METAL CAP TYPE MULTILAYER CERAMIC CAPACITORS
NTJ
Series
RoHS
Compliant
◆FEATURES
1. Small size and large capacitance, high ripple current.
2. Temperature cycle: 1000 cycles.
3. X7R temperature characteristics.
4. Excellent noise absorption.
5. For reflow soldering use.
6. Suitable for aluminum substrate.
◆APPLICATIONS
1. Smoothing circuit of switching mode AC-DC or DC-DC converter.
2. On-board power supply.
3. Noise suppressor for various kinds of equipments.
◆CUSTOM MADE PRODUCTS
We can offer custom made one element metal cap type capacitors for request of customers.
Please contact us if you have questions for details.
◆CONSTRUCTION
Chip Ceramic Capacitor
Metal Cap, Tin plating
Pb-free Soldering
Termination
◆RATINGS
1.
2.
3.
4.
5.
6.
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Rated Capacitance Tolerance
Temperature Characteristics
Rated Ripple Current
-55∼+125℃
25, 50, 100, 250Vdc
1.0 to 100µF
M(±20%)
X7R
See No.5 on the following table
◆SPECIFICATIONS
No.
Items
Specification
Test Condition
1
Withstand Voltage
No abnormality.
2
Insulation Resistance
100/CR(MΩ) or 4000(MΩ) whichever
is less.
3
Rated Capacitance
Within specified tolerance.
250% of rated voltage shall be applied for 5 seconds.
(Only 250Vdc products : 475V)
Rated voltage shall be applied for 60±5 seconds at
temperature 25±2℃.
Temperature
4
5
Dissipation Factor
5.0% maximum
Size
Element
Arms
1
2.0
55
2
3.0
CR>10µF
CR≦10µF
1
3.0
76
2
4.0
25±2℃
Frequency
1±0.1kHz
120±12Hz
Voltage
1±0.2Vrms
0.5±0.2Vrms
10kHz∼1MHz (sine curve)
Ripple voltage Vp shall be less than
the rated voltage.
As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic
capacitors. Please contact us for more information.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1002V
NTJ
Series
◆SPECIFICATIONS
No.
6
Items
Specification
Appearance : No visible damage.
ΔC/C : ±15%
D.F. : To meet the initial specification.
I.R. : To meet the initial specification.
Temperature Cycle
Test Condition
Step
1
2
3
4
Temperature (℃)
Min. Category temperature ±3
Room temperature
Max. Category temperature ±3
Room temperature
1000 cycles
7
Humidity Load Life
Appearance : No abnormality.
ΔC/C : ±20%
D.F. : 10% max.
I.R. : 25/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 40±2℃
Humidity
: 90 to 95%RH
Voltage
: Rated voltage
Time
: 500±24
hours
Endurance
ΔC/C : ±20%
D.F. : 10% max.
I.R. : 50/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 125±3℃
Voltage
: Rated voltage
Time
: 1000±48
0 hours
(min.)
30±3
3 max.
30±3
3 max.
*CR : Rated Capacitance(µF)
◆Note of mountig for NTJ series.
1. The gap of capacitor and a substrate shall be the mounting face.
2. To prevent degredation of temperature cycling capability, if need to be careful about amount of solder that would not go into
the inner side of terminations.
Substrate
Gap
21
CAT. No. E1002V
NTJ
Series
◆STANDARD RATINGS
Dimensions(mm)
Rated voltage Rated Capacitance
(Vdc)
(µF)
33
33
47
47
68
100
15
15
22
22
33
47
4.7
6.8
10
6.8
15
1.0
1.5
2.2
2.2
3.3
25
50
100
250
Element
Maximum
ripple current
(Arms)
L
W
Tmax.
a
6.0±0.4
5.3±0.4
3.8
1.3±0.3
1
2.0
6.0±0.4
5.3±0.4
5.5
1.3±0.3
2
3.0
7.8±0.5
6.6±0.5
1
3.0
6.6±0.5
1.5±0.3
2
4.0
6.0±0.4
5.3±0.4
5.5
8.5
9.5
3.8
1.5±0.3
7.8±0.5
1.3±0.3
1
2.0
6.0±0.4
5.3±0.4
5.5
1.3±0.3
2
3.0
7.8±0.5
6.6±0.5
5.5
1.5±0.3
1
3.0
7.8±0.5
6.6±0.5
8.5
1.5±0.3
2
4.0
6.0±0.4
5.3±0.4
3.8
1.3±0.3
1
2.0
6.0±0.4
5.3±0.4
5.5
1.3±0.3
2
3.0
7.8±0.5
7.8±0.5
6.0±0.4
6.6±0.5
6.6±0.5
5.3±0.4
1.5±0.3
1.5±0.3
1.3±0.3
1
2
1
3.0
4.0
2.0
6.0±0.4
5.3±0.4
1.3±0.3
2
3.0
7.8±0.5
7.8±0.5
6.6±0.5
6.6±0.5
5.5
8.5
3.8
5.5
6.5
5.5
8.5
1.5±0.3
1.5±0.3
1
2
3.0
3.0
Part Number
KTJ250B336M55AFT00
KTJ250B336M55BFT00
KTJ250B476M55BFT00
KTJ250B476M76AFT00
KTJ250B686M76BFT00
KTJ250B107M76BFT00
KTJ500B156M55AFT00
KTJ500B156M55BFT00
KTJ500B226M55BFT00
KTJ500B226M76AFT00
KTJ500B336M76BFT00
KTJ500B476M76BFT00
KTJ101B475M55AFT00
KTJ101B685M55BFT00
KTJ101B106M55BFT00
KTJ101B685M76AFT00
KTJ101B156M76BFT00
KTJ251B105M55AFT00
KTJ251B155M55BFT00
KTJ251B225M55BFT00
KTJ251B225M76AFT00
KTJ251B335M76BFT00
Taping
Quantity per reel
(pcs. / reel)
400
2,000
2,000
1,200
500
400
400
2,000
2,000
1,200
500
500
400
2,000
2,000
1,200
500
400
2,000
2,000
1,200
500
※Please consult with us when you consider the rating other than a standard table.
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
◆DIMENSIONS
16
17
18
T
a
W
a
W
Supplement code
Taping code
Terminal code
Size code
Capacitance tolerance code
Nominal Capacitance code
Temperature characteristics code
Rated voltage code
Series code
Category
T
K T J 2 5 0 B 4 7 6 M 5 5 BF T 0 0
L
L
1 Element
2 Elements
Please refer to"Part Numbering System" of the beginning of a catalog for the details.
22
CAT. No. E1002V
很抱歉,暂时无法提供与“KTJ101B475M55AFT00”相匹配的价格&库存,您可以联系我们找货
