MULTILAYER CERAMIC CHIP CAPACITORS
NTS
Series
(General product)
/ NTF
RoHS2
Compliant
Series
Temperature cycle : 1000 cycles
◆FEATURES
1. Large capacitance by small size.
2. X7R and X7S temperature characteristics.
3. High permissible ripple current capability.
4. NTF: Temperature cycle : 1000 cycles.
◆APPLICATIONS
1. Smoothing circuit of DC-DC converters.
2. On-board power supplies.
3. Voltage regulators for computers.
3. Noise suppressor for various kinds of equipments.
4. High reliability equipments.
◆CONSTRUCTION
Ceramic Dielectric
Termination
(Tin Plating)
Internal Electrode
◆RATINGS
1.
2.
3.
4.
5.
6.
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Rated Capacitance Tolerance
Temperature Characteristics
Rated Ripple Current
-55 to +125℃
25, 35, 50, 100, 250, 500Vdc
0.010 to 47µF
M (±20%) : Standard, K (±10%)
X7R
See No.5 on the following table
◆SPECIFICATIONS
No.
1
Items
Withstand Voltage
Specification
No abnormality.
Test Condition
Rated voltage
Withstand voltage
Less than 250V
250% of rated voltage
More than 250V
Less than 500V
100V +
150% of rated voltage
130% of rated voltage
More than 500V
Shall be applied for 5 seconds.
2
Insulation Resistance
100/CR(MΩ) or 4000(MΩ)
whichever is less.
3
Rated Capacitance
Within specified tolerance.
Rated voltage shall be applied for 60±5 seconds at
temperature 25±2℃.
CR>10µF
CR≦10µF
Temperature
4
5
Dissipation Factor
25±2℃
X7R temperature characteristics
of 5.0% or less
of 7.5% or less
Frequency
1±0.1kHz
120±12Hz
Voltage
1±0.2Vrms
0.5±0.2Vrms
See STANDARD RATINGS
10kHz~1MHz (sine curve)
Ripple voltage Vp shall be less than
the rated voltage.
As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic
capacitors. Please contact us for more information.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
13
CAT. No. E1002Z Ver.2
NTS
Series
/ NTF
Series
◆SPECIFICATIONS
No.
6
Items
Adhesion
Specification
Test Condition
No visible damage.
Substrate
5N (0.51kgf)
for 10±1 seconds
Capacitor
7
Bend strength of the face plating Appearance : No visible damage.
ΔC/C : ±15%
The substrate shall be bend at a rate of 1mm/s
for 5 seconds.
Press
Press bar
Capacitor
Substrate
Bending capability*
45±2mm
45±2mm
Support
*Bending capability
NTS : 1mm
NTF : 1mm or 2mm
8
Solderability
Min. 75% of surface of the termination
shall be covered with new solder
9
Resistance to Soldering Heat
ΔC/C : ±15%
D.F. : To meet the initial specification.
I.R. : To meet the initial specification.
Solder
Solder Temperature
Dipping Time
Pb Free
245±5℃
2±0.5sec.
Preheating Condition :
Step
1
2
Temperature
100±10℃
200±10℃
Time
2min.
2min.
Solder Temperature : 260±5℃
Dipping Time
: 2±0.5 seconds
10
Temperature Cycle
ΔC/C : ±15%
Step
1
2
3
4
Temperature (℃)
Min. Category temperature ±3
Room temperature
Max. Category temperature ±3
Room temperature
(min.)
30±3
3 max.
30±3
3 max.
For above temperature cycle.
NTS : For 5 cycles
NTF : For 1000 cycles
11
Humidity Load Life
Appearance : No abnormality.
ΔC/C : ±15%
I.R. : 25/CR(MΩ) or 1000(MΩ)
whichever is less.
Dissipation Factor
D.F: 10% or less
D.F: 15% or less
Temperature : 40±2℃
Humidity
: 90 to 95%RH
Voltage
: Rated voltage
Time
: 500±24
0 hours
12
Endurance
ΔC/C : ±15%
I.R. : 50/CR(MΩ) or 1000(MΩ)
whichever is less.
Dissipation Factor
D.F: 10% or less
D.F: 15% or less
Temperature : 125±3℃
Voltage
: Rated voltage
Time
: 1000±48
0 hours
*CR : Rated Capacitance(µF)
14
NTS
Series
◆STANDARD RATINGS
Rated voltage Rated Capacitance
(μF)
(Vdc)
25
35
50
100
1.0
1.5
2.2
3.3
3.3
4.7
6.8
10
10
15
22
22
33
47
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
0.33
0.47
0.68
1.0
1.5
2.2
1.5
2.2
3.3
4.7
4.7
6.8
10
10
15
22
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
1.0
1.5
2.2
3.3
1.5
2.2
3.3
4.7
6.8
3.3
4.7
6.8
10
6.8
Electrostatic
Capacitance
Temperature
Characteristics
X7R
X7R
X7R
X7S
X7R
X7R
X7R
X7S
X7R
X7R
X7S
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
L
W
T max.
a
Maximum ripple
current
(Arms)
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
0.8±0.5
2.0
7.5±0.5
6.3±0.5
2.8
3.0
4.0
1.0±0.5
3.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
2.8
0.8±0.5
2.0
7.5±0.5
6.3±0.5
4.0
1.0±0.5
3.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
2.8
0.8±0.5
2.0
7.5±0.5
6.3±0.5
4.0
1.0±0.5
3.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
0.6±0.3
1.0
0.6±0.3
1.0
Dimensions(mm)
3.2±0.4
4.5±0.4
3.2±0.5
3.2±0.4
5.7±0.4
7.5±0.5
5.0±0.4
6.3±0.5
2.8
3.2
2.8
2.8
0.8±0.5
3.2
2.8
3.5
1.0±0.4
1.0±0.5
2.0
3.0
※Please consult with us when you consider the rating other than a standard table.
Part Number
Taping
Quantity per reel
(pcs. / reel)
KTS250B105M31N0T00
KTS250B155M31N0T00
KTS250B225M31N0T00
KTS250S335M31N0T00
KTS250B335M32N0T00
KTS250B475M32N0T00
KTS250B685M32N0T00
KTS250S106M32N0T00
KTS250B106M43N0T00
KTS250B156M43N0T00
KTS250S226M43N0T00
KTS250B226M55N0T00
KTS250B336M55N0T00
KTS250B476M76N0T00
KTS350B105M31N0T00
KTS350B155M31N0T00
KTS350B225M31N0T00
KTS350B335M32N0T00
KTS350B475M32N0T00
KTS350B685M43N0T00
KTS350B106M43N0T00
KTS350B156M55N0T00
KTS350B226M55N0T00
KTS350B336M76N0T00
KTS350B476M76N0T00
KTS500B334M31N0T00
KTS500B474M31N0T00
KTS500B684M31N0T00
KTS500B105M31N0T00
KTS500B155M31N0T00
KTS500B225M31N0T00
KTS500B155M32N0T00
KTS500B225M32N0T00
KTS500B335M32N0T00
KTS500B475M32N0T00
KTS500B475M43N0T00
KTS500B685M43N0T00
KTS500B106M43N0T00
KTS500B106M55N0T00
KTS500B156M55N0T00
KTS500B226M76N0T00
KTS101B104M31N0T00
KTS101B154M31N0T00
KTS101B224M31N0T00
KTS101B334M31N0T00
KTS101B474M31N0T00
KTS101B684M31N0T00
KTS101B105M31N0T00
KTS101B155M31N0T00
KTS101B225M31N0T00
KTS101B105M32N0T00
KTS101B155M32N0T00
KTS101B225M32N0T00
KTS101B335M32N0T00
KTS101B155M43N0T00
KTS101B225M43N0T00
KTS101B335M43J0T00
KTS101B475M43E0T00
KTS101B685M43N0T00
KTS101B335M55N0T00
KTS101B475M55N0T00
KTS101B685M55F0T00
KTS101B106M55NHT00
KTS101B685M76N0T00
3,000
3,000
3,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
300
3,000
3,000
3,000
1,600
1,600
800
800
800
800
300
300
3,000
3,000
3,000
3,000
2,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
300
3,000
3,000
3,000
3,000
3,000
3,000
2,000
2,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
800
800
800
800
300
15
NTS
Series
◆STANDARD RATINGS
0.01
0.022
0.033
0.047
0.068
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
1.5
2.2
0.47
0.56
0.68
1.0
1.2
250
500
Electrostatic
Capacitance
Temperature
Characteristics
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
Dimensions(mm)
L
W
Tmax.
a
Maximum ripple
current
(Arms)
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
2.8
0.8±0.5
2.0
1.0±0.5
3.0
0.8±0.5
1.5
1.0±0.5
2.0
7.5±0.5
6.3±0.5
5.7±0.4
5.0±0.4
7.5±0.5
6.3±0.5
3.5
5.0
2.7
3.0
2.5
3.2
3.5
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
KTS251B103M31N0T00
KTS251B223M31N0T00
KTS251B333M31N0T00
KTS251B473M31N0T00
KTS251B683M31N0T00
KTS251B104M31N0T00
KTS251B154M32N0T00
KTS251B224M32N0T00
KTS251B334M32N0T00
KTS251B474M43N0T00
KTS251B684M43N0T00
KTS251B105M55N0T00
KTS251B155M55N0T00
KTS251B155M76N0T00
KTS251B225M76N0T00
KTS501B474M55N0T00
KTS501B564M55N0T00
KTS501B684M76N0T00
KTS501B105M76N0T00
KTS501B125M76N0T00
3,000
3,000
3,000
3,000
3,000
3,000
1,600
1,600
1,600
800
800
800
800
300
300
800
800
500
300
300
◆DIMENSIONS
18
K TS 101 B 225 M 32 N0 T 00
Size Code
Supplement code
Taping code
Terminal code
Size code
Capacitance tolerance code
Nominal Capacitance code
Temperature characteristics code
Rated voltage code
Series code
Category
Size
Code
Code
JIS
T
◆PART NUMBERING SYSTEM
Taping
Quantity per reel
(pcs. / reel)
Part Number
3216
1206
43
4532
1812
32
55
76
3225
5750
7563
L
EIA
31
1210
2220
W
(Vdc)
(µF)
a
3025
Please refer to"Part Numbering System" of the beginning of a catalog for the details.
16
NTF
Series
◆STANDARD RATINGS
(μF)
(Vdc)
25
35
50
100
1.0
1.5
2.2
3.3
3.3
4.7
6.8
10
10
15
22
22
33
47
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
0.33
0.47
0.68
1.0
1.5
2.2
1.5
2.2
3.3
4.7
4.7
6.8
10
10
15
22
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
1.0
1.5
2.2
3.3
1.5
2.2
3.3
4.7
6.8
4.7
6.8
10
Electrostatic
Capacitance
Temperature
Characteristics
X7R
X7R
X7R
X7S
X7R
X7R
X7R
X7S
X7R
X7R
X7S
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
L
W
T max.
a
Maximum ripple
current
(Arms)
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
0.8±0.5
2.0
7.5±0.5
6.3±0.5
2.8
3.0
4.0
1.0±0.5
3.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
2.8
0.8±0.5
2.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
4.5±0.4
3.2±0.4
2.8
0.6±0.3
1.0
5.7±0.4
5.0±0.4
2.8
0.8±0.5
2.0
7.5±0.5
6.3±0.5
4.0
1.0±0.5
3.0
3.2±0.2
1.6±0.2
1.8
0.5±0.3
0.3
3.2±0.4
2.5±0.3
2.6
0.6±0.3
0.5
0.6±0.3
1.0
0.6±0.3
1.0
Dimensions(mm)
3.2±0.4
4.5±0.4
3.2±0.5
3.2±0.4
5.7±0.4
5.0±0.4
2.8
3.2
2.8
2.8
3.2
2.8
0.8±0.5
1.0±0.4
2.0
Part Number
Taping
Quantity per reel
(pcs. / reel)
KTF250B105M31NLT00
KTF250B155M31NLT00
KTF250B225M31NLT00
KTF250S335M31NLT00
KTF250B335M32NHT00
KTF250B475M32NHT00
KTF250B685M32NHT00
KTF250S106M32NHT00
KTF250B106M43NHT00
KTF250B156M43NHT00
KTF250S226M43NHT00
KTF250B226M55NHT00
KTF250B336M55NHT00
KTF250B476M76NHT00
KTF350B105M31NLT00
KTF350B155M31NLT00
KTF350B225M31NLT00
KTF350B335M32NHT00
KTF350B475M32NHT00
KTF350B685M43NHT00
KTF350B106M43NHT00
KTF350B156M55NHT00
KTF350B226M55NHT00
KTF500B334M31NLT00
KTF500B474M31NLT00
KTF500B684M31NLT00
KTF500B105M31NLT00
KTF500B155M31NLT00
KTF500B225M31NLT00
KTF500B155M32NHT00
KTF500B225M32NHT00
KTF500B335M32NHT00
KTF500B475M32NHT00
KTF500B475M43NHT00
KTS500B685M43NHT00
KTF500B106M43NHT00
KTF500B106M55NHT00
KTF500B156M55NHT00
KTF500B226M76NHT00
KTF101B104M31NLT00
KTF101B154M31NLT00
KTF101B224M31NLT00
KTF101B334M31NLT00
KTF101B474M31NLT00
KTF101B684M31NlT00
KTF101B105M31NLT00
KTF101B155M31NLT00
KTF101B225M31NLT00
KTF101B105M32NHT00
KTF101B155M32NHT00
KTF101B225M32NHT00
KTF101B335M32NHT00
KTF101B155M43NHT00
KTF101B225M43NHT00
KTF101B335M43JHT00
KTF101B475M43EHT00
KTF101B685M43NHT00
KTF101B475M55NHT00
KTF101B685M55FHT00
KTF101B106M55NHT00
3,000
3,000
3,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
300
3,000
3,000
3,000
1,600
1,600
800
800
800
800
3,000
3,000
3,000
3,000
2,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
300
3,000
3,000
3,000
3,000
3,000
3,000
2,000
2,000
2,000
1,600
1,600
1,600
1,600
800
800
800
800
800
800
800
800
17
3.3
4.7
6.8
10
15
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
Series
2.2
1.5
2.2 RATINGS
◆STANDARD
3.3
Electrostatic
Rated voltage Rated4.7
Capacitance Capacitance
4.7
Temperature
(Vdc)
(µF)
Characteristics
6.8
0.033
X7R
0.047
X7R
0.068
X7R
0.1
X7R
0.15
X7R
250
0.22
X7R
0.33
X7R
0.47
X7R
0.68
X7R
1.0
X7R
1.5
X7R
0.47
X7R
500
0.56
X7R
KTF500B335M32NHT00
KTF500B475M43NHT00
KTF500B685M43NHT00
KTF500B106M55NHT00
KTF500B156M55NHT00
KTF101B104M31NLT00
KTF101B154M31NLT00
KTF101B224M31NLT00
KTF101B334M31NLT00
KTF101B474M31NLT00
KTF101B684M31NLT00
KTF101B105M32NHT00
KTF101B155M32NHT00
KTF101B225M32NHT00
KTF101B155M43NHT00
KTF101B225M43NHT00
KTF101B335M43JHT00
KTF101B475M43EHT00
Part Number
KTF101B475M55NHT00
NTF
Tmax.
a
Maximum ripple
current
(Arms)
1.6±0.2
1.8
0.7±0.2
0.3
3.2±0.4
2.5±0.3
2.6
0.7±0.2
0.5
4.5±0.4
3.2±0.4
2.8
0.7±0.2
1.0
5.7±0.4
5.0±0.4
2.8
1.0±0.4
2.0
5.0±0.4
2.7
3.0
1.0±0.4
1.5
Dimensions(mm)
L
W
3.2±0.3
5.7±0.4
3.2
KTF101B685M55FHT00
KTF251B333M31NLT00
KTF251B473M31NLT00
KTF251B683M31NLT00
KTF251B104M31NLT00
KTF251B154M32NLT00
KTF251B224M32NLT00
KTF251B334M32NLT00
KTF251B474M43NLT00
KTF251B684M43NLT00
KTF251B105M55NLT00
KTF251B155M55NLT00
KTF501B474M55NLT00
KTF501B564M55NLT00
1,600
800
800
800
800
3,000
3,000
3,000
3,000
3,000
3,000
1,600
1,600
1,600
800
800
800
Taping
800
Quantity800
per reel
(pcs.800
/ reel)
3,000
3,000
3,000
3,000
1,600
1,600
1,600
800
800
800
800
800
800
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
◆DIMENSIONS
18
K T F 1 0 1 B 2 2 5 M 3 2 NH T 0 0
Size Code
Supplement code
Taping code
Terminal code (Bending NL:1mm, NH:2mm)
Size code
Rated voltage code
Series code
Category
Size
Code
Code
JIS
T
1
3216
1206
43
4532
1812
32
55
76
3225
5750
7563
L
EIA
31
1210
2220
W
a
3025
18
