AA2512JK-077K5L
AA2512JK-077K5L
    YAGEO(国巨)
    贴片电阻 2512 7.5KΩ ±5% 1W ±150ppm/℃
AA2512JK-077K5L 数据手册
DATA SHEET ANTI-SULFURATED CHIP RESISTORS AUTOMOTIVE GRADE AA series ±5%, ±1%, ±0.5% sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – December 08, 2015 V.3 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount SCOPE This specification describes AA0201 to AA2512 chip resistors with leadfree terminations made by thick film process. AA 10 0201 to 2512 SERIES ORDERING INFORMATION - GLOBAL PART NUMBER Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER AA XXXX X X X XX XXXX L APPLICATIONS  Car electronics  Engine control unit  Body control system  Safety devices FEATURES  Superior resistance against sulfur containing atmosphere  AEC-Q200 qualified  Moisture sensitivity level: MSL1  AA series soldering is compliant with J-STD-020D  Halogen free epoxy  RoHS compliant  Reduce environmentally hazardous waste  High component and equipment reliability  The resistors are 100% performed by automatic optical inspection (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D =± 0.5% F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper/PE taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE 1Ω to 10 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω 976R = 976 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω XXMX (10 MΩ) ORDERING EXAMPLE The ordering code for an AA0402 chip resistor, value 100 KΩ with ±1% tolerance, supplied in 7-inch tape reel is: AA0402FR-07100KL NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 10M = 10,000,000 Ω www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 3 10 0201 to 2512 MARKING AA0201 / AA0402 No marking ynsc007 Fig. 1 AA0603 / AA0805 / AA1206 / AA1210 / AA2010 / AA2512 03 Fig. 2 YNSC001 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ AA0603 0 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AA0805 / AA1206 / AA1210 / AA2010 / AA2512 00 YNSC004 Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AA1218 YNSC099 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros YNSC103 Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AA series is the same as RC series. www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead-free glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. 4 10 0201 to 2512 SERIES OUTLINES marking layer overcoat protective glass resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode ceramic substrate YNSC088 Fig. 8 Chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AA0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AA0402 1.00 ± 0.05 0.50 ± 0.05 0.35 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AA0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AA0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AA1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.50 ± 0.20 0.57 ± 0.10 0.45 ± 0.20 0.50 ± 0.20 0.50 ± 0.20 AA1210 3.10 ± 0.10 2.60 ± 0.15 AA1218 3.10 ± 0.10 4.60 ± 0.10 0.57 ± 0.10 0.45 ± 0.20 AA2010 5.00 ± 0.10 2.50 ± 0.15 0.57 ± 0.10 0.55 ± 0.20 0.55 ± 0.20 AA2512 6.35 ± 0.10 3.20 ± 0.15 0.57 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 For dimension, please refer to Table 1 AA0201 / AA0402 AA1218 AA0603/0805/1206/ 1210/2010/2512 I1 Side view for all type I1 I1 W W H W I2 Fig. 9 Chip resistor dimensions L L L YNSC096 www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 5 10 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS Operating Max. Max. Dielectric RESISTANCE RANGE Temperature Range Working Overload Withstanding Voltage Voltage Voltage TYPE AA0201 25V AA0402 AA0603 AA0805 5% (E24) 1Ω≤ R ≤ 22MΩ (0201: Max. 10MΩ. 1218: Max. 1MΩ) 0.5%, 1% (E24/E96) 1Ω≤ R ≤10MΩ (1218: Max. 1MΩ) Jumper < 50mΩ 50V 50V 50 V 100 V 100 V 75V 150 V 150 V 150 V 300 V 300 V 200 V 400 V 500 V AA1210 200 V 500 V AA1218 200 V 500 V AA2010 200 V 500 V AA1206 AA2512 –55 °C to +155 °C 200 V 500 V Temperature Coefficient of Resistance Jumper Criteria 1Ω ≤ R ≤ 10Ω, Rated Current 0.5A -100/+400 ppm/°C 10Ω < R ≤ 10 MΩ, ± 300 ppm/°C Max. Current 1.0A Rated Current 1A Max. Current 2A Rated Current 1A Max. Current 2A Rated Current 2A Max. Current 5A 1Ω ≤ R ≤ 10Ω, ± 200 ppm/°C Rated Current 2A 10Ω < R ≤ 10 MΩ, Max. Current 10A ± 150 ppm/°C Rated Current 2A 500 V 10 MΩ < R ≤ 22 MΩ, Max. Current 10A ± 200 ppm/°C Rated Current 6A 500 V Max. Current 10A 500 V 500 V Rated Current 2A Max. Current 10A Rated Current 2A Max. Current 10A www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 6 10 0201 to 2512 FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles. Please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE Paper/PE taping reel (R) REEL AA0201 AA0402 DIMENSION AA0603 AA0805 AA1206 AA1210 AA1218 AA2010 AA2512 7" (178 mm) 10,000 10,000 5,000 5,000 5,000 5,000 --- --- --- 13" (330 mm) 50,000 50,000 20,000 20,000 20,000 20,000 --- --- --- Embossed taping 7" (178 mm) reel (K) RESISTANCE --- --- --- --- --- --- 4,000 4,000 4,000 NOTE RANGE TEMPERATURE COEFFICIENT OF RESISTANCE PT040 100 specifications/dimensions, mΩ to 910 mΩ 1. For paper/PE/embossed tape and reel please refer to data sheet “Chip resistors packing”. 2 ± 200 ppm/°C PT060 ± 200 ppm/°C 3 FUNCTIONAL DESCRIPTION PT080 ± 200 ppm/°C O 5 PERATING TEMPERATURE RANGE 100 MΩ TO 910 MΩ Range: PT120 -55°C to +155°C 100 mΩ 6POWER RATING PT201 Each type rated power at 70°C: ± 100 ppm/°C 0AA0201=1/20W (0.05W) AA0402=1/16 W (0.0625W) PT251 ± 100 ppm/°C 2AA0603=1/10 W (0.1W) AA0805=1/8 W (0.125W) AA1206=1/4 W (0.25W) AA1210=1/2 W (0.5W) AA1218=1 W AA2010=3/4 W (0.75W) AA2512=1 W MLB206_2 P (%Prated) 100 > 100 mΩ ± 75 ppm/°C 50 ± 75 ppm/°C 0 55 0 50 70 100 155 o Tamb ( C) Fig. 10 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb ) RATED VOLTAGE The DC or AA (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) Or Maximum working voltage whichever is less Where V = Continuous rated DC or AA (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 7 10 0201 to 2512 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE High Temperature Exposure AEC-Q200 Test 3 Moisture Resistance AEC-Q200 Test 6 1,000 hours at TA = 155 °C, unpowered MIL-STD-202 Method 108 MIL-STD-202 Method 106 REQUIREMENTS ± (1.0%+0.05Ω)
AA2512JK-077K5L AI解析
1. 物料型号:文档描述了YAGEO的AA系列贴片电阻,尺寸从0201到2512不等。
2. 器件简介:这些电阻采用无铅端子制造,符合RoHS标准,无卤素,具有优越的抗含硫气氛性能,并且通过了AEC-Q200认证。
3. 引脚分配:文档中没有明确指出具体的引脚分配,但提到了电阻器的构造,包括陶瓷基底、内部金属电极、电阻性釉料、覆盖玻璃和保护层。
4. 参数特性: - 工作温度范围:-55°C 至 +155°C - 最大电压、电压系数、电阻温度系数等根据不同尺寸有不同规格 - 额定功率和最大电流承载能力随电阻尺寸而变化
5. 功能详解:电阻器通过调整釉料的组成来实现所需的电阻值,并通过激光修调来确保电阻值在公差范围内。
6. 应用信息:适用于汽车电子、发动机控制单元、车身控制系统和安全设备等。
7. 封装信息:提供了不同尺寸的详细尺寸信息,包括长度、宽度、高度以及标记层、覆盖层、保护玻璃、电阻层、内电极和端子等的构造细节。
*介绍内容由AI识别生成
AA2512JK-077K5L 价格&库存
很抱歉,暂时无法提供与“AA2512JK-077K5L”相匹配的价格&库存,您可以联系我们找货
