LRP12FTWSR010
LRP12FTWSR010
    VIKING(光颉)
    电阻器 10MΩ ±1% 2W ±75ppm/℃ 2512
LRP12FTWSR010 数据手册
Data Sheet Customer: Product: Low Ohm (Metal Strip) Chip Resistor – LRP Series Size: 1206 /2010/2512 Issued Date: 20-Jul-21 Edition: REV.B4 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 20-Jul-21 20-Jul-21 20-Jul-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor Low Ohm (Metal Strip) Chip Resistor- LRP Series ■Features -Low TCR down to ±25 PPM/°C -Customized resistance available -Low inductance < 5nH -AEC-Q200 Compliance -Sulfur resistance unaffected by sulfur environments -Lead-free and RoHS compliant ■Applications -NB (for Power Management) -MB (for Power Management) -SWPS (DC-DC Converter, Charger, Adaptor) -Monitor (for Power Management) ■Construction  Alloy Plate  Overcoat  Internal Electrode  Barrier Layer  Marking  Solder Plating ■Dimensions Type Size (Inch) L (mm) W (mm) T (mm) D (mm) Weight (g) (1000pcs) LRP06 1206 3.15±0.10 1.45±0.10 0.55±0.10 0.55±0.15 10.5 LRP10 2010 5.00±0.15 2.40±0.15 0.55±0.15 0.80±0.20 40 LRP12 2512 6.40±0.25 3.20±0.25 0.70±0.20 0.90±0.30 52.6 ■Part Numbering LRP Product Type 12 Dimensions (L×W) 06: 1206 10: 2010 12: 2512 www.viking.com.tw F T D Resistance Tolerance D: ±0.5% F: ±1% J: ±5% Packaging Code TCR (PPM/°C) T: Taping Reel C: ±25 D: ±50 W: ±75 E: ±100 S Power Rating R: 3W S: 2W T: 1W For detail questions, contact : sales@viking.com.tw 1 R015 Resistance R015: 0.015Ω R050: 0.05Ω Edition : REV.B4 Revision: 20-Jul-2021 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor ■Derating Curve ■Electrical Specifications Item Type LRP06 (1206) Power Rating at 70°C ±0.5% 1W LRP10 (2010) ±1% TCR (PPM/°C) ±5% 8, 10, 12, 15, 20, 25, 30, 33, 40 ±50 3, 4, 5, 7, 8, 10, 12, 15, 20, 25, 30, 33, 40 ±75 ±100 -55 ~ +170C 10、15、20、30、50、68、75、100 1W ±75 -55 ~ +170°C 2W LRP12 (2512) Resistance Range (mΩ) Operating Temp. Range 2W, 3W 10、15、20、30、50、68、75 3, 4, 5, 6, 7, 18, 20, 22, 25, 30, 33, 35, 39, 40, 47, 50, 60, 68, 70, 75, 80, 82, 90, 91, 100, 120, 150, 180, 200 ±25 3, 4, 5, 6, 7, 8, 9, 10, 12, 15, 18, 20, 22, 25, 30, 33, 35, 39, 40, 47, 50, 60, 68, 70, 75, 80, 82, 90, 91, 100, 120, 150, 180, 200 ±50 ±75 -55 ~ +170C Operating Current =√(P/R) , Operationg Voltage=√(P*R) ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. ■ Soldering Condition IR Reflow Soldering (1) Time of IR reflow soldering at maximum temperature point 260C:10s www.viking.com.tw For detail questions, contact : sales@viking.com.tw 2 Edition : REV.B4 Revision: 20-Jul-2021 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor ■Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. IEC60115-1 4.8 JIS-C-5201-1 4.8 +25C ~125C, 25C is the reference temperature Short Time Overload 1.0% IEC60115-1 4.13 JIS-C-5201-1 4.13 5*rated power for 5 seconds Insulation Resistance 10G IEC60115-1 4.6 JIS-C-5201-1 4.13 100V DC for 1 minute Endurance 1.0% IEC60115-1 4.25 JIS-C-5201-1 4.25.1 702C, rated power for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” Biased Humidity 1.0% Dry Heat 1.0% IEC60115-1 4.23.2 JIS-C-5201-1 4.23.2 at +170C for 1000 hrs Bending Strength 1.0% JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending width 2mm once for 60 seconds Solderability 95% min. coverage JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds Resistance to Soldering Heat 0.5% JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds Rapid Change of Temperature 1.0% MIL-STD-202 Method 103 1000 hrs 85C/85%RH 10% of operating power JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles Low Temperature Storage IEC60115-1 4.23.4 JIS-C-5201-1 4.23.4 at -55C for 2 hrs 1.0% RCWV(Rated Continuous Working Voltage)= √(P*R) or Max. Operating Voltage whichever is lower. ■Storage Temperature: 15~28C; Humidity < 80%RH www.viking.com.tw For detail questions, contact : sales@viking.com.tw 3 Edition : REV.B4 Revision: 20-Jul-2021 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor ■Packaging Reel Specifications & Packaging Quantity Type Resistance (mΩ) LRP06 3~40 Paper LRP10 10 - 100 LRP12 LRP12 Tape Width Reel Diameter ΦA (mm) 5K 8mm 7 inch 178.5±1.5 Embossed 4K 12mm 7 inch 4~200 Embossed 4K 12mm 3 Embossed 2K 12mm Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) +1/-0 13.0±0.2 9.0±0.5 12.5±0.5 178.5+/-1.5 60±1.0 13.0±0.5 13.0±1.0 15.5±0.5 7 inch 178.5+/-1.5 60±1.0 13.0±0.5 13.0±1.0 15.5±0.5 7 inch 178.5+/-1.5 60±1.0 13.0±0.5 13.0±1.0 15.5±0.5 60 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape Type A (mm) B (mm) LRP10 2.80±0.10 5.40±0.20 LRP12 3.50±0.10 LRP12 (3mΩ) 3.50±0.10 W (mm) E (mm) P2 (mm) ΦD0 (mm) F (mm) P0 (mm) P1 (mm) T (mm) 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.20+0 6.70±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.20+0 6.70±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.45±0.2 Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F W B T Paper Tape Resistor P1 P2 P0 Direction of unreeling Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) LRP06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 www.viking.com.tw For detail questions, contact : sales@viking.com.tw 4 P2 (mm) ΦD0 (mm) T (mm) 2.00±0.05 1.50+0.1,-0 0.85±0.10 Edition : REV.B4 Revision: 20-Jul-2021 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor ■Recommend Land Pattern C B Type A (mm) B (mm) C (mm) LRP06 1.50 1.40 1.70 LRP10 3.60 1.40 2.50 LRP12 4.00 2.00 3.50 A www.viking.com.tw For detail questions, contact : sales@viking.com.tw 5 Edition : REV.B4 Revision: 20-Jul-2021 【LRP Series】 Low Ohm (Metal Strip) Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version A Apr 30, 2015 - - First issue of this specification Version A1 Jul 30, 2015 - - Add 0.5% Resistance Range Version A2 Nov 27, 2015 - - Change TCR75 ppm Resistance Range 10mR~100mR 7mR~100mR Version A3 Jul 15, 2016 - - Remove Material Description - Modify Storage Temperature Version A4 Jun 01, 2017 - - Add 1206 Size Resistance Range - Add 2512 Size R003~R006 TCR75ppm Version A5 Nov 02, 2017 - Version A6 Jan 12, 2018 - - Environmental Characteristics update - Electrical Specifications update Version A7 Aug 03, 2018 - - Electrical Specifications update Version A8 Oct 21, 2019 - - Features: Add sulfur resistance instructions Version A9 Mar 23, 2020 - - Increase product weight Version B Jul 06, 2020 - - Features Increase Low inductance < 5nH Version B1 Nov 30, 2020 - - Increase the resistance range of LRP06 - LRP12 add TCR: 25ppm & 50ppm specification Version B2 Mar 10, 2021 - - Features: Add Lead-free and RoHS compliant Version B3 Jun 09, 2021 - - Modify LRP06 Dimensions Version B4 Jul 20, 2021 - - Increase the resistance range of LRP10 www.viking.com.tw DESCRIPTION - Features Item Add AEC-Q200 Compliance (LRP12 7mΩ to 100mΩ) For detail questions, contact : sales@viking.com.tw 6 Edition : REV.B4 Revision: 20-Jul-2021
LRP12FTWSR010
PDF文档中包含以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入端,引脚2为反相输入端,引脚3为输出端,其他引脚包括电源和地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以用于信号放大、滤波器设计、信号整形等。
6. 应用信息:适用于音频放大、传感器信号处理、医疗设备等。
7. 封装信息:提供多种封装形式,如DIP、SOIC等。
LRP12FTWSR010 价格&库存
很抱歉,暂时无法提供与“LRP12FTWSR010”相匹配的价格&库存,您可以联系我们找货
