KTS251B155K55N0T00
KTS251B155K55N0T00
    NCC(贵弥功)
    贴片电容(MLCC) 2220 1.5µF ±10% 250V X7R
KTS251B155K55N0T00 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS NTS Series (General product) / NTF RoHS2 Compliant Series Temperature cycle : 1000 cycles ◆FEATURES 1. Large capacitance by small size. 2. X7R and X7S temperature characteristics. 3. High permissible ripple current capability. 4. NTF: Temperature cycle : 1000 cycles. ◆APPLICATIONS 1. Smoothing circuit of DC-DC converters. 2. On-board power supplies. 3. Voltage regulators for computers. 3. Noise suppressor for various kinds of equipments. 4. High reliability equipments. ◆CONSTRUCTION Ceramic Dielectric Termination (Tin Plating) Internal Electrode ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55 to +125℃ 25, 35, 50, 100, 250, 500Vdc 0.010 to 47µF M (±20%) : Standard, K (±10%) X7R See No.5 on the following table ◆SPECIFICATIONS No. 1 Items Withstand Voltage Specification No abnormality. Test Condition Rated voltage Withstand voltage Less than 250V 250% of rated voltage More than 250V Less than 500V 100V + 150% of rated voltage 130% of rated voltage More than 500V Shall be applied for 5 seconds. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. 3 Rated Capacitance Within specified tolerance. Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. CR>10µF CR≦10µF Temperature 4 5 Dissipation Factor Rated Ripple Current 25±2℃ X7R temperature characteristics of 5.0% or less X7S temperature characteristics of 7.5% or less Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms See STANDARD RATINGS 10kHz~1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 13 CAT. No. E1002Z Ver.2 MULTILAYER CERAMIC CHIP CAPACITORS NTS Series / NTF Series ◆SPECIFICATIONS No. 6 Items Adhesion Specification Test Condition No visible damage. Substrate 5N (0.51kgf) for 10±1 seconds Capacitor 7 Bend strength of the face plating Appearance : No visible damage. ΔC/C : ±15% The substrate shall be bend at a rate of 1mm/s for 5 seconds. Press Press bar Capacitor Substrate Bending capability* 45±2mm 45±2mm Support *Bending capability NTS : 1mm NTF : 1mm or 2mm 8 Solderability Min. 75% of surface of the termination shall be covered with new solder 9 Resistance to Soldering Heat Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Solder Solder Temperature Dipping Time Pb Free 245±5℃ 2±0.5sec. Preheating Condition : Step 1 2 Temperature 100±10℃ 200±10℃ Time 2min. 2min. Solder Temperature : 260±5℃ Dipping Time : 2±0.5 seconds 10 Temperature Cycle Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Step 1 2 3 4 Temperature (℃) Min. Category temperature ±3 Room temperature Max. Category temperature ±3 Room temperature (min.) 30±3 3 max. 30±3 3 max. For above temperature cycle. NTS : For 5 cycles NTF : For 1000 cycles 11 Humidity Load Life Appearance : No abnormality. ΔC/C : ±15% I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Dissipation Factor X7R temperature characteristics D.F: 10% or less X7S temperature characteristics D.F: 15% or less Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500±24 0 hours 12 Endurance Appearance : No abnormality. ΔC/C : ±15% I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Dissipation Factor X7R temperature characteristics D.F: 10% or less X7S temperature characteristics D.F: 15% or less Temperature : 125±3℃ Voltage : Rated voltage Time : 1000±48 0 hours *CR : Rated Capacitance(µF) Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 14 CAT. No. E1002Z Ver.2 MULTILAYER CERAMIC CHIP CAPACITORS NTS Series ◆STANDARD RATINGS Rated voltage Rated Capacitance (μF) (Vdc) 25 35 50 100 1.0 1.5 2.2 3.3 3.3 4.7 6.8 10 10 15 22 22 33 47 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 4.7 6.8 10 10 15 22 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 1.0 1.5 2.2 3.3 1.5 2.2 3.3 4.7 6.8 3.3 4.7 6.8 10 6.8 Electrostatic Capacitance Temperature Characteristics X7R X7R X7R X7S X7R X7R X7R X7S X7R X7R X7S X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R L W T max. a Maximum ripple current (Arms) 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 0.8±0.5 2.0 7.5±0.5 6.3±0.5 2.8 3.0 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 7.5±0.5 6.3±0.5 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 7.5±0.5 6.3±0.5 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 0.6±0.3 1.0 0.6±0.3 1.0 Dimensions(mm) 3.2±0.4 4.5±0.4 3.2±0.5 3.2±0.4 5.7±0.4 7.5±0.5 5.0±0.4 6.3±0.5 2.8 3.2 2.8 2.8 0.8±0.5 3.2 2.8 3.5 1.0±0.4 1.0±0.5 2.0 3.0 ※Please consult with us when you consider the rating other than a standard table. Part Number Taping Quantity per reel (pcs. / reel) KTS250B105M31N0T00 KTS250B155M31N0T00 KTS250B225M31N0T00 KTS250S335M31N0T00 KTS250B335M32N0T00 KTS250B475M32N0T00 KTS250B685M32N0T00 KTS250S106M32N0T00 KTS250B106M43N0T00 KTS250B156M43N0T00 KTS250S226M43N0T00 KTS250B226M55N0T00 KTS250B336M55N0T00 KTS250B476M76N0T00 KTS350B105M31N0T00 KTS350B155M31N0T00 KTS350B225M31N0T00 KTS350B335M32N0T00 KTS350B475M32N0T00 KTS350B685M43N0T00 KTS350B106M43N0T00 KTS350B156M55N0T00 KTS350B226M55N0T00 KTS350B336M76N0T00 KTS350B476M76N0T00 KTS500B334M31N0T00 KTS500B474M31N0T00 KTS500B684M31N0T00 KTS500B105M31N0T00 KTS500B155M31N0T00 KTS500B225M31N0T00 KTS500B155M32N0T00 KTS500B225M32N0T00 KTS500B335M32N0T00 KTS500B475M32N0T00 KTS500B475M43N0T00 KTS500B685M43N0T00 KTS500B106M43N0T00 KTS500B106M55N0T00 KTS500B156M55N0T00 KTS500B226M76N0T00 KTS101B104M31N0T00 KTS101B154M31N0T00 KTS101B224M31N0T00 KTS101B334M31N0T00 KTS101B474M31N0T00 KTS101B684M31N0T00 KTS101B105M31N0T00 KTS101B155M31N0T00 KTS101B225M31N0T00 KTS101B105M32N0T00 KTS101B155M32N0T00 KTS101B225M32N0T00 KTS101B335M32N0T00 KTS101B155M43N0T00 KTS101B225M43N0T00 KTS101B335M43J0T00 KTS101B475M43E0T00 KTS101B685M43N0T00 KTS101B335M55N0T00 KTS101B475M55N0T00 KTS101B685M55F0T00 KTS101B106M55NHT00 KTS101B685M76N0T00 3,000 3,000 3,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 300 3,000 3,000 3,000 1,600 1,600 800 800 800 800 300 300 3,000 3,000 3,000 3,000 2,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 300 3,000 3,000 3,000 3,000 3,000 3,000 2,000 2,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 800 800 800 800 300 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 15 CAT. No. E1002Z Ver.2 MULTILAYER CERAMIC CHIP CAPACITORS NTS Series ◆STANDARD RATINGS 0.01 0.022 0.033 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 1.5 2.2 0.47 0.56 0.68 1.0 1.2 250 500 Electrostatic Capacitance Temperature Characteristics X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R Dimensions(mm) L W Tmax. a Maximum ripple current (Arms) 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 1.0±0.5 3.0 0.8±0.5 1.5 1.0±0.5 2.0 7.5±0.5 6.3±0.5 5.7±0.4 5.0±0.4 7.5±0.5 6.3±0.5 3.5 5.0 2.7 3.0 2.5 3.2 3.5 ※Please consult with us when you consider the rating other than a standard table. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 KTS251B103M31N0T00 KTS251B223M31N0T00 KTS251B333M31N0T00 KTS251B473M31N0T00 KTS251B683M31N0T00 KTS251B104M31N0T00 KTS251B154M32N0T00 KTS251B224M32N0T00 KTS251B334M32N0T00 KTS251B474M43N0T00 KTS251B684M43N0T00 KTS251B105M55N0T00 KTS251B155M55N0T00 KTS251B155M76N0T00 KTS251B225M76N0T00 KTS501B474M55N0T00 KTS501B564M55N0T00 KTS501B684M76N0T00 KTS501B105M76N0T00 KTS501B125M76N0T00 3,000 3,000 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 300 300 800 800 500 300 300 ◆DIMENSIONS 18 K TS 101 B 225 M 32 N0 T 00 Size Code Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Size Code Code JIS T ◆PART NUMBERING SYSTEM Taping Quantity per reel (pcs. / reel) Part Number 3216 1206 43 4532 1812 32 55 76 3225 5750 7563 L EIA 31 1210 2220 W Rated voltage Rated Capacitance (Vdc) (µF) a 3025 Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 16 CAT. No. E1002Z Ver.2 MULTILAYER CERAMIC CHIP CAPACITORS NTF Series ◆STANDARD RATINGS Rated voltage Rated Capacitance (μF) (Vdc) 25 35 50 100 1.0 1.5 2.2 3.3 3.3 4.7 6.8 10 10 15 22 22 33 47 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 4.7 6.8 10 10 15 22 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 1.0 1.5 2.2 3.3 1.5 2.2 3.3 4.7 6.8 4.7 6.8 10 Electrostatic Capacitance Temperature Characteristics X7R X7R X7R X7S X7R X7R X7R X7S X7R X7R X7S X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R L W T max. a Maximum ripple current (Arms) 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 0.8±0.5 2.0 7.5±0.5 6.3±0.5 2.8 3.0 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 4.5±0.4 3.2±0.4 2.8 0.6±0.3 1.0 5.7±0.4 5.0±0.4 2.8 0.8±0.5 2.0 7.5±0.5 6.3±0.5 4.0 1.0±0.5 3.0 3.2±0.2 1.6±0.2 1.8 0.5±0.3 0.3 3.2±0.4 2.5±0.3 2.6 0.6±0.3 0.5 0.6±0.3 1.0 0.6±0.3 1.0 Dimensions(mm) 3.2±0.4 4.5±0.4 3.2±0.5 3.2±0.4 5.7±0.4 5.0±0.4 2.8 3.2 2.8 2.8 3.2 2.8 0.8±0.5 1.0±0.4 2.0 ※Please consult with us when you consider the rating other than a standard table. Part Number Taping Quantity per reel (pcs. / reel) KTF250B105M31NLT00 KTF250B155M31NLT00 KTF250B225M31NLT00 KTF250S335M31NLT00 KTF250B335M32NHT00 KTF250B475M32NHT00 KTF250B685M32NHT00 KTF250S106M32NHT00 KTF250B106M43NHT00 KTF250B156M43NHT00 KTF250S226M43NHT00 KTF250B226M55NHT00 KTF250B336M55NHT00 KTF250B476M76NHT00 KTF350B105M31NLT00 KTF350B155M31NLT00 KTF350B225M31NLT00 KTF350B335M32NHT00 KTF350B475M32NHT00 KTF350B685M43NHT00 KTF350B106M43NHT00 KTF350B156M55NHT00 KTF350B226M55NHT00 KTF500B334M31NLT00 KTF500B474M31NLT00 KTF500B684M31NLT00 KTF500B105M31NLT00 KTF500B155M31NLT00 KTF500B225M31NLT00 KTF500B155M32NHT00 KTF500B225M32NHT00 KTF500B335M32NHT00 KTF500B475M32NHT00 KTF500B475M43NHT00 KTS500B685M43NHT00 KTF500B106M43NHT00 KTF500B106M55NHT00 KTF500B156M55NHT00 KTF500B226M76NHT00 KTF101B104M31NLT00 KTF101B154M31NLT00 KTF101B224M31NLT00 KTF101B334M31NLT00 KTF101B474M31NLT00 KTF101B684M31NlT00 KTF101B105M31NLT00 KTF101B155M31NLT00 KTF101B225M31NLT00 KTF101B105M32NHT00 KTF101B155M32NHT00 KTF101B225M32NHT00 KTF101B335M32NHT00 KTF101B155M43NHT00 KTF101B225M43NHT00 KTF101B335M43JHT00 KTF101B475M43EHT00 KTF101B685M43NHT00 KTF101B475M55NHT00 KTF101B685M55FHT00 KTF101B106M55NHT00 3,000 3,000 3,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 300 3,000 3,000 3,000 1,600 1,600 800 800 800 800 3,000 3,000 3,000 3,000 2,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 300 3,000 3,000 3,000 3,000 3,000 3,000 2,000 2,000 2,000 1,600 1,600 1,600 1,600 800 800 800 800 800 800 800 800 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 17 CAT. No. E1002Z Ver.2 3.3 4.7 6.8 10 15 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 Series 2.2 1.5 2.2 RATINGS ◆STANDARD 3.3 Electrostatic Rated voltage Rated4.7 Capacitance Capacitance 4.7 Temperature (Vdc) (µF) Characteristics 6.8 0.033 X7R 0.047 X7R 0.068 X7R 0.1 X7R 0.15 X7R 250 0.22 X7R 0.33 X7R 0.47 X7R 0.68 X7R 1.0 X7R 1.5 X7R 0.47 X7R 500 0.56 X7R KTF500B335M32NHT00 KTF500B475M43NHT00 KTF500B685M43NHT00 KTF500B106M55NHT00 KTF500B156M55NHT00 KTF101B104M31NLT00 KTF101B154M31NLT00 KTF101B224M31NLT00 KTF101B334M31NLT00 KTF101B474M31NLT00 KTF101B684M31NLT00 KTF101B105M32NHT00 KTF101B155M32NHT00 KTF101B225M32NHT00 KTF101B155M43NHT00 KTF101B225M43NHT00 KTF101B335M43JHT00 KTF101B475M43EHT00 Part Number KTF101B475M55NHT00 MULTILAYER CERAMIC CHIP CAPACITORS NTF Tmax. a Maximum ripple current (Arms) 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 1.0±0.4 2.0 5.0±0.4 2.7 3.0 1.0±0.4 1.5 Dimensions(mm) L W 3.2±0.3 5.7±0.4 3.2 KTF101B685M55FHT00 KTF251B333M31NLT00 KTF251B473M31NLT00 KTF251B683M31NLT00 KTF251B104M31NLT00 KTF251B154M32NLT00 KTF251B224M32NLT00 KTF251B334M32NLT00 KTF251B474M43NLT00 KTF251B684M43NLT00 KTF251B105M55NLT00 KTF251B155M55NLT00 KTF501B474M55NLT00 KTF501B564M55NLT00 1,600 800 800 800 800 3,000 3,000 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 Taping 800 Quantity800 per reel (pcs.800 / reel) 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 800 800 ※Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆DIMENSIONS 18 K T F 1 0 1 B 2 2 5 M 3 2 NH T 0 0 Size Code Supplement code Taping code Terminal code (Bending NL:1mm, NH:2mm) Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Size Code Code JIS T 1 3216 1206 43 4532 1812 32 55 76 3225 5750 7563 L EIA 31 1210 2220 W ◆PART NUMBERING SYSTEM a 3025 Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 18 CAT. No. E1002Z Ver.2
KTS251B155K55N0T00 价格&库存
很抱歉,暂时无法提供与“KTS251B155K55N0T00”相匹配的价格&库存,您可以联系我们找货
