RGT1608P-1540-B-T5
RGT1608P-1540-B-T5
    SUSUMU
    154Ω ±0.1% 62.5MW
RGT1608P-1540-B-T5 数据手册
Metal thin film chip resistors (wide temperature range) ■RGT series AEC-Q200 Compliant Features ・ Wide temperature operation (Upper category temperature :175°C) ・ Long term stability with igorganic passivation ・ Resistance tolerance : ±0.1% , TCR : ±10ppm/°C Thin film surface mount resistors ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Automotive electronics ・ Industrial measurement instrumentation, industrial machines RGT series ・ Wide temperature operation machines ◆Part numbering system RGT 2012 N - 105 - B - T5 Packaging quantity : T5(5,000pcs) T10(10,000pcs) Series code Resistance tolerance Nominal resistance value (E-24 : 3 digit, E-96:4 digit) Size: RGT1005, RGT1608, RGT2012, RGT3216 Temperature coefficient of resistance ◆Electrical Specification Type Temperature coefficient of resistance Power ratings Resistance range(Ω) Resistance tolerance ±0.1%(B) (ppm/℃) ±10(N) RGT1005 RGT1608 RGT2012 RGT3216 47≦R≦100k 1/32W 1/16W 1/10W 1/8W ±0.5%(D) Maximum voltage ±25(P) 47≦R≦150k ±10(N) 47≦R≦270k ±25(P) 47≦R≦1M ±10(N) 47≦R≦475k ±25(P) 47≦R≦2.7M ±10(N) 47≦R≦1M ±25(P) 47≦R≦5.1M Resistance value series Operating temperature Packaging quantity T5 50V T10* 1 100V E-24, E-96 -55℃∼ 175℃ T5 150V 200V *1:Resistance tolerance ± 0.5% (D) of RGT1005 is available only at T10 ◆Dimensions Type Size (inch) L W a RGT1005 0402 1.00+0.1/-0.05 0.50±0.05 0.20±0.10 0.25±0.05 0.35±0.05 RGT1608 0603 1.60±0.20 0.80+0.25/-0.20 0.30±0.20 0.30±0.20 0.40+0.15/-0.10 RGT2012 0805 2.00±0.20 1.25+0.25/-0.20 0.40±0.20 0.40±0.20 0.40+0.15/-0.10 RGT3216 1206 3.20±0.20 1.60±0.25 0.50±0.25 0.50±0.20 0.40+0.15/0.10 L b t W a t b (unit:mm) 17 ◆Reliability specification Standard Test items Condition( IEC60115-1/JIS C5201-1) Standard ※1 ±0.05%+0.01Ω 2.5 x rated voltage, 5 seconds Life (baised) 125℃, rated voltage , 90min. ON/ 30min. OFF, 1000hours ±0.25%+0.05Ω High temperature high humidity 85℃、85%RH, 1/10 of rated power, 90min. ON/ 30min. OFF, 1000hours ±0.25%+0.05Ω Temperature shock -55℃ (30min) ∼ 125℃(30min) 1000 cycles ±0.1%+0.01Ω High temperature exposure 175℃, no baias, not mounted, 1000h ±0.1%+0.01Ω Resistance to soldering heat 260±5℃, 10seconds (reflow) ±0.05%+0.01Ω ※1 Thin film surface mount resistors Short time overload *1 Rated voltage is given by E= RxP E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. ○High temperature exposure RGT1608-680Ω 0.15 RGT1608-10kΩ RGT1608-100kΩ 0.10 Resistance drift (%) Resistance drift (%) ○ Biased life test 0.30 0.25 0.20 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 -0.25 -0.30 RGT series ◆ Reliability test data RGT1608-680Ω RGT1608-10kΩ RGT1608-100kΩ 0.05 0.00 -0.05 -0.10 -0.15 1            10          100          1000 Test duration (h) 1            10           100     Test duration (h)   1000 Ratio to rated power (%) ◆Derating Curve 100 50 0 -55 0 50 100 125 150 175 Ambient temperature (℃) 18
RGT1608P-1540-B-T5
物料型号:RGT系列薄膜表面贴装电阻器,包括RGT1005、RGT1608、RGT2012和RGT3216。
器件简介:这些电阻器符合AEC-Q200标准,适用于宽温度范围操作,具有长期稳定性、低噪声、抗硫特性,并且无铅、无卤素,符合RoHS标准。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:电阻公差±0.1%(B级)、±0.5%(D级),温度系数±10ppm/°C,多种电阻值范围和系列,最高电压和工作温度范围从-55°C至175°C。
功能详解:文档提供了详细的电气规格,包括功率等级、电阻范围、电阻公差、最大电压、电阻值系列和操作温度。
应用信息:适用于汽车电子、工业测量仪器、工业机器和宽温度操作机器。
封装信息:提供了不同尺寸的电阻器尺寸,包括0402、0603、0805和1206,以及它们的具体尺寸参数。
RGT1608P-1540-B-T5 价格&库存
很抱歉,暂时无法提供与“RGT1608P-1540-B-T5”相匹配的价格&库存,您可以联系我们找货
