78B03T
78B03T
    GRAYHILLINC.
    插件
    拨码开关 单刀单掷 3位 通孔安装 滑动式 (标准型) Actuator 150毫安 30伏直流
78B03T 数据手册
Thru-Hole DIP Switches SERIES 78 SPST To 4PST Slide FEATURES • Raised and Recessed Slides • SPST, 2PST, 3PST, 4PST • Sealed Base Standard • Spring and Ball Contact • Top Tape Seal Option 78 DIMENSIONS In inches (and millimeters) Typical Multiple Pole Switch with Raised Slides (Switch shown here is 78H02, 4PST) .380 ± .010 (9,65 ± 0,25) O N Single Pole/Single Throw Switch in Raised and Recessed Slides .380 ± .010 (9,65 ± 0,25) O N 1 2 3 4 5 6 7 8 9 10 Note: Recessed slides have a dimple for tool actuation. For recessed slides, the .295 dimension does not apply. 1 2 Length ± .010 (± 0.25) See Ordering Information .060 ± .002 (1,52 ± 0,05) .070 (1,78) REF. .295 + .000 –.020 (7,49 –0,51) Length ± .010 (± 0.25) See Ordering Information DIM. B ± .002 (± 0,05) DIM. B 2PST = .100 (2,54 3PST = .200 (5,08) 4PST = .300 (7,62) DIP Switches C L C L .020 ± .002 (0,51 ± 0,05) A .156 + .015 –.010 (3,96 + 0,38 –0,25) TYP. A = .245 + .000 –.020 (6,22 + 0,51) .180 ± .010 (4,57 ± 0,25) .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) C L C L .020 ± .002 (0,51 ± 0,05) .090 ± .005 (2,29 ± 0,13) .100 ± .005 (2,5 ± 0,13) .050 ± .005 (1,27 ± 0,13) TYP. .020 ± .002 (0,51 ± 0,05) .090 ± .005 (2,29 ± 0,13) .100 ± .005 (2,5 ± 0,13) C L C L CIRCUITRY Single Pole/Single Throw Switch ORDERING INFORMATION No. of Circuitry Positions 2 3 4 5 6 7 8 9 10 12 1 2 3 4 5 6 1 2 3 1 2 Length Inches 0.280" 0.380" 0.480" 0.580" 0.680" 0.780" 0.880" 0.980" 1.080" 1.280" 0.280" 0.480" 0.680" 0.880" 1.080" 1.280" 0.380" 0.680" 0.980" 0.480" 0.880" Length Metric 7,1mm 9,7mm 12,2mm 14,7mm 17,3mm 19,8mm 22,4mm 24,9mm 27,4mm 32,5mm 7,1mm 12,2mm 17,3mm 22,4mm 27,4mm 32,5mm 9,7mm 17,3mm 24,9mm 12,2mm 22,4mm No./ Tube 35 27 21 18 15 13 12 10 9 8 35 21 15 12 9 8 27 15 10 21 12 Raised Slides* 78B02T 78B03T 78B04T 78B05T 78B06T 78B07T 78B08T 78B09T 78B10T 78B12T 78F01T 78F02T 78F03T 78F04T 78F05T 78F06T 78G01T 78G02T 78G03T 78H01T 78H02T Recessed Slides* 78RB02T 78RB03T 78RB04T 78RB05T 78RB06T 78RB07T 78RB08T 78RB09T 78RB10T 78RB12T O N 1234 O N 1234 SPST Typical Multiple Pole Switch O N Typical Circuit Diagram O N 1 1 2PST Recessed Slides Not Available 3PST 4PST For switches with 5, 6, 7, 8, or 10PST circuitry, contact Grayhill. *A top tape seal is required for switches that are machine soldered or heavily cleaned after hand soldering. To order top seal versions, add "S" before the "T" in the Grayhill part number. DIP 11 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
78B03T
1. 物料型号: - SPST: 78B02T, 78B03T, 78B04T, 78B05T, 78B06T, 78B07T, 78B08T, 78B09T, 78B10T, 78B12T - 2PST: 78F01T, 78F02T, 78F03T, 78F04T, 78F05T, 78F06T - 3PST: 78G01T, 78G02T, 78G03T - 4PST: 78H01T, 78H02T
2. 器件简介: - 提供了凸起和凹进滑块的SPST, 2PST, 3PST, 4PST DIP开关。 - 标准密封底座。 - 弹簧和球接触。 - 提供顶部胶带密封选项。
3. 引脚分配: - 引脚数(No. of Positions)从2至10不等,具体取决于型号。
4. 参数特性: - 长度(Length)从0.280英寸(7.1mm)至1.280英寸(32.5mm)不等。 - 引脚数(No. J Tube)从35至8不等,具体取决于型号。
5. 功能详解: - 提供了开关的典型多极开关图和电路图。 - 提到了凸起滑块和凹进滑块的不同特点,例如凹进滑块有一个用于工具驱动的凹痕。
6. 应用信息: - 适用于需要DIP开关的应用场合,如电子设备编程、配置等。 - 对于5, 6, 7, 8, 或10PST电路的开关,需要联系Grayhill。
7. 封装信息: - 提供了凸起滑块和凹进滑块的封装选项。 - 对于需要机器焊接或手工焊接后需要重度清洗的开关,需要顶部胶带密封,可以通过在Grayhill零件号中“T”前加上“S”来订购。
78B03T 价格&库存
很抱歉,暂时无法提供与“78B03T”相匹配的价格&库存,您可以联系我们找货
