700A102FW50XT
700A102FW50XT
    ATC
    贴片电容(MLCC) 0505 1nF ±1% 50V C0G(NP0)
700A102FW50XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors FEATURES • • • • • • • • • GENERAL DESCRIPTION Case A Size (.055” x .055”) Low ESR / ESL High Q Low Noise Capacitance Range 0.1 pF to 1000 pF Extended WVDC up to 250 VDC Zero TCC High Self-Resonance Established Reliability (QPL) PACKAGING OPTIONS KYOCERA AVX, the industry leader, offers new improved ESR/ESL performance for the 700 A Series RF/Microwave Capacitors. The superior high self- resonance and zero TCC characteristic of this Series provide excellent performance over a broad range of RF and microwave applications requiring minimum drift. High density porcelain and ceramic constructions provide a rugged, hermetic package. Tape & Reel Vertical Orientation Tape & Reel Cap-Pak® (100 pcs) Typical functional applications: Bypass, Coupling, Tuning and DC Blocking. Typical circuit applications: Filters, Oscillators and Timing ELECTRICAL SPECIFICATIONS ENVIRONMENTAL CHARACTERISTICS Temperature Coefficient (TCC) 0 ± 30 PPM/ºC Themal Shock Mil-STD-202, Method 107, Condition A Capacitance Range 0.1 pF to 1000 pF Mil-STD-202, Method 106 Operating Temperature -55ºC to +125ºC* Moisture Resistance Low Voltage Humidity Mil-STD-202, Method 103, condition A, with 1.5 VDC applied while subjected to an environment of 85ºC with 85% relative humidity for 240 hours Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. 200% WVDC applied. Solderability Mil-STD-202, Method 208 Terminal Strength Terminations for chips and pellets withstand a pull of 5 lbs. min., 10 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Quality Factor Greater than 10,000 (0.1 pF to 100 pF) @ 1 MHz. Greater than 2000 (110 pF to 1000 pF) @ 1 MHz. Insulation Resistance (IR) 0.1 pF to 470 pF 106 Megohms min. @ 25ºC at rated WVDC 105 Megohms min. @ 125ºC at rated WVDC 510 pF to 1000 pF 105 Megohms min. @ 25ºC at rated WVDC 104 Megohms min. @ 125ºC at rated WVDC Working Voltage (WVDC) See Capacitance Values table Dielectric Withstanding Voltage (DWV) 250% of rated WVDC for 5 seconds Aging Effects None Piezoelectric Effects None Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater 512 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032521 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors CAPACITANCE VALUES 250 B, C, D 150 B, C, J, K, M 250 F, G, J, K, M 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 Tol. Rated WVDC STD. EXT. VOLTAGE Cap. (pF) 250 F, G, J, K, M 150 EXTENDED 150 B, C, D Cap. Code VOLT. B, C 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 Rated WVDC STD. EXT. 200 EXT. 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 Tol. EXTENDED VOLTAGE ED B Cap. Cap. Code (pF) EXTENDED VOLTAGE 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 Rated WVDC STD. EXT. EXTENDED VOLTAGE ED 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 Tol. EXTENDED VOLTAGE Cap. Cap. Code (pF) N/A Cap. Code 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 Cap. (pF) Tol. Rated WVDC STD. EXT. 150 160 180 200 220 240 270 300 330 360 F, G, 390 J, K, 430 M 470 510 560 620 680 750 820 910 1000 150 N/A 50 vrms = 0.707 x WVDC Special values, tolerances, higher WVDC and matching available. Please consult factory. note: extended wvdc does not apply to cdr products. Capacitance values in bold type indicate porcelain dielectric. All other capacitance values indicate ceramic dielectric. All 700 A Capacitors are available laser marked with KYOCERA AVX identification, capacitance code and tolerance. HOW TO ORDER 700 A 6R8 J W 150 Series T Packaging T = Tape and Reel, 500 pc qty TV = Vertical Tape and Reel, 500 pc qty Case Size Please see last column of mechanical configuration table for other options. See mechanical dimensions below Capacitance Laser Marking (Optional) EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Voltage Rating Termination Style Code Capacitance Tolerance Code Code Tol. X B C D ±.1 pF ±.25 pF ±.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% Please see 2nd Column Mechanical Configuration Table The above part number refers to a 700A Series (case size A) 6.8 pF capacitor, J tolerance (+/-5%), 150 WVDC, with W termination, (Tin/Lead, Solder Plated over Nickel Barrier), laser marking and Tape and Reel Packaging. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – 513 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors MECHANICAL CONFIGURATION Series & Case Size 700A 700A Outline ES W/T is a Termination Surface Term. Case Size MIL-PRF-55681 Code & Type W P CDR12BP CDR12BP Y A Solder Plate W T L Y A Pellet W T L Body Dimensions inches (mm) Length (L) Width (W) Lead and Termination Dimensions and Material Thickness (T) .055+.015 -.010 .055 ±.015 (1.40+0.38-0.25) (1.40 ±0.38) .055+.025 -.010 .055 ±.015 (1.40+0.64-0.25) (1.40 ±0.38) .057 (1.45) max. 700A 700A T CA N/A CDR11BP A Solderable Nickel Barrier A Gold Chip Y W T L Y W L T .055+.015 -.010 .055 ±.015 (1.40+0.38-0.25) (1.40 ±0.38) .055+.015 -.010 .055 ±.015 (1.40+0.38-0.25) (1.40 ±0.38) Overlap (Y) Materials Pkg Type T&R, 1000 or 500 pcs Tin/ Lead, Solder Vertical Plated over Nickel T&R, 1000 Barrier Termination or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Heavy Tin/ Lead Vertical Coated, over Nickel T&R, 1000 Barrier Termination or 500 pcs Cap Pac, 100 pcs .010+.010 -.005 (0.25+0.25 -0.13) T&R, 1000 or 500 pcs RoHS Compliant Vertical Tin Plated over T&R, 1000 Nickel Barrier or 500 pcs Termination Cap Pac, 100 pcs T&R, 1000 or 500 pcs RoHS Compliant Vertical Gold Plated over T&R, 1000 Nickel Barrier or 500 pcs Termination Cap Pac, 100 pcs Pkg Code T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 NON-MAGNETIC CONFIGURATION Series & Case Size Term. Case Size MIL-PRF-55681 Code & Type Non-Magnetic Configuration Body Dimensions inches (mm) Length (L) Width (W) Lead and Termination Dimensions and Material Thickness (T) Overlap (Y) Materials Pkg Type T&R, 1000 or 500 pcs Tin/ Lead, Solder A Y Vertical .055+.025 -.010 .055 ±.015 Plated over WN Meets Non-Mag W T&R, 1000 700A (1.40+0.64-0.25) (1.40 ±0.38) Non-Magnetic Requirements Solder T L or 500 pcs Barrier Termination Plate Cap Pac, 100 pcs T&R, 1000 or 500 pcs Heavy Tin/ Lead Y Vertical .057 A .055+.025 -.010 .055 ±.015 Coated, over Meets .010+.010 -.005 W T&R, 1000 700A PN (1.45) Non-Mag (1.40+0.64-0.25) (1.40 ±0.38) Non-Magnetic Requirements (0.25+0.25 -0.13) T L or 500 pcs max. Pellet Barrier Termination Cap Pac, 100 pcs T&R, 1000 or 500 pcs RoHS Compliant A Y Vertical .055+.015 -.010 .055 ±.015 Tin Plated over TN Meets Non-Mag W T&R, 1000 700A (1.40+0.38-0.25) (1.40 ±0.38) Non-Magnetic Requirements Solderable T L or 500 pcs Barrier Termination Barrier Cap Pac, 100 pcs *Capacitors with values greater than 100 pF contain a trace magnetic element that may exhibit weak magnetic properties. 514 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – Pkg Code T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors SUGGESTED MOUNTING PAD DIMENSIONS Case A A Min. .070 .050 .080 .060 Mount Type Pad Size Normal Vertical Mount High Density Normal Horizontal Mount High Density B Min. .050 .030 .050 .030 C Min. .030 .030 .030 .030 D Min. .130 .090 .130 .090 Dimensions are in inches. PERFORMANCE DATA ESR VS. CAPACITANCE SERIES 700, CASE A Q VS. CAPACITANCE SERIES 700, CASE A 10000 1 1000 Q ESR (Ohms) 150 MHz 1000 MHz 0.1 500 MHz 500 MHz 1000 MHz 100 150 MHz (Typical) (Typical) 0.01 10 1 10 1 100 CAPACITANCE (pF) (1.0 pF to 100 pF) ESR VS. CAPACITANCE SERIES 700, CASE A 1000 100 150 MHz 100 1000 MHz 500 MHz Q VS. CAPACITANCE SERIES 700, CASE A Q ESR (Ohms) 1 0.1 10 CAPACITANCE (pF) (1.0 pF to 1000 pF) 500 MHz 150 MHz 10 1000 MHz 0.01 (Typical) (Typical) 100 300 1 1000 100 CAPACITANCE (pF) (110 pF to 100 pF) 300 1000 CAPACITANCE (pF) (110 pF to 1000 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 515 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors PERFORMANCE DATA SERIES RESONANCE VS. CAPACITANCE SERIES 700, CASE A 100 CAPACITANCE CHANGE VS. TEMPERATURE SERIES 700, CASE A 1 TCC= 0 ± 30 PPM/°C % CHANGE IN CAPACITANCE FREQUENCY (GHz) 0.8 10 1 0.6 0.4 0.2 0 -0.2 -0.4 -0.6 -0.8 -1 (Typical) -55 0.1 0.1 1 10 100 -35 -15 5 25 45 65 85 105 125 TEMPERATURE (°C) 1000 CAPACITANCE (pF) CURRENT RATING VS. CAPACITANCE SERIES 700, CASE A CURRENT RATING VS. CAPACITANCE SERIES 700, CASE A 10 The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. 1000 MHz 500 MHz The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. RMS CURRENT (Amps) RMS CURRENT (Amps) 10 150 MHz 1 150 MHz 500 MHz 1000 MHz Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 0.1 0.1 1 10 Dotted line = Power dissipation limited 1 100 100 CAPACITANCE (pF) (0.1 pF to 100 pF) CURRENT RATING VS. CAPACITANCE SERIES 700, CASE A, EXTENDED VOLTAGE 10 The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. 1 1000 MHz 1000 MHz 500 MHz RMS CURRENT (Amps) RMS CURRENT (Amps) 10 CURRENT RATING VS. CAPACITANCE SERIES 700, CASE A, EXTENDED VOLTAGE 150 MHz Typical 0.1 0.1 Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 1 10 150 MHz 500 MHz 1000 MHz 1 (Typical) 0.1 100 The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. Dotted line = Power dissipation limited 10 CAPACITANCE (pF) (1 pF to 56 pF) 516 1000 CAPACITANCE (pF) (120 pF to 1000 pF) 100 CAPACITANCE (pF) (62 pF to 100 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 700A Series NP0 Porcelain and Ceramic Multilayer Capacitors SAMPLE KITS Kit # RoHS Compliant Item Number Kit 4 - DK0004 Kit 4T Kit 5 DK0004T - Kit 5T Kit 6 DK0005T - Kit 6T Kit 7 Kit 7T DK0005 DK0006 DK0006T - DK0007 DK0007T Description 700A Porcelain and Ceramic 16 different values, 15 pc. min. per value Cap. Value Range (pF) Tol. Price 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2, 1.5..................................................... ±0.1 0.1 to 2.0 $158.40 1.5, 1.8, 2.0............................................................ ±0.25 1.0, 1.2, 1.5, 1.8, 2.0, 2.2, 2.4, 2.7, 3.0, 3.3,........... ±0.1 700A Porcelain and Ceramic 16 different values, 15 pc. min. per value 1.0 to 10 700A Porcelain and Ceramic 16 different values, 15 pc. min. per value 10 to 100 700A Porcelain and Ceramic 16 different values, 15 pc. min. per value Cap Value (pF) 3.9, 4.7, 5.6, 6.8, 8.2.............................................. ±0.25 $158.40 10........................................................................... ±5% 10, 12, 15, 18, 20, 22, 24, 27, 30, 33, 39, 47, 56, 68, 82, 100................................................. ± 5% $158.40 100, 120, 150, 180, 200, 220, 240, 270 300, 330, 390, 470................................................. ±5% 100 to 1000 $158.40 560, 680, 820, 1000............................................... ±10 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 113020 – rf microwave products – 517
700A102FW50XT 价格&库存
很抱歉,暂时无法提供与“700A102FW50XT”相匹配的价格&库存,您可以联系我们找货
