MULTILAYER CERAMIC CHIP CAPACITORS
- GMC SERIES APPLICATIONS
- Can be used on surface mount assembly equipment
- Our fully integrated manufacturing and total quality
control systems ensure unprecedented high standards of
quality and reliability.
FEATURES
- Large capacitance values in small sizes
- Excellent high frequency characteristics
CHIP CAPACITOR SELECTION
DIELECTRIC TYPE
COG (NPO) - Capacitance change with temperature is 0-30ppml°C which is less than -0.3%°C from -55°C to +125°C.
Typical capacitance change with life is less than -0.1 % for NPOs, one-fifth that shown by most other dielectrics. NPO
formulations show no aging characteristics.
Ultra stable class I dielectric: linear temperature coefficient, low loss, negligible change of electrical properties with
time, voltage and frequency.
OPERATING
TEMPERATURE
RANGE
TEMPERATURE
COEFFICIENT
DISSIPATION
FACTOR
-55°C to° +125 C
0±30ppm°C
0.1% Max,
0.02% Typlical
DIELECTRIC
WITHSTANDING
VOLTAGE
AGING
RATE
•>100GΩ or 1000ΩF
•125°C VDCW: 10GΩF or 100ΩF
whichever is less
3 X VDCW
0% per
decade hour
INSULATION
RESISTANCE
TEST
PARAMETERS
• C1000pF f=1KHz
V=1.0Vrms ±0.2Vrms T=25°C
Stable class II dielectric
OPERATING
TEMPERATURE
RANGE
TEMPERATURE
COEFFICIENT
DISSIPATION
FACTOR
INSULATION
RESISTANCE
DIELECTRIC
WITHSTANDING
VOLTAGE
AGING
RATE
X7R: -55C to+125C
X5R: -55C to+85C
X6S: -55C to+105C
X7S: -55C to+125C
± 15%
± 15%
± 22%
± 22%
2.5% Max,
1.8% Typical
•25°C, VdCW: >100GΩF or 1000ΩF,
whichever is less
•125°C, VdCW: >100GΩF or1000ΩF
whichever is less
2.5 X VDCW
or = to 10μF 0.5+/-0.1
VDCW @120Hz
Z5U - Despite their capacitance instability, Z5U formulations are very popular because of their small size, temperature
range low ESL, low ESR and excellent frequency response. These features are particularly important for decoupling
application where only a minimum capacitance value is required.
Y5V - Y5V formulations are for general purpose use in a limited temperature range. They have a wide temperature
characteristic of +22% - 82% capacitance change over the operating temperature range of -30°C to +85°C. Y5Vs high
dielectric constant allows the manufacture of very high capacitance values (up to 100μF) in small physical sizes.
High capacitance per unit volume: general purpose product
TEMPERATURE
OPERATING
TEMPERATURE
VOLTAGE
TEMPERATURE
COEFFICIENT COEFFICIENT
RANGE
(∆c MAX @ VDCW)
DISSIPATION
FACTOR
+22%
-82%
3.0% Max, 2.0%
Typical
-30°C to +85°C
N/A
INSULATION
RESISTANCE
•10GΩ or 100ΩF whichever is less,
25°C, VdCW
DIELECTRIC
WITHSTANDING
VOLTAGE
2.5 X VdCW
AGING
RATE
3.0% per
decade hour
TEST
PARAMETERS
• 1 KHz, 1 Vrms 25°C values >
or = to 10uF 1.0Vrms 120Hz
1
CONSTRUCTION
NO.
NAME
CLASS I DIELECTRIC
CLASS II DIELECTRIC
1
Ceramic Material
CaZrO3
BatTi03
2
Inner Electrode
Ni
Ni
Cu
Cu
3
Inner layer
3
4
4
5
Termination
5
Middle layer
Ni
Ni
Outer layer
Sn
Sn
2
1
CAPACITANCE VALUE & TOLERANCE
Determined by circuit requirements. Note that chip prices
decrease with lower capacitance value and looser
tolerance.
VOLTAGE
CAPACITOR SIZE
Select the smallest unit permitted by the circuit constraints
that provides the required capacitance and voltage rating.
All Cal-Chip capacitors conform to EIA specifications.
CAPACITOR TERMINATION
Nickel barrier is standard and recommended for units
exposed to repeated solder cycles, to minimize leaching of
the termination.
REFLOW SOLDERING CONDITIONS
280
MAX TEMP
260
240
4°C/sec
220
200
The lead-free termination MLCCs are not only to be used
on SMT against lead-free solder paste, but also suitable
against lead-containing solder paste. If the optimized
solder joint is requested, increasing soldering time,
temperature and concentration of N2 within oven are
recommended.
4°C/sec
Sn-Ag-Cu Solder Paste
180
160
140
3°C/sec
120
MIN TEMP
100
80
60
Peal Temperature: 280°C max
Duration Time:
>260°C, 10 sec max
>215°C, 60-90 sec
40
60-90 sec
120 sec
120 sec
Time
120 sec
PART NUMBER GUIDE
GMC
PRODUCT TYPE
21
DIMENSIONS
01: 1005
02: 0201
04: 0402
10: 0603
21: 0805
31: 1206
2
32: 1210
40: 1808
43: 1812
45: 1825
55: 2220
57: 2225
CG
102
DIELECTRIC
CAPACITANCE
CG: COG/NPO
X7R
X5R
X7S
X6S
Y5V
Z5U
0R5:
5R0:
R75:
100:
101:
102:
103:
104:
105:
106:
107:
0.5pF
5.0pF
0.75pF
10pF
100pF
1000pF
.01uF
.1uF
1.0uF
10uF
100uF
J
50
NT
TOLERANCE
VOLTAGE DC
TERMINATION
PACKAGING CODE
NT: Sn/Ni
PT: Pd/Ag
Blank: 7" reel
D: See page 19 & 20
G: See page 19 & 20
Q: See page 19 & 20
B: +/-.1pF
C: +/-.25pF
D: +/-.5pF
F: +/-1%
G: +/-2%
J: +/-5%
K: +/-10%
M: +/-20%
Z: -20%/+80%
4R0:
6R3:
10:
16:
25:
35:
50:
63:
100:
200:
4.0V
6.3V
10V
16V
25V
35V
50V
63V
100V
200V
D
NPO/COG
NPO/COG
GMC04
GMC10
GMC21
GMC31
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
0.07 ~ 0.14
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
DIMENSION (MM)
GMC01
GMC02
L
0.4 ± 0.02
W
BW
RATED VOLTAGE
6.3
10
16
25
50
16
25
50
100
6.3 10
C
C
C
C
H
C
C
C
C
H
16
25
50 100 200 25
H
H
H
H
H
H
H
H
50 100 200 10
16
25
50 100 200 25
50 100 200
CAP. RANGE
0.1pF
R10
0.2
R20
A
A
A
A
0.3
R30
A
A
A
A
A
C
C
C
C
H
H
H
H
H
0.4
R40
A
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
0.47
R47
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
0.5
0R5
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
0.56
R56
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
C
C
C
C
A
A
A
A
A
A
A
A
A
0.6
0R6
0.68
R68
0.7
0R7
A
A
A
A
C
C
C
0.75
R75
A
A
A
A
C
C
C
A
A
A
A
L
L
L
L
L
L
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
L
C
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
A
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
L
L
A
C
C
C
C
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
L
L
C
C
C
C
H
H
H
H
H
H
J
J
J
J
J
J
L
L
L
L
A
C
C
C
C
H
H
H
H
H
H
J
J
J
J
J
J
L
L
L
L
A
A
C
C
C
C
H
H
H
H
H
H
J
J
J
J
J
J
L
L
L
L
A
A
A
C
C
C
C
H
H
H
H
H
H
J
J
J
J
J
J
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
0.8
0R8
0.82
R82
0.9
0R9
A
A
A
1
1R0
A
A
A
1.1
1R1
A
A
A
A
1.2
1R2
A
A
A
1.3
1R3
A
A
1.4
1R4
A
1.5
1R5
1.6
1R6
1.7
1R7
A
A
1.8
1R8
A
A
A
A
C
C
C
C
H
H
H
H
H
H
1.9
1R9
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2
2R0
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.1
2R1
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.2
2R2
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.3
2R3
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.4
2R4
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.5
2R5
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.6
2R6
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.7
2R7
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.8
2R8
A
A
A
A
C
C
C
C
H
H
H
H
H
H
2.9
2R9
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3
3R0
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.1
3R1
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.2
3R2
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.3
3R3
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.4
3R4
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.5
3R5
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.6
3R6
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.7
3R7
A
A
A
A
C
C
C
C
H
H
H
H
H
H
A
A
A
A
H
H
H
H
L
L
L
L
L
L
L
L
C
C
C
C
H
H
H
H
H
H
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
A
A
C
C
C
C
H
H
H
H
H
H
A
A
A
C
C
C
C
H
H
H
H
H
H
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
A
A
A
A
C
C
C
C
H
H
H
H
H
H
A
A
A
A
C
C
C
C
H
H
H
H
H
H
3.8
3R8
A
A
A
A
3.9
3R9
A
A
A
A
4
4R0
A
A
A
4.1
4R1
A
A
4.2
4R2
A
4.3
4R3
A
4.4
4R4
4.5
4R5
A
MAX HEIGHT
A
C
H
J
L
0.22
0.33
0.55
0.7
0.90
3
NPO/COG
NPO/COG
DIMENSION (MM)
GMC01
GMC02
GMC04
GMC10
GMC21
GMC31
L
0.4 ± 0.02
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
W
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
BW
0.07 ~ 0.14
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
RATED VOLTAGE
6.3 10 16 25 50 16 25 50 100 6.3 10 16 25 50 100 200 25 50 100 200 10 16 25 50 100 200 25 50 100 200
CAP. RANGE
4.6pF
4R6
A
A A A
C C C
C
H
H H H H
H
L
L
L
4.7
4R7
A
A A A A C C C
C
H
H H H H
H
L
L
L
4.8
4R8
A
A A A
C
H
H H H H
H
L
L
L
C C C
4.9
4R9
A
A A A
C C C
C
H
H H H H
H
L
L
L
5
5R0
A
A A A
C C C
C
H
H H H H
H
L
L
L
5.1
5R1
A
A A A
C C C
C
H
H H H H
H
L
L
L
5.2
5R2
A
A A A
C C C
C
H
H H H H
H
L
L
L
L
L
L
L
L
J
L
L
L
L
J
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
J J J J
J
J
J J J J
J
J
J J J J
J
J J J J
J
5.3
5R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
5.4
5R4
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
5.5
5R5
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
5.6
5R6
A
A A A A C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
5.7
5R7
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
5.8
5R8
A
A A A
C C C
C
H
H H H H
H
L
L
L
5.9
5R9
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6
6R0
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6.1
6R1
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6.2
6R2
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6.3
6R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6.4
6R4
A
A A A
C C C
C
H
H H H H
H
L
L
L
6.5
6R5
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
6.6
6R6
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
J J J J
J
J
L
L
L
L
J J J J
J
J
L
L
L
L
J J J J
J
J
J J J J
J
J
J J J J
J
J
L
L
L
L
J J J J
J
J
L
L
L
L
J J J J
J
J
L
L
L
L
L
L
L
L
H
H
6.7
6R7
A
A A A
C C C
C
H
H H H H
H
L
L
L
6.8
6R8
A
A A A A C C C
C
H
H H H H
H
L
L
L
6.9
6R9
A
A A A
C
H
H H H H
H
L
L
L
C C C
7
7R0
A
A A A A C C C
C
H
H H H H
H
L
L
L
7.1
7R1
A
A A A
C
H
H H H H
H
L
L
L
C C C
7.2
7R2
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.3
7R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
L
L
L
L
7.4
7R4
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.5
7R5
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.6
7R6
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.7
7R7
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.8
7R8
A
A A A
C C C
C
H
H H H H
H
L
L
L
7.9
7R9
A
A A A
C C C
C
H
H H H H
H
L
L
L
8
8R0
A
A A A A C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
8.1
8R1
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
8.2
8R2
A
A A A A C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
8.3
8R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
8.3
8R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
8.4
8R4
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
J J J J
J
J
H
8.5
8R5
A
A A A
C C C
C
H
H H H H
H
L
L
L
8.6
8R6
A
A A A
C C C
C
H
H H H H
H
L
L
L
L
L
8.7
8R7
A
A A A
C C C
C
H
H H H H
H
L
L
L
8.8
8R8
A
A A A
C C C
C
H
H H H H
H
L
L
L
8.9
8R9
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
9
9R0
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
L
L
L
L
9.1
9R1
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
L
L
L
L
9.2
9R2
A
A A A
C C C
C
H
H H H H
H
L
L
L
J J J J
J
J
J J J J
J
J
J J J J
J
J
9.3
9R3
A
A A A
C C C
C
H
H H H H
H
L
L
L
9.4
9R4
A
A A A
C C C
C
H
H H H H
H
L
L
L
9.5
9R5
A
A A A
C C C
C
H
H H H H
H
L
L
L
9.6
9R6
A
A A A
C C C
C
H
H H H H
H
L
L
L
9.7
9R7
A
A A A
C C C
C
H
H H H H
H
L
L
L
MAX HEIGHT
4
L
A
C
H
J
L
0.22
0.33
0.55
0.7
0.90
L
NPO/COG
NPO/COG
GMC04
DIELECTRIC
DIMENSION (MM)
GMC01
GMC02
L
0.4 ± 0.02
0.6 ± 0.03
GMC10
GMC21
GMC31
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
W
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
BW
0.07 ~ 0.14
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
RATED VOLTAGE
6.3 10
16
25
50
16
25
50
100
6.3 10
16
25
50 100 200 25
50 100 200 10
16
25
50 100 200 25
50 100 200
CAP. RANGE
9.8pF
9R8
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
9.9
9R9
A
A
A
A
C
C
C
C
H
H
H
H
H
H
L
L
L
L
10
100
A
A
A
A
A
C
C
C
C
H
H
H
H
H
H
11
110
A
A
A
A
A
C
C
C
H
H
H
H
H
12
120
A
A
A
A
A
C
C
C
13
130
A
A
A
A
A
C
C
C
15
150
A
A
A
A
A
C
C
C
H
H
H
H
H
16
160
A
A
A
A
C
C
C
H
H
H
H
H
18
180
A
A
A
A
C
C
C
H
H
H
H
H
A
A
A
A
C
C
C
H
H
H
H
H
22
220
A
A
A
A
C
C
C
H
H
H
H
H
23
230
H
H
H
H
H
24
240
H
H
H
H
H
25
250
H
H
H
H
H
27
270
A
A
A
A
C
C
C
H
H
H
H
30
300
A
A
A
A
C
C
C
H
H
H
H
33
330
A
A
A
A
C
C
C
H
H
H
36
360
A
A
A
A
C
C
C
H
H
38
380
H
39
390
40
400
42
420
43
430
A
A
A
A
47
470
A
A
A
A
50
500
51
510
53
530
56
560
60
600
62
620
A
A
A
A
A
C
C
68
680
A
A
A
A
A
C
C
70
700
75
750
80
800
82
820
A
A
A
A
91
910
A
A
A
A
100
101
A
A
A
A
110
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
C
A
C
A
A
C
C
C
H
H
H
H
H
H
H
H
H
H
H
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
H
H
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
H
H
H
L
L
L
H
H
H
H
H
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
H
H
H
H
H
H
L
L
L
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
C
A
C
C
H
L
L
C
C
A
C
C
H
C
C
C
C
C
H
H
H
H
H
H
H
H
H
H
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
J
J
J
J
J
J
R
R
R
R
L
J
J
J
J
J
J
L
L
L
L
J
J
J
J
J
J
L
L
L
L
J
J
J
J
J
J
L
L
L
L
J
J
J
J
J
J
L
L
L
L
J
J
J
J
J
J
L
L
L
L
J
J
J
J
J
J
L
L
L
L
C
C
H
H
H
H
H
H
H
H
H
H
H
H
C
C
C
H
H
H
H
H
C
C
C
H
H
H
H
H
C
C
C
H
H
H
H
H
H
H
L
L
L
111
C
C
C
H
H
H
H
H
H
H
L
L
L
120
121
C
C
C
H
H
H
H
H
H
L
L
L
130
131
C
C
C
H
H
H
H
H
L
L
L
150
151
C
C
C
H
H
H
H
H
L
L
L
160
161
H
H
H
H
H
L
L
L
180
181
C
C
C
H
H
H
H
H
L
L
L
200
201
C
C
C
H
H
H
H
H
L
L
L
220
221
A
A
A
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
240
241
A
A
A
C
C
C
H
H
H
H
H
H
L
L
L
L
J
J
J
J
J
J
L
L
L
L
250
251
L
L
L
270
271
L
L
L
L
J
J
J
J
J
J
L
L
L
L
300
301
L
L
L
L
J
J
J
J
J
J
L
L
L
L
330
331
L
L
L
L
J
J
J
J
J
J
L
L
L
L
360
L
L
L
L
J
J
J
J
J
J
L
L
L
L
L
L
L
L
M
M
M
M
M
M
L
L
L
L
L
L
L
M
M
M
M
M
M
L
L
L
L
L
L
L
M
M
M
M
M
M
L
L
L
L
A
A
C
C
C
C
H
H
H
H
H
C
C
C
H
H
H
H
H
C
C
C
H
H
H
H
H
361
C
C
C
H
H
H
H
H
390
391
C
C
C
H
H
H
H
H
430
431
C
C
C
H
H
H
H
H
470
471
C
C
C
H
H
H
H
H
A
A
A
A
A
A
H
H
H
H
H
H
H
H
L
L
L
MAX HEIGHT
A
C
H
J
L
R
0.22
0.33
0.55
0.7
0.90
1.45
5
NPO/COG
NPO/COG
GMC04
GMC10
GMC21
GMC31
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
0.07 ~ 0.14
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
DIMENSION (MM)
GMC01
GMC02
L
0.4 ± 0.02
W
BW
RATED VOLTAGE
6.3 25
16
25
50
25
50
6.3 10
16
25
50 100 200 25
50 100 200 16
25
50 100 200 25
50 100 200
CAP. RANGE
500pF
501
M
M
M
M
510
511
C
H
H
H
H
H
H
L
L
L
L
M
M
M
M
560
561
C
H
H
H
H
H
H
L
L
L
L
M
M
M
M
620
621
C
H
H
H
H
H
H
L
L
L
L
M
M
M
M
680
681
C
H
H
H
H
H
H
L
L
L
L
M
M
M
M
750
751
C
H
H
H
H
H
H
L
L
L
M
M
M
820
821
C
H
H
H
H
H
H
L
L
L
L
M
M
910
911
C
H
H
H
H
H
H
L
L
L
L
M
1000
102
C
H
H
H
H
H
H
L
L
L
L
1100
112
H
H
H
H
H
L
L
L
1200
122
H
H
H
H
H
M
M
M
1300
132
H
H
H
H
H
M
M
M
1500
152
H
H
H
H
H
M
M
M
1600
162
H
H
H
H
M
M
M
1800
182
H
H
H
H
M
M
M
2000
202
H
H
H
H
M
M
M
2200
222
H
H
H
H
M
M
M
2400
242
M
M
M
2700
272
M
3000
302
3300
332
3600
362
3900
392
4300
432
4700
472
I
I
I
I
I
M
M
5600
562
I
I
I
I
I
M
M
6200
622
M
M
6800
682
M
M
7500
752
M
M
8200
822
M
M
9100
912
M
M
0.01uF
103
M
M
0.012
123
M
0.015
153
M
0.018
183
0.02
L
L
L
L
L
L
L
L
L
L
L
M
L
L
L
L
M
M
L
L
L
L
M
M
M
L
L
L
L
M
M
M
M
L
L
L
L
M
M
M
M
M
L
L
L
L
M
M
M
M
M
M
M
M
M
M
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
M
M
M
M
M
M
L
L
L
L
M
M
M
M
M
R
R
R
R
R
L
L
L
L
R
R
R
R
R
L
L
L
L
M
R
R
R
R
R
L
L
L
L
M
M
H
H
H
H
M
M
M
R
R
R
R
R
M
M
M
M
H
H
H
H
M
M
M
R
R
R
R
R
M
M
M
M
R
R
R
R
R
M
M
M
R
R
R
R
R
M
M
M
M
R
R
R
R
R
M
R
R
R
R
R
M
M
M
M
M
R
R
R
R
M
M
M
M
R
R
R
R
R
R
R
O
O
O
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
U
U
U
R
R
R
U
U
U
R
R
R
U
U
U
203
R
R
R
0.022
223
R
R
R
U
U
U
0.027
273
R
R
R
U
U
U
0.03
303
R
R
0.033
333
R
R
U
U
U
0.039
393
U
U
U
0.047
473
U
U
U
0.056
563
U
U
U
0.068
683
U
U
U
0.082
823
U
U
U
0.1
104
U
U
U
0.12
124
I
I
I
I
I
I
I
I
I
M
M
M
R
MAX HEIGHT
6
L
M
C
H
I
L
M
Q
R
U
0.33
0.55
0.65
0.90
0.95
1.40
1.45
1.90
R
R
R
R
R
R
R
NPO/COG
DIELECTRIC
DIMENSION (MM)
GMC32
GMC40
NPO/COG
GMC43
GMC45
GMC55
GMC57
5.7 ± 0.4
L
3.2 ± 0.3
4.57 ± 0.25
4.5 ± 0.35
4.5 ± 0.35
5.7 ± 0.4
W
2.5 ± 0.3
2.03 ± 0.25
3.2 ± 0.3
6.3 ± 0.4
5.0 ± 0.4
6.3 ± 0.4
BW
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.40 ~ 1.10
0.50 ~ 1.20
0.50 ~ 1.20
RATED VOLTAGE
16
25
50 100 200 50 100 200 50 100 200 50 100 200 50 100 200 50 100 200
CAP. RANGE
10pF
100
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
11
110
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
12
120
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
13
130
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
15
150
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
16
160
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
18
180
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
22
220
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
24
240
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
27
270
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
30
300
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
33
330
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
36
360
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
390
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
43
430
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
47
470
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
51
510
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
56
560
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
62
620
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
68
680
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
75
750
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
82
820
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
91
910
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
100
101
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
120
121
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
130
131
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
150
151
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
160
161
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
180
181
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
200
201
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
220
221
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
240
241
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
270
271
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
300
301
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
330
331
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
360
361
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
390
391
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
430
431
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
470
471
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
39
MAX HEIGHT
R
V
1.45
2.20
7
NPO/COG
NPO/COG
GMC43
GMC45
GMC55
GMC57
4.57 ± 0.25
4.5 ± 0.35
4.5 ± 0.35
5.7 ± 0.4
5.7 ± 0.4
2.5 ± 0.3
2.03 ± 0.25
3.2 ± 0.3
6.3 ± 0.4
5.0 ± 0.4
6.3 ± 0.4
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.40 ~ 1.10
0.50 ~ 1.20
0.50 ~ 1.20
DIELECTRIC
DIMENSION (MM)
GMC32
GMC40
L
3.2 ± 0.3
W
BW
RATED VOLTAGE
16
25
CAP. RANGE
510pF
511
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
560
561
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
620
621
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
680
681
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
750
751
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
820
821
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
910
911
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1000
102
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1100
112
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1200
1500
1800
2000
122
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
152
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
182
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
202
2200
222
R
2400
242
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
2700
272
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3000
302
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3300
332
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3900
392
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
4700
472
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
5600
562
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
6800
682
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
7500
752
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
8200
822
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
.01uF
103
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.012
123
P
P
P
P
P
V
V
V
V
V
V
V
V
V
V
V
V
V
0.015
153
P
P
P
P
P
V
V
V
V
V
V
V
V
V
V
V
V
0.018
183
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.022
223
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.027
273
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.033
333
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.039
393
V
V
V
V
V
Y
Y
Y
V
V
V
V
V
V
V
0.047
473
V
V
V
V
V
Y
Y
Y
V
V
V
V
V
V
V
0.056
563
V
V
V
V
Y
Y
Y
V
V
V
V
V
V
Y
683
V
V
V
V
Y
Y
Y
V
V
V
V
V
V
Y
823
V
V
V
V
Y
Y
Y
V
Y
Y
V
V
Y
104
V
V
V
V
Y
Y
Y
V
Y
Y
V
V
Y
Y
Y
V
V
V
Y
Y
Y
Y
V
V
V
Y
V
V
A2
V
V
0.068
0.082
0.1
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.12
124
0.15
154
0.18
184
0.22
224
0.27
274
V
V
0.33
334
V
V
0.47
474
V
W
W
W
W
W
1
105
2.2
225
4.7
475
R
P
V
W
Y
A2
1.45
1.35
2.2
2.3
2.8
3.5
MAX HEIGHT
8
X7R
DIMENSION (MM)
GMC01
GMC02
GMC04
X7R
GMC10
GMC21
GMC31
L
0.4 ± 0.02
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
W
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
BW
0.07 ~ 0.14
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
6.3
10
16
6.3
10
16
25
50
6.3
10
16
25
50
100
4
6.3
10
16
25
35
50
100
200
6.3
10
16
25
35
50
100
200
6.3 10
16
25
35
50
100
200
CAP. RANGE
56pF
560
A
A
68
680
A
A
82
820
A
A
100
101
A
A
120
121
A
A
150
151
A
A
180
181
A
A
200
201
220
221
240
241
270
271
300
301
330
331
360
361
390
391
430
431
470
471
510
511
560
561
620
621
680
681
750
751
820
821
910
911
1000
102
A
A
C
C
C
C
1200
122
A
A
C
C
C
C
1500
152
A
A
C
C
C
C
1800
182
C
C
C
C
2000
202
2200
222
2400
242
2700
272
3000
302
3300
332
3600
362
3900
392
A
A
A
A
A
A
A
A
A
A
A
A
A
A
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
A
A
C
C
A
A
A
C
C
C
A
A
C
C
C
A
A
C
C
C
C
A
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
H
H
H
H
H
H
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
H
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
H
H
H
H
H
L
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
L
L
L
L
L
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
L
L
L
L
L
L
L
L
L
L
L
L
MAX HEIGHT
A
C
H
L
M
R
0.22
0.33
0.55
0.90
0.95
1.45
9
X7R
DIMENSION (MM)
GMC01
GMC02
GMC04
X7R
GMC10
GMC21
L(L1)
0.4 ± 0.02
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
W
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
DIELECTRIC
BW(L2/LW)
RATED VOLTAGE
0.07 ~ 0.14
6.3
10
16
0.15 ± 0.05
6.3 10
16
25
0.1 ~ 0.35
50
6.3 10
16
25
35
0.1 ~ 0.4
50
100
4
H
6.3 10
GMC31
0.25 ~ 0.75
16
25
35
50
100
200
0.25 ~ 0.75
6.3 10
16
25
35
50
100
200
6.3 10
16
25
35
50
100
200
CAP. RANGE
4700pF
472
C
C
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
5600
562
C
C
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
6800
682
C
C
C
C
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
8200
822
C
C
C
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.01uF
103
C
C
C
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.012
123
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.015
153
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.018
183
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.02
203
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.022
223
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.027
H
H
H
H
H
H
273
H
H
H
H
H
H
L
L
L
L
L
L
L
L
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.033
333
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
0.039
393
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
T
0.047
473
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
R
T
0.056
563
H
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
R
T
0.068
683
H
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
R
T
0.082
823
H
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
R
R
R
T
0.1
104
H
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
M
M
M
R
M
M
M
M
M
M
M
M
0.12
124
M
M
M
M
M
M
M
M
M
M
M
M
M
R
M
M
M
M
M
M
M
0.15
154
H
H
H
H
M
M
M
M
M
M
M
R
R
R
R
R
R
R
P
P
P
P
P
P
T
0.18
184
M
M
M
M
M
M
M
R
R
R
R
R
R
R
P
P
P
P
P
P
T
0.22
224
M
M
M
M
M
M
M
R
R
R
R
R
R
R
Q
Q
Q
Q
Q
Q
T
0.27
274
M
M
M
M
M
M
M
R
R
R
R
R
R
Q
Q
Q
Q
Q
Q
T
0.33
334
M
M
M
M
M
M
M
R
R
R
R
R
R
Q
Q
Q
Q
Q
Q
T
0.39
394
M
M
M
M
M
M
M
R
R
R
R
R
R
U
U
U
U
U
U
U
0.47
474
M
M
M
M
M
M
M
R
R
R
R
R
R
U
U
U
U
U
U
U
0.56
564
M
M
M
M
R
R
R
R
R
R
U
U
U
U
U
U
U
0.68
684
M
M
M
M
R
R
R
R
R
R
U
U
U
U
U
U
U
0.82
824
M
M
M
M
R
R
R
R
U
U
U
U
U
U
U
1
105
M
M
M
M
R
R
R
R
R
R
T
T
T
T
T
T
T
1.5
155
N
N
N
R
R
R
R
R
R
U
U
U
U
U
U
N
N
N
R
R
2.2
225
3.3
335
4.7
475
6.8
685
10
106
22
226
33
336
47
476
100
107
150
157
220
227
* L 1.0±0.10 | W 0.5±0.10
*1L 1.0±0.15 | W 0.5±0.15
10
C
C
C
C
H
H
H
H
H
H
H
H* H*
I*
I*
N
N
N
N
N
N
M
M
M
M
M
M
N
N
N
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
Q
Q
Q
R
R
R
R
R
R
A3 A3 A3 A3 A3 A3
R
R
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
MAX HEIGHT
C
H
I
J
L
M
N
P
Q
R
S
A3
T
U
0.33
0.55
0.65
0.70
0.90
0.95
1.00
1.35
1.40
1.45
1.50
1.70
1.80
1.90
X7R
X7R
DIELECTRIC
DIMENSION (MM)
GMC32
GMC40
GMC43
GMC45
GMC55
GMC57
L
3.2 ± 0.3
4.57 ± 0.25
4.5 ± 0.35
4.5 ± 0.35
5.7 ± 0.4
5.7 ± 0.4
W
2.5 ± 0.3
2.03 ± 0.25
3.2 ± 0.3
6.3 ± 0.4
5.0 ± 0.4
6.3 ± 0.4
BW
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.40 ~ 1.10
0.50 ~ 1.20
0.50 ~ 1.20
RATED VOLTAGE
6.3
10
16
25
35
50
100
200
50
100
200
10
16
25
50
100
200
16
25
50
100
200
16
25
50
100
200
16
25
50
100
200
CAP. RANGE
1000pF
102
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1200
122
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1500
152
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1800
182
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
2200
222
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
2400
242
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
2700
272
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3000
302
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3300
332
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3600
362
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
3900
392
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
4300
432
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
MAX HEIGHT
O
R
V
1.10
1.45
2.20
11
X7R
X7R
DIELECTRIC
DIMENSION (MM)
GMC32
GMC40
GMC43
GMC45
GMC55
L(L1)
3.2 ± 0.3
4.57 ± 0.25
4.5 ± 0.35
4.5 ± 0.35
5.7 ± 0.4
5.7 ± 0.4
W
2.5 ± 0.3
2.03 ± 0.25
3.2 ± 0.3
6.3 ± 0.4
5.0 ± 0.4
6.3 ± 0.4
0.25 ~ 0.75
BW(L2/LW)
RATED VOLTAGE
0.25 ~ 0.75
0.25 ~ 0.75
0.40 ~ 1.10
GMC57
0.50 ~ 1.20
0.50 ~ 1.20
6.3 10
16
25
35
50
63
100
200
50
100
200
10
16
25
50
100
200
16
25
50
100
200
16
25
50
100
200
16
25
50
100
200
CAP. RANGE
4700pF
472
O
O
O
O
O
O
O
O
O
R
R
R
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
5600
562
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
6800
682
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
8200
822
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.01uF
103
R
R
R
R
R
R
R
R
R
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.012
123
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.015
153
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.018
183
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.022
223
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.027
273
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.033
333
O
O
O
O
O
O
T
T
T
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.039
393
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.04
473
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.056
563
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.068
683
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.082
823
O
O
O
O
O
O
O
O
O
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.1
104
V
V
V
V
V
V
V
V
V
V
V
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.12
124
O
O
O
O
O
O
O
O
O
A1
A1
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.15
154
O
O
O
O
O
O
O
Y
Y
A1
A1
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.18
184
O
O
O
O
O
O
O
Y
Y
A1
A1
V
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.22
224
O
O
O
O
O
O
O
O
R
A1
A1
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.27
274
O
O
O
O
O
O
O
T
Y
A1
A1
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.33
334
O
O
O
O
O
O
O
O
T
A1
A1
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.39
394
O
O
O
O
R
R
Z
Z
Z
A1
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.47
474
O
O
O
O
O
O
O
O
V
A1
R
R
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.56
564
R
R
R
R
R
R
R
Y
Y
A1
R
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.68
684
O
O
O
O
O
O
O
T
Y
A1
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
0.82
824
O
O
O
O
O
O
O
V
R
R
R
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
1
105
T
T
T
T
T
T
T
Y
V
V
V
V
V
R
R
R
R
V
X
X
X
X
X
V
V
V
V
V
1.5
155
Z
Z
Z
Z
Z
Z
Z
Z
V
V
V
V
V
V
V
V
V
Y
V
V
V
V
V
Y
Y
Y
Y
Y
2.2
225
Z
Z
Z
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
V
V
V
V
Y
V
V
V
V
V
Y
Y
Y
Y
Y
3.3
335
Z
Z
Z
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
V
V
V
V
V
V
V
V
V
V
V
V
4.7
475
Z
Z
Z
Z
Z
Z
Z
Z
V
V
V
V
Y
V
V
V
V
V
V
V
V
V
V
V
V
6.8
685
Z
Z
Z
Z
Z
Y
Y
Y
Y
V
V
V
V
V
V
V
V
V
V
V
V
10
106
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
15
156
Y
Y
Y
22
226
Y
Y
Y
33
336
47
476
100
107
150
157
220
227
330
337
Y
Z
Y
Y
A1 A1 A1
Y
Y
Y
Y
Y
A1 A1
Y A4
Y
Y
Y
V
V
X
X
Y
MAX HEIGHT
12
O
R
T
V
X
Y
Z
A1
A4
1.10
1.45
1.80
2.2
2.5
2.8
2.9
3.1
3.4
X7S
X7S
DIELECTRIC
DIMENSION (MM)
GMC02
GMC04
GMC10
GMC21
GMC31
GMC32
GMC55
L(L1)
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
5.7 ± 0.4
W
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
2.5 ± 0.3
6.3 ± 0.4
BW(L2/LW)
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.50 ~ 1.2
RATED VOLTAGE
4
6.3 10
16 4/6.3 10
16
25
50 100 4/6.3 10
16
25
35
50 100
4
6.3 10
16
25
35
50 100 4
6
10
16
25
35
50 100
4
6.3 10
16
25
50
63 100 4
6.3 10 16 25 50 100
CAP. RANGE
1000pF
102
H
H
H
H
H
H
L
L
L
L
L
L
L
1500
152
H
H
H
H
H
H
L
L
L
L
L
L
L
2200
222
H
H
H
H
H
H
L
L
L
L
L
L
L
3300
332
H
H
H
H
H
H
L
L
L
L
L
L
L
4700
472
H
H
H
H
H
H
L
L
L
L
L
L
L
L
6800
682
H
H
H
H
H
H
L
L
L
L
L
L
.01uF
103
H
H
H
H
H
H
L
L
L
L
L
L
L
0.022
223
H
H
H
H
H
H
L
L
L
L
L
L
L
0.033
333
H
H
H
H
H
M
M
M
M
M
M
M
0.039
393
H
H
H
H
H
M
M
M
M
M
M
M
0.047
473
H
H
H
H
H
M
M
M
M
M
M
M
0.056
563
H
H
H
H
H
M
M
M
M
M
M
M
0.068
683
H
H
H
H
H
M
M
M
M
M
M
M
0.082
823
H
H
H
H
M
M
M
M
M
M
M
0.1
104
H
H
H
H
M
M
M
M
M
M
M
0.15
154
M
M
M
M
M
M
0.22
224
0.33
0.47
0.56
564
0.68
684
0.82
824
C
C
C
C
C
C
C
C
C
C
R
R
R
R
R
R
R
R
H
H
H
M
M
M
M
M
M
R
R
R
R
R
R
R
R
334
H
H
H
M
M
M
M
M
M
R
R
R
R
R
R
R
R
474
H
H
H
M
M
M
M
M
M
R
R
R
R
R
R
R
R
M
M
M
R
R
R
R
R
M
M
M
R
R
R
R
R
R
R
M
M
M
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
U U
U
U
U
U
U
U
R
R
R
R
R
R
R
U U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
R
R
R
R
R
T T
T
T
T
T
T
T
Z
Z
Z
Z
Z
Z
Z
Z
R
R
R
R
R
U U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
U U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
Z
Z
V
V
U U
U
U
U
U
Z
Z
Z
Z
Z
Z
Y
Y
X
X
D
D
H
H
M
M
M
1
105
H
H
M
M
M
1.5
155
I
I
N
N
N
M
2.2
225
J
J
N
N
N
3.3
335
N
N
4.7
475
N
N
6.8
685
N
R
R
R
R
10
106
N
R
R
R
R
15
156
R
R
R
22
226
R
R
R
33
336
47
476
100
107
N
N
R
R
R
R
U U
U
U
U
Y
Y
Y
U U
Y
Y
Y
U U
Y
Y
Y
Z
Z
Z
Y
Y
Y
Y
Y
Y
MAX HEIGHT
C
D
H
I
J
L
M
N
P
R
T
U
V
X
Y
Z
0.33
0.35
0.55
0.65
0.7
0.90
0.95
1.00
1.35
1.45
1.80
1.90
2.2
2.5
2.8
2.9
13
X6S
DIMENSION (MM)
GMC02
GMC04
X6S
GMC10
GMC21
GMC31
L
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
W
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
BW
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
4
6.3
10
16
25
C
35
4
6.3 10
16
25
35
50
4
6.3 10
16
25
35
50
4
6.3
10
16
25
35
50
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
N
N
N
N
N
N
N
N
N
4
6.3
10
16
25
35
50 100
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
T
T
T
T
T
T
T
T
R
R
R
R
R
R
R
U
U
U
U
U
U
U
U
N
R
R
R
R
R
R
R
U
U
U
U
U
U
U
U
N
N
R
R
R
R
R
R
R
U
U
U
U
U
U
U
N
R
R
R
U
U
U
U
CAP. RANGE
2200pF
222
C
C
C
C
4700
472
C
C
C
C
C
.01uf
103
C
C
C
C
C
H
H
H
H
H
H
H
0.012
123
C
C
H
H
H
H
H
H
H
0.015
153
C
C
H
H
H
H
H
H
H
0.018
183
C
C
H
H
H
H
H
H
H
0.022
223
C
C
C
C
H
H
H
H
H
H
H
0.027
273
C
C
C
C
H
H
H
H
H
0.033
333
C
C
C
C
H
H
H
H
H
H
H
0.039
393
C
C
0.047
473
C
C
C
C
H
H
H
H
H
H
H
0.056
563
C
C
H
H
H
H
H
J
J
0.068
683
C
C
H
H
H
H
H
J
J
0.082
823
C
C
H
H
H
H
H
J
J
0.1
104
C
C
H
H
H
H
H
J
J
0.12
124
H
H
0.15
154
H
H
H
H
H
0.18
184
H
H
0.22
224
H
H
0.27
274
H
H
0.33
334
H
H
0.39
394
H
H
0.47
474
H
H
0.56
564
H
H
0.68
684
H
H
0.82
824
H
H
J
J
C
E
E
C
C
C
C
C
C
C
E
E
E
E
E
E
H
H
H
H
J
H
H
H
H
H
H
J
J
J
M
M
M
M
M
M
1
105
1.5
155
2.2
225
2.7
275
3.3
335
3.9
395
4.7
475
6.8
685
10
106
15
156
22
226
33
336
47
476
68
686
100
107
150
157
U
220
227
U
J
I
J
J
J
J
J
I
J
K
N
N
N
N
N
N
N
N
N
N
N
N
N
N
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
N
R
R
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
U
R
U
U
MAX HEIGHT
14
C
E
H
I
J
K
M
N
R
T
U
0.33
0.39
0.55
0.65
0.7
0.8
0.95
1.00
1.45
1.80
1.90
U
X6S
X6S
DIMENSION (MM)
GMC32
GMC43
L(L1)
3.2 ± 0.30
4.5 ± 0.35
W
2.5 ± 0.30
3.2 ± 0.30
BW(L2/LW)
0.75 ± 0.25
0.25 ~ 0.75
RATED VOLTAGE
2.5
4
6.3 10 16 25 35 50 4
6.3 10 16 25 35 50
CAP. RANGE
3.3uF
335
Z
Z
Z
4.7
475
Z
Z
Z
6.8
685
Z
Z
Z
10
106
Z
Z
Z
Z
Z
22
226
Y
Y
Y
33
336
47
476
Y
Y
Y
68
686
Z
Z
100
107
Z
Z
150
157
Z
Z
220
227
Z
Z
330
337
Z
Z
A1 A1
Z
MAX HEIGHT
Y
Z
A1
2.8
2.9
3.1
15
X5R
X5R
DIELECTRIC
DIMENSION (MM)
GMC01
GMC02
GMC04
GMC10
L(L1)
0.4 ± 0.02
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
W
0.2 ± 0.02
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
BW(L2/LW)
RATED VOLTAGE
0.07 ~ 0.14
0.15 ± 0.05
4V
6.3
10
16
4
6.3 10
A
A
C
C
C
C
C
0.1 ~ 0.35
GMC21
0.1 ~ 0.4
16
25
35
50
4
6.3 10
16
25
35
50
63
6.3 10
C
C
C
C
C
H
H
H
H
H
H
H
L
C
C
C
C
C
H
H
H
H
H
H
H
L
C
C
C
C
C
C
H
H
H
H
H
H
H
C
C
C
C
C
C
C
H
H
H
H
H
H
C
C
C
C
C
C
C
H
H
H
H
H
C
C
C
C
C
H
H
H
H
C
C
C
C
C
C
C
H
H
H
C
C
C
C
C
C
C
H
H
C
C
C
C
C
C
H
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
0.25 ~ 0.75
16
25
35
50 100
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
H
L
L
L
L
L
L
L
H
H
L
L
L
L
L
L
L
H
H
H
L
L
L
L
L
L
L
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
H
H
L
L
L
L
L
L
L
H
H
H
H
H
H
H
L
L
L
L
L
L
L
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
C
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
C
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
L
4
6.3
10
16
25
35
50 100
CAP. RANGE
1000pF
102
A
A
1200
122
A
A
1500
152
A
A
1800
182
A
A
2200
222
A
A
2700
272
A
A
3300
332
A
A
3900
392
A
A
4700
472
A
A
A
5600
562
A
A
A
6800
682
A
A
A
8200
822
A
A
.01uF
103
A
A
0.012
123
0.015
153
0.018
183
0.02
203
0.022
223
A
A
C
C
C
C
0.027
273
A
A
C
C
C
0.033
333
A
A
C
C
C
0.039
393
C
C
0.047
473
C
0.056
563
0.068
683
0.082
823
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
C
C
H
H
H
H
H
H
H
C
H
H
H
H
H
H
H
L
L
L
L
L
L
L
C
H
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
H
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
C
C
C
H
H
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
C
C
C
C
H
H
H
H
H
J
J
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
C
C
C
C
J
J
J
J
J
J
J
M
M
M
M
M
M
M
M
M
M
M
M
M
M
R
C
C
C
C
H
H
H
H
H
J
J
M
M
M
M
M
M
M
M
M
M
M
M
M
R
C
H
H
H
H
H
J
J
M
M
M
M
M
M
M
M
M
M
M
M
M
R
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
R
H
H
H
M
M
M
M
M
M
R
R
R
R
R
R
R
H
H
H
M
M
M
M
R
R
R
R
R
R
R
H
H
H
M
M
M
M
R
R
R
R
R
R
R
H
H
H
M
M
M
R
R
R
R
R
R
R
H
H
H
M
M
M
R
R
R
R
R
R
R
H
H
H
M
M
M
R
R
R
R
R
R
R
M
M
M
R
R
R
R
R
R
R
M
M
M
R
R
R
R
R
M
M
M
R
R
R
R
R
R
R
M
M
M
R
R
R
R
R
M
M
M
R
R
R
R
R
R
R
N
N
N
R
R
R
R
R
N
N
N
R
R
R
R
R
R
R
N
N
R
R
R
R
R
R
R
N
N
N
N
N
R
R
R
R
R
R
R
R
R
R
R
R
R
R
N
N
N
R
R
R
R
R
R
S
R
R
R
R
R
R
R
R
R
C
0.1
104
C
C
C
0.12
124
C
C
C
0.15
154
C
C
C
0.18
184
0.22
224
A
A
0.27
274
A
A
0.33
334
0.39
394
0.47
474
J
J
J
0.56
564
H
H
H
0.68
684
H
H
H
0.82
824
H
H
H
H
H
H
C
E
B
F
C
F
C
E
C
C
C
C
D
C
D
C
E
C
E*
C* C* C* C*
1
105
1.5
155
C
2.2
225
E* E* E*
3.3
335
4.7
475
H
H
H
J
H
H
H
H
H
H
H
H
H
J
J
H
J
H
H
H
H
C
I
I
I
I
I
I
H
H
H
J*
J*
J*
J*
6.8
685
10
106
K* K* K*
N
N
15
156
H* H*
N
N
18
186
I*
22
226
K* K*
N
N
33
336
47
476
100
107
M
M
M
M
N
M
M
M
M
M
M
M
M
N
M
N
M
I*
N
N* N*
R
R
R
R
R
R
R
R
R
R
R
MAX HEIGHT
A
B
C
D
E
F
H
I
J
K
L
M
N
R
S
0.22
0.25
0.33
0.35
0.39
0.45
0.55
0.65
0.7
0.8
0.90
0.95
1.00
1.45
1.5
GMC02 - * L 0.6 ± 0.09 | W 0.3 ± 0.09
GMC04 - * L1 ± 0.2 | W0.5+0.3-0.05
GMC10 - * L1.6 ± 0.3 | W0.8+/-0.3
16
R
R
R
R
X5R
X5R
DIELECTRIC
DIMENSION (MM)
GMC31
GMC32
GMC43
L(L1)
3.2 ± 0.3
3.2 ± 0.3
4.5 ± 0.35
5.7 ± 0.4
W
1.6 ± 0.2
2.5 ± 0.3
3.2 ± 0.3
5.0 ± 0.4
BW(L2/LW)
RATED VOLTAGE
0.25 ~ 0.75
0.25 ~ 0.75
4
6.3
10
16
25
35
50
100
4
6.3
10
16
25
35
GMC55
0.25 ~ 0.75
50
63 100 6.3
0.50 ~ 1.2
10
16
25
35
50 100 6.3
10
16
25
50 100
CAP. RANGE
.1uF
104
M
M
M
M
M
M
M
M
V
V
V
V
V
V
V
V
V
0.12
124
M
M
M
M
M
M
M
M
O O
O
O
O
O
O
O
O
0.15
154
P
P
P
P
P
P
P
T
O O
O
O
O
O
O
O
Y
0.18
184
P
P
P
P
P
P
P
T
O O
O
O
O
O
O
O
Y
0.22
224
Q
Q
Q
Q
Q
Q
Q
T
O O
O
O
O
O
O
O
O
0.27
274
Q
Q
Q
Q
Q
Q
Q
T
O O
O
O
O
O
O
O
T
0.33
334
Q
Q
Q
Q
Q
Q
Q
T
O O
O
O
O
O
O
O
O
0.39
394
U
U
U
U
U
U
U
U
O O
O
O
O
R
R
Y
Y
0.47
474
U
U
U
U
U
U
U
U
O O
O
O
O
O
O
O
O
0.56
564
U
U
U
U
U
U
U
U
R
R
R
R
R
R
R
R
Y
0.68
684
U
U
U
U
U
U
U
U
O O
O
O
O
O
O
O
T
0.82
824
U
U
U
U
U
U
U
U
O O
O
O
O
O
O
O
V
1
105
T
T
T
T
T
T
T
T
T
T
T
T
T
T
T
T
Y
1.5
155
U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
Z
2.2
225
U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
Z
3.3
335
U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
Y
Y
V
V
V
V
V
4.7
475
U
U
U
U
U
U
U
Z
Z
Z
Z
Z
Z
Z
Z
Z
V
V
V
V
V
V
Y
V
V
V
V
V
V
6.8
685
U
U
U
U
U
U
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
Y
V
V
V
V
V
V
10
106
U
U
U
U
U
U
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
15
156
T
T
T
T
T
T
Y
Y
Y
Y
22
226
T
T
T
T
T
T
Y
Y
Y
Y
Y
Y
33
336
T
T
T
T
T
V
V
V
47
476
T
T
T
T
T
Y
Y
Y
68
686
U
U
U
V
V
100
107
T
T
T
Y
Y
Y
220
227
U*
U*
Y
Y
Y
330
337
Y
Y
U
U
U
Y
Z
Y
A1 A1 A1 A1
Y
Y
Y
Y
Y
Y
Y
Y
Y
V
A1 A1 A1
Y
Y
Y
Y
V
V
V
X
A1 A1
X
X
A1 A1
X
X
A1 A1
X
A1 A1
MAX HEIGHT
M
O
P
Q
R
T
U
V
X
Y
Z
A1
0.95
1.1
1.35
1.40
1.45
1.80
1.9
2.2
2.5
2.80
2.9
3.1
GMC31 - * L3.2 ± 0.3 | W1.6+/-0.3
17
Y5V / Z5U
Y5V / Z5U
DIELECTRIC
DIMENSION (MM)
GMC02
GMC04
GMC10
GMC21
GMC31
GMC32
GMC43
GMC55
L
0.6 ± 0.03
1.0 ± 0.05
1.6 ± 0.2
2.0 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
4.5 ± 0.35
5.7 ± 0.4
W
0.3 ± 0.03
0.5 ± 0.05
0.8 ± 0.2
1.25 ± 0.2
1.6 ± 0.2
2.5 ± 0.3
3.2 ± 0.3
5.0 ± 0.4
BW
0.15 ± 0.05
0.1 ~ 0.35
0.1 ~ 0.4
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.50 ~ 1.20
RATED VOLTAGE
6.3/10
6.3 10
16
25
50
6.3 10
16
25
50
6.3
10
16
25
50
6.3 10
16
25
50
6.3 10
16
25
50
6.3 10
16
25
50
6.3 10
16
25
50
CAP. RANGE
0.01uF
103
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
R
R
R
R
R
0.012
123
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.015
153
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.018
183
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.02
203
C
M
M
M
M
M
O
O
O
O
O
0.022
223
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.027
273
C
H
H
H
H
H
L
L
L
L
L
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.03
303
C
M
M
M
M
M
O
O
O
O
O
0.033
333
C
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.039
393
C
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
0.047
473
C
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
R
R
R
R
R
0.056
563
C
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
R
R
R
R
R
0.068
683
C
J
J
J
J
J
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
0.082
823
C
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
R
R
R
R
R
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
0.1
104
C
H
H
H
H
J
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
V
V
V
V
V
R
R
R
R
R
V
V
V
V
V
0.12
124
H
H
H
H
H
M
M
M
M
M
M
M
M
M
M
M
M
M
M
M
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
0.15
154
H
H
H
H
M
M
M
M
M
R
R
R
R
R
P
P
P
P
P
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
0.18
184
H
H
H
H
R
R
R
R
R
P
P
P
P
P
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
0.22
224
H
H
H
H
0.27
274
H
H
0.33
334
H
H
0.39
394
H
0.47
474
0.56
564
0.68
M
M
M
M
M
R
R
R
R
R
Q
Q
Q
Q
Q
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
H
M
M
M
M
M
R
R
R
R
R
Q
Q
Q
Q
Q
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
H
M
M
M
M
M
R
R
R
R
R
Q
Q
Q
Q
Q
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
H
H
M
M
M
M
M
R
R
R
R
R
U
U
U
U
U
O
O
O
R
R
R
R
R
R
R
V
V
V
V
V
H
H
H
M
M
M
M
M
R
R
R
R
R
U
U
U
U
U
O
O
O
O
O
R
R
R
R
R
V
V
V
V
V
H
H
H
M
M
M
M
M
R
R
R
R
R
U
U
U
U
U
R
R
R
R
R
R
R
R
R
R
V
V
V
V
V
684
H
H
H
M
M
M
M
M
R
R
R
R
R
U
U
U
U
U
O
O
O
O
O
R
R
R
R
V
V
V
V
V
V
0.82
824
H
H
H
M
M
M
M
M
R
R
R
R
R
U
U
U
U
U
O
O
O
O
O
R
R
R
R
V
V
V
V
V
V
1.0uF
105
H
H
H
M
M
M
M
M
R
R
R
R
R
T
T
T
T
T
T
T
T
T
T
V
V
V
V
V
V
V
V
V
V
1.2
125
U
U
U
U
U
Z
Z
Z
Z
Z
V
V
V
V
V
V
V
V
V
V
1.5
155
U
U
U
U
U
Z
Z
Z
Z
Z
V
V
V
V
V
V
V
V
V
V
2.2
225
V
V
V
V
2.7
275
3.3
335
4.7
475
5.6
565
6.8
685
8.2
825
10
106
15
156
22
226
33
336
47
476
68
686
100
107
220
227
330
337
H
M
M
M
M
M
N
N
R
R
R
R
R
U
U
U
U
U
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
V
V
V
V
V
V
R
R
R
R
R
U
U
U
U
U
Z
Z
Z
Z
Z
Y
Y
Y
Y
Y
V
V
V
V
V
R
R
R
R
R
U
U
U
U
U
Z
Z
Z
Z
Z
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Y
Y
Y
Y
Y
Y
Y
R
R
R
U
U
U
U
U
Z
Z
Z
Z
Z
Z
R
R
R
U
U
U
U
U
Y
Y
Y
Y
Y
Y
Y
Y
Y
R
N
R
R
R
R
T
Z
T
T
Y
Y
T
T
V
V
T
T
Y
Y
T
T
T
T
Y
Z
Y
Y
Z
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
A1 A1 A1 A1
Y
Y
Y
Y
Y
Y
Y
Y
Y
A1 A1 A1
Y
Y
Y
V
V
V
A1 A1 A1
X
X
X
A1
X
X
A1 A1
X
A1 A1 A1
MAX HEIGHT
18
C
H
L
M
N
O
P
Q
R
T
U
V
X
Y
Z
A1
0.33
0.55
0.90
0.95
1.00
1.10
1.35
1.40
1.45
1.8
1.90
2.20
2.5
2.8
2.9
3.10
PACKAGING (TAPING)
Per EIA-481 - Reel Type Size
t
SYMBOL
7” Reel
A
E min
10” Reel
13” Reel
B
C
TAPE WIDTH
A
B
C
D
E
W
t
8mm
Ø178±2.0
MINØ50
Ø13±0.5
21±0.8
2.0±0.5
10±0.5
0.9±0.2
12mm
Ø178±2.0
MINØ50
Ø13±0.5
21±0.8
2.0±0.5
13±0.5
1.2±0.2
8mm
Ø258±2.0
MINØ70
Ø13±0.5
21±0.8
2.0±0.5
10±0.5
1.8±0.2
8mm
Ø330±2.0
MINØ70
Ø13±0.5
21±0.8
2.0±0.5
10±0.5
1.8±0.2
12mm
Ø330±2.0
MINØ70
Ø13±0.5
21±0.8
2.0±0.5
13±0.5
2.2±0.2
D
W
- To peel off the cover tape by the method shown in the
right figure apply a peel-off force of 20GF - 60GF (card
board); 10GF - 75GF (plastic tape).
-The cover tape should not touch the top or bottom of
the chip.
- If the cover tape has been peeled off it may be
difficult to remove the chip due to punch-hole clearance,
dirt, and debris. Make sure therefore that no paper
waste will adhere to and block the absorption nozzle.
- If the cover tape has been peeled off from the top,
stick it back on with a suitable adhesive.
- Follow the illustration for the start and end of the
winding operation.
DIMENSION OF PAPER TAPE
CARDBOARD CARRIER TAPE FOR 01005, 0201, 0402, 0603, 0805, 1206
UNIT=mm
19
PACKAGING (TAPING)
Tape & Reel Dimensions
• Embossed plastic carrier tape for 0805/1206/1210/1808/1812/1825/2220 AND 2225 type
TYPE
A0
B0
T
K0
W
P0
10XPo
P1
P2
D0
D1
0805
很抱歉,暂时无法提供与“GMC21X7R222K100NT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+0.168934000+0.02119
- 8000+0.154838000+0.01942
- 12000+0.1477812000+0.01854
- 20000+0.1399620000+0.01755
- 28000+0.1353928000+0.01698
- 40000+0.1310140000+0.01643
- 48000+0.1289248000+0.01617
- 96000+0.1219296000+0.01529
- 100000+0.12155100000+0.01525
- 国内价格 香港价格
- 1+0.963901+0.12088
- 10+0.5253810+0.06589
- 50+0.3643850+0.04570
- 100+0.31534100+0.03955
- 500+0.23248500+0.02916
- 1000+0.206991000+0.02596
