AC1206JRNPOBBN220
AC1206JRNPOBBN220
    YAGEO(国巨)
    贴片电容(MLCC) 22pF 500V ±5% C0G (NP0) 1206
AC1206JRNPOBBN220 数据手册
85 DATA SHEET SURFACE MOUNT MULTILAYER CERAMIC CAPACITORS Automotive grade NP0/X7R 6.3 V TO 630 V 0.2 pF to 2.2 µF Product Specification – February 26, 2019 V.12 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 2 24 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes Automotive grade NP0/X7R series chip capacitors with lead-free terminations and used for automotive equipments. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. GLOBAL PART NUMBER AC XXXX X X XXX X (1) APPLICATIONS All general purpose applications Entertainment applications Comfort / security applications Information applications (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) / 0508 (1220) / 0612 (1632) (2) TOLERANCE B = ± 0.1 pF FEATURES  AEC-Q200 qualified  MSL class: MSL 1  AC series soldering is compliant with J-STD-020D  Halogen free epoxy  RoHS compliant  Reduce environmentally hazardous waste  High component and equipment reliability  Save PCB space  The capacitors are 100% performed by automatic optical inspection prior to taping. C = ± 0.25 pF D = ± 0.5 pF F = ± 1% G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO X7R (5) RATED VOLTAGE 5 = 6.3 V 6 = 10 V 7 = 16 V 8 = 25 V 9 = 50 V 0 = 100 V A = 200 V Y = 250 V B = 500 V Z = 630 V (6) PROCESS N = NP0 B = Class 2 MLCC (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 3 24 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (Matte Sn). The terminations are leadfree. A cross section of the structure is shown in Fig.1. Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig. 2 T (MM) L2 / L3 (mm) L4 (mm) min. max. min. TYPE L1 (mm) W (mm) 0201 0.6 ± 0.03 0.3 ± 0.03 0.10 0.20 0.20 0402 1.0 ± 0.05 0.5 ± 0.05 0.15 0.30 0.40 0603 1.6 ± 0.10 0.8 ± 0.10 0.20 0.60 0.40 0.25 0.75 0.70 Refer to 1.25 ± 0.20 table 3 to 12 0805 2.0 ± 0.20 1206 3.2 ± 0.30 1.6 ± 0.20 0.25 0.75 1.40 1210 3.2 ± 0.30 2.5 ± 0.20 0.25 0.75 1.40 1812 4.5± 0.40 3.2± 0.40 0.25 0.75 2.20 For dimension see Table 1 Fig. 2 Surface mounted multilayer ceramic capacitor dimension OUTLINES Table 2 For outlines see fig. 3 TYPE For dimensions see Table 2 0508 (4 X 0402) 0612 (4 X 0603) L (mm) 2.0 ± 0.15 3.2 ± 0.15 W (mm) 1.25 ± 0.15 1.60 ± 0.15 0.50 0.70 Tmin. (mm) Tmax. (mm) 0.70 0.90 A (mm) 0.28 ± 0.10 0.4 ± 0.10 B (mm) 0.2 ± 0.10 0.3 ± 0.20 P (mm) 0.5 ± 0.10 0.8 ± 0.10 Fig. 3 Surface mounted multilayer ceramic capacitor dimension www.yageo.com Dec. 30, 2019 V.12 4 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0201 to 0805 0201 0402 0603 CAP. 25 V / 50 V NP0/X7R 6.3 V to 630 V 24 0805 50 V 50 V 100 V 250 V 50 V 100 V 250V 0.2 pF 0.3± 0.03 0.47 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.56 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.68 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.82 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.0 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.5 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.3 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.9 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 4.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 5.6 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 6.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 8.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 10 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 12 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 15 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 18 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 22 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 27 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 33 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 39 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 47 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 56 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 68 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 82 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 100 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 5 24 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 0402 to 0805 (continued) 0402 0603 50 V 50 V 100 V 250 V 50 V 100 V 250 V 120 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 150 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 180 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 220 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 270 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 330 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 390 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 470 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 560 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 680 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 820 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.0 nF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.2 nF 0.85± 0.1 0.85± 0.1 1.5 nF 0.85± 0.1 0.85± 0.1 1.8 nF 0.85± 0.1 0.85± 0.1 2.2 nF 1.25± 0.2 1.25± 0.2 2.7 nF 1.25± 0.2 1.25± 0.2 3.3 nF 1.25± 0.2 1.25± 0.2 3.9 nF 1.25± 0.2 1.25± 0.2 4.7 nF 1.25± 0.2 1.25± 0.2 5.6 nF 1.25± 0.2 1.25± 0.2 6.8 nF 1.25± 0.2 1.25± 0.2 8.2 nF 1.25± 0.2 1.25± 0.2 10 nF 1.25± 0.2 1.25± 0.2 CAP. 0805 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 1206 to 1210 1206 CAP. NP0/X7R 6.3 V to 630 V 6 24 1210 50 V 100 V 250 V 500 V 630 V 10 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 12 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 15 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 18 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 22 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 27 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 33 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 39 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 47 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 56 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 68 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 50 V 100 V 250 V 500 V 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 82 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 100 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 120 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 150 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 180 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 220 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 270 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 330 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 390 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 470 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 560 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 680 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 820 pF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.0 nF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.2 nF 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.5 nF 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.8 nF 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.2 nF 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.7 nF 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 7 24 CAPACITANCE RANGE & THICKNESS FOR X7R Table 6 Sizes from 0201 to 0603 CAP. 0201 25V 0603 0402 50 V 10V 16 V 25 V 50 V 100 V 10V 16 V 25 V 50 V 100 V 1.0 nF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 1.5 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 2.2 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 3.3 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 4.7 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 6.8 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 10 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 15 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 22 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 33 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 47 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 68 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 100 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 150 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 220 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 330 nF 0.8± 0.1 0.8± 0.1 470 nF 0.8± 0.1 0.8± 0.1 680 nF 0.8± 0.1 0.8± 0.1 1 µF 0.8± 0.1 0.8± 0.1 100 pF 0.3± 0.03 0.3± 0.03 150 pF 0.3± 0.03 0.3± 0.03 220 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 330 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 470 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 680 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 8 24 CAPACITANCE RANGE & THICKNESS FOR X7R Table 8 Size 0805 0805 CAP. 10 V 16 V 25 V 50 V 100 V 250 V 500 V 1.0 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.5 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 2.2 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 3.3 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 4.7 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 6.8 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 10 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 15 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 330 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1 µF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.2 µF 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 9 24 CAPACITANCE RANGE & THICKNESS FOR X7R Table 9 Size 1206 1206 CAP. 6.3 V 10V 16V 25V 50 V 100 V 250 V 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 1.60± 0.2 470 nF 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.60± 0.2 1.60± 0.2 680 nF 1.15± 0.1 1.15± 0.1 1.15± 0.1 1.60± 0.2 1.60± 0.2 1.60± 0.2 1 µF 1.15± 0.1 1.15± 0.1 1.15± 0.1 1.60± 0.2 1.60± 0.2 1.60± 0.2 2.2 µF 1.60± 0.2 1.60± 0.2 1.60± 0.2 1.60± 0.2 1.60± 0.2 1.60± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 10 24 CAPACITANCE RANGE & THICKNESS FOR X7R Table 10 Size 1210 CAP. 1812 1210 6.3V 10 V 16 V 25 V 50V 100 V 250 V 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 2.0± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1 µF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 50V 100V 2.0± 0.2 1.60± 0.2 1.60± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 2.2 µF 2.0± 0.2 2.0± 0.2 4.7 µF 2.5± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 11 24 CAPACITANCE RANGE & THICKNESS FOR 4C-ARRAY Table 11 Temperature characteristic material from NP0 0508 (4 x 0402) 0612 (4 x 0603) CAPACITANCE 50 V 50 V 10 pF 0.6± 0.1 0.8± 0.1 15 pF 0.6± 0.1 0.8± 0.1 18 pF 0.6± 0.1 0.8± 0.1 22 pF 0.6± 0.1 0.8± 0.1 33 pF 0.6± 0.1 0.8± 0.1 39 pF 0.6± 0.1 0.8± 0.1 47 pF 0.6± 0.1 0.8± 0.1 56 pF 0.6± 0.1 0.8± 0.1 68 pF 0.6± 0.1 0.8± 0.1 82 pF 0.6± 0.1 0.8± 0.1 100 pF 0.6± 0.1 0.8± 0.1 120 pF 0.8± 0.1 150 pF 0.8± 0.1 180 pF 0.8± 0.1 220 pF 0.8± 0.1 270 pF 0.8± 0.1 330 pF 0.8± 0.1 390 pF 0.8± 0.1 470 pF 0.8± 0.1 560 pF 680 pF 820 pF 1.0 nF NOTE Values in shaded cells indicate thickness class in mm www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR 4C-ARRAY Table 12 Temperature characteristic material from X7R 0508 (4 x 0402) CAPACITANCE 16 V 25 V Automotive grade NP0/X7R 6.3 V to 630 V 12 24 0612 (4 x 0603) 50 V 16 V 25 V 50 V 220 pF 0.8± 0.1 0.8± 0.1 0.8± 0.1 330 pF 0.8± 0.1 0.8± 0.1 0.8± 0.1 470 pF 0.8± 0.1 0.8± 0.1 0.8± 0.1 680 pF 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 1.0 nF 0.6± 0.1 0.6± 0.1 1.5 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 2.2 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 3.3 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 4.7 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 6.8 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 10 nF 0.6± 0.1 0.6± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 15 nF 0.6± 0.1 0.8± 0.1 0.8± 0.1 22 nF 0.6± 0.1 0.8± 0.1 0.8± 0.1 33 nF 0.6± 0.1 0.8± 0.1 0.8± 0.1 47 nF 0.6± 0.1 0.8± 0.1 0.8± 0.1 68 nF 0.6± 0.1 100 nF 0.6± 0.1 NOTE Values in shaded cells indicate thickness class in mm www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 13 24 THICKNESS CLASSES AND PACKING QUANTITY Table 13 SIZE CODE Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister 8 mm 15,000 --- 50,000 --- 0.5 ± 0.05 mm 8 mm 10,000 --- 50,000 --- 0.8 ± 0.1 mm 8 mm 4,000 --- 15,000 --- 0.6 ± 0.1 mm 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm 8 mm --- 3,000 --- 10,000 0.6 ± 0.1 mm 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- 1.0/1.15 ± 0.1 mm 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm 8 mm --- 3,000 --- 10,000 1.6 ± 0.2 mm 8 mm --- 2,000 --- 10,000 0.85 ± 0.1 mm 8 mm --- 4,000 --- 10,000 1.15 ± 0.1 mm 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm 8 mm --- 3,000 --- 10,000 0.6 / 0.85± 0.1 mm 12 mm --- 2,000 --- --- 1.15± 0.1 mm 12 mm --- 1,000 --- --- 1.25± 0.2 mm 12 mm --- 1,000 --- --- THICKNESS CLASSIFICATION TAPE WIDTH QUANTITY PER REEL 0201 0.3 ± 0.03 mm 0402 0603 0805/0508 1206/0612 1210 1812 www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 14 24 6.3 V to 630 V ELECTRICAL CHARACTERISTICS NP0/X7R DIELECTRIC CAPACITORS; NI/SIN TERMINATIONS Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: - Temperature: 15 °C to 35 °C - Relative humidity: 25% to 75% - Air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. VALUE DESCRIPTION Table 14 Capacitance range 0.2 pF to 2.2 µF Capacitance tolerance NP0 C < 10 pF ± 0.1 pF, ± 0.25 pF, ± 0.5 pF C ≥ 10 pF ± 1%, ± 2%, ± 5% X7R ± 5% (1), ± 10%, ± 20% Dissipation factor (D.F.) NP0 C < 30 pF C ≥ 30 pF X7R 0201 ≤10V ≤ 1 / ( 400 + 20C ) ≤ 0.1 % 0402 0603 0805 220pF to 100nF 1nF to 1uF 1nF to 2.2uF 1206 1210 0508 0612 (Array) (Array) 1812 22nF to 2.2uF 100nF to 1uF ≤ 5% ≤ 10% 16V 25V 100pF to 470pF 220pF to 22nF 1nF to 220nF 1nF to 470nF 27nF to 100nF 470nF to 1uF 680nF to 2.2uF 220pF to 10nF 1nF to 39nF 1nF to 180nF 12nF to 27nF 47nF to 220nF 220nF to 470nF 50V 560pF to 10nF 47nF to 100nF 1uF 680nF to 1uF 100pF to 470pF 220pF to 10nF 1nF to 39nF 1nF to 180nF 47nF to 100nF 220nF to 470nF 680nF to 1uF 22nF to 1uF 100nF to 1uF 2.2 uF 22nF to 680nF 100nF to 1uF 220pF to 1.5nF 1nF to 10nF 1nF to 100nF 12nF to 47nF ≤ 3.5% 2.2 uF ≤ 5% 22nF to 470nF 100nF to 1uF 470nF to 1uF 680nF to 2.2uF 2.2uF 4.7uF 22nF to 470nF 100nF to 220nF 470nF to 1uF 680nF to 2.2uF 330nF to 2.2uF 250V 1nF to 22nF 500V 1nF to 4.7nF Insulation resistance after 1 minute at Ur (DC) 22nF to 100nF ≤ 5% 1nF to 10nF 220pF to 47nF ≤ 2.5% 1uF 560pF to 1nF 100V 1nF to 10nF 220pF to 47nF ≤ 3.5% 15nF to 100nF 100nF 1nF 220pF to 10nF ≤ 2.5% ≤ 3.5% ≤ 5% ≤ 10% ≤ 2.5% ≤ 5% ≤ 2.5% ≤ 2.5% IR ≥ 10 GΩ or I.R × C ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): NP0 X7R Operating temperature range: NP0/X7R ± 30 ppm/°C ± 15% –55 °C to +125 °C NOTE 1. Capacitance tolerance ±5% doesn't available for X7R full product range, please contact local sales force before order www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 15 24 6.3 V to 630 V SOLDERING RECOMMENDATION Table 15 SOLDERING METHOD SIZE 0402 0603 0805 1206 ≥ 1210 Reflow ≥ 0.1 µF ≥ 1.0 µF ≥ 2.2 µF ≥ 4.7 µF Reflow only Reflow/Wave < 0.1 µF < 1.0 µF < 2.2 µF < 4.7 µF --- SOLDERING CONDITIONS The lead free MLCCs are able to stand the reflow soldering conditions as below:    Temperature: above 220 °C Endurance: 95 to 120 seconds Cycles: 3 times The test of "soldering heat resistance" is carried out in accordance with the schedule of "MIL-STD-202F-method 210F", "The robust construction of chip capacitors allows them to be completely immersed in a solder bath of 270 °C for 10 seconds". Therefore, it is possible to mount MLCCs on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Capacitors are tested for solderability at 245 °C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. TESTS AND REQUIREMENTS Table 16 Test procedures and requirements TEST Mounting TEST METHOD PROCEDURE REQUIREMENTS IEC 60384- 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage 4.5.1 Class 1: At 20 °C, 24 hours after annealing Within specified tolerance 21/22 Capacitance IEC 6038421/22 f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 20 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 20 °C Class 2: At 20 °C, 24 hours after annealing f = 1 KHz, measuring at voltage 1 Vrms at 20 °C Dissipation Factor (D.F.) IEC 60384- 4.5.2 21/22 Class 1: At 20 °C, 24 hours after annealing In accordance with specification f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 20 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 20 °C Class 2: At 20 °C, 24 hours after annealing f = 1 KHz, measuring at voltage 1 Vrms at 20 °C Insulation Resistance IEC 6038421/22 4.5.3 At Ur (DC) for 1 minute In accordance with specification www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD 4.6 Temperature coefficient Automotive grade NP0/X7R 6.3 V to 630 V PROCEDURE REQUIREMENTS Capacitance shall be measured by the steps shown in the following table. Class1: ∆ C/C: ± 30ppm The capacitance change should be measured after 5 min at each specified temperature stage. Step Temperature(℃) a 25± 2 b Lower temperature± 3℃ c 25± 2 d Upper Temperature± 2℃ e 25± 2 16 24 Class2: X7R: ∆ C/C: ±15% Class2: X7R/X5R: ∆ C/C: ±15% (1) Class I Temperature Coefficient shall be calculated from the formula as below C2 - C1 Temp, Coefficient = 106 [ppm/℃] C1 xΔT C1: Capacitance at step c C2: Capacitance at 125℃ ∆T: 100℃(=125℃-25℃) (2) Class II Capacitance Change shall be calculated from the formula as below C2 - C1 ∆C = x 100% C1 C1: Capacitance at step c C2: Capacitance at step b or d High Temperature Exposure AEC-Q200 3 Unpowered ; 1000hours @ T=150℃ No visual damage Measurement at 24± 2 hours after test conclusion. Δ C/C: Class1: NP0: within ± 0.5% or 0.5 pF whichever is greater Class2: X7R: ± 10% D.F.: within initial specified value IR: within initial specified value www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Temperature Cycling Automotive grade NP0/X7R TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature No visual damage 4 1000 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ± 2 hours 17 6.3 V to 630 V 24 ∆C/C Class1: NP0: Within ± 1% or 0.5pF, whichever is greater. Class2: X7R: ±10% D.F. meet initial specified value IR meet initial specified value Destructive Physical Analysis AEC-Q200 Moisture Resistance AEC-Q200 5 10ea X 3 lots. Note: Only applies to SMD ceramics. Electrical test not required. 6 T=24 hrs/per cycle; 10 continuous cycles unpowered. Measurement at 24 ± 2 hours after test condition. No visual damage ∆C/C NP0: Within ± 3% or 3 pF, whichever is greater X7R: ± 15% D.F. Within initial specified value IR NP0: ≥ 10,000 MΩ X7R: Meet initial specified value Fig. 4 Moisture resistant www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Biased Humidity Automotive grade NP0/X7R 6.3 V to 630 V TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp No visual damage after recovery 2. Initial measure: Parameter: IR Measuring voltage: 1.5V ± 0.1 VDC Note: Series with 100 KΩ & 6.8 KΩ Initial requirement: 7 3. Test condition: 85 °C, 85% R.H. connected with 100 KΩ resistor, applied 1.5V/Ur for 1,000 hours. 4. Recovery: Class1: 6 to 24 hours Class2: 24 ± 2 hours 5. Final measure: IR 18 24 Class1: - Connected to 100 KΩ: C ≤ 10 nF: I.R ≥ 10,000 MΩ or C > 10 nF: (I.R-100 KΩ) x C ≥ 100s. - Connected to 6.8 KΩ: C ≤ 10 nF: I.R ≥ 10,000 MΩ or C > 10 nF: (I.R-6.8 KΩ) x C ≥ 100s. Class2: - Connected to 100 KΩ: C ≤ 25 nF: I.R ≥ 4,000 MΩ or C > 25 nF: (I.R-100 KΩ) x C ≥ 100s. - Connected to 6.8 KΩ: C ≤ 25 nF: I.R ≥ 10,000 MΩ or C > 25 nF: (I.R-6.8 KΩ) x C ≥ 100s. Final measurement: The insulation resistance shall be greater than 0.1 time initial value. www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Operational Life Automotive grade NP0/X7R TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp No visual damage 8 2. Initial measure: Spec: refer to initial spec C, D, IR 3. Endurance test: Temperature: X7R: 125 °C Specified stress voltage applied for 1,000 hours: Applied 2.0 x Ur for general products Applied 1.5 x Ur for high cap. Products High voltage series follows with below stress condition: 19 6.3 V to 630 V 24 ∆C/C NP0: Within ± 2% or 1 pF, whichever is greater X7R: ± 15% D.F. NP0: ≤ 2 x specified value. X7R: ≤ 16V: ≤ 7% or specified value whichever is greater ≥ 25V: ≤ 5% or specified value whichever is greater Applied 1.5 x Ur for 200V, 250V series Applied 1.3 x Ur for 500V, 630V series IR Applied 1.2 x Ur for 1KV, 2KV, 3KV series NP0: ≥ 4,000 MΩ or IR x Cr ≥ 40s whichever is less 4. Recovery time: 24 ± 2 hours 5. Final measure: C, D, IR X7R: ≥ 1,000 MΩ or IRx Cr ≥ 50s whichever is less Note: If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be preconditioned according to “IEC 60384 4.1” and then the requirement shall be met. External Visual AEC-Q200 9 Any applicable method using × 10 magnification In accordance with specification Physical Dimension AEC-Q200 10 Verify physical dimensions to the applicable device specification. In accordance with specification Mechanical Shock AEC-Q200 13 Three shocks in each direction shall be applied along the three mutually perpendicular axes of the test specimen (18 shocks) Peak value: 1,500 g’s ∆C/C NP0: Within ± 0.5% or 0.5 pF, whichever is greater Duration: 0.5 ms X7R: ± 10% Velocity change: 15.4 ft/s Waveform: Half-sin D.F. Within initial specified value IR Within initial specified value Vibration AEC-Q200 14 5 g’s for 20 minutes, 12 cycles each of 3 orientations. Note: Use 8” x 5” PCB. 0.31” thick 7 secure points on one long side and 2 secure points at corners of opposite sides. Parts mounted within 2” from any secure point. Test from 10-2000 Hz. ∆C/C NP0: Within ± 0.5% or 0.5 pF, whichever is greater X7R: ± 10% D.F: meet initial specified value IR meet initial specified value www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Resistance to Soldering Heat Automotive grade NP0/X7R 6.3 V to 630 V 20 24 TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned 15 Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Preheating: for size >1206: 100 °C to 120 °C for 1 minute and 170 °C to 200 °C for 1 minute Solder bath temperature: 260 ± 5 °C Dipping time: 10 ± 0.5 seconds Recovery time: 24 ± 2 hours ∆C/C Class1: NP0: Within ± 1% or 0.5 pF, whichever is greater. Class2: X7R: ± 10% D.F. within initial specified value IR within initial specified value Thermal Shock AEC-Q200 16 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C, D, IR 3. Rapid change of temperature test: NP0/X7R: -55 °C to +125 °C; 300 cycles 15 minutes at lower category temperature; 15 minutes at upper category temperature. No visual damage ∆C/C NP0: Within ± 1% or 1 pF, whichever is greater X7R: ± 15% D.F: meet initial specified value IR meet initial specified value 4. Recovery time: Class1: 6 to 24 hours Class2: 24 ± 2 hours 5. Final measure: C, D, IR ESD AEC-Q200 17 Per AEC-Q200-002 A component passes a voltage level if all components stressed at that voltage level pass. Solderability AEC-Q200 18 Preheated to a temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. The solder should cover over 95% of the critical area of each termination. Test conditions for lead containing solder alloy Temperature: 235 ± 5 °C Dipping time: 2 ± 0.2 seconds Depth of immersion: 10 mm Alloy Composition: 60/40 Sn/Pb Number of immersions: 1 Test conditions for lead-free containing solder alloy Temperature: 245 ± 5 °C Dipping time: 3 ± 0.3 seconds Depth of immersion: 10 mm Alloy Composition: SAC305 Number of immersions: 1 www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Electrical Characterization Automotive grade NP0/X7R TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Parametrically test per lot and sample size requirements, summary to show Min, Max, Mean and Standard deviation at room as well as Min and Max operating temperatures. ∆C/C Class 1: NP0: -55 °C to +125 °C Normal temperature: 20 °C Class2: X7R: ± 15% 19 21 24 6.3 V to 630 V Class 1: NP0: ± 30 ppm/°C Class 2: X7R: -55 °C to +125 °C Normal temperature: 20 °C Board Flex AEC-Q200 21 Part mounted on a 100 mm X 40 mm FR4 PCB board, which is 1.6 ± 0.2 mm thick and has a layer-thickness 35 µm ± 10 µm. Part should be mounted using the following soldering reflow profile. Conditions: No visible damage ∆C/C Class1: NP0: Within ± 1% or 0.5 pF, whichever is greater Class2: X7R: ± 10% Class1: Bending 3 mm at a rate of 1 mm/s, radius jig 340 mm Class2: Bending 2 mm at a rate of 1 mm/s, radius jig 340 mm Test Substrate: b C 4.5 40 a 100 unit: mm Terminal Strength AEC-Q200 22 With the component mounted on a PCB obtained with the device to be tested, apply a 17.7N (1.8Kg) force to the side of a device being tested. This force shall be applied for 60+1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. * Apply 2N force for 0402 size. Dimension(mm) YNSC147 Type a b c 0201 0.3 0.9 0.3 0402 0.4 1.5 0.5 0603 1.0 3.0 1.2 0805 1.2 4.0 1.65 1206 2.2 5.0 1.65 1210 2.2 5.0 2.0 1808 3.5 7.0 3.7 Magnification of 20X or greater may be employed for inspection of the mechanical integrity of the device body, terminals and body/terminal junction. Before, during and after the test, the device shall comply with all electrical requirements stated in this specification. www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Beam Load Test Automotive grade NP0/X7R TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Place the part in the beam load fixture. Apply a force until the part breaks or the minimum acceptable force level required in the user specification(s) is attained. ≤ 0805 23 22 6.3 V to 630 V 24 Thickness > 0.5mm: 20N Thickness ≤ 0.5mm: 8N ≥ 1206 Thickness ≥1.25 mm: 54N Thickness < 1.25 mm: 15N Voltage Proof 1. Specified stress voltage applied for 1~5 seconds No breakdown or flashover 2. Ur ≤ 100 V: series applied 2.5 Ur 3. 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 4. 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) 5. Ur > 500 V: 1.3 Ur 6. Ur ≥ 1000 V: 1.2 Ur Charge/Discharge current is less than 50 mA Note: Classify the components according to the highest ESD voltage level survived during ESD testing. Fig. 5 Passive component HBM ESD test flow diagram (DC = Direct Contact Discharge, AD = Air Discharge) www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 23 24 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 11 Jun. 29, 2018 - DESCRIPTION - Add 0201 NPO 25V/ 50V, 0.2pF to 33pF, Add 0402 NPO 50V 270pF to 1nF, Add 0805 X7R 25V 2.2uF Version 10 May. 2, 2018 - - Add 0603 NPO 100V 820pF to 1nF, - Add 0805 NPO 50V to 100V, 1.2nF to 10nF, - Add 0805 X7R 16V 2.2uF, 50V 680nF to 1uF, - Add 1206 X7R 100V 330nF to 2.2uF, 250V 33nF to 100nF Version 9 Mar. 22, 2018 - - Add 0402 X7R 100nF 25~50V Version 8 Nov. 22, 2017 - - Add X7R/0201/25V/100pF~10nF Version 7 Jul. 7, 2017 - - Add X7R/0805/330nF to 470nF/50V, X7R/1206/10uF/6.3V Version 6 Mar. 31, 2017 - - Add NPO/0603/1nF/50V, X7R/0603/1uF/10V, X7R/0603/470nF/16V, X7R/0603/220nF/25V Version 5 Nov. 15, 2016 - - Add Soldering Condition Version 4 Jun. 14, 2016 - - Add X7R/0805/2.2uF/10V and NPO/1206/1.2nF to 1.5nF/250V Version 3 Jul. 21, 2015 - - Tests and Requirements update Version 2 Jul. 17, 2014 - - Tests and Requirements update Version 1 Apr. 19, 2013 - - Capacitance range update Version 0 Dec. 25, 2012 - - New www.yageo.com Dec. 30, 2019 V.12 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NP0/X7R 6.3 V to 630 V 24 24 LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a ge neric nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life -saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above -mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Dec. 30, 2019 V.12
AC1206JRNPOBBN220
物料型号: - 该文档描述的是YAGEO品牌的汽车级表面贴装多层陶瓷电容器,型号包括NP0和X7R系列。
器件简介: - 这些电容器是用于汽车设备的,具有无铅端子和符合RoHS标准的卤素自由环氧树脂。
引脚分配: - 文档中没有提供具体的引脚分配图,但提到了电容器由金属电极和陶瓷介质组成,内电极连接到两端子,并且端子覆盖有镀锡层。
参数特性: - 电容器的额定电压范围从6.3V至630V。 - 电容值范围从0.2pF至2.2µF。 - 容差、温度系数和介质材料(NP0或X7R)是电容器的关键参数。
功能详解: - 电容器符合AEC-Q200标准,具有高可靠性和高组件及设备可靠性。 - 它们适用于各种汽车应用,包括娱乐、舒适/安全和信息应用。
应用信息: - 电容器适用于所有通用应用,包括但不限于娱乐应用、舒适/安全应用和信息应用。
封装信息: - 提供了多种尺寸的封装,包括0201、0402、0603、0805、1206、1210等,每种封装都有详细的尺寸和厚度规格。
AC1206JRNPOBBN220 价格&库存
很抱歉,暂时无法提供与“AC1206JRNPOBBN220”相匹配的价格&库存,您可以联系我们找货
AC1206JRNPOBBN220
    • 20+0.21410
    • 200+0.17277
    • 600+0.14981
    库存:3707
    AC1206JRNPOBBN220
      • 1+0.97680
      • 100+0.55000
      • 1000+0.35480
      • 2000+0.23870
      • 4000+0.17520
      库存:20
      AC1206JRNPOBBN220
      • 4000+0.618524000+0.07461
      库存:15953
      AC1206JRNPOBBN220
      • 1+2.556311+0.30836
      • 10+1.6720010+0.20169
      • 50+1.2301550+0.14839
      • 100+1.00154100+0.12082
      • 500+0.79051500+0.09536
      • 1000+0.667491000+0.08052
      库存:15953
