RGH1608-2C-P-751-B
RGH1608-2C-P-751-B
    SUSUMU
    贴片电阻 0603 750Ω ±0.1% 1/6W ±25ppm/℃
RGH1608-2C-P-751-B 数据手册
RGH series,high-power and high-precision metal film chip resistors NEW Resistors with high power in small size are realized as 1/6W for 1.60.8mm(0603), 1/4W for 2.01.25mm(0805)size and 1/8W for 1.00.5mm(0402)size. Tight resistance tolerance of 0.1% and temperature coefficient of resistance of 25ppm/ C are achieved. Operating temperature range:55155C Completely lead free RoHS compliant SPECIFICATIONS L Mechanical W A T Dimension (Inch Size) RGH1005-2B (0402) RGH1608-2C (0603) NEW RGH2012-2E (0805) L W A B T 1.00.05 0.50.05 0.20.10 0.250.05 0.350.05 1.60.2 0.80.2 0.30.2 0.30.2 0.40.1 2.00.2 1.250.2 0.40.2 0.40.2 0.40.1 (unit:mm) B Electrical Type Power Tolerance % (code) Resistance range () TCR ppm /C(code) Max Operating Voltage Resistance value Operating Temp. Range Package RGH1005-2B RGH1608-2C NEW RGH2012-2E 1/8W 1/6W 1/4W 0.1%(B),0.5%(D) 0.5%(D),0.1%(B) 0.1%(B),0.5%(D) 47∼100k 47∼470k 47∼360k 25ppm/ C(P) 25ppm/ C(P) 25ppm/ C(P) 125V 75V 100V E-24,E-96 E-24,E-96 E-24,E-96 55155C 10,000pcs/reel 55155C 5,000pcs/reel 55155C 5,000pcs/reel • RGH1608 with 1/5W power consumption are available to meet your needs. PART NUMBER RGH 1005 - 2B - P - 102 - B Resistance Tolerance Resistance(E-24:in a 3 digit,E-96:in a 4 digit) Temperature coefficient of resistance Power(2B for 1/8W, 2C for 1/6W, 2E for 1/4W) Dimension Part Code susumu group catalog
RGH1608-2C-P-751-B
1. 物料型号:RGH系列,包括RGH1005-2B (0402)、RGH1608-2C (0603)、RGH2012-2E (0805)。 2. 器件简介:这些电阻具有高功率和小尺寸,例如1/6W的0603尺寸、1/4W的0805尺寸和1/8W的0402尺寸。 3. 引脚分配:文档中没有提供引脚分配信息,因为这些是表面贴装电阻,不是引脚元件。 4. 参数特性: - 电阻公差:0.1% (B) 和 0.5% (D) - 温度系数:±25ppm/°C (P) - 功率:1/8W、1/6W、1/4W - 电阻范围:47~100kΩ、47~360kΩ、47~470kΩ - 最大工作电压:75V、100V、125V - 电阻值:E-24和E-96系列 - 工作温度范围:-55~155°C 5. 功能详解:文档中没有提供详细的功能解释,但提到了电阻的高精度和高功率特性。 6. 应用信息:文档中没有明确提供应用信息,但根据电阻的特性,它们可能适用于需要高精度和高功率的应用。 7. 封装信息:电阻以卷带形式提供,每卷10000pcs、5000pcs或5000pcs。
RGH1608-2C-P-751-B 价格&库存
很抱歉,暂时无法提供与“RGH1608-2C-P-751-B”相匹配的价格&库存,您可以联系我们找货
