RMCF / RMCP Series
Stackpole Electronics, Inc.
General Purpose Thick Film Standard Power
and High-Power Chip Resistor
Resistive Product Solutions
Features:
RMCF – standard power ratings
RMCP – high power ratings
Nickel barrier terminations standard
Power derating from 100% at 70ºC to zero at +155ºC
AEC-Q200 compliant (except RMCP0201)
RoHS compliant and halogen free
REACH compliant
For ultra high power, see RMCP-UP Series – Thick Film Ultra High Power Chip Resistor
Electrical Specifications - RMCF
Type/Code
Power Rating
(W)
@ 70ºC
Max.
Working
Voltage (V)
(1)
Max.
Overload
Voltage (V)
Max.
Jumper Current
(A)
RMCF01005
0.03
15
30
0.5
RMCF0201
0.05
25
50
0.5
RMCF0402
0.063
50
100
1
RMCF0603
0.1
75
150
1
RMCF0805
0.125
150
300
2
RMCF1206
0.25
200
400
2
RMCF1210
0.5
200
400
3
RMCF2010
0.75
200
400
3
RMCF2512
1
200
400
3
TCR (ppm/ºC)
Ohmic Range (Ω) and Tolerance (2)
1%
± 300
± 200
± 400
± 200
± 200
± 100
± 200
± 500
± 400
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 400
± 100
± 200
± 400
± 200
± 100
± 200
± 400
± 200
± 100
5%
10 - 97.6
100 - 1M
1 - 9.76
10 - 10M
1 - 9.76 (3)
10 - 1M
1.02M - 10M
1.1M - 20M
0.1 - 0.499
0.5 - 0.976
1 - 9.76
1 - 20M
10 - 1M
1.02M - 10M
0.1 - 9.76
0.1 - 20M
10 - 1M
1.02M - 10M
0.1 - 9.76
0.1 - 20M
10 - 1M
1.02M - 10M
0.1 - 0.976
1 - 9.76
10 - 10M
0.1 - 0.976
1 - 9.76
10 - 10M
10 - 10M
0.1 - 0.976
1 - 9.76
10 - 10M
10 - 10M
Notes: (1) Lesser of √ P*R or maximum working voltage
(2) Contact Stackpole for extended ohmic values
(3) Contact Stackpole for lower ohmic values
Rev Date: 8/9/2021
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RMCF / RMCP Series
Electrical Specifications - RMCP
Type/Code
Power Rating
(W)
@ 70ºC
Max.
Working
(1)
Voltage (V)
Max.
Overload
Voltage (V)
Max.
Jumper Current
(A)
RMCP0201
0.063
25
50
1
RMCP0402
0.125
50
100
1.5
RMCP0603
0.25
75
150
2
RMCP0805
0.33
150
300
2.5
RMCP1206
0.5
200
400
3.5
RMCP1210
0.66
200
400
5
RMCP2010
1
200
400
6
RMCP2512
2
250
500
7
TCR (ppm/ºC)
1%, 5%
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
1 - 9.76
10 - 10M
-200 / +400
± 200
± 200
± 100
± 200
± 100
± 200
± 100
± 400
± 100
± 400
± 100
± 200
± 100
± 200
± 100
Electrical Specifications - Jumper
Type/Code
RMCF01005
RMCF0201
RMCF0402
RMCF0603
RMCF0805
RMCF1206
RMCF1210
RMCF2010
RMCF2512
Jumper Rated Current
(A)
0.5
0.5
1
1
2
2
3
3
3
Max Overload Current
(A)*
1
1
3
5
5
10
12
12
15
Jumper Resistance Value
(Ω)
0.05 max.
* < 1 second and 1 time
Mechanical Specifications
Type/Code
Average Unit
Weight (mg)
RMCF01005
0.07
RMCF0201
RMCP0201
RMCF0402
RMCP0402
RMCF0603
RMCP0603
RMCF0805
RMCP0805
0.16
0.57
0.62
1.88
2.04
5.00
4.37
L
Body Length
0.016 ± 0.0008
0.40 ± 0.02
0.024 ± 0.0012
0.60 ± 0.03
0.039 ± 0.004
1.00 ± 0.10
0.061 ± 0.006
1.55 ± 0.15
0.079 ± 0.008
2.00 ± 0.20
W
Body Width
0.008 ± 0.0008
0.20 ± 0.02
0.012 ± 0.0012
0.30 ± 0.03
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.006
0.80 ± 0.15
0.049 ± 0.004
1.25 ± 0.10
Rev Date: 8/9/2021
2
H
Body Height
0.005 ± 0.0008
0.13 ± 0.02
0.009 ± 0.0012
0.23 ± 0.03
0.012 ± 0.004
0.30 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.006
0.50 ± 0.15
a
Top Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
b
Bottom Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCF / RMCP Series
Mechanical Specifications (cont.)
Type/Code
RMCF1206
RMCP1206
RMCF1210
RMCP1210
RMCF2010
RMCP2010
RMCF2512
RMCP2512
L
Body Length
0.126 ± 0.010
3.20 ± 0.25
0.126 ± 0.010
3.20 ± 0.25
0.197 ± 0.008
5.00 ± 0.20
0.248 ± 0.008
6.30 ± 0.20
Average Unit
Weight (mg)
8.86
8.95
15.55
15.96
23.56
24.24
40.02
39.45
W
Body Width
0.063 ± 0.006
1.60 ± 0.15
0.098 ± 0.010
2.50 ± 0.25
0.098 ± 0.008
2.50 ± 0.20
0.126 ± 0.010
3.20 ± 0.25
H
Body Height
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.008
0.55 ± 0.20
a
Top Termination
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.014
0.60 ± 0.35
0.024 ± 0.014
0.60 ± 0.35
Unit
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Short Time Overload
Test Specifications
Test Conditions (JIS-C 5202)
± (2% + 0.1Ω)
2.5 X rated voltage for 5 seconds
0201 = 1A
0402 / 0603 / 0805 = 2.5A
1206 / 1210 / 2010 / 2512 = 5A
100 VAC, 1 minute
260ºC ± 5ºC, for 10 seconds ± 0.5 seconds (Solder Bath)
235ºC ± 5ºC, for 2 seconds ± 0.5 seconds (Colophonium flux)
-65ºC: 30 minutes 25ºC: 2 to 3 minutes
155ºC: 30 minutes 25ºC: 2 to 3 minutes
(5 Cycles)
Jumper: Max 0.05Ω after test
Dielectric Withstanding Voltage
Resistance to Soldering Heat
Solderability
No flashover or breakdown
± 1%
95% coverage, minimum
Temperature Cycle
± (1% + 0.05Ω)
Jumper (< 0.05Ω)
Load Life
(Endurance)
1% and below: ± (1% + 0.05Ω)
2% and 5%: ± (3% + 0.1Ω)
Value < 1Ω: ± (3% + 0.1Ω)
Jumper: Max 0.1Ω after test.
Voltage Coefficient
± 100 (ppm/V)
70ºC ± 2°C, RCWV or max. working voltage whichever is less
for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF"
1/10 rated voltage for 3 seconds max. then rated voltage for
3 seconds max.
Bend of 3 mm for 5 ± 1 seconds
The tested resistor should be immersed into isopropyl alcohol of
20ºC ~ 25°C for 60 seconds. Then the resitor is left in the room
for 48 hours.
Robustness of Termination
± (1% + 0.05Ω)
1%: ± (0.5% + 0.05Ω)
Resistance to Solvent
5%: ± (0.5% + 0.05Ω)
Jumper: Max. 0.05Ω after test
1%: ± (1% + 0.05Ω)
40ºC ± 2°C, 90%~95% R.H. RCWV or max. working voltage
5%: ± (2% + 0.05Ω)
Damp Heat with Load
whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hours
Values < 1Ω: ± (3% + 0.1Ω)
"OFF"
Jumper: Max. 0.1Ω after test
Operating temperature range is -55°C to +155°C for all sizes except for 01005 size
Operating temperature range for 01005 is -55°C to +125°C
Power Derating Curve:
100
-55ºC
70ºC
Power Load (%)
80
60
01005 size
All other sizes
40
125ºC
60
80
100
120
140
155ºC
160
180
Ambient Temperature (ºC)
Rev Date: 8/9/2021
3
www.seielect.com
RMCF / RMCP Series
Repetitive Pulse Information
(This information is for reference only and is not guaranteed performance.)
If repetitive pulses are applied to resistors, pulse wave form must be less than “Pulse limiting voltage”, “Pulse limiting
current” or “Pulse limiting wattage” calculated by the formula below.
Vp = K√P x R x T/t
lp = K√P/R x T/t
Pp = K2 x P x T/t
Where: Vp:
lp:
Pp:
P:
R:
T:
t:
K:
[Vr:
Pulse limiting voltage (V)
Pulse limiting current (A)
Pulse limiting wattage (W)
Power rating (W)
Nominal resistance (ohm)
Repetitive period (sec)
Pulse duration (sec)
Coefficient by resistors type (refer to below matrix)
Rated Voltage (V), Ir: Rated Current (A)]
Note 1: If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000
Note 2: If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied
Note 3: If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp)
Note 4: Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient
temperature is more than the rated temperature (70°C), please decrease power rating according to “Power Derating
Curve”
Note 5: Please assure sufficient margin for use period and conditions for “Pulse limiting voltage”
Note 6: If the pulse waveform is not square wave, please judge after transform the waveform into square wave
according to the “Waveform Transformation to Square Wave”.
RMCF Coefficient (K) Matrix
Ohmic Value
K
R < 10Ω
10Ω ≤ R < 100Ω
100Ω ≤ R < 1KΩ
1KΩ ≤ R < 10KΩ
10KΩ ≤ R
0.50
0.45
0.35
0.25
0.20
Rev Date: 8/9/2021
4
www.seielect.com
RMCF / RMCP Series
1.
Discharge curve wave with time constant “t” → Square wave
2.
Damping oscillation wave with time constant of envelope “t” → Square wave
3.
Half-wave rectification wave → Square wave
4.
Triangular wave → Square wave
5.
Special wave → Square wave
Rev Date: 8/9/2021
5
www.seielect.com
RMCF / RMCP Series
Recommended Pad Layout
Type/Code
RMCF01005
RMCF0201
RMCP0201
RMCF0402
RMCP0402
RMCF0603
RMCP0603
RMCF0805
RMCP0805
RMCF1206
RMCP1206
RMCF1210
RMCP1210
RMCF2010
RMCP2010
RMCF2512
RMCP2512
A
B
C
Unit
0.008
0.20
0.012
0.30
0.020
0.50
0.031
0.80
0.047
1.20
0.087
2.20
0.087
2.20
0.138
3.50
0.193
4.90
0.020
0.50
0.039
1.00
0.059
1.50
0.083
2.10
0.118
3.00
0.165
4.20
0.165
4.20
0.240
6.10
0.315
8.00
0.008
0.20
0.016
0.40
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
0.110
2.80
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Rev Date: 8/9/2021
6
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
RMCF / RMCP Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
Packaging (EIA Standard RS-481)
Packaging Specifications
Reel Type
7" reel for
8 mm tape
10" reel for
8 mm tape
Wa
0.354
9.00
0.394
10.00
M
0.020
0.50
0.020
0.50
7.008
178.00
10.000
254.00
0.079
2.00
0.079
2.00
Rev Date: 8/9/2021
A
B
C
0.079 ± 0.020
2.00 ± 0.50
0.531 ± 0.020
13.50 ± 0.50
0.827 ± 0.020
21.00 ± 0.50
7
D
2.362
60.00
3.937
100.00
Unit
0.039
1.00
0.039
1.00
inches
mm
inches
mm
www.seielect.com
RMCF / RMCP Series
Taping Specifications - 01005, 0201, 0402
Type/Code
7" Reel
Typical Full
Tape
Quantity Reel Weight (g) Width
RMCF01005
RMCF0201
RMCP0201
RMCF0402
RMCP0402
127.3 ± 12.0
10000
97.2 ± 9.0
94.5 ± 9.0
Type/Code
T1
0.012
RMCF01005
0.31
RMCF0201 0.015
RMCP0201
0.38
RMCF0402 0.016
RMCP0402
0.40
A
0.018
0.45
0.315 0.028
8.00
0.70
0.047
1.20
T2
B
W
E
F
Unit
0.001 0.010 ± 0.001
inches
0.02
0.25 ± 0.02
mm
0.006 0.016 ± 0.006 0.315 ± 0.008 0.069 ± 0.004 0.138 ± 0.002 inches
0.15
0.40 ± 0.15
8.00 ± 0.20
1.75 ± 0.10
3.50 ± 0.05
mm
0.006 0.028 ± 0.006
inches
0.15
0.70 ± 0.15
mm
P
P0
P1
Unit
0.001 0.007 ± 0.001
inches
0.03
0.17 ± 0.03
mm
0.006 0.011 ± 0.001 0.079 ± 0.004 0.157 ± 0.004 0.079 ± 0.002 inches
0.15
0.28 ± 0.02
2.00 ± 0.10
4.00 ± 0.10
2.00 ± 0.05
mm
0.008 0.016 ± 0.002
inches
0.20
0.40 ± 0.05
mm
Taping Specifications - 0603, 0805, 1206, 1210
Type/Code
RMCF0603
RMCP0603
RMCF0805
RMCP0805
RMCF1206
RMCP1206
RMCF1210
RMCP1210
7" Reel
Quantity
(1)
Typical Full Reel
Tape Width
Weight (g)
5000
118.3 ± 11.0
5000
139.2 ± 13.0
5000
151.4 ± 15.0
4000
175.7 ± 17.0
0.315
8.00
Rev Date: 8/9/2021
A
0.071
1.80
0.093
2.35
0.140
3.55
0.138
3.50
8
B
0.008
0.20
0.010
0.25
0.010
0.25
0.008
0.20
0.041
1.05
0.063
1.60
0.077
1.95
0.110
2.80
W
0.008
0.20
0.010
0.25
0.010
0.25
0.010
0.25
0.315 ± 0.008
8.00 ± 0.20
E
Unit
0.069 ± 0.004
1.75 ± 0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCF / RMCP Series
Taping Specifications - 0603, 0805, 1206, 1210 (cont.)
Type/Code
F
RMCF0603
RMCP0603
RMCF0805
RMCP0805
RMCF1206
RMCP1206
RMCF1210
RMCP1210
0.138 ± 0.002
3.50 ± 0.05
T1
0.024
0.60
0.030
0.75
0.030
0.75
0.030
0.75
T2
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.024
0.60
0.030
0.75
0.030
0.75
0.030
0.75
P
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
P0
0.157 ± 0.004
4.00 ± 0.10
P1
0.157 ± 0.004
4.00 ± 0.10
Unit
inches
mm
inches
0.079 ± 0.002
mm
2.00 ± 0.05
inches
mm
inches
mm
Taping Specifications - 2010, 2512
Type/Code
RMCF2010
RMCP2010
RMCF2512
RMCP2512
Type/Code
7" Reel Typical Full Reel Tape
Quantity
Weight (g)
Width
183.1 ± 18.0
4000
255.3 ± 25.0
T1
0.217
0.472 5.50
12.00 0.264
6.70
T2
A
B
E
F
Unit
0.012 0.110 ± 0.008
inches
0.30
2.80 ± 0.20 0.472 ± 0.008 0.069 ± 0.004 0.217 ± 0.002 mm
0.008 0.134 ± 0.008 12.00 ± 0.20
1.75 ± 0.10
5.50 ± 0.05 inches
0.20
3.40 ± 0.20
mm
P
RMCF2010
RMCP2010 0.041 ± 0.008 0.009 ± 0.006 0.157 ± 0.004
RMCF2512
1.05 ± 0.20
0.23 ± 0.15
4.00 ± 0.10
RMCP2512
Note: Plastic carrier tape used for 2010 and 2512 sizes.
Rev Date: 8/9/2021
W
9
P0
P1
Unit
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
inches
mm
inches
mm
www.seielect.com
RMCF / RMCP Series
Single Pulse Power
The data provided are for reference only. They are typical performance for this product but are not guaranteed. The actual pulse
handling of each individual resistor may vary depending on a variety of factors including resistance tolerance and resistance
value. Stackpole Electronics, Inc. assumes no liability for the use of this information. Customers should validate the performance of
these products in their applications. Contact Stackpole marketing to discuss specific pulse application requirements.
Temperature Measurement of Resistor Surface
Description: The resistor surface generated temperature variation after applied rated voltage.
Products and power:
Size
R-V
Rated Power (W)
Max Rated Voltage (V)
0201
15K
1/20
25
0402
40.2K
1/16
50
0603
57.6K
1/10
75
0805
180K
1/8
150
1206
182K
1/4
200
1210
100K
1/2
200
2010
100K
3.4
200
2512
75K
1
200
Test method: Measure component surface temperature directly after the temperature stabilizes.
Test result: As per table below:
Hot Spot Temperature - RMCF
Size
0201
0402
0603
0805
1206
1210
2010
2512
Surface Temp. (°C)
36
37
46.2
50.4
70.6
110.6
141
150.4
Rev Date: 8/9/2021
10
www.seielect.com
RMCF / RMCP Series
The thermal resistance of the RMCP will be similar to the RMCF. For example, the RMCF2512 and the RMCP2512 will have similar
surface temperatures at 1W; the RMCP is designed to withstand higher temperatures associated with high power levels.
Part Marking Specifications
5% Marking
The nominal resistance is marked on
the surface of the overcoating with the
use of 3 digit markings.
0201 and 0402 are not marked.
1% Marking
use of 4 digit markings.
For shared E24/E96 values, 1% tolerance product may be marked wit three digit marking instead of the standard four-digit marking
for all other E96 values. All E24 values available in 1% tolerance are also marked with three-digit marking.
Marking Instructions for 0603 1% Chip Resistors (per EIA-J)
A two-digit number is assigned to each standard R-Value (E96) as shown in the chart below. This is followed by one alpha character
which is used as a multiplier. Each letter represents a specific multiplier as follows:
Z = 0.01
Y = 0.1
X=1
A = 10
B = 100
C = 1000
D = 10000
E = 100000
F = 1000000
EXAMPLE:
Chip Marking
01B
25C
93D
Explanation
01 means 10.0 and B = 100
25 means 17.8 and C = 1,000
93 means 90.9 and D = 10,000
Value
10.0 x 100 = 1K ohm
17.8 x 1,000 = 17.8K ohm
90.9 x 10,000 = 909K ohm
E96
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
R-Value
10.0
10.2
10.5
10.7
11.0
11.3
11.5
11.8
12.1
12.4
12.7
13.0
13.3
13.7
14.0
14.3
17
18
19
22
23
24
25
26
27
28
29
30
31
32
R-Value
14.7
15.0
15.4
15.8
16.2
16.5
16.9
17.4
17.8
18.2
18.7
19.1
19.6
20.0
20.5
21.0
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
Rev Date: 8/9/2021
R-Value
21.5
22.1
22.6
23.2
23.7
24.3
24.9
25.5
26.1
26.7
27.4
28.0
28.7
29.4
30.1
30.9
11
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
R-Value
31.6
32.4
33.2
34.0
34.8
35.7
36.5
37.4
38.3
39.2
40.2
41.2
42.2
43.2
44.2
45.3
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
R-Value
46.4
47.5
48.7
49.9
51.1
52.3
53.6
54.9
56.2
57.6
59.0
60.4
61.9
63.4
64.9
66.5
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
R-Value
68.1
69.8
71.5
73.2
75.0
76.8
78.7
80.6
82.5
84.5
86.6
88.7
90.9
93.1
95.3
97.6
www.seielect.com
RMCF / RMCP Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet
the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on
Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status
regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive
2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted
substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
SMD
Surface Mount Chip Resistor
General Purpose High Power
RMCP
SMD
Thick Film Chip Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
RMCF
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
YES(1)
100% Matte Sn over Ni
Jan-04 (Japan)
Jan-05 (Taiwan, China)
Lead-Free
Effective Date
Code
(YY/WW)
04/01
05/01
YES(1)
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region”
of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals
used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible
that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in
compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High
Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation,
Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH
Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We
continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the
protection of our environment and all requests related to the environment to which we have agreed. We are committed
to the prevention of all forms of pollution.
Rev Date: 8/9/2021
12
www.seielect.com
RMCF / RMCP Series
How to Order - RMCF
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
M
C
F
J
T
4
K
7
Product Series
Code Description
Thick Film
RMCF
Chip
Size
Size
W
01005 0.03
0201 0.05
0402 0.063
0603
0.1
0805 0.125
1206 0.25
1210
0.5
2010 0.75
2512
1
Code
F
J
Z
Tolerance
Tol
Value
1% E96, E24
5%
E24
Jumper
Code
T
G
Packaging
Size
Quantity
01005
10000
7" Reel - Paper
0201, 0402
10000
Tape
0603, 0805, 1206 5000
1210
4000
7" Reel 2010, 2512
4000
Plastic Tape
10" Reel 0603, 0805, 1206 10000
Paper Tape
Description
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
0.1 ohm = R100
4.70 ohm = 4R70
10.0 Kohm = 10K0
1 Mohm = 1M00
Zero ohm jumper = 0R00
How to Order - RMCP
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
M
C
P
J
T
4
K
7
Product Series
Code Description
RMCP High Power
Size
Size
W
0201 0.063
0402 0.125
0603 0.25
0805 0.33
1206
0.5
1210 0.66
2010
1
2512
2
Code
F
J
Z
Tolerance
Tol
Value
1% E96, E24
5%
E24
Jumper
Rev Date: 8/9/2021
Code
T
G
13
Packaging
Description
Size
0201, 0402
7" Reel
0603, 0805
Paper Tape
1206, 1210
2010, 2512
0603, 0805
10" Reel
1206, 1210
Paper Tape
2010
Quantity
10000
5000
4000
10000
Resistance Value
decimal holder.
1 ohm = 1R00
10 Kohm = 10K0
1 Mohm = 1M00
8000
www.seielect.com
