Ri bon (GN) and Vertical Narrow Microstrip (HN). Other lead lengths are available; consult factory; •• All leads are high purity silver attached with high temperature solder and RoHS compliant. LL W L • T The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 – rf microwave products – 521 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors SUGGESTED MOUNTING PAD DIMENSIONS Case B Vertical Mount Pad Size A Min. B Min. Normal .065 .050 0.1 pF High Density .045 .030 Normal .090 .050 0.2 pF High Density .070 .030 Normal .110 .050 0.3 to 510 pF High Density .090 .030 Normal .120 .050 > 510 pF High Density .100 .030 Cap Value All Values Normal High Density C Min. .075 .075 .075 .075 .075 .075 .075 .075 D Min. .175 .135 .175 .135 .175 .135 .175 .135 .075 .075 .175 .135 Horizontal Mount .130 .050 .110 .030 PERFORMANCE DATA 1 ESR VS. CAPACITANCE SERIES 700, CASE B Q VS. CAPACITANCE SERIES 700, CASE B 100000 150 MHz 1000 MHz 0.1 1000 Q ESR (Ohms) 10000 500 MHz 500 MHz 1000 MHz 100 150 MHz (Typical) 0.01 1 10 10 100 CAPACITANCE (pF) (1.0 pF to 51 pF) ESR VS. CAPACITANCE SERIES 700, CASE B 1 1000 (Typical) 1 10 100 CAPACITANCE (pF) (1.0 pF to 51 pF) Q VS. CAPACITANCE SERIES 700, CASE B 100 0.1 500 MHz 1000 MHz 500 MHz 150 MHz 0.01 10 522 1000 MHz Q ESR (Ohms) 150 MHz 10 (Typical) 100 CAPACITANCE (pF) (56 pF to 200 pF) (Typical) 1 10 1000 100 CAPACITANCE (pF) (56 pF to 200 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 010721 – rf microwave products – 1000 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors PERFORMANCE DATA ESR VS. CAPACITANCE SERIES 700, CASE B 1 Q VS. CAPACITANCE SERIES 700, CASE B 100 500 MHz 0.1 Q ESR (Ohms) 150 MHz 500 MHz 10 150 MHz (Typical) (Typical) 0.01 100 1000 1 100 10000 1000 SERIES RESONANCE VS. CAPACITANCE SERIES 700, CASE B CURRENT RATING VS. CAPACITANCE SERIES 700, CASE B 100 RMS CURRENT (Amps) FREQUENCY (GHz) 100 10 1 0.1 The current rating is based on 65°C mounting surface and device thermal resistance (Ѳ) of 20°C/W. A power dissipation of 3 W will result in a case temperature of 125°C. 10 1000 MHz 500 MHz 1 (Typical) 0.01 0.1 1 10 100 1000 10000 1 10 RMS CURRENT (Amps) The current rating is based on a 65°C mounting surface and a device thermal resistance of 20°C/W. A power dissipation of 3 W will result in a case temperature of 125°C. 150 MHz 500 MHz 1000 MHz 30 MHz The current rating is based on a 65°C mounting surface and a device thermal resistance of 20°C/W. A power dissipation of 3 W will result in a case temperature of 125°C. 30 MHz 10 150 MHz 500 MHz Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 100 CAPACITANCE (pF) (56 pF to 200 pF) 100 CURRENT RATING VS. CAPACITANCE SERIES 700, CASE B 100 100 1 10 30 MHz CAPACITANCE (pF) (0.1 pF to 51 pF) CURRENT RATING VS. CAPACITANCE SERIES 700, CASE B RMS CURRENT (Amps) 150 MHz Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 0.1 0.1 CAPACITANCE (pF) 10 10000 CAPACITANCE (pF) (220 pF to 5100 pF) CAPACITANCE (pF) (220 pF to 5100 pF) 1 100 1000 1000 10000 CAPACITANCE (pF) (220 pF to 5100 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 010721 – rf microwave products – 523 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors PERFORMANCE DATA CURRENT RATING VS. CAPACITANCE SERIES 700, CASE B, EXTENDED VOTAGE CURRENT CHANGE VS. TEMPERATURE SERIES 700, CASE B 100 TC = 0 ± 30 PPM/°C RMS CURRENT (Amps) % CHANGE IN CAPACITANCE 1 0.8 0.6 0.4 0.2 0 -0.2 -0.4 -0.6 10 500 MHz 1000 MHz -35 -15 5 25 45 65 85 105 0.1 125 Dotted Line = Power dissipation limited Solid line = Voltage limited (Vrms) 0.1 1 CAPACITANCE (pF) (0.1 pF to 51 pF) TEMPERATURE (°C) CURRENT RATING VS. CAPACITANCE SERIES 700, CASE B, EXTENDED VOTAGE 100 The current rating is based on a 65°C mounting surface with a device thermal resistance (θ) dissipation of 3 W will result in a case temperature of 125°C 30 MHz 150 MHz 10 500 MHz 1 10 1000 MHz 100 1000 CAPACITANCE (pF) (56 pF to 200 pF) 524 30 MHz 150 MHz 1 -0.8 -1 -55 RMS CURRENT (Amps) The current rating is based on a 65 °C mounting surface with a device thermal resistance (θ) of 20 °C/W. A power dissipation of 3 W will result in a case temperature The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 010721 – rf microwave products – 10 100 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700B Series NPO Porcelain and Ceramic Multilayer Capacitors SAMPLE KITS Kit # RoHS Compliant Item Number Kit 11 - DK0011 Kit 11T Kit 12 DK0011T - Kit 12T Kit 13 Kit 13T DK0012 DK0012T - DK0013 DK0013T Description Cap. Value Range (pF) Cap Value (pF) Tol. Price 1.0, 1.2, 1.5, 1.8, 2.0, 2.2, 2.4, 2.7, 3.0, 3.3............ ±0.1 700B Porcelain and Ceramic 16 different values, 15 pcs. min. per value 1.0 to 10 700B Porcelain and Ceramic 16 different values, 15 pcs. min. per value 10 to 100 700B Porcelain and Ceramic 16 different values, 15 pcs. min. per value 100 to 1000 3.9, 4.7, 5.6, 6.8, 8.2 3.9, 4.7, 5.6, 6.8, 8.2............ ±0.25 $165.00 10........................................................................... ±5% 10, 12, 15, 18, 20, 22, 24, 27, 30, 33, 39, 47, 56, 68, 82, 100..................................... ±5% 100, 120, 150, 180, 200, 220, 240, 270, 300, 330, 390, 470................................................. ± 5% $165.00 $165.00 560, 680, 820, 1000............................................... ±10% The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070721 – rf microwave products – 525
700B151JT300XT 价格&库存
很抱歉,暂时无法提供与“700B151JT300XT”相匹配的价格&库存,您可以联系我们找货
