Q10E1D152MN0B0S0N0
Q10E1D152MN0B0S0N0
    STE(松田)
    插件,P=10mm
    贴片电容(MLCC) 径向 1.5nF ±20% 400V Y5U
Q10E1D152MN0B0S0N0 数据手册
Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) SPECIFICATION CD Series (Y1-Series) Company and Factory Name: SHANTOU FREE TRADE ZONE SONGTIAN ELECTRONIC TECHNOLOGY CO.,LTD Add: Songtian science and technology park,Free trade zone,Shantou,City,Guangdong,China. E-mail: info@songtian.cn P.O.BOX: 515071 Homepage: http://songtian-ste.com 1 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) Contents 1. Applications.......................................................................................................................................................3 2. Part Number Code........................................................................................................................................... 3 3. Electrical Characteristics.................................................................................................................................4 4. Dimensions....................................................................................................................................................... 4 5. nternal Structure...............................................................................................................................................6 6. Marking.............................................................................................................................................................. 6 7. Temperature Characteristic Curves.............................................................................................................. 7 8. Taping And Dimensions.................................................................................................................................. 7 9. Safety Certificate.............................................................................................................................................. 8 10. Performance Test Methods And Requirements........................................................................................8 11. Reliability Test Methods And Requirements............................................................................................. 9 12. Storage Conditions......................................................................................................................................11 13. Environmental Compliance........................................................................................................................ 11 14. Packaging..................................................................................................................................................... 12 2 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 1. Applications Can be used for power supply noise suppression circuit in cross connection and bypass.It is a primary and secondary coupling X/Y capacitor used as AC line filter and switching power supply and AC converter. 2. Part Number Code Q Rated Voltage Q:Y1 09 F 1 Temperatur e Characteris tic S:SL B:Y5P E:Y5U F:Y5V D Pitch D:10.0mm M N0 Tolerance K:±10% M:±20% B 0 S Package B: Bulk T:Tape 0 N 0 Inner Management Environmental Standard 0:RoHS 2:RoHS+Halogen-Free Foot Type 1:Long straight 2:Outside Crimped 3:Short Straight 8:Vertical Crimped Core Diameter 07:7mm 08:8mm 09:9mm 10:10mm 11:11mm 12:12mm 222 Lead Length S0~S9:1.0~1.9mm X0~X9:2.0~2.9mm A0~A9:3.0~3.9mm B0~B9:4.0~4.9mm C0~C9:5.0~5.9mm D0~D9:6.0~6.9mm E0~E9:7.0~7.9mm Nominal capacitance 101:100pF 151:470pF 221:470pF 331:470pF 471:470pF 102:1000pF 152:1500pF 222:2200pF 472:4700pF 3 Lead Length F0~F9:8.0~8.9mm G0~G9:9.0~9.9mm H0~H9:10.0~10.9mm J0~J9:11.0~11.9mm K0~K9:12.0~12.9mm L0~L9:13.0~13.9mm M0~M9:14.0~14.9mm Lead Length M0~M9:14.0~14.9mm N0:16~27.0mm(Bulk) Crimped Lead Taped N0:H0=16.5mm P0:H0=17.0mm Q0:H0=19.0mm Straight Lead Q0:20.0mm Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 3. Electrical Characteristics Capacitance and Dissipation factor testing condition SL: 25℃, 1MHz, 1Vrms Y5P/Y5U/Y5V:25℃, 1KHz, 1Vrms Dissipation Factor(tanδ) S(SL): D.F.≤0.15% B(Y5P), E(Y5U), F(Y5V): D.F.≤2.5% Rated Voltage 400VAC Withstand Voltage 4000VAC Insulation Resistance (I.R.) ≥10000MΩ Temperature Characteristic SL, Y5P, Y5U, Y5V 4. Dimensions PN of STE Dimension (mm) D Max T Max L Min F±0.8 Φd±0.05 Q07B1D101KN0B0 S0N0 7.0 4.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk Q07B1D221KN0B0 S0N0 7.0 5.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk Q08B1D331KN0B0 S0N0 8.5 5.0 16.0 10.0 0.6 11.0 2.5 Example 2 Bulk Q09B1D471KN0B0 S0N0 9.0 5.0 16.0 10.0 0.65 11.5 2.5 Example 1 Bulk 4 H1 Max c Max Marking Packing Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) Q12B1D102KN0B0 S0N0 12.0 5.5 16.0 10.0 0.65 15.0 3.0 Example 1 Bulk Q07E1D331KN0B0 S0N0 7.0 5.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk Q07E1D471KN0B0 S0N0 7.0 5.0 16.0 10.0 0.6 9.5 2.5 Example 2 Bulk Q08E1D102MN0B0 S0N0 8.0 5.0 16.0 10.0 0.6 10.5 2.5 Example 2 Bulk Q10E1D152MN0B0 S0N0 10.0 5.0 16.0 10.0 0.65 12.5 2.5 Example 1 Bulk Q11E1D222MN0B0 S0N0 11.0 5.0 16.0 10.0 0.65 14.0 3.0 Example 1 Bulk Q08F1D152MN0B0 S0N0 8.0 5.0 16.0 10.0 0.6 10.5 2.5 Example 2 Bulk Q09F1D222MN0B0 S0N0 9.0 5.0 16.0 10.0 0.65 11.5 2.5 Example 1 Bulk Q07B1D101KQ0T0 S0N0 7.0 4.0 / 10.0 0.6 9.5 2.5 Example 2 Taping Q07B1D151KQ0T0 S0N0 7.0 4.0 / 10.0 0.6 9.5 2.5 Example 2 Taping Q07B1D221KQ0T0 S0N0 7.0 5.0 / 10.0 0.6 9.5 2.5 Example 2 Taping Q07E1D331KQ0T0 S0N0 7.0 5.0 / 10.0 0.6 9.5 2.5 Example 2 Taping Q08E1D102MQ0T0 S0N0 8.0 5.0 / 10.0 0.6 10.5 2.5 Example 2 Taping Q09F1D222MQ0T0 S0N0 9.0 5.0 / 10.0 0.65 11.5 2.5 Example 1 Taping Q12F1D472MQ0T0 S0N0 12.0 5.5 / 10.0 0.65 15.0 3.0 Example 1 Taping 5 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 5. Internal Structure No. Name Material 1 Electrode Metal Layer 2 Ceramic Dielectric Ceramic 3 Lead Free Tin Bar 4 Lead Wire CP wire 5 Coating Epoxy Resin 6 Marking Laser marking Note Color:Blue 6. Marking ①Registered Trademark Type(CD:Y1) □□□ M (±20%) ②CD ③Nominal Capacitance ④Capacitance Tolerance ENEC(EU) VDE ⑤Safety Certification Sign KTL CQC UL ⑥Rated Voltage 400V~(400VAC) ⑦Sub-Class of X1 Y1 Safety Performance Example 1:Y1 Single Sided Printing Example 1: Y2 Double Sided Printing 6 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 7. Temperature Characteristic Curves 8. Taping And Dimensions Code Po P P1 P2 F ΔS Δh W Wo Size(mm) 12.7 25.4 7.7 12.7 10.0 0 0 17.0 10.5 Tolerance ±0.3 ±1.0 ±0.7 ±1.3 ±0.8 ±2.0 ±2.0 +1.5/-1.0 Max Code W1 W2 H1 Do H L t1 t2 c Size(mm) 9.0 3.0 45.0 4.0 20.0 11.0 0.5 1.7 2.5 Tolerance +0.75/-0.5 Max Max ±0.2 +1.5/-1 Max ±0.2 Max Max 7 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 9. Safety Certificate USA Canada Certification Body UL CUL Korea KTL China CQC Germany VDE EU ENEC Country Report Reference Certificate No. Capacitance Range UL60384-14 E208107 10~4700pF SU03031-19001A 100~4700pF CQC19001213616 10~4700pF 40025754 10~4700pF 40025754 10~4700pF K60384-14 (2015) GB/T 6346.14-2015 En 60384-14: 2017-04 En 60384-14: 2017-04 Rated Voltage X1Y1: 400VAC 10. Performance Test Methods And Requirements No. 1 Item Standard Test Method Temperature Range -25℃~125℃ 2 Appearance/Size 3 Marking 4 Capacitance / Capacitors must be visually inspect to No opparent defect,size within the check if there’s opparent defect and normal range measure size with vernier caliper Clear and easy to recognize Within the specified tolerance 5 D.F. S(SL): D.F.≤0.15% B(Y5P), E(Y5U), F(Y5V): D.F.≤2.5% 6 I.R. >10000MΩ Dielectric Strength S(SL): 25 ° C, 1 ± 0.1 MHz, 1.0 V B(Y5P), E(Y5U), F(Y5V): 25 ° C, 1 ± 0.1 KHz, 1.0 V. 500VDC, 60s±5s . Between No breakdown and flashover Leads 7 Visual inspection Between Leads and No breakdown and flashover Body 8 Between terminals: AC4000V (r.m.s.), 60s, ≤50mA As shown in figure at right,a metal foil should be closely wrapped around the body of the capacitor to the distance of about 3 to 4mm from each terminal.hen,the capacitor should be inserted into a container filled with metal balls of about 1mm diameter.voltage applied AC4000V(r.m.s.),60s Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 11. Reliability Test Methods And Requirements No. Item Standard B(Y5P) Capacitance change +140~-1000ppm/ ℃ ±10% E(Y5U) +22/-56% Char. S(SL) 1 Temperature Characteristics Test Method F(Y5V) +30/-80% Temperature range: -25 ~+85℃ 2 Solderability The capacitance measurement should be made at each step specified in Table 3 < Table 3> Step 1 2 3 4 5 Temperature 20 -25 20 85 20 (℃) ±2 ±2 ±2 ±2 ±2 Lead wire should be 245±3℃, 3±0.3s. soldered with uniform coating on the axial direction Solder composition: over 95% of the Sn96.5Ag3.0Cu0.5 circumferential direction. Appearance No marked defect 3 Solder Resistance Heat Up Capacitance Within ±10% change I.R. Dielectric Strength 260 ± 5℃,10.0 ± 0.5 s. ≥1000MΩ Per 10.1 [Basic characteristics] item7 Appearance No visible damage 4 Vibration Capacity D.F. 5 Humidity (Under Steady State) Appearance Capacity Rate of Change I.R. Within the tolerance S(SL): D.F.≤5% B(Y5P)/E(Y5U)/F(Y5V): D.F.≤2.5% 10~55Hz, 0.75mm, 10Hz→55Hz→10Hz. 1min Apply for a total of 6 hours, 2 hrs each in 3 mutually perpendicular directions. No visible damage S(SL)/B(Y5P)/ E(Y5U)/F(Y5V): ≤±15% >5000MΩ Withstand Per 10.1 Voltage [Basic characteristics] item7 9 40±2℃, 90-95%RH, 500±12 hours. Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) No. Item Standard Test Method Appearance No visible damage 6 Humidity Loading Capacitance S(SL)/B(Y5P)/ E(Y5U)/F(Y5V): Change ≤±15% I.R. Dielectric Strength 40±2℃, 90~ 95% RH, Apply with UR,500±12 hours. >5000MΩ Per 10.1[Basic characteristics] item7 Impulse Voltage: 8KVDC,three times. After the capacitors are applied to life test. Appearance No visible damage 7 Life Test Capacitance Within ±20% change I.R. Dielectric Strength 8 >5000MΩ 125+2/-0℃,relative humidity of 50% max, 1000 hours,1.7*UR (r.m.s.), except that once each Per 10.1[Basic hour the voltage is increased to AC1000V(r.m.s.) for characteristics] item7 0.1 sec. The Varistor under test shall be held in the flame in the position which best promotes burning. Each specimen shall be exposed once in the flame. Specifically as follows: level C requirements. Capacitor volume (mm3) Apply flame time (S) Passive The burning time shall not be exceeded the standard. Flammability The tissue paper shall ignite. 9 250< volume≤ 500 500< volume≤ 1750 volume >1750 Maximum burning time (S) A B 15 10 30 20 60 30 120 60 3 10 C 5 10 20 30 30 As shown in the figure at right, 10N, 10±1 sec. Tensile Strength Robustness of Termination Class volume <250 Lead wire should not be cut off. Capacitor should Each lead wire should be subjected to 5N weight not be broken. and then a 90° bend, at the point of egress, in one Bending Strength direction, return to original position, and then apply a 90° bend in the opposite direction at the rate of one bend in 2 to 3 sec. 10 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) No. 10 Item Standard Test Method No visible Capacitors should be tested in the order shown in the Appearance damage following table (for one cycle) for five consecutive cycles. Temperature cycling S(SL)/B(Y5P)/ Capacitance E(Y5U): (℃) Order (min) Rate of ±20%; 1 -25 +0/-3 30 Change F(Y5V): ±30%。 2 +25 +0/-3 3 Rapid S(SL)/B(Y5P)/E 3 125 +3/-0 30 Temperature (Y5U): 4 +25 +0/-3 3 D.F. D.F.≤5.0% Changes F(Y5V): [Pre-treatment]: D.F.≤7.5% Stored at 85 ± 2 ° C , 1 hour and then 24 ± 2 hours before I.R. >5000MΩ making initial measurements. Per 10.1[Basic [Treatment After testing]: Withstand characteristics] Capacitors must be stored at room temperature for 24 ± 2 Voltage hours. item7 12. Storage Conditions 12.1 Storage Temperature: ≤35℃. 12.2 Relative Humidity: ≤70% RH. 12.3 Keep away from corrosive atmosphere and sunlight. 12.4 Period : 1 year. 13. Environmental Compliance: RoHS Compliance REACH Compliance 11 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) 14. Packaging External Packaging (Bulk) Internal Packaging (Bulk) External Packaging (Taping) Internal Packaging (Taping) Dimension Description (cm) External Packaging (Bulk) Internal Packaging (Bulk) L B H L B H 41.0 29.0 16.0 18.6 27.3 12.6 External Packaging (Taping) L B H 54.0 36.0 26.3 Internal Packaging (Taping) B A C 4.4 33.5 26.2 12 Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1) SPQ Reference Table Type Specification P=5 B P=7.5 E Bulk P=10 Type D SPQ Quantity Long Lead/Short Lead Φ≤13 500 Long Lead/Short Lead Φ≤8 1000 Long Lead/Short Lead Φ>8 500 Short lead 1000 Long Lead 500 Long Lead 14≦Φ
Q10E1D152MN0B0S0N0 价格&库存
很抱歉,暂时无法提供与“Q10E1D152MN0B0S0N0”相匹配的价格&库存,您可以联系我们找货
