78HF03GWT
78HF03GWT
    GRAYHILLINC.
    插件
    开关 DIP 双刀单掷 滑动式 3位
78HF03GWT 数据手册
Surface Mount DIP Switches SERIES 78H SPDT and DPST FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Reliable Spring and Ball Contact DIMENSIONS In inches (and millimeters) Recommended PC Pad Dimensions LENGTH ± .010 (0,25) SEE ORDER INFO .530 (13,46) TYP. .100 ± .005 (2,54 ± 0,13) TYP. .295 + .000 – .020 (7,49 – 0,51) .070 (1,78) TYP. .100 (2,54) TYP. .280 (7,11) TYP. SPDT, DPST, Top Actuated, Slide Operated .380 ± .010 (9,65 ± 0,25) .023 .055 ± .010 (5,84) (1,40 ± 0,25) REF. .025 (0,64) R. .303 ± .015 (7,70 ± 0,38) .424 ± .015 (10,77 ± 0,38) TYP. .268 ± .010 (6,81 ± 0,25) .012 ± .001 (0,30 ± 0,03) TYP. CC LL CC LL CIRCUITRY SPDT 2 Circuits (no common) 1 1 ON DPST 1 ON 1 Dot indicates active circuit. Materials and Finishes Shorting Member: B rass, gold-plated over nickel barrier. Base Contacts: Copper alloy, gold-plated over nickel barrier. Terminals: Copper alloy, matte tin-plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) DIP Switches OFF ON SPECIFICATIONS Electrical Ratings Make-and-break Current Rating: 2 ,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: Initial: 30 mohms max. After Life: 100 mohms max. (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms; After Life: 1,000 Mohms Dielectric Strength: Minimum voltage (AC, RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Current Carry Rating: 4 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1megahertz Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures Thermal Shock: Per specification; no failures; passes contact resistance TAPE AND REEL PACKAGING Meets requirements of EIA 481-2 or EIA 481-3 13 INCH DIAMETER REEL CONDUCTIVE PLASTIC EMBOSSED TAPE 4 3 2 1 Environmental Ratings Meets all requirements of MIL- S-83504. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: P er MIL-STD-202, Method 106 4 3 2 1 Soldering Information Solderability: Per MIL-STD-202, Method 208 Soldering Heat Resistance: Per MIL-S-83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed with all actuators in the closed (on) position as shipped. 4 3 2 4 DIRECTION OF FEED 16mm 16 & 24mm TAPE 1 1 4 3 2 1 Mechanical Ratings Mechanical Life: 2,000 operations per switch position Vibration Resistance: Per method 204, Test Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) 1 3 1 2 4 1 2 3 4 1 2 3 4 1 2 3 4 ORDERING INFORMATION: Tube Packaging No. of Positions 1 2 3 4 5 Length (inches) 0.280" 0.480" 0.680" 0.880" 1.080" Length (metric) 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm Carrier Width Dim. A 24 mm 24 mm 32 mm 44 mm 44 mm Part Number* SPDT DPST 78HJ01GWT 78HJ02GWT 78HJ03GWT 78HJ04GWT 78HJ05GWT 78HF01GWT 78HF02GWT 78HF03GWT 78HF04GWT 78HF05GWT 16mm PIN ONE LOCATION COVER TAPE 32 & 44mm TAPE DIM. A (SEE ORDER INFO.) Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. * Insert "R" before the "T" in the Grayhill part number for tape and reel packaging (500 switches/reel). Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. DIP 7 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
78HF03GWT 价格&库存
很抱歉,暂时无法提供与“78HF03GWT”相匹配的价格&库存,您可以联系我们找货
