800R101JT500XT
800R101JT500XT
    ATC
    贴片电容(MLCC) 0709 100pF ±5% 500V C0G (NP0)
800R101JT500XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800R Series NPO Ceramic Ultra-Low ESR Multilayer Capacitors FEATURES • Case R Size (.070” x .090”) • Capable of highest RF Power • Rugged, reliable NPO dielectric • RoHS Compliant / Lead-Free • Optimized for highest self • Optimized for lowest ESR resonant frequency and superior heat transfer • Capacitance Range 1 pF to 100 pF PACKAGING OPTIONS GENERAL DESCRIPTION KYOCERA AVX’s 800 R Series offers superb performance in demanding high RF power applications requiring consistent and reliable operation. The combination of optimized case geometry, highly conductive electrode formulations and proprietary dielectrics, yields the lowest ESR and superior heat transfer. KYOCERA AVX’s new NPO low loss rugged dielectrics are designed to provide superior heat transfer in high RF power applications. Ultra-low ESR and superior thermal performance ensure that the 800 R Series products are your best choice for high RF power applications from UHF through microwave frequencies. • Digital HD FM Transmitters • Avionics • Digital HDTV Transmitters • Medical Electronics TYPICAL CIRCUIT APPLICATIONS • • • • High RF Power Filter Networks Matching Networks Output Coupling DC Blocking ENVIRONMENTAL CHARACTERISTICS Quality Factor (Q) • • • • Combiners Couplers Antenna Coupling Bypassing ENVIRONMENTAL TEST Insulation Resistance (IR) 1 pF to 100 pF: 105 Megohms min. @ +25°C at rated WVDC 104 Megohms min. @ +125°C at rated WVDC Working Voltage (WVDC) 500 WVDC Dielectric Withstanding Voltage (DWV) Case R: 250% of rated WVDC for 5 secs Aging Effects None Piezoelectric Effects None Capacitance Drift ±(0.02% or 0.02 pF), whichever is greater Operating Temperature Range From -55°C to +125°C Termination Styles RoHS Compliant and Solder Plate See Mechanical Configurations Terminal Strength Terminations for chips withstand a pull of 5 lbs. min., 15 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Test per MILSTD-202, Method 211. Thermal Shock MIL-STD-202, Method 107, Condition A. Moisture Resistance MIL-STD-202, Method 106. Low Voltage Humidity MIL-STD-202, Method 103, Condition A, with 1.5 Volts D.C. applied while subjected to an environment of 85°C with 85% relative humidity for 240 hours min. Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C 200% WVDC applied 562 > 2,000 @ 1 MHz Temperature Coefficient 0 ±30 PPM/°C (-55°C to +125°C) of Capacitance (TCC) TYPICAL APPLICATIONS • Homeland Security/Public Safety Radio (APCO-25) • WiMAX/LTE* • Satellite Systems • Microwave Communications Tape & Reel The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070121 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800R Series NPO Ceramic Ultra-Low ESR Multilayer Capacitors CAPACITANCE VALUES Cap. Code 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 2R4 2R7 3R0 3R3 3R6 Cap.(pF) 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.4 2.7 3.0 3.3 3.6 Tol. Rated WVDC B, C, D 500 Cap. Code 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 200 Cap. (pF) 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 Tol. Rated WVDC B, C, D B, C, J, K, M G, J K, M 500 Cap. Code 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 Cap. (pF) 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 Tol. Rated WVDC G, J K, M 500 VRMS = 0.707 X WVDC SPECIAL VALUES, TOLERANCES AND MATCHING AVAILABLE. PLEASE CONSULT FACTORY. HOW TO ORDER 800 R 100 J T 500 X T Series Packaging Case Size T = Tape and Reel, 500 pc. TS = Electrodes in Horizontal Orientation Tape and Reel: 500 pc. See mechanical dimensions below Capacitance Please see last Column Mechanical Configuration Table for other options EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Laser Marking (Optional) WVDC Capacitance Tolerance Code Code Tol. B C D ±0.1 pF ±0.25 pF ±0.5 pF G J K M ±2% ±5% ±10% ±20% Termination Code The above part number refers to a 800 R Series (case size R) 10 pF capacitor, J tolerance (±5%), 500 WVDC, with T termination (Tin Plated over Nickel Barrier, RoHS Compliant), laser marked, and tape and reel packaging. *Consult ATC for other quantities. Please see 2nd Column Mechanical Configuration Table The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – 563 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800R Series NPO Ceramic Ultra-Low ESR Multilayer Capacitors MECHANICAL CONFIGURATION Series & Case Size Term. Code Case Size & Type Body Dimensions inches (mm) Length (L) Width (W) Thickness (T) Outline ES W/T is a Termination Surface Lead and Termination Dimensions and Material Overlap (Y) Materials R 800R T Solderable Nickel Barrier R 800R W Solder Plate Pkg Type & Qty Pkg Code .070 ±.015 (1.78±0.38) .090 ±.010 (2.29±0.25) .115 (2.92) max. .010+.010 - .005 (0.25+0.25 - 0.13) RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Horizontal T&R, 1000 or 500 pcs T1K or T TS1K or TS .070 ±.015 (1.78±0.38) .090 ±.010 (2.29±0.25) .115 (2.92) max. .010+.010 - .005 (0.25+0.25 - 0.13) Tin/ Lead, Solder Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Horizontal T&R, 1000 or 500 pcs T1K or T TS1K or TS Pkg Type & Qty Pkg Code T&R, 1000 or 500 pcs Horizontal T&R, 1000 or 500 pcs T1K or T TS1K or TS NON-MAGNETIC CONFIGURATION Series & Case Size Term. Case Size Code & Type Non-Magnetic Configuration Body Dimensions inches (mm) Length (L) Width (W) Thickness (T) .070 ±.015 (1.78±0.38) .090 ±.010 (2.29±0.25) .115 (2.92) max. Lead and Termination Dimensions and Material Overlap (Y) Materials .010+.010 - .005 (0.25+0.25 - 0.13) RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination R 800R TN Non-Mag Solderable Barrier SUGGESTED MOUNTING PAD DIMENSIONS L W 391k 1k 39 T T L W Mount Type Horizontal Electrode Orientation Vertical Electrode Orientation B B Pad Size Normal Vertical Mount High Density Normal Horizontal Mount High Density A Min. .125 .115 .110 .090 Case R B Min. .050 .030 .050 .030 C Min. .030 .030 .030 .030 D Min. .130 .090 .130 .090 Dimensions are in inches. A C D 564 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070121 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 800R Series NPO Ceramic Ultra-Low ESR Multilayer Capacitors 1.00 800 R ESR vs. Frequency 800 R Resonance Vertical and Horizontal Orientation 100 W T 1.0 pF Frequency (GHz) L 3.3 pF ESR (Ohms) 10 pF 12 pF 0.10 15 pF 33 pF 47 pF 51 pF Horizontal Orientation T W L Vertical Orientation 10 Vertical Fpr Horizontal Fpr 100 pF Vertical & Horizontal Fsr Vertical Fpr Horizontal Fpr Vertical & Horizontal Fsr 1000 1 10000 Frequency (MHz) 1.0 10.0 100.0 Capacitance (pF) 800R Capacitance Change vs. Temperature 1 0.8 TCC= 0 ±30 PPM/C 0.6 0.4 % Change in Capacitance 0.01 100 0.2 0 -0.2 -0.4 -0.6 -0.8 -1 -55 -35 -15 5 25 45 65 85 105 125 Temperature (Degrees C) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 012021 – rf microwave products – 565
800R101JT500XT 价格&库存
很抱歉,暂时无法提供与“800R101JT500XT”相匹配的价格&库存,您可以联系我们找货
