RMCF0402JT68K0
RMCF0402JT68K0
    SEI
    电阻器 68KΩ ±5% 1/16W ±100ppm/℃ 0402
RMCF0402JT68K0 数据手册
Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions Radial Lead Taping Specification – Pana-Sert Carbon Film & Metal Film Resistors (1/4 W Body Size) Symbol Description A Resistor body length C PANA-SERT Unit Symbol Description 0.256 ± 0.020 6.50 ± 0.50 inches mm L Cutout Length (1) 0.433 max. 11.00 max. inches mm Height of bending 0.098 ± 0.020 2.50 ± 0.50 inches mm P Resistor pitch (1) 0.500 ± 0.039 12.70 ± 1.00 inches mm D Resistor body diameter 0.091 ± 0.008 2.30 ± 0.20 inches mm P0 Sprocket-hole pitch (1) 0.500 ± 0.012 12.70 ± 0.30 inches mm D0 Sprocket-hole diameter 0.157 ± 0.012 4.00 ± 0.30 inches mm P1 Sprocket-hole center to lead center 0.152 ± 0.028 3.85 ± 0.70 inches mm F Resistor lead spacing 0.197 ± 0.039 5.00 ± 1.00 inches mm P2 Sprocket-hole center to resistor center (1) 0.250 ± 0.051 6.35 ± 1.30 inches mm H Height to bottom of resistor 0.748 ± 0.039 19.00 ± 1.00 inches mm T Thickness (chipboard and tape) 0.028 ± 0.008 0.70 ± 0.20 inches mm H0 Height to lead clinch 0.630 ± 0.020 16.00 ± 0.50 inches mm W Chipboard width (1) 0.709 ± 0.039 18.00 ± 1.00 inches mm H1 Height of resistor 1.122 max. 28.50 max. inches mm W0 Hold-down tape width 0.49 min. 12.50 min. inches mm h Resistor alignment 0 ± 0.079 (0 ± 5º) 0 ± 2.00 (0 ± 5º) inches mm W1 Sprocket-hole position 0.354 ± 0.030 9.00 ± 0.75 inches mm h1 Resistor alignment 0 ± 0.079 (0 ± 5º) 0 ± 2.00 (0 ± 5º) inches mm W2 Hold-down tape position 0.118 max. 3.00 max. inches mm I Lead protrusion 0.079 max. 2.00 max. Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. PANA-SERT Unit inches mm 1 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Axial Leaded Resistor Packaging & Identification Variations Lead-Tape Specifications: Reeled in accordance with EIA-296-F Series ASR Code 1 14 ASRM 12 18 CD 14 12 18 14 CF 12 1 2 14 CFM 12 14 12 FRN 1 2 1 3 MR 5 10 A max.(1) 3.917 99.50 2.508 63.70 2.618 66.50 2.508 63.70 2.618 66.50 2.736 69.50 2.508 63.70 2.638 67.00 2.736 69.50 2.972 75.50 3.130 79.50 2.508 63.70 2.638 67.00 2.618 66.50 2.736 69.50 2.421 61.50 3.917 99.50 3.311 84.10 3.484 88.50 3.850 97.80 4.764 121.00 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. B max 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.197 5.00 0.394 10.00 0.394 10.00 0.394 10.00 2 C ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 D(2) 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.500 ± 0.079 63.50 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.875 ± 0.079 73.03 ± 2.00 4.310 ± 0.079 109.47 ± 2.00 Tape 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Lead Tape Specifications: Reeled in accordance with EIA-296-F (cont.) Series Code 1 3 MWW 5 10 14 RC 12 18 14 RNF 12 1 2 14 RNMF 12 12 1 RSF 2 3 5 12 1 RSMF 2 3 5 12 1 RSPF 2 3 .(1) A max 3.563 90.50 3.736 94.90 4.094 104.00 5.118 130.00 2.787 70.80 2.756 70.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.756 ± 0.118 70.00 ± 3.00 2.736 69.50 2.815 71.50 3.524 89.50 3.740 95.00 4.331 110.00 2.618 66.50 2.736 69.50 2.815 71.50 3.524 89.50 3.740 95.00 2.618 66.50 2.736 69.50 2.815 71.50 3.524 89.50 B max 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 11.811 ± 0.197 300.00 ± 5.00 13.504 343.00 13.504 343.00 13.504 343.00 12.008 305.00 12.008 305.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 12.008 305.00 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.394 10.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 C ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± (2) 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 2.063 52.40 2.063 52.40 2.063 52.40 2.063 52.40 2.063 52.40 2.063 52.40 2.047 52.00 2.047 52.00 2.047 52.00 2.047 52.00 2.047 52.00 2.047 52.00 2.047 52.00 2.063 52.40 2.063 52.40 2.500 63.50 2.874 73.00 3.465 88.00 2.063 52.40 2.063 52.40 2.063 52.40 2.500 63.50 2.874 73.00 2.063 52.40 2.063 52.40 2.063 52.40 2.063 52.40 D ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 Tape 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.350 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Lead Tape Specifications: Reeled in accordance with EIA-296-F (cont.) Series SP Code 3A 12 SPR 1 3 TMR 5 1S 1 WRC 2, 2A, 3A, 4A, 5A 3B, 4B, 5B H 1/WWS2 1A 2/WWS3 2A 3/WWS4 WW 3A 4/WWS5 5/WWS7 7 7B/WWS10 10 A max.(1) 2.063 52.40 2.736 69.50 3.917 99.50 6.299 160.00 6.614 168.00 2.756 70.00 2.756 70.00 2.756 70.00 2.756 70.00 2.880 73.15 2.880 73.15 2.880 73.15 2.880 73.15 2.880 73.15 2.880 73.15 3.740 95.00 2.500 63.50 3.740 95.00 5.100 129.54 5.100 129.54 5.100 129.54 B max C 11.000 279.40 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 11.933 303.10 11.933 303.10 11.933 303.10 11.933 303.10 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 11.000 279.40 0.394 10.00 0.197 5.00 0.394 10.00 0.394 10.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 D(2) 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.047 ± 0.079 52.00 ± 2.00 2.047 ± 0.079 52.00 ± 2.00 2.047 ± 0.079 52.00 ± 2.00 2.047 ± 0.079 52.00 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.500 ± 0.079 63.50 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 2.500 ± 0.079 63.50 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 Tape Unit 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.236 ± 0.039 6.00 ± 1.00 0.236 ± 0.039 6.00 ± 1.00 0.236 ± 0.039 6.00 ± 1.00 0.236 ± 0.039 6.00 ± 1.00 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm). (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code. Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions Chip Array Resistors Packaging Specifications RAVF10 - RAVF32 Packaging Specifications Symbol FEATURES Material Pieces / Reel A Pocket Width B Pocket Length C Pin Spacing D Pin Diameter F Pin-Pocket C/L H Reel Diameter J Hub Diameter K Hole Diameter L Key Diameter M Key Width P Pocket Spacing S Reel Inside Width T Side Thickness T1 Strip Thickness T2 Total Thickness U Reel Outside Width W Strip Width RAVF102D Paper - 10000 0.046 ± 0.004 1.17 ± 0.10 0.046 ± 0.004 1.17 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 1.969 50.00 0.512 ± 0.039 13.00 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 0.079 ± 0.039 2.00 ± 1.00 0.079 ± 0.002 2.00 ± 0.05 0.531 ± 0.079 13.50 ± 2.00 0.031 ± 0.008 0.80 ± 0.20 0.039 max 1.00 max 0.055 max 1.40 max RAVF104D Paper - 10000 0.051 ± 0.008 1.30 ± 0.20 0.091 ± 0.008 2.30 ± 0.20 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 1.969 50.00 0.512 ± 0.039 13.00 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 0.079 ± 0.039 2.00 ± 1.00 0.079 ± 0.002 2.00 ± 0.05 0.531 ± 0.079 13.50 ± 2.00 0.031 ± 0.008 0.80 ± 0.20 0.039 max 1.00 max 0.055 max 1.40 max RAVF162D Paper - 5000 0.071 ± 0.004 1.80 ± 0.10 0.071 ± 0.004 1.80 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 1.969 50.00 0.512 ± 0.039 13.00 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 0.079 ± 0.039 2.00 ± 1.00 0.157 ± 0.004 4.00 ± 0.10 0.531 ± 0.079 13.50 ± 2.00 0.031 ± 0.008 0.80 ± 0.20 0.020 max 0.50 max 0.039 max 1.00 max RAVF164D / RAVF328 Paper - 5000 0.079 ± 0.008 2.00 ± 0.20 0.142 ± 0.008 3.60 ± 0.20 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 1.969 50.00 0.512 ± 0.039 13.00 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 0.079 ± 0.039 2.00 ± 1.00 0.157 ± 0.004 4.00 ± 0.10 0.531 ± 0.079 13.50 ± 2.00 0.031 ± 0.008 0.80 ± 0.20 0.039 max 1.00 max 0.055 max 1.40 max 0.315 ± 0.008 8.00 ± 0.20 0.315 ± 0.008 8.00 ± 0.20 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.315 ± 0.008 8.00 ± 0.20 5 0.315 ± 0.008 8.00 ± 0.20 RAVF324D Embossed - 4000 0.134 ± 0.004 3.40 ± 0.10 0.220 ± 0.004 5.60 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.039 ± 0.004 1.00 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 2.362 60.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.157 ± 0.004 4.00 ± 0.10 0.354 ± 0.012 9.00 ± 0.30 0.010 ± 0.002 0.25 ± 0.05 0.043 max 1.10 max 0.449 11.40 0.472 ± 0.008 12.00 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions RACF16 - RACF64 Packaging Specifications Symbol FEATURES Material Pieces / Reel RACF164D Paper - 5000 0.079 ± 0.008 2.00 ± 0.20 0.142 ± 0.008 3.60 ± 0.20 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 1.969 50.00 0.512 ± 0.039 13.00 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 0.079 ± 0.039 2.00 ± 1.00 0.157 ± 0.004 4.00 ± 0.10 0.531 ± 0.079 13.50 ± 2.00 0.031 ± 0.008 0.80 ± 0.20 0.020 max 0.50 max 0.039 max 1.00 max A Pocket Width B Pocket Length C Pin Spacing D Pin Diameter F Pin-to-Pocket Center H Reel Diameter J Hub Diameter K Hole Diameter L Key Diameter M Key Width P Pocket Spacing S Reel Inside Width T Reel Side Thickness T1 Strip Thickness T2 Total Thickness U Reel Outside Width - W Strip Width 0.315 ± 0.008 8.00 ± 0.20 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. RACF324D Embossed - 4000 0.138 ± 0.004 3.50 ± 0.10 0.224 ± 0.004 5.70 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.039 ± 0.004 1.00 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.157 ± 0.004 4.00 ± 0.10 0.354 ± 0.012 9.00 ± 0.30 RACF408M Embossed - 4000 0.098 ± 0.004 2.50 ± 0.10 0.173 ± 0.004 4.40 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.217 ± 0.020 5.50 ± 0.50 7.008 ± 0.079 178.00 ± 2.00 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.157 ± 0.004 4.00 ± 0.10 0.354 ± 0.012 9.00 ± 0.30 RACF648N / RACF648R Embossed - 4000 0.138 ± 0.004 3.50 ± 0.10 0.266 ± 0.004 6.75 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 7.008 ± 0.079 178.00 ± 2.00 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.157 ± 0.004 4.00 ± 0.10 0.354 ± 0.012 9.00 ± 0.30 0.010 0.25 0.043 1.10 0.449 11.40 0.472 12.00 6 ± 0.002 ± 0.05 max max ± 0.039 ± 1.00 ± 0.008 ± 0.20 0.010 0.25 0.043 1.10 0.449 11.40 0.472 12.00 ± 0.002 ± 0.05 max max ± 0.039 ± 1.00 ± 0.008 ± 0.20 0.010 0.25 0.043 1.10 0.449 11.40 0.472 12.00 ± 0.002 ± 0.05 max max ± 0.039 ± 1.00 ± 0.008 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions RMCS Packaging Specifications – Paper Tape Type RMCS0201 RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 Type RMCS0201 RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 L ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.110 2.80 M ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 W ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P2 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 F 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 K1 / K2 0.017 ± 0.008 0.42 ± 0.20 0.018 ± 0.004 0.45 ± 0.10 0.028 ± 0.004 0.70 ± 0.10 0.033 ± 0.004 0.85 ± 0.10 0.033 ± 0.004 0.85 ± 0.10 0.033 ± 0.004 0.85 ± 0.10 Unit inches mm inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm inches mm F 0.217 ± 0.002 5.50 ± 0.05 0.217 ± 0.002 5.50 ± 0.05 K1 / K2 0.047 - 0 1.20 - 0 0.047 - 0 1.20 - 0 Unit inches mm inches mm Unit inches mm inches mm RMCS Packaging Specifications – Embossed Plastic Tape Type RMCS2010 RMCS2512 Type RMCS2010 RMCS2512 L ± 0.008 ± 0.20 ± 0.008 ± 0.20 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.110 2.80 0.138 3.50 M ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.217 5.50 0.264 6.70 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. W ± 0.012 ± 0.30 ± 0.012 ± 0.30 P2 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.472 12.00 0.472 12.00 7 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions RNCS Packaging Specifications – Paper Tape Type RNCS0402 RNCS0603 RNCS0805 RNCS1206 Type RNCS0402 RNCS0603 RNCS0805 RNCS1206 L ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.028 0.70 0.043 1.10 0.063 1.60 0.079 2.00 0.046 1.16 0.075 1.90 0.093 2.37 0.140 3.55 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 M ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P1 ± ± ± ± ± ± ± ± 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 W ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P2 ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.061 ± 0.002 1.55 ± 0.05 0.061 ± 0.002 1.55 ± 0.05 0.061 ± 0.002 1.55 ± 0.05 0.061 ± 0.002 1.55 ± 0.05 F 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 K1 / K2 0.016 0.40 0.024 0.60 0.030 0.75 0.030 0.75 ± ± ± ± ± ± ± ± 0.001 0.03 0.001 0.03 0.002 0.05 0.002 0.05 Unit inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm RNCS Packaging Specifications – Embossed Plastic Tape Type RNCS2010 RNCS2512 Type RNCS2010 RNCS2512 L ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0.157 ± 0.004 4.00 ± 0.10 0.112 2.85 0.134 3.40 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.061 ± 0.002 1.55 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.061 ± 0.002 1.55 ± 0.05 0.215 5.45 0.262 6.65 M ± 0.004 ± 0.10 ± 0.004 ± 0.10 P1 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.472 12.00 0.472 12.00 8 W ± 0.004 ± 0.10 ± 0.004 ± 0.10 P2 F 0.217 ± 0.002 5.50 ± 0.05 0.217 ± 0.002 5.50 ± 0.05 K1 / K2 0.039 ± 0.008 1.00 ± 0.20 Unit inches mm inches mm Unit inches mm 0.039 ± 0.008 1.00 ± 0.20 inches mm www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions RPC Packaging Specifications – Paper Tape Type RPC0603 RPC0805 RPC1206 RPC1210 Type RPC0603 RPC0805 RPC1206 RPC1210 L ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.043 1.10 0.063 1.60 0.075 1.90 0.110 2.80 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 M ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 ± ± ± ± ± ± ± ± 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.394 10.00 0.394 10.00 0.394 10.00 0.394 10.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 W ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P2 ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 F 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 0.138 ± 0.002 3.50 ± 0.05 K1 / K2 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.028 0.70 0.033 0.85 0.033 0.85 0.033 0.85 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Unit inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm RPC Packaging Specifications – Embossed Plastic Tape Type RPC2010 RPC2512 Type RPC2010 RPC2512 L ± 0.008 ± 0.20 ± 0.008 ± 0.20 P0 0.157 ± 0.004 4.00 ± 0.10 0.110 2.80 0.138 3.50 0.157 ± 0.004 4.00 ± 0.10 W ± 0.012 ± 0.30 ± 0.012 ± 0.30 P2 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 F 0.217 ± 0.002 5.50 ± 0.05 0.217 ± 0.002 5.50 ± 0.05 K1 / K2 0.157 ± 0.394 4.00 ± 10.00 0.079 ± 0.002 2.00 ± 0.05 0.059 ± 0.004 1.50 ± 0.10 0.047 - 0 1.20 - 0 Unit inches mm inches mm Unit inches mm 0.157 ± 0.394 4.00 ± 10.00 0.079 ± 0.002 2.00 ± 0.05 0.059 ± 0.004 1.50 ± 0.10 0.047 - 0 1.20 - 0 inches mm 0.217 5.50 0.264 6.70 M ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.472 12.00 0.472 12.00 9 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions CSS Packaging Specifications – Embossed Plastic Tape Type CSS1206 CSS2010 CSS2512 CSS2725 CSS2728 CSS4527 Type CSS1206 CSS2010 CSS2512 CSS2725 CSS2728 CSS4527 A ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 T2 0.008 ± 0.002 0.20 ± 0.05 0.009 ± 0.002 0.23 ± 0.05 0.008 ± 0.002 0.20 ± 0.05 0.010 ± 0.002 0.25 ± 0.05 0.010 ± 0.002 0.25 ± 0.05 0.012 ± 0.004 0.30 ± 0.10 0.137 3.48 0.215 5.45 0.266 6.75 0.281 7.15 0.281 7.15 0.465 11.80 0.072 1.83 0.114 2.90 0.138 3.50 0.266 6.75 0.303 7.70 0.283 7.20 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 0.472 12.00 0.472 12.00 B ± ± ± ± ± ± ± ± ± ± ± ± P ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 W ± 0.006 ± 0.15 ± 0.006 ± 0.15 ± 0.006 ± 0.15 ± 0.006 ± 0.15 ± 0.006 ± 0.15 ± 0.006 ± 0.15 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.315 8.00 0.472 12.00 0.472 12.00 0.472 12.00 0.472 12.00 0.945 24.00 E ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P1 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 F 0.138 ± 0.004 3.50 ± 0.10 0.217 ± 0.004 5.50 ± 0.10 0.217 ± 0.004 5.50 ± 0.10 0.217 ± 0.004 5.50 ± 0.10 0.217 ± 0.004 5.50 ± 0.10 0.453 ± 0.004 11.50 ± 0.10 ΦD 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.043 1.10 0.052 1.33 0.051 1.30 0.077 1.95 0.057 1.45 0.079 2.00 Unit inches mm inches mm inches mm inches mm inches mm inches mm T1 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 Unit inches mm inches mm inches mm inches mm inches mm inches mm RHC Packaging Specifications – Embossed Plastic Tape Type A B W F E P1 Unit RHC2512 0.134 ± 0.004 3.40 ± 0.10 0.260 ± 0.004 6.60 ± 0.10 0.472 ± 0.008 12.00 ± 0.20 0.217 ± 0.002 5.50 ± 0.05 0.069 ± 0.004 1.75 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 Inches mm Type P2 P0 D0 t1 t2 Unit RHC2512 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 0.061 ± 0.002 1.55 ± 0.05 0.010 ± 0.002 0.25 ± 0.05 0.039 ± 0.004 1.00 ± 0.10 Inches mm Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions RHC Reel Specifications Type A 7.087 ± 0.118 180.00 ± 3.00 RHC2512 B C D E W W2 Unit 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.512 ± 0.012 13.00 ± 0.30 0.606 ± 0.039 15.40 ± 1.00 Inches mm CSR / CSRN Packaging Specification – Paper Tape Type 0201 0402 0603 0805 1206 1210 A 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.114 2.90 ± ± ± ± ± ± ± ± ± ± ± ± B 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± ± ± ± ± W 0.002 0.05 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± ± ± ± ± E 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± ± ± ± ± F 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± ± ± ± ± P0 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± P1 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± P2 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± ± ± D0 0.004 0.10 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 + + + + + + + + + + + + 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 T 0.017 0.42 0.018 0.45 0.028 0.70 0.033 0.85 0.033 0.85 0.033 0.85 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm inches mm 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm CSR / CSRN Packaging Specification – Embossed Plastic Tape Type 2010 2512 1225 0815 0830 A 0.110 2.80 0.133 3.38 0.133 3.38 0.098 2.50 0.098 2.50 ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.217 5.50 0.263 6.68 0.263 6.68 0.175 4.45 0.327 8.30 ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.472 12.00 0.472 12.00 0.472 12.00 0.472 12.00 0.630 16.00 ± ± ± ± ± ± ± ± ± ± E 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.217 5.50 0.217 5.50 0.217 5.50 0.217 5.50 0.307 7.80 ± ± ± ± ± ± ± ± ± ± P0 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 11 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± P1 0.002 0.05 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± P2 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± D0 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.061 1.55 0.061 1.55 0.061 1.55 0.059 1.50 + + + + + + + + + + 0.004, -0 0.10, -0 0.002, -0 0.05, -0 0.002, -0 0.05, -0 0.004, -0 0.10, -0 0.004, -0 0.10, -0 T 0.039 1.00 0.057 1.45 0.057 1.45 0.047 1.20 0.047 1.20 ± ± ± ± ± ± ± ± ± ± Unit www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Packaging: Chips per EIA Standard RS-481 Reel Specifications Reel Dimensions A 7.008 178.00 7.008 Embossed Plastic Tape 178.00 7" Paper Tape ± ± ± ± B 0.039 1.00 0.039 1.00 2.362 60.00 2.362 60.00 ± ± ± ± C 0.039 1.00 0.039 1.00 0.531 13.50 0.531 13.50 ± ± ± ± 0.028 0.70 0.028 0.70 0.795 20.20 0.795 20.20 D E W ± ± ± ± 0.031 0.059 ± 0.020 0.331 0.80 1.50 ± 0.50 8.40 0.031 0.059 ± 0.020 0.531 0.80 1.50 ± 0.50 13.50 W2 +0.059/-0 +1.50/-0 ± 0.039 ± 1.00 0.453 11.50 0.610 15.50 ± ± ± ± Unit 0.039 Inches 1.00 mm 0.039 Inches 1.00 mm Tape Specifications A B C D E F G H J (1) Unit 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.039 1.00 0.069 ± 0.002 1.75 ± 0.05 0.197 5.00 0.138 ± 0.002 3.50 ± 0.05 0.315 ± 0.004 8.00 ± 0.10 inches mm (1) For RMCF and RNCF, package size 2010 and 2512, dimensions are 0.472 ± 0.012 inches (12.00 ± 0.30 mm). Tape Specifications (cont.) Type HVC0603, RGC0603, RMCF0603, RNCF0603 FCR0805, HMC0805, HVC0805, RGC0805, RMCF0805, RNCF0805 FCR1206, HMC1206, HVC1206, RGC1206, RMCF1206, RNCF1206, RMCF1210, RNCF1210 Note: K1 0.043 1.10 0.043 1.10 0.043 1.10 max max max max max max FCR1210 - HVC2010, RMCF2010, RNCF2010 - HVC2512, RMCF2512, RNCF2512 - K2 0.094 2.40 0.094 2.40 0.094 2.40 0.094 2.40 max max max max max max max max L 0.043 1.10 0.065 1.65 0.079 2.00 0.110 2.80 0.110 2.80 0.150 3.80 ± ± ± ± ± ± ± ± ± ± ± ± M 0.008 0.20 0.008 0.20 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.075 1.90 0.094 2.40 0.138 3.50 0.142 3.60 0.217 5.50 0.264 6.70 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.002 0.05 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm For reel quantities, please see individual product specifications. Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 12 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Chip Resistors Packaging Specifications Packaging Specification - 0201 and 0402 Chip Size (2 mm pitch) Standard Tape Packaging 2 mm Pitch - 10000 per reel Reel diameter - 7 inches (178 mm) Reel width - 0.315 inches (8 mm) A 0.026 ± 0.004 0.65 ± 0.10 F 0.079 ± 0.002 2.00 ± 0.05 B 0.045 ± 0.004 1.15 ± 0.10 G 0.039 ± 0.002 1.00 ± 0.05 W 0.315 ± 0.008 8.00 ± 0.20 J 0.059 ± 0.004 1.50 ± 0.10 D 0.138 ± 0.002 3.50 ± 0.05 K 0.016 ± 0.002 0.40 ± 0.05 E 0.069 ± 0.004 1.75 ± 0.10 L 0.020 max 0.50 max Unit inches mm Unit inches mm SMD Resistors Packaging Specifications SM Packaging Product SM2615 SM4124 SM6227 SM8035 W 0.630 16.00 0.945 24.00 1.260 32.00 1.732 44.00 ± ± ± ± ± ± ± ± 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 P0 E1 T 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.018 0.45 0.018 0.45 0.018 0.45 0.018 0.45 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 13 S0 1.118 28.40 1.591 40.40 P1 A0 K0 B0 Unit 0.315 8.00 0.472 12.00 0.472 12.00 0.630 16.00 0.161 4.10 0.257 6.53 0.276 7.01 0.343 8.71 0.159 4.03 0.206 5.22 0.271 6.88 0.396 10.05 0.302 7.66 0.457 11.60 0.665 16.89 0.856 21.73 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions Chip Resistors – Part Marking Instructions 1% Marking 5% Marking The nominal resistance is marked on the surface of the overcoating with the use of 4 digit markings. 0201 and 0402 are not marked. The nominal resistance is marked on the surface of the overcoating with the use of 3 digit markings. 0201 and 0402 are not marked. For shared E24 / E96 values, 1% tolerance product may be marked with three-digit marking instead of the standard fourdigit marking for all other E96 values. All E24 values available in 1% tolerance are also marked with three digit marking. Standard HVC is unmarked. Mark Instructions for 0603 1% Chip Resistor (per EIA-J) A two-digit number is assigned to each standard R-Value (E96) as shown in the chart below. This is followed by one alpha character which is used as a multiplier. Each letter from “Y” – “F” represents a specific multiplier as follows: Y = 0.1 X=1 A = 10 B = 100 C = 1,000 D = 10,000 E = 100,000 F = 1,000,000 EXAMPLE: Chip Marking 01B 25C 93D Explanation 01 means 10.0 and B = 100 25 means 17.8 and C = 1,000 93 means 90.9 and D = 10,000 Value 10.0 x 100 = 1 K ohm 17.8 x 1,000 = 17.8 K ohm 90.9 x 10,000 = 909 K ohm E96 1% 10.0 10.2 10.5 10.7 11.0 11.3 11.5 11.8 12.1 12.4 12.7 13.0 13.3 13.7 14.0 14.3 # 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 1% 14.7 15.0 15.4 15.8 16.2 16.5 16.9 17.4 17.8 18.2 18.7 19.1 19.6 20.0 20.5 21.0 # 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1% 21.5 22.1 22.6 23.2 23.7 24.3 24.9 25.5 26.1 26.7 27.4 28.0 28.7 29.4 30.1 30.9 Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. # 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 14 1% 31.6 32.4 33.2 34.0 34.8 35.7 36.5 37.4 38.3 39.2 40.2 41.2 42.2 43.2 44.2 45.3 # 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 1% 46.4 47.5 48.7 49.9 51.1 52.3 53.6 54.9 56.2 57.6 59.0 60.4 61.9 63.4 64.9 66.5 # 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 1% 68.1 69.8 71.5 73.2 75.0 76.8 78.7 80.6 82.5 84.5 86.6 88.7 90.9 93.1 95.3 97.6 # 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions General Product Information Temperature Coefficient Codes Stackpole TC Code M L D C E S T Y MIL TC Code N/A N/A D C E N/A N/A N/A Industry Std TC Code T0 T1 T2 T9 T10 T13 T16 Tolerance Codes Stackpole/MIL Reference S N M K J H G F D C B A T Temperature Coefficient ±300 ppm/ºC ±200 ppm/ºC ±100 ppm/ºC ±50 ppm/ºC ±25 ppm/ºC ±15 ppm/ºC ±10 ppm/ºC ±5 ppm/ºC Resistance Values Tolerance ±40% ±30% ±20% ±10% ±5% ±3% ±2% ±1% ±0.5% ±0.25% ±0.1% ±0.05% ±0.01% Stackpole Standard for Nominal Values & Tolerances Series Tolerance E12 ±10% ±5% E24 ±2% E96 ±1% ±0.5% E192 ±0.25% ±0.1% Note: Non-standard ohmic values are available. Consult factory for minimum order quantities Component Flammability Product Type Carbon Films CF18 (CFM14) CF14 (CFM12) CF12 Metal Films RNF18 (RNMF14) RNF14 (RNMF12) RNF12 Metal Oxides RSMF12 RSMF1 (RSF12) RSMF2 (RSF1) RSMF3 (RSF2) RSMF5 (RSF3) RSF5 Chip Resistors RMCF Series Polymer Type IEC 695-2-2 UL94V Rating Epoxy Epoxy Epoxy Meets Specification Meets Specification Meets Specification N/A N/A N/A 3 mg 15 mg 30 mg N/A N/A N/A Epoxy Epoxy Epoxy Meets Specification Meets Specification Meets Specification N/A N/A N/A 3 mg 15 mg 30 mg N/A N/A N/A Silicone Silicone Silicone Silicone Silicone Silicone Meets Specification Meets Specification Meets Specification Meets Specification Meets Specification 94V-0 94V-0 94V-0 94V-0 94V-0 94V-0 20 mg 30 mg 50 mg 130 mg 500 mg 400 mg 46 - 48% 46 - 48% 46 - 48% 46 - 48% 46 - 48% 46 - 48% Meets Specification 94V-0 N/A N/A Meets Specification 94V-0 N/A N/A Meets Specification 94V-0 N/A N/A Boro-Silicated Acid Lead Glass Total Polymer Mass Oxygen Index Chip Networks RACF Series RAVF Series Boro-Silicated Acid Lead Glass Boro-Silicated Acid Lead Glass Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 15 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Standard Color Codes Standard Color Codes Band Color Nominal Multiplier Tolerance (%) Black Brown Red Orange Yellow Green Blue Violet Gray White Silver Gold 0 1 2 3 4 5 6 7 8 9 - 1 10 100 1K 10K 100K 1,000K 0.001 0.01 0.1 1 2 0.5 0.25 10 5 Color Band Description Band Precision General Purpose 1st Band 2nd Band 3rd Band 4th Band 5th Band Have three significant-figure bands, a multiplier band and a tolerance band. Tolerances 1% or less. Nominal Nominal Nominal Multiplier Tolerance Have two significant-figure bands, a multiplier band and a tolerance band. Tolerances 2% or greater. Nominal Nominal Multiplier Tolerance Resistor Glossary Term Ambient temperature Carbon-composition Carbon-film Climate category Definition The ambient temperature is the temperature in the immediate environment of the resistor. Resistor with the resistance element formed by molding a body of carbon powder mixed with a phenolic binder. Resistor whose resistance element is carbon film deposited on a ceramic core. Indicates the lowest and the highest ambient temperature at which the resistors may be operated continuously. Color-band or color code Method of indicating value and tolerance on axial leaded resistors whose body is too small for legible alphanumerical marking. Critical resistance Current noise Current sensor Derating Dielectric strength (dielectric withstanding voltage) The critical resistance (Rcrit) is the resistance that can be calculated from the rated dissipation Pv occurring under operating voltage Vmax. A resistor of critical resistance will exhibit the largest drift in a style, because it is the highest value that may carry the full rated power load. Random low frequency electrostatic noise arising from current fluctuations in parallel with the resistor. A resistive device employed to sense levels of changes in current. The power load capability of a resistor is limited by its permissible element temperature. Since the rated power dissipation is referenced to a specific ambient temperature, higher ambient temperatures require a reduced permissible load, i.e., a derating. The derating curve indicates the permissible power load as a function of the ambient temperature. The ultimate breakdown voltage of the dielectric or insulation of the resistor when the voltage is applied between the case and all terminals tied together. Dielectric strength is usually specified at sea level and simulated at high altitude air pressures. Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 16 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Packaging and Technical Information Resistive Product Solutions Resistor Glossary (cont.) Term DIP Definition Fixed resistors Dual-in-line package resistor network. Method of deriving nominal resistance values required for each tolerance level. The series E24 is comprised of 24 values per decade and applies to 2% and 5% tolerances. The series E96 applies to 1% tolerance and E192 applies to 0.1%, 0.25% and 0.5%. The failure rate indicates the statistically established maximum rate of failures at a level of confidence of 60%. The figures are derived from certified results of standard endurance tests after 1000 hours duration at the rated dissipation. The temperature of the resistive film is considered in discussions about power rating and pulse load capability. The film temperature determines the drift and stability of the resistor. For resistors that feature hot spots in the resistive film, the higher temperature of the hot spot is to be considered. Since most resistors are covered with lacquer or protective coating, only the surface temperature can be measured on the outside. However, the surface temperature is almost as high as the film temperature. Resistors whose value is set in the manufacturing process. Insulation resistance The DC resistance measured between all terminals connected together and the case, exterior insulation, or external hardware. E-series Failure rate Film temperature Four-terminal connection required in low-resistance measurements to eliminate the effects of contact resistance and lead resistance, as well as the effects of lead temperature, providing accurate measurements. Invented by Lord Kelvin in the 19th Century. The maximum voltage stress (DC or rms) that may be applied to the resistor (resistance element). Maximum working voltage A function of the materials used, the required performance, and the physical dimensions. Resistor whose resistance element is a thick film ruthenium oxide paste deposited on a cylindrical ceramic core by means of Metal oxide dipping or spiral-coating. The limiting element voltage Vmax is the maximum voltage that may be applied continuously to the resistor, provided its Operating voltage resistance value is equal to or higher than the critical resistance. The limit applies to DC voltages and to AC rms voltage of undistorted sinusoidal shape. Maximum power in still air that will limit the resistor internal hot-spot temperature to a satisfactory level. Power ratings must Power rating be reduced as the temperature rises, so derating curves or charts are published. These parameters are applicationdependent. The pulse load capability of a resistor is its ability to withstand transient loads that considerably exceed the rated dissipation Pulse load capability with its peak value. Kelvin connection Resistance temperature characteristic (coefficient) Resistance tolerance Resistor Shunt SIP SMD Solderability Stability Temperature rise Thick-film Variable resistors Voltage coefficient Wirewound Zero-ohm resistors The magnitude of change in resistance due to temperature, expressed in percent or degree centigrade or parts-per-million per degree centigrade (PPM/C). If the resistance changes are linear over the specified temperature range, the parameter is known as the temperature "coefficient". This assumption of linearity is usually made in order to ease calculations. The permissible deviation of the manufactured resistance value (express in percent) from the specified nominal resistance value at standard or stated environmental conditions. A device that converts electrical energy to thermal energy according to Ohm's Law. A resistive device employed to divert most of the current in an electric circuit. Single-in-line package resistor network. Surface mount devices. Chips and chip arrays are examples. Property of the termination to accept new solder in a soldering process. Ability of a resistor to maintain its initial resistance value of extended periods of time when subjected to any combination of electrical stresses and environmental conditions. Thermal resistance that impedes the dissipation of heat from the resistor. Resistor whose resistance element consists of a ruthenium oxide (also called cermet) screen printed onto a ceramic substrate and fired at a high temperature. Resistors whose value can be adjusted (trimmed) by the user, typically by means of a dial. A resistor has a voltage coefficient if measurements of resistance with different voltages yield different results. The voltage coefficient is the quotient of the relative difference in resistance and the difference of measuring voltage. Resistor whose resistance element consists of a wire (nickel-chromium, copper-nickel, or gold-platinum) wound around a bobbin or core. Jumpers that are manufactured into resistor bodies for ease of insertion by the user. Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 17 www.seielect.com marketing@seielect.com Packaging and Technical Information Stackpole Electronics, Inc. Resistive Product Solutions EIA Standard Resistor Values Rev Date: 01/02/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 18 www.seielect.com marketing@seielect.com
RMCF0402JT68K0
物料型号:文档中没有明确指出具体的物料型号,但提供了多种电阻器的封装和规格信息。
器件简介:文档主要描述了Stackpole Electronics, Inc.的电阻产品解决方案,包括径向引线、轴向引线和芯片阵列电阻的封装和技术指标。
引脚分配:文档提供了详细的引脚分配信息,包括电阻体长度、高度、直径、引线间距等,以及不同系列电阻的引脚规格。
参数特性:文档列出了多种电阻器的参数特性,如尺寸、公差、引线规格等,并按照EIA标准进行了归类。
功能详解:虽然文档没有直接提供功能详解,但从提供的技术规格可以推断出这些电阻器适用于各种电子电路,用于限制电流、分压、负载分摊等。
应用信息:文档中没有具体的应用案例,但根据电阻器的规格和封装类型,它们可以广泛应用于消费电子、工业控制、汽车电子等领域。
封装信息:文档详细列出了不同类型电阻器的封装信息,包括尺寸、形状、材料等。
RMCF0402JT68K0 价格&库存
很抱歉,暂时无法提供与“RMCF0402JT68K0”相匹配的价格&库存,您可以联系我们找货
RMCF0402JT68K0
  • 10000+0.0208610000+0.00270
  • 20000+0.0182820000+0.00237
  • 30000+0.0170430000+0.00221
  • 50000+0.0156950000+0.00203
  • 70000+0.0149270000+0.00193
  • 100000+0.01419100000+0.00184
库存:19780
RMCF0402JT68K0
  • 1+0.883701+0.11422
  • 10+0.1586410+0.02051
  • 25+0.1090325+0.01410
  • 50+0.0862450+0.01115
  • 100+0.06953100+0.00899
  • 250+0.05247250+0.00679
  • 500+0.04298500+0.00556
  • 1000+0.035581000+0.00460
  • 5000+0.024135000+0.00312
库存:19780
