CML0805X7R471KT50V
CML0805X7R471KT50V
    SEI
    贴片电容(MLCC) 470pF X7R ±10% 0805 50V
CML0805X7R471KT50V 数据手册
CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Features: • • • • • • -55°C to 125°C operating temperature range EIA sizes 0402, 0603, 0805, 1206, 1210 and 1812 Capacitance offering from 0.1 pF to 0.1 uF 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Construction 1 - Ceramic layers (dielectric) 2 - Inner electrodes 3 - Base termination 4 - Nickel plating layer 5 - Tin plating layer Electrical Specifications Type/Code Dielectric Code CML0402 C0G CML0603 C0G CML0805 C0G CML1206 C0G Standard Tolerance Code Description C ± 0.25 pF J C J C J C ± 5% ± 0.25 pF ± 5% ± 0.25 pF ± 5% ± 0.25 pF J ± 5% C J C CML1812 C0G J Note: Capacitance values < 10 pF: B = ± 0.1 pF may be available Note: Capacitance values ≥ 10 pF: G = ± 2% may be available CML1210 Capacitance Range 50V 100V 0.1 pF - 8.2 pF 10 pF - 1000 pF 0.1 pF - 6.8 pF 10 pF - 6800 pF 0.3 pF - 6,8 pF 10 pF - 0.022 uF 0.3 pF - 8.2 pF 10 pF - 3300 pF 3900 pF - 4700 pF 10 pF - 0.1 uF 10 pF - 0.1 uF ± 0.25 pF ± 5% ± 0.25 pF ± 5% C0G 0.5 pF - 8.2 pF 10 pF - 1000 pF 0.5 pF - 8.2 pF 10 pF - 3300 pF 0.5 pF - 8.2 pF 10 pF - 3300 pF 1 pF - 8.2 pF 10 pF - 6800 pF 3 pF - 8.2 pF 10 pF - 0.01 uF How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 C M L 0 4 0 2 C 0 G 1 0 0 J T 5 0 V ` Product Series Code Description Multilayer CML Ceramic Size Code 0402 0603 0805 1206 1210 1812 Dielectric Code C0G Capacitance Range 0.1pF to 0.10uF (E12) EIA Code Capacitance 0R1 0.1 pF 100 10 pF 101 100 pF 102 1000 pF 103 0.01 uF 104 0.1 uF Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Tolerance (*) Code Description B ± 0.1 pF C ± 0.25 pF G ± 2% J ± 5% Code T Packaging Description Size and Quantity 7" Paper Reel Refer to Packaging Specifications 7" Plastic Tape Max Working Voltage 50V 100V (*) Other tolerances may be available. Contact Stackpole. 1 www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Capacitance and Voltage Available Dielectric Size EIA Code VDCW 0R1 0.1 pF 0R2 0.2 pF 0R3 0.3 pF 0R4 0.4 pF 0R5 0.5 pF 0R6 0.6 pF 0R7 0.7 pF 0R8 0.8 pF 0R9 0.9 pF 1R0 1 pF 1R2 1.2 pF 1R5 1.5 pF 1R8 1.8 pF 2R0 2 pF 2R2 2.2 pF 2R7 2.7 pF 3R0 3 pF 3R3 3.3 pF 3R9 3.9 pF 4R7 4.7 pF 5R0 5 pF 5R6 5.6 pF 6R8 6.8 pF 8R2 8.2 pF 100 10 pF 120 12 pF 150 15 pF 180 18 pF 220 22 pF 270 27 pF 330 33 pF 390 39 pF 470 47 pF 560 56 pF 680 68 pF 820 82 pF 101 100 pF 121 120 pF 151 150 pF 181 180 pF 221 220 pF 271 270 pF 331 330 pF 391 390 pF 471 470 pF 561 560 pF 681 680 pF 751 750 pF 821 820 pF 102 1000 pF 122 1200 pF 152 1500 pF 182 1800 pF 222 2200 pF 272 2700 pF 332 3300 pF 392 3900 pF 472 4700 pF 562 5600 pF 682 6800 pF 822 8200 pF 103 0.01 uF C0G 0402 50V 0603 50V 0805 100V 50V Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1206 100V 2 50V 1210 100V 50V 1812 100V 50V 100V www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Capacitance and Voltage Available (cont.) Dielectric Size EIA Code VDCW 123 0.012 uF 153 0.015 uF 183 0.018 uF 223 0.022 uF 273 0.027 uF 333 0.033 uF 473 0.047 uF 563 0.056 uF 683 0.068 uF 823 0.082 uF 104 0.1 uF C0G 0402 50V 0603 50V 0805 100V 50V 1206 100V 50V 1210 100V 50V 1812 100V 50V 100V Mechanical Specifications and Packaging Specifications Type/Code Voltage Capacitance Value CML0402C0G 50V 0.1 pF - 1000 pF CML0603C0G 50V - 100V 0.1 pF - 6800 pF 50V CML0805C0G 0.3 pF - 1500 pF 4700 pF 1800 pF - 3900 pF 5600 pF - 8200 pF 0.01 uF - 0.022 uF 100V 0.5 pF - 3300 pF 0.3 pF - 8200 pF 50V CML1206C0G 0.01 uF - 0.1 uF 100V 0.5 pF - 3300 pF 50V 10 pF - 0.1 uF 100V 1 pF - 6800 pF 50V 10 pF - 0.1 uF 100V 3 pF - 0.01 uF CML1210C0G CML1812C0G L 0.039 1.00 0.063 1.60 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.177 4.50 0.177 4.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.016 0.40 0.016 0.40 0.020 0.50 0.031 0.80 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.063 1.60 0.063 1.60 0.063 1.60 0.098 2.50 0.098 2.50 0.126 3.20 0.126 3.20 3 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.020 0.50 0.031 0.80 0.028 0.70 0.031 0.80 0.047 1.20 0.031 0.80 0.028 0.70 0.063 1.60 0.031 0.80 0.047 1.20 0.047 1.20 0.047 1.20 0.047 1.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.002 0.05 0.004 0.10 0.002 0.05 0.004 0.09 0.004 0.10 0.004 0.10 0.002 0.05 0.004 0.10 0.004 0.09 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.012 0.30 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging (7" Reel) Qty. Paper Tape Plastic Tape 10000 - 4000 - 4000 - 4000 - - 2000 4000 - 4000 - - 2000 4000 - - 3000 - 2000 - 1000 - 1000 www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics Test Test Specification Capacitance Test Condition Should be within the specified tolerance. Dissipation Factor (DF) C0G (Class I) Insulation Resistance C0G (Class I) DF ≤ 0.56% 1.5 [(150 / Cr) + 7] x 10 - 4 ≤ 0.15% ≤ 0.15% C ≤ 10 nF, Ri ≥ 50000 MΩ C > 10 nF, RI*CR ≥ 500 S Dielectric Withstanding Voltage No breakdown or damage. Solderability At least 95% of the terminal electrode is covered by new solder. Visual appearance: No visible damage. Resistance to Soldering Heat C0G ≤ ± 0.5% or ± 0.5 pF whichever is larger DF Same to initial value IR Same to initial value Appearance: No visible damage. At least 95% of the terminal electrode is covered by new solder. Resistance to Flexure of Substrate (Bending Strength) Appearance: No visible damage. Δ C/C: ≤ ± 10% Item Δ C/C Termination Adhesion No visible damage C0G: Δ C/C: ≤ ± 1% or ± 1 pF, whichever is larger Temperature Cycle Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 C0G: (Class I) Cap ≤ 1000 pF 1.0 ± 0.2 Vrms, 1 MHz ± 10% Cap > 1000 pF 1.0 ± 0.2 Vrms, 1 KHz ± 10% Capacitance Measuring Frequency Measuring Voltage Cr < 5 pF 1 MHZ ± 10% 5 pF ≤ Cr < 50 pF 1 ± 0.2 Vrms 50 pF ≤ Cr ≤ 1000 pF > 1000 pF 1 KHZ ± 10% Measuring Voltage: Rated Voltage (Max 500V) Duration: 60 ± 5 seconds Test Humidity: ≤ 75% Test Temperature: 25°C ± 5°C Test Current: ≤ 50 mA Measuring voltage: Class I: 300% rated voltage Duration: 1 ~ 5 seconds Charge/Discharge Current: 50 mA max. Preheating Conditions: 80ºC to 120°C, 10 ~ 30 seconds Solder Temperature: 235ºC ± 5% (Sn/Pb: 63/37) Duration: 2 ± 0.5 seconds Solder Temperature: 245ºC ± 5°C (Lead-free) Duration: 2 ± 0.5 seconds Preheating Conditions: 100ºC to 200°C; 10 ± 2 minutes Solder Temperature: 265ºC ± 5°C Duration: 10 ± 1 seconds Clean the capacitor with solvent and examine it with a 10X (min.) microscope. Recovery Time: 24 ± 2 hours Recovery Condition: Room temperature. Test Board: AI2O3 or PCB Warp: 1 mm Speed: 0.5 mm/second The measurement should be made with the board in the bending position. Unit: mm Applied Force: 5 N Duration: 10 ± 1 seconds Preheating Conditions: up-category Temperature: 1 hour Recovery Time: 24 ± 1 hours Initial Measurement Cycling times: 5 times, 1 cycle, 4 steps: Step Temp. ( °C ) Time (min.) Low-category temp. 1 30 ± 3 C0G: -55ºC 2 Normal temp. (+20) 2-3 Up-category temp. 3 30 ± 3 C0G: +125ºC 4 Normal temp. (+20ºC) 2-3 Recovery time after test: 24 ± 2 hours www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics (cont.) Test Moisture Resistance Life Test Test Specification Test Condition Temperature: 40ºC ± 2°C Humidity: 90 ~ 95% R.H. Duration: 500 hours Recovery Conditions: Room temperature Recovery Time: 24 hours (Class I) Low-voltage (< 100V) Applied Voltage: 1.5 x rated voltage Duration: 1000 hours Temperature: 125°C (C0G) Charge/Discharge Current: 50 mA max. Recovery Conditions: Room temperature Recovery Time: 24 hours (Class I) Applied voltage: 100V ≤ rated voltage < 500V: 2 multiple 500V ≤ rated voltage ≤ 1000V: 1.5 multiple > 1000V rated voltage: 1.2 multiple Duration: 1000 hours Charge/Discharge Current: 50 mA max. Temperature: 125°C (C0G) Recovery Conditions: Room temperature Recovery Time: 24 hours (Class I) C0G: Δ C/C: ≤ ± 2% or ± 1 pF, whichever is larger DF: Not more than twice of initial value. IR: C0G: Ri ≥ 2500 M Ω or RI*CR ≥ 25 S whichever is smaller Appearance: No visible damage C0G: Δ C/C: ≤ ± 2% or ± 1 pF, whichever is larger DF: Not more than twice of initial value. IR: C0G: Ri ≥ 4000 M Ω or RI*CR ≥ 40 S whichever is smaller Appearance: No visible damage C0G: Δ C/C: ≤ ± 2% or ± 1 pF, whichever is larger Middle and High Voltage Life Test DF: Not more than twice of initial value. IR: C0G: Ri ≥ 4000 M Ω or Ri*CR ≥ 40 S whichever is smaller Appearance: No visible damage Reel Specifications Type/Code CML_C0G (all sizes) A 7.008 ± 0.079 178.00 ± 2.00 B C D 0.118 3.00 0.512 ± 0.020 13.00 ± 0.50 0.827 ± 0.031 21.00 ± 0.80 E F 1.969 or more 50.00 or more G 0.394 ± 0.059 10.00 ± 1.50 Unit 0.472 max inches 12.00 max mm Paper Tape Specifications Type/Code CML0402C0G CML0603C0G CML0805C0G CML1206C0G A0 0.026 0.65 0.043 1.10 0.057 1.45 0.071 1.80 ± ± ± ± ± ± ± ± B0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.045 1.15 0.075 1.90 0.091 2.30 0.134 3.40 ± ± ± ± ± ± ± ± Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. T 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.031 0.80 0.043 1.10 0.043 1.10 0.043 1.10 5 below below max max max max max max W 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± P0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Paper Tape Specifications (cont.) Type/Code P1 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 CML0402C0G CML0603C0G CML0805C0G CML1206C0G ± ± ± ± ± ± ± ± P2 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± D0 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 E 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± F 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm Unit max max max max max max max max inches mm inches mm inches mm inches mm Plastic Tape Specifications Type/Code A CML0805C0G CML1206C0G CML1210C0G CML1812C0G CML1206C0G CML1210C0G CML1812C0G C D ± ± ± ± ± ± ± ± J E ± ± ± ± ± ± ± ± F 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.093 2.35 0.142 3.60 0.135 3.42 0.195 4.95 ± ± ± ± ± ± ± ± G 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.315 8.00 0.315 8.00 0.315 8.00 0.472 12.00 ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.217 5.50 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 Type/Code CML0805C0G B 0.061 1.55 0.077 1.95 0.106 2.70 0.144 3.66 ± ± ± ± ± ± ± ± T 0.059 1.50 0.073 1.85 0.126 3.20 0.157 4.00 Unit RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description CML Multilayer Ceramic Chip Capacitor Package / Standard Termination Series RoHS Type Compliant SMD Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. YES 6 Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Matte Sn over Ni Always Lead-Free Effective Date Code (YY/WW) Always www.seielect.com marketing@seielect.com CML_C0G Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 5/27/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Features: • • • • • • -55°C to 125°C operating temperature range EIA sizes 0402, 0603, 0805, 1206, 1210 and 1812 Capacitance offering from 100 pF to 47 uF 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Construction 1 - Ceramic layers (dielectric) 2 - Inner electrodes 3 - Base termination 4 - Nickel plating layer 5 - Tin plating layer Electrical Specifications Type/Code Dielectric Code CML0402 X7R K ± 10% CML0603 X7R K ± 10% CML0805 Standard Tolerance Code Description X7R K Capacitance Range 16V 25V 120 pF - 0.039 uF 0.012 uF - 0.1 uF 150 pF - 0.1 uF 0.012 uF - 0.18 uF 0.12 uF - 0.33 uF 0.12 uF - 2.2 uF 150 pF - 0.1 uF 0.12 uF - 0.39 uF 0.12 uF - 2.2 uF 150 pF - 1 uF 2.2 uF - 4.7 uF 220 pF - 10 uF 22 uF 47 uF 470 pF - 4.7 uF 6.8 uF 10V ± 10% CML1206 X7R K ± 10% CML1210 X7R K ± 10% CML1812 X7R K ± 10% 50V 100V - 150 pF - 2.2 uF 270 pF - 1 uF - Note: J = 5% tolerance may be available How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 C M L 0 4 0 2 X 7 R 1 0 3 K T 5 0 V Product Series Code Description Multilayer CML Ceramic Size Code 0402 0603 0805 1206 1210 1812 Dielectric Code X7R Capacitance Range 0.1pF to 0.10uF (E12) EIA Code Capacitance 101 100 pF 102 1000 pF 103 0.01 uF 104 0.1 uF 105 1 uF 106 10 uF Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Tolerance (*) Code Description J ± 5% K ± 10% Code T Packaging Description Size Quantity 7" Paper Reel Refer to Packaging Specifications 7" Plastic Tape (*) Other tolerances may be available. Contact Stackpole. 1 Max Working Voltage 10V 16V 25V 50V 100V www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Capacitance and Voltage Available Dielectric X7R Size 0402 0603 0805 1206 1210 1812 EIA Code VDCW 10V 16V 25V 50V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 16V 25V 50V 100V 101 100 pF 121 120 pF 151 150 pF 181 180 pF 201 200 pF 221 220 pF 271 270 pF 331 330 pF 391 390 pF 471 470 pF 561 560 pF 681 680 pF 751 750 pF 821 820 pF 102 1000 pF 122 1200 pF 152 1500 pF 182 1800 pF 222 2200 pF 272 2700 pF 332 3300 pF 392 3900 pF 472 4700 pF 562 5600 pF 682 6800 pF 822 8200 pF 103 0.01 uF 123 0.012 uF 153 0.015 uF 183 0.018 uF 223 0.022 uF 273 0.027 uF 333 0.033 uF 393 0.039 uF 473 0.047 uF 563 0.056 uF 683 0.068 uF 823 0.082 uF 104 0.1 uF 124 0.12 uF 154 0.15 uF 184 0.18 uF 224 0.22 uF 274 0.27 uF 334 0.33 uF 394 0.39 uF 474 0.47 uF 564 0.56 uF 684 0.68 uF 824 0.82 uF 105 1 uF 125 1.2 uF 155 1.5 uF 225 ` 2.2 uF 335 3.3 uf 475 4.7 uF 685 6.8 uF 106 10 uF 226 22 uf 476 47 uF Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Mechanical Specifications and Packaging Specifications Type/Code Voltage Capacitance Range CML0402X7R 10V - 50V 100 pF - 0.47 uF CML0603X7R 10V - 100V 150 pF - 2.2 uF 150 pF - 0.33 uF 0.47 uF 0.56 uF - 0.68 uF 10V 0.82 uF - 1 uF 1.5 uF 2.2 uF 3.3 uF - 10 uF 150 pF - 0.33 uF 0.47 uF 0.56 uF - 0.68 uF CML0805X7R 16V 0.82 uF - 1 uF 1.5 uF 2.2 uF 3.3 uF - 4.7 uF 150 pF - 0.33 uF 0.47 uF 0.56 uF - 0.68 uF 25V 0.82 uF - 1 uF 1.5 uF - 2.2 uF 3.3 uF - 4.7 uF L 0.039 1.00 0.063 1.60 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.020 0.50 0.031 0.80 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 3 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.020 0.50 0.031 0.80 0.031 0.80 0.031 0.80 0.047 1.20 0.039 1.00 0.047 1.20 0.031 0.80 0.047 1.20 0.031 0.80 0.031 0.80 0.047 1.20 0.039 1.00 0.047 1.20 0.031 0.80 0.047 1.20 0.031 0.80 0.031 0.80 0.047 1.20 0.039 1.00 0.047 1.20 0.047 1.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.012 0.30 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging (7" Reel) Qty. Paper Tape Plastic Tape 10000 - 4000 - 4000 - 4000 - - 3000 - 3000 - 3000 4000 - - 2000 4000 - 4000 - - 3000 - 3000 - 3000 4000 - - 2000 4000 - 4000 - - 3000 - 3000 - 2000 - 2000 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Mechanical Specifications and Packaging Specifications (cont.) Type/Code Voltage Capacitance Range 150 pF - 0.33 uF 0.47 uF 50V 0.56 uF - 0.68 uF 0.82 uF - 1 uF CML0805X7R 1.5 uF - 2.2 uF 100 pF 100V 150 pF - 0.047 uF 0.056 uF - 0.1 uF 200 pF - 0.33 uF 0.47 uF - 0.68 uF 0.82 uF - 1.5 uF 10V 2.2 uF 3.3 uF 4.7 uF - 22 uF 200 pF - 0.33 uF 0.47 uF - 0.68 uF 0.82 uF - 1.5 uF 16V - 25V 2.2 uF CML1206X7R 3.3 uF 4.7 uF - 10 uF 200 pF - 0.33 uF 0.47 uF - 0.68 uF 0.82 uF - 1.5 uF 50V 2.2 uF 3.3 uF 4.7 uF 150 pF - 0.056 uF 100V 0.068 uF - 0.33 uF 0.47 uF - 1 uF L 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 4 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.031 0.80 0.031 0.80 0.047 1.20 0.039 1.00 0.047 1.20 0.028 0.70 0.031 0.80 0.047 1.20 0.031 0.80 0.047 1.20 0.031 0.80 0.063 1.60 0.047 1.20 0.063 1.60 0.031 0.80 0.047 1.20 0.031 0.80 0.063 1.60 0.047 1.20 0.063 1.60 0.031 0.80 0.047 1.20 0.031 0.80 0.063 1.60 0.047 1.20 0.063 1.60 0.031 0.80 0.047 1.20 0.063 1.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.020 0.50 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.012 0.30 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.012 0.30 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.012 0.30 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging (7" Reel) Qty. Paper Tape Plastic Tape 4000 - 4000 - - 3000 - 3000 - 3000 4000 - 4000 - - 3000 4000 - - 3000 4000 - - 2000 - 3000 - 2000 4000 - - 3000 4000 - - 2000 - 3000 - 2000 4000 - - 3000 4000 - - 2000 - 3000 - 2000 4000 - - 3000 - 2000 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Mechanical Specifications and Packaging Specifications (cont.) Type/Code Voltage Capacitance Range 220 pF - 0.47 uF 0.68 uF - 1 uF 10V 4.7 uF 10 uF 47 uF 220 pF - 0.47 uF 0.68 uF - 1 uF 16V - 25V 4.7 uF CML1210X7R 10 uF 22 uF 220 pF - 0.47 uF 0.68 uF - 1 uF 50V 4.7 uF 10 uF 150 pF - 0.22 uF 100V 0.33 uF - 2.2 uF 470 pF - 1 uF 16V - 25V 1.5 uF - 6.8 uF 470 pF - 1 uF CML1812X7R 50V 1.5 uF - 4.7 uF 270 pF - 0.56 uF 100V 0.68 uF - 1 uF L 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.177 4.50 0.177 4.50 0.177 4.50 0.177 4.50 0.177 4.50 0.177 4.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.098 2.50 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 5 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.047 1.20 0.063 1.60 0.047 1.20 0.071 1.80 0.098 2.50 0.047 1.20 0.063 1.60 0.047 1.20 0.071 1.80 0.098 2.50 0.047 1.20 0.063 1.60 0.071 1.80 0.098 2.50 0.055 1.40 0.063 1.60 0.063 1.60 0.071 1.80 0.063 1.60 0.071 1.80 0.063 1.60 0.063 1.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.009 0.24 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging (7" Reel) Qty. Paper Tape Plastic Tape - 2000 - 2000 - 2000 - 2000 - 500 - 2000 - 2000 - 2000 - 2000 - 500 - 2000 - 2000 - 2000 - 500 - 2000 - 2000 - 1000 - 1000 - 1000 - 1000 - 1000 - 500 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics Test Capacitance Dissipation Factor (DF) X7R X7R (Class II) (≥ 0402) Insulation Resistance X7R (Class II) Test Specification Test Condition Should be within the specified tolerance. X7R: (Class II) Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10% Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10% ≥ 50V ≤ 2.5% 25V 16V ≤ 3.5% (C < 0.47uF) ≤ 10.0% (C ≥ 0.47uF) 10V ≤ 5% (C < 0.15uF) ≤ 10.0% ( C ≥ 0.15 uF) C ≤ 25nF, Ri ≥ 10000M Ω C > 25nF, RI*CR > 100S Dielectric Withstanding Voltage No breakdown or damage. Solderability At least 95% of the terminal electrode is covered by new solder. Visual appearance: No visible damage. Resistance to Soldering Heat Item X7R Δ C/C -5 ~ + 10% DF Same to initial value IR Same to initial value Appearance: No visible damage. At least 95% of the terminal electrode is covered by new solder. Resistance to Flexure of Substrate (Bending Strength) Appearance: No visible damage. Δ C/C: ≤ ± 10% Termination Adhesion No visible damage Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10% Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10% Measuring Voltage: Rated Voltage (Max 500V) Duration: 60 ± 5 seconds Test Humidity: ≤ 75% Test Temperature: 25°C ± 5°C Test Current: ≤ 50 mA Measuring voltage: Class II: 250% rated voltage Duration: 1 ~ 5 seconds Charge/Discharge Current: 50 mA max. Preheating Conditions: 80ºC to 120°C, 10 ~ 30 seconds Solder Temperature: 235ºC ± 5% (Sn/Pb: 63/37) Duration: 2 ± 0.5 seconds Solder Temperature: 245ºC ± 5°C (Lead-free) Duration: 2 ± 0.5 seconds Preheating Conditions: 100ºC to 200°C; 10 ± 2 minutes Solder Temperature: 265ºC ± 5°C Duration: 10 ± 1 seconds Clean the capacitor with solvent and examine it with a 10X (min.) microscope. Recovery Time: 24 ± 2 hours Recovery Condition: Room temperature. Test Board: AI2O3 or PCB Warp: 1 mm Speed: 0.5 mm / second The measurement should be made with the board in the bending position. Unit: mm Applied Force: 5 N Duration: 10 ± 1 seconds Preheating Conditions: up-category temperature 1 hour Recovery Time: 24 ± 1 hours Initial Measurement Cycling times: 5 times, 1 cycle, 4 steps: Step Temp. (°C) Time (min.) Low-category 1 30 ± 3 temp. X7R: -55ºC Normal temp. 2 2-3 (+20ºC) X7R: Δ C/C: ≤ ± 10% Temperature Cycle 3 Up-category temp. 30 ± 3 X7R: +125ºC Normal temp. 4 2-3 (+20ºC) Recovery time after test: 24 ± 2 hours Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics (cont.) Test Moisture Resistance Life Test Middle and High Voltage Life Test Test Specification Test Condition X7R: Δ C/C: ≤ ± 10% DF: Not more than twice of initial value. IR: X7R: Ri ≥ 1000M Ω or RI*CR ≥ 25S whichever is smaller Appearance: No visible damage Temperature: 40ºC ± 2°C Humidity: 90 ~ 95% R.H. Duration: 500 hours Recovery Conditions: Room temperature Recovery Time: 48 hours (Class II) Low-voltage (< 100V) Applied Voltage: 1.5 x rated voltage Duration: 1000 hours Temperature: 125°C (X7R) Charge/Discharge Current: 50 mA max. Recovery Conditions: Room temperature Recovery Time: 48 hours (Class II) Applied voltage: 100V ≤ rated voltage < 500V: 2 multiple 500V ≤ rated voltage ≤ 1000V: 1.5 multiple > 1000V rated voltage: 1.2 multiple Duration: 1000 hours Charge/Discharge Current: 50 mA max. Temperature: 125°C (X7R) Recovery Conditions: Room temperature Recovery Time: 48 hours (Class II) X7R: Δ C/C: ≤ ± 20% DF: Not more than twice of initial value. IR: X7R: Ri ≥ 2000M Ω or RI*CR ≥ 50 S whichever is smaller Appearance: No visible damage X7R: Δ C/C: ≤ ± 20% DF: Not more than twice of initial value. IR: X7R Ri ≥ 2000M Ω or Ri*CR ≥ 50 S whichever is smaller Appearance: No visible damage Reel Specifications Type/Code CML_X7R (all sizes) A 7.008 ± 0.079 178.00 ± 2.00 B C D 0.118 3.00 0.512 ± 0.020 13.00 ± 0.50 0.827 ± 0.031 21.00 ± 0.80 E F 1.969 or more 50.00 or more G 0.394 ± 0.059 10.00 ± 1.50 Unit 0.472 max inches 12.00 max mm Paper Tape Specifications Type/Code CML0402X7R CML0603X7R CML0805X7R CML1206X7R A0 0.026 0.65 0.043 1.10 0.057 1.45 0.071 1.80 ± ± ± ± ± ± ± ± B0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.045 1.15 0.075 1.90 0.091 2.30 0.134 3.40 ± ± ± ± ± ± ± ± T 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.031 0.80 0.043 1.10 0.043 1.10 0.043 1.10 7 below below max max max max max max W 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± P0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Paper Tape Specifications (cont.) Type/Code CML0402X7R CML0603X7R CML0805X7R CML1206X7R P1 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± P2 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± D0 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 E 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± F 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm Unit max max max max max max max max inches mm inches mm inches mm inches mm Plastic Tape Specifications Type/Code A CML0805X7R CML1206X7R CML1210X7R CML1812X7R CML1206X7R CML1210X7R CML1812X7R C D ± ± ± ± ± ± ± ± J E ± ± ± ± ± ± ± ± F 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.093 2.35 0.142 3.60 0.135 3.42 0.195 4.95 ± ± ± ± ± ± ± ± G 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.315 8.00 0.315 8.00 0.315 8.00 0.472 12.00 ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.217 5.50 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 Type/Code CML0805X7R B 0.061 1.55 0.077 1.95 0.106 2.70 0.144 3.66 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± T 0.059 1.50 0.073 1.85 0.126 3.20 0.157 4.00 Unit RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description CML Multilayer Ceramic Chip Capacitor Package / Standard Termination Series RoHS Type Compliant SMD Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. YES 8 Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Matte Sn over Ni Always Lead-Free Effective Date Code (YY/WW) Always www.seielect.com marketing@seielect.com CML_X7R Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 7/26/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Features: • • • • • • -30°C to 85°C operating temperature range EIA sizes 0402, 0603, 0805, 1206, 1210 and 1812 Capacitance offering from 1000 pF to 22 uF 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Construction 1 - Ceramic layers (dielectric) 2 - Inner electrodes 3 - Base termination 4 - Nickel plating layer 5 - Tin plating layer Electrical Specifications Type / Code Dielectric Code Standard Tolerance Code Description CML0402 Y5V Z +80% / 20% CML0603 Y5V Z +80% / 20% CML0805 Y5V Z +80% / 20% CML1206 Y5V Z +80% / 20% Capacitance Range 16V 25V 1000 pF - 0.1 uF 0.12 uF - 0.18 uF 0.12 uF - 0.47 uF 0.12 uF - 1 uF 10000 pF - 0.1 uF 10000 pF - 0.82 uF 0.18 uF - 2.2 uF 0.012 uF - 0.1 uF 1 uF - 4.7 uF 10000 pF - 1 uF 2.2 uF - 4.7 uF 10 uF 10V CML1210 Y5V Z +80% / CML1812 Y5V Z +80% / Note: M = ±20% tolerance may be available 50V 100V - - 0.015 uF - 1 uF 0.15 uF - 2.2 uF How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 C M L 0 4 0 2 Y 5 V 1 0 3 Z T 5 0 V Product Series Code Description Multilayer CML Ceramic Size Code 0402 0603 0805 1206 1210 1812 Dielectric Code Y5V Capacitance Range 0.1pF to 0.10uF (E6) EIA Code Capacitance 102 1000 pF 103 0.01 uF 104 0.1 uF 105 1 uF 106 10 uF Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Tolerance (*) Code Description M ± 20% Z +80%/-20% Code T Packaging Description Size Quantity 7" Paper Reel Refer to Packaging Specifications 7" Plastic Tape (*) Other tolerances may be available. Contact 1 Max Working Voltage 10V 16V 25V 50V 100V www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Capacitance and Voltage Available Dielectric Y5V EIA Size 0402 0603 0805 1206 1210 Code VDCW 10V 16V 25V 50V 10V 16V 25V 50V 100 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 102 1000 pF 122 1200 pF 152 1500 pF 182 1800 pF 222 2200 pF 272 2700 pF 332 3300 pF 392 3900 pF 472 4700 pF 562 5600 pF 682 6800 pF 822 8200 pF 103 0.01 uF 123 0.012 uF 153 0.015 uF 183 0.018 uf 223 0.022 uF 273 0.027 uF 333 0.033 uF 393 0.039 uF 473 0.047 uF 563 0.056 uF 683 0.068 uF 823 0.082 uF 104 0.1 uF 124 0.12 uF 154 0.15 uF 224 0.22 uF 334 0.33 uF 394 0.39 uF 474 0.47 uF 564 0.56 uF 684 0.68 uF 824 0.82 uF 105 1 uF 125 1.2 uF 135 1.3 uF 155 1.5 uF 225 2.2 uF 335 3.3 uF 475 4.7 uF 685 6.8 uF 106 10 uF 226 22 uF Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 1812 16V www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Mechanical Specifications and Packaging Specifications Type / Code Voltage Capacitance Range CML0402Y5V 10V - 50V 1000 pF - 1 uF CML0603Y5V 10V - 100V 1000 pF - 10 uF 1000 pF - 0.22 uF 10V 0.33 uF - 2.2 uF 3.3 uF - 22 uF 1000 pF - 0.22 uF 16V 0.33 uF - 2.2 uF 3.3 uF - 10 uF CML0805Y5V 1000 pF - 0.22 uF 25V 0.33 uF - 2.2 uF 3.3 uF - 4.7 uF 1000 pF - 0.22 uF 50V 0.33 uF - 2.2 uF 100V 0.01 uF - 0.1 uF 1000 pF - 10 uF 10V - 16V 22 uF CML1206Y5V 25V 1000 pF - 10 uF 50V - 100V 1000 pF - 4.7 uF CML1210Y5V 100V 0.015 uF - 1 uF CML1812Y5V 100V 0.15 uF - 2.2 uF L 0.039 1.00 0.063 1.60 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.126 3.20 0.177 4.50 Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.016 0.40 0.020 0.50 0.031 0.80 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.049 1.25 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.098 2.50 0.126 3.20 3 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.020 0.50 0.031 0.80 0.028 0.70 0.031 0.80 0.047 1.20 0.028 0.70 0.031 0.80 0.047 1.20 0.028 0.70 0.031 0.80 0.047 1.20 0.028 0.70 0.031 0.80 0.028 0.70 0.031 0.80 0.063 1.60 0.031 0.80 0.031 0.80 0.039 1.00 0.063 1.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.002 0.05 0.004 0.09 0.020 0.50 0.004 0.10 0.004 0.10 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.004 0.10 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.010 0.25 0.012 0.30 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Packaging (7" Reel) Qty. Paper Tape Plastic Tape Unit 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm 10000 - 4000 - 4000 - 4000 - - 3000 4000 - 4000 - - 3000 4000 - 4000 - - 3000 4000 - 4000 - 4000 - 4000 - - 2000 4000 - 4000 - - 2000 - 1000 www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics Test Test Specification Test Condition Capacitance Should be within the specified tolerance. Y5V: (Class II) Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10% Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10% Dissipation Factor (DF) Y5V (Class II) Insulation Resistance Y5V (Class II) ≥ 25V ≤ 7% (C < 1uF) ≤ 9% (C ≥ 1uF) 16V 10V ≤ 15% ≤ 15% C ≤ 25 nF, Ri ≥ 4,000 MΩ C > 25 nF, Ri*CR > 100 S Dielectric Withstanding Voltage No breakdown or damage. Solderability At least 95% of the terminal electrode is covered by new solder. Visual appearance: No visible damage. Resistance to Soldering Heat Item Δ C/C DF IR Y5V -10 ~ +20% Same to initial value Same to initial value Appearance: No visible damage. At least 95% of the terminal electrode is covered by new solder. Resistance to Flexure of Substrate (Bending Strength) Appearance: No visible damage. Δ C/C: ≤ ± 10% Termination Adhesion No visible damage Temperature Cycle Applied Force: 5 N Duration: 10 ± 1 seconds Preheating Conditions: up-category temperature 1 hour Recovery Time: 24 ± 1 hours Initial Measurement Cycling times: 5 times, 1 cycle, 4 steps: Step Temp. ( °C ) Time (min.) Low-category temp. 1 30 ± 3 Y5V: -25 ºC 2 Normal temp. (+20ºC) 2-3 Up-category temp. 3 30 ± 3 Y5V: +85ºC 4 Normal temp. (+20ºC) 2-3 Recovery time after test: 24 ± 2 hours Y5V: Δ C/C: ≤ ± 20% Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10% Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10% Measuring Voltage: Rated Voltage (Max 500V) Duration: 60 ± 5 seconds Test Humidity: ≤ 75% Test Temperature: 25°C ± 5°C Test Current: ≤ 50 mA Measuring voltage: Class II: 250% rated voltage Duration: 1 ~ 5 seconds Charge/Discharge Current: 50 mA max. Preheating Conditions: 80ºC to 120°C, 10 ~ 30 seconds Solder Temperature: 235ºC ± 5% (Sn/Pb: 63/37) Duration: 2 ± 0.5 seconds Solder Temperature: 245ºC ± 5 °C (Lead-free) Duration: 2 ± 0.5 seconds Preheating Conditions: 100ºC to 200°C; 10 ± 2 minutes Solder Temperature: 265ºC ± 5°C Duration: 10 ± 1 seconds Clean the capacitor with solvent and examine it with a 10X (min.) microscope. Recovery Time: 24 ± 2 hours Recovery Condition: Room temperature. Test Board: AI2O3 or PCB Warp: 1 mm Speed: 0.5 mm / second The measurement should be made with the board in the bending position. Unit: mm 4 www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Environmental Characteristics (cont.) Test Moisture Resistance Life Test Middle and High Voltage Life Test Test Specification Test Condition Y5V: Δ C/C: ≤ ± 30% DF: Not more than twice of initial value. IR: Y5V: Ri ≥ 1000 MΩ or Ri*CR ≥ 25 S whichever is smaller Appearance: No visible damage Temperature: 40ºC ± 2 °C Humidity: 90 ~ 95% R.H. Duration: 500 hours Recovery Conditions: Room temperature Recovery Time: 48 hours (Class II) Low-voltage ( 1000V rated voltage: 1.2 multiple Duration: 1000 hours Charge/Discharge Current: 50 mA max. Temperature: 85°C (Y5V) Recovery Conditions: Room temperature Recovery Time: 48 hours (Class II) Y5V: Δ C/C: ≤ ± 30% DF: Not more than twice of initial value. IR: Y5V: Ri ≥ 2000 MΩ or Ri*CR ≥ 50 S whichever is smaller Appearance: No visible damage Y5V: Δ C/C: ≤ ± 30% DF: Not more than twice of initial value. IR: Y5V Ri ≥ 2000 MΩ or Ri*CR ≥ 50 S whichever is smaller Appearance: No visible damage Reel Specifications Type/Code CML_Y5V (all sizes) A 7.008 ± 0.079 178.00 ± 2.00 B C D 0.118 3.00 0.512 ± 0.020 13.00 ± 0.50 0.827 ± 0.031 21.00 ± 0.80 E F 1.969 or more 50.00 or more G 0.394 ± 0.059 10.00 ± 1.50 Unit 0.472 max inches 12.00 max mm Paper Tape Specifications Type/Code CML0402Y5V CML0603Y5V CML0805Y5V CML1206Y5V A0 0.026 0.65 0.043 1.10 0.057 1.45 0.071 1.80 ± ± ± ± ± ± ± ± B0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.045 1.15 0.075 1.90 0.091 2.30 0.134 3.40 ± ± ± ± ± ± ± ± Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. T 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.031 0.80 0.043 1.10 0.043 1.10 0.043 1.10 5 below below max max max max max max W 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± P0 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor Paper Tape Specifications (cont.) Type/Code P1 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 CML0402Y5V CML0603Y5V CML0805Y5V CML1206Y5V ± ± ± ± ± ± ± ± P2 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± D0 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 E 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± F 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm Unit max max max max max max max max inches mm inches mm inches mm inches mm Plastic Tape Specifications Type/Code A CML0805Y5V CML1206Y5V CML1210Y5V CML1812Y5V CML1206Y5V CML1210Y5V CML1812Y5V C D ± ± ± ± ± ± ± ± J E ± ± ± ± ± ± ± ± F 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.093 2.35 0.142 3.60 0.135 3.42 0.195 4.95 ± ± ± ± ± ± ± ± G 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.315 8.00 0.315 8.00 0.315 8.00 0.472 12.00 ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.217 5.50 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 0.059-0/+0.004 1.5-0/+0.10 Type/Code CML0805Y5V B 0.061 1.55 0.077 1.95 0.106 2.70 0.144 3.66 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± T 0.059 1.50 0.073 1.85 0.126 3.20 0.157 4.00 Unit RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description CML Multilayer Ceramic Chip Capacitor Package / Standard Termination Series RoHS Type Compliant SMD Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. YES 6 Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Matte Sn over Ni Always Lead-Free Effective Date Code (YY/WW) Always www.seielect.com marketing@seielect.com CML_Y5V Series Stackpole Electronics, Inc. Resistive Product Solutions Multilayer Ceramic Chip Capacitor “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 01/20/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com
CML0805X7R471KT50V 价格&库存
很抱歉,暂时无法提供与“CML0805X7R471KT50V”相匹配的价格&库存,您可以联系我们找货
