CSR2010FK50L0
CSR2010FK50L0
    SEI
    电阻器 50MΩ ±1% 1W ±100ppm/℃ 2010
CSR2010FK50L0 数据手册
CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Features: • • • • • • • 0201 to 1225 sizes available Power ratings to 3W Low inductance – less than 0.2nH typically Non-standard resistance values available 0815, 2010 and 2512 sizes available with narrow terminations (CSRN) RoHS compliant and halogen free REACH compliant Electrical Specifications - CSR Type/Code Power Rating (W) @ 70°C Dielectric Withstanding Voltage (V) CSR0201 0.05 200 CSR0402 CSR0603 CSR0805 CSR1206 0.125 0.125 0.25 0.5 200 200 200 200 CSR1210 0.5 200 CSR2010 CSR2512 1 2 200 200 CSR0830 2 200 CSR1225 3 TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 1% ± 1000 ± 600 ± 300 ± 200 ± 300 ± 200 ± 100 (1) ± 600 ± 400 ± 300 ± 200 ± 100 (1) ± 200 ± 300 ± 200 ± 150 - ± 300 ± 200 ± 150 ± 100 200 2%, 5% 0.1 - 0.147 0.15 - 0.499 0.511 - 1 0.0511 - 1 0.02 - 1 0.02 - 1 0.01 - 1 0.01 - 0.02 0.0205 - 0.0511 0.0523 - 0.0976 0.1 - 1 0.01 - 1 0.01 - 1 0.001 - 0.004 0.0051 - 0.01 0.0102 - 0.348 0.003 - 0.0049 0.0051 - 0.02 0.0205 - 0.0301 0.0332 - 7.87 (1) Contact Stackpole for TCR below 50 mohm Electrical Specifications – CSRN (Narrow Termination) Type/Code Power Rating (W) @ 70°C CSRN2010 1 Dielectric Withstanding Voltage (V) 200 CSRN0815 1 200 CSRN2512(*) (*) AEC-Q200 Qualified 2 200 TCR (ppm/ºC) ± 250 ± 300 ± 150 ± 200 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.01 - 1 0.01 - 0.0196 0.02 - 0.499 0.01 - 1 Electrical Specifications – CSR-HP Type/Code CSR0603…-HP Power Rating (W) @ 70°C Dielectric Withstanding Voltage (V) TCR (ppm/ºC) 200 ± 400 ± 300 ± 200 0.2 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.051 - 0.1 0.102 - 0.499 0.51 - 1 www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Electrical Specifications – CSR-HP (cont.) Power Rating (W) @ 70°C Type/Code CSR1210…-HP Dielectric Withstanding Voltage (V) 0.75 TCR (ppm/ºC) 200 Ohmic Range (Ω) and Tolerance ± 600 ± 400 ± 300 1%, 2%, 5% 0.01 - 0.02 0.0205 - 0.0499 0.051 - 0.091 ± 200 0.1 - 1 Please refer to the High-Power Resistor Application Note (page 7) for more information on designing and implementing high power resistor types. Mechanical Specifications Type/Code Weight (g) (1000 pieces) L Body Length 0.024 ± 0.001 0.60 ± 0.03 W Body Width 0.012 ± 0.001 0.30 ± 0.03 T Body Height 0.009 ± 0.002 0.23 ± 0.05 D1 Top Termination 0.005 ± 0.002 0.12 ± 0.05 CSR0201 0.18 CSR0402 D2 Unit Bottom Termination 0.006 ± 0.002 inches 0.15 ± 0.05 mm 0.7 0.039 ± 0.002 1.00 ± 0.05 0.020 ± 0.002 0.50 ± 0.05 0.013 ± 0.004 0.32 ± 0.10 0.010 ± 0.004 0.25 ± 0.10 0.008 ± 0.004 0.20 ± 0.10 inches mm CSR0603 1.99 0.063 ± 0.004 1.60 ± 0.10 0.031 ± 0.004 0.80 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 inches mm CSR0805 5.3 0.079 ± 0.006 2.00 ± 0.15 0.049 ± 0.006 1.25 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 inches mm CSR1206 8.82 0.120 ± 0.006 3.05 ± 0.15 0.061 ± 0.006 1.55 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.012 0.50 ± 0.30 0.016 ± 0.010 0.40 ± 0.25 inches mm CSR1210 15.5 0.122 ± 0.004 3.10 ± 0.10 0.102 ± 0.006 2.60 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.010 0.50 ± 0.25 inches mm CSR2010 27.03 0.197 ± 0.008 5.00 ± 0.20 0.100 ± 0.008 2.54 ± 0.20 0.020 ± 0.006 0.50 ± 0.15 0.068 ± 0.006 1.72 ± 0.15 0.067 ± 0.006 1.70 ± 0.15 inches mm CSR2512 53.08 0.252 ± 0.008 6.40 ± 0.20 0.126 ± 0.008 3.20 ± 0.20 0.020 ± 0.006 0.50 ± 0.15 0.024 ± 0.012 0.60 ± 0.30 0.079 ± 0.010 2.00 ± 0.25 inches mm CSR0830 35.71 0.079 ± 0.008 2.00 ± 0.20 0.295 ± 0.012 7.50 ± 0.30 0.024 ± 0.004 0.60 ± 0.10 0.016 ± 0.008 0.40 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 inches mm Type/Code Weight (g) (1000 pieces) CSRN0815 19.96 CSRN2010 CSRN2512 Mechanical Specifications – CSRN (Narrow Termination) L Body Length 0.079 ± 0.008 2.00 ± 0.20 W Body Width 0.148 ± 0.008 3.75 ± 0.20 T Body Height 0.024 ± 0.004 0.60 ± 0.10 D1 Top Termination 0.016 ± 0.008 0.40 ± 0.20 27.03 0.197 ± 0.008 5.00 ± 0.20 0.096 ± 0.006 2.45 ± 0.15 0.024 ± 0.006 0.60 ± 0.15 0.024 ± 0.012 0.60 ± 0.30 0.020 ± 0.010 0.50 ± 0.25 inches mm 53.08 0.250 ± 0.008 6.35 ± 0.20 0.124 ± 0.006 3.15 ± 0.15 0.024 ± 0.004 0.60 ± 0.10 0.024 ± 0.012 0.60 ± 0.30 0.022 ± 0.010 0.55 ± 0.25 inches mm Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 D2 Unit Bottom Termination 0.016 ± 0.008 inches 0.40 ± 0.20 mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Mechanical Specifications – CSR1225 Type/Code Weight (g) (1000 pieces) L W T D1 D2 F Unit 64.88 0.126 ± 0.006 3.20 ± 0.15 0.254 ± 0.006 6.45 ± 0.15 0.035 ± 0.006 0.90 ± 0.15 0.024 ± 0.012 0.60 ± 0.30 0.031 ± 0.010 0.80 ± 0.25 0.090 ± 0.005 2.29 ± 0.13 inches mm CSR1225 Performance Characteristics Test Method Test Specification Typical Test Condition High Temperature Exposure Test MIL-STD-202 Method 108 1% Tol: (± 1% + 0.05Ω) 2%, 5% Tol: (± 1.5% + 0.1Ω) ≤ 0.5% 1000 hours at T = 155°C. Unpowered. Measurement at 24 ± 4 hours after test conclusion. Short Time Overload JIS-C-5201-1 4.13 IEC 60115-1 4.13 ± (0.5% + 0.05Ω) ≤ 0.25% ± (1% + 0.05Ω) For high power rating ≤ 0.5% RCV (rated current) * 2.5 for 5 seconds. 1000 Cycles (-55°C to +125°C) Measurement at 24 ± 4 hours after test conclusion. 30 minuntes maximum ≤ 0.5% dwell time at each temperature extreme. 1 minute maximum transition time. 1000 hours 85°C / 85% RH. Note: Specified ≤ 0.5% conditions: 10% of operating power. Measurement at 24 ± 4 hours after test conclusion. Temperature Cycling JESD22 Method JA-104 1% Tol: (± 0.5% + 0.05Ω) 2%, 5% Tol: (± 1.5% + 0.1Ω) Biased Humidity MIL-STD-202 Method 103 1% Tol: (± 1% + 0.1Ω) 2%, 5% Tol: (± 2% + 0.1Ω) Operational Life MIL-STD-202 Method 108 1% Tol: (± 1% + 0.1Ω) 2%, 5% Tol: (±2% + 0.1Ω) ≤ 0.5% External Visual MIL-STD 883 Method 2009 - Pass Physical Dimensions JESD22 Method JB-100 - Pass MIL-STD 202 Method 215 Marking unsmeared Pass MIL-STD 202 Method 213 1% Tol: (± 0.25% + 0.05Ω) 2%, 5% Tol: (± 1% + 0.05Ω) ≤ 0.5% Resistance to Solvents Mechanical Shock Vibration MIL-STD 202 Method 204 1% Tol: (± 0.5% + 0.05Ω) 2%, 5% Tol: (±1% + 0.05Ω) Resistance to Soldering Heat MIL-STD 202 Method 210 1% Tol: (± 0.5% +0.05Ω) 2%, 5% Tol: (± 1% + 0.05Ω) ESD AEC-Q200-002 -- Solderability J-STD-002 > 95% Coverage Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 Condition D Steady State TA = 125°C at rated power. Measurement at 24 ± 4 hours after test conclusion. Electrical test not required. Inspect device construction, marking and workmanship. Verify physical dimensions to the applicable device detail specification. Note: User(s) and supplier specification, electrical test not required. Note: Aqueous wash chemical - OKEM Clean or equivalent. Do not use banned solvents. Figure 1 of Method 213. Condition C. 5g's for 20 minuntes, 12 cycles each of 3 orientations. Note: Use 8" X 5" PCB 0.031" thick 7 secure points on ≤ 0.5% one long side and 2 secure points at corners of opposite sides. Parts mounted within 2" from any secure point. Test from 10 - 2000Hz. Condition B no pre-heat of samples. Note: Single ≤ 0.5% wave solder - Procedure 2 for SMD. With the electrometer in direct contact with the discharge tip, verify the voltage setting at levels of ± Pass 500V, ± 1kV, ± 2kV, ± 4kV, ± 8kV. The electrometer reading shall be within ± 10% for voltages from 500V to ≤ 8kV. Electrical test not required. Magnification 50 times. Conditions: SMD: Pass a) Method B, 4 hours @ 155°C dry heat @ 235°C. b) Method B @ 215°C category 3. c) Method D category 3 at 260°C. www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Method Electrical Characterization User Spec Flammability UL-94 Board Flex AEC-Q200-005 Terminal Strength (SMD) Flame Retardance Voltage Proof Test Specification -- Typical Pass No ignition of tissue or scorching Pass of pine board. 1% Tol: (± 1% + 0.05Ω) ≤ 0.5% 2%, 5% Tol: (± 1% + 0.05Ω) AEC-Q200-006 No breakage Pass AEC-Q200-001 No flame Pass JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover Pass Test Condition Parametrically test per lot and sample size requirements, summary to show Min, Max, Mean and Standard Deviation at room as well as Min and Max operating temperatures. V - 0 or V - 1 are acceptable. Electrical test not required. 60 second minimum holding time. 1.42 times Max. Operating Voltage for 1 minute. 0201: 50V; 0402: 100V; 0603: 150V; 0805: 300V 1206, 1210, 2010, 2512, 0830, 1225, 0815: 400V Operating temperature range is -55ºC to +155ºC Power Derating Curve: Recommended Pad Layouts - CSR Type/Code CSR0201 CSR0402 CSR0603 CSR0805 CSR1206 CSR1210 a 0.010 0.25 0.020 0.50 0.031 0.80 0.039 1.00 0.079 2.00 0.079 2.00 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. b 0.012 0.30 0.020 0.50 0.039 1.00 0.039 1.00 0.045 1.15 0.045 1.15 4 0.016 0.40 0.024 0.60 0.035 0.90 0.053 1.35 0.067 1.70 0.098 2.50 c ± ± ± ± ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Recommended Pad Layouts – CSR (cont.) Type/Code a 0.039 1.00 0.142 3.60 0.193 4.90 0.047 1.20 CSR0830 CSR2010 CSR2512 CSR1225 b 0.071 1.80 0.055 1.40 0.063 1.60 0.079 2.00 0.299 7.60 0.098 2.50 0.126 3.20 0.276 7.00 c ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm inches mm 0.154 3.90 0.098 2.50 0.126 3.20 c ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 Unit inches mm inches mm inches mm Recommended Pad Layouts - CSRN Type/Code a 0.039 1.00 0.142 3.60 0.193 4.90 CSRN0815 CSRN2010 CSRN2512 b 0.071 1.80 0.055 1.40 0.063 1.60 Reel Specifications Type/Code A B C W T 0201 0402 0603 0805 0.374 ± 0.004 9.50 ± 0.10 0.453 ± 0.039 11.50 ± 1.00 0.531 ± 0.039 13.50 ± 1.00 0.610 ± 0.039 15.50 ± 1.00 0.689 ± 0.039 17.50 ± 1.00 0.768 ± 0.039 19.50 ± 1.00 1206 1210 7.008 ± 0.039 178.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 0.531 ± 0.028 13.50 ± 0.70 2010 2512 1225 0815 0830 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Packaging Specifications – Paper Tape Size 0201 0402 0603 0805 1206 1210 A 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.114 2.90 Size B ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0201 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 E 0.315 ± 0.004 8.00 ± 0.10 0.069 ± 0.002 1.75 ± 0.05 0.315 ± 0.008 8.00 ± 0.20 0.069 ± 0.004 1.75 ± 0.10 P2 D0 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0402 W 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.002 4.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 Unit 0.138 ± 0.002 3.50 ± 0.05 T 0.017 0.42 0.018 0.45 0.028 0.70 0603 0805 F ± ± ± ± ± ± 0.008 0.20 0.004 0.10 0.004 0.10 0.059 + 0.004/-0 1.50 + 0.10/-0 0.033 ± 0.004 0.85 ± 0.10 1206 1210 inches mm inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm inches mm Packaging Specifications – Embossed Plastic Tape Size 2010 2512 1225 0815 0830 A 0.110 2.80 0.133 3.38 0.133 3.38 0.098 2.50 0.098 2.50 ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.217 5.50 0.263 6.68 0.263 6.68 0.175 4.45 0.327 8.30 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 6 0.472 ± 0.012 12.00 ± 0.30 0.630 ± 0.012 16.00 ± 0.30 E 0.069 ± 0.004 1.75 ± 0.10 F 0.217 5.50 0.217 5.50 0.217 5.50 0.217 5.50 0.307 7.80 ± ± ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions Packaging Specifications – Embossed Plastic Tape (cont.) Size P0 2010 0.157 ± 0.002 4.00 ± 0.05 2512 1225 0815 0830 0.157 ± 0.004 4.00 ± 0.10 P1 P2 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.002 4.00 ± 0.05 T Unit 0.059 + 0.004/-0 1.50 + 0.10, -0 D0 0.039 ± 0.008 1.00 ± 0.20 0.061 + 0.002/-0 1.55 + 0.05, -0 0.057 ± 0.008 1.45 ± 0.20 0.061 + 0.004/-0 1.55 + 0.10, -0 0.047 ± 0.008 1.20 ± 0.20 inches mm inches mm inches mm inches mm inches mm High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohms at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 mΩ. This should be taken into account when designing. Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com CSR / CSRN Series Stackpole Electronics, Inc. Thick Film Current Sensing Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series CSR CSRN Package / Termination Type Description Thick Film Current Sensing Surface Mount Chip Resistor Thick Film Current Sensing Surface Mount Chip Resistor, Narrow Standard Series RoHS Compliant YES by means of exemption 7c-I YES by means of exemption 7c-I SMD SMD Lead-Free Termination Composition Lead-Free Lead-Free Effective Date Mfg. Effective Date Code (Std Product Series) (YY/WW) 100% Matte Sn over Ni May-04 04/18 100% Matte Sn over Ni May-04 04/18 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 C S R 1 2 0 6 F T 1 0 L 0 - H P Product Series Code Description CSR Standard Narrow CSRN Terminations Size Code W 0201 0.05 0402 0.13 0603 0.13 0805 0.25 1206 0.5 1210 0.5 2010 1 2512 2 0815 1 0830 2 1225 3 Tolerance Code Tol F 1% G 2% J 5% Code Description 7" Reel Paper Tape T 7" Reel Plastic Tape 7" Reel Paper Tape K 7" Reel Plastic Tape Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Packaging Size Quantity 0201, 0402 10000 0603, 0805, 1206, 1210 5000 2010, 2512 4000 0815, 0830, 1225 2000 0402 0603, 0805, 1206, 1210 1000 2010, 2512 0815, 0830, 1225 8 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of -3 10 for any value under 0.1 ohm Special (*) Code Description -HP High Power (*) Only available for 0603 and 1210 sizes 0.051 ohm = 51L0 0.35 ohm = R350 1 ohm = 1R00 www.seielect.com marketing@seielect.com
CSR2010FK50L0 价格&库存
很抱歉,暂时无法提供与“CSR2010FK50L0”相匹配的价格&库存,您可以联系我们找货
