CX0805MRX7R9BB183
CX0805MRX7R9BB183
    YAGEO(国巨)
    CX0805MRX7R9BB183
CX0805MRX7R9BB183 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC EMI FILTER CAPACITORS X2Y® Series Product Specification – September 30, 2016 V.15 6.3 V TO 100 V ® DESCRIPTION FEATURES BENEFITS             APPLICATIONS             ® QUICK REFERENCE DATA DESCRIPTION VALUE μ  ® GENERAL SELECTION CHART C (pF) X7R 0603 0805 X5R 1206 1210 0603 50V 10 V 1,000 1,500 2,200 100V 100 V 4,700 5,600 10,000 50 V 15,000 100 V 18,000 25 V 50 V 22,000 25 V 39,000 47,000 16 V 50 V 16 V 56,000 100,000 10 V 180,000 220,000 270,000 10 V 16 V 330,000 390,000 470,000 10 V 560,000 820,000 16 V 1,000,000 ® MECHANICAL DATA Physical dimensions Table 1 CASE SIZE L W T MIN. A MAX. MIN. MAX. C Dimensions in millimetres                         Dimensions in inches ® CHARACTERISTICS FOR X7R Class 2 capacitors; X7R dielectric; Ni/Sn terminations DESCRIPTION VALUE ≧ Ω Note  CHARACTERISTICS FOR X5R Class 2 capacitors; X5R dielectric; Ni/Sn terminations DESCRIPTION VALUE Ω Note  ® SELECTION CHART FOR X7R SIZES 0603, 0805, 1206,1210 AND ORDERING INFORMATION Y-CAPACITOR SIZE 0603 0805 CAP. (nF) TOLERANCE ( %) VOLTAGE RATING (V) 1 20% 100 0.65 CX0603MRX7R0BB102 4,000 1 20% 50 0.65 CX0603MRX7R9BB102 4,000 1 20% 16 0.65 CX0603MRX7R7BB102 4,000 1.5 20% 100 0.65 CX0603MRX7R0BB152 4,000 1.5 20% 50 0.65 CX0603MRX7R9BB152 4,000 2.2 20% 100 0.65 CX0603MRX7R0BB222 4,000 4.7 20% 100 0.65 CX0603MRX7R0BB472 4,000 5.6 20% 100 0.65 CX0603MRX7R0BB562 4,000 5.6 20% 50 / 63 0.65 CX0603MRX7R9BB562 4,000 10 20% 50 / 63 0.65 CX0603MRX7R9BB103 4,000 15 20% 25 0.65 CX0603MRX7R8BB153 4,000 18 20% 25 0.65 CX0603MRX7R8BB183 4,000 22 20% 25 0.65 CX0603MRX7R8BB223 4,000 39 20% 16 0.65 CX0603MRX7R7BB393 4,000 47 20% 16 0.65 CX0603MRX7R7BB473 4,000 56 20% 16 0.65 CX0603MRX7R7BB563 4,000 100 20% 10 0.65 CX0603MRX7R6BB104 4,000 180 20% 10 0.65 CX0603MRX7R6BB184 4,000 220 20% 10 0.65 CX0603MRX7R6BB224 4,000 270 20% 10 0.65 CX0603MRX7R6BB274 4,000 330 20% 10 0.65 CX0603MRX7R6BB334 4,000 1 20% 100 0.85 CX0805MRX7R0BB102 4,000 1 20% 50 0.85 CX0805MRX7R9BB102 4,000 1.5 20% 100 0.85 CX0805MRX7R0BB152 4,000 2.2 20% 100 0.85 CX0805MRX7R0BB222 4,000 4.7 20% 100 0.85 CX0805MRX7R0BB472 4,000 10 20% 100 0.85 CX0805MRX7R0BB103 4,000 15 20% 50 0.85 CX0805MRX7R9BB153 4,000 18 20% 50 0.85 CX0805MRX7R9BB183 4,000 22 20% 50 0.85 CX0805MRX7R9BB223 4,000 22 20% 50 0.85 CX0805MRX7R8BB223 4,000 47 20% 16 0.85 CX0805MRX7R7BB473 4,000 56 20% 16 0.85 CX0805MRX7R7BB563 4,000 100 20% 16 0.85 CX0805MRX7R7BB104 4,000 180 20% 10 0.85 CX0805MRX7R6BB184 4,000 THICKNESS (mm) CTC ORDERING CODE QUANTITY PER REEL ® Y-CAPACITOR SIZE CAP. (nF) TOLERANCE ( %) VOLTAGE RATING (V) THICKNESS (mm) CTC ORDERING CODE QUANTITY PER REEL 10 20% 100 1.2 CX1206MKX7R0BB103 3,000 15 20% 100 1.2 CX1206MKX7R0BB153 3,000 15 20% 50 1.2 CX1206MKX7R9BB153 3,000 18 20% 100 1.2 CX1206MKX7R0BB183 3,000 22 20% 100 1.2 CX1206MKX7R0BB223 3,000 33 20% 100 1.2 CX1206MKX7R0BB333 3,000 39 20% 50 1.2 CX1206MKX7R9BB393 3,000 47 20% 50 1.2 CX1206MKX7R9BB473 3,000 56 20% 50 1.2 CX1206MKX7R9BB563 3,000 100 20% 50 1.2 CX1206MKX7R9BB104 3,000 180 20% 16 1.2 CX1206MKX7R7BB184 3,000 220 20% 16 1.2 CX1206MKX7R7BB224 3,000 270 20% 16 1.2 CX1206MKX7R7BB274 3,000 330 20% 16 1.2 CX1206MKX7R7BB334 3,000 390 20% 16 1.2 CX1206MKX7R7BB394 3,000 470 20% 10 1.2 CX1206MKX7R6BB474 3,000 100 20% 50 1.6 CX1210MKX7R9BB104 2,000 180 20% 50 1.6 CX1210MKX7R9BB184 2,000 220 20% 50 1.6 CX1210MKX7R9BB224 2,000 270 20% 50 1.6 CX1210MKX7R9BB274 2,000 330 20% 50 1.6 CX1210MKX7R9BB334 2,000 390 20% 50 1.6 CX1210MKX7R9BB394 2,000 470 20% 50 1.6 CX1210MKX7R9BB474 2,000 470 20% 25 1.6 CX1210MKX7R8BB474 2,000 560 20% 50 1.6 CX1210MKX7R9BB564 2,000 560 20% 25 1.6 CX1210MKX7R8BB564 2,000 820 20% 16 1.6 CX1210MKX7R7BB824 2,000 1000 20% 16 1.6 CX1210MKX7R7BB105 2,000 1206 1210 ® SELECTION CHART FOR X5R SIZES 0603 Y-CAPACITOR SIZE CAP. (nF) TOLERANCE ( %) VOLTAGE RATING (V) 180 20% 10 0.65 CX0603MRX5R6BB184 4,000 220 20% 10 0.65 CX0603MRX5R6BB224 4,000 270 20% 10 0.65 CX0603MRX5R6BB274 4,000 330 20% 10 0.65 CX0603MRX5R6BB334 4,000 390 20% 10 0.65 CX0603MRX5R6BB394 4,000 470 20% 10 0.65 CX0603MRX5R6BB474 4,000 470 20% 10 0.65 CX0603MRX5R5BB474 4,000 0603 THICKNESS (mm) CTC ORDERING CODE QUANTITY PER REEL Notes THICKNESS CLASSIFICATION AND PACKING QUANTITIES FOR X7R QUANTITY PER REEL 8 mm TAPE WIDTH THICKNESS CLASSIFICATION (mm) ∅ 180 mm; 7" 0603 - 1210 PAPER 0.65 ±0.1 4,000 0.85 ±0.1 4,000 − 1.2 ±0.15 1.6 ±0.15 ∅ 330 mm; 13" − BLISTER 3,000 2,000 PAPER BLISTER ® ORDERING INFORMATION Ordering code: Yageo part number Example: CX0805MRX7R8BB223 ® RECOMMENDED DIMENSIONS OF SOLDER LANDS Table 3 CASE SIZE (EIA) Footprint dimensions (mm) A B C D E Placement Accuracy (mm)     ® MEASUREMENT SETUP W      Table 4 CASE SIZE A( ) B(         ) ® TESTS AND REQUIREMENTS Table 5 IEC 60384-10/ CECC 32 100 CLAUSE IEC 60068-2 TEST METHOD TEST δ PROCEDURE REQUIREMENTS ® Table 5 δ ® REVISION HISTORY Revision Date Change Notification Description
CX0805MRX7R9BB183
物料型号:X2Y系列,包括X7R和X5R两种材料类型。
器件简介:X2Y系列是用于去耦和滤波的陶瓷多层产品的突破性设计。它由两个相同的Y型电容器和一个X型电容器组成,集成在一个4端子设备中,提供标准MLCC尺寸。独特的多层结构设计使设备内部实现噪声抵消,将等效串联电感(ESL)从纳亨级别降低到皮亨级别。
引脚分配:文档中未明确说明具体的引脚分配,但提到了4端子设备。
参数特性: - 额定电压:X7R系列为6.3V至100V,X5R系列为6.3V和10V。 - 电容范围:Y型电容器的容量范围从1nF至1uF,具体容量取决于尺寸和材料。 - 电容公差:+20%。 - 测试电压:直流2.5倍额定电压,持续1分钟。 - 气候类别:X7R系列为55/125/56。
功能详解:X2Y设备作为宽带滤波器,能够在广泛的应用范围内实现更好的电磁兼容性(EMC)。
应用信息: - 用于高速数字电路、电源供应、信号线路、USB端口、RJ-45连接器等的去耦和电磁干扰(EMI)抑制。 - 可以替代多个电感器和/或电容器,消除差模和共模噪声。
封装信息:提供多种尺寸,包括0603、0805、1206、1210和1210,具体尺寸和物理参数在文档中有详细表格说明。
CX0805MRX7R9BB183 价格&库存
很抱歉,暂时无法提供与“CX0805MRX7R9BB183”相匹配的价格&库存,您可以联系我们找货
CX0805MRX7R9BB183
    • 1+1.41167
    • 200+0.54627
    • 500+0.52715
    • 1000+0.51765
