85
DATA SHEET
SURFACE MOUNT MULTILAYER
CERAMIC CAPACITORS
Automotive grade
High Temperature Application
X8G / X8R
16 V TO 100 V
1 nF to 100 nF
Product Specification – October 3, 2019 V.1
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
Automotive grade
X8G / X8R
16 V to 100 V
2
17
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
Automotive grade X8G / X8R
series chip capacitors with leadfree terminations and used for
automotive equipments.
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
GLOBAL PART NUMBER
AC
XXXX X X XXX X
(1)
APPLICATIONS
Decoupling, smoothing, snubber
and resonant of high temperature
operating equipment.
FEATURES
AEC-Q200 qualified
Operating temperature range:
-55 to 150°C
MSL class: MSL 1
Soldering is compliant with JSTD-020D
Halogen free epoxy
RoHS compliant
Reduce environmentally
hazardous waste
High component and
equipment reliability
The capacitors are 100%
performed by automatic optical
inspection prior to taping.
(2) (3) (4)
B
(5)
X XXX
(6) (7)
(1) SIZE – INCH BASED (METRIC)
0805 (2012)
(2) TOLERANCE
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
M = ± 20%
(3) PACKING STYLE (SEE TABLE 3)
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
(4) TC MATERIAL
X8G : 0± 30 ppm/°C
X8R : ± 15%
(5) RATED VOLTAGE
7 = 16 V
8 = 25 V
9 = 50 V
0 = 100 V
(6) PROCESS
N = Class I MLCC (X8G)
B = Class II MLCC (X8R)
(7) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Oct. 03,2019 V.1
3
Automotive grade
X8G / X8R
17
16 V to 100 V
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
terminations
electrodes
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (Matte
Sn). The terminations are leadfree. A cross section of the
structure is shown in Fig.1.
MLB457
ceramic material
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
OUTLINES
Table 1 For outlines see fig. 2
TYPE
0805
L1 (mm)
W (mm)
T (MM)
2.0 ± 0.10
1.25 ± 0.10
0.60 ± 0.10
2.0 ± 0.10
1.25 ± 0.10
0.85 ± 0.10
2.0 ± 0.20
1.25 ± 0.20
1.25 ± 0.20
L2 / L3 (mm) L4 (mm)
min.
max.
min.
0.25
0.75
0.70
For dimension see Table 1
W
T
L2
L4
L1
CAPACITANCE RANGE & THICKNESS FOR X8G
L3
MBB211
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
Table 2-1 Size 0805
0805
CAP.
50 V
100 V
1 nF
0.6± 0.1
0.6± 0.1
1.2 nF
0.6± 0.1
0.6± 0.1
1.5 nF
0.6± 0.1
0.6± 0.1
1.8 nF
0.6± 0.1
0.6± 0.1
2.7 nF
0.6± 0.1
0.6± 0.1
3.3 nF
0.6± 0.1
0.6± 0.1
3.9 nF
0.6± 0.1
0.6± 0.1
4.7 nF
0.6± 0.1
0.6± 0.1
5.6 nF
0.6± 0.1
0.6± 0.1
6.8 nF
0.85± 0.1
0.85± 0.1
8.2 nF
0.85± 0.1
0.85± 0.1
10 nF
0.85± 0.1
0.85± 0.1
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-12 series is on request
www.yageo.com
Oct. 03,2019 V.1
Automotive grade
X8G / X8R
16 V to 100 V
4
17
CAPACITANCE RANGE & THICKNESS FOR X8R
Table 2-2 Size 0805
0805
CAP.
16 V
25 V
50 V
22 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
33 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
47 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
68 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
100 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
NOTE
2. Capacitance value of non E-6 series is on request
THICKNESS CLASSES AND PACKING QUANTITY
Table 3
SIZE
CODE
0805
THICKNESS
CLASSIFICATION
PACKING CODE
QUANTITY PER REEL
TAPE WIDTH Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
7 INCH
13 INCH
0.60 ± 0.1 mm
R
P
8 mm
4,000
20,000
0.85 ± 0.1 mm
R
P
8 mm
4,000
15,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
www.yageo.com
Oct. 03,2019 V.1
Automotive grade
X8G / X8R
5
17
16 V to 100 V
PAPER/PE TAPE SPECIFICATION
P0
D0
T
P2
E
F
cover tape
W
B0
K0
A0
P1
MBG251-1
Fig. 3 Paper/PE tape
Table 4 Dimensions of paper/PE tape for relevant chip size; see Fig.3
SIZE
Unit: mm
SYMBOL
CODE A0
B0
W
E
F
P0 (1)
P1
P2
Ø D0
K0
T
0.38 ± 0.05
(0.47 / 0.55)±0.10
0201
0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20
1.75 ± 0.1
3.50 ± 0.05 4.0 ± 0.05
2.0 ± 0.05
2.0 ± 0.05
1.55 ± 0.03
0402
0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20
1.75 ± 0.1
2.0 ± 0.05
2.0 ± 0.05
1.50 +0.1 /-0 (0.75 / 0.60)±0.10
(0.85 / 0.70)±0.10
0603
1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20
1.75 ± 0.1
3.50 ± 0.05 4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10
(1.15 / 1.05 / 0.85)±0.10
0805
1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20
1.75 ± 0.1
4.0 ± 0.10
2.0 ± 0.05
1206
1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20
1.75 ± 0.1
4.0 ± 0.10
2.0 ± 0.05
1.50 +0.1 /-0 (0.95 / 0.75)±0.10
(1.05 / 0.85)± 0.10
NOTE
1. P0 pitch tolerance over any 10 pitches is 0.2 mm
www.yageo.com
Oct. 03,2019 V.1
Automotive grade
X8G / X8R
16 V to 100 V
6
17
BLISTER TAPE SPECIFICATION
P0
D0
K0
P2
E
F
cover tape
W
B0
A0
T2
SCM015
D1
P1
direction of unreeling
Table 5 Dimensions of blister tape for relevant chip size; see Fig.4
SYMBOL
SIZE
B0
CODE A0
Unit: mm
K0
W
E
F
Min. Max. Min. Max. Min. Max.
Ø D0
Ø D1
P0 (2)
P1
P2
T2
Min.
Min. Max.
0805
1.29
1.65
2.09
2.60
1.25
1.62
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
1.5 +0.1/-0.0 1 +0.1/-0.0
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.30
1.67
1206
1.65
2.12
3.30
3.75
1.22
2.15
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.27
2.20
1210
2.55
3.02
3.31
3.88
0.97
2.92
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.02
2.97
1808
2.05
2.55
4.80
5.45
1.30
2.45
12.1 ± 0.20
1.75 ± 0.1
5.5 ± 0.05
1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.35
2.50
1812
3.35
3.75
4.70
5.33
0.70
2.40
12.1 ± 0.20
1.75 ± 0.1
5.5 ± 0.05
8.0 ± 0.10
2.0 ± 0.05
0.75
2.45
NOTE
1. Typical capacitor displacement in pocket
2. P0 pitch tolerance over any 10 pitches is ±0.2 mm
www.yageo.com
Oct. 03,2019 V.1
Automotive grade
X8G / X8R
16 V to 100 V
7
17
REEL SPECIFICATION
W2
C
N
A
HBK039
W1
Table 6 Reel dimensions; see Fig.5
TAPE WIDTH
SYMBOL
Unit: mm
A
N
C
W1
W2max.
8 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
9.4 ± 1.5
14.4
8 (Ø 330 mm/13")
330 ± 1.0
100 ± 1.0
13 +0.50/-0.20
9.0 ± 0.2
14.4
12 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
13.4 ± 1.5
18.4
P ROPERTIES OF REEL
Material: polystyrene
Surface resistance:
很抱歉,暂时无法提供与“AC0805KKX8R9BB104”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.456913000+0.05510
- 6000+0.415386000+0.05009
- 9000+0.394609000+0.04759
- 15000+0.3738415000+0.04508
- 30000+0.3530830000+0.04258
- 75000+0.3323075000+0.04007
- 150000+0.27623150000+0.03331
- 300000+0.25961300000+0.03131
- 国内价格 香港价格
- 1+2.302451+0.27765
- 10+1.4820810+0.17872
- 50+0.9348850+0.11274
- 100+0.74757100+0.09015
- 500+0.54000500+0.06512
- 1000+0.477681000+0.05760
