TFCR0603-16W-C-90R9DT-1K
    VENKEL
    90.9Ω ±0.5% 62.5MW
TFCR0603-16W-C-90R9DT-1K 数据手册
TFCR SERIES PRECISION THIN FILM RESISTORS FEATURES: • TCR as low as ±25ppm • Higher operating frequency with less parasitics • Noise characteristics superior to standard thick film resistors • Reference standards of EIA JIS C 5201-1 • Tolerance as low as ±0.1% PART NUMBER STRUCTURE TFCR 1206 Series Size 0201 0402 0603 0805 1206 1210 2010 2512 - 8W - E Power Rating 32W = 0.03W 20W = 0.05W 16W = 0.063W 10W = 0.10W 8W = 0.125W 4W = 0.25W 2W = 0.50W - TCR E = ±25ppm/˚C C = ±50ppm/˚C K = ±100ppm/˚C 1001 B T M Resistance Value 1001 = 1KΩ 4 digit code e.g. 4R70 = 4.7Ω 1001 = 1KΩ 2494 = 2.49MΩ Resistance Tolerance B = ±0.1% C = ±0.25% D = ±0.50% F = ±1% Packaging T = Tape & Reel Optional Reel Identifier Leave blank for standard quantity. Example P/N: TFCR1206-8W-E-1001BT Add "-1K" if 1000 piece reel is required Standard Termination is 100% matte Tin over Nickel. DIMENSIONS Unit: inches (mm) L W ι1 ι1 T ι2 ι2 SIZE L W T i1 i2 0201 0.023 ± 0.001 (0.60 ± 0.03) 0.011 ± 0.001 (0.30 ± 0.03) 0.009 ± 0.001 (0.23 ± 0.03) 0.006 ± 0.002 (0.15 ± 0.05) 0.006 ± 0.002 (0.15 ± 0.05) 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.019 ± 0.002 (0.5 ± 0.05) 0.012 ± 0.002 (0.30 ± 0.05) 0.008 ± 0.004 (0.2 ± 0.10) 0.008 ± 0.004 (0.2 ± 0.10) 0603 0.061 ± 0.004 (1.55 ± 0.10) 0.031 ± 0.004 (0.8 ± 0.1) 0.018 ± 0.004 (0.45 ± 0.10) 0.012 ± 0.008 (0.30 ± 0.20) 0.012 ± 0.008 (0.30 ± 0.20) 0805 0.079 ± 0.006 (2.0 ± 0.15) 0.049± 0.006 (1.25 ± 0.15) 0.022 ± 0.004 (0.55 ± 0.10) 0.012 ± 0.008 (0.30 ± 0.20) 0.016 ± 0.010 (0.40 ± 0.25) 1206 0.120 ± 0.006 (3.05 ± 0.15) 0.061 ± 0.006 (1.55 ± 0.15) 0.022 ± 0.004 (0.55 ± 0.10) 0.017 ± 0.008 (0.42 ± 0.20) 0.014 ± 0.010 (0.35 ± 0.25) 1210 0.122 ± 0.006 (3.10 ± 0.15) 0.094 ± 0.006 (2.40 ± 0.15) 0.022 ± 0.004 (0.55 ± 0.10) 0.016 ± 0.008 (0.40 ± 0.20) 0.022 ± 0.010 (0.55 ± 0.25) 2010 0.193 ± 0.006 (4.90 ± 0.15) 0.094 ± 0.006 (2.40 ± 0.15) 0.022 ± 0.004 (0.55 ± 0.10) 0.024 ± 0.012 (0.60 ± 0.30) 0.020 ± 0.010 (0.50 ± 0.25) 2512 0.248 ± 0.006 (6.30 ± 0.15) 0.122 ± 0.006 (3.10 ± 0.15) 0.022 ± 0.004 (0.55 ± 0.10) 0.024 ± 0.012 (0.60 ± 0.30) 0.020 ± 0.010 (0.50 ± 0.25) STRUCTURE 3 8 4 1 6 7 9 5 1 Alumina Substrate 5 Nickel Plating 2 Backside Electrode 6 Tin Plating 3 Top Electrode 7 Resistive layer 4 Edge Electrode 8 Overcoat 2 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 1 TFCR SERIES PRECISION THIN FILM RESISTORS ELECTRICAL SPECIFICATION & RANGE SIZE 0201 Power Rating at 70°C (W) 0.03W (1/32W) 0402 0.05W (1/20W) 0603 0.063W (1/16W) 0.063W (1/16W) 0805 0.10W (1/10W) 0.10W (1/10W) 0.125W (1/8W) 1206 0.125W (1/8W) 0.25W (1/4W) 1210 2010 2512 0.25W (1/4W) 0.25W (1/4W) 0.50W (1/2W) Max. Working Voltage 15V 25V 50V 100V 150V 150V 150V 150V Max. Overload Voltage 30V 50V 100V 200V 300V 300V 300V 300V Operating Temp. Range -55°C to +125°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C Tolerance TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±25ppm 100Ω - 10KΩ 100Ω - 12KΩ 10Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 2MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 3MΩ 4.7Ω - 3MΩ ±0.1% (B) ±50ppm 100Ω - 10KΩ 100Ω - 12KΩ 10Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 2MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 3MΩ 4.7Ω - 3MΩ ±100ppm 100Ω - 10KΩ - 10Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 2MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ 4.7Ω - 3MΩ 4.7Ω - 3MΩ ±25ppm 100Ω - 10KΩ - 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ ±0.25% (C) ±0.5% (D) 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±50ppm 100Ω - 10KΩ - 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±100ppm 100Ω - 10KΩ - 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±25ppm - 27Ω - 12KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±50ppm 49.9Ω-33KΩ 27Ω - 22.1KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±100ppm 49.9Ω-33KΩ 27Ω - 22.1KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±25ppm ±1% (F) 1Ω - 2MΩ Resistance Resistance Range Range - 27Ω - 12KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ ±50ppm 49.9Ω-33KΩ 27Ω - 22.1KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ ±100ppm 49.9Ω-33KΩ 27Ω - 22.1KΩ 4.7Ω - 511KΩ 1Ω - 1MΩ 4.7Ω - 1MΩ 1Ω - 2MΩ 1Ω - 1MΩ 1Ω - 2.49MΩ 4.7Ω - 1MΩ 1Ω - 2.49MΩ 1Ω - 3MΩ 1Ω - 3MΩ NOTE: Max Working Voltage is listed above or √(P*R), whichever is lower. Max overload Voltage is listed above or 2.5*√(P*R), whichever is lower. MARKING CODE • E-24 values for 0603 size maybe marked with the standard 3 digit marking code. • E-96 values for 0805 size and larger, will be marked with standard 4 digit marking code. • E-24 values for 0603 size and larger, will be marked with standard 3 digit marking code. • 0603 - E-96 values will be marked with a standard 3 digit alpha numeric code Please see 0603 marking codes PDF. Note: 0201 and 0402 cannot be marked. DERATING CURVE Rated power (%) 120 100 80 60 40 20 0 -50 -55 -25 0 25 50 75 100 70 Ambient temperature (˚C) 0201 Size Email: sales@venkel.com 125 150 175 0402 to 2512 Size | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 2 TFCR SERIES PRECISION THIN FILM RESISTORS REEL SPECIFICATIONS F Label H Unit: mm (inch) M C E C E F G H M 13.0 ± 0.2 (0.51 ± 0.008) 60.0 ± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0.45 ± 0.04) 9.0 ± .3 (0.35 ± 0.012) 1.5 ± .3 (0.06 ± 0.012) 180 ± 2.0 (7.09 ± 0.08) Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G TAPE SPECIFICATIONS T G B A W F T J Dø Embossed H Paper E Units: mm TAPE SIZE (in) A B W E F T G H J Dø 0201 0.70±0.05 0.40±0.05 8.0±0.10 1.75±0.05 3.50±0.05 0.42±0.02 2.00±0.05 4.00±0.10 2.00±0.05 1.55±0.03 0402 1.16±0.10 0.70±0.10 8.0±0.10 1.75±0.05 3.50±0.05 0.40±0.03 2.00±0.05 4.00±0.10 2.00±0.05 1.55±0.05 0603 1.90±0.10 1.10±0.05 8.0±0.10 1.75±0.05 3.50±0.05 0.60±0.03 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0805 2.37±0.20 1.60±0.05 8.0±0.10 1.75±0.05 3.50±0.05 0.75±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 1206 3.55±0.05 2.00±0.05 8.0±0.10 1.75±0.05 3.50±0.05 0.75±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 1210 3.40±0.05 2.75±0.05 8.0±0.10 1.75±0.05 3.50±0.05 0.75±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.60±0.10 2010 5.45±0.10 2.85±0.10 12.00±0.10 1.75±0.10 5.50±0.05 1.00 +0.20, -0 4.00±0.10 4.00±0.10 2.00±0.05 1.50 +0.1, -0 2512 6.65±0.10 3.40±0.10 12.00±0.10 1.75±0.10 5.50±0.05 1.00 +.02.0, -0 4.00±0.10 4.00±0.10 2.00±0.05 1.50 +0.1, -0 Paper Embossed PEEL BACK FORCE AND DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 3 TFCR SERIES PRECISION THIN FILM RESISTORS ENVIRONMENTAL CHARACTERISTICS REQUIREMENT TEST Tol. ≤0.05% Temperature Coefficient of Resistance (T.C.R.) Short Time Overload TEST METHOD Tol. >0.05% MIL-STD-202 Method 304 +25/-55/+125/+25°C As Spec. ΔR±0.05 % ΔR±0.02% JIS-C-5201-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds ΔR±0.02% for high power rating Insulation Resistance MIL-STD-202 Method 302 Apply 100VDC for 1 minute >9999MΩ ΔR±0.05% ΔR±0.02% ΔR±0.05% for high power rating MIL-STD-202 Method 108A 70±2°C RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Endurance 0201:>7kΩ→ΔR±0.05% ≤7kΩ→ΔR±0.02% Damp Heat with Load Bending Strength Solderability Resistance to Soldering Heat ΔR±0.05% ΔR±0.3% ΔR±0.5% for high power rating ΔR±0.05% JIS-C-5201-1 4.33 Bending amplitude 3mm for 10 seconds 2010 / 2512 sizes: 2mm Other sizes: 3mm ΔR±0.1% MIL-STD-202 Method 208H 245±5°C for 3 seconds 95% min. coverage ΔR±0.05% MIL-STD-202 Method 210E 260±5°C for 10 seconds ΔR±0.1% Dielectric Withstanding Voltage Low Temperature Operation MIL-STD-202 Method 103B 40±2°C 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” MIL-STD-202 Method 301 Max. Overload Voltage for 1 minute By Type ΔR±0.05% ΔR±0.2% JIS-C-5201-1 4.36 1 hour, -65°C, followed by 45 minutes of RCWV ΔR±0.5% for high power rating High Temperature Exposure MIL-STD-202 Method 108 at +155°C for 1000 hrs ΔR±0.05% RCWV (Rated continuous working voltage) = √(P*R) or Max operating voltage whichever is lower Storage Temperature: 25±3°C; Humidity
物料型号:TFCR系列
器件简介:TFCR系列是Venkel Ltd生产的精密薄膜电阻器,具有低温度系数(TCR低至±25ppm)、高工作频率、优越的噪声特性,符合EIA JIS C 5201-1标准,并且有RoHS和REACH合规性。
引脚分配:文档中未明确提供引脚分配信息,但通常薄膜电阻器为两个端子。
参数特性: - 尺寸:0201至2512,不同尺寸具有不同的功率额定值和TCR。 - 功率额定值:从0.03W至2W不等。 - 最大工作电压:根据尺寸不同,从15V至150V不等。 - 电阻公差:从±0.1%至±1%不等。 - TCR:从+25ppm至+100ppm不等。
功能详解:TFCR系列电阻器适用于需要高精度和稳定性的应用场合,例如在高温或高频率环境下。
应用信息:适用于需要低TCR、高稳定性和优越噪声特性的场合。
封装信息:提供了详细的尺寸数据,包括长度、宽度、厚度等,以及标准封装结构。
TFCR0603-16W-C-90R9DT-1K 价格&库存
很抱歉,暂时无法提供与“TFCR0603-16W-C-90R9DT-1K”相匹配的价格&库存,您可以联系我们找货
