RG series
SUSUMU CO.,LTD
Ultra precision 0.02%, 0.05%, 0.1%, 0.25%, 0.5%, tolerance
Thin Film Chip Resistor
FEATURES
• High Reliability and Excellent Stability at different environmental conditions
• Low noise, THIN FILM(NiCr) construction
• EIA Standard case size(0402, 0603, 0805, 1206)
• RoHS Compliance and 100% Lead-Free (Matte Sn termination finished)
APPLICATIONS
• Automotive
• Test & Measurement
• Optical & Telecommunication
• Medical and Industrial Equipment
Electrical Specification
Power Rating ar 85 oC
Type
Size
Low
(ultra precision)
Regular
High
Resistance
Tolerance
(Code)
+0.5% (D)
Resistance
Range
(ohm)
10-100K
+0.25% (C)
RG1005
0402
0.032W
0.063W
0.125W
+0.1% (B)
47-100K
+0.05% (W)
RG1608
0603
0.063W
+0.02% (V)
100-2.94K
+0.5% (D)
10-360K
+0.25% (C)
47-274K
0.166W
0.1W
+0.1% (B)
47-332K
+0.05% (W)
RG2012
RG3216
0805
1206
0.1W
0.125W
0.125W
+0.02% (V)
100-4.99K
+0.5% (D)
10-1M
+0.25% (C)
47-1M
+0.1% (B)
47-1M
0.25W
+0.05% (W)
47-475K
+0.02% (V)
100-10K
+0.5% (D)
47-1M
+0.25% (C)
47-1M
+0.1% (B)
47-1M
0.25W
+0.05% (W)
47-1M
+0.02% (V)
100-33.2K
Temperature Coefficient (Code)
(ohm)
(ppm/oC)
10-46.4
47-100K
100-2.94K
47-100K
100-2.94K
47-100K
100-2.94K
47-100K
100-2.94K
100-2.94K
10-46.4
47-360K
47-274K
100-4.99K
47-274K
100-4.99K
47-332K
47-274K
100-4.99K
47-332K
47-274K
100-4.99K
100-4.99K
10-46.4
47-1M
47-475K
100-10K
47-1M
100-10K
47-1M
47-475K
100-10K
47-475K
47-475K
100-10K
100-10K
10-46.4
10-1M
100-33.2K
47-1M
100-33.2K
47-1M
100-33.2K
47-1M
100-33.2K
100-33.2K
100(R)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N), 5(V)
50(Q)
25(P)
10(N)
5(V)
25(P), 10(N)
5(V)
25(P)
10(N)
5(V)
25(P)
10(N)
5(V)
25(P), 10(N), 5(V)
50(Q)
25(P)
10(N)
5(V)
25(P), 10(N)
5(V)
25(P)
10(N)
5(V)
25(P)
10(N)
5(V)
25(P), 10(N), 5(V)
50(Q)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N)
5(V)
25(P), 10(N), 5(V)
Max.
operating
Voltage
Resistance
Values
(E-series)
25V
E-24, E-96
75V
E-24, E-96
100V
E-24, E-96
150V
E-24, E-96
www.susumu.co.jp
RG series
SUSUMU CO.,LTD
Performance
Dimensions & Footprints
Dimensions inch (mm)
L
P
P
R G 1005
R G 1608
W
R G 2012
T
R G 3216
L
W
P
T
.0 4 0 ± .0 0 2
.0 2 0 ± .0 0 2
.0 0 8 ± .0 0 4
.0 1 4 ± .0 0 2
(1 .0 ± 0 .0 5 )
(0 .5 ± 0 .0 5 )
(0 .2 ± 0 .1 )
(0 .3 5 ± 0 .0 5 )
.0 6 3 ± .0 0 8
.0 3 1 ± .0 0 8
.0 1 2 ± .0 0 8
0 .0 1 6 ± .0 0 4
(1 .6 ± 0 .2 )
(0 .8 ± 0 .2 )
(0 .3 ± 0 .2 )
(0 .4 ± 0 .1 )
.0 7 9 ± .0 0 8
.0 4 9 ± .0 0 8
.0 1 6 ± .0 0 8
0 .0 1 6 ± .0 0 4
(2 .0 ± 0 .2 )
(1 .2 5 ± 0 .2 )
(0 .4 ± 0 .2 )
(0 .4 ± 0 .1 )
.1 2 6 ± .0 0 8
.0 6 3 ± .0 0 8
.0 2 ± .0 1
0 .0 1 6 ± .0 0 4
(3 .2 ± 0 .2 )
(1 .6 ± 0 .2 )
(0 .5 ± 0 .2 5 )
(0 .4 ± 0 .1 )
Dimensions (mm)
c
a
b
c
R G 1005
0 .5
1 .6
0 .6
R G 1608
1 .0
3 .0
1 .2
a
R G 2012
1 .2
4 .0
1 .7
b
R G 3216
2 .0
5 .0
2 .0
Recommended Reflow Curve
Power Derating Curve
Sldering Temperature Profile
:For operation above 85degC, power rating must be
derated according to the following chart
300
Peak Temperature 260oC
250
1-5oC/Sec.
1-5oC/Sec.
200
150
10 Sec.
100
120 Sec.
50
1-9oC/Sec.
Ordering information
RG
1608
TYPE
S iz e
N
104
TCR
W
R - Va lu e s
T5
To le r a n c e
Package
1005
V = 5 p p m /oC
3 d ig its f o r E 2 4 s e r ie s
P = 0 .0 2 %
T1=1000
1608
N =10ppm / C
(E x .1 0 4 = 1 0 0 K
W = 0 .0 5 %
T5=5000
2012
P = 2 5 p p m /oC
4 d ig its f o r E 9 6 s e r ie s
B = 0 .1 %
3216
Q = 5 0 p p m /oC
(E x .4 9 9 2 = 4 9 .9 K
C = 0 .2 5 %
o
R =100ppm / C
o
oh m )
oh m )
D = 0 .5 %
www.susumu.co.jp
RG series
SUSUMU CO.,LTD
Reliability Test Data
Tape & Reel Dimensions (mm)
www.susumu.co.jp
很抱歉,暂时无法提供与“RG2012V-1241-W-T1”相匹配的价格&库存,您可以联系我们找货
