KTJ500B156M55BFT00
KTJ500B156M55BFT00
    NCC(贵弥功)
    Ceramic
    贴片电容(MLCC) CAP_6.1X5.1MM_SM 15µF ±20% 50V X7R
KTJ500B156M55BFT00 数据手册
METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS NTJ Series RoHS Compliant ◆FEATURES 1. Small size and large capacitance, high ripple current. 2. Temperature cycle: 1000 cycles. 3. X7R temperature characteristics. 4. Excellent noise absorption. 5. For reflow soldering use. 6. Suitable for aluminum substrate. ◆APPLICATIONS 1. Smoothing circuit of switching mode AC-DC or DC-DC converter. 2. On-board power supply. 3. Noise suppressor for various kinds of equipments. ◆CUSTOM MADE PRODUCTS We can offer custom made one element metal cap type capacitors for request of customers. Please contact us if you have questions for details. ◆CONSTRUCTION Chip Ceramic Capacitor Metal Cap, Tin plating Pb-free Soldering Termination ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55∼+125℃ 25, 50, 100, 250Vdc 1.0 to 100µF M(±20%) X7R See No.5 on the following table ◆SPECIFICATIONS No. Items Specification Test Condition 1 Withstand Voltage No abnormality. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. 3 Rated Capacitance Within specified tolerance. 250% of rated voltage shall be applied for 5 seconds. (Only 250Vdc products : 475V) Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. Temperature 4 5 Dissipation Factor Rated Ripple Current 5.0% maximum Size Element Arms 1 2.0 55 2 3.0 CR>10µF CR≦10µF 1 3.0 76 2 4.0 25±2℃ Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms 10kHz∼1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 20 CAT. No. E1002V METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS NTJ Series ◆SPECIFICATIONS No. 6 Items Specification Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Temperature Cycle Test Condition Step 1 2 3 4 Temperature (℃) Min. Category temperature ±3 Room temperature Max. Category temperature ±3 Room temperature 1000 cycles 7 Humidity Load Life Appearance : No abnormality. ΔC/C : ±20% D.F. : 10% max. I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500±24 hours 0 8 Endurance Appearance : No abnormality. ΔC/C : ±20% D.F. : 10% max. I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 125±3℃ Voltage : Rated voltage Time : 1000±48 0 hours (min.) 30±3 3 max. 30±3 3 max. *CR : Rated Capacitance(µF) ◆Note of mountig for NTJ series. 1. The gap of capacitor and a substrate shall be the mounting face. 2. To prevent degredation of temperature cycling capability, if need to be careful about amount of solder that would not go into the inner side of terminations. Substrate Gap Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 21 CAT. No. E1002V METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS NTJ Series ◆STANDARD RATINGS Dimensions(mm) Rated voltage Rated Capacitance (Vdc) (µF) 33 33 47 47 68 100 15 15 22 22 33 47 4.7 6.8 10 6.8 15 1.0 1.5 2.2 2.2 3.3 25 50 100 250 Element Maximum ripple current (Arms) L W Tmax. a 6.0±0.4 5.3±0.4 3.8 1.3±0.3 1 2.0 6.0±0.4 5.3±0.4 5.5 1.3±0.3 2 3.0 7.8±0.5 6.6±0.5 1 3.0 6.6±0.5 1.5±0.3 2 4.0 6.0±0.4 5.3±0.4 5.5 8.5 9.5 3.8 1.5±0.3 7.8±0.5 1.3±0.3 1 2.0 6.0±0.4 5.3±0.4 5.5 1.3±0.3 2 3.0 7.8±0.5 6.6±0.5 5.5 1.5±0.3 1 3.0 7.8±0.5 6.6±0.5 8.5 1.5±0.3 2 4.0 6.0±0.4 5.3±0.4 3.8 1.3±0.3 1 2.0 6.0±0.4 5.3±0.4 5.5 1.3±0.3 2 3.0 7.8±0.5 7.8±0.5 6.0±0.4 6.6±0.5 6.6±0.5 5.3±0.4 1.5±0.3 1.5±0.3 1.3±0.3 1 2 1 3.0 4.0 2.0 6.0±0.4 5.3±0.4 1.3±0.3 2 3.0 7.8±0.5 7.8±0.5 6.6±0.5 6.6±0.5 5.5 8.5 3.8 5.5 6.5 5.5 8.5 1.5±0.3 1.5±0.3 1 2 3.0 3.0 Part Number KTJ250B336M55AFT00 KTJ250B336M55BFT00 KTJ250B476M55BFT00 KTJ250B476M76AFT00 KTJ250B686M76BFT00 KTJ250B107M76BFT00 KTJ500B156M55AFT00 KTJ500B156M55BFT00 KTJ500B226M55BFT00 KTJ500B226M76AFT00 KTJ500B336M76BFT00 KTJ500B476M76BFT00 KTJ101B475M55AFT00 KTJ101B685M55BFT00 KTJ101B106M55BFT00 KTJ101B685M76AFT00 KTJ101B156M76BFT00 KTJ251B105M55AFT00 KTJ251B155M55BFT00 KTJ251B225M55BFT00 KTJ251B225M76AFT00 KTJ251B335M76BFT00 Taping Quantity per reel (pcs. / reel) 400 2,000 2,000 1,200 500 400 400 2,000 2,000 1,200 500 500 400 2,000 2,000 1,200 500 400 2,000 2,000 1,200 500 ※Please consult with us when you consider the rating other than a standard table. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ◆DIMENSIONS 16 17 18 T a W a W Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category T K T J 2 5 0 B 4 7 6 M 5 5 BF T 0 0 L L 1 Element 2 Elements Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 22 CAT. No. E1002V
KTJ500B156M55BFT00
1. 物料型号:文档中提供了多个型号,例如KTJ250B336M55AFT00、KTJ251B225M76AFT00等。型号编号系统包括了额定电压、电容值、尺寸、公差、温度特性等信息。
2. 器件简介:这些电容器具有小尺寸、大电容、高纹波电流、1000次温度循环、X7R温度特性、优良的降噪性能,并且适用于回流焊。
3. 引脚分配:文档没有明确说明引脚分配,但提到了电容器的安装方式,应与基板保持一定间隙。
4. 参数特性: - 工作温度范围:-55~+125°C - 额定电压范围:25, 50, 100, 250Vdc - 额定电容范围:1.0至100F - 额定电容公差:M(±20%) - 温度特性:X7R - 额定纹波电流:根据尺寸不同而不同
5. 功能详解:适用于开关模式AC-DC或DC-DC转换器的平滑电路、板上电源供应、各种设备的噪声抑制器。
6. 应用信息:文档提供了定制产品服务,可根据客户需求提供定制的金属帽型电容器。
7. 封装信息:封装包括芯片陶瓷电容器、金属帽锡镀层、无铅焊接端子。
8. 规格:包括耐压测试、绝缘电阻、额定电容、耗散因数、额定纹波电流等测试条件和要求。
KTJ500B156M55BFT00 价格&库存
很抱歉,暂时无法提供与“KTJ500B156M55BFT00”相匹配的价格&库存,您可以联系我们找货
