Safety Standard Certified Ceramic Capacitors-CE Series (Class Y2)
SPECIFICATION
CE Series(Y2-Series)
Company and Factory Name: SHANTOU FREE TRADE ZONE SONGTIAN ELECTRONIC TECHNOLOGY CO.,LTD
Add: Songtian science and technology park,Free trade zone,Shantou,City,Guangdong,China.
E-mail: info@songtian.cn P.O.BOX: 515071
Homepage: http://songtian-ste.com
1
Contents
1. Applications.......................................................................................................................................................3
2. Part Number Code........................................................................................................................................... 3
3. Electrical Characteristics.................................................................................................................................4
4. Dimensions....................................................................................................................................................... 4
5. nternal Structure...............................................................................................................................................6
6. Marking.............................................................................................................................................................. 6
7. Temperature Characteristic Curves.............................................................................................................. 7
8. Taping And Dimensions.................................................................................................................................. 7
9. Safety Certificate.............................................................................................................................................. 8
10. Performance Test Methods And Requirements........................................................................................8
11. Reliability Test Methods And Requirements............................................................................................. 9
12. Storage Conditions......................................................................................................................................11
13. Environmental Compliance........................................................................................................................ 12
14. Packaging..................................................................................................................................................... 12
2
1. Applications
Can be used for power supply noise suppression circuit in cross connection and bypass.It is a primary
and secondary coupling X/Y capacitor used as AC line filter and switching power supply and AC
converter.
2. Part Number Code
Part Number Code
G
08
F
Rated
Voltage
G:Y2
Core Diameter
07:mm
08:8mm
09:9mm
10:10mm
1
E
222
Pitch
E:7.5mm
D:10.0mm
M
N0
Tolerance
K:±10%
M:±20%
B
Nominal capacitance
101:100pF
151:150pF
221:220pF
471:470pF
681:680pF
102:1000pF
152:1500pF
222:2200pF
332:3300pF
472:4700pF
S
Package
B: Bulk
T:Tape
Foot Type
1:Long straight
2:Outside Crimped
3:Short Straight
8:Vertical Crimped
Temperature
Characteristic
B:Y5P
E:Y5U
F:Y5V
N
Inner
Management
Environmental
Standard
0:RoHS
2:RoHS+Halogen-Free
Lead Length
S0~S9:1.0~1.9mm
X0~X9:2.0~2.9mm
A0~A9:3.0~3.9mm
B0~B9:4.0~4.9mm
C0~C9:5.0~5.9mm
D0~D9:6.0~6.9mm
E0~E9:7.0~7.9mm
3
Lead Length
F0~F9:8.0~8.9mm
G0~G9:9.0~9.9mm
H0~H9:10.0~10.9mm
J0~J9:11.0~11.9mm
K0~K9:12.0~12.9mm
L0~L9:13.0~13.9mm
M0~M9:14.0~14.9mm
Lead Length
M0~M9:14.0~14.9mm
N0:16~27.0mm(Bulk)
Crimped Lead Taped
N0:H0=16.5mm
P0:H0=17.0mm
Q0:H0=19.0mm
Straight Lead
Q0:20.0mm
Capacitance and Dissipation factor
testing condition
25℃, 1KHz, 1Vrms
Dissipation Factor(tanδ)
≤2.5%
Rated Voltage
250VAC
Withstand Voltage
2500VAC
Insulation Resistance (I.R.)
≥10000MΩ
Y5P, Y5U, Y5V
4. Dimensions
PN of STE
Dimension (mm)
D Max T Max L Min
F±0.8 Φd±0.05
H1 Max
C Max
Marking
Packing
G07B1E101KN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
G07B1E151KN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
G07B1E221KN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
G07B1E471KN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
4
G08B1E681KN0B0
S0N0
8.5
4.0
16.0
10.0
0.6
11.0
2.5
Example 2
Bulk
G07E1E102MN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
G09E1E152MN0B0
S0N0
9.0
4.0
16.0
10.0
0.6
11.5
2.5
Example 1
Bulk
G10E1E222MN0B0
S0N0
10.0
4.0
16.0
10.0
0.6
12.5
2.5
Example 1
Bulk
G07F1E152MN0B0
S0N0
7.0
4.0
16.0
10.0
0.6
9.5
2.5
Example 2
Bulk
G08F1E222MN0B0
S0N0
8.0
4.0
16.0
10.0
0.6
10.5
2.5
Example 2
Bulk
G09F1E332MN0B0
S0N0
9.0
4.0
16.0
10.0
0.6
11.5
2.5
Example 1
Bulk
G10F1E472MN0B0
S0N0
10.0
4.0
16.0
10.0
0.6
12.5
2.5
Example 1
Bulk
G07B1E101KQ0T0
S0N0
7.0
4.0
10.0
0.6
9.5
2.5
Example 2 Taping
G07B1E471KQ0T0
S0N0
7.0
4.0
10.0
0.6
9.5
2.5
Example 2 Taping
G08B1E681KQ0T0
S0N0
8.5
4.0
10.0
0.6
11.0
2.5
Example 2 Taping
G09E1E152MQ0T0
S0N0
9.0
4.0
10.0
0.6
11.5
2.5
Example 1 Taping
G09F1E332MQ0T0
S0N0
9.0
4.0
10.0
0.6
11.5
2.5
Example 1 Taping
5
5. Internal Structure
No.
Name
Material
1
Electrode
Metal Layer
2
Ceramic Dielectric
Ceramic
3
Lead Free
Tin Bar
4
Lead Wire
CP wire
5
Coating
Epoxy Resin
6
Marking
Laser marking
6. Marking
①Registered Trademark
Type(CE:Y2)
M (±20%)
②CE
③Nominal Capacitance
④Capacitance Tolerance
ENEC(EU)
VDE
⑤Safety Certification
Sign
KTL
CQC
UL
⑥Rated Voltage
⑦Sub-Class of
Safety Performance
Example 1:Y2 Single Sided Printing
250V~(250VAC)
X1 Y2
Example 2: Y2 Double Sided Printing
6
Note
Color:Blue
Code
Po
P
P1
P2
F
ΔS
Δh
W
Wo
Size(mm)
12.7
25.4
8.95
12.7
7.5
10.5
Tolerance
±0.3
±1.0
±0.7
±1.3
±0.8
±2.0
±2.0
+1.5/-1.0
Max
Code
W1
W2
H1
Do
H
L
t1
t2
c
Size(mm)
9.0
3.0
45.0
4.0
20.0
11.0
0.5
1.7
2.5
Tolerance
+0.75/-0.5
Max
Max
±0.2
+1.5/-1
Max
±0.2
Max
7
USA
Canada
Certification
Body
UL
CUL
Korea
KTL
China
CQC
Germany
VDE
EU
ENEC
Country
Report
Reference
Certificate No.
Capacitance
Range
UL60384-14
E208107
100~10000pF
SU03031-7001B
100~10000pF
CQC19001213202
100~10000pF
40025748
100~10000pF
40025748
100~10000pF
K60384-14
(2015)
GB/T
6346.14-2015
En 60384-14:
2017-04
En 60384-14:
2017-04
Rated
Voltage
X1Y2:
250VAC
No.
1
Item
Standard
Test Method
Temperature Range -25℃~125℃
Capacitors must be visually inspect to
No opparent defect,size within the
check if there’s opparent defect and
normal range
measure size with vernier caliper
2
Appearance/Size
3
Marking
4
Capacitance
5
D.F.
D.F.≤2.5%
6
I.R.
>10000MΩ
Clear and easy to recognize
Within the specified tolerance
Dielectric
Strength
25 ℃ ,1 ± 0.1 KHz, 1.0 V.
500VDC, 60s±5s .
Between
No breakdown and flashover
Leads
7
Visual inspection
Between
Leads and No breakdown and flashover
Body
8
Between terminals:
AC2500V (r.m.s.) 60s, ≤50mA
As shown in figure at right,a metal foil
should be closely wrapped around the
body of the capacitor to the distance of
about 3 to 4mm from each
terminal.hen,the capacitor
should be inserted into a
container filled with metal
balls of about 1mm
diameter.voltage appliedA
C2500V(r.m.s.),60s
No.
Item
Standard
B(Y5P)
Capacitance
change
±10%
E(Y5U)
+22/-56%
Char.
1
2
Temperature
Characteristics
Solderability
Test Method
The capacitance measurement should be
made at each step specified in Table 3
< Table 3>
Step
1
2
3
4
5
Temperature 20 -25 20 85 20
±2 ±2 ±2 ±2 ±2
F(Y5V)
+30/-80%
Temperature range:
-25 ~+85℃
Lead wire should be
245±3℃, 3±0.3s.
soldered with uniform
Solder composition:
coating on the axial direction
Sn96.5Ag3.0Cu0.5
over 95% of the
circumferential direction.
Appearance No marked defect
3
Solder
Resistance
Heat Up
Capacitance
Within ±10%
change
I.R.
Dielectric
Strength
260 ± 5℃,10.0 ± 0.5 s.
≥1000MΩ
Per 10.1[Basic
characteristics] item7
10~55Hz, 0.75mm,
10Hz→55Hz→10Hz. 1min
Apply for a total of 6 hours, 2 hrs each
in 3 mutually perpendicular
directions.
Appearance No visible damage
4
Vibration
Capacity
D.F.
Within the tolerance
.≤2.5%
5
Humidity
(Under
Steady
State)
Capacity
Rate of
Change
I.R.
≤±15%
40±2℃, 90-95%RH, 500±12 hours.
>5000MΩ
Withstand Per 10.1[Basic
Voltage characteristics] item7
9
No.
Item
Standard
Test Method
6
Humidity
Loading
Capacitance
≤±15%
Change
I.R.
40±2℃, 90~ 95% RH, Apply with UR,500±12 hours.
>5000MΩ
Dielectric Per 10.1[Basic
Strength characteristics] item7
Impulse Voltage: 5KVDC,three times.
After the capacitors are applied to life test.
Capacitance
Within ±20%
change
7
Life Test
I.R.
>5000MΩ
125+2/-0℃,relative humidity of 50% max,
1000 hours,1.7*UR (r.m.s.), except that once each
hour the voltage is increased to AC1000V(r.m.s.) for
0.1 sec.
The Varistor under test shall be held in the flame in
the position which best promotes
burning. Each specimen shall be exposed once in
the flame.
Specifically as follows: level C requirements.
8
9
Capacitor volume (mm3) Apply flame time
(S)
Passive The burning time shall not be
exceeded the standard.
Flammability
The tissue paper shall ignite.
Robustness
of
Termination
Tensile
Strength
Bending
Strength
Class
volume
<250
250<
volume≤
500
500<
volume≤
1750
volume
>1750
Maximum
burning
time
(S)
A
15
30
60
120
3
B
C
10
5
30
30
10
30
As shown in the figure at right,
10N, 10±1 sec.
Lead wire should not
be cut off. Capacitor Each lead wire should be subjected to 5N weight
should not be broken. and then a 90° bend, at the point of egress, in one
direction, return to original position, and then apply
a 90° bend in the opposite direction at the rate of
one bend in 2 to 3 sec.
10
No.
Item
Standard
Test Method
No visible
Capacitors should be tested in the order shown in the
damage
following table (for one cycle) for five consecutive cycles.
Temperature cycling
Capacitance B(Y5P)/E(Y5U):
Order
(min)
±20%;
Rate of
Change F(Y5V): ±30%。
1
-25 +0/-3
30
2
+25 +0/-3
3
B(Y5P)/E(Y5U):
Rapid
D.F.≤5.0%
3
125 +3/-0
30
D.F.
Temperature
F(Y5V):
4
+25 +0/-3
3
Changes
D.F.≤7.5%
I.R.
>5000MΩ
[Pre-treatment]:
Stored at 85 ± 2 ° C , 1 hour and then 24 ± 2 hours before
Per 10.1[Basic making initial measurements.
Withstand
characteristics] [Treatment After testing]:
Voltage
Capacitors must be stored at room temperature for 24 ± 2
item7
hours.
The capacitor should be individually wrapped in at least
one but not more than two complete layers of
cheese-cloth. The capacitor should be subjected to
discharges for 20 times. he interval between successive
discharges should be 5 sec. The UAC should be
maintained for 2 min. after the last discharge.
Appearance
10
11
Active
The
Flammability cheese-cloth
(Only for Y2) should not
be on fire.
C1, 2:1UF±10%
C3:0.033UF±5%, 10KV
Ct:3UF±5% 10KV
Cx: Capacitor under test
F: Fuse,Rated 10A
R:100Ω±5%
Ur: Rated Voltage
Ut: Voltage applied to Ct
L1 to 4: 1.5mH±20% 16A Rod core choke
12.1 Storage Temperature: ≤35℃.
12.2 Relative Humidity: ≤70% RH.
12.3 Keep away from corrosive atmosphere and sunlight.
12.4 Period : 1 year.
11
13. Environmental Compliance:
RoHS Compliance
REACH Compliance
14. Packaging
External Packaging (Bulk)
Internal Packaging (Bulk)
External Packaging (Taping)
Internal Packaging (Taping)
Dimension Description (cm)
L
B
H
L
B
H
41.0
29.0
16.0
18.6
27.3
12.6
L
B
H
54.0
36.0
26.3
B
A
C
4.4
33.5
26.2
12
SPQ Reference Table
Type
Specification
P=5 B
P=7.5 E
Bulk
P=10
Type
D
SPQ Quantity
Long Lead/Short Lead Φ≤13
500
Long Lead/Short Lead Φ≤8
1000
Long Lead/Short Lead Φ>8
500
Short lead
1000
Long Lead
500
Long Lead 14≦Φ
很抱歉,暂时无法提供与“G07E1E102MN0B0S0N0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.13651
- 50+0.12715
- 200+0.11935
- 600+0.11155
- 1500+0.10531
- 3000+0.10141
- 国内价格
- 20+0.27860
- 200+0.21990
- 1000+0.16870
- 2000+0.14920
- 10000+0.13200
- 20000+0.12310
- 国内价格
- 20+0.29765
- 200+0.23987
- 1000+0.18933
- 2000+0.17010
- 10000+0.15336
- 20000+0.14440
