CRG
SERIES
GENERAL PURPOSE RoHS 10/10 GREEN RESISTORS
FEATURES:
• TCR as low as ±100ppm
• Available Sizes 01005 to 2512
• 100% matte Tin over Nickel with wrap around termination
for excellent solderability
PART NUMBER STRUCTURE
CRG
1206
Series
Size
01005
0201
0402
0603
0805
1206
1210
2010
2512
T
Power rating
M = 1/32W (0.03W)
N = 1/20W (0.05W)
P = 1/16W (0.063W)
Q = 1/10W (0.10W)
R = 1/8W (0.125W)
T = 1/4W (0.25W)
U = 1/3W (0.33W)
V = 1/2W (0.5W)
X = 1W (1.0W)
103
J
T
Resistance
Tolerance
F = ± 1%
J = ± 5%
Packaging
T = Tape & Reel
Optional Reel Identifies
Leave blank if standard
Reel size.
3 DIGIT
(J TOL.)
2R2=2.2Ω
103=10KΩ
4 DIGIT
(F TOL.)
10R2=10.2Ω
1002=10KΩ
Jumper
3 zeros
No tolerance
specified for the
zero ohm
Add “-13” if 13” Reel is
required
Leave blank for
zero ohm value
Example P/N: CRG1206-T-103JT
Standard temination finish is 100% matte Tin (Sn) over Nickel.
DIMENSIONS
Unit: inches (mm)
SIZE
L
W
T
C1
C2
01005
0.016 ± 0.0008
(0.40 ± 0.02)
0.008 ± 0.0008
(0.20 ± 0.02)
0.005 ± 0.0008
(0.13 ± 0.02)
0.003 ± 0.0012
(0.08 ± 0.03)
0.004 ± 0.0012
(0.10 ± 0.03)
0201
0.023 ± 0.0012
(0.60 ± 0.03)
0.012 ± 0.0012
(0.30 ± 0.03)
0.009 ± 0.0012
(0.23 ± 0.03)
0.004 ± 0.002
(0.10 ± 0.05)
0.005 ± 0.002
(0.15 ± 0.05)
0402
0.039 ± 0.002
(1.00 ± 0.05)
0.0191 ± 0.002
(0.50 ± 0.05)
0.013 ± 0.002
(0.35 ± 0.05)
0.007 ± 0.004
(0.20 ± 0.10)
0.010 ± 0.004
(0.25 ± 0.10)
0603
0.062 ± 0.004
(1.60 ± 0.10)
0.031 ± 0.004
(0.80 ± 0.10)
0.017 ± 0.006
(0.45 ± 0.15)
0.012 ± 0.003
(0.30 ± 0.10)
0.012 ± 0.006
(0.30 ± 0.15)
0805
0.078 ± 0.004
(2.00 ± 0.10)
0.049 ± 0.004
(1.25 ± 0.10)
0.019 ± 0.006
(0.50 ± 0.15)
0.0151 ± 0.008
(0.40 ± 0.20)
0.015 ± 0.008
(0.40 ± 0.20)
1206
0.122 ± 0.003
(3.10 ± 0.10)
0.063 ± 0.004
(1.60 ± 0.10)
0.0236 ± 0.006
(0.60 ± 0.15)
0.019 ± 0.008
(0.50 ± 0.20)
0.017 ± 0.008
(0.45 ± 0.20)
1210
0.122 ± 0.003
(3.10 ± 0.10)
0.102 ± 0.004
(2.60 ± 0.10)
0.0215 ± 0.004
(0.55 ± 0.10)
0.019 ± 0.007
(0.50 ± 0.20)
0.019 ± 0.008
(0.50 ± 0.20)
2010
0.20 ± 0.004
(5.0 ± 0.20)
0.098 ± 0.008
(2.50 ± 0.20)
0.0215 ± 0.004
(0.55 ± 0.10)
0.0256 ± 0.01
(0.65 ± 0.25)
0.0236 ± 0.01
(0.60 ± 0.25)
2512
0.252 ± 0.008
(6.4 ± 0.20)
0.126 ± 0.008
(3.20 ± 0.20)
0.24 ± 0.008
(0.60 ± 0.10)
0.0256 ± 0.008
(0.65 ± 0.25)
0.0354 ± 0.01
(0.90 ± 0.25)
L
W
C1
C1
T
C2
C2
STRUCTURE
7
6
4
9
1
8
2
3
5
Email: sales@venkel.com
Phone: 512.794.0081 |
1
Alumina Substrate
6
Primary Coating
2
Backside Electrode
7
Protective Coating
3
Topside Electrode
8
Barrier Layer (Ni)
4
Edge Electrode
9
Termination-100% matte Tin
5
Resistive Layer
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 06/2020-A
1
CRG
SERIES
ELECTRICAL SPECIFICATIONS & RANGE
SIZE
01005
0201
0402
0603
0805
1206
1210
2010
2512
Power Rating
at 70°C (W)
0.03W
(1/32W)
0.05W
(1/20W)
0.063W
(1/16W)
0.10W
(1/10W)
0.125W
(1/8W)
0.25W
(1/4W)
0.33W
(1/3W)
0.5W
(1/2W)
1W
Max.
Working
Voltage
√PR or 25V
whichever
is less
√PR or 25V
whichever
is less
√PR or 50V
whichever
is less
√PR or 50V
whichever
is less
√PR or 150V
whichever
is less
√PR or 200V
whichever
is less
√PR or 200V
whichever
is less
√PR or 200V
whichever
is less
√PR or 250V
whichever
is less
Operating
Temp. Range
-55 to +125°C
-55 to +125°C
-55 to + 155°C
-55 to +155°C
-55 to +155°C
-55 to +155°C
-55 to +155°C
-55 to +155°C
-55 to +155°C
0.5A
0.5A
1A
1A
1.5A
2A
2.5A
3.2A
4.5A
TCR
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
± 100
10.2Ω - 976KΩ
10.2Ω - 976KΩ
10.2Ω - 976KΩ
10.2Ω - 976KΩ
10.2Ω - 976KΩ
10Ω - 10MΩ
10.Ω - 10MΩ
1Ω - 10Ω
Zero ohm
Current Rating
(Jumpers)
Tolerance
±1% (F)
±5% (J)
± 200
100Ω - 1MΩ
100Ω - 1MΩ
1MΩ - 10MΩ
1MΩ - 10MΩ
1MΩ - 10MΩ
1MΩ - 10MΩ
1Ω - 10Ω
± 300
1MΩ - 10MΩ
-300/+ 500
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
+600/-0
10Ω - 97.6Ω
10Ω - 97.6Ω
+800/-100
1Ω - 9.76Ω
± 100
10Ω - 10MΩ
10Ω - 10MΩ
1Ω - 10Ω
± 200
100Ω - 1MΩ
100Ω - 10MΩ
10.2Ω - 910KΩ
11Ω - 10MΩ
11Ω - 10MΩ
11Ω - 10MΩ
11Ω - 10MΩ
1Ω - 10Ω
± 300
1MΩ - 10MΩ
-300/+ 500
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
1Ω - 10Ω
+600/- 0
10Ω - 91Ω
10Ω - 91Ω
+800/-100
1Ω - 9.1Ω
NOTE: Overload Voltage=2.5*√(P*R).
DERATING CURVE
DERATING CURVE (CR Only)
Rated power (%)
120
100
80
60
40
-55
-25
50
75
100
70
Ambient temperature (˚C)
01005 & 0201 Size
125
150
175
0402 to 2512 Size
Web: www.venkel.com
Rev: 06/2020-A
2
CRG
SERIES
TAPE & REEL SPECIFICATIONS
REEL
I
F
Label
Unit: mm (inch)
H
M C
C
E
F
G
H
M
13.0 ± 0.20
(0.51 ± 0.008)
60.0± 1.0
(2.36 ± 0.03)
11.4 ± 1.0
(0345 ± 0.04)
9.0 ± 0.30
(0.35 ± 0.012)
1.5 ± 0.30
(0.06 ± 0.012)
178.0 ±2.0
(7.00 ± 0.08)
E
Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end.
G
T
G
B
TAPE
A
F
W
T
J
Dø
H
Embossed
E
Paper
All dimensions in mm
TAPE
Paper
SIZE
(INCHES)
A
B
W
E
F
T
G
H
J
DØ
01005
0.45
± 0.03
0.24
±0.03
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
0.40
± 0.05
2.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
0201
0.67
± 0.05
0.37
±0.05
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
0.45
± 0.05
2.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
0402
1.20
± 0.10
0.70
± 0.10
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
0.40
± 0.05
2.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
0603
1.90
± 0.20
1.10
± 0.20
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
0.65
± 0.05
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
0805
2.40
± 0.20
1.65
± 0.20
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
1.0
± 0.20
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
1206
3.60
± 0.20
2.00
± 0.20
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
1.0
± 0.20
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
1210
3.60
± 0.20
3.00
± 0.20
8.00
± 0.30
1.75
± 0.10
3.50
± 0.20
1.0
± 0.20
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
2010
5.50
± 0.20
2.80
± 0.20
12.00
± 0.30
1.75
± 0.10
5.50
± 0.10
1.0
± 0.20
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
2512
6.90
± 0.20
3.60
± 0.20
12.00
± 0.30
1.75
± 0.10
5.50
± 0.10
1.0
± 0.20
4.00
± 0.10
4.00
± 0.10
2.00
± 0.05
1.50
+ 0.1 - 0.0
PEEL BACK FORCE AND DIRECTION DIAGRAM
Direction of pull
Top cover tape
Carrier tape
165 ~ 180˚
Direction of unreeling
Bottom cover tape
Peel back force and direction of peel back angle should
follow EIA481-1-A. Peel back force should be between
0.1N – 1.3N and peel back angle of 165˚ – 180˚.
Web: www.venkel.com
Rev: 06/2020-A
3
CRG
SERIES
ENVIRONMENTAL CHARACTERISTICS
REQUIREMENT
TEST
RESISTOR
DC resistance
Clause 4.5
Within the specified tolerance
Temperature Coefficient of
Resistance (T.C.R)
Clause 4.8
TEST METHOD
0Ω
很抱歉,暂时无法提供与“CRG1206-T-9090FT”相匹配的价格&库存,您可以联系我们找货
