C0402C0G500-3R0BNE
C0402C0G500-3R0BNE
    VENKEL
    贴片电容(MLCC) 3.0pF ±0.1pF C0G (NP0) 0402 50V
C0402C0G500-3R0BNE 数据手册
C SERIES GENERAL PURPOSE CERAMIC CAPACITORS FEATURES: • Capacitance range: 0.1pF to 220uF • Voltage range: 4V to 100V • Terminations: 100% matte Tin (Sn), Palladium (Pd-Ag), Gold (Au) and Lead (Pb) • Very low ESR in X7R/X7S/X6S/X5R (1000 Ω-F or 10 GΩ, for values ≤ 0.047uF (whichever is less at 25°C, WDCV). For Capacitance values > 0.047uF, the 500 Ω-F rule applies. (The IR at 125°C is 10% of the value at 25°C) Typical Capacitance Change vs. Temperature 15% 10% 5% 0% -5% -10% -15% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C 125˚C Ageing: None Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: B,C,D,F,G,J,K Dissipation Factor: 0.1% max X7R RATED VOLTAGE Operating Temperature Range: -55°C to +125°C Temperature Coefficient: 0 ±15%Δ°C MAX. Temperature Voltage Coefficient: X7R not applicable Insulation Resistance: >100 Ω-F or 10 GΩ, whichever is less at 25°C, VDCW. (The IR at 125°C is 10% of the value at 25°C) Ageing: 2.5% per decade hour, typical Typical Capacitance Change vs. Temperature 15% 10% 5% 0% -5% -10% -15% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: J,K,M 125˚C ≥50V 25V 16V D.F. EXCEPTION OF D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤2.5% ≤2.5% ≤3.5% 10V ≤5% 6.3V ≤10% RATED VOLTAGE D.F. X7S Operating Temperature Range: -55°C to +125°C Temperature Coefficient: 0 ±22%Δ°C MAX. Insulation Resistance: >1000 Ω-F or 100 GΩ, whichever is less at 25°C, VDCW. (The IR at 125°C is 10% of the value at 25°C) Ageing: 2.5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: K,M Typical Capacitance Change vs. Temperature 40% 20% 0% -20% -40% -60% -80% -100% -55˚C -25˚C 0˚C 25˚C 50C 75˚C 100˚C 125˚C Email: sales@venkel.com | Phone: 512.794.0081 | ≥50V 25V 16V EXCEPTION OF D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤2.5% ≤2.5% ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤3.5% ≤10V ≤5% 6.3V ≤10% Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 2 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ELECTRICAL SPECIFICATIONS RATED VOLTAGE X6S Typical Capacitance Change vs. Temperature 40% 20% 0% -20% -40% -60% -80% -100% -55˚C -25˚C 0˚C 25˚C 50C 75˚C 100˚C 125˚C Operating Temperature Range: -55°C to +105°C Temperature Coefficient: 0 ±22%Δ°C MAX. Insulation Resistance: 100,000 MΩ min., or 1000 MΩ (@ +25˚C, RVDC) per uF min. or 100GW, whichever is less Ageing: 2.5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: K,M X5R Operating Temperature Range: -55°C to +85°C Temperature Coefficient: 0 ±15%Δ°C MAX. Insulation Resistance: >100 Ω-F or 10 GΩ, whichever is less at 25°C, VDCW. (The IR at 125°C is 10% of the value at 25°C) Ageing: 2.5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: K,M Typical Capacitance Change vs. Temperature 15% 10% 5% 0% -5% -10% -15% -55°C -25°C 0°C 25°C 50°C 75°C 100°C 125°C Z5U Typical Capacitance Change vs. Temperature 20% 0% -20% -40% -60% -80% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C 125˚C Y5V Operating Temperature Range: -30°C to +85°C Temperature Coefficient: +22% - 82%Δ°C MAX. Insulation Resistance: >100 Ω-F or 10 GΩ, whichever is less at 25°C, VDCW. (The IR at 125°C is 10% of the value at 25°C) Ageing: 7% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: M,Z Typical Capacitance Change vs. Temperature 40% 20% 0% -20% -40% -60% -80% -100% -55˚C -25˚C 0˚C 25˚C 50C 75˚C 100˚C 125˚C Email: sales@venkel.com Operating Temperature Range: +10°C to +85°C Temperature Coefficient: +22% - 56%Δ°C MAX. Insulation Resistance: >100 Ω-F or 10 GΩ, whichever is less at 25°C, WDCV. (The IR at 125°C is 10% of the value at 25°C) Ageing: 5% per decade hour, typical Withstanding Voltage: >2.5 times VDCW Capacitance Tolerance: M,Z | Phone: 512.794.0081 | ≥50V 25V 16V D.F. ≤2.5% 4V/6.3V ≤10% RATED VOLTAGE D.F. 16V 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤3.5% ≤5% 25V ≤3% ≤2.5% ≤10V ≥50V EXCEPTION OF D.F. EXCEPTION OF D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤2.5% ≤2.5% ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤3.5% ≤10V ≤5% 6.3V ≤10% RATED VOLTAGE D.F. ≥50V ≤5% EXCEPTION OF D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% RATED VOLTAGE D.F. ≥50V ≤5% EXCEPTION OF D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; ≥1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 3 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS TEST PARAMETERS Test parameters for Multilayer Ceramic Capacitors - X7R, X7S, X6S, X5R and Y5V: 1KHz ± 100Hz at 1.0 ± 0.2 Vrms < 10uF (10 V min.) 1KHz ± 100Hz at 0.5 ± 0.1 Vrms < 10uF (6.3V max.) 120Hz ± 24Hz at 1.0 ± 0.1 Vrms ≥ 10uF Test parameters for Multilayer Ceramic Capacitors - C0G: 1MHz ± 100KHz at 1.0 ± 0.2 Vrms ≤ 1000pF, 25°C 1KHz ± 100Hz at 1.0 ± 0.2 Vrms > 1000pF, 25°C NOTE: T  o ensure proper capacitance readings, the voltage level must be held constant. The HP4284 and Agilent E4980 has a “ALC” (Automatic Level Control) function and should be switched to the “ON” position for accurate capacitance readings. VOLTAGE AND CAPACITANCE RANGE L w C0G (C0G) DIELECTRIC E/B T Values that are typically available. (All measurements in inches) SIZE 01005 T (max) 0.008 0R2 0R3 0R4 0R5 1R0 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 5R0 5R6 6R8 8R2 100 120 150 180 220 VDCW (MAX) 0R1 0201 6.3V 16V 25V 0402 0.012 50V 25V 0504 0.025 50V 25V 50V 0.040 100V 50V 100V 0603 0805 0.033 50V 100V 1206 0.055 25V 50V 1210 0.075 100V 50V 100V 0.075 50V 100V 1812 0.085 50V 100V 0.1pF 0.2pF 0.3pF 0.4pF 0.5pF 1.0pF 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.0 5.6 6.8 8.2 10pF 12 15 18 22 NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 4 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w C0G (C0G) DIELECTRIC E/B T Values that are typically available. (All measurements in inches) 01005 T (max) 0.008 VDCW (MAX) 6.3V 16V 25V 50V 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 SIZE 0201 0402 0.012 25V 0504 0.025 50V 25V 50V 0.040 100V 50V 100V 0603 0805 0.033 50V 100V 1206 0.055 25V 50V 0.075 100V 50V 100V 1210 0.075 50V 100V 1812 2220 / 2221 0.085 0.108 /.108 50V 100V 50V 100V 27 33 39 47 56 68 82 100pF 120 150 180 220 270 330 390 470 560 680 820 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .012 .015 .018 .022 .027 .033 .039 .047 .056 .068 .082 .100uF 25V 50V .120 .150 .180 .220 .270 .330 .390 .470 .560 .680 .820 NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 5 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 01005 T (max) 0.008 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 VDCW (MAX) 101 0201 6.3V 10V 0402 0.012 6.3V 10V 16V 0504 0.025 25V 16V 25V 0603 0.040 50V 100V 25V 50V 0805 0.038 100V 10V 16V 25V 0.058 50V 100V 25V 50V 100V 100pF 120 150 180 220 270 330 390 470 560 680 820 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .012 .015 .018 .022 .027 .033 *F  or values above 1uF, thickness may be greater than specified above. T(max): 0603 – 0.040" 0805 – 0.060" NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 6 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 0201 T (max)* 0.012 473 563 683 823 104 124 154 184 224 274 334 394 474 564 684 824 105 125 155 185 225 335 475 685 106 156 226 476 107 VDCW (MAX) 393 0402 0603 0.025 4V 6.3V 10V ** ** ** 6.3V 10V 16V 0805 0.038 25V 50V 6.3V 10V 16V 25V 0.059 50V 100V 6.3V 10V 16V 25V 50V 100V .039 .047 .056 .068 .082 0.10uF .120 .150 .180 .220 .270 .330 .390 .470 .560 .680 .820 1.00uF 1.20 1.50 1.80 2.20 3.30 4.70 6.80 10.0uF 15.0uF 35V 22.0uF 47.0uF 100.0uF *F  or values above 1uF, thickness may be greater than specified above. T(max): 0603 – 0.040" 0805 – 0.060" NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. All components manufactured with the X7R dielectric are also available as an X5R dielectric. ** RE: 0201, X7R, 0.1uF; When the operating temperature range is between 100˚C and 125˚C, it is recommended to apply the following voltage derating as shown in the diagram below. Ratio [Operating Voltage / Rated Voltage (%)] DERATING CURVE FOR 0201, 0.1UF, X7R ONLY 120 100 80 60 402 0 0 0 25 50 75 100 125 150 Ambient temperature (˚C) Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 7 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 1206 T (max)* 0.070 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 VDCW (MAX) 102 1210 10V 16V 25V 1812 0.125 50V 100V 10V 16V 25V 2220 / 2221 0.085 50V 100V 6.3V 10V 16V 25V 0.108 /0.108 50V 100V 16V 25V 50V 100V 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .012 .015 .018 .022 .027 .033 .039 .047 .056 .068 .082 .100uF .120 .150 .180 .220 .270 .330 *F  or values above 1uF, thickness may be greater than specified above. T(max): 0603 – 0.040" 0805 – 0.060" NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 8 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7R DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 1206 T (max)* 0.070 474 564 684 824 105 125 155 185 225 335 475 685 106 156 226 476 107 VDCW (MAX) 394 1210 6.3V 10V 16V 25V 1812 0.125 50V 100V 6.3V 10V 16V 2220 / 2221 0.095 25V 50V 100V 6.3V 10V 16V 25V 0.108 /0.108 50V 100V 16V 25V 50V 100V .390 .470 .560 .680 .820 1.00uF 1.20 1.50 1.80 2.20 3.30 4.70 6.80 10.0uF 15.0uF X7S/X7R X7S/X7R X7S/X7R 22.0uF 47.0uF 100.0uF *F  or values above 1uF, thickness may be greater than specified above. T(max): 1206 – 0.075” 1812 – 0.130” 1210 – 0.125” 2220 – 0.135” NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 9 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X7S DIELECTRIC (0201-0805) Values that are typically available. (All measurements in inches) SIZE 0201 T (max)* 0.012 224 474 105 225 475 106 226 476 107 VDCW (MAX) 104 0402 4V 6.3V 0603 0.025 10V 16V 6.3V 10V 16V 0805 0.038 25V 50V 6.3V 10V 16V 0.059 25V 50V 6.3V 10V 1.00uF 2.2 4.7 10.0uF 22.0uF 47.0uF 100.0uF T (max)* 335 475 106 156 226 476 107 105 225 (All measurements in inches) 1206 1210 0.07 VDCW (MAX) 474 50V 0.22 SIZE 224 25V 0.47 X7S DIELECTRIC (1206-2220) 104 16V 0.10uF 6.3V 10V 16V 1812 0.125 25V 50V 6.3V 10V 16V 2220 0.095 25V 50V 16V 25V 50V 0.108 100V 16V 25V 50V 100V 0.10uF 0.22 0.47 1.00uF 2.2 3.3 4.7 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF *F  or values above 1uF, thickness may be greater than specified above. T(max): 0603 – 0.040" 0805 – 0.060" NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 10 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X6S DIELECTRIC (0201-0805) Values that are typically available. (All measurements in inches) SIZE 0201 T (max)* 0.012 224 474 105 225 475 106 226 476 107 VDCW (MAX) 104 0402 4V 6.3V 0603 0.025 10V 16V 6.3V 10V 16V 0805 0.038 25V 50V 4V 6.3V 10V 16V 0.059 25V 50V 4V 6.3V 1.00uF 2.2 4.7 10.0uF 22.0uF 47.0uF 100.0uF 335 475 106 156 226 476 107 105 (All measurements in inches) 1206 T (max)* 225 50V 0.22 1210 0.07 VDCW (MAX) 474 25V 0.47 SIZE 224 16V 0.10uF X6S DIELECTRIC (1206-2220) 104 10V 6.3V 10V 16V 1812 0.125 25V 50V 6.3V 10V 16V 2220 0.095 25V 50V 16V 25V 50V 0.108 100V 16V 25V 50V 100V 0.10uF 0.22 0.47 1.00uF 2.2 3.3 4.7 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF *F  or values above 1uF, thickness may be greater than specified above. T(max): 0603 – 0.040" 0805 – 0.060" NOTE: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 11 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X5R DIELECTRIC Values that are typically available. (All measurements in inches) 01005 T (max) 0.008 VDCW (MAX) 6.3V 10V 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 393 473 104 154 224 334 474 684 105 125 155 185 225 335 SIZE 0201 0.0216 4V 6.3V 10V 16V 25V 0402 0603 0805 0.025 0.040 0.060 4V 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 35V 50V 6.3V 10V 16V 1206 1210 0.072 25V 50V 6.3V 10V 16V 0.125 25V 16V 25V 1812 0.130 16V 25V 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .015 .022 .033 .039 .047 0.10uF .150 .220 .330 .470 .680 1.00uF 1.20 1.50 1.80 2.20 3.30 *F  or values above 1uF, thickness may be greater than specified above. T(max): 1206 – 0.075” 1812 – 0.130” 1210 – 0.125” 2220 – 0.135” NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 12 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE X5R DIELECTRIC (0402-1206) Values that are typically available. (All measurements in inches) SIZE 0201 0402 0603 0805 1206 T (max) 0.0216 0.0335 0.040 0.060 0.072 395 475 685 106 156 226 476 107 157 227 VDCW (MAX) 4V 6.3V 10V 4V 6.3V 10V 16V 4V 6.3V 10V 16V 25V 4V 6.3V 10V 16V 25V 35V 50V 6.3V 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF 150.0uF 220.0uF 476 107 157 227 156 226 (All measurements in inches) 1210 T (max) 106 50V 6.80uF 1812 0.125 VDCW (MAX) 685 25V 4.70uF SIZE 475 16V 3.90uF X5R DIELECTRIC (1210-2221) 395 10V 6.3V 10V 16V 2220 / 2221 0.130 25V 50V 6.3V 10V 0.135 16V 25V 6.3V 10V 16V 25V 50V 3.90uF 4.70uF 6.80uF 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF 150.0uF 220.0uF *F  or values above 1uF, thickness may be greater than specified above. T(max): 1206 – 0.075” 1812 – 0.130” 1210 – 0.125” 2220 – 0.135” NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. All components manufactured with the X7R dielectric are also available as an X5R dielectric. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 13 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE Z5U DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 0504 T (max) 0.040 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 VDCW (MAX) 102 0603 25V 0805 0.038 50V 25V 1206 0.058 50V 25V 1210 0.070 50V 25V 1812 0.075 50V 25V 2220 / 2221 0.085 50V 25V 0.108 /0.108 50V 25V 50V 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .012 .015 .018 .022 .027 .033 .039 .047 .056 .068 .082 .100uF .120 .150 .180 .220 .270 .330 NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 14 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE Z5U DIELECTRIC Values that are typically available. (All measurements in inches) SIZE 0504 T (max) 0.040 474 564 684 824 105 125 155 185 225 335 395 475 685 106 156 226 476 107 VDCW (MAX) 394 0603 25V 0805 0.038 50V 25V 1206 0.058 50V 25V 1210 0.070 50V 25V 1812 0.075 50V 25V 2220 / 2221 0.085 50V 25V 0.108 /0.108 50V 25V 50V .390 .470 .560 .680 .820 1.00uF 1.20 1.50 1.80 2.20 3.30 3.90 4.70 6.80 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. For values above 1uF, thickness may be greater than specified above. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 15 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE Y5V DIELECTRIC Values that are typically available. 0201 T (max) 0.012 VDCW (MAX) 10V 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 184 224 274 334 (All measurements in inches) SIZE 0402 0603 0805 1206 1210 1812 0.025 0.038 0.058 0.070 0.096 0.085 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 10V 16V 25V 50V 6.3V 10V 16V 25V 6.3V 10V 25V 1000pF 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 .01uF .012 .015 .018 .022 .027 .033 .039 .047 .056 .068 .082 .100uF .120 .150 .180 .220 .270 .330 NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. For values above 1uF, thickness may be greater than specified above. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 16 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE Y5V DIELECTRIC Values that are typically available. 0201 T (max) 0.012 VDCW (MAX) 10V 394 474 564 684 824 105 125 155 185 225 335 395 475 685 106 156 226 476 107 (All measurements in inches) SIZE 0402 0.025 6.3V 10V 16V 6.3V 10V 0603 0805 0.038 0.058 16V 25V 50V 6.3V 10V 16V 25V 50V 10V 1206 1210 1812 0.070 0.10 0.085 16V 25V 50V 6.3V 10V 16V 25V 50V 6.3V 10V 25V .390 .470 .560 .680 .820 1.00uF 1.20 1.50 1.80 2.20 3.30 3.90 4.70 6.80 10.0uF 15.0uF 22.0uF 47.0uF 100.0uF NOTE: A  dditional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. For values above 1uF, thickness may be greater than specified above. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 17 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS TAPE & REEL SPECIFICATIONS All tape and reel specifications must be adhered to per EIA-481-1-A. REEL G Unit: mm (inch) Tape B N To T D 10 Pitches Cumulative Tolerance 0.008 ( 0.2 ) G T max - 21 ± 0.8 (0.82 ± 0.03) 50 (1.97) 5.0 ± 1.5 (0.196 ± 0.05) 8.0 max (0.315 max) 20.2 (0.795) 50 (1.97) 10 ± 1.5 (0.394 ± 0.059) 14.9 (0.587) 12mm 2.0 (0.07) 13 ± 0.05 178 ±2.0 (0.512 ± 0.02) (7 ± 0.079) 330 ± 2.0 (13± 0.08) 20.2 (0.795) 50 (1.97) 10 ± 1.5 (0.394 ± 0.059) 14.9 (0.587) 7” Reel Quantities ** SIZE 01005 (E) 01005 (P) 0201 0402 0603 0805 1206 1210 1812 2221 Tape Size 4mm 8mm 8mm Po Pz E F P 8mm 8mm 8mm 8mm 8mm 12mm 12mm Min Qty Per Reel 40,000* 20000* 15,000 5,000 3,000 2,000 2,000 1,000 1,000 1,000 Max Qty Per Reel 40,000* 20000* 15,000 10,000 4,000 5,000 5,000 5,000 3,000 1,000 W Center Of Cavity NOTE: ** Quantity dependent on thickness *Smaller quantities may be available. Please contact us. Direction Of Feed Paper Tape Size Carrier (inches) Dimensions (8mm) 01005 Embossed Carrier Dimensions (4mm, 8mm & 12mm) N min 330 ± 2.0 (13± 0.08) B Paper Top Tape Embossed D min 13 ± 0.05 178 ±2.0 (0.512 ± 0.02) (7 ± 0.079) A T A (13”) 2.0 (0.07) T TAPE A (7”) 8mm C FULL RADIUS C 2.0 13 ± 0.05 178 ±2.0 (0.079) (0.512 ± 0.02) (7 ± 0.079) 4mm D A B min Unit: mm (inch) A B W F E Po Pz D t P 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 2.0 ± 0.05 (0.079 ± 0.002) 0.25 ± 0.05 (0.010 ± 0.002) 0.45 ± 0.05 (0.018 ± 0.002) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 0201 0.37 ± 0.05 (0.014 ± 0.002) 0.67 ± 0.05 (0.026 ± 0.002) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 2.0 ± 0.05 (0.079 ± 0.002) 0402 0.65 ± 0.1 (0.026 ± 0.004) 1.10 ± 0.2 (0.043 ± 0.008) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 2.0 ± 0.05 (0.079 ± 0.002) 0603 1.10 ± 0.2 (0.043 ± 0.008) 1.90 ± 0.2 (0.075 ± 0.008) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 4.0 ± 0.1 (0.157 ± 0.004) 0805 1.16 ± 0.2 (0.046 ± 0.008) 2.4 ± 0.2 (0.095 ± 0.008) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 4.0 ± 0.1 (0.157 ± 0.004) 1206 2.0 ± 0.2 (0.079 ± 0.008) 3.6 ± 0.2 (0.142 ± 0.008) 8.0 ± 0.2 (0.315 ± 0.008) 3.5 ± 0.1 (0.138 ± 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 4.0 ± 0.1 (0.157 ± 0.004) 2.0 ± 0.05 - 0.0 (0.039 ± 0.002) - 0.000 1.5 + 0.1 (0.064 + .004) 1.15 max (0.045 max) 4.0 ± 0.1 (0.157 ± 0.004) Size (inches) 01005 0603 A B 0.23 (0.009) 0.43 (0.016) W F E Po 4.0 ± 0.05 1.8 ± 0.02 0.9 ± 0.05 2.0 ± 0.04 (0.157 ± 0.002) (0.070 ± 0.001) (0.035 ± 0.002) (0.079 ± 0.001) 1.05 ± 0.15 1.90 ± 0.15 8.0 ± 0.3 (0.042 ± .006) (0.075 ± 0.006) (0.315 ± 0.012) 3.5 ± .0.1 (0.138 ± .004) 1.75 ± 0.1 (0.069 ± .004) 4.0 ± 0.1 (0.157 ± .004) Pz D To T P 2.00 (0.079) 0.8 ± 0.04 (0.031 ± 0.001) 0.5 max (0.019 max) 0.15 ~0.4 (0.005 ~0.015) 1.00 (0.039) 2.0 ± 0.05 (0.079 ± .002) 1.5 + 0.1 - 0.0 (0.06 + .004) - 0.000 0.75 max (0.03 max) 0.6 max (0.024 max) 4.0 ± 0.1 (0.157 ± 0.004) 0805 1.48 ± 0.2 2.3 ± 0.3 (0.058 ± 0.008) (0.091 ± .008) 1.5 + 0.1 8.0 ± 0.3 3.5 ± .0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (0.315 ± 0.008) (0.138 ± 0.004) (0.069 ± 0.004) (0.157 ± 0.004) (0.079 ± 0.002) (0.06 + 0.004) - 0.000 2.5 max (0.098 max) 0.6 max (0.024 max) 4.0 ± 0.1 (0.157 ± 0.004) 1206 1.5 + 0.1 2.0 ± 0.2 3.6 ± 0.3 8.0 ± 0.3 3.5 ± .0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (0.079 ± 0.008) (0.142 ± 0.008) (0.315 ± 0.008) (0.138 ± 0.004) (0.069 ± 0.004) (0.157 ± 0.004) (0.079 ± 0.002) (0.06 + 0.004) - 0.000 2.5 max (0.098 max) 0.6 max (0.024 max) 4.0 ± 0.1 (0.157 ±0.004) 1210 1.5 + 0.1 2.9 ± 0.2 3.6 ± 0.3 8.0 ± 0.3 3.5 ± .0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (0.114 ± 0.008) (0.142 ± 0.008) (0.315 ± 0.008) (0.138 ±0.004) (0.069 ± 0.004) (0.157 ± 0.004) (0.079 ± 0.002) (0.06 + 0.004) - 0.000 2.5 max (0.098 max) 0.6 max (0.024 max) 4.0 ± 0.1 (0.157 ± 0.004) 1812 1.5 + 0.1 3.6 ± 0.2 4.9 ± 0.3 12.0 ± 0.3 5.6 ± .0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (0.142 ± 0.008) (0.193 ± 0.008) (0.472 ± 0.012) (0.221 ± 0.004) (0.069 ± 0.004) (0.157 ± 0.004) (0.079 ± 0.002) (0.06 + 0.004) - 0.000 3.8 max (0.150 max) 0.6 max (0.024 max) 8.0 ± 0.1 (0.315 ± 0.004) Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 18 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE TEST CONDITION 1 APPEARANCE NO ABNORMAL EXTERIOR APPEARANCE THROUGH MICROSCOPE (X10) 2 INSULATION RESISTANCE 10,000M OR 50OM μF PRODUCT WHICHEVER IS SMALLER (RATED VOLTAGE IS BELOW 16V: 10,000M OR 100M μF) RATED VOLTAGE SHALL BE APPLIED. MEASUREMENT TIME IS 60 - 120 RATED VOLTAGE TIME 60 SEC . 3 WITHSTANDING VOLTAGE NO DIELECTRIC BREAKDOWN OR MECHANICAL BREAKDOWN CLASS I : 300% OF THE RATED VOLTAGE FOR 1-5 SEC, CLASS II: 250% OF THE RATED VOLTAGE FOR 1-5 SEC IS APPLIED WITH LESS THAN 50mA CURRENT CAPACITANCE WITHIN THE SPECIFIED TOLERANCE CLASS I 4 CAPACITANCE WITHIN THE SPECIFIED TOLERANCE CLASS II 5 Q OVER 30pF : Q 1,000 LESS THAN 30pF: Q 400 +20C (C: CAPACITANCE) CLASS I FREQUENCY 1,000pF AND BELOW 1MHz ±10% MORE THAN 1,000 pF 1kHz ± 10% VOLTAGE 0.5 ~ 5 Vrms CAPACITANCE FREQUENCY VOLTAGE 4.7μF AND BELOW 1kHz ± 10% 1.0 ± 0.2Vrms MORE THAN 4.7μF 120Hz ± 20% 1.0 ± 0.2Vrms VOLTAGE CAPACITANCE FREQUENCY 1,000pF AND BELOW 1MHz ±10% MORE THAN 1,000 pF 1kHz ± 10% 0.5 ~ 5 Vrms X7R, X6S, X5R Rated Voltage D.F. ≥50V ≤2.5% 25V 16V 6 DISSIPATION FACTOR CLASS II (TanΘ CLASS II) ≤2.5% Exception of D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤3.5% 10V ≤5% 6.3V ≤10% Y5V, Z5U Rated Voltage D.F. ≥50V ≤5% ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% Email: sales@venkel.com | Exception of D.F. Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 19 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE TEMP. COEFFICIENT (PPM/°C) CHARACTERISTIC 7 CAPACITANCE TEMPERATURE COEFFICIENT TEST CONDITION CLASS I COG/C0G THESE SYMMETRICAL TOLERANCE APPLY TO 2 POINT MEASUREMENT OF TEMPERATURE COEFFICIENT: ONE AT -25°C AND AT 85°C 0 ± 60 (±30) STEP TEMPERATURE (°C) –150 ± 60 1 25 ± 2 -220 ± 60 2 MIN RATED TEMP ± 2 –330 ± 60 3 25 ± 2 –470 ± 60 4 MAX RATED TEMP ± 2 –750 ± 120 5 25 ± 2 +350 ~ –1000 CAPACITANCE CHANGE CHAR. X 8 TEMPERATURE CHARACTERISTICS CLASS II Y CAP. CHANGE (%) X7R ±15% STEP TEMP. (°C) B TEMP. (°C) F 1 25 ± 2 25 ± 2 2 -55 ± 2 -25 ± 2 X6S ±22% 3 25 ± 2 25 ± 2 X5R ±15% 4 125 ± 2 85 ± 2 Y5V -82% ~ +22% 5 25 ± 2 25 ± 2 Z5U -56% ~ +22% C2 - C1 X 100% C1 C1: CAPACITANCE AT STANDARD TEMPERATURE (25°C) C2: CAPACITANCE AT EACH TEMPERATURE A 500g.f PRESSURE SHALL BE APPLIED FOR 10±1 SECOND 9 ADHESIVE STRENGTH OF TERMINATION NO INDICATION OF PEELING SHALL OCCUR ON THE TERMINAL ELECTRODE 500g. f APPEARANCE NO MECHANICAL DAMAGE SHALL OCCURE CHARACTER 10 CAPACITANCE CLASS II X (X7R, X6S, X5R) WITHIN ±12.5% Y (Y5V,Z5U) WITHIN ±30% SOLDERABILITY Email: sales@venkel.com | R=340 50 WITHIN ±5% OR ±0.5pF WHICHEVER IS LARGER MORE THAN 75% OF THE TERMINAL SURFACE IS TO BE SOLDERED NEWLY, SO METAL PART (A) DOES NOT COME OUT OR DISSOLVE 11 20 CHANGE OF CAPACITANCE CLASS I BENDING STRENGTH BENDING SHALL BE APPLIED TO THE LIMIT (1mm) WITH 0.3mm/SEC Phone: 512.794.0081 | 45± 1 45± 1 BENDING LIMIT SOLDER TEMPERATURE: 245 ± 5 ˚C SOLDER: Sn_Ag3_0.5Cu FLUX: RMA Type PRE-HEATING: AT 80 ~ 120 ˚C FOR 10 ~ 30 SEC. Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 20 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE APPEARANCE NO MECHANICAL DAMAGE SHALL OCCUR CHARACTERISTIC CAP. CHANGE CLASSS I WITHIN ±2.5% OR ±0.25 pF WHICHEVER IS LARGER CAPACITANCE 12 RESISTANCE TO SOLDERING HEAT X WITHIN ±7.5% Y WITHIN ±20% CLASS II QCLASS I 30 pF AND OVER: Q 1000 LESS THAN 30 pF: Q 400 + 20xC Tan CLASS II TO SATISFY THE SPECIFIED INITIAL VALUE INSULATION RESISTANCE TO SATISFY THE SPECIFIED INITIAL VALUE WITHSTANDING VOLTAGE TO SATISFY THE SPECIFIED INITIAL VALUE APPEARANCE NO MECHANICAL DAMAGE SHALL OCCUR CHARACTERISTIC CAP. CHANGE CLASSS I WITHIN ±2.5% OR ±0.25 pF WHICHEVER IS LARGER CAPACITANCE 13 VIBRATION TEST CLASS II X WITHIN ±5% Y WITHIN ±20% QCLASS I 30 pF AND OVER: Q 1000 LESS THAN 30 pF: Q 400 + 20xC Tan CLASS II TO SATISFY THE SPECIFIED INITIAL VALUE INSULATION RESISTANCE TO SATISFY THE SPECIFIED INITIAL VALUE Email: sales@venkel.com | TEST CONDITION Phone: 512.794.0081 | DIP : SOLDER TEMPERATURE OF 270± 5 ˚C DIP TIME :10±1 SEC. EACH TERMINATION SHALL BE FULLY IMMERSED AND PREHEATED AS FOLLOWING: STEP TEMP. (˚C) TIME (SEC.) 1 80~100 60 2 150~180 60 MEASURE AT ROOM TEMP. AFTER COOLING FOR CLASS I : 24 ± 2 HOURS CLASS II : 48 ± 4 HOURS THE CAPACITOR SHALL BE SUBJECTED TO A HARMONIC MOTION HAVING A TOTAL AMPLITUDE of 1.5mm THE ENTIRE FREQUENCY RANGE, FROM 10 TO 55Hz AND RETURN TO 10Hz SHALL BE TRAVERSED IN 1 MINUTE. THIS CYCLE SHALL BE PERFORMED 2 HOURS IN EACH THREE MUTUALLY PERPENDICULAR DIRECTION, FOR TOTAL PERIOD of 6 HOURS. Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 21 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE APPEARANCE TEST CONDITION NO MECHANICAL DAMAGE SHALL OCCUR CHARACTERISTIC CAPACITANCE CHANGE CLASS I WITHIN ±5% OR±0.5pF WHICHEVER IS LARGER CAPACITANCE CLASS II X WITHIN ±12.5% Y WITHIN ±30% 30pF AND OVER : Q 350 10 ~ 30pF : Q 275 + 2.5xC LESS THAN 10pF : Q 200 + 10xC QCLASS I X7R, X6S, X5R 14 HUMIDITY (STEADY STATE) DISSIPATION FACTOR (TanΘ CLASS II) Rated Voltage D.F. ≥50V ≤2.5% 25V ≤2.5% 16V ≤3.5% 10V ≤5% 6.3V ≤10% Exception of D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF TEMPERATURE : 40±2 ˚C RELATIVE HUMIDITY: 90~95 %RH TEST TIME : 500 +12/-0 Hr. MEASURE AT ROOM TEMPERATURE AFTER COOLING FOR CLASS I : 24±2 Hr. CLASS II : 48±4 Hr. SEE (FIG.3) Y5V, Z5U Rated Voltage D.F. ≥50V ≤5% Exception of D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% INSULATION RESISTANCE Email: sales@venkel.com MINIMUM INSULATION RESISTANCE: 1,000M OR 50M μF PRODUCT WHICHEVER IS SMALLER | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 22 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE APPEARANCE TEST CONDITION NO MECHANICAL DAMAGE SHALL OCCUR CHARACTERISTIC CAPACITANCE CHANGE CLASS I WITHIN ±7.5% OR±0.75pF WHICHEVER IS LARGER CAPACITANCE CLASS II X WITHIN ±12.5% Y WITHIN ±30% 30pF AND OVER : Q 200 30pF AND BELOW : Q 100 + 10/3xC QCLASS I X7R, X6S, X5R 15 MOISTURE RESISTANCE DISSIPATION FACTOR (TanΘ CLASS II) Rated Voltage D.F. ≥50V ≤2.5% 25V ≤2.5% 16V ≤3.5% 10V ≤5% 6.3V ≤10% Exception of D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF APPLIED VOLTAGE: RATED VOLTAGE TEMPERATURE : 40±2 ˚C RELATIVE HUMIDITY: 90~95%RH TEST TIME : 500 +12/-0 Hr. CURRENT APPLIED: 50mA MAX. MEASURING AT ROOM TEMPERATURE AFTER COOLING FOR CLASS I : 24±2 Hr. CLASS II : 48±4 Hr. SEE (FIG.3) Y5V, Z5U Rated Voltage D.F. ≥50V ≤5% Exception of D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% INSULATION RESISTANCE Email: sales@venkel.com MINIMUM INSULATION RESISTANCE: 100 M OR 25M μF PRODUCT, WHICHEVER IS SMALLER | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 23 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM PERFORMANCE APPEARANCE TEST CONDITION NO MECHANICAL DAMAGE SHALL OCCUR CHARACTERISTIC CAP. CHANGE CLASS I WITHIN ±3% OR ±0.3pF, WHICHEVER IS LARGER CAPACITANCE CLASS II X WITHIN ±12.5% CHAR. TEMP. Y WITHIN ±30% CLASS I 125 ±3 ˚C 30pF AND OVER : Q 350 10 - 30 pF : Q 275 + 2.5xC LESS THAN 10pF :Q 200 + I0xC QCLASS I APPLIED VOLTAGE: 200% OF RATED VOLTAGE TEST TIME : 1000 +48/-0 Hr. CURRENT APPLIED: 5OmA MAX. CLASS II X 125 ±3 ˚C Y 85 ±3 ˚C X7R, X6S, X5R 16 HIGH TEMERATURE RESISTANCE DISSIPATION FACTOR (TanΘ CLASS II) Rated Voltage D.F. ≥50V ≤2.5% 25V ≤2.5% 16V ≤3.5% 10V ≤5% 6.3V ≤10% Exception of D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF (INITIAL VALUE MEASUREMENT) FOR CLASS II CAPACITORS, 200 % OF RATED VOLTAGE SHALL BE APPLIED FOR 1 HOUR AT THE MAXIMUM OPERATING TEMPERATURE, THEN KEEP IT AT ROOM TEMPERATURE FOR 48 ±4 HRS. SEE (FIG.3) Y5V, Z5U Rated Voltage D.F. ≥50V ≤5% Exception of D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% INSULATION RESISTANCE Email: sales@venkel.com MINIMUM INSULATION RESISTANCE: 1,000M OR 50M μF PRODUCT WHICHEVER IS SMALLER | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 24 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM APPEARANCE PERFORMANCE TEST CONDITION NO MECHANICAL DAMAGE SHALL OCCUR CAPACITORS SHALL BE SUBJECTED TO FIVE CYCLES OF THE TEMPERATURE CYCLE AS FOLLOWING CHARACTERISTIC CAP. CHANGE CLASS I WITHIN ±2.5% OR ±0.25pF WHICHEVER IS LARGER CAPACITANCE X WITHIN ±7.5% Y WITHIN ±20% CLASS II 30 pF AND OVER : Q 1000 LESS THAN 3OpF:Q 400 +20xC QCLASS I STEP TEMP.(˚C) TIME (MIN) 1 MIN. RATED TEMP. +0/–3 30 2 25 2~3 3 MAX. RATED TEMP. +3/–0 30 4 25 2~3 X7R, X6S, X5R Rated Voltage D.F. ≥50V ≤2.5% 25V 17 TEMPERATURE CYCLE 16V TAN CLASS II ≤2.5% Exception of D.F. ≤3% 0201 (50V); 0603≥0.047uF 0805≥0.22uF; 1206≥0.47uF ≤5% 0603≥1uF; 0805≥1uF; 1206≥4.7uF; 1210≥4.7uF ≤5% 0201≥0.01uF; 0805≥1uF; 1210≥4.7uF ≤10% 0402≥0.10uF; 0603≥0.33uF; 0805≥2.2uF 1206≥4.7uF; 1210≥22uF ≤5% 0201≥0.01uF; 0402≥0.033uF; 0805≥0.68uF; 1206≥2.2uF; 1210≥4.7uF ≤10% 0402≥0.47uF; 0603≥0.68uF; 0805≥2.2uF; 1206≥4.7uF; 1210≥22uF ≤10% 0402≥0.33uF; 0603≥0.33uF; 0805≥2.2uF; 1206≥2.2uF; 1210≥22uF ≤3.5% 10V ≤5% 6.3V ≤10% MEASURE AT ROOM TEMPERATURE AFTER COOLING FOR CLASS I : 24±2 Hr. CLASS II : 48±4 Hr. SEE(FIG.3) Y5V, Z5U Rated Voltage D.F. ≥50V ≤5% Exception of D.F. ≤9% 0603≥0.1uF; 0805≥0.47uF; 1206≥4.7uF; 25V ≤5% ≤9% 0402≥0.047uF; 0603≥0.1uF; 0805≥0.33uF; 1206≥1uF; 1210≥4.7uF 16V ≤9% ≤12.5% 0603≥2.2uF; 0805≥3.3uF; 1206≥10uF; 1210≥22uF; 1812≥47uF 10V ≤12.5% ≤16% 0603≥2.2uF; 0805≥3.3uF; 1206≥4.7uF; 1210≥10uF; 1812≥47uF 6.3V ≤16% INSULATION RESISTANCE Email: sales@venkel.com TO SATISFY THE SPECIFIED INITIAL VALUE | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 25 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM TEST CONDITION REQUIREMENTS *Test Temperature: C0G, X7R/X7S: 125±3˚C X5R, Y5V: 85±3˚C Test time: 1000+24/-0 hrs. Endurance or Life Test Voltage (RVLL) * All components are tested at 100% of rated voltage (Vr) for the below range: RATED VOLTAGE SIZE DIELECTRIC 0201 X5R/X7R/X6S X5R 0402 18 C>0.1μF 25V, 50V C≥0.1μF C>0.1μF C≥0.1μF 35V C≥0.1μF 4V C≥22μF 6.3V, 10V C≥4.7μF X5R/X7R/X6S 25V C≥0.1μF X7R 35V C≥0.1μF 4V C≥47μF 6.3V C≥22μF 10V, 50V C≥10μF 0805 X7R/X6S RATED VOLTAGE D.F. ≥100V ≤3% 50V 35V ≤3% ≤5% ≤5% 16V ≤5% 10V ≤7.5% C≥22μF ≤6.3V C≥47μF X5R/X7R/X6S 16V C≥47μF X7R 100V C≥43.3μF *Any items outside this range or with a different dielectric will hold the following test conditions: (1) ≤ 6.3V or C ≥ 10µF : 150% of rated voltage. (2) 10V ≤ Vr ≤ 100V: 200% of rated voltage. | Phone: 512.794.0081 | EXCEPTIONS OF D.F. ≤ ≤6% C≥10μF X5R/X7R/X6S Email: sales@venkel.com X7R, XSR, X6S, X7S: 25V 16V, 25V X5R 1210 ≤16V 25V X5R/X7R/ X6S/X7S 1206 C>0.1μF C≥0.1μF X5R/X7R/ X6S/X7S HIGH TEMPERATURE Load-Endurance (Life Testing) C≥0.1μF ≥16V 16V, 25V X7R/X7S/Y5V 0603 ≤10V 6,3V, 10V X6S CAPACITANCE • No remarkable damage. CAP CHANGE: C0G: ±3.0% or ±0.3pF whichever Is larger X7R, X5R, X6S, X7S: ≥10V**, within ±12.5%; ≤6.3V within ±25%; **10V: 0603≥4.7μF; 0402≥1.0μF; 0201≥0.1μF, within ±25% Y5V≥10V, within ±30%; ≤6.3V, within +30/-40% Q/D.F. VALUE: C0G: More than 30pF, Q≥350 10pF≤30pF, Q≥275+2.5C Less than 10pF, Q≥200+10C 1206≥0.47μF ≤7.5% 0603≥0.068μF; 0805>0.1μF; 1206≥1μF; 1210≥2.2μF ≤20% 0805>2.2μF; 1210≤3.3μF ≤6% 0201(50V); 0603>0.047μF; 0805≥0.18μF; 1206≥0.47μF ≤10% 0201≥0.01μF; 1210≥3.3μF ≤20% 0402≥0.012μF; 0603>0.1μF; 0805≥1.0μF (0805/ X7R>0.47μF); 1206≥2.2μF; 1210≥10μF ≤20% 0603≥1.0μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF ≤10% 0201=0.01μF; 0805≥1.0μF; 1210≥10μF ≤14% 0603≥0.33μF ≤15% 0201>0.01μF; 0402>0.10μF (0402/X7R≥0.056μF); 0603≥0.47μF; 0805≥2.2μF; 1206≥0.47μF; 1210≥22μF (1210/X5R≥10μF) ≤20% 0402≥0.47μF ≤10% 0603≥0.15μF; 0805≥0.68μF; 1206≥2.2μF; 1210≥4.7μF ≤15% 0201≥0.01μF (0201/X7R≥0.022μF); 0402≥0.033μF 0603>0.47μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥22μF ≤15% 0201≥0.012μF; 0402≥0.22μF; 0603≥0.33μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥22μF ≤20% 0201≥0.01μF; 0402≥1.0μF; 0603/X5R≥10μF; 01R5/x5R 0201≥0.01μF; 0402≥1.0μF (0402/X6S≥0.47μF); 0603≥10μF; 0805≥4.7μF; 1206≥47μF; 1210≥100μF 6.3V ≤15% ≤30% 4V ≤20% - Toll Free: 800.950.8365 | - Web: www.venkel.com Rev: 08/2021-A 26 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ENVIRONMENTAL CHARACTERISTICS NO ITEM TEST CONDITION REQUIREMENTS (3) 150% of rated voltage for below range. SIZE 50V C≥0.01μF 10~25V C≥0.22μF 16V C≥0.47μF 50~100V C>0.22μF Y5V: 50V C>0.1μF X7R 25V C=1.0μF DIELECTRIC RATED VOLTAGE X5R/X6S 16V, 25V C=0.1μF X7R 16V C≥0.022μF 0201 0402 • No remarkable damage. CAP CHANGE: C0G: ±3.0% or ±0.3pF whichever Is larger X7R, X5R, X6S, X7S: ≥10V**, within ±12.5%; ≤6.3V within ±25%; **10V: 0603≥4.7μF; 0402≥1.0μF; 0201≥0.1μF, within ±25% Y5V≥10V, within ±30%; ≤6.3V, within +30/-40% Q/D.F. VALUE: C0G: More than 30pF, Q≥350 10pF≤30pF, Q≥275+2.5C Less than 10pF, Q≥200+10C X7R/X5R/X6S Y5V X7S 0603 X5R 50V C≥1.0μF X5R/X7R/ X6S/X7S 10V, 16V C≥1.0μF Y5V 16V C≥2.2μF 100V C≥0.47μF 50V C≥0.68μF 35V C≥2.2μF 10~25V C≥4.7μF 16V C≥4.7μF 100V C≥1.0μF X5R/X7R/ X6S/X7S 0805 Y5V X7R 1206 RATED VOLTAGE D.F. ≥0V ≤7.5% 35V ≤10% 25V ≤7.5% EXCEPTIONS OF D.F. ≤ ≤10% 0603≥0.1μF; 0805≥0.47μF; 1206≥4.7μF ≤20% 1210≥6.8μF - 0402≥0.047μF; 0603≥0.1μF; 0805≥0.33μF; 1206≥1.0μF; 1210≥4.7μF ≤10% 0402≥0.068μF; 0603≥0.47μF; 1206≥4.7μF; 1210≥22μF ≤15% 16V (C1.0μF 6.3V ≤30% - 50V C=4.7μF 1210 X5R/X7R/ X6S/X7S 50~100V C≥2.2μF 1825 2220 2225 X7R 100~250V C≥1.0μF *B  efore initial measurement (Class II only): To apply de-aging at 150˚C for 1 hr then set for 24±2 hrs at room temp *C  ap./DF(Q)/I.R. Measurement to be made after de-aging at 150˚C for 1hr then set for 24±2hrs at room temp. ** De-rating conditions: 0402≥0.068μF; 0603≥0.68μF 0402≥0.22μF 0603≥2.2μF; 0805≥3.3μF; 1206≥10μF; 1210≥22μF; 1812≥47μF 0402≥0.47μF - *I.R.: ≥10V, 1GΩ or 50Ω-F whichever Is smaller. Class II (X7R, X5R, X6S, X7S, Y5V) RATED VOLTAGE INSULATION RESISTANCE 100V: All X7R; 1210≥3.3μF 50V: 0402>0.01μF; 0603≥1.0μF; 0805≥1.0μF; 1206≥4.7μF; 1210≥4.7μF 35V: 0603≥1.0μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF 25V: 0201≥0.1μF; 0402≥0.22μF; 0603≥2.2μF; 0805≥2.2μF; 1206≥10μF; 1210≥10μF DERATING CURVE Ratio [Operating Voltage / Rated Voltage (%)] 18 X5R/X6S/X7S HIGH TEMPERATURE Load-Endurance (Life Testing) CAPACITANCE 1GΩ or apply ≥10Ω-F rule, whichever is smaller. 16V: 0201≥0.1μF; 0402≥0.22μF; 0603≥1.0μF; 0805≥2.2μF; 1206≥10μF; 1210≥47μF 120 100 10V: 0201≥47nF; 0402≥0.47μF; 0603≥0.47μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥47μF 80 6.3V; 4V : All X6S/X7S items, Size≥1812 60 402 0 0 0 25 50 75 100 125 150 Ambient temperature (˚C) Product for 85˚C Email: sales@venkel.com Product for 105˚C | Product for 125˚C Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 27 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS ADHESIVE STRENGTH OF TERMINATION 5 A 5 1.0 mm CODE DIMENSION (mm) A (mm) CODE DIMENSION (mm) A (mm) 01005 (0402) 0.40 x 0.20 0.12 1206 (3216) 3.2 x 1.6 2.2 0201 (0603) 0.61 x 0.31 0.2 1210 (3225) 3.2 x 2.5 2.2 0402 (1005) 1.0 x 0.5 0.4 1812 (4532) 4.5 x 3.2 3.5 0603 (1608) 1.6 x 0.8 1.0 2220 (5750) 5.7 x 5.08 4.7 0805 (2012) 2.0 x 1.25 1.2 Material: Alumina Substrate (Al203 95% Min) or Glass Epoxy Substrate Copper Foil (T = 0.035mm) SUBSTRATE BENDING STRENGTH B b C CC 40 A 100 1.6 (UNIT: mm) CODE DIMENSION (mm) A (mm) B (mm) C (mm) 01005 (0402) 0.40 x 0.20 0.12 0.7 0.20 0201 (0603) 0.61 x 0.31 0.2 1.0 0.4 0402 (1005) 1.0 x 0.5 0.4 1.4 0.5 0603 (1608) 1.6 x 0.8 1.0 3.0 1.0 0805 (2012) 2.0 x 1.25 1.2 4.0 1.65 1206 (3216) 3.2 x 1.6 2.2 5.0 2.0 1210 (3225) 3.2 x 2.5 2.2 5.0 3.2 1812 (4532) 4.5 x 3.2 3.5 7.0 4.0 2220 (5750) 5.7 x 5.08 4.7 8.5 5.0 MATERIAL: GLASS EPOXY SUBSTRATE Email: sales@venkel.com COPPER FOIL ( t = 0.035mm) | Phone: 512.794.0081 | SOLDER RESIST Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 28 C SERIES GENERAL PURPOSE CERAMIC CAPACITORS TEST SUBSTRATE C A B D E (UNIT: mm) CODE DIMENSION (MM) A B C D E 0201 (0603) 0.61 x 0.31 0.2 1.0 0.4 7.5 3.6 0402 (1005) 1.0 x 0.5 0.4 1.4 0.5 7.5 3.8 0603 (1608) 1.6 x 0.8 1.0 3.0 0.7 7.5 4.0 0805 (2012) 2.0 x 1.25 1.2 4.0 1.0 7.5 4.2 1206 (3216) 3.2 x 1.6 2.2 5.0 1.3 7.5 4.6 1210 (3225) 3.2 x 2.5 2.2 5.0 2.0 7.5 5.5 1812 (4532) 4.5 x 3.2 3.5 7.0 2.7 7.5 6.2 2220 (5750) 5.7 x 5.08 4.7 8.5 3.4 7.5 7.0 MATERIAL: GLASS EPOXY SUBSTRATE Email: sales@venkel.com COPPER FOIL ( t = 0.035mm) | Phone: 512.794.0081 | SOLDER RESIST Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 08/2021-A 29
C0402C0G500-3R0BNE
物料型号:文档中提到了多种物料型号,例如“C0805C0G500-101JNP”,这些型号遵循VENKEL LTD的特定编码规则。
器件简介:文档描述了通用陶瓷电容器,包括它们的特点,如电容范围(0.1pF至220uF)、电压范围(4V至100V)和终止类型(100%亚光锡(Sn)、钯银(Pd-Ag)等)。
引脚分配:文档中没有明确提到引脚分配,但提供了电容器的尺寸和结构信息。
参数特性:详细列出了不同电容器的电气规格,包括电容公差、损耗因子(D.F.)、绝缘电阻和老化特性。
功能详解:文档解释了电容器的工作原理和它们在电路中的应用,如C0G/C0G、X7R、X7S、X6S、X5R和Y5V等不同的介质材料及其对应的温度特性。
应用信息:虽然文档没有直接提到具体的应用案例,但它提供了电容器的通用特性,这些特性适用于多种电子电路。
封装信息:文档提供了不同尺寸的电容器的封装信息,包括尺寸、最小/最大厚度和相关的尺寸代码。
C0402C0G500-3R0BNE 价格&库存
很抱歉,暂时无法提供与“C0402C0G500-3R0BNE”相匹配的价格&库存,您可以联系我们找货
