RG1005P-1621-B-T5
RG1005P-1621-B-T5
    SUSUMU
    贴片电阻 0402 1.62KΩ ±0.1% 1/16W ±25ppm/℃
RG1005P-1621-B-T5 数据手册
er put Com e il b o M TV MULTILAYER CERAMIC CAPACITORS MULTILAYER CERAMIC CAPACITORS Interactive User Guide Samsung Electro-Mechanics’ MLCC Catalog was produced as an INTERACTIVE PDF that allows transferring to related webpages for better understanding of the content. Click ‘HOME,’ ‘CONTENTS,’ OR ‘GO BACK TO PAGE’ as needed, and it is also possible to ‘PRINT’ the pages. If you click the icon at the top of the page, it is possible to view a specific page of choice. By clicking this icon, you can By clicking this icon, you can jump directly to the cover page of jump directly to the Table of this catalog. Contents. By clicking this icon, you can By clicking this icon, you can set jump directly to the previous page. and print pages of your choice. C O N T E N T S 04 Explanation of Ceramic Capacitors 06 Part Numbering 09 Reliability Level Description 10 Normal Capacitors_Standard 56 Normal Capacitors_High Level Ⅰ 70 Normal Capacitors_High Level Ⅱ 72 Embedded/LSC Capacitors 74 High Bending Strength Capacitors 80 Low Acoustic Noise Capacitors 84 Low ESL Capacitors 88 Array Type Capacitors 90 Application Guide 94 Reliability Test Conditions 100 Packaging Specifications 106 Caution/Notice 127 Disclaimer & Limitation of Use and Applications 128 Component sales offices/manufacturing sites Explanation of Ceramic Capacitors Part Numbering Reliability Level Description Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Embedded/LSC Capacitors Reliability Test Conditions Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide sites Explanation of Ceramic Capacitors Normal Capacitors Normal Capacitors Standard High Level Ⅰ High Level Ⅱ Improved Reliability Reinforced Reliability (65℃, 90%RH, 1Vr, 500H) (85℃, 85%RH, 1Vr, 1000H) Embedded/LSC Capacitors Lower thickness and space saving Embedded/LSC High Bending Strength Capacitors More Resistant to stress caused by board bending High-bending Strength MULTILAYER CERAMIC CAPACITORS 04 Explanation of Ceramic Capacitors Part Numbering Reliability Level Description Normal Capacitors_Standard Embedded/LSC Capacitors Reliability Test Conditions Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Explanation of Ceramic Capacitors Low Acoustic Noise Capacitors A solution that effectively reduces audible noise Low Acoustic Noise Low ESL Capacitors Space Saving & High Speed Energy Transfer Low ESL Array Type Capacitors Reduces mounting cost and ripple voltage Array MULTILAYER CERAMIC CAPACITORS 05 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Part Numbering Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ CL 10 1 1 A 106 M 2 3 4 5 Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Part Numbering Packaging Specifications Component sales offices/manufacturing ‌ Application Guide Q 8 6 7 sites N N 8 N 9 C 10 11 SERIES CODE CL = Multilayer Ceramic Capacitors 2 3 SIZE CODE Code mm (inch) Code mm (inch) Code mm (inch) 02 0402 (01005) 21 2012 (0805) 42 4520 (1808) 03 0603 (0201) 31 3216 (1206) 43 4532 (1812) 05 1005 (0402) 32 3225 (1210) 55 5750 (2220) 10 1608 (0603) DIELECTRIC CODE Class Ⅰ (Temperature Compensation) Symbol EIA Code Operation Temperature Range (℃) Temperature Coefficient Range (ppm/℃) C C0G -55 ~ +125 0 ± 30 Class Ⅱ (High Dielectric Constant) 4 5 Symbol EIA Code Operation Temperature Range (℃) Capacitance Change (ΔC %) A X5R -55 ~ +85 ±15 B X7R -55 ~ +125 ±15 X X6S -55 ~ +105 ±22 -82 ~ +22 F Y5V -30 ~ +85 Y X7S -55 ~ +125 ±22 Z X7T -55 ~ +125 -33 ~ +22 CAPACITANCE CODE Capacitance expressed in ㎊. 2 significant digits plus number of zeros. For Values <10㎊, Letter R denotes decimal point example) 106=10×106=10,000,000㎊ example) 1R5 =1.5㎊ CAPACITANCE TOLERANCE CODE Code Tolerance Code Tolerance Code Tolerance Code N ±0.03㎊ H +0.25㎊ F ±1% V Tolerance -5% A ±0.05㎊ L -0.25㎊ G ±2% K ±10% B ±0.1㎊ D ±0.5㎊ J ±5% M ±20% C ±0.25㎊ F* ±1㎊ U +5% Z -20, +80% *For Values<10pF, F=±1pF / Values≥10pF, F=±1% MULTILAYER CERAMIC CAPACITORS 06 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Part Numbering Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Part Numbering Series Nominal Capcitance E-3 1.0 E-6 E-12 E-24 6 7 2.2 1.0 1.5 4.7 2.2 3.3 4.7 6.8 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 1.1 1.3 1.6 2.0 2.4 3.0 3.6 4.3 5.1 6.2 7.5 9.1 RATED VOLTAGE CODE Code Voltage Code Voltage Code Voltage Code Voltage S 2.5Vdc O 16Vdc C 100Vdc H 630Vdc R 4.0Vdc A 25Vdc D 200Vdc I 1kVdc Q 6.3Vdc L 35Vdc E 250Vdc J 2kVdc P 10Vdc B 50Vdc G 500Vdc K 3kVdc THICKNESS CODE Size mm (inch) Code Thickness Tolerance Code Thickness Tolerance 0402 (01005) 2 0.20 ±0.02 C 0.85 ±0.10* 0603 (0201) 3 0.30 ±0.03 9 0.90 ±0.10* 3 0.30 ±0.03* F 1.25 ±0.20 5 0.50 ±0.05 ±0.15* 5 0.50 +0.0/-0.1* 8 0.80 ±0.10 A 0.65 C 0.85 C 0.85 M 1005 (0402) 1608 (0603) 2012 (0805) 3216 (1206) Size mm (inch) S 1.35 H 1.60 ±0.20 U 1.80 ±0.20* ±0.10 I 2.00 ±0.20 ±0.10* J 2.50 ±0.20 ±0.10 V 2.50 ±0.30 1.15 ±0.10 F 1.25 ±0.20 F 1.25 ±0.10 G 1.40 ±0.20 Q 1.25 ±0.15 I 2.00 ±0.20 Y 1.25 ±0.20 F 1.25 ±0.20 C 0.85 ±0.15 H 1.60 ±0.20 C 0.85 ±0.10* I 2.00 ±0.20 E 1.10 ±0.15 J 2.50 ±0.20 E 1.10 ±0.10* L 3.20 ±0.30 P 1.15 ±0.10* H 1.60 ±0.20 M 1.15 ±0.15 F 1.25 ±0.15 H 1.6 ±0.20 3225 (1210) 4520 (1808) 4532 (1812) 5750 (2220) I 2.00 ±0.20 J 2.50 ±0.20 L 3.20 ±0.30 * Mark is only applicable to “L”,”Y”,”F”, 12th code in part number. MULTILAYER CERAMIC CAPACITORS 07 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Part Numbering Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Part Numbering 8 9 INNER ELECTRODE/TERMINATION/PLATING CODE Code Thickness division Inner electrode Termination Plating material N Normal Ni Cu Ni / Sn _100% G Normal Cu Cu Ni / Sn _100% S Normal Ni Metal Epoxy Ni / Sn _100% C Normal Ni Control Code Ni / Sn _100% L Low profile Ni Cu Ni / Sn _100% Y Low profile Ni Metal Epoxy Ni / Sn _100% Z Normal Ni Metal Epoxy Ni / Sn _100% F Low profile Ni Metal Epoxy Ni / Sn _100% PRODUCT CODE OR SIZE CONTROL CODE N=Normal A=Array (2-element) B=Array (4-element) L=LICC (Low Inductance Ceramic Capacitor) J=SLIC (Super Low Inductance Capacitor) (Unit : mm (inch)) Size 0402 (01005) 0603 (0201) 1005 (0402) 1608 (0603) S ±0.03 ±0.05 ±0.07 ±0.07 Q ±0.05 ±0.07 ±0.10 ±0.15 ±0.15 R ±0.07 ±0.09 ±0.15 ±0.20 ±0.20 U ±0.09 ±0.20 ±0.25 ±0.25 Z ±0.40 ±0.30 ±0.30 9 ±0.30 Code 10 2012 (0805) 3216 (1206) ±0.30 CONTROL CODE N= Reserved for future use 11 PACKAGING CODE Cardboard Tape (paper) Embossed Tape (plastic) Code Taping Type Code Taping Type 8/C/H Normal, 7"reel (Quantity option) E/G Normal, 7"reel (Quantity option) J 1mm Pitch, 7"reel R Chip aligned for horizontal, 7"reel Z Chip aligned for horizontal, 7"reel W Chip aligned for vertical, 7"reel Y Chip aligned for vertical, 7"reel S Normal, 10"reel O Normal, 10"reel F Normal, 13"reel (Quantity option) 3/D/L Normal, 13"reel (Quantity option) 2 1mm Pitch, 13"reel 7 Chip aligned for vertical, 13"reel MULTILAYER CERAMIC CAPACITORS 08 Explanation of Ceramic Capacitors Part Numbering Reliability Level Description Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Embedded/LSC Capacitors Reliability Test Conditions Low Acoustic Noise Capacitors Caution/Notice High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide sites Reliability Level Description Reliability Level Standard High Level Ⅰ High Level Ⅱ AEC-Q200 Humidity Test 40℃, 95%RH, 1Vr, 500h 65℃, 90%RH, 1Vr, 500h 85℃, 85%RH, 1Vr, 1000h 85℃, 85%RH, 1.3~1.5Vr, 1000h High Temp Load Test Max. Temp, 1.5Vr, 1000h Max. Temp, 1.5Vr, 1000h Max. Temp, 1.5Vr, 1000h Max. Temp, 2Vr, 1000h Board Flex 1mm 1mm 2mm 2mm Temp. Cycling 5cycle 5cycle 1000cycle 1000cycle 1. The part marked ‘derating’ is less than 150% of rated voltage in the durability and operational life test. 2. Some of the parts are applicable in rated voltage × 150% or × 120%. Please refer to individual specifications. 3. Some of parts are 3mm bending guaranteed. Please refer to individual specifications. MULTILAYER CERAMIC CAPACITORS 09 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Low ESL Capacitors Array Type Capacitors Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Application Guide Normal Capacitors_Standard Packaging Specifications sites Normal Standard Features  ‌A Normal MLCC temporarily charges and remove noise in electronic circuits, and is the most broadly available chip-type capacitor.  ‌The product line allows realization of various sizes and a wide range of capacitance.  ‌It also has the structural capacity to mount chips on a PCB at a high speed. ❶ Ceramic Body ❷ Electrode (Ni/Cu*) Wide Selection of Size & Wide Capacitance Range ❸ Plating (Ni) ❹ ‌Termination Products offered with various sizes and a wide range of capacities (Cu or Cu+Metal Epoxy) ⑤ Plating (Sn) Excellent DC Bias Characteristics Capacitor with Excellent DC Bias Characteristics High Speed Automatic Chip Placement on PCBs * Internal Cu electrode is only applied to limited products. Chip Mountable on PCB at High Speed Application  ‌Smart Phone, PC, HDD/SSD Board, Tablet, Display, Game Machine, DC-DC Converter Structure and Dimensions BW T W L Size Code Dimension (mm) L W T BW EIA (inch) 02 0.40±0.02 0.20±0.02 0.20±0.02 0.1±0.03 01005 05025 0.50±0.025 0.25±0.025 0.25±0.025 0.13±0.04 15008 0.60±0.03 0.30±0.03 0.30±0.03 0.60±0.05 0.30±0.05 0.30±0.05 0.60±0.09 0.30±0.09 0.50±0.05 0.15±0.05 0201 0.60±0.09 0.30±0.09 0.30±0.09 1.00±0.05 0.50±0.05 0.50±0.05 1.00±0.05 0.50±0.05 0.30±0.03 1.00±0.05 0.50±0.05 0.20±0.02 1.00±0.07 0.50±0.07 0.50±0.07 1.00±0.10 0.50±0.10 0.50±0.10 1.00±0.10 0.50±0.10 0.30±0.03 1.00±0.15 0.50±0.15 0.50±0.15 0.25±0.10 0402 1.00±0.15 0.50±0.15 0.30±0.03 1.00±0.20 0.50±0.20 0.50±0.20 1.00±0.20 0.50±0.25 0.70±0.10 1.00±0.20 0.50±0.20 0.60±0.20 1.00±0.20 0.50±0.20 0.50±0.05 1.15±0.05 0.70±0.05 0.70±0.05 03 05 MULTILAYER CERAMIC CAPACITORS 10 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size Code 10 21 31 32 43 Dimension (mm) L W 1.60±0.10 0.80±0.10 0.80±0.10 1.60±0.10 0.80±0.10 0.50+0.00/-0.10 1.60±0.15 0.80±0.15 0.80±0.15 1.60±0.20 0.80±0.20 0.80±0.20 1.60±0.20 0.80±0.20 0.80±0.20 1.60±0.20 0.80±0.20 0.70±0.20 1.60±0.25 0.80±0.25 0.70±0.10 1.60±0.25 0.80±0.25 0.80±0.25 1.60±0.30 0.80±0.30 0.70±0.10 1.60±0.30 0.80±0.30 0.80±0.30 1.60±0.30 0.80±0.30 0.50±0.30 1.80±0.10 1.00±0.10 0.70±0.10 2.00±0.10 1.25±0.10 0.65±0.10 2.00±0.10 1.25±0.10 0.85±0.10 2.00±0.10 1.25±0.10 0.90±0.10 2.00±0.10 1.25±0.10 1.25±0.10 2.00±0.15 1.25±0.15 0.85±0.10 2.00±0.15 1.25±0.15 1.25±0.15 2.00±0.20 1.25±0.20 0.70±0.10 2.00±0.20 1.25±0.20 0.80±0.10 2.00±0.20 1.25±0.20 0.85±0.10 2.00±0.20 1.25±0.20 0.90±0.10 2.00±0.20 1.25±0.20 1.10±0.10 2.00±0.20 1.25±0.20 1.25±0.20 3.20±0.15 1.60±0.15 0.85±0.15 3.20±0.15 1.60±0.15 1.25±0.15 3.20±0.20 1.60±0.20 0.85±0.10 3.20±0.20 1.60±0.20 0.90±0.10 3.20±0.20 1.60±0.20 1.15±0.10 3.20±0.20 1.60±0.20 1.15±0.15 3.20±0.20 1.60±0.20 1.60±0.20 3.20±0.30 2.50±0.20 0.85±0.10 3.20±0.30 2.50±0.20 1.25±0.20 3.20±0.30 2.50±0.20 1.35±0.15 3.20±0.30 2.50±0.20 1.40±0.20 3.20±0.30 2.50±0.20 1.60±0.10 3.20±0.30 2.50±0.20 1.60±0.20 3.20±0.30 2.50±0.20 1.80±0.20 3.20±0.30 2.50±0.20 2.50±0.20 3.20±0.30 2.50±0.20 2.00±0.20 3.20±0.40 2.50±0.30 2.50±0.20 3.20±0.40 2.50±0.30 2.50±0.30 4.50±0.40 3.20±0.30 1.60±0.20 MULTILAYER CERAMIC CAPACITORS T BW EIA (inch) 0.30±0.20 0603 0.5+0.2/-0.3 0805 0.50±0.30 1206 0.60±0.30 1210 0.80±0.30 1812 11 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_Standard Capacitance Table (C0G) Category TC Size mm (inch) 0402 (01005) 0603 (0201) 1005 (0402) 1608 (0603) Normal C0G (125℃) 2012 (0805) 3216 (1206) 3225 (1210) MULTILAYER CERAMIC CAPACITORS Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 16 0.3pF - 27pF 25 0.2pF - 100pF 50 1pF - 100pF 16 1nF - 1nF 25 27pF - 180pF 50 0.5pF - 1nF 100 100pF - 100pF 25 680pF - 3.3nF 50 0.3pF - 5.6nF 100 10pF - 1nF 200 220pF - 220pF 250 470pF - 470pF 25 3.9nF - 4.7nF 50 0.47pF - 10nF 100 10pF - 2.2nF 200 100pF - 1nF 250 1nF - 1nF 25 10nF - 10nF 50 1pF - 47nF 100 22pF - 2.2nF 200 1nF - 1nF 500 10pF - 1nF 630 10pF - 3.3nF 1000 10pF - 470pF 2000 15pF - 100pF 50 2000 10nF - 11nF 100pF - 100pF 12 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_Standard Capacitance Table (X5R) Category TC Size mm (inch) Rated Voltage (Vdc) 4 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 100nF - 220nF 0402 (01005) 6.3 1nF - 220nF 10 1nF - 10nF 05025 (015008) 6.3 1uF - 1uF 4 6.3 0603 (0201) 1005 (0402) 1608 (0603) Normal Capacitance pF X5R (85℃) 2012 (0805) 3216 (1206) 3225 (1210) MULTILAYER CERAMIC CAPACITORS 1uF - 4uF 15nF - 4.7uF 10 4.7nF - 2.2uF 16 100nF - 100nF 25 4.7nF - 330nF 35 100nF - 100nF 4 2.2uF - 22uF 6.3 100nF - 22uF 10 100nF - 15uF 16 100nF - 4.7uF 25 100nF - 2.2uF 35 1uF - 1uF 4 22uF - 47uF 6.3 1uF - 47uF 10 220nF - 22uF 16 470nF - 22uF 25 100nF - 10uF 35 1uF - 4.7uF 50 220nF - 2.2uF 4 47uF - 47uF 6.3 4.7uF - 47uF 10 1uF - 22uF 16 1uF - 22uF 25 1uF - 22uF 35 4.7uF - 4.7uF 50 1uF - 10uF 6.3 10uF - 100uF 10 10uF - 47uF 16 2.2uF - 22uF 25 3.3uF - 22uF 35 4.7uF - 4.7uF 50 1uF - 10uF 100 2.2uF - 2.2uF 6.3 22uF - 220uF 10 10uF - 100uF 16 10uF - 47uF 25 10uF - 22uF 35 4.7uF - 10uF 50 10uF - 10uF 13 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_Standard Capacitance Table (X6S) Category TC Size mm (inch) 0603 (0201) 1005 (0402) 1608 (0603) Normal X6S (105℃) 2012 (0805) 3216 (1206) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 4 Capacitance Range 1uF - 1uF 6.3 100nF - 220nF 2.5 2.2uF - 2.2uF 4 4.7uF - 10uF 6.3 1uF - 2.2uF 10 1uF - 1uF 25 1uF - 1uF 4 10uF - 22uF 6.3 4.7uF - 10uF 10 2.2uF - 10uF 16 4.7uF - 10uF 2.5 22uF - 22uF 4 10uF - 47uF 6.3 10uF - 22uF 10 10uF - 10uF 16 2.2uF - 10uF 25 4.7uF - 10uF 4 47uF - 47uF 6.3 22uF - 47uF 10 22uF - 22uF 16 22uF - 22uF 25 10uF - 22uF 6.3 100uF - 100uF 10 47uF - 47uF Capacitance Table (X7R) Category TC Size mm (inch) 0402 (01005) 0603 (0201) Normal X7R (125℃) 1005 (0402) MULTILAYER CERAMIC CAPACITORS Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 10 100pF - 1nF 16 330pF - 330pF 6.3 4.7nF - 10nF 10 1.5nF - 10nF 16 150pF - 1nF 25 150pF - 1nF 6.3 100nF - 470nF 10 22nF - 470nF 16 820pF - 220nF 25 560pF - 100nF 50 180pF - 100nF 14 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_Standard Category TC Size mm (inch) 1608 (0603) 2012 (0805) Normal X7R (125℃) 3216 (1206) Rated Voltage (Vdc) 1 10 100 1 10 uF 100 1 10 100 Capacitance Range 470nF - 10uF 10 220nF - 2.2uF 16 10nF - 1uF 25 4.7nF - 1uF 50 100pF - 1uF 100 1nF - 100nF 6.3 10uF - 10uF 10 680nF - 10uF 16 100nF - 10uF 25 1nF - 4.7uF 50 180pF - 1uF 100 220pF - 220nF 200 220pF - 10nF 250 1nF - 10nF 6.3 10uF - 22uF 10 4.7uF - 22uF 16 330nF - 10uF 25 220nF - 10uF 35 10uF - 10uF 50 330pF - 10uF 100 2.2nF - 2.2uF 200 470pF - 100nF 250 33nF - 100nF 500 220pF - 33nF 630 330pF - 33nF 1000 680pF - 2.2nF 6.3 MULTILAYER CERAMIC CAPACITORS 0.1 nF 6.3 2000 3225 (1210) Capacitance pF 1nF - 1nF 47uF - 47uF 10 10uF - 47uF 16 4.7uF - 22uF 25 1uF - 22uF 35 10uF - 10uF 50 150nF - 10uF 100 1uF - 2.2uF 250 100nF - 100nF 500 10nF - 10nF 15 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_Standard Capacitance Table (X7S) Category Normal TC X7S (125℃) Size mm (inch) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 1608 (0603) 6.3 10uF - 10uF 2012 (0805) 25 4.7uF - 4.7uF Capacitance Table (X7T) Category TC Normal X7T (125℃) Size mm (inch) 2012 (0805) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 6.3 Capacitance Range 22uF - 22uF Capacitance Table (Y5V) Category TC Size mm (inch) 1005 (0402) 1608 (0603) Normal Y5V (85℃) 2012 (0805) 3216 (1206) 3225 (1210) MULTILAYER CERAMIC CAPACITORS Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 6.3 1uF - 1uF 10 220nF - 470nF 16 22nF - 220nF 25 22nF - 33nF 50 15nF - 15nF 6.3 2.2uF - 2.2uF 10 2.2uF - 2.2uF 16 100nF - 470nF 25 100nF - 470nF 50 10nF - 100nF 6.3 10uF - 10uF 10 2.2uF - 10uF 16 2.2uF - 2.2uF 25 100nF - 1uF 50 47nF - 1uF 10 10uF - 10uF 16 1uF - 4.7uF 25 1uF - 2.2uF 50 220nF - 1uF 16 10uF - 10uF 25 10uF - 10uF 35 10uF - 10uF 16 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Product Line Up (C0G) Size : 0.20 × 0.10mm (inch : 01005) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.22 16 C0G 0.3pF ±0.10pF CL02C0R3BO2GNN# 2 0.22 16 C0G 0.4pF ±0.10pF CL02C0R4BO2GNN# 3 0.22 16 C0G 0.5pF ±0.10pF CL02C0R5BO2GNN# 4 0.22 16 C0G 0.9pF ±0.10pF CL02C0R9BO2GNN# 5 0.22 16 C0G 1pF ±0.10pF CL02C010BO2GNN# 6 0.22 16 C0G 1.2pF ±0.10pF CL02C1R2BO2GNN# 7 0.22 16 C0G 1.5pF ±0.10pF CL02C1R5BO2GNN# 8 0.22 16 C0G 1.6pF ±0.10pF CL02C1R6BO2GNN# 9 0.22 16 C0G 1.7pF ±0.10pF CL02C1R7BO2GNN# 10 0.22 16 C0G 1.8pF ±0.10pF CL02C1R8BO2GNN# 11 0.22 16 C0G 2pF ±0.10pF CL02C020BO2GNN# 12 0.22 16 C0G 2.4pF ±0.10pF CL02C2R4BO2GNN# 13 0.22 16 C0G 2.9pF ±0.10pF CL02C2R9BO2GNN# 14 0.22 16 C0G 3pF ±0.10pF CL02C030BO2GNN# 15 0.22 16 C0G 3.3pF ±0.25pF CL02C3R3CO2GNN# 16 0.22 16 C0G 4pF ±0.10pF CL02C040BO2GNN# 17 0.22 16 C0G 5.6pF ±0.10pF CL02C5R6BO2GNN# 18 0.22 16 C0G 5.6pF ±0.25pF CL02C5R6CO2GNN# 19 0.22 16 C0G 22pF ±2% CL02C220GO2GNN# 20 0.22 16 C0G 27pF ±5% CL02C270JO2NNN# Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.33 25 C0G 0.2pF ±0.10pF CL03C0R2BA3GNN# 2 0.33 25 C0G 0.3pF ±0.10pF CL03C0R3BA3GNN# 3 0.33 25 C0G 0.4pF ±0.10pF CL03C0R4BA3GNN# 4 0.33 25 C0G 0.4pF ±0.25pF CL03C0R4CA3GNN# 5 0.33 25 C0G 0.5pF ±0.10pF CL03C0R5BA3GNN# 6 0.33 25 C0G 0.5pF ±0.25pF CL03C0R5CA3GNN# 7 0.33 25 C0G 0.6pF ±0.10pF CL03C0R6BA3GNN# 8 0.33 25 C0G 0.6pF ±0.25pF CL03C0R6CA3GNN# 9 0.33 25 C0G 0.7pF ±0.10pF CL03C0R7BA3GNN# 10 0.33 25 C0G 0.8pF ±0.10pF CL03C0R8BA3GNN# 11 0.33 25 C0G 0.8pF ±0.25pF CL03C0R8CA3GNN# 12 0.33 25 C0G 0.9pF ±0.10pF CL03C0R9BA3GNN# 13 0.33 25 C0G 0.9pF ±0.25pF CL03C0R9CA3GNN# 14 0.33 25 C0G 1pF ±0.10pF CL03C010BA3GNN# 15 0.33 25 C0G 1pF ±0.25pF CL03C010CA3GNN# 16 0.33 25 C0G 1.2pF ±0.10pF CL03C1R2BA3GNN# 17 0.33 25 C0G 1.2pF ±0.25pF CL03C1R2CA3GNN# 18 0.33 25 C0G 1.5pF ±0.25pF CL03C1R5CA3GNN# 19 0.33 25 C0G 1.6pF ±0.10pF CL03C1R6BA3GNN# 20 0.33 25 C0G 1.8pF ±0.10pF CL03C1R8BA3GNN# MULTILAYER CERAMIC CAPACITORS 17 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 21 0.33 25 C0G 1.8pF ±0.25pF CL03C1R8CA3GNN# 22 0.33 25 C0G 2pF ±0.10pF CL03C020BA3GNN# 23 0.33 25 C0G 2.2pF ±0.10pF CL03C2R2BA3GNN# 24 0.33 25 C0G 2.2pF ±0.25pF CL03C2R2CA3GNN# 25 0.33 25 C0G 2.4pF ±0.10pF CL03C2R4BA3GNN# 26 0.33 25 C0G 2.4pF ±0.25pF CL03C2R4CA3GNN# 27 0.33 25 C0G 2.6pF ±0.10pF CL03C2R6BA3GNN# 28 0.33 25 C0G 2.7pF ±0.10pF CL03C2R7BA3GNN# 29 0.33 25 C0G 2.7pF ±0.25pF CL03C2R7CA3GNN# 30 0.33 25 C0G 3pF ±0.10pF CL03C030BA3GNN# 31 0.33 25 C0G 3.6pF ±0.10pF CL03C3R6BA3GNN# 32 0.33 25 C0G 3.6pF ±0.25pF CL03C3R6CA3GNN# 33 0.33 25 C0G 3.9pF ±0.10pF CL03C3R9BA3GNN# 34 0.33 25 C0G 4.3pF ±0.10pF CL03C4R3BA3GNN# 35 0.33 25 C0G 4.3pF ±0.25pF CL03C4R3CA3GNN# 36 0.33 25 C0G 4.7pF ±0.25pF CL03C4R7CA3GNN# 37 0.33 25 C0G 5pF ±0.25pF CL03C050CA3GNN# 38 0.33 25 C0G 5.1pF ±0.10pF CL03C5R1BA3GNN# 39 0.33 25 C0G 5.1pF ±0.25pF CL03C5R1CA3GNN# 40 0.33 25 C0G 5.6pF ±0.10pF CL03C5R6BA3GNN# 41 0.33 25 C0G 5.6pF ±0.25pF CL03C5R6CA3GNN# 42 0.33 25 C0G 6pF ±0.10pF CL03C060BA3GNN# 43 0.33 25 C0G 6pF ±0.50pF CL03C060DA3GNN# 44 0.33 25 C0G 6.2pF ±0.10pF CL03C6R2BA3GNN# 45 0.33 25 C0G 6.8pF ±0.10pF CL03C6R8BA3GNN# 46 0.33 25 C0G 6.8pF ±0.25pF CL03C6R8CA3GNN# 47 0.33 25 C0G 7pF ±0.10pF CL03C070BA3GNN# 48 0.33 25 C0G 7.5pF ±0.10pF CL03C7R5BA3GNN# 49 0.33 25 C0G 8pF ±0.50pF CL03C080DA3GNN# 50 0.33 25 C0G 8.2pF ±0.10pF CL03C8R2BA3GNN# 51 0.33 25 C0G 8.2pF ±0.25pF CL03C8R2CA3GNN# 52 0.33 25 C0G 9pF ±0.25pF CL03C090CA3GNN# 53 0.33 25 C0G 9.1pF ±0.25pF CL03C9R1CA3GNN# 54 0.33 25 C0G 10pF ±0.50pF CL03C100DA3GNN# 55 0.33 25 C0G 10pF ±5% CL03C100JA3GNN# 56 0.33 25 C0G 11pF ±2% CL03C110GA3GNN# 57 0.33 25 C0G 11pF ±5% CL03C110JA3GNN# 58 0.33 25 C0G 12pF ±5% CL03C120JA3GNN# 59 0.33 25 C0G 12pF ±5% CL03C120JA3NNN# 60 0.33 25 C0G 13pF ±5% CL03C130JA3GNN# 61 0.33 25 C0G 15pF ±5% CL03C150JA3NNN# 62 0.33 25 C0G 16pF ±2% CL03C160GA3GNN# 63 0.33 25 C0G 16pF ±5% CL03C160JA3GNN# 64 0.33 25 C0G 18pF ±5% CL03C180JA3GNN# 65 0.33 25 C0G 18pF ±5% CL03C180JA3NNN# 66 0.33 25 C0G 20pF ±5% CL03C200JA3GNN# 67 0.33 25 C0G 22pF ±2% CL03C220GA3GNN# MULTILAYER CERAMIC CAPACITORS 18 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 68 0.33 25 C0G 22pF ±5% CL03C220JA3GNN# 69 0.33 25 C0G 22pF ±5% CL03C220JA3NNN# 70 0.33 25 C0G 24pF ±5% CL03C240JA3GNN# 71 0.33 25 C0G 27pF ±5% CL03C270JA3GNN# 72 0.33 25 C0G 27pF ±5% CL03C270JA3NNN# 73 0.33 25 C0G 33pF ±5% CL03C330JA3NNN# 74 0.33 25 C0G 39pF ±5% CL03C390JA3NNN# 75 0.33 25 C0G 47pF ±5% CL03C470JA3NNN# 76 0.33 25 C0G 56pF ±5% CL03C560JA3NNN# 77 0.33 25 C0G 68pF ±5% CL03C680JA3NNN# 78 0.33 25 C0G 82pF ±5% CL03C820JA3NNN# 79 0.33 25 C0G 100pF ±5% CL03C101JA3NNN# 80 0.33 50 C0G 1pF ±0.10pF CL03C010BB3GNN# 81 0.33 50 C0G 1.2pF ±0.10pF CL03C1R2BB3GNN# 82 0.33 50 C0G 1.5pF ±0.10pF CL03C1R5BB3GNN# 83 0.33 50 C0G 2.7pF ±0.10pF CL03C2R7BB3GNN# 84 0.33 50 C0G 3pF ±0.25pF CL03C030CB3GNN# 85 0.33 50 C0G 3.3pF ±0.10pF CL03C3R3BB3GNN# 86 0.33 50 C0G 10pF ±5% CL03C100JB3GNN# 87 0.33 50 C0G 10pF ±5% CL03C100JB3NNN# 88 0.33 50 C0G 33pF ±5% CL03C330JB3NNN# 89 0.33 50 C0G 100pF ±5% CL03C101JB3NNN# Capacitance Capacitance Tolerance Part Number Part Number Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 0.55 16 C0G 1nF ±5% CL05C102JO5NNN# 2 0.55 25 C0G 27pF ±5% CL05C270JA5NNN# 3 0.55 25 C0G 180pF ±5% CL05C181JA5NNN# 4 0.55 50 C0G 0.5pF ±0.10pF CL05C0R5BB5NNN# 5 0.55 50 C0G 0.75pF ±0.10pF CL05CR75BB5NNN# 6 0.55 50 C0G 1pF ±0.10pF CL05C010BB5NCN# 7 0.55 50 C0G 1pF ±0.10pF CL05C010BB5NNN# 8 0.55 50 C0G 1pF ±0.25pF CL05C010CB5NNN# 9 0.55 50 C0G 1.2pF ±0.10pF CL05C1R2BB5NCN# 10 0.55 50 C0G 1.2pF ±0.10pF CL05C1R2BB5NNN# 11 0.55 50 C0G 1.2pF ±0.25pF CL05C1R2CB5NNN# 12 0.55 50 C0G 1.3pF ±0.10pF CL05C1R3BB5NNN# 13 0.55 50 C0G 1.5pF ±0.10pF CL05C1R5BB5NNN# 14 0.55 50 C0G 1.5pF ±0.25pF CL05C1R5CB5NCN# 15 0.55 50 C0G 1.8pF ±0.10pF CL05C1R8BB5NNN# 16 0.55 50 C0G 2.2pF ±0.10pF CL05C2R2BB5NNN# 17 0.55 50 C0G 2.4pF ±0.10pF CL05C2R4BB5NNN# 18 0.55 50 C0G 2.4pF ±0.25pF CL05C2R4CB5NNN# 19 0.55 50 C0G 2.5pF ±0.10pF CL05C2R5BB5NNN# MULTILAYER CERAMIC CAPACITORS 19 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 20 0.55 50 C0G 2.5pF ±0.25pF CL05C2R5CB5NNN# 21 0.55 50 C0G 2.7pF ±0.10pF CL05C2R7BB5NNN# 22 0.55 50 C0G 3.3pF ±0.10pF CL05C3R3BB5NNN# 23 0.55 50 C0G 3.3pF ±0.25pF CL05C3R3CB5NNN# 24 0.55 50 C0G 3.6pF ±0.25pF CL05C3R6CB5NNN# 25 0.55 50 C0G 3.9pF ±0.25pF CL05C3R9CB5NNN# 26 0.55 50 C0G 4.7pF ±0.25pF CL05C4R7CB5NNN# 27 0.55 50 C0G 5pF ±0.10pF CL05C050BB5NNN# 28 0.55 50 C0G 5pF ±0.25pF CL05C050CB5NNN# 29 0.55 50 C0G 5pF ±0.50pF CL05C050DB5NNN# 30 0.55 50 C0G 5.1pF ±0.25pF CL05C5R1CB5NNN# 31 0.55 50 C0G 5.6pF ±0.10pF CL05C5R6BB5NNN# 32 0.55 50 C0G 5.6pF ±0.50pF CL05C5R6DB5NNN# 33 0.55 50 C0G 6pF ±0.25pF CL05C060CB5NNN# 34 0.55 50 C0G 6pF ±0.50pF CL05C060DB5NNN# 35 0.55 50 C0G 6.2pF ±0.25pF CL05C6R2CB5NNN# 36 0.55 50 C0G 6.2pF ±0.50pF CL05C6R2DB5NNN# 37 0.55 50 C0G 6.8pF ±0.25pF CL05C6R8CB5NNN# 38 0.55 50 C0G 7pF ±0.25pF CL05C070CB5NNN# 39 0.55 50 C0G 7pF ±0.50pF CL05C070DB5NNN# 40 0.55 50 C0G 8pF ±0.25pF CL05C080CB5NNN# 41 0.55 50 C0G 8.2pF ±0.25pF CL05C8R2CB5NNN# 42 0.55 50 C0G 9pF ±0.25pF CL05C090CB5NNN# 43 0.55 50 C0G 9pF ±0.50pF CL05C090DB5NNN# 44 0.55 50 C0G 10pF ±0.25pF CL05C100CB5NCN# 45 0.55 50 C0G 10pF ±0.25pF CL05C100CB5NNN# 46 0.55 50 C0G 10pF ±0.50pF CL05C100DB5NCN# 47 0.55 50 C0G 10pF ±0.50pF CL05C100DB5NNN# 48 0.55 50 C0G 10pF ±5% CL05C100JB5NFN# 49 0.55 50 C0G 10pF ±5% CL05C100JB5NNN# 50 0.55 50 C0G 11pF ±5% CL05C110JB5NNN# 51 0.55 50 C0G 12pF ±2% CL05C120GB5NNN# 52 0.55 50 C0G 12pF ±5% CL05C120JB5NNN# 53 0.55 50 C0G 15pF ±5% CL05C150JB5NCN# 54 0.55 50 C0G 15pF ±5% CL05C150JB5NNN# 55 0.55 50 C0G 16pF ±5% CL05C160JB5NCN# 56 0.55 50 C0G 18pF ±2% CL05C180GB5NCN# 57 0.55 50 C0G 18pF ±5% CL05C180JB5NCN# 58 0.55 50 C0G 18pF ±5% CL05C180JB5NFN# 59 0.55 50 C0G 18pF ±5% CL05C180JB5NNN# 60 0.55 50 C0G 20pF ±2% CL05C200GB5NNN# 61 0.55 50 C0G 22pF ±5% CL05C220JB5NCN# 62 0.55 50 C0G 22pF ±5% CL05C220JB5NFN# 63 0.55 50 C0G 22pF ±5% CL05C220JB5NNN# 64 0.55 50 C0G 24pF ±5% CL05C240JB5NNN# 65 0.55 50 C0G 27pF ±5% CL05C270JB5NNN# 66 0.55 50 C0G 30pF ±5% CL05C300JB5NCN# MULTILAYER CERAMIC CAPACITORS 20 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 67 0.55 50 C0G 33pF ±1pF CL05C330FB5NNN# 68 0.55 50 C0G 33pF ±5% CL05C330JB5NCN# 69 0.55 50 C0G 33pF ±5% CL05C330JB5NFN# 70 0.55 50 C0G 33pF ±5% CL05C330JB5NNN# 71 0.55 50 C0G 36pF ±5% CL05C360JB5NNN# 72 0.55 50 C0G 39pF ±5% CL05C390JB5NNN# 73 0.55 50 C0G 43pF ±5% CL05C430JB5NNN# 74 0.55 50 C0G 47pF ±1pF CL05C470FB5NNN# 75 0.55 50 C0G 47pF ±5% CL05C470JB5NFN# 76 0.55 50 C0G 47pF ±5% CL05C470JB5NNN# 77 0.55 50 C0G 56pF ±1pF CL05C560FB5NNN# 78 0.55 50 C0G 56pF ±5% CL05C560JB5NNN# 79 0.55 50 C0G 62pF ±5% CL05C620JB5NNN# 80 0.55 50 C0G 68pF ±5% CL05C680JB5NNN# 81 0.55 50 C0G 75pF ±5% CL05C750JB5NNN# 82 0.55 50 C0G 82pF ±5% CL05C820JB5NNN# 83 0.55 50 C0G 91pF ±5% CL05C910JB5NNN# 84 0.55 50 C0G 100pF ±1pF CL05C101FB5NNN# 85 0.55 50 C0G 100pF ±5% CL05C101JB5NCN# 86 0.55 50 C0G 100pF ±5% CL05C101JB5NFN# 87 0.55 50 C0G 100pF ±5% CL05C101JB5NNN# 88 0.55 50 C0G 100pF ±10% CL05C101KB5NNN# 89 0.55 50 C0G 120pF ±5% CL05C121JB5NNN# 90 0.55 50 C0G 150pF ±5% CL05C151JB5NNN# 91 0.55 50 C0G 180pF ±5% CL05C181JB5NNN# 92 0.55 50 C0G 200pF ±5% CL05C201JB5NNN# 93 0.55 50 C0G 220pF ±5% CL05C221JB5NFN# 94 0.55 50 C0G 220pF ±5% CL05C221JB5NNN# 95 0.55 50 C0G 270pF ±5% CL05C271JB5NNN# 96 0.55 50 C0G 330pF ±5% CL05C331JB5NNN# 97 0.55 50 C0G 390pF ±5% CL05C391JB5NNN# 98 0.55 50 C0G 470pF ±5% CL05C471JB5NFN# 99 0.55 50 C0G 470pF ±5% CL05C471JB5NNN# 100 0.55 50 C0G 680pF ±5% CL05C681JB5NNN# 101 0.55 50 C0G 820pF ±5% CL05C821JB5NFN# 102 0.55 50 C0G 820pF ±5% CL05C821JB5NNN# 103 0.55 50 C0G 1nF ±5% CL05C102JB5NFN# 104 0.55 50 C0G 1nF ±5% CL05C102JB5NNN# 105 0.55 100 C0G 100pF ±5% CL05C101JC5NNN# MULTILAYER CERAMIC CAPACITORS 21 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 25 25 25 25 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 680pF 1nF 1nF 3.3nF 0.3pF 0.5pF 0.56pF 0.75pF 0.8pF 1pF 1.8pF 2pF 2.2pF 2.4pF 2.4pF 3.5pF 3.6pF 3.6pF 4pF 4pF 4.3pF 4.7pF 5pF 5pF 5pF 5.1pF 5.6pF 5.6pF 6pF 6.2pF 6.2pF 6.8pF 7pF 7pF 7pF 7.5pF 7.5pF 7.5pF 8.2pF 9.1pF 9.1pF 10pF 10pF 10pF 10pF 10pF 10pF 10pF 11pF ±5% ±5% ±5% ±5% ±0.10pF ±0.25pF ±0.10pF ±0.25pF ±0.10pF ±0.10pF ±0.10pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.10pF ±0.25pF ±0.10pF ±0.10pF ±0.10pF ±0.25pF ±0.50pF ±0.25pF ±0.10pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.10pF ±0.25pF ±0.50pF ±0.10pF ±0.25pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.10pF ±0.25pF ±1pF ±5% ±5% ±5% ±10% ±5% CL10C681JA8NNN# CL10C102JA8NFN# CL10C102JA8NNN# CL10C332JA8NNN# CL10C0R3BB8NNN# CL10C0R5CB8NNN# CL10CR56BB8NNN# CL10CR75CB8NNN# CL10C0R8BB8NNN# CL10C010BB8NNN# CL10C1R8BB8NNN# CL10C020CB8NNN# CL10C2R2CB8NNN# CL10C2R4BB8NNN# CL10C2R4CB8NNN# CL10C3R5CB8NNN# CL10C3R6BB8NNN# CL10C3R6CB8NNN# CL10C040BB8NNN# CL10C040CB8NNN# CL10C4R3BB8NNN# CL10C4R7BB8NNN# CL10C050BB8NNN# CL10C050CB8NFN# CL10C050DB8NNN# CL10C5R1CB8NNN# CL10C5R6BB8NNN# CL10C5R6DB8NNN# CL10C060DB8NNN# CL10C6R2CB8NNN# CL10C6R2DB8NNN# CL10C6R8CB8NNN# CL10C070BB8NNN# CL10C070CB8NNN# CL10C070DB8NNN# CL10C7R5BB8NNN# CL10C7R5CB8NNN# CL10C7R5DB8NNN# CL10C8R2DB8NNN# CL10C9R1CB8NNN# CL10C9R1DB8NNN# CL10C100BB8NNN# CL10C100CB8NNN# CL10C100FB8NNN# CL10C100JB8NCN# CL10C100JB8NFN# CL10C100JB8NNN# CL10C100KB8NNN# CL10C110JB8NNN# MULTILAYER CERAMIC CAPACITORS 22 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 12pF 12pF 13pF 14pF 15pF 15pF 15pF 15pF 15pF 16pF 18pF 18pF 20pF 20pF 20pF 22pF 22pF 24pF 25pF 27pF 27pF 27pF 27pF 30pF 30pF 33pF 33pF 33pF 33pF 33pF 39pF 39pF 43pF 47pF 47pF 47pF 47pF 51pF 56pF 56pF 56pF 62pF 68pF 68pF 68pF 82pF 82pF 91pF 100pF ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±1pF ±2% ±5% ±5% ±1pF ±5% ±1pF ±2% ±5% ±5% ±10% ±2% ±5% ±5% ±1pF ±2% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% CL10C120JB8NFN# CL10C120JB8NNN# CL10C130JB8NNN# CL10C140JB8NNN# CL10C150FB8NNN# CL10C150JB8NCN# CL10C150JB8NFN# CL10C150JB8NNN# CL10C150KB8NNN# CL10C160JB8NFN# CL10C180JB8NFN# CL10C180JB8NNN# CL10C200JB8NCN# CL10C200JB8NFN# CL10C200JB8NNN# CL10C220JB8NFN# CL10C220JB8NNN# CL10C240JB8NCN# CL10C250JB8NNN# CL10C270FB8NNN# CL10C270GB8NNN# CL10C270JB8NFN# CL10C270JB8NNN# CL10C300FB8NNN# CL10C300JB8NCN# CL10C330FB8NNN# CL10C330GB8NNN# CL10C330JB8NFN# CL10C330JB8NNN# CL10C330KB8NNN# CL10C390GB8NNN# CL10C390JB8NCN# CL10C430JB8NNN# CL10C470FB8NNN# CL10C470GB8NNN# CL10C470JB8NFN# CL10C470JB8NNN# CL10C510JB8NNN# CL10C560FB8NNN# CL10C560JB8NFN# CL10C560JB8NNN# CL10C620JB8NNN# CL10C680GB8NNN# CL10C680JB8NFN# CL10C680JB8NNN# CL10C820GB8NNN# CL10C820JB8NFN# CL10C910JB8NNN# CL10C101GB8NNN# MULTILAYER CERAMIC CAPACITORS 23 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 100pF 100pF 100pF 110pF 120pF 120pF 120pF 120pF 150pF 150pF 150pF 150pF 150pF 160pF 180pF 180pF 180pF 200pF 220pF 220pF 220pF 220pF 220pF 220pF 240pF 270pF 270pF 330pF 330pF 330pF 330pF 360pF 390pF 430pF 470pF 470pF 470pF 510pF 560pF 560pF 680pF 680pF 680pF 750pF 820pF 1nF 1nF 1nF 1.2nF 1.5nF ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±1pF ±2% ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±1pF ±2% ±5% ±5% ±5% ±10% ±5% ±2% ±5% ±1pF ±2% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±5% CL10C101JB8NCN# CL10C101JB8NFN# CL10C101JB8NNN# CL10C111JB8NNN# CL10C121FB8NNN# CL10C121JB8NCN# CL10C121JB8NFN# CL10C121JB8NNN# CL10C151FB8NNN# CL10C151GB8NNN# CL10C151JB8NCN# CL10C151JB8NFN# CL10C151JB8NNN# CL10C161JB8NNN# CL10C181FB8NNN# CL10C181JB8NFN# CL10C181JB8NNN# CL10C201JB8NNN# CL10C221FB8NNN# CL10C221GB8NNN# CL10C221JB8NCN# CL10C221JB8NFN# CL10C221JB8NNN# CL10C221KB8NNN# CL10C241JB8NNN# CL10C271GB8NNN# CL10C271JB8NNN# CL10C331FB8NNN# CL10C331GB8NNN# CL10C331JB8NFN# CL10C331JB8NNN# CL10C361JB8NNN# CL10C391JB8NFN# CL10C431JB8NNN# CL10C471JB8NCN# CL10C471JB8NFN# CL10C471JB8NNN# CL10C511JB8NNN# CL10C561JB8NFN# CL10C561JB8NNN# CL10C681FB8NNN# CL10C681JB8NFN# CL10C681JB8NNN# CL10C751JB8NNN# CL10C821JB8NFN# CL10C102FB8NNN# CL10C102JB8NFN# CL10C102JB8NNN# CL10C122JB8NNN# CL10C152JB8NFN# MULTILAYER CERAMIC CAPACITORS 24 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 50 50 50 50 50 50 50 50 50 50 100 100 100 100 100 100 100 100 100 100 200 250 C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 1.5nF 1.8nF 1.8nF 2.2nF 2.2nF 2.7nF 3.3nF 3.3nF 4.7nF 5.6nF 10pF 12pF 47pF 68pF 100pF 220pF 330pF 470pF 470pF 1nF 220pF 470pF ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±10% ±5% ±5% ±5% ±5% ±10% ±5% CL10C152JB8NNN# CL10C182JB8NFN# CL10C182JB8NNN# CL10C222JB8NFN# CL10C222JB8NNN# CL10C272JB8NNN# CL10C332JB8NFN# CL10C332JB8NNN# CL10C472JB8NNN# CL10C562JB8NNN# CL10C100JC8NNN# CL10C120JC8NNN# CL10C470JC8NNN# CL10C680JC8NNN# CL10C101JC8NNN# CL10C221KC8NNN# CL10C331JC8NNN# CL10C471JC8NFN# CL10C471JC8NNN# CL10C102JC8NNN# CL10C221KD8NNN# CL10C471JE8NNN# Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.75 25 C0G 3.9nF ±5% CL21C392JAANNN# 2 1.35 25 C0G 4.7nF ±5% CL21C472JAFNNN# 3 0.75 50 C0G 0.47pF ±0.10pF CL21CR47BBANNN# 4 0.75 50 C0G 0.47pF ±0.25pF CL21CR47CBANNN# 5 0.75 50 C0G 0.68pF ±0.10pF CL21CR68BBANNN# 6 0.75 50 C0G 1pF ±0.10pF CL21C010BBANNN# 7 0.75 50 C0G 1.2pF ±0.10pF CL21C1R2BBANNN# 8 0.75 50 C0G 1.2pF ±0.25pF CL21C1R2CBANNN# 9 0.75 50 C0G 1.5pF ±0.10pF CL21C1R5BBANNN# 10 0.75 50 C0G 1.5pF ±0.25pF CL21C1R5CBANNN# 11 0.75 50 C0G 1.8pF ±0.10pF CL21C1R8BBANNN# 12 0.75 50 C0G 1.8pF ±0.25pF CL21C1R8CBANNN# 13 0.75 50 C0G 2.2pF ±0.10pF CL21C2R2BBANNN# 14 0.75 50 C0G 2.4pF ±0.25pF CL21C2R4CBANNN# 15 0.75 50 C0G 2.5pF ±0.25pF CL21C2R5CBANNN# 16 0.75 50 C0G 2.7pF ±0.10pF CL21C2R7BBANNN# 17 0.75 50 C0G 2.7pF ±0.25pF CL21C2R7CBANNN# 18 0.75 50 C0G 3pF ±0.10pF CL21C030BBANNN# 19 0.75 50 C0G 3pF ±0.25pF CL21C030CBANNN# 20 0.75 50 C0G 3.9pF ±0.25pF CL21C3R9CBANNN# 21 0.75 50 C0G 4.7pF ±0.10pF CL21C4R7BBANNN# MULTILAYER CERAMIC CAPACITORS 25 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 22 0.75 50 23 0.75 50 C0G 5pF ±0.25pF CL21C050CBANNN# C0G 5.6pF ±0.10pF CL21C5R6BBANNN# 24 0.75 25 0.75 50 C0G 5.6pF ±0.25pF CL21C5R6CBANNN# 50 C0G 5.6pF ±0.50pF CL21C5R6DBANNN# 26 27 0.75 50 C0G 6pF ±0.25pF CL21C060CBANNN# 0.75 50 C0G 6pF ±0.50pF CL21C060DBANNN# 28 0.75 50 C0G 6.8pF ±0.25pF CL21C6R8CBANNN# 29 0.75 50 C0G 6.8pF ±0.50pF CL21C6R8DBANNN# 30 0.75 50 C0G 7pF ±0.25pF CL21C070CBANNN# 31 0.75 50 C0G 8pF ±0.25pF CL21C080CBANNN# 32 0.75 50 C0G 8pF ±0.50pF CL21C080DBANNN# 33 0.75 50 C0G 8.2pF ±0.50pF CL21C8R2DBANNN# 34 0.75 50 C0G 9pF ±0.25pF CL21C090CBANNN# 35 0.75 50 C0G 9pF ±0.50pF CL21C090DBANNN# 36 0.75 50 C0G 10pF ±0.25pF CL21C100CBANNN# 37 0.75 50 C0G 10pF ±5% CL21C100JBANFN# 38 0.75 50 C0G 12pF ±1pF CL21C120FBANNN# 39 0.75 50 C0G 13pF ±5% CL21C130JBANNN# 40 0.75 50 C0G 15pF ±2% CL21C150GBANNN# 41 0.75 50 C0G 20pF ±5% CL21C200JBANNN# 42 0.75 50 C0G 22pF ±1pF CL21C220FBANNN# 43 0.75 50 C0G 22pF ±2% CL21C220GBANNN# 44 0.75 50 C0G 22pF ±5% CL21C220JBANFN# 45 0.75 50 C0G 22pF ±5% CL21C220JBANNN# 46 0.75 50 C0G 24pF ±5% CL21C240JBANNN# 47 0.75 50 C0G 33pF ±5% CL21C330JBANFN# 48 0.75 50 C0G 33pF ±10% CL21C330KBANNN# 49 0.75 50 C0G 36pF ±5% CL21C360JBANNN# 50 0.75 50 C0G 39pF ±5% CL21C390JBANNN# 51 0.75 50 C0G 43pF ±5% CL21C430JBANNN# 52 0.75 50 C0G 47pF ±1pF CL21C470FBANNN# 53 0.75 50 C0G 47pF ±5% CL21C470JBANFN# 54 0.75 50 C0G 47pF ±5% CL21C470JBANNN# 55 0.75 50 C0G 51pF ±5% CL21C510JBANNN# 56 0.75 50 C0G 62pF ±5% CL21C620JBANNN# 57 0.75 50 C0G 68pF ±1pF CL21C680FBANNN# 58 0.75 50 C0G 68pF ±2% CL21C680GBANNN# 59 0.75 50 C0G 75pF ±5% CL21C750JBANNN# 60 0.75 50 C0G 82pF ±2% CL21C820GBANNN# 61 0.75 50 C0G 91pF ±5% CL21C910JBANNN# 62 0.75 50 C0G 100pF ±5% CL21C101JBANFN# 63 0.75 50 C0G 100pF ±5% CL21C101JBANNN# 64 0.75 50 C0G 100pF ±10% CL21C101KBANFN# 65 0.75 50 C0G 150pF ±1pF CL21C151FBANNN# 66 0.75 50 C0G 150pF ±5% CL21C151JBANFN# 67 0.75 50 C0G 150pF ±5% CL21C151JBANNN# 68 0.75 50 C0G 180pF ±5% CL21C181JBANNN# MULTILAYER CERAMIC CAPACITORS Part Number 26 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 69 0.75 50 C0G 200pF ±5% CL21C201JBANNN# 70 0.75 50 C0G 220pF ±1pF CL21C221FBANNN# 71 0.75 50 C0G 220pF ±2% CL21C221GBANNN# 72 0.75 50 C0G 220pF ±5% CL21C221JBANFN# 73 0.75 50 C0G 220pF ±5% CL21C221JBANNN# 74 0.75 50 C0G 270pF ±2% CL21C271GBANNN# 75 0.75 50 C0G 270pF ±5% CL21C271JBANNN# 76 0.75 50 C0G 300pF ±5% CL21C301JBANNN# 77 0.75 50 C0G 330pF ±1pF CL21C331FBANNN# 78 0.75 50 C0G 330pF ±2% CL21C331GBANNN# 79 0.75 50 C0G 330pF ±5% CL21C331JBANFN# 80 0.75 50 C0G 360pF ±5% CL21C361JBANNN# 81 0.75 50 C0G 390pF ±2% CL21C391GBANNN# 82 0.75 50 C0G 390pF ±5% CL21C391JBANNN# 83 0.75 50 C0G 430pF ±5% CL21C431JBANNN# 84 0.75 50 C0G 470pF ±1pF CL21C471FBANNN# 85 0.75 50 C0G 470pF ±2% CL21C471GBANNN# 86 0.75 50 C0G 470pF ±5% CL21C471JBANFN# 87 0.95 50 C0G 620pF ±5% CL21C621JBCNNN# 88 0.75 50 C0G 680pF ±5% CL21C681JBANNN# 89 0.95 50 C0G 680pF ±5% CL21C681JBCNFN# 90 0.95 50 C0G 910pF ±5% CL21C911JBCNNN# 91 0.95 50 C0G 1nF ±2% CL21C102GBCNNN# 92 0.95 50 C0G 1nF ±5% CL21C102JBCNFN# 93 1.35 50 C0G 1.2nF ±5% CL21C122JBFNNN# 94 1.35 50 C0G 1.5nF ±5% CL21C152JBFNFN# 95 1.35 50 C0G 1.8nF ±5% CL21C182JBFNNN# 96 1.35 50 C0G 2.2nF ±2% CL21C222GBFNNN# 97 1.35 50 C0G 2.2nF ±5% CL21C222JBFNFN# 98 1.35 50 C0G 2.2nF ±5% CL21C222JBFNNN# CL21C272JBFNNN# Part Number 99 1.35 50 C0G 2.7nF ±5% 100 1.35 50 C0G 4.7nF ±5% CL21C472JBFNFN# 101 1.35 50 C0G 4.7nF ±5% CL21C472JBFNNN# 102 1.35 50 C0G 5.6nF ±5% CL21C562JBFNNN# 103 1.35 50 C0G 10nF ±5% CL21C103JBFNFN# 104 1.35 50 C0G 10nF ±5% CL21C103JBFNNN# 105 0.75 100 C0G 10pF ±0.25pF CL21C100CCANNN# 106 0.75 100 C0G 18pF ±2% CL21C180GCANNN# 107 0.75 100 C0G 27pF ±5% CL21C270JCANNN# 108 0.75 100 C0G 47pF ±5% CL21C470JCANNN# 109 0.75 100 C0G 68pF ±5% CL21C680JCANNN# 110 0.75 100 C0G 100pF ±5% CL21C101JCANNN# 111 0.75 100 C0G 150pF ±1pF CL21C151FCANNN# 112 0.75 100 C0G 330pF ±5% CL21C331JCANNN# 113 0.95 100 C0G 470pF ±5% CL21C471JCCNFN# 114 0.95 100 C0G 680pF ±5% CL21C681JCCNNN# 115 1.35 100 C0G 1nF ±5% CL21C102JCFNNN# MULTILAYER CERAMIC CAPACITORS 27 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 116 1.35 100 117 0.95 200 C0G 2.2nF ±5% CL21C222JCFNNN# C0G 100pF ±5% 118 0.95 CL21C101JDCNFN# 200 C0G 100pF ±5% CL21C101JDCNNN# 119 0.95 200 C0G 120pF ±5% CL21C121JDCNNN# 120 0.95 200 C0G 220pF ±5% CL21C221JDCNFN# 121 0.95 200 C0G 220pF ±5% CL21C221JDCNNN# 122 1.35 200 C0G 1nF ±5% CL21C102JDFNFN# 123 1.35 250 C0G 1nF ±5% CL21C102JEFNFN# 124 1.35 250 C0G 1nF ±5% CL21C102JEFNNN# Capacitance Tolerance Part Number Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance 1 1.40 25 C0G 10nF ±5% CL31C103JAFNNN# 2 1.00 50 C0G 1pF ±0.25pF CL31C010CBCNNN# 3 1.00 50 C0G 2.2pF ±0.25pF CL31C2R2CBCNNN# 4 1.00 50 C0G 3.9pF ±0.10pF CL31C3R9BBCNNN# 5 1.00 50 C0G 4.7pF ±0.25pF CL31C4R7CBCNNN# 6 1.00 50 C0G 6.8pF ±0.25pF CL31C6R8CBCNNN# 7 1.00 50 C0G 10pF ±0.50pF CL31C100DBCNNN# 8 1.00 50 C0G 10pF ±5% CL31C100JBCNNN# 9 1.00 50 C0G 12pF ±5% CL31C120JBCNNN# 10 1.00 50 C0G 15pF ±5% CL31C150JBCNNN# 11 1.00 50 C0G 18pF ±5% CL31C180JBCNNN# 12 1.00 50 C0G 20pF ±5% CL31C200JBCNNN# 13 1.00 50 C0G 22pF ±5% CL31C220JBCNNN# 14 1.00 50 C0G 27pF ±1pF CL31C270FBCNNN# 15 1.00 50 C0G 27pF ±5% CL31C270JBCNNN# 16 1.00 50 C0G 30pF ±5% CL31C300JBCNNN# 17 1.00 50 C0G 56pF ±5% CL31C560JBCNNN# 18 1.00 50 C0G 82pF ±5% CL31C820JBCNNN# 19 1.00 50 C0G 100pF ±1pF CL31C101FBCNNN# 20 1.00 50 C0G 100pF ±5% CL31C101JBCNFN# 21 1.00 50 C0G 100pF ±10% CL31C101KBCNNN# 22 1.00 50 C0G 120pF ±5% CL31C121JBCNNN# 23 1.00 50 C0G 180pF ±5% CL31C181JBCNNN# 24 1.00 50 C0G 220pF ±5% CL31C221JBCNFN# 25 1.00 50 C0G 220pF ±5% CL31C221JBCNNN# 26 1.00 50 C0G 270pF ±5% CL31C271JBCNNN# 27 1.00 50 C0G 330pF ±5% CL31C331JBCNNN# 28 1.00 50 C0G 390pF ±5% CL31C391JBCNNN# 29 1.00 50 C0G 560pF ±5% CL31C561JBCNNN# 30 1.00 50 C0G 680pF ±5% CL31C681JBCNNN# 31 1.00 50 C0G 820pF ±5% CL31C821JBCNNN# 32 1.00 50 C0G 1nF ±1pF CL31C102FBCNNN# 33 1.00 50 C0G 1.2nF ±5% CL31C122JBCNNN# MULTILAYER CERAMIC CAPACITORS 28 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 34 1.00 50 C0G 1.5nF ±5% CL31C152JBCNNN# 35 1.00 50 C0G 2.2nF ±5% CL31C222JBCNNN# 36 1.40 50 C0G 3.3nF ±1pF CL31C332FBFNNN# 37 1.40 50 C0G 3.3nF ±5% CL31C332JBFNNN# 38 1.80 50 C0G 22nF ±5% CL31C223JBHNNN# 39 1.80 50 C0G 47nF ±5% CL31C473JBHNNN# 40 1.00 100 C0G 22pF ±5% CL31C220JCCNNN# 41 1.00 100 C0G 100pF ±5% CL31C101JCCNFN# 42 1.00 100 C0G 220pF ±5% CL31C221JCCNNN# 43 1.00 100 C0G 1.5nF ±5% CL31C152JCCNNN# 44 1.00 100 C0G 2.2nF ±5% CL31C222JCCNNN# 45 1.40 200 C0G 1nF ±5% CL31C102JDFNNN# 46 1.40 500 C0G 10pF ±5% CL31C100JGFNNN# 47 1.40 500 C0G 100pF ±5% CL31C101JGFNFN# 48 1.40 500 C0G 100pF ±5% CL31C101JGFNNN# 49 1.40 500 C0G 100pF ±10% CL31C101KGFNNN# 50 1.40 500 C0G 150pF ±5% CL31C151JGFNNN# 51 1.40 500 C0G 220pF ±5% CL31C221JGFNFN# 52 1.40 500 C0G 220pF ±5% CL31C221JGFNNN# 53 1.40 500 C0G 270pF ±5% CL31C271JGFNNN# 54 1.40 500 C0G 470pF ±5% CL31C471JGFNNN# 55 1.80 500 C0G 680pF ±5% CL31C681JGHNFN# 56 1.80 500 C0G 1nF ±5% CL31C102JGHNFN# 57 1.40 630 C0G 10pF ±5% CL31C100JHFNNN# 58 1.40 630 C0G 15pF ±5% CL31C150JHFNNN# 59 1.40 630 C0G 22pF ±5% CL31C220JHFNFN# 60 1.40 630 C0G 22pF ±5% CL31C220JHFNNC# 61 1.40 630 C0G 22pF ±5% CL31C220JHFNNN# 62 1.40 630 C0G 27pF ±5% CL31C270JHFNNN# 63 1.40 630 C0G 33pF ±5% CL31C330JHFNNN# 64 1.40 630 C0G 47pF ±5% CL31C470JHFNFN# 65 1.40 630 C0G 47pF ±5% CL31C470JHFNNN# 66 1.40 630 C0G 68pF ±5% CL31C680JHFNNN# 67 1.40 630 C0G 100pF ±5% CL31C101JHFNFN# 68 1.40 630 C0G 100pF ±5% CL31C101JHFNNN# 69 1.40 630 C0G 150pF ±5% CL31C151JHFNFN# 70 1.40 630 C0G 150pF ±5% CL31C151JHFNNN# 71 1.40 630 C0G 220pF ±5% CL31C221JHFNFN# 72 1.40 630 C0G 220pF ±5% CL31C221JHFNNN# 73 1.40 630 C0G 330pF ±5% CL31C331JHFNFN# 74 1.40 630 C0G 330pF ±5% CL31C331JHFNNN# 75 1.40 630 C0G 390pF ±5% CL31C391JHFNNN# 76 1.40 630 C0G 470pF ±5% CL31C471JHFNFN# 77 1.40 630 C0G 470pF ±5% CL31C471JHFNNN# 78 1.80 630 C0G 680pF ±5% CL31C681JHHNFN# 79 1.80 630 C0G 680pF ±5% CL31C681JHHNNN# 80 1.80 630 C0G 820pF ±5% CL31C821JHHNNN# MULTILAYER CERAMIC CAPACITORS 29 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 81 1.30 630 C0G 1nF ±5% CL31C102JHMLNN# 82 1.80 630 C0G 1nF ±5% CL31C102JHHNFN# 83 1.80 630 C0G 1nF ±5% CL31C102JHHNNC# 84 1.80 630 C0G 1nF ±5% CL31C102JHHNNN# 85 1.80 630 C0G 1.2nF ±5% CL31C122JHHNNN# 86 1.80 630 C0G 1.5nF ±5% CL31C152JHHNFN# 87 1.80 630 C0G 2.2nF ±5% CL31C222JHHNFN# 88 1.80 630 C0G 2.2nF ±5% CL31C222JHHNNN# 89 1.80 630 C0G 3.3nF ±5% CL31C332JHHNFN# 90 1.80 630 C0G 3.3nF ±5% CL31C332JHHNNN# 91 1.40 1000 C0G 10pF ±5% CL31C100JIFNNN# 92 1.40 1000 C0G 22pF ±5% CL31C220JIFNFN# 93 1.40 1000 C0G 22pF ±5% CL31C220JIFNNN# 94 1.40 1000 C0G 33pF ±5% CL31C330JIFNFN# 95 1.40 1000 C0G 33pF ±5% CL31C330JIFNNN# 96 1.40 1000 C0G 47pF ±5% CL31C470JIFNFN# 97 1.40 1000 C0G 47pF ±5% CL31C470JIFNNN# 98 1.40 1000 C0G 68pF ±5% CL31C680JIFNFN# 99 1.40 1000 C0G 68pF ±5% CL31C680JIFNNN# 100 1.40 1000 C0G 100pF ±5% CL31C101JIFNFN# 101 1.40 1000 C0G 100pF ±5% CL31C101JIFNNN# 102 1.40 1000 C0G 150pF ±5% CL31C151JIFNNN# 103 1.80 1000 C0G 180pF ±5% CL31C181JIHNNN# 104 1.80 1000 C0G 220pF ±5% CL31C221JIHNFN# 105 1.80 1000 C0G 220pF ±5% CL31C221JIHNNC# 106 1.80 1000 C0G 220pF ±5% CL31C221JIHNNN# 107 1.80 1000 C0G 270pF ±5% CL31C271JIHNNN# 108 1.80 1000 C0G 330pF ±5% CL31C331JIHNNN# 109 1.80 1000 C0G 470pF ±5% CL31C471JIHNFN# 110 1.80 1000 C0G 470pF ±5% CL31C471JIHNNC# 111 1.80 1000 C0G 470pF ±5% CL31C471JIHNNN# 112 1.80 2000 C0G 15pF ±5% CL31C150JJHNNN# 113 1.80 2000 C0G 47pF ±5% CL31C470JJHNNN# 114 1.80 2000 C0G 100pF ±5% CL31C101JJHNNN# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.45 50 C0G 10nF ±1pF CL32C103FBFNNN# 2 1.80 50 C0G 11nF ±5% CL32C113JBHNNN# 3 1.45 2000 C0G 100pF ±5% CL32C101JJFNNN# MULTILAYER CERAMIC CAPACITORS 30 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Product Line Up (X5R) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 0.55 6.3 X5R 4.7uF ±20% CL03A475MQ5C65# 2 0.39 4 X5R 4uF ±20% CL03A405MR3CRN# 3 0.39 6.3 X5R 3uF ±20% CL03A305MQ37RN# 4 0.39 6.3 X5R 3uF ±20% CL03A305MQ3CRN# 5 0.39 10 X5R 2.2uF ±20% CL03A225MP3CRN# 6 0.39 6.3 X5R 2.2uF ±20% CL03A225MQ3CRN# 7 0.35 6.3 X5R 2.2uF ±20% CL03A225MQ3ISN# 8 0.35 10 X5R 1uF ±10% CL03A105KP3NSN# Part Number 9 0.35 6.3 X5R 1uF ±10% CL03A105KQ3CSN# 10 0.35 10 X5R 1uF ±20% CL03A105MP3NSN# 11 0.33 6.3 X5R 1uF ±20% CL03A105MQ3CNN# 12 0.35 6.3 X5R 1uF ±20% CL03A105MQ3CSN# 13 0.35 4 X5R 1uF ±20% CL03A105MR3CSN# 14 0.33 10 X5R 470nF ±10% CL03A474KP3NNN# 15 0.33 6.3 X5R 470nF ±10% CL03A474KQ3NNN# 16 0.33 6.3 X5R 470nF ±20% CL03A474MQ3NNN# 17 0.39 25 X5R 330nF ±10% CL03A334KA3NRN# 18 0.39 25 X5R 220nF ±10% CL03A224KA3NRN# 19 0.33 10 X5R 220nF ±10% CL03A224KP3NNN# 20 0.33 6.3 X5R 220nF ±10% CL03A224KQ3NNN# 21 0.33 6.3 X5R 220nF ±20% CL03A224MQ3NNN# 22 0.33 25 X5R 100nF ±10% CL03A104KA3NNN# 23 0.33 35 X5R 100nF ±10% CL03A104KL3NNN# 24 0.33 16 X5R 100nF ±10% CL03A104KO3NNN# 25 0.33 10 X5R 100nF ±10% CL03A104KP3NNN# 26 0.33 6.3 X5R 100nF ±10% CL03A104KQ3NNN# 27 0.33 25 X5R 100nF ±20% CL03A104MA3NNN# 28 0.33 16 X5R 100nF ±20% CL03A104MO3NNN# 29 0.33 10 X5R 100nF ±20% CL03A104MP3NNN# 30 0.33 6.3 X5R 100nF ±20% CL03A104MQ3NNN# 31 0.33 6.3 X5R 68nF ±10% CL03A683KQ3NNN# 32 0.33 10 X5R 47nF ±10% CL03A473KP3NNN# 33 0.33 6.3 X5R 47nF ±10% CL03A473KQ3NNN# 34 0.33 25 X5R 22nF ±10% CL03A223KA3NNN# 35 0.33 6.3 X5R 22nF ±10% CL03A223KQ3NNN# 36 0.33 6.3 X5R 15nF ±10% CL03A153KQ3NNN# 37 0.33 25 X5R 10nF ±10% CL03A103KA3NNN# 38 0.33 10 X5R 10nF ±10% CL03A103KP3NNN# 39 0.33 25 X5R 4.7nF ±10% CL03A472KA3NNN# 40 0.33 10 X5R 4.7nF ±10% CL03A472KP3NNN# MULTILAYER CERAMIC CAPACITORS 31 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.70 6.3 X5R 22uF ±20% CL05A226MQ5QUN# 2 0.70 4 X5R 22uF ±20% CL05A226MR5QUN# 3 0.65 4 X5R 20uF ±20% CL05A206MR5CRN# 4 0.80 10 X5R 15uF ±20% CL05A156MP7N6J# 5 0.75 6.3 X5R 15uF ±20% CL05A156MQ586J# 6 0.65 10 X5R 10uF ±20% CL05A106MP5NRN# 7 0.80 10 X5R 10uF ±20% CL05A106MP68UN# 8 0.80 10 X5R 10uF ±20% CL05A106MP6NUN# 9 0.70 6.3 X5R 10uF ±20% CL05A106MQ5N3U# 10 0.65 6.3 X5R 10uF ±20% CL05A106MQ5NRN# 11 0.70 6.3 X5R 10uF ±20% CL05A106MQ5NUN# 12 0.70 4 X5R 10uF ±20% CL05A106MR5NUN# 13 0.65 6.3 X5R 4.7uF ±10% CL05A475KQ5NRN# 14 0.55 16 X5R 4.7uF ±20% CL05A475MO5LUN# 15 0.70 16 X5R 4.7uF ±20% CL05A475MO5NUN# 16 0.60 4 X5R 4.7uF ±20% CL05A475MR5NQN# 17 0.55 16 X5R 4.2uF ±10% CL05A425KO5LUN# 18 0.70 25 X5R 2.2uF ±10% CL05A225KA5NUN# 19 0.60 16 X5R 2.2uF ±10% CL05A225KO5NQN# 20 0.55 10 X5R 2.2uF ±10% CL05A225KP5NNN# 21 0.57 10 X5R 2.2uF ±10% CL05A225KP5NSN# 22 0.55 6.3 X5R 2.2uF ±10% CL05A225KQ5NNN# 23 0.57 6.3 X5R 2.2uF ±10% CL05A225KQ5NSN# 24 0.55 25 X5R 2.2uF ±20% CL05A225MA5JUN# 25 0.70 25 X5R 2.2uF ±20% CL05A225MA5NUN# 26 0.55 10 X5R 2.2uF ±20% CL05A225MP5NNN# 27 0.57 10 X5R 2.2uF ±20% CL05A225MP5NSN# 28 0.33 6.3 X5R 2.2uF ±20% CL05A225MQ3LRN# 29 0.57 6.3 X5R 2.2uF ±20% CL05A225MQ5NSN# 30 0.55 4 X5R 2.2uF ±20% CL05A225MR5NNN# 31 0.55 6.3 X5R 1uF ±5% CL05A105JQ5NNN# 32 0.60 25 X5R 1uF ±10% CL05A105KA5NFQ# 33 0.55 25 X5R 1uF ±10% CL05A105KA5NNN# 34 0.60 25 X5R 1uF ±10% CL05A105KA5NQN# 35 0.65 35 X5R 1uF ±10% CL05A105KL5NRN# 36 0.55 16 X5R 1uF ±10% CL05A105KO5NFN# 37 0.55 16 X5R 1uF ±10% CL05A105KO5NNN# 38 0.55 10 X5R 1uF ±10% CL05A105KP5NFN# 39 0.33 6.3 X5R 1uF ±10% CL05A105KQ3LNN# 40 0.55 6.3 X5R 1uF ±10% CL05A105KQ5NNN# 41 0.55 6.3 X5R 1uF ±20% CL05A105MQ5NNN# 43 0.55 25 X5R 470nF ±10% CL05A474KA5NNN# 44 0.55 16 X5R 470nF ±10% CL05A474KO5NNN# 45 0.55 10 X5R 470nF ±10% CL05A474KP5NNN# 46 0.55 6.3 X5R 470nF ±10% CL05A474KQ5NNN# 48 0.55 25 X5R 330nF ±10% CL05A334KA5NNN# 49 0.55 6.3 X5R 330nF ±10% CL05A334KQ5NNN# MULTILAYER CERAMIC CAPACITORS 32 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 50 0.55 6.3 X5R 330nF ±20% CL05A334MQ5NNN# 52 0.55 25 X5R 220nF ±10% CL05A224KA5NNN# 53 0.55 16 X5R 220nF ±10% CL05A224KO5NNN# 54 0.55 10 X5R 220nF ±10% CL05A224KP5NNN# 55 0.55 6.3 X5R 220nF ±10% CL05A224KQ5NNN# 56 0.55 10 X5R 220nF ±20% CL05A224MP5NNN# 59 0.55 10 X5R 150nF ±10% CL05A154KP5NNN# 60 0.55 16 X5R 100nF ±5% CL05A104JO5NNN# 61 0.55 25 X5R 100nF ±10% CL05A104KA5NFN# 62 0.55 25 X5R 100nF ±10% CL05A104KA5NNN# 63 0.55 16 X5R 100nF ±10% CL05A104KO5NNN# 64 0.55 10 X5R 100nF ±10% CL05A104KP5NNN# 65 0.55 6.3 X5R 100nF ±10% CL05A104KQ5NNN# 66 0.55 16 X5R 100nF ±20% CL05A104MO5NNN# 67 0.22 6.3 X5R 100nF ±20% CL05A104MQ2HNN# Capacitance Tolerance Part Number Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance 1 0.80 6.3 X5R 47uF ±20% CL10A476MQ7LZN# 2 1.00 6.3 X5R 47uF ±20 % CL10A476MQ8QRN# 3 1.00 4 X5R 47uF ±20% CL10A476MR8NRN# 4 1.10 4 X5R 47uF ±20% CL10A476MR8NZN# 5 1.00 6.3 X5R 22uF ±10% CL10A226KQ8NRN# 6 0.80 16 X5R 22uF ±20% CL10A226MO79ZN# 7 0.80 16 X5R 22uF ±20% CL10A226MO7FZN# 8 0.80 16 X5R 22uF ±20% CL10A226MO7JZN# 9 0.80 10 X5R 22uF ±20% CL10A226MP7LUN# 10 0.80 10 X5R 22uF ±20% CL10A226MP7ZZB# 11 1.00 10 X5R 22uF ±20% CL10A226MP8NRN# 12 1.05 10 X5R 22uF ±20% CL10A226MP8NUN# 13 0.80 6.3 X5R 22uF ±20% CL10A226MQ7LUN# 14 0.90 6.3 X5R 22uF ±20% CL10A226MQ7NRN# 15 1.00 6.3 X5R 22uF ±20% CL10A226MQ8NFR# 16 1.00 6.3 X5R 22uF ±20% CL10A226MQ8NRN# 17 1.05 6.3 X5R 22uF ±20% CL10A226MQ8NUN# 18 0.95 4 X5R 22uF ±20% CL10A226MR8NQN# 19 0.95 16 X5R 10uF ±10% CL10A106KO8NQN# 20 0.90 10 X5R 10uF ±10% CL10A106KP8NFN# 21 0.90 10 X5R 10uF ±10% CL10A106KP8NNN# 22 0.90 6.3 X5R 10uF ±10% CL10A106KQ8NNN# 23 0.90 10 X5R 10uF ±20% CL10A106MP8NFN# 24 0.95 10 X5R 10uF ±20% CL10A106MP8NFS# 25 0.90 10 X5R 10uF ±20% CL10A106MP8NNN# 26 0.95 25 X5R 4.7uF ±10% CL10A475KA8NQN# 27 1.00 35 X5R 4.7uF ±10% CL10A475KL8NRN# MULTILAYER CERAMIC CAPACITORS 33 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 28 0.90 16 X5R 4.7uF ±10% CL10A475KO8NFN# 29 0.90 16 X5R 4.7uF ±10% CL10A475KO8NNN# 30 0.95 16 X5R 4.7uF ±10% CL10A475KO8NQN# 31 0.50 10 X5R 4.7uF ±10% CL10A475KP5LNN# 32 0.90 10 X5R 4.7uF ±10% CL10A475KP8NFN# 33 0.90 10 X5R 4.7uF ±10% CL10A475KP8NNN# 34 0.50 6.3 X5R 4.7uF ±10% CL10A475KQ5LNN# 35 0.90 6.3 X5R 4.7uF ±10% CL10A475KQ8NFN# 36 0.90 6.3 X5R 4.7uF ±10% CL10A475KQ8NNN# 37 0.95 25 X5R 4.7uF ±20% CL10A475MA8NQN# 38 0.90 16 X5R 4.7uF ±20% CL10A475MO8NNN# 39 0.90 6.3 X5R 4.7uF ±20% CL10A475MQ8NNN# 40 0.90 10 X5R 3.3uF ±10% CL10A335KP8NFN# 41 0.90 10 X5R 3.3uF ±10% CL10A335KP8NNN# 43 0.50 25 X5R 2.2uF ±10% CL10A225KA5LNN# 44 0.90 25 X5R 2.2uF ±10% CL10A225KA8NNN# 45 0.90 50 X5R 2.2uF ±10% CL10A225KB8NNN# 46 0.90 35 X5R 2.2uF ±10% CL10A225KL8NNN# 48 0.50 16 X5R 2.2uF ±10% CL10A225KO5LNN# 49 0.90 16 X5R 2.2uF ±10% CL10A225KO8N3N# 50 0.90 16 X5R 2.2uF ±10% CL10A225KO8NFN# 52 0.90 16 X5R 2.2uF ±10% CL10A225KO8NNN# 53 0.50 10 X5R 2.2uF ±10% CL10A225KP5LNN# 54 0.90 10 X5R 2.2uF ±10% CL10A225KP8NNN# 55 0.50 6.3 X5R 2.2uF ±10% CL10A225KQ5LNN# 56 0.90 6.3 X5R 2.2uF ±10% CL10A225KQ8N3N# 59 0.90 6.3 X5R 2.2uF ±10% CL10A225KQ8NNN# 60 0.90 10 X5R 2.2uF ±20% CL10A225MP8NNN# 61 0.90 25 X5R 1uF ±10% CL10A105KA8NFN# 62 0.90 25 X5R 1uF ±10% CL10A105KA8NNN# 63 0.90 50 X5R 1uF ±10% CL10A105KB8NNN# 64 0.90 35 X5R 1uF ±10% CL10A105KL8NNN# 65 0.90 16 X5R 1uF ±10% CL10A105KO8NNN# 66 0.90 10 X5R 1uF ±10% CL10A105KP8NNN# 67 0.90 6.3 X5R 1uF ±10% CL10A105KQ8NNN# 68 0.90 50 X5R 1uF ±20% CL10A105MB8NNN# 69 0.90 16 X5R 1uF ±20% CL10A105MO8NNN# 70 0.90 25 X5R 470nF ±10% CL10A474KA8NNN# 71 0.90 50 X5R 470nF ±10% CL10A474KB8NNN# 72 0.90 16 X5R 470nF ±10% CL10A474KO8NNN# 73 0.90 50 X5R 220nF ±10% CL10A224KB8NNN# 74 0.90 10 X5R 220nF ±10% CL10A224KP8NNN# 75 0.90 25 X5R 100nF ±10% CL10A104KA8NNN# MULTILAYER CERAMIC CAPACITORS Part Number 34 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.80 6.3 X5R 47uF ±20% CL21A476MQ7LRN# 2 0.90 6.3 X5R 47uF ±20% CL21A476MQ8LRN# 3 1.00 6.3 X5R 47uF ±20% CL21A476MQ9LRN# 4 0.95 6.3 X5R 47uF ±20% CL21A476MQCLRN# 5 1.45 6.3 X5R 47uF ±20% CL21A476MQYN3N# 6 1.45 6.3 X5R 47uF ±20% CL21A476MQYNNN# 7 1.45 4 X5R 47uF ±20% CL21A476MRYNNN# 8 1.20 6.3 X5R 33uF ±20% CL21A336MQELRN# 9 1.40 16 X5R 22uF ±10% CL21A226KOQNNN# 10 0.95 10 X5R 22uF ±10% CL21A226KPCLRN# 11 0.95 6.3 X5R 22uF ±10% CL21A226KQCLRN# 12 1.40 6.3 X5R 22uF ±10% CL21A226KQQNFN# 13 1.40 6.3 X5R 22uF ±10% CL21A226KQQNNN# 14 1.45 25 X5R 22uF ±20% CL21A226MAYNNN# 15 0.95 16 X5R 22uF ±20% CL21A226MOCLRN# 16 1.40 16 X5R 22uF ±20% CL21A226MOQNNN# 17 0.95 10 X5R 22uF ±20% CL21A226MPCLRN# 18 1.40 10 X5R 22uF ±20% CL21A226MPQNNN# 19 0.95 6.3 X5R 22uF ±20% CL21A226MQCLRN# 20 1.40 6.3 X5R 22uF ±20% CL21A226MQQN3N# 21 1.40 6.3 X5R 22uF ±20% CL21A226MQQNNN# 22 0.95 25 X5R 10uF ±10% CL21A106KACLRN# 23 1.35 25 X5R 10uF ±10% CL21A106KAFN3N# 24 1.45 25 X5R 10uF ±10% CL21A106KAYN3N# 25 1.45 25 X5R 10uF ±10% CL21A106KAYNFN# 26 1.45 25 X5R 10uF ±10% CL21A106KAYNNN# 27 1.45 50 X5R 10uF ±10% CL21A106KBYQNN# 28 0.95 16 X5R 10uF ±10% CL21A106KOCLRN# 29 1.35 16 X5R 10uF ±10% CL21A106KOFNNN# 30 1.40 16 X5R 10uF ±10% CL21A106KOQNFN# 31 1.40 16 X5R 10uF ±10% CL21A106KOQNNN# 32 0.95 10 X5R 10uF ±10% CL21A106KPCLQN# 33 0.95 10 X5R 10uF ±10% CL21A106KPCLRN# 34 1.35 10 X5R 10uF ±10% CL21A106KPFNNN# 35 0.95 6.3 X5R 10uF ±10% CL21A106KQCLNN# 36 0.95 6.3 X5R 10uF ±10% CL21A106KQCLRN# 37 1.35 6.3 X5R 10uF ±10% CL21A106KQFNFN# 38 1.35 6.3 X5R 10uF ±10% CL21A106KQFNNN# 39 1.45 25 X5R 10uF ±20% CL21A106MAYNNN# 40 1.35 16 X5R 10uF ±20% CL21A106MOFNNN# 41 1.35 10 X5R 10uF ±20% CL21A106MPFNNN# 43 0.95 6.3 X5R 10uF ±20% CL21A106MQCLNN# 44 1.35 6.3 X5R 10uF ±20% CL21A106MQFNNN# 45 1.40 6.3 X5R 10uF ±20% CL21A106MQQNNN# 46 0.95 25 X5R 4.7uF ±10% CL21A475KACLRN# 48 1.40 25 X5R 4.7uF ±10% CL21A475KAQN3N# 49 1.40 25 X5R 4.7uF ±10% CL21A475KAQNFN# MULTILAYER CERAMIC CAPACITORS 35 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 50 1.40 25 X5R 4.7uF ±10% CL21A475KAQNNN# 52 1.40 50 X5R 4.7uF ±10% CL21A475KBQNNN# 53 0.95 35 X5R 4.7uF ±10% CL21A475KLCLQN# 54 0.95 16 X5R 4.7uF ±10% CL21A475KOCLRN# 55 1.35 16 X5R 4.7uF ±10% CL21A475KOFNNN# 56 0.95 10 X5R 4.7uF ±10% CL21A475KPCLNN# 59 1.35 10 X5R 4.7uF ±10% CL21A475KPFNNN# 60 0.95 6.3 X5R 4.7uF ±10% CL21A475KQCLNN# 61 1.35 6.3 X5R 4.7uF ±10% CL21A475KQFNNN# 62 1.35 25 X5R 4.7uF ±20% CL21A475MAFNNN# 63 1.40 25 X5R 4.7uF ±20% CL21A475MAQNNN# 64 1.35 10 X5R 4.7uF ±20% CL21A475MPFNNN# 65 1.35 6.3 X5R 4.7uF ±20% CL21A475MQFNNN# 66 1.35 10 X5R 3.3uF ±10% CL21A335KPFNNN# 67 0.95 25 X5R 2.2uF ±10% CL21A225KACLNN# 68 1.35 25 X5R 2.2uF ±10% CL21A225KAFNFN# 69 1.35 25 X5R 2.2uF ±10% CL21A225KAFNNN# 70 1.00 50 X5R 2.2uF ±10% CL21A225KB9LNN# 71 1.35 50 X5R 2.2uF ±10% CL21A225KBFNNN# 72 1.40 50 X5R 2.2uF ±10% CL21A225KBQNNN# 73 0.95 16 X5R 2.2uF ±10% CL21A225KOCLNN# 74 1.35 16 X5R 2.2uF ±10% CL21A225KOFNNN# 75 0.95 10 X5R 2.2uF ±10% CL21A225KPCLNN# 76 1.35 10 X5R 2.2uF ±10% CL21A225KPFNNN# 77 0.95 25 X5R 1uF ±10% CL21A105KACLNN# 78 0.95 50 X5R 1uF ±10% CL21A105KBCLNN# 79 0.95 16 X5R 1uF ±10% CL21A105KOCLNN# 80 1.35 10 X5R 1uF ±10% CL21A105KPFNNN# Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.80 6.3 X5R 47uF ±20% CL31A107MQHNNN# 2 1.80 6.3 X5R 47uF ±20% CL31A476KQHNNN# 3 1.80 10 X5R 47uF ±20% CL31A476MPHNFN# 4 1.80 10 X5R 47uF ±20% CL31A476MPHNNN# 5 1.80 6.3 X5R 47uF ±20% CL31A476MQHNNN# 6 1.80 25 X5R 47uF ±20% CL31A226KAHNNN# 7 0.95 16 X5R 47uF ±20% CL31A226KOCLFN# 8 0.95 16 X5R 33uF ±20% CL31A226KOCLNN# 9 1.80 16 X5R 22uF ±10% CL31A226KOHNFN# 10 1.80 16 X5R 22uF ±10% CL31A226KOHNNN# 11 1.80 10 X5R 22uF ±10% CL31A226KPHNNN# 12 1.80 6.3 X5R 22uF ±10% CL31A226KQHNNN# 13 1.80 25 X5R 22uF ±10% CL31A226MAHNNN# 14 0.95 16 X5R 22uF ±20% CL31A226MOCLFN# MULTILAYER CERAMIC CAPACITORS 36 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 15 0.95 16 X5R 22uF ±20% CL31A226MOCLNN# 16 1.80 16 X5R 22uF ±20% CL31A226MOHNNN# 17 1.80 10 X5R 22uF ±20% CL31A226MPHNNN# 18 1.80 6.3 X5R 22uF ±20% CL31A226MQHNNN# 19 0.95 25 X5R 22uF ±20% CL31A106KACLNN# 20 1.80 25 X5R 22uF ±20% CL31A106KAHNFN# 21 1.80 25 X5R 22uF ±20% CL31A106KAHNNN# 22 1.80 50 X5R 10uF ±10% CL31A106KBHNNN# 23 0.95 16 X5R 10uF ±10% CL31A106KOCLNN# 24 1.80 16 X5R 10uF ±10% CL31A106KOHNNN# 25 1.80 10 X5R 10uF ±10% CL31A106KPHNNN# 26 1.25 10 X5R 10uF ±10% CL31A106KPPLNN# 27 1.80 6.3 X5R 10uF ±10% CL31A106KQHNNN# 28 1.80 25 X5R 10uF ±10% CL31A106MAHNNN# 29 1.80 50 X5R 10uF ±10% CL31A106MBHNNN# 30 1.80 16 X5R 10uF ±10% CL31A106MOHNNN# 31 1.80 6.3 X5R 10uF ±10% CL31A106MQHNNN# 32 0.95 25 X5R 10uF ±10% CL31A475KACLNN# 33 1.80 25 X5R 10uF ±10% CL31A475KAHNNN# 34 1.00 50 X5R 10uF ±10% CL31A475KB9LNN# 35 1.80 50 X5R 10uF ±10% CL31A475KBHNNN# 36 1.00 35 X5R 10uF ±10% CL31A475KL9LNN# 37 0.95 16 X5R 10uF ±10% CL31A475KOCLNN# 38 1.80 16 X5R 10uF ±10% CL31A475KOHNNN# 39 1.80 16 X5R 10uF ±20% CL31A475MOHNNN# 40 1.80 25 X5R 10uF ±20% CL31A335KAHNNN# 41 0.95 16 X5R 10uF ±20% CL31A335KOCLNN# 43 1.80 16 X5R 10uF ±20% CL31A335KOHNNN# 44 1.00 50 X5R 10uF ±20% CL31A225KB9LNN# 45 1.00 100 X5R 10uF ±20% CL31A225KC9LNN# 46 1.80 16 X5R 4.7uF ±10% CL31A225KOHNNN# 48 1.00 50 X5R 4.7uF ±10% CL31A105KB9LNN# Part Number Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2.80 6.3 X5R 220uF ±20% CL32A227MQVNNN# 2 2.80 6.3 X5R 150uF ±20% CL32A157MQVNNN# 3 2.80 10 X5R 100uF ±20% CL32A107MPVNNN# 4 2.80 6.3 X5R 100uF ±20% CL32A107MQVNNN# 5 2.70 16 X5R 47uF ±10% CL32A476KOJNNN# 6 2.70 10 X5R 47uF ±10% CL32A476KPJNNN# 7 2.70 6.3 X5R 47uF ±10% CL32A476KQJNNN# 8 2.70 16 X5R 47uF ±20% CL32A476MOJNNN# 9 2.70 6.3 X5R 47uF ±20% CL32A476MQJNNN# 10 2.70 25 X5R 22uF ±10% CL32A226KAJNFN# MULTILAYER CERAMIC CAPACITORS 37 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 11 2.70 25 X5R 22uF ±10% CL32A226KAJNNN# 12 2.70 16 X5R 22uF ±10% CL32A226KOJNFN# 13 2.70 16 X5R 22uF ±10% CL32A226KOJNNN# 14 2.70 10 X5R 22uF ±10% CL32A226KPJNNN# 15 2.70 6.3 X5R 22uF ±10% CL32A226KQJNNN# 16 2.70 25 X5R 22uF ±20% CL32A226MAJNNN# 17 0.95 16 X5R 22uF ±20% CL32A226MOCLNN# 18 2.70 16 X5R 22uF ±20% CL32A226MOJNNN# 19 1.70 16 X5R 22uF ±20% CL32A226MOTLNN# 20 2.70 10 X5R 22uF ±20% CL32A226MPJNNN# 21 2.70 6.3 X5R 22uF ±20% CL32A226MQJNNN# 22 2.70 25 X5R 10uF ±10% CL32A106KAJNNN# 23 1.70 25 X5R 10uF ±10% CL32A106KATLNN# 24 2.00 25 X5R 10uF ±10% CL32A106KAULNN# 25 2.70 50 X5R 10uF ±10% CL32A106KBJNNN# 26 2.00 35 X5R 10uF ±10% CL32A106KLULNN# 27 0.95 16 X5R 10uF ±10% CL32A106KOCLNN# 28 2.70 16 X5R 10uF ±10% CL32A106KOJNNN# 29 2.20 10 X5R 10uF ±10% CL32A106KPINNN# 30 2.70 50 X5R 10uF ±20% CL32A106MBJNNN# 31 2.70 16 X5R 10uF ±20% CL32A106MOJNNN# 32 2.00 35 X5R 4.7uF ±10% CL32A475KLULNN# Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Product Line Up (X6S) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) 1 0.39 4 X6S 1uF ±20% CL03X105MR3NRN# 2 0.33 6.3 X6S 220nF ±10% CL03X224KQ3NNN# 3 0.33 6.3 X6S 100nF ±10% CL03X104KQ3NNN# Capacitance Capacitance Tolerance Part Number Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 0.70 4 X6S 10uF ±20% CL05X106MR5NUN# 2 0.70 4 X6S 4.7uF ±20% CL05X475MR5NUN# 3 0.57 6.3 X6S 2.2uF ±20% CL05X225MQ5NSN# 4 0.57 2.5 X6S 2.2uF ±20% CL05X225MS5NSN# 5 0.60 25 X6S 1uF ±10% CL05X105KA5NQN# 6 0.55 10 X6S 1uF ±10% CL05X105KP5NNN# 7 0.55 6.3 X6S 1uF ±10% CL05X105KQ5NFN# 8 0.55 6.3 X6S 1uF ±10% CL05X105KQ5NNN# 9 0.33 10 X6S 1uF ±20% CL05X105MP3JQN# MULTILAYER CERAMIC CAPACITORS 38 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 1.05 0.90 1.00 1.00 1.00 0.90 0.90 0.95 0.95 0.95 1.00 0.90 0.90 0.90 4 4 16 10 10 6.3 4 25 16 16 16 6.3 6.3 10 X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S 22uF 10uF 10uF 10uF 10uF 10uF 10uF 4.7uF 4.7uF 4.7uF 4.7uF 4.7uF 4.7uF 2.2uF ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±20% ±10% CL10X226MR8NUN# CL10X106KR8NNN# CL10X106MO8NRN# CL10X106MP8NFR# CL10X106MP8NRN# CL10X106MQ8NNN# CL10X106MR8NNN# CL10X475KA8NQN# CL10X475KO8NFQ# CL10X475KO8NQN# CL10X475KO8NRN# CL10X475KQ8NNN# CL10X475MQ8NNN# CL10X225KP8NNN# Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 1.45 1.40 1.40 1.40 1.40 0.95 1.45 1.40 0.95 1.45 1.40 1.40 1.35 1.40 1.35 4 6.3 6.3 4 4 2.5 25 16 10 10 6.3 16 4 25 16 X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S 47uF 22uF 22uF 22uF 22uF 22uF 10uF 10uF 10uF 10uF 10uF 10uF 10uF 4.7uF 2.2uF ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±20% ±20% ±10% ±10% CL21X476MRYNNN# CL21X226MQQNFN# CL21X226MQQNNN# CL21X226MRQNFN# CL21X226MRQNNN# CL21X226MSCLRN# CL21X106KAYNNN# CL21X106KOQNNN# CL21X106KPCLRN# CL21X106KPYNNN# CL21X106KQQNNN# CL21X106MOQNNN# CL21X106MRFNNN# CL21X475KAQNNN# CL21X225KOFNNN# Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 6.3 6.3 6.3 4 25 25 16 16 10 6.3 25 X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S 47uF 47uF 47uF 47uF 22uF 22uF 22uF 22uF 22uF 22uF 10uF ±10% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL31X476KQHNNN# CL31X476MQHNFN# CL31X476MQHNNN# CL31X476MRHNNN# CL31X226KAHN3N# CL31X226KAHNF3# CL31X226KOHN3N# CL31X226KOHNNN# CL31X226KPHN3N# CL31X226KQHNNN# CL31X106KAHNNN# MULTILAYER CERAMIC CAPACITORS 39 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2.70 6.3 X6S 100uF ±20% CL32X107MQVNNN# 2 2.70 10 X6S 47uF ±10% CL32X476KPJNNN# 3 2.70 16 X6S 10uF ±10% CL32X106KOJNNN# Capacitance Capacitance Tolerance Part Number Product Line Up (Y5V) Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 0.55 6.3 Y5V 1uF -20/+80% CL05F105ZQ5NNN# 2 0.55 10 Y5V 470nF -20/+80% CL05F474ZP5NNN# 3 0.55 10 Y5V 330nF -20/+80% CL05F334ZP5NNN# 4 0.55 16 Y5V 220nF -20/+80% CL05F224ZO5NNN# 5 0.55 10 Y5V 220nF -20/+80% CL05F224ZP5NNN# 6 0.55 16 Y5V 100nF -20/+80% CL05F104ZO5NNN# 7 0.55 16 Y5V 47nF -20/+80% CL05F473ZO5NNN# 8 0.55 25 Y5V 33nF -20/+80% CL05F333ZA5NNN# 9 0.55 16 Y5V 33nF -20/+80% CL05F333ZO5NNN# 10 0.55 25 Y5V 22nF -20/+80% CL05F223ZA5NNN# 11 0.55 16 Y5V 22nF -20/+80% CL05F223ZO5NNN# 12 0.55 50 Y5V 15nF -20/+80% CL05F153ZB5NNN# Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.90 10 Y5V 2.2uF -20/+80% CL10F225ZP8NNN# 2 0.90 6.3 Y5V 2.2uF -20/+80% CL10F225ZQ8NNN# 3 0.90 25 Y5V 470nF -20/+80% CL10F474ZA8NNN# 4 0.90 16 Y5V 470nF -20/+80% CL10F474ZO8NNN# 5 0.90 25 Y5V 330nF -20/+80% CL10F334ZA8NNN# 6 0.90 16 Y5V 330nF -20/+80% CL10F334ZO8NNN# 7 0.90 25 Y5V 150nF -20/+80% CL10F154ZA8NNN# 8 0.90 25 Y5V 100nF -20/+80% CL10F104ZA8NFN# CL10F104ZA8NNN# 9 0.90 25 Y5V 100nF -20/+80% 10 0.90 50 Y5V 100nF -20/+80% CL10F104ZB8NNN# 11 0.90 16 Y5V 100nF -20/+80% CL10F104ZO8NNN# 12 0.90 50 Y5V 68nF -20/+80% CL10F683ZB8NNN# 13 0.90 50 Y5V 39nF -20/+80% CL10F393ZB8NNN# 14 0.90 50 Y5V 33nF -20/+80% CL10F333ZB8NNN# 15 0.90 50 Y5V 22nF -20/+80% CL10F223ZB8NNN# 16 0.90 50 Y5V 10nF -20/+80% CL10F103ZB8NNN# MULTILAYER CERAMIC CAPACITORS 40 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 0.75 0.95 0.95 1.35 0.75 0.95 0.95 0.95 0.75 0.75 0.75 0.75 0.75 10 6.3 10 10 16 10 25 50 16 25 25 50 25 50 50 50 25 50 50 50 50 Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V 10uF 10uF 4.7uF 3.3uF 2.2uF 2.2uF 1uF 1uF 680nF 470nF 330nF 330nF 220nF 220nF 150nF 100nF 100nF 100nF 47nF 22nF 10nF -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% ±20% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% CL21F106ZPFNNN# CL21F106ZQFNNN# CL21F475ZPFNNN# CL21F335ZPFNNN# CL21F225ZOFNNN# CL21F225ZPFNNN# CL21F105ZAFNNN# CL21F105ZBFNNN# CL21F684ZOANNN# CL21F474ZACNNN# CL21F334ZACNNN# CL21F334ZBFNNN# CL21F224ZAANNN# CL21F224ZBCNNN# CL21F154ZBCNNN# CL21F104MBCNNN# CL21F104ZAANNN# CL21F104ZBANNN# CL21F473ZBANNN# CL21F223ZBANNN# CL21F103ZBANNN# Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 1.40 1.80 1.40 1.40 1.40 1.00 1.00 1.40 1.00 1.00 1.00 1.00 1.00 10 10 16 16 25 16 25 50 16 50 50 50 50 Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V Y5V 10uF 10uF 4.7uF 3.3uF 2.2uF 2.2uF 1uF 1uF 1uF 470nF 330nF 220nF 100nF -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% CL31F106ZPFNNN# CL31F106ZPHNNN# CL31F475ZOFNNN# CL31F335ZOFNNN# CL31F225ZAFNNN# CL31F225ZOCNNN# CL31F105ZACNNN# CL31F105ZBFNNN# CL31F105ZOCNNN# CL31F474ZBCNNN# CL31F334ZBCNNN# CL31F224ZBCNNN# CL31F104ZBCNNN# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 1.80 1.50 1.60 1.80 1.80 1.45 25 25 35 35 16 50 Y5V Y5V Y5V Y5V Y5V Y5V 10uF 10uF 10uF 10uF 10uF 1uF -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% -20/+80% CL32F106ZAHNNN# CL32F106ZASLNN# CL32F106ZLGNNN# CL32F106ZLHNNN# CL32F106ZOHNNN# CL32F105ZBFNNN# MULTILAYER CERAMIC CAPACITORS 41 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Product Line Up (X7R) Size : 0.20 × 0.10mm (inch : 01005) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.22 10 X7R 100pF ±10% CL02B101KP2NNN# 2 0.22 10 X7R 120pF ±10% CL02B121KP2NNN# 3 0.22 10 X7R 220pF ±10% CL02B221KP2NNN# 4 0.22 10 X7R 330pF ±10% CL02B331KP2NNN# 5 0.22 10 X7R 470pF ±10% CL02B471KP2NNN# 6 0.22 10 X7R 1nF ±10% CL02B102KP2NNN# 7 0.22 16 X7R 330pF ±10% CL02B331KO2NNN# Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.33 6.3 X7R 4.7nF ±10% CL03B472KQ3NNN# 2 0.33 6.3 X7R 10nF ±10% CL03B103KQ3NNN# 3 0.33 10 X7R 1.5nF ±10% CL03B152KP3NNN# 4 0.33 10 X7R 3.3nF ±10% CL03B332KP3NNN# 5 0.33 10 X7R 6.8nF ±10% CL03B682KP3NNN# 6 0.33 10 X7R 10nF ±10% CL03B103KP3NNN# 7 0.33 16 X7R 150pF ±10% CL03B151KO3NNN# 8 0.33 16 X7R 220pF ±10% CL03B221KO3NNN# 9 0.33 16 X7R 270pF ±10% CL03B271KO3NNN# 10 0.33 16 X7R 470pF ±10% CL03B471KO3NNN# 11 0.33 16 X7R 560pF ±10% CL03B561KO3NNN# 12 0.33 16 X7R 820pF ±10% CL03B821KO3NNN# 13 0.33 16 X7R 1nF ±10% CL03B102KO3NNN# 14 0.33 25 X7R 150pF ±10% CL03B151KA3NNN# 15 0.33 25 X7R 220pF ±10% CL03B221KA3NNN# 16 0.33 25 X7R 330pF ±10% CL03B331KA3NNN# 17 0.33 25 X7R 470pF ±10% CL03B471KA3NNN# 18 0.33 25 X7R 680pF ±10% CL03B681KA3NNN# 19 0.33 25 X7R 1nF ±5% CL03B102JA3NNN# 20 0.33 25 X7R 1nF ±10% CL03B102KA3NNN# Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.55 6.3 X7R 100nF ±10% CL05B104KQ5NNN# 2 0.55 6.3 X7R 470nF ±10% CL05B474KQ5NNN# 3 0.55 10 X7R 22nF ±10% CL05B223KP5NNN# 4 0.55 10 X7R 27nF ±10% CL05B273KP5NNN# 5 0.55 10 X7R 47nF ±10% CL05B473KP5NNN# 6 0.55 10 X7R 68nF ±10% CL05B683KP5NNN# 7 0.55 10 X7R 82nF ±10% CL05B823KP5NNN# 8 0.55 10 X7R 100nF ±10% CL05B104KP5NFN# MULTILAYER CERAMIC CAPACITORS 42 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 9 0.55 10 X7R 100nF ±10% CL05B104KP5NNN# 10 0.55 10 X7R 100nF ±20% CL05B104MP5NNN# 11 0.55 10 X7R 220nF ±10% CL05B224KP5NNN# 12 0.55 10 X7R 470nF ±10% CL05B474KP5NNN# 13 0.55 16 X7R 820pF ±10% CL05B821KO5NNN# 14 0.55 16 X7R 8.2nF ±10% CL05B822KO5NNN# 15 0.55 16 X7R 10nF ±5% CL05B103JO5NNN# 16 0.55 16 X7R 10nF ±10% CL05B103KO5NCN# 17 0.55 16 X7R 10nF ±10% CL05B103KO5NFN# 18 0.55 16 X7R 10nF ±10% CL05B103KO5NNN# 19 0.55 16 X7R 22nF ±5% CL05B223JO5NNN# 20 0.55 16 X7R 22nF ±10% CL05B223KO5NFN# 21 0.55 16 X7R 22nF ±10% CL05B223KO5NNN# 22 0.55 16 X7R 27nF ±10% CL05B273KO5NNN# 23 0.55 16 X7R 33nF ±5% CL05B333JO5NNN# 24 0.55 16 X7R 33nF ±10% CL05B333KO5NFN# 25 0.55 16 X7R 33nF ±10% CL05B333KO5NNN# 26 0.55 16 X7R 47nF ±5% CL05B473JO5NNN# 27 0.55 16 X7R 47nF ±10% CL05B473KO5NFN# 28 0.55 16 X7R 47nF ±10% CL05B473KO5NNN# 29 0.55 16 X7R 68nF ±10% CL05B683KO5NNN# 30 0.33 16 X7R 100nF ±10% CL05B104KO3LNN# 31 0.55 16 X7R 100nF ±5% CL05B104JO5NNN# 32 0.55 16 X7R 100nF ±10% CL05B104KO5NFN# 33 0.55 16 X7R 100nF ±10% CL05B104KO5NNN# 34 0.55 16 X7R 100nF ±20% CL05B104MO5NNN# 35 0.55 16 X7R 220nF ±10% CL05B224KO5NFN# 36 0.55 16 X7R 220nF ±10% CL05B224KO5NNN# 37 0.55 25 X7R 560pF ±10% CL05B561KA5NNN# 38 0.55 25 X7R 1.5nF ±10% CL05B152KA5NNN# 39 0.55 25 X7R 3.3nF ±5% CL05B332JA5NNN# 40 0.55 25 X7R 4.7nF ±10% CL05B472KA5NFN# 41 0.55 25 X7R 4.7nF ±10% CL05B472KA5NNN# 42 0.55 25 X7R 5.6nF ±10% CL05B562KA5NNN# 43 0.55 25 X7R 6.8nF ±10% CL05B682KA5NNN# 44 0.55 25 X7R 8.2nF ±10% CL05B822KA5NNN# 45 0.55 25 X7R 10nF ±10% CL05B103KA5NFN# 46 0.55 25 X7R 10nF ±10% CL05B103KA5NNN# 47 0.55 25 X7R 18nF ±10% CL05B183KA5NNN# 48 0.55 25 X7R 22nF ±10% CL05B223KA5NNN# 49 0.55 25 X7R 47nF ±10% CL05B473KA5NNN# 50 0.55 25 X7R 100nF ±10% CL05B104KA5NNN# 51 0.55 50 X7R 180pF ±10% CL05B181KB5NNN# 52 0.55 50 X7R 220pF ±5% CL05B221JB5NNN# 53 0.55 50 X7R 220pF ±10% CL05B221KB5NNN# 54 0.55 50 X7R 300pF ±10% CL05B301KB5NNN# 55 0.55 50 X7R 330pF ±5% CL05B331JB5NNN# MULTILAYER CERAMIC CAPACITORS 43 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 56 0.55 50 X7R 330pF ±10% CL05B331KB5NNN# 57 0.55 50 X7R 390pF ±10% CL05B391KB5NNN# 58 0.55 50 X7R 470pF ±10% CL05B471KB5NFN# 59 0.55 50 X7R 470pF ±10% CL05B471KB5NNN# 60 0.55 50 X7R 560pF ±5% CL05B561JB5NNN# 61 0.55 50 X7R 680pF ±5% CL05B681JB5NNN# 62 0.55 50 X7R 680pF ±10% CL05B681KB5NNN# 63 0.55 50 X7R 1nF ±5% CL05B102JB5NNN# 64 0.55 50 X7R 1nF ±10% CL05B102KB5NCN# 65 0.55 50 X7R 1nF ±10% CL05B102KB5NFN# 66 0.55 50 X7R 1nF ±10% CL05B102KB5NNN# 67 0.55 50 X7R 1.2nF ±5% CL05B122JB5NNN# 68 0.55 50 X7R 1.5nF ±5% CL05B152JB5NNN# 69 0.55 50 X7R 1.5nF ±10% CL05B152KB5NNN# 70 0.55 50 X7R 1.8nF ±10% CL05B182KB5NNN# 71 0.55 50 X7R 2.2nF ±5% CL05B222JB5NNN# 72 0.55 50 X7R 2.2nF ±10% CL05B222KB5NFN# 73 0.55 50 X7R 2.2nF ±10% CL05B222KB5NNN# 74 0.55 50 X7R 2.7nF ±10% CL05B272KB5NNN# 75 0.55 50 X7R 3.3nF ±10% CL05B332KB5NFN# 76 0.55 50 X7R 3.3nF ±10% CL05B332KB5NNN# 77 0.55 50 X7R 3.9nF ±10% CL05B392KB5NNN# 78 0.55 50 X7R 4.7nF ±5% CL05B472JB5NNN# 79 0.55 50 X7R 4.7nF ±10% CL05B472KB5NFN# 80 0.55 50 X7R 4.7nF ±10% CL05B472KB5NNN# 81 0.55 50 X7R 5.6nF ±10% CL05B562KB5NFN# 82 0.55 50 X7R 5.6nF ±10% CL05B562KB5NNN# 83 0.55 50 X7R 6.8nF ±5% CL05B682JB5NNN# 84 0.55 50 X7R 6.8nF ±10% CL05B682KB5NNN# 85 0.55 50 X7R 8.2nF ±10% CL05B822KB5NNN# 86 0.55 50 X7R 10nF ±10% CL05B103KB5NFN# 87 0.55 50 X7R 10nF ±10% CL05B103KB5NNN# 88 0.55 50 X7R 15nF ±10% CL05B153KB5NNN# 89 0.55 50 X7R 22nF ±10% CL05B223KB5NNN# 90 0.55 50 X7R 100nF ±10% CL05B104KB5NFN# 91 0.55 50 X7R 100nF ±10% CL05B104KB5NNN# Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.90 6.3 X7R 470nF ±10% CL10B474KQ8NNN# 2 0.90 6.3 X7R 680nF ±10% CL10B684KQ8NNN# 3 0.90 6.3 X7R 1uF ±10% CL10B105KQ8NNN# 4 0.90 6.3 X7R 2.2uF ±10% CL10B225KQ8NFN# 5 0.90 6.3 X7R 2.2uF ±10% CL10B225KQ8NNN# 6 0.95 6.3 X7R 4.7uF ±10% CL10B475KQ8NFQ# MULTILAYER CERAMIC CAPACITORS 44 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 7 0.95 6.3 X7R 4.7uF ±10% CL10B475KQ8NQN# 8 0.95 6.3 X7R 4.7uF ±20% CL10B475MQ8NQN# Part Number 9 1.00 6.3 X7R 10uF ±20% CL10B106MQ8NFR# 10 1.00 6.3 X7R 10uF ±20% CL10B106MQ8NRN# 11 0.90 10 X7R 220nF ±5% CL10B224JP8NNN# 12 0.90 10 X7R 220nF ±10% CL10B224KP8NFN# 13 0.90 10 X7R 330nF ±10% CL10B334KP8NNN# 14 0.90 10 X7R 470nF ±10% CL10B474KP8NNN# 15 0.90 10 X7R 1uF ±10% CL10B105KP8NFN# 16 0.90 10 X7R 1uF ±10% CL10B105KP8NNN# 17 0.90 10 X7R 2.2uF ±10% CL10B225KP8NFN# 18 0.90 10 X7R 2.2uF ±10% CL10B225KP8NNN# 19 0.90 16 X7R 10nF ±10% CL10B103KO8NNN# 20 0.90 16 X7R 15nF ±10% CL10B153KO8NNN# 21 0.90 16 X7R 22nF ±10% CL10B223KO8NNN# 22 0.90 16 X7R 27nF ±10% CL10B273KO8NNN# 23 0.90 16 X7R 33nF ±10% CL10B333KO8NFN# 24 0.90 16 X7R 39nF ±10% CL10B393KO8NNN# 25 0.90 16 X7R 47nF ±5% CL10B473JO8NNN# 26 0.90 16 X7R 47nF ±10% CL10B473KO8NFN# 27 0.90 16 X7R 47nF ±10% CL10B473KO8NNN# 28 0.90 16 X7R 56nF ±10% CL10B563KO8NNN# 29 0.90 16 X7R 82nF ±10% CL10B823KO8NNN# 30 0.90 16 X7R 100nF ±10% CL10B104KO8NFN# 31 0.90 16 X7R 100nF ±10% CL10B104KO8NNN# 32 0.90 16 X7R 150nF ±10% CL10B154KO8NFN# 33 0.90 16 X7R 150nF ±10% CL10B154KO8NNN# 34 0.90 16 X7R 220nF ±5% CL10B224JO8NNN# 35 0.90 16 X7R 220nF ±5% CL10B224JO8SFN# 36 0.90 16 X7R 220nF ±10% CL10B224KO8NFN# 37 0.90 16 X7R 220nF ±10% CL10B224KO8NNN# 38 0.90 16 X7R 220nF ±10% CL10B224KO8SFN# 39 0.90 16 X7R 330nF ±10% CL10B334KO8NFN# 40 0.90 16 X7R 330nF ±10% CL10B334KO8NNN# 41 0.90 16 X7R 470nF ±10% CL10B474KO8NFN# 42 0.90 16 X7R 470nF ±10% CL10B474KO8NNN# 43 0.90 16 X7R 680nF ±10% CL10B684KO8NFN# 44 0.90 16 X7R 1uF ±10% CL10B105KO8NFN# 45 0.90 16 X7R 1uF ±10% CL10B105KO8NNN# 46 0.90 16 X7R 1uF ±10% CL10B105KO8ZFN# 47 0.90 25 X7R 4.7nF ±10% CL10B472KA8NNN# 48 0.90 25 X7R 10nF ±10% CL10B103KA8NFN# 49 0.90 25 X7R 10nF ±10% CL10B103KA8NNN# 50 0.90 25 X7R 22nF ±10% CL10B223KA8NFN# 51 0.90 25 X7R 27nF ±10% CL10B273KA8NNN# 52 0.90 25 X7R 47nF ±10% CL10B473KA8NFN# 53 0.90 25 X7R 56nF ±10% CL10B563KA8NNN# MULTILAYER CERAMIC CAPACITORS 45 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 54 0.90 25 55 0.90 25 X7R 68nF ±10% CL10B683KA8NNN# X7R 100nF ±5% 56 0.90 CL10B104JA8NNN# 25 X7R 100nF ±10% CL10B104KA8NFN# 57 0.90 25 X7R 100nF ±10% CL10B104KA8NNN# 58 0.90 25 X7R 150nF ±10% CL10B154KA8NFN# 59 0.90 25 X7R 220nF ±10% CL10B224KA8NFN# 60 0.90 25 X7R 220nF ±10% CL10B224KA8NNN# 61 0.90 25 X7R 220nF ±10% CL10B224KA8SFN# 62 0.90 25 X7R 470nF ±10% CL10B474KA8NFN# 63 0.90 25 X7R 470nF ±10% CL10B474KA8NNN# 64 0.90 25 X7R 1uF ±10% CL10B105KA8NFN# 65 0.90 25 X7R 1uF ±10% CL10B105KA8NNN# 66 0.90 25 X7R 1uF ±10% CL10B105KA8ZFN# 67 0.90 50 X7R 100pF ±10% CL10B101KB8NFN# 68 0.90 50 X7R 120pF ±10% CL10B121KB8NNN# 69 0.90 50 X7R 150pF ±10% CL10B151KB8NNN# 70 0.90 50 X7R 200pF ±10% CL10B201KB8NNN# 71 0.90 50 X7R 220pF ±5% CL10B221JB8NNN# 72 0.90 50 X7R 220pF ±10% CL10B221KB8NFN# 73 0.90 50 X7R 220pF ±10% CL10B221KB8NNN# 74 0.90 50 X7R 300pF ±10% CL10B301KB8NNN# 75 0.90 50 X7R 330pF ±5% CL10B331JB8NNN# 76 0.90 50 X7R 330pF ±10% CL10B331KB8NFN# 77 0.90 50 X7R 330pF ±10% CL10B331KB8NNN# 78 0.90 50 X7R 390pF ±10% CL10B391KB8NNN# 79 0.90 50 X7R 470pF ±5% CL10B471JB8NNN# 80 0.90 50 X7R 470pF ±10% CL10B471KB8NFN# 81 0.90 50 X7R 470pF ±10% CL10B471KB8NNN# 82 0.90 50 X7R 510pF ±10% CL10B511KB8NNN# 83 0.90 50 X7R 560pF ±5% CL10B561JB8NNN# 84 0.90 50 X7R 680pF ±5% CL10B681JB8NNN# 85 0.90 50 X7R 680pF ±10% CL10B681KB8NFN# 86 0.90 50 X7R 820pF ±10% CL10B821KB8NFN# 87 0.90 50 X7R 1nF ±5% CL10B102JB8NFN# 88 0.90 50 X7R 1nF ±10% CL10B102KB8NCN# 89 0.90 50 X7R 1nF ±10% CL10B102KB8NFN# 90 0.90 50 X7R 1nF ±10% CL10B102KB8NNN# 91 0.90 50 X7R 1nF ±10% CL10B102KB8SFN# 92 0.90 50 X7R 1.2nF ±10% CL10B122KB8NFN# 93 0.90 50 X7R 1.2nF ±10% CL10B122KB8NNN# 94 0.90 50 X7R 1.5nF ±10% CL10B152KB8NFN# 95 0.90 50 X7R 1.5nF ±10% CL10B152KB8NNN# 96 0.90 50 X7R 1.5nF ±10% CL10B152KB8SFN# 97 0.90 50 X7R 1.8nF ±10% CL10B182KB8NFN# 98 0.90 50 X7R 2nF ±10% CL10B202KB8NNN# 99 0.90 50 X7R 2.2nF ±10% CL10B222KB8NFN# 100 0.90 50 X7R 2.2nF ±10% CL10B222KB8NNN# MULTILAYER CERAMIC CAPACITORS 46 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 101 0.90 50 X7R 2.2nF ±10% CL10B222KB8SFN# 102 0.90 50 X7R 2.7nF ±5% CL10B272JB8NNN# 103 0.90 50 X7R 2.7nF ±10% CL10B272KB8NFN# 104 0.90 50 X7R 2.7nF ±10% CL10B272KB8NNN# 105 0.90 50 X7R 3.3nF ±10% CL10B332KB8NFN# 106 0.90 50 X7R 3.3nF ±10% CL10B332KB8NNN# 107 0.90 50 X7R 3.3nF ±20% CL10B332MB8NNN# 108 0.90 50 X7R 3.9nF ±10% CL10B392KB8NFN# 109 0.90 50 X7R 3.9nF ±10% CL10B392KB8NNN# 110 0.90 50 X7R 4.7nF ±10% CL10B472KB8NFN# 111 0.90 50 X7R 4.7nF ±10% CL10B472KB8NNN# 112 0.90 50 X7R 4.7nF ±10% CL10B472KB8SFN# 113 0.90 50 X7R 5.6nF ±5% CL10B562JB8NNN# 114 0.90 50 X7R 5.6nF ±10% CL10B562KB8NFN# 115 0.90 50 X7R 5.6nF ±10% CL10B562KB8NNN# 116 0.90 50 X7R 6.8nF ±5% CL10B682JB8NNN# 117 0.90 50 X7R 6.8nF ±10% CL10B682KB8NFN# 118 0.90 50 X7R 6.8nF ±10% CL10B682KB8NNN# 119 0.90 50 X7R 8.2nF ±10% CL10B822KB8NFN# 120 0.90 50 X7R 10nF ±5% CL10B103JB8NFN# 121 0.90 50 X7R 10nF ±10% CL10B103KB8NFN# 122 0.90 50 X7R 10nF ±10% CL10B103KB8NNN# 123 0.90 50 X7R 10nF ±20% CL10B103MB8NCN# 124 0.90 50 X7R 10nF ±20% CL10B103MB8NNN# 125 0.90 50 X7R 12nF ±10% CL10B123KB8NNN# 126 0.90 50 X7R 15nF ±10% CL10B153KB8NFN# 127 0.90 50 X7R 15nF ±10% CL10B153KB8NNN# 128 0.90 50 X7R 18nF ±5% CL10B183JB8NNN# 129 0.90 50 X7R 20nF ±10% CL10B203KB8NNN# 130 0.90 50 X7R 22nF ±5% CL10B223JB8NFN# 131 0.90 50 X7R 22nF ±10% CL10B223KB8NFN# 132 0.90 50 X7R 22nF ±10% CL10B223KB8NNN# 133 0.90 50 X7R 22nF ±10% CL10B223KB8SFN# 134 0.90 50 X7R 27nF ±10% CL10B273KB8NNN# 135 0.90 50 X7R 33nF ±10% CL10B333KB8NFN# 136 0.90 50 X7R 33nF ±10% CL10B333KB8NNN# 137 0.90 50 X7R 33nF ±10% CL10B333KB8SFN# 138 0.90 50 X7R 39nF ±10% CL10B393KB8NNN# 139 0.90 50 X7R 47nF ±5% CL10B473JB8NNN# 140 0.90 50 X7R 47nF ±10% CL10B473KB8NFN# 141 0.90 50 X7R 47nF ±10% CL10B473KB8NNN# 142 0.90 50 X7R 47nF ±10% CL10B473KB8SFN# 143 0.90 50 X7R 56nF ±10% CL10B563KB8SFN# 144 0.90 50 X7R 68nF ±10% CL10B683KB8NFN# 145 0.90 50 X7R 68nF ±10% CL10B683KB8NNN# 146 0.90 50 X7R 82nF ±10% CL10B823KB8NFN# 147 0.90 50 X7R 100nF ±5% CL10B104JB8NNN# MULTILAYER CERAMIC CAPACITORS Part Number 47 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 148 0.90 50 X7R 100nF ±10% CL10B104KB8NFN# 149 0.90 50 X7R 100nF ±10% CL10B104KB8NNN# 150 0.90 50 X7R 100nF ±10% CL10B104KB8SFN# 151 0.90 50 X7R 100nF ±20% CL10B104MB8NFN# 152 0.90 50 X7R 100nF ±20% CL10B104MB8NNN# 153 0.90 50 X7R 220nF ±10% CL10B224KB8NFN# 154 0.90 50 X7R 220nF ±10% CL10B224KB8NNN# 155 0.90 50 X7R 220nF ±10% CL10B224KB8SFN# 156 0.95 50 X7R 1uF ±10% CL10B105KB8NQN# 157 0.90 100 X7R 1nF ±10% CL10B102KC8NFN# 158 0.90 100 X7R 1nF ±10% CL10B102KC8NNN# 159 0.90 100 X7R 1.5nF ±10% CL10B152KC8NNN# 160 0.90 100 X7R 3.3nF ±10% CL10B332KC8NNN# 161 0.90 100 X7R 4.7nF ±10% CL10B472KC8NNN# 162 0.90 100 X7R 10nF ±10% CL10B103KC8NNN# 163 0.90 100 X7R 100nF ±10% CL10B104KC8NNN# Part Number Part Number Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 1.40 6.3 X7R 10uF ±10% CL21B106KQQNFN# 2 1.40 6.3 X7R 10uF ±10% CL21B106KQQNNN# 3 1.35 10 X7R 680nF ±10% CL21B684KPFNNN# 4 1.35 10 X7R 1uF ±10% CL21B105KPFNNN# 5 1.35 10 X7R 1uF ±20% CL21B105MPFNNN# 6 1.35 10 X7R 2.2uF ±10% CL21B225KPFNNN# 7 1.35 10 X7R 3.3uF ±10% CL21B335KPFNNN# 8 1.35 10 X7R 4.7uF ±10% CL21B475KPFN3N# 9 1.35 10 X7R 4.7uF ±10% CL21B475KPFNFN# 10 1.35 10 X7R 4.7uF ±10% CL21B475KPFNNN# 11 1.40 10 X7R 10uF ±10% CL21B106KPQNFN# 12 1.40 10 X7R 10uF ±10% CL21B106KPQNNN# 13 1.40 10 X7R 10uF ±10% CL21B106KPQZFN# 14 0.75 16 X7R 100nF ±10% CL21B104KOANNN# 15 0.75 16 X7R 180nF ±10% CL21B184KOANNN# 16 1.35 16 X7R 220nF ±10% CL21B224KOFNNN# 17 0.95 16 X7R 330nF ±10% CL21B334KOCNNN# 18 1.35 16 X7R 470nF ±10% CL21B474KOFNFN# 19 1.35 16 X7R 470nF ±10% CL21B474KOFNNN# 20 1.35 16 X7R 680nF ±5% CL21B684JOFNNN# 21 1.35 16 X7R 680nF ±10% CL21B684KOFNFN# 22 1.35 16 X7R 1uF ±10% CL21B105KOFNFN# 23 1.35 16 X7R 1uF ±10% CL21B105KOFNNN# 24 1.35 16 X7R 1uF ±10% CL21B105KOFSFN# 25 1.35 16 X7R 1uF ±20% CL21B105MOFNNN# 26 1.35 16 X7R 2.2uF ±10% CL21B225KOFNFN# MULTILAYER CERAMIC CAPACITORS 48 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 27 1.35 16 X7R 2.2uF ±10% CL21B225KOFNNN# 28 1.35 16 X7R 4.7uF ±10% CL21B475KOFNFN# 29 1.35 16 X7R 4.7uF ±10% CL21B475KOFNNN# 30 1.35 16 X7R 4.7uF ±10% CL21B475KOFZFN# 31 1.40 16 X7R 10uF ±10% CL21B106KOQNFN# 32 1.40 16 X7R 10uF ±10% CL21B106KOQNNN# 33 0.75 25 X7R 1nF ±10% CL21B102KAANFN# 34 0.75 25 X7R 10nF ±10% CL21B103KAANNN# 35 0.95 25 X7R 100nF ±10% CL21B104KACNFN# 36 0.95 25 X7R 100nF ±10% CL21B104KACNNN# 37 0.95 25 X7R 100nF ±20% CL21B104MACNNN# 38 1.35 25 X7R 100nF ±10% CL21B104KAFNNN# 39 0.95 25 X7R 120nF ±5% CL21B124JACNNN# 40 0.95 25 X7R 120nF ±10% CL21B124KACNNN# 41 1.35 25 X7R 220nF ±5% CL21B224JAFNNN# 42 1.35 25 X7R 220nF ±10% CL21B224KAFNFN# 43 1.35 25 X7R 220nF ±10% CL21B224KAFNNN# 44 1.35 25 X7R 470nF ±5% CL21B474JAFNNN# 45 1.35 25 X7R 470nF ±10% CL21B474KAFNFN# 46 1.35 25 X7R 470nF ±10% CL21B474KAFNNN# 47 1.35 25 X7R 470nF ±10% CL21B474KAFSFN# 48 1.35 25 X7R 470nF ±20% CL21B474MAFNNN# 49 1.35 25 X7R 1uF ±10% CL21B105KAFN3N# 50 1.35 25 X7R 1uF ±10% CL21B105KAFNFN# 51 1.35 25 X7R 1uF ±10% CL21B105KAFNNN# 52 1.35 25 X7R 1uF ±10% CL21B105KAFSFN# 53 1.35 25 X7R 1uF ±20% CL21B105MAFNNN# 54 1.35 25 X7R 1.5uF ±10% CL21B155KAFNFN# 55 1.35 25 X7R 2.2uF ±10% CL21B225KAFNFN# 56 1.35 25 X7R 2.2uF ±10% CL21B225KAFNNN# 57 1.35 25 X7R 2.2uF ±20% CL21B225MAFNNN# 58 1.35 25 X7R 3.3uF ±10% CL21B335KAFNFN# 59 1.35 25 X7R 4.7uF ±10% CL21B475KAFNFN# 60 1.35 25 X7R 4.7uF ±10% CL21B475KAFNNN# 61 1.35 25 X7R 4.7uF ±10% CL21B475KAFZF6# 62 1.35 25 X7R 4.7uF ±10% CL21B475KAFZFN# 63 1.35 25 X7R 4.7uF ±20% CL21B475MAFNNN# 64 0.75 50 X7R 180pF ±10% CL21B181KBANNN# 65 0.75 50 X7R 200pF ±10% CL21B201KBANNN# 66 0.75 50 X7R 220pF ±10% CL21B221KBANFN# 67 0.75 50 X7R 300pF ±10% CL21B301KBANNN# 68 0.75 50 X7R 330pF ±5% CL21B331JBANNN# 69 0.75 50 X7R 470pF ±5% CL21B471JBANNN# 70 0.75 50 X7R 470pF ±10% CL21B471KBANFN# 71 0.75 50 X7R 510pF ±10% CL21B511KBANNN# 72 0.75 50 X7R 680pF ±10% CL21B681KBANFN# 73 0.75 50 X7R 1nF ±5% CL21B102JBANFN# MULTILAYER CERAMIC CAPACITORS 49 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 74 0.75 50 X7R 1nF ±10% CL21B102KBANFN# 75 0.75 50 X7R 1nF ±10% CL21B102KBANNN# 76 0.95 50 X7R 1nF ±10% CL21B102KBCNNN# 77 0.75 50 X7R 1.2nF ±10% CL21B122KBANNN# 78 0.75 50 X7R 2nF ±10% CL21B202KBANNN# 79 0.75 50 X7R 2.2nF ±5% CL21B222JBANNN# 80 0.75 50 X7R 2.2nF ±10% CL21B222KBANFN# 81 0.75 50 X7R 2.2nF ±10% CL21B222KBANNN# 82 0.95 50 X7R 2.2nF ±10% CL21B222KBCNNN# 83 0.75 50 X7R 2.7nF ±10% CL21B272KBANNN# 84 0.75 50 X7R 3.3nF ±5% CL21B332JBANNN# 85 0.75 50 X7R 3.9nF ±10% CL21B392KBANNN# 86 0.75 50 X7R 4.7nF ±10% CL21B472KBANFN# 87 0.75 50 X7R 4.7nF ±10% CL21B472KBANNN# 88 0.75 50 X7R 5.6nF ±5% CL21B562JBANNN# 89 0.75 50 X7R 5.6nF ±10% CL21B562KBANFN# 90 0.75 50 X7R 5.6nF ±10% CL21B562KBANNN# 91 0.75 50 X7R 6.8nF ±10% CL21B682KBANFN# 92 0.75 50 X7R 8.2nF ±10% CL21B822KBANNN# 93 0.75 50 X7R 10nF ±10% CL21B103KBANFN# 94 0.75 50 X7R 10nF ±10% CL21B103KBANNN# 95 0.75 50 X7R 10nF ±20% CL21B103MBANNN# 96 0.95 50 X7R 10nF ±5% CL21B103JBCNNN# 97 0.95 50 X7R 10nF ±10% CL21B103KBCNNN# 98 0.75 50 X7R 15nF ±5% CL21B153JBANNN# 99 0.75 50 X7R 15nF ±10% CL21B153KBANFN# 100 0.75 50 X7R 18nF ±10% CL21B183KBANNN# 101 0.75 50 X7R 20nF ±10% CL21B203KBANNN# 102 0.75 50 X7R 22nF ±5% CL21B223JBANNN# 103 0.75 50 X7R 22nF ±10% CL21B223KBANFN# 104 0.75 50 X7R 22nF ±10% CL21B223KBANNN# 105 0.75 50 X7R 27nF ±10% CL21B273KBANNN# 106 0.75 50 X7R 33nF ±10% CL21B333KBANFN# 107 0.75 50 X7R 39nF ±10% CL21B393KBANNN# 108 0.95 50 X7R 47nF ±10% CL21B473KBCNFN# 109 0.95 50 X7R 47nF ±10% CL21B473KBCNNN# 110 0.95 50 X7R 47nF ±20% CL21B473MBCNNN# 111 0.95 50 X7R 56nF ±10% CL21B563KBCNNN# 112 0.95 50 X7R 68nF ±5% CL21B683JBCNNN# 113 0.95 50 X7R 68nF ±10% CL21B683KBCNFN# 114 1.35 50 X7R 68nF ±10% CL21B683KBFNNN# 115 0.95 50 X7R 82nF ±10% CL21B823KBCNNN# 116 1.35 50 X7R 82nF ±10% CL21B823KBFNNN# 117 0.95 50 X7R 100nF ±5% CL21B104JBCNFN# 118 0.95 50 X7R 100nF ±10% CL21B104KBCNFN# 119 0.95 50 X7R 100nF ±10% CL21B104KBCNNN# 120 0.95 50 X7R 100nF ±10% CL21B104KBCSFN# MULTILAYER CERAMIC CAPACITORS Part Number 50 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 121 1.35 50 X7R 100nF ±10% CL21B104KBFNNN# 122 1.35 50 X7R 100nF ±20% CL21B104MBFNNN# 123 1.35 50 X7R 120nF ±10% CL21B124KBFNNN# 124 1.35 50 X7R 150nF ±10% CL21B154KBFNFN# 125 1.35 50 X7R 150nF ±10% CL21B154KBFNNN# 126 1.35 50 X7R 220nF ±10% CL21B224KBFNFN# 127 1.35 50 X7R 220nF ±10% CL21B224KBFNNN# 128 1.35 50 X7R 330nF ±10% CL21B334KBFNFN# 129 1.35 50 X7R 330nF ±10% CL21B334KBFNNN# 130 1.35 50 X7R 330nF ±20% CL21B334MBFNNN# 131 1.35 50 X7R 470nF ±10% CL21B474KBFNFN# 132 1.35 50 X7R 470nF ±10% CL21B474KBFNNN# 133 1.35 50 X7R 680nF ±10% CL21B684KBFNNN# 134 1.35 50 X7R 1uF ±10% CL21B105KBFNFN# 135 1.35 50 X7R 1uF ±10% CL21B105KBFNNN# 136 1.35 50 X7R 1uF ±10% CL21B105KBFSFN# 137 1.35 50 X7R 1uF ±10% CL21B105KBFZFN# 138 1.35 50 X7R 1uF ±20% CL21B105MBFNNN# 139 0.75 100 X7R 220pF ±10% CL21B221KCANFN# 140 0.75 100 X7R 270pF ±10% CL21B271KCANNN# 141 0.75 100 X7R 1nF ±5% CL21B102JCANNN# 142 0.75 100 X7R 1nF ±10% CL21B102KCANNN# 143 0.75 100 X7R 1.5nF ±10% CL21B152KCANNN# 144 0.75 100 X7R 2.2nF ±10% CL21B222KCANFN# 145 0.75 100 X7R 4.7nF ±10% CL21B472KCANFN# 146 0.75 100 X7R 10nF ±10% CL21B103KCANFN# 147 0.75 100 X7R 10nF ±10% CL21B103KCANNN# 148 0.95 100 X7R 15nF ±10% CL21B153KCCNNN# 149 1.35 100 X7R 22nF ±10% CL21B223KCFNNN# 150 1.35 100 X7R 47nF ±10% CL21B473KCFNNN# 151 1.35 100 X7R 100nF ±10% CL21B104KCFNNN# 152 1.35 100 X7R 100nF ±10% CL21B104KCFSFN# 153 1.35 100 X7R 220nF ±10% CL21B224KCFSFN# 154 0.95 200 X7R 220pF ±10% CL21B221KDCNFN# 155 0.95 200 X7R 470pF ±10% CL21B471KDCNFN# 156 0.95 200 X7R 1nF ±5% CL21B102JDCNNN# 157 0.95 200 X7R 1nF ±10% CL21B102KDCNFN# 158 0.95 200 X7R 2.2nF ±10% CL21B222KDCNFN# 159 0.95 200 X7R 4.7nF ±10% CL21B472KDCNNN# 160 0.95 200 X7R 10nF ±10% CL21B103KDCNFN# 161 0.95 200 X7R 10nF ±10% CL21B103KDCNNN# 162 0.95 250 X7R 1nF ±10% CL21B102KECSFN# 163 0.95 250 X7R 1nF ±10% CL21B102KECSNN# 164 1.35 250 X7R 10nF ±10% CL21B103KEFNNN# MULTILAYER CERAMIC CAPACITORS Part Number 51 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.00 1.00 1.00 1.40 1.40 1.40 1.40 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.00 1.00 1.00 1.80 1.25 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.00 1.00 6.3 6.3 6.3 10 10 10 10 10 10 10 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 35 35 35 50 50 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 10uF 10uF 22uF 4.7uF 4.7uF 10uF 10uF 22uF 22uF 22uF 330nF 470nF 680nF 1uF 1uF 1uF 1.5uF 2.2uF 2.2uF 2.2uF 3.3uF 3.3uF 4.7uF 4.7uF 10uF 10uF 10uF 10uF 220nF 220nF 330nF 680nF 1uF 1uF 1uF 1uF 1uF 2.2uF 2.2uF 4.7uF 4.7uF 10uF 10uF 10uF 10uF 10uF 10uF 330pF 560pF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL31B106KQHNFN# CL31B106KQHNNN# CL31B226KQHNNN# CL31B475KPHNFN# CL31B475KPHNNN# CL31B106KPHNFN# CL31B106KPHNNN# CL31B226KPHNFN# CL31B226KPHNNN# CL31B226MPHNNN# CL31B334KOCNNN# CL31B474KOCNNN# CL31B684KOCNNN# CL31B105KOFNFN# CL31B105KOFNNN# CL31B105MOFNNN# CL31B155KOFNNN# CL31B225KOHNFN# CL31B225KOHNNN# CL31B225MOHNNN# CL31B335KOHNFN# CL31B335KOHNNN# CL31B475KOHNFN# CL31B475KOHNNN# CL31B106KOHNFN# CL31B106KOHNNN# CL31B106KOHZFN# CL31B106MOHNNN# CL31B224KACNFN# CL31B224KACNNN# CL31B334KACNNN# CL31B684KAHNNN# CL31B105KAPLNN# CL31B105JAHNNN# CL31B105KAHNFN# CL31B105KAHNNN# CL31B105MAHNNN# CL31B225KAHNFN# CL31B225KAHNNN# CL31B475KAHNFN# CL31B475KAHNNN# CL31B106KAHNFN# CL31B106KAHNNN# CL31B106KAHSFN# CL31B106KLHNFN# CL31B106KLHNNN# CL31B106KLHSFN# CL31B331KBCNNN# CL31B561KBCNNN# MULTILAYER CERAMIC CAPACITORS 52 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.40 1.40 1.40 1.40 1.40 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.00 1.00 1.00 1.00 1.00 1.00 1.40 1.40 1.40 1.80 1.80 1.80 1.80 1.80 1.80 1.80 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 680pF 1nF 1.5nF 3.3nF 8.2nF 10nF 10nF 33nF 47nF 47nF 100nF 100nF 100nF 150nF 220nF 220nF 330nF 330nF 330nF 470nF 470nF 470nF 1uF 1uF 1uF 2.2uF 2.2uF 4.7uF 4.7uF 4.7uF 4.7uF 10uF 10uF 2.2nF 3.3nF 10nF 22nF 22nF 33nF 100nF 100nF 100nF 470nF 1uF 1uF 1uF 1uF 2.2uF 2.2uF ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±5% ±5% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL31B681KBCNNN# CL31B102KBCNNN# CL31B152KBCNNN# CL31B332KBCNNN# CL31B822KBCNNN# CL31B103KBCNFN# CL31B103MBCNNN# CL31B333JBCNNN# CL31B473JBCNNN# CL31B473KBCNNN# CL31B104KBCNFN# CL31B104KBCNNN# CL31B104MBCNNN# CL31B154KBCNNN# CL31B224KBFNFN# CL31B224KBFNNN# CL31B334JBFNNN# CL31B334KBFNFN# CL31B334KBFNNN# CL31B474KBHNFN# CL31B474KBHNNN# CL31B474MBHNNN# CL31B105KBHNFN# CL31B105KBHNNN# CL31B105KBHSNN# CL31B225KBHNFN# CL31B225KBHNNN# CL31B475KBHN3N# CL31B475KBHNFN# CL31B475KBHNNN# CL31B475KBHZFN# CL31B106KBHNFN# CL31B106KBHNNN# CL31B222KCCNNN# CL31B332KCCNNN# CL31B103KCCNFN# CL31B223KCCNFN# CL31B223KCCNNN# CL31B333KCCNNN# CL31B104JCFNNN# CL31B104KCFNFN# CL31B104KCFNNN# CL31B474KCHSFN# CL31B105KCHNFN# CL31B105KCHNNN# CL31B105KCHSFN# CL31B105KCHSNN# CL31B225KCHSFN# CL31B225KCHSNN# MULTILAYER CERAMIC CAPACITORS 53 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 1.00 1.00 1.00 1.40 1.80 1.80 1.80 1.80 1.80 1.80 1.80 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.80 1.80 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.40 1.80 1.80 1.80 1.80 1.80 1.40 1.40 1.40 200 200 200 200 200 250 250 250 250 250 250 500 500 500 500 500 500 500 500 500 500 500 500 500 500 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 630 1000 1000 1000 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 470pF 1nF 10nF 33nF 100nF 33nF 47nF 47nF 100nF 100nF 100nF 220pF 470pF 680pF 1nF 1nF 1.5nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 22nF 33nF 330pF 470pF 680pF 1nF 1nF 1.5nF 2.2nF 2.2nF 3.3nF 4.7nF 4.7nF 4.7nF 6.8nF 10nF 10nF 10nF 22nF 22nF 22nF 33nF 33nF 680pF 1nF 1nF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL31B471KDCNNN# CL31B102KDCNNN# CL31B103KDCNFN# CL31B333KDFNNN# CL31B104KDHNFN# CL31B333KEHNNN# CL31B473KEHNNN# CL31B473KEHSFN# CL31B104KEHNFN# CL31B104KEHNNN# CL31B104KEHSFN# CL31B221KGFNNN# CL31B471KGFNNN# CL31B681KGFNNN# CL31B102KGFNFN# CL31B102KGFNNN# CL31B152KGFNFN# CL31B152KGFNNN# CL31B222KGFNFN# CL31B332KGFNFN# CL31B472KGFNFN# CL31B682KGFNNN# CL31B103KGFNFN# CL31B223KGHNNN# CL31B333KGHNFN# CL31B331KHFNNN# CL31B471KHFNNN# CL31B681KHFNNN# CL31B102KHFNFN# CL31B102KHFSFN# CL31B152KHFNFN# CL31B222KHFNFN# CL31B222KHFSFN# CL31B332KHFSFN# CL31B472KHFNFN# CL31B472KHFNNN# CL31B472KHFSFN# CL31B682KHFNFN# CL31B103KHFNFN# CL31B103KHFNNN# CL31B103KHFSFN# CL31B223KHHNFN# CL31B223KHHNNN# CL31B223KHHSFN# CL31B333KHHNFN# CL31B333KHHSFN# CL31B681KIFNNN# CL31B102KIFNFN# CL31B102KIFNNN# MULTILAYER CERAMIC CAPACITORS 54 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_Standard Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 148 149 150 1.40 1.40 1.80 1000 1000 2000 X7R X7R X7R 2.2nF 2.2nF 1nF ±10% ±10% ±10% CL31B222KIFNFN# CL31B222KIFNNN# CL31B102KJHNNN# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 2.70 2.20 2.70 2.70 2.70 2.20 2.00 2.70 2.70 2.70 2.70 1.45 2.20 2.00 2.00 2.70 2.70 2.70 2.70 2.00 2.70 1.45 1.45 1.80 1.80 2.70 2.00 2.00 2.70 2.70 2.80 2.70 2.70 2.70 2.70 2.70 2.70 2.70 1.45 6.3 10 10 10 10 16 16 16 16 16 16 25 25 25 25 25 25 25 25 35 35 50 50 50 50 50 50 50 50 50 50 50 50 100 100 100 100 250 500 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 47uF 10uF 22uF 47uF 47uF 4.7uF 10uF 10uF 22uF 22uF 22uF 1uF 2.2uF 10uF 10uF 10uF 10uF 22uF 22uF 10uF 10uF 150nF 470nF 1uF 1uF 2.2uF 4.7uF 4.7uF 4.7uF 4.7uF 4.7uF 10uF 10uF 1uF 1uF 2.2uF 2.2uF 100nF 10nF ±20% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL32B476MQJNNN# CL32B106KPINNN# CL32B226KPJNNN# CL32B476KPJNNN# CL32B476MPJNNN# CL32B475KOINNN# CL32B106KOULNN# CL32B106KOJNNN# CL32B226KOJNFN# CL32B226KOJNNN# CL32B226MOJNNN# CL32B105KAFNNN# CL32B225KAINNN# CL32B106KAUL3N# CL32B106KAULNN# CL32B106KAJNFN# CL32B106KAJNNN# CL32B226KAJNFN# CL32B226KAJNNN# CL32B106KLULNN# CL32B106KLJNNN# CL32B154KBFNNN# CL32B474KBFNNN# CL32B105KBHNNN# CL32B105MBHNNN# CL32B225KBJNNN# CL32B475KBUYFN# CL32B475KBUYNN# CL32B475KBJNFN# CL32B475KBJNNN# CL32B475KBVZNN# CL32B106KBJNFN# CL32B106KBJNNN# CL32B105KCJNNN# CL32B105KCJSNN# CL32B225KCJSFN# CL32B225KCJSNN# CL32B104KEJNNN# CL32B103KGFNNN# MULTILAYER CERAMIC CAPACITORS 55 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_High Level Ⅰ Normal High Level Ⅰ Features  ‌A High level Ⅰ MLCC is a chip-type capacitor suitable for industrial applicatons, with greater reliability than a general MLCC.  ‌It has improved the moisture resistance characteristics.  ‌In the outgoing inspection, proceed with the bending strength evaluation strengthen. ❶ Ceramic Body ❷ Electrode (Ni/Cu*) ❸ Plating (Ni) ❹ ‌Termination (Cu or Cu+Metal Epoxy) ⑤ Plating (Sn) High Level Ⅰ Improved Reliability (65℃, 90%RH, 1Vr, 500H) High Level Ⅱ Reinforced Reliability (85℃, 85%RH, 1Vr, 1000H) * Internal Cu electrode is only applied to limited products. Application  ‌Server, Network, Base station, Solar Inverter, DC-DC Converter Structure and Dimensions BW T Size Code 03 W L 05 10 21 31 32 MULTILAYER CERAMIC CAPACITORS Dimension (mm) L W T 0.60±0.03 0.30±0.03 0.30±0.03 0.60±0.05 0.30±0.05 0.30±0.05 1.00±0.05 0.50±0.05 0.50±0.05 1.00±0.10 0.50±0.10 0.50±0.10 1.00±0.15 0.50±0.15 0.50±0.15 1.00±0.20 0.50±0.20 0.50±0.20 1.60±0.10 0.80±0.10 0.80±0.10 1.60±0.15 0.80±0.15 0.80±0.15 1.60±0.20 0.80±0.20 0.80±0.20 1.60±0.25 0.80±0.25 0.80±0.25 2.00±0.10 1.25±0.10 0.65±0.10 2.00±0.10 1.25±0.10 0.85±0.10 2.00±0.10 1.25±0.10 1.25±0.10 2.00±0.15 1.25±0.15 1.25±0.15 2.00±0.20 1.25±0.20 1.25±0.20 3.20±0.15 1.60±0.15 0.85±0.15 3.20±0.15 1.60±0.15 1.25±0.15 3.20±0.20 1.60±0.20 1.60±0.20 3.20±0.30 1.60±0.20 1.60±0.20 3.20±0.30 1.60±0.30 1.60±0.30 3.20±0.15 1.60±0.15 0.85±0.15 3.20±0.15 1.60±0.15 1.25±0.15 3.20±0.20 1.60±0.20 1.60±0.20 3.20±0.30 1.60±0.20 1.60±0.20 3.20±0.30 1.60±0.30 1.60±0.30 BW EIA (inch) 0.15±0.05 0201 0.25±0.10 0402 0.30±0.20 0603 0.5+0.2/-0.3 0805 0.50±0.30 1206 0.60±0.30 1210 56 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_High Level Ⅰ Capacitance Table (C0G) Category TC Size mm (inch) 0603 (0201) 1005 (0402) 1608 (0603) High LevelⅠ C0G 2012 (0805) 3216 (1206) 3225 (1210) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 25 50 50 25 50 100 50 100 200 250 25 50 100 500 630 100 Capacitance Range 10nF - 100nF 33pF - 47pF 0.5pF - 1nF 680pF - 1.5nF 1pF - 2.2nF 10pF - 330pF 33pF - 10nF 330pF - 1nF 220pF - 220pF 10pF - 10pF 10nF - 10nF 1.5nF - 33nF 1nF - 1nF 10pF - 39pF 220pF - 220pF 47nF - 47nF Capacitance Table (X5R) Category TC Size mm (inch) 0603 (0201) 1005 (0402) 1608 (0603) High LevelⅠ X5R (85℃) 2012 (0805) 3216 (1206) 3225 (1210) MULTILAYER CERAMIC CAPACITORS Rated Voltage (Vdc) 6.3 10 4 6.3 10 16 25 4 6.3 10 16 25 4 6.3 10 16 25 6.3 10 16 25 6.3 10 16 25 Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 10nF - 470nF 2.2nF - 100nF 2.2uF - 4.7uF 220nF - 4.7uF 100nF - 1uF 100nF - 1uF 100nF - 1uF 10uF - 47uF 2.2uF - 10uF 470nF - 4.7uF 1uF - 2.2uF 220nF - 1uF 47uF - 47uF 4.7uF - 47uF 2.2uF - 22uF 10uF - 22uF 2.2uF - 22uF 22uF - 100uF 22uF - 47uF 22uF - 22uF 4.7uF - 22uF 22uF - 100uF 22uF - 22uF 22uF - 47uF 22uF - 22uF 57 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_High Level Ⅰ Capacitance Table (X6S) Category TC Size mm (inch) 0603 (0201) 1005 (0402) High LevelⅠ X6S (105℃) 1608 (0603) 2012 (0805) 3216 (1206) 3225 (1210) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 6.3 100nF - 100nF 16 100nF - 100nF 6.3 470nF - 1uF 10 1uF - 2.2uF 25 1uF - 1uF 2.5 47uF - 47uF 4 4.7uF - 47uF 6.3 4.7uF - 22uF 10 10uF - 10uF 16 4.7uF - 4.7uF 4 22uF - 47uF 6.3 10uF - 22uF 10 22uF - 22uF 16 10uF - 22uF 4 100uF - 100uF 6.3 47uF - 47uF 6.3 100uF - 100uF Capacitance Table (X7R) Category TC Size mm (inch) Rated Voltage (Vdc) 10 0603 (0201) 1005 (0402) High LevelⅠ X7R (125℃) 1608 (0603) 2012 (0805) MULTILAYER CERAMIC CAPACITORS Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 10nF - 10nF 16 1nF - 10nF 25 680pF - 1nF 6.3 220nF - 1uF 10 27nF - 220F 16 1nF - 220nF 25 1nF - 220nF 50 220pF - 100nF 10 220nF - 1uF 16 100nF - 1uF 25 39nF - 1uF 50 100pF - 220nF 100 1nF - 100nF 6.3 10uF - 10uF 10 2.2uF - 10uF 16 2.2uF - 4.7uF 25 100nF - 2.2uF 50 1nF - 2.2uF 100 10nF - 10nF 58 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_High Level Ⅰ Capacitance Table (X7R) Category TC Size mm (inch) 3216 (1206) High LevelⅠ X7R (125℃) 3225 (1210) Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 6.3 22uF - 22uF 10 22uF - 22uF 16 1uF - 2.2uF 25 1uF - 2.2uF 50 100nF - 2.2uF 100 2.2uF - 2.2uF 630 10nF - 10nF 25 10uF - 10uF 50 4.7uF - 10uF 100 4.7uF - 4.7uF 630 47nF - 47nF 1000 22nF - 22nF Capacitance Table (X7S) Category TC High LevelⅠ X7S (125℃) Size mm (inch) 3225 (1210) MULTILAYER CERAMIC CAPACITORS Rated Voltage (Vdc) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 6.3 100uF - 100uF 25 22uF - 22uF 59 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Product Line Up (C0G) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 0.33 0.33 0.33 0.33 0.33 25 25 25 50 50 C0G C0G C0G C0G C0G 10pF 33pF 100pF 33pF 47pF ±5% ±5% ±5% ±5% ±5% CL03C100JA3NNW# CL03C330JA3NNW# CL03C101JA3NNW# CL03C330JB3NNW# CL03C470JB3NNW# TC code Capacitance C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 0.5pF 0.75pF 1.3pF 2pF 2.2pF 2.4pF 4pF 4.3pF 4.7pF 5.6pF 8.2pF 9pF 10pF 12pF 15pF 15pF 18pF 20pF 22pF 24pF 27pF 33pF 39pF 47pF 47pF 56pF 68pF 82pF 100pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1nF Size : 1.00 × 0.50mm (inch : 0402) No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Thickness Max. (mm) 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 Rated Voltage (Vdc) 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 MULTILAYER CERAMIC CAPACITORS Capacitance Tolerance ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±5% ±0.25pF ±0.25pF ±5% ±1pF ±5% ±5% ±5% ±5% ±5% ±5% ±1pF ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Part Number CL05C0R5CB5NNW# CL05CR75CB5NNW# CL05C1R3CB5NNW# CL05C020CB5NNW# CL05C2R2CB5NNW# CL05C2R4BB5NNW# CL05C040CB5NNW# CL05C4R3CB5NNW# CL05C4R7CB5NNW# CL05C5R6CB5NNW# CL05C8R2CB5NNW# CL05C090CB5NNW# CL05C100JB5NNW# CL05C120CB5NNW# CL05C150CB5NNW# CL05C150JB5NNW# CL05C180FB5NNW# CL05C200JB5NNW# CL05C220JB5NNW# CL05C240JB5NNW# CL05C270JB5NNW# CL05C330JB5NNW# CL05C390JB5NNW# CL05C470FB5NNW# CL05C470JB5NNW# CL05C560JB5NNW# CL05C680JB5NNW# CL05C820JB5NNW# CL05C101JB5NNW# CL05C151JB5NNW# CL05C181JB5NNW# CL05C221JB5NNW# CL05C271JB5NNW# CL05C331JB5NNW# CL05C391JB5NNW# CL05C471JB5NNW# CL05C561JB5NNW# CL05C681JB5NNW# CL05C821JB5NNW# CL05C102JB5NNW# 60 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 1.60 × 0.80mm (inch : 0603) No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 Thickness Max. (mm) 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 Rated Voltage (Vdc) 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 100 100 100 100 100 100 100 MULTILAYER CERAMIC CAPACITORS TC code Capacitance C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G C0G 680pF 1.5nF 1pF 1.8pF 2.2pF 2.2pF 3.3pF 3.9pF 3.9pF 4.7pF 4.7pF 5pF 5.6pF 6.2pF 6.8pF 6.8pF 8.2pF 10pF 10pF 12pF 15pF 15pF 18pF 22pF 22pF 22pF 27pF 33pF 39pF 47pF 47pF 56pF 68pF 82pF 100pF 120pF 200pF 220pF 330pF 470pF 1nF 1.2nF 1.5nF 2.2nF 10pF 33pF 100pF 150pF 220pF 270pF 330pF Capacitance Tolerance ±5% ±2% ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.10pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.50pF ±0.25pF ±0.25pF ±5% ±5% ±1pF ±5% ±5% ±1pF ±2% ±5% ±5% ±5% ±5% ±5% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Part Number CL10C681JA8NNW# CL10C152GA8NNW# CL10C010CB8NNW# CL10C1R8CB8NNW# CL10C2R2BB8NNW# CL10C2R2CB8NNW# CL10C3R3CB8NNW# CL10C3R9BB8NNW# CL10C3R9CB8NNW# CL10C4R7BB8NNW# CL10C4R7CB8NNW# CL10C050BB8NNW# CL10C5R6CB8NNW# CL10C6R2CB8NNW# CL10C6R8CB8NNW# CL10C6R8DB8NNW# CL10C8R2CB8NNW# CL10C100CB8NNW# CL10C100JB8NNW# CL10C120JB8NNW# CL10C150FB8NNW# CL10C150JB8NNW# CL10C180JB8NNW# CL10C220FB8NNW# CL10C220GB8NNW# CL10C220JB8NNW# CL10C270JB8NNW# CL10C330JB8NNW# CL10C390JB8NNW# CL10C470JB8NNW# CL10C470KB8NNW# CL10C560JB8NNW# CL10C680JB8NNW# CL10C820JB8NNW# CL10C101JB8NNW# CL10C121JB8NNW# CL10C201JB8NNW# CL10C221JB8NNW# CL10C331JB8NNW# CL10C471JB8NNW# CL10C102JB8NNW# CL10C122JB8NNW# CL10C152JB8NNW# CL10C222JB8NNW# CL10C100JC8NNW# CL10C330JC8NNW# CL10C101JC8NNW# CL10C151JC8NNW# CL10C221JC8NNW# CL10C271JC8NNW# CL10C331JC8NNW# 61 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 0.75 50 2 0.75 50 C0G 33pF ±5% CL21C330JBANNW# C0G 100pF ±2% CL21C101GBANNW# 3 0.75 4 0.75 50 C0G 100pF ±5% CL21C101JBANNW# 50 C0G 220pF ±5% CL21C221JBANNW# 5 6 0.95 50 C0G 680pF ±5% CL21C681JBCNNW# 0.95 50 C0G 1nF ±5% CL21C102JBCNNW# 7 1.35 50 C0G 2.2nF ±5% CL21C222JBFNNW# 8 1.35 50 C0G 2.7nF ±5% CL21C272JBFNNW# 9 1.35 50 C0G 4.7nF ±5% CL21C472JBFNNW# 10 1.35 50 C0G 10nF ±5% CL21C103JBFNNW# 11 0.75 100 C0G 330pF ±5% CL21C331JCANNW# 12 0.95 100 C0G 470pF ±5% CL21C471JCCNNW# 13 1.35 100 C0G 1nF ±5% CL21C102JCFNNW# 14 0.95 200 C0G 220pF ±5% CL21C221JDCNNW# 15 0.95 250 C0G 10pF ±5% CL21C100JECNNW# Capacitance Capacitance Tolerance Part Number Part Number Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 1.40 25 C0G 10nF ±2% CL31C103GAFNNW# 2 1.00 50 C0G 1.5nF ±2% CL31C152GBCNNW# 3 1.40 50 C0G 3.3nF ±5% CL31C332JBFNNW# 4 1.80 50 C0G 27nF ±5% CL31C273JBHNNW# 5 1.80 50 C0G 33nF ±5% CL31C333JBHNNW# 6 1.00 100 C0G 1nF ±10% CL31C102KCCNNW# 7 1.40 500 C0G 10pF ±5% CL31C100JGFNNW# 8 1.40 500 C0G 39pF ±5% CL31C390JGFNNW# 9 1.40 630 C0G 220pF ±5% CL31C221JHFNNW# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2.70 100 C0G 47nF ±5% CL32C473JCJNNW# MULTILAYER CERAMIC CAPACITORS 62 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Product Line Up (X5R) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.33 6.3 2 0.33 6.3 X5R 10nF ±10% CL03A103KQ3NNW# X5R 100nF ±10% 3 0.33 CL03A104KQ3N3W# 6.3 X5R 100nF ±10% CL03A104KQ3NNW# 4 5 0.33 6.3 X5R 470nF ±20% CL03A474MQ3NNW# 0.33 10 X5R 2.2nF ±10% CL03A222KP3NNW# 6 0.33 10 X5R 4.7nF ±10% CL03A472KP3NNW# 7 0.33 10 X5R 10nF ±10% CL03A103KP3NNW# 8 0.33 10 X5R 100nF ±10% CL03A104KP3NNW# Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.55 4 X5R 2.2uF ±20% CL05A225MR5NNW# 2 0.65 4 X5R 4.7uF ±20% CL05A475MR5NRW# 3 0.55 6.3 X5R 220nF ±10% CL05A224KQ5NNW# 4 0.55 6.3 X5R 470nF ±10% CL05A474KQ5NNW# 5 0.55 6.3 X5R 1uF ±10% CL05A105KQ5NNW# 6 0.55 6.3 X5R 1uF ±20% CL05A105MQ5NNW# 7 0.55 6.3 X5R 2.2uF ±20% CL05A225MQ5NNW# 8 0.65 6.3 X5R 4.7uF ±20% CL05A475MQ5NRW# 9 0.55 10 X5R 100nF ±10% CL05A104KP5NNW# 10 0.55 10 X5R 220nF ±10% CL05A224KP5NNW# 11 0.55 10 X5R 1uF ±10% CL05A105KP5NNW# 12 0.6 10 X5R 1uF ±10% CL05A105KP5NQW# 13 0.55 16 X5R 100nF ±10% CL05A104KO5NNW# 14 0.55 16 X5R 220nF ±10% CL05A224KO5NNW# 15 0.55 16 X5R 1uF ±10% CL05A105KO5NNW# 16 0.60 16 X5R 1uF ±10% CL05A105KO5NQW# 17 0.60 16 X5R 1uF ±20% CL05A105MO5NQW# 18 0.55 25 X5R 100nF ±10% CL05A104KA5NNW# 19 0.55 25 X5R 470nF ±10% CL05A474KA5NNW# 20 0.60 25 X5R 1uF ±10% CL05A105KA5NQW# MULTILAYER CERAMIC CAPACITORS 63 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.90 4 X5R 10uF ±20% CL10A106MR8NNW# 2 0.95 4 X5R 22uF ±20% CL10A226MR8NQW# 3 1.05 4 X5R 22uF ±20% CL10A226MR8NUW# 4 1.00 4 X5R 47uF ±20% CL10A476MR8NRW# 5 0.90 6.3 X5R 2.2uF ±10% CL10A225KQ8NNW# 6 0.90 6.3 X5R 4.7uF ±10% CL10A475KQ8NNW# 7 0.90 6.3 X5R 4.7uF ±20% CL10A475MQ8NNW# 8 0.95 6.3 X5R 4.7uF ±20% CL10A475MQ8NQW# 9 0.90 6.3 X5R 10uF ±10% CL10A106KQ8NNW# 10 0.90 6.3 X5R 10uF ±20% CL10A106MQ8NNW# 11 0.90 10 X5R 470nF ±10% CL10A474KP8NNW# 12 0.90 10 X5R 1uF ±10% CL10A105KP8NNW# 13 0.90 10 X5R 2.2uF ±10% CL10A225KP8NNW# 14 0.90 10 X5R 4.7uF ±10% CL10A475KP8NNW# 15 0.90 16 X5R 1uF ±10% CL10A105KO8NNW# 16 0.90 16 X5R 2.2uF ±10% CL10A225KO8NNW# 17 0.90 25 X5R 220nF ±10% CL10A224KA8NNW# 18 0.90 25 X5R 470nF ±10% CL10A474KA8NNW# 19 0.90 25 X5R 1uF ±10% CL10A105KA8NNW# Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number CL21A476MRYNNW# Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) 1 1.45 4 X5R 47uF ±20% 2 1.35 6.3 X5R 4.7uF ±10% CL21A475KQFNNW# 3 1.35 6.3 X5R 4.7uF ±20% CL21A475MQFNNW# 4 1.35 6.3 X5R 10uF ±10% CL21A106KQFNNW# 5 1.40 6.3 X5R 22uF ±20% CL21A226MQQNNW# 6 1.45 6.3 X5R 22uF ±20% CL21A226MQYNNW# 7 1.45 6.3 X5R 47uF ±20% CL21A476MQYNNW# 8 1.35 10 X5R 2.2uF ±10% CL21A225KPFNNW# 9 1.35 10 X5R 4.7uF ±10% CL21A475KPFNNW# 10 1.35 10 X5R 10uF ±10% CL21A106KPFNNW# 11 1.35 10 X5R 10uF ±20% CL21A106MPFNNW# 12 1.40 10 X5R 10uF ±20% CL21A106MPQNNW# 13 1.45 10 X5R 22uF ±20% CL21A226MPYNNW# 14 1.35 16 X5R 10uF ±10% CL21A106KOFNNW# 15 1.40 16 X5R 10uF ±10% CL21A106KOQNNW# 16 1.45 16 X5R 22uF ±20% CL21A226MOYNNW# 17 1.35 25 X5R 2.2uF ±10% CL21A225KAFNNW# 18 1.35 25 X5R 4.7uF ±10% CL21A475KAFNNW# 19 1.40 25 X5R 4.7uF ±10% CL21A475KAQNNW# 20 1.45 25 X5R 22uF ±20% CL21A226MAYNNW# MULTILAYER CERAMIC CAPACITORS 64 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 1.80 6.3 X5R 22uF ±10% CL31A226KQHNNW# 2 1.80 6.3 X5R 47uF ±20% CL31A476MQHNNW# 3 1.90 6.3 X5R 100uF ±20% CL31A107MQKNNW# 4 1.80 10 X5R 22uF ±10% CL31A226KPHNNW# 5 1.80 10 X5R 22uF ±20% CL31A226MPHNNW# 6 1.80 10 X5R 47uF ±20% CL31A476MPHNNW# 7 1.80 16 X5R 22uF ±10% CL31A226KOHNNW# 8 1.80 16 X5R 22uF ±20% CL31A226MOHNNW# CL31A475KAHNNW# Part Number 9 1.80 25 X5R 4.7uF ±10% 10 1.80 25 X5R 10uF ±10% CL31A106KAHNNW# 11 1.80 25 X5R 10uF ±20% CL31A106MAHNNW# 12 1.80 25 X5R 22uF ±10% CL31A226KAHNNW# Part Number Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 2.70 6.3 X5R 22uF ±10% CL32A226KQJNNW# 2 2.70 6.3 X5R 22uF ±20% CL32A226MQJNNW# 3 2.80 6.3 X5R 100uF ±20% CL32A107MQVNNW# 4 2.70 10 X5R 22uF ±20% CL32A226MPJNNW# 5 2.70 16 X5R 22uF ±10% CL32A226KOJNNW# 6 2.70 16 X5R 47uF ±10% CL32A476KOJNNW# 7 2.70 16 X5R 47uF ±20% CL32A476MOJNNW# 8 2.70 25 X5R 22uF ±10% CL32A226KAJNNW# 9 2.70 25 X5R 22uF ±20% CL32A226MAJNNW# MULTILAYER CERAMIC CAPACITORS 65 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Product Line Up (X6S) Size : 0.60 × 0.30mm (inch : 0201), 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 0.33 0.33 0.55 0.55 0.60 0.55 0.70 0.60 6.3 16 6.3 6.3 6.3 10 10 25 X6S X6S X6S X6S X6S X6S X6S X6S 100nF 100nF 470nF 1uF 1uF 1uF 2.2uF 1uF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL03X104KQ3NNW# CL03X104KO3NNW# CL05X474KQ5NNW# CL05X105KQ5NNW# CL05X105KQ5NQW# CL05X105KP5NNW# CL05X225KP5QUW# CL05X105KA5NQW# Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 1.00 0.90 1.00 1.05 1.00 0.90 0.95 1.00 1.00 0.90 1.00 1.00 1.00 2.5 4 4 4 4 6.3 6.3 6.3 6.3 6.3 6.3 10 16 X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S X6S 47uF 4.7uF 22uF 22uF 47uF 4.7uF 4.7uF 4.7uF 4.7uF 10uF 22uF 10uF 4.7uF ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±10% ±20% ±20% ±20% ±20% ±10% CL10X476MS8NRW# CL10X475KR8NNW# CL10X226MR8QRW# CL10X226MR8NUW# CL10X476MR8NRW# CL10X475MQ8NNW# CL10X475MQ8NQW# CL10X475KQ8NRW# CL10X475MQ8NRW# CL10X106MQ8NNW# CL10X226MQ8QRW# CL10X106MP8NRW# CL10X475KO8NRW# Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 1.40 1.45 1.45 1.40 1.40 1.45 1.45 1.40 1.45 4 4 4 6.3 6.3 6.3 10 16 16 X6S X6S X6S X6S X6S X6S X6S X6S X6S 22uF 22uF 47uF 10uF 22uF 22uF 22uF 10uF 22uF ±20% ±20% ±20% ±10% ±20% ±20% ±20% ±10% ±20% CL21X226MRQNNW# CL21X226MRYNNW# CL21X476MRYNNW# CL21X106KQQNNW# CL21X226MQQNNW# CL21X226MQYNNW# CL21X226MPYNNW# CL21X106KOQNNW# CL21X226MOYNNW# Size : 3.20 × 1.60mm (inch : 1206), 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 1.90 1.80 2.70 4Vdc 6.3Vdc 6.3Vdc X6S X6S X6S 100uF 47uF 100uF ±20% ±20% ±20% CL31X107MRKNNW# CL31X476MQHNNW# CL32X107MQVNNW# MULTILAYER CERAMIC CAPACITORS 66 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Product Line Up (X7R) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 0.33 10 X7R 10nF ±10% CL03B103KP3NNW# 2 0.33 16 X7R 1nF ±10% CL03B102KO3NNW# 3 0.33 16 X7R 10nF ±10% CL03B103KO3NNW# 4 0.33 25 X7R 680pF ±10% CL03B681KA3NNW# 5 0.33 25 X7R 1nF ±10% CL03B102KA3NNW# Part Number Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 6.3 6.3 10 10 10 10 10 10 16 16 16 16 16 16 16 16 16 16 16 25 25 25 25 25 25 25 25 25 25 25 50 50 50 50 50 50 50 50 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 220nF 1uF 27nF 33nF 47nF 100nF 220nF 1nF 10nF 10nF 10nF 15nF 22nF 33nF 47nF 68nF 82nF 100nF 220nF 1nF 5.6nF 6.8nF 10nF 10nF 15nF 22nF 33nF 47nF 100nF 220nF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 1nF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% CL05B224KQ5NNW# CL05B105KQ5QNW# CL05B273KP5NNW# CL05B333KP5NNW# CL05B473KP5NNW# CL05B104KP5NNW# CL05B224KP5NNW# CL05B102KO5NNW# CL05B103JO5NNW# CL05B103KO5NNW# CL05B103MO5NNW# CL05B153KO5NNW# CL05B223KO5NNW# CL05B333KO5NNW# CL05B473KO5NNW# CL05B683KO5NNW# CL05B823KO5NNW# CL05B104KO5NNW# CL05B224KO5NNW# CL05B102KA5NNW# CL05B562KA5NNW# CL05B682KA5NNW# CL05B103JA5NNW# CL05B103KA5NNW# CL05B153KA5NNW# CL05B223KA5NNW# CL05B333KA5NNW# CL05B473KA5NNW# CL05B104KA5NNW# CL05B224KA5NNW# CL05B221KB5NNW# CL05B271KB5NNW# CL05B331KB5NNW# CL05B391KB5NNW# CL05B471KB5NNW# CL05B561KB5NNW# CL05B681KB5NNW# CL05B102JB5NNW# MULTILAYER CERAMIC CAPACITORS 67 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 39 40 41 42 43 44 45 46 47 48 49 50 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 0.55 50 50 50 50 50 50 50 50 50 50 50 50 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 1nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 8.2nF 10nF 22nF 100nF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% CL05B102KB5NNW# CL05B152KB5NNW# CL05B182KB5NNW# CL05B222KB5NNW# CL05B272KB5NNW# CL05B332KB5NNW# CL05B392KB5NNW# CL05B472KB5NNW# CL05B822KB5NNW# CL05B103KB5NNW# CL05B223KB5NNW# CL05B104KB5NNW# Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 0.90 10 10 16 16 16 16 16 25 25 25 25 25 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 100 100 100 X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R 220nF 1uF 100nF 150nF 220nF 470nF 1uF 39nF 47nF 100nF 100nF 1uF 100pF 680pF 1nF 1.5nF 2.2nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 10nF 22nF 27nF 47nF 100nF 100nF 220nF 1nF 10nF 100nF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±5% ±10% ±10% ±10% ±10% ±10% CL10B224KP8NNW# CL10B105KP8NNW# CL10B104KO8NNW# CL10B154KO8NNW# CL10B224KO8NNW# CL10B474KO8NNW# CL10B105KO8NNW# CL10B393KA8NNW# CL10B473KA8NNW# CL10B104KA8NNW# CL10B104MA8NNW# CL10B105KA8NNW# CL10B101KB8NNW# CL10B681KB8NNW# CL10B102KB8NNW# CL10B152KB8NNW# CL10B222JB8NNW# CL10B222KB8NNW# CL10B332KB8NNW# CL10B472KB8NNW# CL10B682KB8NNW# CL10B103JB8NNW# CL10B103KB8NNW# CL10B223KB8NNW# CL10B273KB8NNW# CL10B473KB8NNW# CL10B104JB8NNW# CL10B104KB8NNW# CL10B224KB8NNW# CL10B102KC8NNW# CL10B103KC8NNW# CL10B104KC8N3W# MULTILAYER CERAMIC CAPACITORS 68 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Array Type Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Normal Capacitors_High Level Ⅰ Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.40 6.3 2 1.35 10 X7R 10uF ±10% CL21B106KQQNNW# X7R 2.2uF ±10% 3 1.40 CL21B225KPFNNW# 10 X7R 10uF ±10% CL21B106KPQNNW# 4 1.35 16 X7R 2.2uF ±10% CL21B225KOFNNW# 5 1.35 16 X7R 4.7uF ±10% CL21B475KOFNNW# 6 0.95 25 X7R 100nF ±10% CL21B104KACNNW# 7 1.35 25 X7R 2.2uF ±10% CL21B225KAFNNW# 8 0.75 50 X7R 1nF ±10% CL21B102KBANNW# 9 0.75 50 X7R 10nF ±10% CL21B103KBANNW# 10 0.75 50 X7R 15nF ±10% CL21B153KBANNW# 11 0.75 50 X7R 22nF ±10% CL21B223KBANNW# 12 0.95 50 X7R 100nF ±10% CL21B104KBCNNW# 13 1.45 50 X7R 2.2uF ±10% CL21B225KBYNNW# 14 0.75 100 X7R 10nF ±10% CL21B103KCANNW# Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.80 6.3 X7R 22uF ±10% CL31B226KQHNNW# 2 1.80 10 X7R 22uF ±10% CL31B226KPHNNW# 3 1.40 16 X7R 1uF ±10% CL31B105KOFNNW# 4 1.80 16 X7R 2.2uF ±10% CL31B225KOHNNW# 5 1.80 25 X7R 1uF ±10% CL31B105KAHNNW# 6 1.80 25 X7R 1uF ±20% CL31B105MAHNNW# 7 1.80 25 X7R 2.2uF ±10% CL31B225KAHNNW# 8 1.00 50 X7R 100nF ±10% CL31B104KBCNNW# 9 1.40 50 X7R 330nF ±10% CL31B334KBFNNW# 10 1.80 50 X7R 470nF ±10% CL31B474KBHNNW# 11 1.80 50 X7R 1uF ±10% CL31B105KBHNNW# 12 1.80 50 X7R 2.2uF ±10% CL31B225KBHNNW# 13 1.80 100 X7R 2.2uF ±10% CL31B225KCHZNW# 14 1.40 630 X7R 10nF ±10% CL31B103KHFNNW# Capacitance Capacitance Tolerance Part Number Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 2.00 25 X7R 10uF ±10% CL32B106KAULNW# 2 2.70 50 X7R 4.7uF ±10% CL32B475KBJNNW# 3 2.80 50 X7R 10uF ±10% CL32B106KBVZNW# 4 2.20 100 X7R 4.7uF ±10% CL32B475KCIZNW# 5 2.20 630 X7R 47nF ±10% CL32B473KHINNW# 6 2.20 1000 X7R 22nF ±10% CL32B223KIIZNW# 7 2.80 6.3 X7S 100uF ±20% CL32Y107MQVNNW# 8 2.80 25 X7S 22uF ±10% CL32Y226KAVZNW# MULTILAYER CERAMIC CAPACITORS 69 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide sites Normal Capacitors_High Level Ⅱ Normal High Level Ⅱ Features  ‌A High Level Ⅱ MLCC is a chip-type capacitor designed to be suitable for outdoor industrial applications.  ‌Reliability for moisture resistance and temperature change has been strengthened, and the bending strength characteristic is excellent. ❶ Ceramic Body ❷ Electrode (Ni/Cu*) ❸ Plating (Ni) ❹ ‌Termination (Cu or Cu+Metal Epoxy) ⑤ Plating (Sn) High Level Ⅰ Improved Reliability (65℃, 90%RH, 1Vr, 500H) High Level Ⅱ Reinforced Reliability (85℃, 85%RH, 1Vr, 1000H) * Internal Cu electrode is only applied to limited products. Application  ‌Base station, Solar Inverter, DC-DC Converter Structure and Dimensions BW T W L MULTILAYER CERAMIC CAPACITORS Dimension (mm) Size Code L W T BW EIA (inch) 05 1.00±0.05 10 1.60±0.10 0.50±0.05 0.50±0.05 0.25±0.10 0402 0.80±0.10 0.80±0.10 0.30±0.20 21 2.00±0.10 0603 1.25±0.10 1.25±0.10 0.5+0.2/-0.3 0805 70 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide Normal Capacitors_High Level Ⅱ sites Normal Capacitors_High Level Ⅱ Capacitance Table (C0G) Category TC High LevelⅡ C0G (125℃) Size mm (inch) Rated Voltage (Vdc) 1005 (0402) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 50 Capacitance Range 5.6pF - 5.6pF Capacitance Table (X7R) Category High LevelⅡ Size mm (inch) TC X7R (125℃) Rated Voltage (Vdc) 1608 (0603) 2012 (0805) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 25 1uF - 1uF 50 220nF - 470nF 25 2.2uF - 2.2uF 50 1uF - 1uF Capacitance Table (X7S) Category TC High LevelⅡ X7S (125℃) Size mm (inch) Rated Voltage (Vdc) 3225 (1210) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 6.3 1 10 100 Capacitance Range 100uF - 100uF Product Line Up (C0G) Size : 1.00 × 0.50mm (inch:0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.55 50 C0G 5.6pF ±0.25pF CL05C5R6CB5N4N# Capacitance Capacitance Tolerance Part Number Product Line Up (X7R) Size : 1.60 × 0.80mm (inch : 0603), 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 0.90 25 X7R 1uF ±10% CL10B105KA8Z4J# 2 0.90 50 X7R 470nF ±10% CL10B474KB8Z4J# 3 0.90 50 X7R 330nF ±10% CL10B334KB8Z4J# 4 0.90 50 X7R 220nF ±10% CL10B224KB8Z4J# 5 1.35 25 X7R 2.2uF ±10% CL21B225KAFZ4J# 6 1.35 50 X7R 1uF ±10% CL21B105KBFZ4J# 7 2.80 6.3 X7S 100uF ±20% CL32Y107MQVN4N# MULTILAYER CERAMIC CAPACITORS 71 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Reliability Level Description Low Acoustic Noise Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Packaging Specifications Caution/Notice Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Application Guide Embedded/LSC Capacitors Reliability Test Conditions sites Embedded/LSC Features   This can be mounted between the solder balls to deal with thin devices or modules.   It can reduce the thickness of the module or be embedded inside the board to secure the mounting area.   It can quickly supply stable current to high-speed AP of mobile devices.   In addition it helps remove high-frequency noise, suffering less from external environmental stress. IC IC Embedded Capacitor (In package PCB) LSC Thin Thickness Embedded Type (Cu Plating) LSC Type (Ni -Sn Plating) Application  ‌Smart Phone, Wearable Devices, IC Package, Module Products Structure and Dimensions BW T W L Dimension (mm) Size Code L 02 0.40±0.02 05 1.00±0.05 L5 0.52±0.05 1.00±0.05 MULTILAYER CERAMIC CAPACITORS W BW EIA (inch) L 0.10±0.03 01005 L 0.25±0.075 0402 J 0.145±0.050 0204 T Thkckness Code 0.20±0.02 0.095±0.015 0.50±0.05 0.0975±0.0125 0.085±0.015 72 Explanation of Ceramic Capacitors Reliability Test Conditions Embedded/LSC Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Reliability Level Description Packaging Specifications Low Acoustic Noise Capacitors Normal Capacitors_High Level Ⅰ Caution/Notice Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Embedded/LSC Capacitors Capacitance Table (X5R) TC X5R (85℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 0402 (01005) 6.3 51pF - 6.8nF 0510 (0204) 4 220nF - 220nF 1005 (0402) 6.3 220nF - 220nF pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range Product Line Up (X5R) Size : 0.40 × 0.20mm (inch : 01005) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.11 6.3 X5R 6.8nF ±20% CL02A682MQLHNN# 2 0.11 6.3 X5R 1nF ±20% CL02A102MQLHNN# 3 0.11 6.3 X5R 680pF ±20% CL02A681MQLHNN# 4 0.11 6.3 X5R 51pF ±20% CL02A510MQLHNN# Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) 1 0.10 4 X5R 220nF ±20% CLL5A224MRJHLC# 2 0.10 6.3 X5R 220nF ±20% CL05A224MQLHEC# MULTILAYER CERAMIC CAPACITORS 73 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Application Guide sites High Bending Strength Capacitors High Bending Strength Features   The thermal/mechanical stress on the chip can be reduced by the ductile characteristic of Soft Termination.   It is also resistant to stress caused by board bending. ① Ni/Sn ❷ Metal/Epoxy Termination ❸ Cu-Term Application  ‌All Application (Smart Phone, PC, HDD/SSD Board, Tablet, Display, Etc), Power (SMPS, DC-DC Converter), Industrial Application Structure and Dimensions BW T W L Dimension (mm) Size Code L W T Thkckness Code BW EIA (inch) 03 0.60±0.03 0.30±0.03 0.30±0.03 3 0.15±0.05 0201 05 1.00±0.05 0.50±0.05 0.50±0.05 5 0.25±0.10 0402 0.30±0.20 0603 0.50+0.2/-0.3 0805 0.50±0.30 1206 0.60±0.30 1210 10 21 31 32 1.60±0.10 0.80±0.10mm 0.80±0.10mm 8 2.00±0.10mm 1.25±0.10mm 0.85±0.10mm C 2.00±0.10mm 1.25±0.10mm 1.25±0.10mm F 2.00±0.15mm 1.25±0.15mm 1.25±0.15mm Q 3.20±0.15mm 1.60±0.15mm 1.25±0.15mm F 3.20±0.20mm 1.60±0.20mm 1.60±0.20mm H 3.20±0.30mm 2.50±0.20mm 1.60±0.10mm T 3.20±0.30mm 2.50±0.20mm 2.50±0.20mm J 3.20±0.40mm 2.50±0.30mm 2.50±0.30mm V MULTILAYER CERAMIC CAPACITORS 74 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering Packaging Specifications High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Application Guide sites High Bending Strength Capacitors Capacitance Table (X5R) TC X5R (85℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 0603 (0201) 10 100nF - 1uF 1005 (0402) 10 2.2uF - 10uF 1608 (0603) 6.3 10uF - 10uF pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range Capacitance Table (X7R) TC Size mm (inch) Rated Voltage (Vdc) 1608 (0603) 2012 (0805) X7R (125℃) 3216 (1206) 3225 (1210) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 16 1uF - 1uF 50 100nF - 100nF 16 4.7uF - 4.7uF 250 1nF - 1nF 25 4.7uF - 10uF 100 100nF - 1uF 250 100nF - 100nF 630 1nF - 10nF 50 4.7uF - 10uF 100 2.2uF - 4.7uF Capacitance Table (X7S) TC X7S (125℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 2012 (0805) 100 220nF - 220nF 3225 (1210) 100 4.7uF - 4.7uF MULTILAYER CERAMIC CAPACITORS pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 75 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites High Bending Strength Capacitors Product Line Up (X5R) Size : 0.60 × 0.30mm (inch : 0201) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.35 10 2 0.33 10 X5R 1uF ±20% CL03A105MP3ZSN# X5R 100nF ±10% CL03A104KP3ZNN# Capacitance Capacitance Tolerance Part Number Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 0.70 10 X5R 10uF ±20% CL05A106MP5ZUN# 2 0.65 10 X5R 4.7uF ±10% CL05A475KP5ZRN# 3 0.57 10 X5R 2.2uF ±10% CL05A225KP5ZSN# 4 0.57 6.3 X5R 2.2uF ±20% CL05A225MQ5ZSN# Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.05 10 X5R 22uF ±20% CL10A226MP8ZUN# 2 1.00 25 X5R 10uF ±20% CL10A106MA8ZRN# 3 0.95 6.3 X5R 10uF ±20% CL10A106MQ8ZQN# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.70 16 X5R 22uF ±10% CL32A226KOTFNN# MULTILAYER CERAMIC CAPACITORS 76 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites High Bending Strength Capacitors Product Line Up (X7R) Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 0.90 25 X7R 1uF ±10% CL10B105KA8ZFN# 2 0.90 16 X7R 1uF ±10% CL10B105KO8SFN# 3 0.90 16 X7R 1uF ±10% CL10B105KO8ZFN# 4 0.90 16 X7R 1uF ±10% CL10B105KO8ZW6# 5 0.90 16 X7R 220nF ±5% CL10B224JO8SFN# 6 0.90 25 X7R 220nF ±10% CL10B224KA8SFN# 7 0.90 50 X7R 220nF ±10% CL10B224KB8SFN# 8 0.90 16 X7R 220nF ±10% CL10B224KO8SFN# Part Number 9 0.90 50 X7R 100nF ±10% CL10B104KB8SFN# 10 0.90 50 X7R 100nF ±10% CL10B104KB8ZW6# 11 0.90 50 X7R 56nF ±10% CL10B563KB8SFN# 12 0.90 50 X7R 47nF ±10% CL10B473KB8SFN# 13 0.90 50 X7R 33nF ±10% CL10B333KB8SFN# 14 0.90 50 X7R 22nF ±10% CL10B223KB8SFN# 15 0.90 50 X7R 15nF ±10% CL10B153KB8SFN# 16 0.90 50 X7R 5.6nF ±10% CL10B562KB8SFN# 17 0.90 50 X7R 4.7nF ±10% CL10B472KB8SFN# 18 0.90 50 X7R 2.7nF ±10% CL10B272KB8SFN# 19 0.90 50 X7R 2.2nF ±10% CL10B222KB8SFN# 20 0.90 50 X7R 1.5nF ±10% CL10B152KB8SFN# 21 0.90 50 X7R 1nF ±10% CL10B102KB8SFN# Capacitance Capacitance Tolerance Part Number Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 1.40 10 X7R 10uF ±10% CL21B106KPQZFN# 2 1.35 25 X7R 4.7uF ±10% CL21B475KAFZF6# 3 1.35 25 X7R 4.7uF ±10% CL21B475KAFZFN# 4 1.35 16 X7R 4.7uF ±10% CL21B475KOFZFN# 5 1.40 16 X7R 4.7uF ±10% CL21B475KOQZW6# 6 1.35 25 X7R 1uF ±10% CL21B105KAFSFN# 7 1.35 50 X7R 1uF ±10% CL21B105KBFSFN# 8 1.35 50 X7R 1uF ±10% CL21B105KBFZFN# 9 1.35 16 X7R 1uF ±10% CL21B105KOFSFN# 10 1.35 25 X7R 470nF ±10% CL21B474KAFSFN# 11 1.35 100 X7R 220nF ±10% CL21B224KCFSFN# 12 0.95 50 X7R 100nF ±10% CL21B104KBCSFN# 13 1.35 100 X7R 100nF ±10% CL21B104KCFSFN# 14 0.95 250 X7R 1nF ±10% CL21B102KECSFN# 15 0.95 250 X7R 1nF ±10% CL21B102KECSNN# 16 0.95 250 X7R 1nF ±10% CL21B102KECSW6# MULTILAYER CERAMIC CAPACITORS 77 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites High Bending Strength Capacitors Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance 1 1.80 25 X7R 10uF ±10% CL31B106KAHSFN# 2 1.80 25 X7R 10uF ±10% CL31B106KAHZW6# 3 1.80 35 X7R 10uF ±10% CL31B106KLHSFN# 4 1.80 16 X7R 10uF ±10% CL31B106KOHZFN# 5 1.80 25 X7R 4.7uF ±10% CL31B475KAHZW6# 6 1.80 50 X7R 4.7uF ±10% CL31B475KBHZFN# 7 1.80 100 X7R 2.2uF ±10% CL31B225KCHSFN# 8 1.80 100 X7R 2.2uF ±10% CL31B225KCHSNN# CL31B105KBHSNN# Part Number 9 1.80 50 X7R 1uF ±10% 10 1.80 100 X7R 1uF ±10% CL31B105KCHSFN# 11 1.80 100 X7R 1uF ±10% CL31B105KCHSNN# 12 1.80 100 X7R 1uF ±10% CL31B105KCHSW6# 13 1.80 100 X7R 470nF ±10% CL31B474KCHSFN# 14 1.40 100 X7R 100nF ±10% CL31B104KCFZW6# 15 1.80 250 X7R 100nF ±10% CL31B474KCHSFN# 16 1.80 250 X7R 100nF ±10% CL31B104KEHSW6# 17 1.80 250 X7R 47nF ±10% CL31B473KEHSFN# 18 1.80 630 X7R 33nF ±10% CL31B333KHHSFN# 19 1.80 630 X7R 22nF ±10% CL31B223KHHSFN# 20 1.40 630 X7R 10nF ±10% CL31B103KHFSFN# 21 1.40 630 X7R 10nF ±10% CL31B103KHFSW6# 22 1.40 630 X7R 4.7nF ±10% CL31B472KHFSFN# 23 1.40 630 X7R 3.3nF ±10% CL31B332KHFSFN# 24 1.40 630 X7R 2.2nF ±10% CL31B222KHFSFN# 25 1.40 630 X7R 1nF ±10% CL31B102KHFSFN# 26 1.40 630 X7R 1nF ±10% CL31B102KHFSW6# Capacitance Capacitance Tolerance Part Number Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code 1 2.70 50 X7R 10uF ±10% CL32B106KBJZW6# 2 2.70 50 X7R 4.7uF ±10% CL32B475KBJSW6# 3 2.80 50 X7R 4.7uF ±10% CL32B475KBVZNN# 4 2.80 100 X7R 4.7uF ±10% CL32B475KCVZW6# 5 2.70 100 X7R 2.2uF ±10% CL32B225KCJSFN# 6 2.70 100 X7R 2.2uF ±10% CL32B225KCJSNN# 7 2.70 100 X7R 2.2uF ±10% CL32B225KCJZW6# 8 2.70 100 X7R 1uF ±10% CL32B105KCJSNN# MULTILAYER CERAMIC CAPACITORS 78 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Normal Capacitors_High Level Ⅰ Array Type Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites High Bending Strength Capacitors Product Line Up (X7S) Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.35 100 X7S 220nF ±10% CL21Y224KCFSW6# Size : 3.20 × 2.50mm (inch : 1210) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 2.80 100 X7S 4.7uF ±10% CL32Y475KCVZW6# MULTILAYER CERAMIC CAPACITORS 79 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Part Numbering Reliability Test Conditions High Bending Strength Capacitors Reliability Level Description Packaging Specifications Caution/Notice Low Acoustic Noise Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ sites Low Acoustic Noise Capacitors Low Acoustic Noise Features   MLCC tremors can occur due to piezoelectric phenomena in electronic devices.   These tremors are transmitted to the substrate, causing the substrate to tremble, causing audible noise (20Hz~20kHz).   Low Acoustic Noise products are a solution that can effectively reduce this noise. THMC Cross-Sectioned View Bottom Cover ANSC (Type-A) Cross-Sectioned View Inner Electrode Substrate ANSC (Type-B) Cross-Sectioned View * THMC : Thick Horizontally Mounted Capacitor * ANSC : Acoustic Noise Suppressed Capacitor 40 40 0402i Chip Capacitor 30 0805i Chip Capacitor 30 0402i THMC 20 Sound Pressure Level(dBA) Sound Pressure Level(dBA) 20 0805i ANSC 10 0 -10 -20 -30 0 5 10 15 20 10 0 -10 -20 -30 0 Frequency(㎑) 5 10 15 20 Frequency(㎑) [Comparison of Noise Reduction Effects] MULTILAYER CERAMIC CAPACITORS 80 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Part Numbering High Bending Strength Capacitors Reliability Level Description Low Acoustic Noise Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Normal Capacitors_High Level Ⅰ Array Type Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Low Acoustic Noise Capacitors Anechoic Chamber Measurement Condition * Sine Sweep 500㎐ to 20㎑ Microphone * 12.5VDC + 2VPP Height : 3mm DAQ System [Measurement System] Application   All Application (Smart Phone, PC, HDD/SSD Board, Tablet, Display, Etc), Power (SMPS, DC-DC Converter), Industrial Application Structure and Dimensions BW T W L Size Code 05 10 21 Dimension (mm) L W T Thkckness Code 1.00±0.25mm 0.50±0.25mm 0.60±0.25mm 6 1.00±0.15mm 0.50±0.15mm 0.70±0.10mm 7 1.00±0.20mm 0.50±0.20mm 0.80±0.10mm 8 1.00±0.20mm 0.50±0.20mm 0.90±0.10mm 9 1.60±0.30mm 0.80±0.30mm 0.90±0.10mm 9 1.60±0.25mm 0.80±0.25mm 0.85±0.10mm C 1.60±0.20mm 0.80±0.20mm 1.10±0.10mm E 1.60±0.25mm 0.80±0.25mm 1.15±0.10mm M 1.60±0.10mm 0.80±0.10mm 0.95±0.10mm N 2.00±0.20mm 1.25±0.20mm 1.10±0.10mm E MULTILAYER CERAMIC CAPACITORS BW EIA (inch) 0.25±0.10 0402 0.30±0.20 0.30±0.20 0.50+0.20/-0.30 0603 0805 81 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Part Numbering Reliability Test Conditions High Bending Strength Capacitors Reliability Level Description Packaging Specifications Caution/Notice Low Acoustic Noise Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ sites Low Acoustic Noise Capacitors Capacitance Table (X5R) Size mm (inch) TC Rated Voltage (Vdc) 1005 (0402) X5R (85℃) 1608 (0603) 2012 (0805) Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 6.3 10uF - 10uF 10 2.2uF - 10uF 25 2.2uF - 2.2uF 6.3 10uF - 47uF 10 4.7uF - 22uF 25 10uF - 10uF Capacitance Table (X6S) TC X6S (105℃) Size mm (inch) Rated Voltage (Vdc) 1005 (0402) 2.5 Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 20uF - 20uF Product Line Up (X5R) Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.90 10 X5R 10uF ±20% CL05A106MP8NUB# 2 1.00 10 X5R 10uF ±20% CL05A106MP9NUB# 3 0.90 6.3 X5R 10uF ±20% CL05A106MQ8NUB# 4 0.80 10 X5R 4.7uF ±20% CL05A475MP7NRB# 5 0.80 10 X5R 2.2uF ±10% CL05A225KP7NSB# Product Line Up (X6S) Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 0.85 2.5 X6S 20uF ±20% CL05X206MS6N6B# MULTILAYER CERAMIC CAPACITORS 82 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Part Numbering High Bending Strength Capacitors Reliability Level Description Low Acoustic Noise Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅱ Application Guide Normal Capacitors_High Level Ⅰ Array Type Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Low Acoustic Noise Capacitors Product Line Up (X5R) Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.20 6.3 X5R 47uF ±20% CL10A476MQENRB# 2 1.00 10 X5R 22uF ±20% CL10A226MP9NZB# 3 0.95 10 X5R 22uF ±20% CL10A226MPCNUB# 4 1.25 10 X5R 22uF ±20% CL10A226MPMNUB# 5 0.95 6.3 X5R 22uF ±20% CL10A226MQCNRB# 6 0.95 6.3 X5R 22uF ±20% CL10A226MQCNUB# 7 1.25 6.3 X5R 22uF ±20% CL10A226MQMNUB# 8 1.05 10 X5R 10uF ±20% CL10A106MPNNHB# 9 1.05 6.3 X5R 10uF ±20% CL10A106MQNNHB# 10 1.00 10 X5R 4.7uF ±10% CL10A475KP9NHB# 11 1.20 25 X5R 10uF ±20% CL10A106MAEURN# Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number 1 1.20 25 X5R 10uF ±10% CL21A106KAENRB# MULTILAYER CERAMIC CAPACITORS 83 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Low ESL Capacitors Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Application Guide sites Low ESL Features  ‌MLCCs with low equivalent series inductance (ESL) can be used in circuits with limited mounting area, as a small quantity of such MLCCs can sufficiently replace high-speed IC MLCCs. Multiple MLCC Used for Energy Transfer MLCC MLCC Low ESL MLCC High Speed IC (AP) MLCC High Speed IC (AP) Saved Space Multiple MLCC Used Low ESL MLCC Used 1 2 1.E+01 S21 MLCC Impedance(Ω) 1.E+00 1.E-01 LICC 1.E-02 Capacitor region 1.E-03 1.E+04 1.E+05 *ESL : Equivalent Series Inductance 1.E+06 ESL* Region 1.E+07 1.E+08 1.E+09 Frequency(㎒) Plane Connection 3T Cap [Comparison between Impedance-Frequency Characteristics] Application   All Application (Smart Phone, Wearable Devices, IC Package, PC) MULTILAYER CERAMIC CAPACITORS 84 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Disclaimer & Limitation of Use and Applications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Low ESL Capacitors Structure and Dimensions Low ESL Capacitor_Reverse BW T W L Dimension (mm) Size Code T Thkckness Code BW EIA (inch) 1.00±0.05mm 0.30±0.05mm 3 0.18±0.06 0204 1.60±0.20mm 0.50+0.05/-0.10mm 5 0.25±0.15 0306 L W L5 0.52±0.05mm 01 0.80±0.15mm Low ESL Capacitor_3T BW T W L Dimension (mm) Size Code L W T Thkckness Code A B C 05 1.00±0.05 0.65±0.05 0.45±0.05 5 0.17±0.10 0.35±0.10 0.15±0.10 0402 05 1.00±0.15mm 0.50±0.15mm 0.50±0.15mm 6 0.15±0.10 0.35±0.10 0.15±0.10 0402 05 1.00±0.15mm 0.50±0.15mm 0.30±0.09mm B 0.20±0.10 0.35±0.10 0.15±0.10 0402 19 1.20±0.05mm 0.90±0.05mm 0.75±0.05mm 7 0.15±0.11 0.50±0.10 0.20±0.10 0503 BW EIA (inch) Low ESL Capacitor_8T T BW W L SW W P Dimension (mm) Size Code L W T Thkckness Code A B C 10 1.60±0.10 0.80±0.10 0.5+ 0.05/- 0.1 5 0.25±0.10 0.15±0.10 0.40±0.10 0603 21 2.00±0.10 1.25±0.10 0.5+ 0.05/- 0.1 5 0.25+0.15-0.1 0.20+0.15-0.1 0.50±0.10 0805 MULTILAYER CERAMIC CAPACITORS BW EIA (inch) 85 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Disclaimer & Limitation of Use and Applications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Application Guide sites Low ESL Capacitors Capacitance Table_3T TC X5R (85℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 1005 (0402) 4 4.3uF - 15uF 1209 (0503) 4 22uF - 22uF pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range Capacitance Table_8T TC X7S (125℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 1608 (0603) 4 100nF - 2.2uF 2012 (0805) 4 2.2uF - 2.2uF pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range Capacitance Table_Reverse TC X6S (105℃) X7S (125℃) Capacitance Size mm (inch) Rated Voltage (Vdc) 0510 (0204) 4 1uF - 1uF 0510 (0204) 6.3 100nF - 100nF 0816 (0306) 4 1uF - 1uF pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range Product Line Up (X6S) Size : 0.52 × 1.00mm (inch : 0204) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.35 4 X6S 1uF ±20% CLL5X105MR3NLN# Reverse (Low ESL) Product Line Up (X7S) Size : 0.52 × 1.00mm (inch : 0204) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.35 6.3 X7S 100nF ±20% CLL5Y104MQ3NLN# Reverse (Low ESL) Size : 0.80 × 1.60mm (inch : 0306) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.55 4 X7S 1uF ±20% CL01Y105MR5NLN# Reverse (Low ESL) MULTILAYER CERAMIC CAPACITORS 86 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Low ESL Capacitors Product Line Up (X5R) Size : 1.00 × 0.50mm (inch : 0402) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.65 4 X5R 15uF ±20% CL05A156MR6NWR# 3T (Low ESL) 2 0.50 4 X5R 4.3uF ±20% CL05A435MR5NWN# 3T (Low ESL) Size : 1.20 × 0.90mm (inch : 0503) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.80 4 X5R 22uF ±20% CL19A226MR7NWN# 3T (Low ESL) Product Line Up (X7S) Size : 1.60 × 0.80mm (inch : 0603) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.55 4 X7S 2.2uF ±20% CL10Y225MR5NJN# 8T (Low ESL) 2 0.55 4 X7S 470nF ±20% CL10Y474MR5NJN# 8T (Low ESL) 3 0.55 4 X7S 100nF ±20% CL10Y104MR5NJN# 8T (Low ESL) Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.55 4 X7S 2.2uF ±20% CL21Y225MR5NJN# 8T (Low ESL) MULTILAYER CERAMIC CAPACITORS 87 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Array Type Capacitors sites Array Features  ‌As various electronic products such as portable devices have gotten smaller, several chips have been unified in order to secure mounting space.   This reduces cost of mounting and ripple voltage. ❶ End Termination ❷ Ceramic Body Application   All Application (Phone, PC, HDD/SSD Board, Tablet, Display, etc) Structure and Dimensions P SW T W BW L Dimension (mm) Size Code L W T Thkckness Code A B C 21 2.00±0.15mm 1.25±0.15mm 0.85±0.10mm C 0.25±0.10 0.25±0.15 0.50±0.10 0805 31 3.20±0.15mm 1.60±0.15mm 0.85±0.15mm C 0.40±0.20 0.30±0.15 0.80±0.20 1206 MULTILAYER CERAMIC CAPACITORS BW EIA (inch) 88 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide sites Array Type Capacitors Capacitance Table (X7R) TC X7R (125℃) Size mm (inch) Rated Voltage (Vdc) 2012 (0805) 16 3216 (1206) 25 Capacitance pF 0.1 1 10 nF 100 1 10 uF 100 1 10 100 Capacitance Range 100nF - 100nF Product Line Up (X7R) Size : 2.00 × 1.25mm (inch : 0805) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 0.95 16 X7R 100nF ±20% CL21B104MOCNBN# 8T(Array) Size : 3.20 × 1.60mm (inch : 1206) No. Thickness Max. (mm) Rated Voltage (Vdc) TC code Capacitance Capacitance Tolerance Part Number Remarks 1 1.00 25 X7R 47nF ±20% CL31B473MACNBN# 8T(Array) MULTILAYER CERAMIC CAPACITORS 89 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ sites Application Guide Application Guide Smartphone / Tablet As smartphone has high-performance hardware functions to provide enhanced user experience, various voltage regulators are required for each IC. Power management system includes several PMICs as well as charging system with external passive components. 4 Proximity Sensor Application Processor Finger Print Sensor Core 1 NPU GPU mmWave 5 Sub-6 Module Power Management Connectivity (Wi-Fi, BT, GNSS) Camera module MODEM Display, Touch Memory 3 (DRAM, NAND) Battery 5 2 Charger Wireless Charging Tablet, Optional Noise Filtering, Stable Power Delivery High Bending Strength Middle & High Freq. Noise Audible Noise High Freq. Noise, Limited Space Normal Soft Termination Low ESL Low Acoustic Embedded/LSC 1 High C 2 Audio Amp 2 4 2㎜ ↑ 1 3T 2 THMC, ANSC 5 Low Profile 3 10V ↑ 4 Low Profile MULTILAYER CERAMIC CAPACITORS 90 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ sites Application Guide Application Guide Laptop Laptop consist of various form factors and functions by models in consideration of the needs of various customers. In order to implement those functions, many of such function blocks as Memory, Storage, Wi-Fi, are organically connected around the CPU module, and require various power sources. In accordance with the recent trend of high performance, miniaturization and sliming of the sets, passive components are being developed with a focus on high temperature and high capacitance. I2C Camera module PCIe Wi-Fi module CPU Module (Core, PCH, GPU) 1 2 VDDQ CLK PLL AUX iVR VTT VDD VPP VDDSPD DDR Memory PCIe 1 Storage External Device (USB, HDMI) (M.2 SSD) 1 1 Voltage Regulator 3 Charger Battery 4 AC-DC Adapter Noise Filtering, Stable Power Delivery High Bending Strength Middle & High Freq. Noise Normal Soft Termination Low ESL 1 High C 3 4 2㎜ ↑ 2 3T, 8T 4 10V ↑ MULTILAYER CERAMIC CAPACITORS 91 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Disclaimer & Limitation of Use and Applications Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ sites Application Guide Application Guide Server In recent years, many technologies with upgraded performance, such as high-performance CPU, PCIe 5.0, and DDR5 are being applied to servers. Since such a high-performance server consumes a large amount of current during operation and generates a lot of heat to deteriorate the operation environment, high reliability of the components is required. CPU power line consuming a large amount of currents requires many small-sized and high-capacitance MLCCs to lower the impedance, and the components for hightemperature in the high-temperature environment around CPU. External (LAN,USB) External (LAN,USB) 1 2 4 Socket PCIe 3 CPU#1 1 2 Devices (SSD, GPU) DIMM (Bank2) PCIe CPU#0 DIMM (Bank1) DIMM (Bank1) 3 OCP Interface FPGA DIMM (Bank2) PCIe OCP Interface 3 PCIe Devices (SSD, GPU) 1 Socket 3 4 Voltage Regulator 3 AC-DC Power Module Noise Filtering, Stable Power Delivery High Bending Strength Middle & High Freq. Noise Normal Soft Termination Low ESL 1 High C 3 3㎜ ↑ 2 3T, 8T 3 16V ↑ 4 High Temp. (High Level Ⅰ) MULTILAYER CERAMIC CAPACITORS 92 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Component sales offices/manufacturing ‌ sites Application Guide Application Guide Network (Base Station) RUs are required to be small, light-weight and highly reliable because most of them are exposed to the sunlight being installed on towers or building roofs. With the introduction of 5G, high-integrated and high-performance FPGA/DSP are being used for network equipment to cope with the demand of faster data processing speed and to process the data traffic surge. Accordingly, the demand for high-capacitance MLCCs for stable power supply to high-performance ICs is increasing. DU (Distributed Unit) Hot Swap 1 DDR & Flash DSP 4 2 Hot Swap 4 RF Trans - ceiver Power Converter 3 VSource 2 VSource 1 RU (Radio Unit) FPGA I/O Switch Power Converter Baseband ASIC Ethernet Switch Interface Module FPGA DAC PA ADC LNA DSP DDR & Flash to Backhaul Noise Filtering, Stable Power Delivery High Bending Strength Normal Soft Termination 1 3 High Volt. 1 2 4 3㎜ ↑ 3 High C 3 High Temp. (High Level Ⅰ) MULTILAYER CERAMIC CAPACITORS 93 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Application Guide Caution/Notice Component sales offices/manufacturing ‌ sites Reliability Test Conditions No. Item 1 Appearance 2 Insulation resistance Performance Test condition No abnormal exterior appearance Visual Inspection through Microscope (x10) 10,000㏁ min. or 500㏁·㎌ min. (or 100㏁·㎌ ) product whichever is smaller (Rated voltage ≤16V :10,000㏁ min. or 100㏁· ㎌ min. product whichever is smaller) Apply the rated voltage for 60 ~ 120sec. Ratedvoltage>500V: InsulationResistance shall be measured with 500±50Vdc Apply the specified voltage* for 1~5 sec. Charge / Discharge current limit: 50mA max. Withstanding voltage 3 4 Capacitance Q ClassⅠ No dielectric breakdown ormechanical breakdown Within the specified tolerance ClassⅡ Within the specified tolerance ClassⅠ Capacitance ≥30㎊ : Q ≥ 1,000 < 30㎊ : Q ≥ 400+20×C ( C : Capacitance ) 1. Characteristic : A (X5R) Tanδ ClassⅠ Capacitance Frequency ≤1,000㎊ 1㎒±10% >1,000㎊ 1㎑±10% Voltage 0.5~5Vrms ClassⅡ Capacitance Frequency Voltage Spec ≤10㎌ 1㎑±10% 1.0±0.2Vrms 50V /35V 0.025 max / 0.05 max* >10㎌ 120㎐±20% 0.5±0.1Vrms 25V 0.025 max / 0.05 max* / 0.10 max* 16V 0.035 max / 0.10 max* Capacitance Frequency Voltage ≤10 0.035 max / 0.10 max* 0201 (0603)size 0.22㎌≤C≤10㎌ Less than 10V 1㎑±10% 0.5±0.1Vrms Rated Voltage Spec 50V≥/ 35V / 25V 0.025 max / 0.05 max* / 0.10 max* 16V 0.035 max / 0.10 max* ≤10V 0.05 max / 0.10 max* ClassⅡ In the case of Vr ≥100V products, following condition shouldbe applied. 100V≤Rated Voltage<500V : 200% of the rated Voltage 1000V≤Rated Voltage<1000V :150% of the rated Voltage Rated Voltage≥1000V :120% of the rated Voltage Rated Voltage 2. ‌Characteristic :B (X7R), X (X6S), Y (X7S) 5 * ‌CLASSⅠ (Rated Voltage<100V) : 300% of the rated Voltage CLASSⅡ (Rated Voltage<100V) : 250% of the rated Voltage 3.Characteristic : F (Y5V) Rated Voltage Spec 50V / 35V / 25V 0.05 max / 0.07 max* / 0.09 max* 16V 0.07 max / 0.09 max* / 0.125 max* 10V 0.125 max / 0.16 max* ≤6.3V 0.16 max ※ ‌The conditions of measurement may be altered upon request. Exception 0402 (1005) size, 2.2㎌≤C≤10㎌ Less than 25V 0603 (1608) size, 10㎌ Less than 25V 05J105KP5N3* 05J105KQ5N3* 03A105MO3NR* 10B225KP8* 21A475KQQ* 21A106KQQ* 21A625KPQ* 21X106MRC* 21X106KQQ* 21B106KOQ* ※ ‌A capacitor prior to measuring the capacitance is heat treated at 150℃+0/-10℃ for 1hour and maintained in ambient air for 24±2 hours. (ClassⅡ) You can check the specification at the web site or contact sales people for each product with mark* MULTILAYER CERAMIC CAPACITORS 94 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Application Guide sites Reliability Test Conditions No. Item ClassⅠ Performance Test condition Characteristic Temp. coefficien(PPM/℃) c 0 ±30 apacitance shall be measured by the steps shown in the following table. Step Capacitance change Capacitance change Characteristic A(X5R) / B(X7R) 6 Temperature characteristics of capacitance Capacitance change(%) without no bias ±15% X(X6S), Y(X7S) ±22% Z(X7T) +22% ~ -33% F(Y5V) +22% ~ -82% ClassⅡ Temperature(℃) 1 25 ± 2 2 Min. operating temp ± 2 3 25 ± 2 4 Max. operating temp ± 2 5 25 ± 2 (1) ClassⅠ Temperature Coefficient shall be calculated from the formula as below Temp. Coefficient = C2-C1 × 106[ppm/°C] C1×ΔT C1 : Capacitance at 3 C2 : Capacitance at 125℃ ΔT : 125℃-25℃=100℃ (1) ClassⅡ Capacitance change shall be calculated from the formula as below ΔC = C2-C1 × 100(%) C1 C1 : Capacitance at step 3 C2 : Capacitance at step 2 & step 4 Apply 500g.f*pressure for 10±1 sec. *200g.f for 0201 *100g.f for 01005 7 Adhesive strength of termination No indication of peeling shall occur on the terminal electrode. 500g.f Appearance No mechanical damage shall occur. Capacitance change Capacitance change 8 Bending strength ClassⅠ Capacitance ClassⅡ A(X5R), B(X7R), X(X6S), Y(X7S) Z(X7T) Within ±5% or ±0.5㎊ whichever is larger Bending Limit: 1mm Test Speed: 1.0mm/sec. Keep the test board at the limit point in 5 sec. Then Measure Capacitance 20 50 Within ±10% Bendinglimit 45±1 More than 75% of the terminal surface is to be soldered newly, so metal part does not come out or dissolve 9 Solderability MULTILAYER CERAMIC CAPACITORS R=5 Solder 45±1 Sn_Ag3_0.5Cu Solder temp. 245±5℃ Flux RMA Type Dip time 3±0.3sec Pre-heating at 80~120℃ for 10~30sec. 95 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Application Guide Caution/Notice Component sales offices/manufacturing ‌ sites Reliability Test Conditions No. Item Appearance Performance No mechanical damage shall occur Capacitance change Capacitance change ClassⅠ Capacitance 10 Resistance to soldering heat ClassⅡ Q (ClassⅠ) ±2.5% or ±0.25㎊ whichever is larger A(X5R), B(X7R), X(X6S), Y(X7S) Z(X7T) Within ±7.5% F(Y5V) Within ±20% Step Temp.(℃) Time(sec.) 1 80~100 60 2 150~180 60 Leave the capacitor in ambient condition for specified time* before measurement. 24±2 Hours (ClassⅡ) Within the specified initial value Tanδ (ClassⅡ) Within the specified initial value Insulation resistance Within the specified initial value Withstanding voltage No breakdown of dielectric Appearance No mechanical damage shall occur. ClassⅠ Capacitance ClassⅡ Vibration test Q (ClassⅠ) Solder temperature: 270±5℃DIP TIME:10±1 sec. Each termination shall be fully immersed and preheated as below: * ‌24±2 Hours (ClassⅠ) Capacitance change Capacitance change 11 Test condition ±2.5% or ±0.25㎊ whichever is larger A(X5R), B(X7R) Within ±5% X(X6S), Y(X7S) Z(X7T) Within ±10% F(Y5V) Within ±20% The capacitor shall be subjected to a harmonic motion having a total amplitude of 1.5mm changing frequency from 10Hz to 55Hz and back to 10Hz in about 1 min. Repeat this for 2hours each in 3mutually perpendicular directions. Within the specified initial value Tanδ (ClassⅡ) Within the specified initial value Insulation resistance Within the specified initial value MULTILAYER CERAMIC CAPACITORS 96 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Application Guide Caution/Notice Component sales offices/manufacturing ‌ sites Reliability Test Conditions No. Item Appearance Performance Test condition No mechanical damage shall occur Capacitance change Capacitance change ClassⅠ Capacitance ClassⅡ Q (ClassⅠ) ±7.5% or ±0.75㎊ whichever is larger A(X5R), B(X7R), X(X6S), Y(X7S) Z(X7T) Within ±12.5% F(Y5V) ±30% Applied voltage : Rated voltage Temperature : 40±2℃ Humidity : 90~95%RH Duration time : 500+12/-0Hr. Charge/Discharge current : 50㎃ max. Perform the initial measurement according to Note1. Perform the final measurement according to Note2. This test is only applied to Vr≤500V products. You can check the specification at the web site or contact sales people for each product with mark* Capacitance ‌≥30㎊: Q≥200 <30㎊: Q≥100+10/3×C (C: Capacitance) 1. ‌Capacitance : A (X5R) 12 Moisture resistance 0.05 max / 0.075 max* (35V / 50V) 0.05 max / 0.075 max* / 0.125 max*(16V / 25V) 0.075 max / 0.125 max* (≤10V) 2. ‌Capacitance : B (X7R), X (X6S) 0.05 max / 0.125 max* (16V / 25V / 35V / 50V≥) 0.075 max / 0.125 max* (≤10V) Tanδ (ClassⅡ) 3. ‌Capacitance : F (Y5V) 0.09 max (50V) 0.09 max / 0.125 max* (25V / 35V) 0.09 max / 0.125 max* / 0.16 max* (16V) 0.16 max / 0.195 max* (10V) 0.195 max (4V / 6.3V) Insulation resistance 500㏁ min. or 25㏁·㎌ min. product whichever is smaller / 12.5㏁·㎌ or over* MULTILAYER CERAMIC CAPACITORS 97 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Low ESL Capacitors Disclaimer & Limitation of Use and Applications Array Type Capacitors Application Guide Caution/Notice Component sales offices/manufacturing ‌ sites Reliability Test Conditions No. Item Appearance Performance Test condition No mechanical damage shall occur Capacitance change Capacitance change ClassⅠ Capacitance ClassⅡ Q (ClassⅠ) 13 ±3% or ±0.3㎊ whichever is larger A(X5R), B(X7R), X(X6S), Y(X7S) Z(X7T) Within ±12.5% F(Y5V) ±30% Capacitance≥30㎊ : Q≥350 10㎊≤Capacitance 2.0 EMBOSSED 8 - - 2K T ≥ 2.5 EMBOSSED 8 - - 2K 100 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications sites Packaging Specifications 3 Tape Size I. Cardboard(Paper) tape : 4mm pitch Feeding Hole Chip inserting Hole D E A F W B t P0 P2 P1 (Unit : mm) Size mm (inch) A B 1608 (0603) 1.00 ±0.10 1.90 ±0.10 2012 (0805) 1.55 ±0.10 2.30 ±0.10 3216 (1206) 2.05 ±0.10 3.60 ±0.10 W F E P1 P2 P0 D t 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 φ1.50 +0.10/-0 1.1 Below ※ The A, B in the table above are based on normal dimensions. The data may be changed with the special size tolerances. Ⅱ. Cardboard(Paper) tape : 2mm pitch Feeding Hole Chip inserting Hole D E A F W B t P0 P2 P1 (Unit : mm) Size mm (inch) A B 0402 (01005) 0.25 ±0.02 0.46 ±0.02 0.25 ±0.02 0603 (0201) 0.38 ±0.03 0.68 ±0.03 0.35 ±0.03 1005 (0402) 0.62 ±0.05 1.12 ±0.05 0510 (0204) 0.62 0.05 /-0.10 1.12 0.05 /-0.10 W 8.00 ±0.30 F 3.50 ±0.05 E 1.75 ±0.10 P1 4.00 ±0.10 P2 2.00 ±0.05 P0 4.00 ±0.10 D φ1.50 +0.1/-0.03 t 0.60 ±0.05 0.37 ±0.03 ※ The A, B in the table above are based on normal dimensions. The data may be changed with the special size tolerances. MULTILAYER CERAMIC CAPACITORS 101 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Packaging Specifications Disclaimer & Limitation of Use and Applications Application Guide sites Packaging Specifications Ⅲ. Embossed (Plastic) tape Feeding Hole Chip inserting Hole D E A F t1 W B P0 P2 P1 t0 (Unit : mm) Size mm (inch) A B W F E P1 P2 P0 D 0402 (01005) 0.23 ±0.02 0.45 ±0.02 4.00 ±0.05 1.80 ±0.02 0.90 ±0.05 1.00 ±0.02 1.00 ±0.02 2.00 ±0.03 φ0.80 ±0.04 05025 (015008) 0.32 ±0.03 0.58 ±0.03 1608 (0603) 1.05 ±0.15 1.90 ±0.15 2012 (0805) 1.45 ±0.20 2.30 ±0.20 3216 (1206) 1.90 ±0.20 3.50 ±0.20 3225 (1210) 2.80 ±0.20 3.60 ±0.20 4520 (1808) 2.30 ±0.20 4.90 ±0.20 4532 (1812) 3.60 ±0.20 4.90 ±0.20 5750 (2220) 5.50 ±0.20 6.20 ±0.20 0510 (0204) 0.62 0.05 /-0.10 1.12 0.05 /-0.10 0816 (0306) 1.10 ±0.20 1.90 ±0.20 2.00 ±0.05 8.00 ±0.30 3.50 ±0.05 φ1.50 0.1/-0.03 4.00 ±0.10 1.75 ±0.10 t1 t0 0.35 Below 0.50 Below 2.92 Below 2.00 ±0.05 4.00 ±0.10 φ1.50 0.1/-0 0.60 Below 12.0 ±0.30 5.60 ±0.05 8.00 ±0.10 3.80 Below 8.00 ±0.30 3.50 ±0.05 4.00 ±0.10 2.50 Below ※ The A, B in the table above are based on normal dimensions. The data may be changed with the special size tolerances. MULTILAYER CERAMIC CAPACITORS 102 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Packaging Specifications Low ESL Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Disclaimer & Limitation of Use and Applications Application Guide sites Packaging Specifications Ⅳ. Reel Size E C C B D A t W (Unit : mm) Symbol 7”Reel 10”Reel Tape Width A B C D E W t 4mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 5±0.5 1.2±0.2 8mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 10±1.5 0.9±0.2 12mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 13±0.5 1.2±0.2 8mm φ258±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 10±1.5 1.8±0.2 8mm φ330±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 10±1.5 1.8±0.2 12mm φ330±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 13±0.5 2.2±0.2 13”Reel 4 Cover tape peel-off force I. P ‌ eel-off force 10 g.f ≤ peel-off force ≤ 70 g.f Ⅱ. Measurement Method Cover tape's pulling strength 300mm/min Top tape 165~180° Paper tape or Embossed fape Bottom tape Unreeling direction  ‌Taping Packaging design : Packaging design follows IEC 60286-3 standard. (IEC 60286-3 Packaging of components for automatic handling - parts 3) * If the static electricity of SMT process causes any problems, please contact us. MULTILAYER CERAMIC CAPACITORS 103 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications sites Packaging Specifications 5 BOX package I. P ‌ ackaging Label REEL & Box Type Label includes the information as below. 1) 2) 3) 4) 5) 6) 1) Chip size 2) Temperature Characteristics 3) Nominal Capacitance 4) Model Name 5) LOT Number & Reel Number 6) Q’ty Ⅱ. Box Packaging 1) Double packaging with the paper type of inner box and outer box. 2) Avoid any damages during transportation by car, airplane and ship. 3) Remark information of contents on inner box and outer box ※ If special packaging is required, please contact us. Ⅲ. 7" Box packaging (Unit : mm)   Inner Box (7" × 5 REEL )   Inner Box (7" × 10 REEL ) 30±1.0 30±1.0 185±1.0 185±1.0 66±1.0 122±1.0 185±1.0 185±1.0   Outer Box (7" × 20 REEL)   Outer Box (7" × 60 REEL) 195±5.0 215±5.0 285±5.0 187±5.0 MULTILAYER CERAMIC CAPACITORS 410±5.0 370±5.0 104 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Array Type Capacitors Component sales offices/manufacturing ‌ Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Low ESL Capacitors Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications sites Packaging Specifications Ⅳ. 13” Box packaging   Inner Box (13" × 4 REEL )   Outher Box (13" × 20 REEL ) 30±1.0 337±1.0 348±5.0 339±5.0 66±1.0 337±1.0 6 336±5.0 Chip Weight Size (L/W) mm (inch) 0402 (01005) 1005 (0402) 2012 (0805) 3225 (1210) 4532 (1812) 0603 (0201) 1608 (0603) 3216 (1206) 4520 (1808) 5750 (2220) Size (T) (mm) Temp Weight (mg/pc) 0.20 C0G 0.082 0.20 X7R 0.083 0.20 X5R 0.093 0.50 C0G 1.182 0.50 X7R 1.559 0.50 X5R 1.56 0.65 C0G 7.192 1.25 X7R 16.523 1.25 X5R 16.408 2.50 X7R 116.197 2.50 X5R 121.253 1.25 X7R 96.697 0.30 C0G 0.233 0.30 X7R 0.285 0.30 X5R 0.317 0.80 C0G 4.615 0.80 X7R 5.522 0.80 X5R 5.932 1.25 C0G 28.086 1.60 X7R 54.05 1.60 X5R 45.6 1.25 C0G 47.382 1.25 X7R 63.136 1.60 X7R 260.897 ※ The weight of product is typical value per size, for more details, please contact us. MULTILAYER CERAMIC CAPACITORS 105 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice Product Characteristic data 1 Capacitance The capacitance is the ratio of the change in an electric charge according to voltage change. I. M ‌ easure capacitance with voltage and frequency specified in this document. Regarding the voltage/frequency condition for capacitance measurement of each MLCC model, please make sure to follow a section “C. Reliability test Condition - Capacitance” in this document. The following table shows the voltage and frequency condition according to the capacitance range. [The voltage and frequency condition according to MLCC the capacitance range] ClassⅠ ClassⅡ Capacitance Frequency ≤1,000㎊ 1㎒±10% >1,000㎊ 1㎑±10% Voltage 0.5~5Vrms Capacitance Frequency Voltage ≤10㎌ 1㎑±10% 1.0±0.2Vrms >10㎌ 120㎐±20% 0.5±0.1Vrms Exception 1㎑±10% 0.5±0.1Vrms ※ ‌Capacitance shall be measured after the heat treatment of 150+0/10℃ for 1hr, leaving at room temperature for 24±2hr. (ClassⅡ) Ⅱ. ‌It is recommended to use measurement equipment with the ALC (Auto Level Control) option. The reason is that when capacitance or measurement frequency is high, the output voltage of measurement equipment can be lower than the setting voltage due to the equipment limitation. Note that when capacitance or measurement frequency is excessively high, the measurement equipment may show ALC off warning and provide a lower output voltage than the setting voltage even with ALC option selected. It is necessary to ensure the output voltage of measurement equipment is the same as the setting voltage before measuring capacitance. Ⅲ. ‌Capacitance value of high dielectric constant (ClassⅡ) MLCC changes with applied AC and DC voltage. Therefore, it is necessary to take into account MLCC’s AC voltage characteristics and DC-bias voltage characteristics when applying MLCC to the actual circuit. Ⅳ. ‌The capacitance is in compliance with the EIA RS-198-1-F-2002. 2 Tan δ (DF) I. ‌An ideal MLCC’s energy loss is zero, but real MLCC has dielectric loss and resistance loss of electrode. DF (Dissipation Factor) is defined as the ratio of loss energy to stored energy and typically being calculated as percentage. Ⅱ. ‌Quality factor (Q factor) is defined as the ratio of stored energy to loss energy. The equation can be described as 1/ DF. Normally the loss characteristic of ClassⅠ MLCC is presented in Q, since the DF value is so small whereas the loss characteristic of ClassⅡ MLCC is presented in DF. Ⅲ. ‌It is recommended to use ClassⅠ MLCC for applications to require good linearity and low loss such as coupling circuit, filter circuit and time constant circuit. MULTILAYER CERAMIC CAPACITORS 106 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 3 Insulation Resistance Ceramic dielectric has a low leakage current with DC voltage due to the high insulating properties. Insulation resistance is defined as the ratio of a leakage current to DC voltage. I. W ‌ hen applying DC voltage to MLCC, a charging current and a leakage current flow together at the initial stage of measurement. 4 While the charging current decreases, and insulation resistance (IR) in MLCC is saturated by time. Therefore, insulation resistance shall be measured 1 minute after applying the rated voltage. Capacitance Aging The aging characteristic is that the high dielectric (ClassⅡ) MLCC decreases capacitance value over time. It is also necessary to consider the aging characteristic with voltage and temperature characteristics when ClassⅡ MLCC is used in circuitry. I. I‌n general, aging causes capacitance to decrease linearly with the log of time as shown in the following graph. Please check with SEMCO for more details, since the value may vary between different models. Ⅱ. A ‌ fter heat treatment (150 °C, 1hour), the capacitance decreased by aging is recovered, so aging should be considered again from the time of heat treatment. C0G X7R Capacitance Change(%) X5R 1 10 100 1,000 Time(h) 10,000 100,000 * Sample : C0G, X7R, X5R [Example of Capacitance Aging] MULTILAYER CERAMIC CAPACITORS 107 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 5 Temperature Characteristics of Capacitance (TCC) Please consider temperature characteristics of capacitance since the electrical characteristics such as capacitance changes which is caused by a change in ceramic dielectric constant by temperature. 20 20 0 0 -20 -20 ΔC(%) ΔC(%) I. I‌t is necessary to check the values specified in section “C. Reliability test Condition–Temperature Characteristics” for the temperature and capacitance change range of MLCC. -40 -40 -60 -60 -80 -80 -100 DC Voltage = 3.15 Vdc -100 -55 -35 -15 5 25 45 65 85 -55 -35 -15 Temperature(℃) 5 25 45 65 85 Temperature(℃) * Sample : 10uF, Rated voltage 6.3V * Sample : 10uF, Rated voltage 6.3V [Example of Temperature Characteristics (X5R)] [Example of Bias TCC] Ⅱ. ‌When selecting MLCC, it is necessary to consider the heat characteristics of a system, room temperature and TCC of MLCC, since the applied temperature may change the capacitance of MLCC. Ⅲ. ‌In addition, Bias TCC of MLCC should be taken into account when DC voltage is applied to MLCC. 6 Self-heating Temperature It is necessary to design the system, with considering self-heating generated by the ESR (Equivalent Series Resistance) of MLCC when AC voltage or pulse voltage is applied to MLCC. Ⅱ. T ‌ he reliability of MLCC may be affected by MLCC being used in an AC voltage or pulse voltage circuit, even the AC voltage or the pulse voltage is within the range of rated voltage. Therefore, make sure to check the following conditions. 1) ‌The surface temperature of MLCC must stay within the maximum operating temperature after AC or Pulse voltage is applied. 2) ‌The rise in increase by self-heating of MLCC must not exceed 20℃ 100 Temperature Rise(oC) I. W ‌ hen MLCC is used in an AC voltage or pulse voltage circuit, self-heating is generated when AC or pulse current flows through MLCC. Short-circuit may be occurred by the degradation of MLCC’s insulating properties. 10 10㎑ 100㎑ 500㎑ 1000㎑ -100 0 1 2 3 4 5 Ripple Current(Arms) * Sample : X5R 10uF, Rated voltage 6.3V [Example of Ripple current] MULTILAYER CERAMIC CAPACITORS 108 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 7 DC & AC Voltage Characteristics It is required to consider voltage characteristics in the circuit since the capacitance value of high dielectric constant MLCC (ClassⅡ) is changed by applied DC & AC voltage. I. ‌Please ensure the capacitance change is within the allowed operating range of a system. In particular, when high dielectric constant type MLCC (ClassⅡ) is used in circuit with narrow allowed capacitance tolerance, a system should be designed with considering DC voltage, temperature characteristics and aging characteristics of MLCC. Ⅱ. I‌t is necessary to consider the AC voltage characteristics of MLCC and the AC voltage of a system, since the capacitance value of high dielectric constant type MLCC (ClassⅡ) varies with the applied AC voltage. 20 40 30 0 20 ΔC(%) ΔC(%) -20 -40 -60 10 0 -10 -20 -80 -30 -40 -100 0 1 2 3 4 5 6 DC Voltage(V) * Sample : X5R 10uF, Rated voltage 6.3V [Example of DC Bias characteristics] MULTILAYER CERAMIC CAPACITORS 0.0 0.5 1.0 1.5 2.0 AC Voltage(Vrms) * Sample : X5R 10uF, Rated voltage 6.3V [Example of AC voltage characteristics] 109 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 8 Impedance Characteristic Electrical impedance (Z) of MLCC is the measurement of the opposition that MLCC presents to a current (I) when a voltage (V) is applied. It is defined as the ratio of the voltage to the current (Z=V/I). Impedance extends the concept of resistance to AC circuits and is a complex number consisting of the real part of resistance (R) and the imaginary part of reactance (X) as Z=R+jX. Therefore, it is required to design circuit with consideration of the impedance characteristics of MLCC based on the frequency (Z=R+jX) I. ‌MLCC operates as a capacitor in the low frequency and its reactance (XC) decreases as frequency increases ( X_C=1/j2πfC ) where f is frequency and C is capacitance. The resistance (ESR; Equivalent Series Resistance) of MLCC in the low frequency mainly comes from the loss of its dielectric material. Ⅲ. ‌SRF (Self Resonant Frequency) of MLCC is the frequency where its capacitive reactance (XC) and inductive reactance(XL) cancel each other and the impedance of MLCC has only ESR at SRF. Ⅳ. T ‌ he impedance of MLCC can be measured by a network analyzer or an impedance analyzer. When using the network analyzer, please note that the small-signal input may lead to the impedance of low capacitance caused by the AC voltage characteristic of MLCC. MULTILAYER CERAMIC CAPACITORS Impedance IZI, ESR 100 (Capacitor region) (Inductor region) 10 lZl, ESR(Ohm) Ⅱ. ‌MLCC operates as an inductor in the high frequency and the inductance of MLCC is called ESL (Equivalent Series Inductance). The reactance (XL) of MLCC in the high frequency increases as frequency increases ( X_ L=j2πf·ESL ). The resistance (ESR) of MLCC in the high frequency mainly comes from the loss of its electrode metal. SRF 1 0.1 lZl ESR 0.01 0.01 0.1 1 10 100 1000 10000 Frequency(㎒) * Sample : X5R 1uF, Rated voltage 6.3V [Example of Impedance characteristics] 110 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Reliability Test Conditions High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Caution/Notice Electrical & Mechanical Caution 1 Derating MLCC with the test voltage at 100% of the rated voltage in the high temperature resistance test are labeled as “derated MLCC.” For this type of MLCC, the voltage and temperature should be derated as shown in the following graph for the equivalent life time of a normal MLCC with the test voltage at 150% of the rated voltage in the high temperature resistance test. I. T ‌ he derated MLCC should be applied with the derating voltage and temperature as shown in the following graph. Voltage Derating Ratio(%) 100 Ⅱ. ‌The “Temperature of MLCC” in the x-axis of the graph below indicates the surface temperature of MLCC including self-heating effect. The “Voltage Derating Ratio” in the y-axis of the graph below gives the maximum operating voltage of MLCC with reference to the maximum voltage (Vmax) as defined in section “3-2. Applied Voltage.” 85℃ 80 105℃ 125℃ (Max. Temp. of MLCC) 60 40 Operating Max. Voltage Voltage = Derating Ratio Rated Voltage of MLCC 20 0 0 20 40 60 80 100 120 140 Temperature of MLCC(℃) * Vmax ≤ Derated Voltage * Only the Derating marked models [Example of derating graph for derated MLCC] 2 Applied Voltage The actual applied voltage on MLCC should not exceed the rated voltage set in the specifications. I. Cautions by types of voltage applied to MLCC  ‌For DC voltage or DC+AC voltage, DC voltage or the maximum value of DC + AC voltage should not exceed the rated voltage of MLCC.  ‌For AC voltage or pulse voltage, the peak-to-peak value of AC voltage or pulse voltage should not exceed the rated voltage of MLCC.   Abnormal voltage such as surge voltage, static electricity should not exceed the rated voltage of MLCC. DC+Pulse Voltage Voltage DC+AC Voltage 2 Voltage Voltage DC+AC Voltage 1 Voltage AC Voltage Voltage DC Voltage VMax 0 VMax VMax Time 0 Time VMax VMax 0 Time 0 Time 0 Time [Types of Voltage Applied to the Capacitor] MULTILAYER CERAMIC CAPACITORS 111 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ Reliability Test Conditions High Bending Strength Capacitors Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice ‌‌Effect of EOS (Electrical Overstress) Ⅱ.  ‌Electrical Overstress such as a surge voltage or EOS can cause damages to MLCC, resulting in the electrical short failure caused by the dielectric breakdown in MLCC.  ‌Down time of MLCC is varied with the applied voltage and the room temperature and a dielectric shock caused by EOS can accelerate heating on the dielectric. Therefore, it can bring about a failure of MLCC in a market at the early stage.  ‌Please use caution not to apply excessive electrical overstress including spike voltage MLCC when preparing MLCC for testing or evaluating. (1) Surge When the overcurrent caused by surge is applied to MLCC, the influx of current into MLCC can induce the overshooting phenomenon of voltage as shown in the graph below and result in the electrical short failure in MLCC. Therefore, it is necessary to be careful to prevent the influx of surge current into MLCC. (2) ESD (Electrostatic Discharge) Since the voltage of the static electricity is very high but the quantity of electric charge is small compared to the surge, ESD can cause damage to MLCC with low capacitance as shown in the following graph, whereas surge with lots of electric charge quantity can cause damages to even high capacitance MLCC. 1000 High Stress for low cap. MLCC Voltage of Surge(21 Vmax) Voltage of MLCC is higher than Surge voltage by overshooting 100 Voltage of MLCC(V) Voltage Measured Voltage of MLCC (53 Vmax) 10 (ESD 8kV) Voltage by ESD 1 0.1 0.01 0.001 Time 0.01 0.1 1 10 100 Capacitance(㎌) * Simulation for ESD 8kV [Example of Surge applied to MLCC] 3 [Example of ESD applied to MLCC] Vibration Please check the types of vibration and shock, and the status of resonance. Manage. MLCC not to generate resonance and avoid any kind of impact to terminals. When MLCC is used in a vibration environment, please make sure to contact us for the situation and consider special MLCC such as Soft-term, etc. 4 Shock Mechanical stress caused by a drop may cause damages to a dielectric or a crack in MLCC. Do not use a dropped MLCC to avoid any quality and reliability deterioration. When piling up or handling printed circuit boards, do not hit MLCC with the corners of a PCB to prevent cracks or any other damages to the MLCC. 5 Piezo-electric Phenomenon MLCC may generate a noise due to vibration at specific frequency when using the high dielectric constant MLCC (ClassⅡ) at AC or Pulse circuits. MLCC may cause a noise if MLCC is affected by any mechanical vibrations or shocks. MULTILAYER CERAMIC CAPACITORS 112 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice Process of Mounting and Soldering 1 Mounting MLCC with the test voltage at 100% of the rated voltage in the high temperature resistance test are labeled as “derated MLCC.” For this type of MLCC, the voltage and temperature should be derated as shown in the following graph for the equivalent life time of a normal MLCC with the test voltage at 150% of the rated voltage in the high temperature resistance test. I. M ‌ ounting position It is recommended to locate the major axis of MLCC in parallel to the direction in which the stress is applied. Not recommended Recommended Ⅱ. C ‌ autions during mounting near the cutout Please take the following measures to effectively reduce the stress generated from the cutting of PCB. Select the mounting location shown below, since the mechanical stress is affected by a location and a direction of MLCC mounted near the cutting line. ※ ‌Relative mechanical stress ②>① ③>① ④>① Cutting line Ⅲ. C ‌ autions during mounting near screw If MLCC is mounted near a screw hole, the board deflection may be occurred by screw torque. Mount MLCC as far from the screw holes as possible. Not recommended MULTILAYER CERAMIC CAPACITORS Recommended 113 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Normal Capacitors_High Level Ⅱ Reliability Test Conditions Component sales offices/manufacturing ‌ Caution/Notice 2 Caution before Mounting I. I‌t is recommended to store and use MLCC in a reel. Do not re-use MLCC that was isolated from the reel. Ⅱ. C ‌ heck the capacitance characteristics under actual applied voltage. Ⅲ. C ‌ heck the mechanical stress when actual process and equipment is in use. Ⅳ. C ‌ heck the rated capacitance, rated voltage and other electrical characteristics before assembly. Heat treatment must be done prior to measurement of capacitance. Ⅴ. Check the solderability of MLCC that has passed shelf life before use. Ⅵ. The use of Sn-Zn based solder may deteriorate the reliability of MLCC. 3 Cautions during Mounting with Mounting (pick-and-place) Machines I. Mounting Head Pressure ‌Excessive pressure may cause cracks in MLCC. It is recommended to adjust the nozzle pressure within the maximum value of 300g.f. Additional conditions must be set for both thin film and special purpose MLCC. Ⅱ. Bending Stress When using a two-sided substrate, it is required to mount MLCC on one side first before mounting on the other side due to the bending of the substrate caused by the mounting head. Support the substrate as shown in the picture below when MLCC is mounted on the other side. If the substrate is not supported, bending of the substrate may cause cracks in MLCC. Nozzle Force Support Pin Ⅲ. S ‌ uction nozzle Dust accumulated in a suction nozzle and suction mechanism can impede a smooth movement of the nozzle. This may cause cracks in MLCC due to the excessive force during mounting. If the mounting claw is worn out, it may cause cracks in MLCC due to the uneven force during positioning. A regular inspection such as maintenance, monitor and replacement for the suction nozzle and mounting claw should be conducted. MULTILAYER CERAMIC CAPACITORS 114 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 4 Reflow soldering MLCC is in a direct contact with the dissolved solder during soldering, which may be exposed to potential mechanical stress caused by the sudden temperature change. Therefore, MLCC may be contaminated by the location movement and flux. For the reason, the mounting process must be closely monitored. Method Classification Infrared rays Hot plate Overall heating VPS(Vapor phase) Reflow soldering Air heater Local heating Laser Light beam I. Reflow Profile Pre-heating 260±5℃ 30sec. Soldering Temp.(℃) Gradual cooling in the air 217℃ 200℃ 150℃ 60~120sec. 60~150sec. Time(sec) [Reflow Soldering Conditions] Use caution not to exceed the peak temperature (260℃) and time (30sec) as shown. Pre-heating is necessary for all constituents including the PCB to prevent the mechanical damages on MLCC. The temperature difference between the PCB and the component surface must be kept to the minimum. As for reflow soldering, it is recommended to keep the number of reflow soldering to less than three times. Please check with us when the number of reflow soldering needs to exceed three times. Care must be exercised especially for the ultra-small size, thin film and high capacitance MLCC as they can be affected by thermal stress more easily. MULTILAYER CERAMIC CAPACITORS 115 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice ‌ Reflow temperature Ⅱ. The following quality problem may occur when MLCC is mounted with a lower temperature than the reflow temperature recommended by a solder manufacturer. The specified peak temperature must be maintained after taking into consideration the factors such as the placement of peripheral constituent and the reflow temperature.  ‌Drop in solder wettability  ‌Solder voids  ‌Potential occurrence of whisker  ‌Drop in adhesive strength  ‌Drop in self-alignment properties  ‌Potential occurrence of tombstones ‌ Cooling Ⅲ. Natural cooling with air is recommended. ‌Ⅳ. Optimum solder flux for reflow soldering  ‌Overly the thick application of solder pastes results in an excessive solder fillet height.  ‌This makes MLCC more vulnerable to the mechanical and thermal stress from the board, which may cause cracks in MLCC.  ‌Too little solder paste results in a lack of the adhesive strength, which may cause MLCC to isolate from PCB  ‌Check if solder has been applied uniformly after soldering is completed. Too Much Solder large stress may cause cracks Not enough solder Weak holding force may cause bad connections or detaching of the capacitor  ‌It is required to design a PCB with consideration of a solder land pattern and its size to apply an appropriate amount of solder to MLCC. The amount of the solder at the edge may impact directly on cracks in MLCC.  ‌The design of a suitable solder land is necessary since the more the solder amount is, the larger the force MLCC experiences and the higher the chance MLCC cracks. MULTILAYER CERAMIC CAPACITORS 116 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 5 Flow soldering I. Flow profile 260±3℃ 5sec. max. Pre-heating Soldering Temp.(℃) Gradual cooling in the air ΔT i) 3216 and below : 150℃ max. Pre-heating Temp.(℃) 120sec. min Time(sec) [Flow Soldering Conditions] Take caution not to exceed peak temperature (260℃) and time (5sec) as shown. Please contact us before use the type of high capacitance and thin film MLCC for some exceptions that may be caused. ‌ Caution before Flow soldering Ⅱ.  ‌When a sudden heat is applied to MLCC, the mechanical rigidity of MLCC is deteriorated by the internal deformation of MLCC. Preheating all the constituents including PCB is required to prevent the mechanical damages on MLCC. The temperature difference between the solder and the surface of MLCC must be kept to the minimum.  ‌If the flow time is too long or the flow temperature is too high, the adhesive strength with PCB may be deteriorated by the leaching phenomenon of the outer termination, or the capacitance value may be dropped by weak adhesion between the internal termination and the outer termination. MULTILAYER CERAMIC CAPACITORS 117 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Reliability Test Conditions High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Caution/Notice 6 Soldering Iron Manual soldering can pose a great risk on creating thermal cracks in MLCC. The high temperature soldering iron tip may come into a direct contact with the ceramic body of MLCC due to the carelessness of an operator. Therefore, the soldering iron must be handled carefully, and close attention must be paid to the selection of the soldering iron tip and to temperature control of the tip. I. How to use a soldering Iron  ‌In order to minimize damages on MLCC, preheating MLCC and PCB is necessary.  ‌A hot plate and a hot air type preheater should be used for preheating  ‌Do not cool down MLCC and PCB rapidly after soldering.  ‌Keep the contact time between the outer termination of MLCC and the soldering iron as short as possible. Long soldering time may cause problems such as adhesion deterioration by the leaching phenomenon of the outer termination. Variation of Temp. Soldering Temp.(℃) Pre-heating Time(sec) Soldering Time(sec) Cooling Time(sec) ΔT≤130 300±10℃ max ≥60 ≤4 - * Control Δ T in the solder iron and preheating temperature. Condition of Iron facilities Wattage Tip diameter Soldering time 20W max 3㎜ max 4sec max * Caution - ‌Iron tip should not contact with ceramic body directly Lead-free solder: Sn-3.0Ag-0.5CU ‌ How to use a spot heater Ⅱ. Compared to local heating using a solder iron, heat by a spot heater heats the overall MLCC and the PCB, which is likely to lessen the thermal shocks. For a high density PCB, a spot heater can prevent the problem to connect between a solder iron and MLCC directly.  ‌If the distance from the air nozzle outlet to MLCC is too close, MLCC may be cracked due to the thermal stress. Follow the conditions set in the table below to prevent this problem.  ‌The spot heater application angle as shown in the figure is recommended to create a suitable solder fillet shape. ≥ 5㎜ Hot Air Application angle 45℃ Hot Air Temperature Nozzle Outlet ≤ 400℃ Application Time ≤ 10s MULTILAYER CERAMIC CAPACITORS H ea te rN Distance oz zl e  ‌In case that heat of higher than 350℃ is applied to MLCC containing epoxy material, the epoxy material in MLCC may be damaged by heat. 45° 118 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice ‌ Cautions for re-work Ⅲ.  ‌Too much solder amount will increase the risk of PCB bending or cause other damages.  ‌Too little solder amount will result in MLCC breaking loose from the PCB due to the inadequate adhesive strength.  ‌Check if the solder has been applied properly and ensure the solder fillet has a proper shape. 7 * Soldering wire below ø0.5mm is required for soldering. Cleaning I. I‌n general, cleaning is unnecessary if rosin flux is used. When acidic flux is used strongly, chlorine in the flux may dissolve into some types of cleaning fluids, thereby affecting the performance of MLCC. This means that the cleansing solution must be carefully selected and should always be new. ‌ Cautions for cleaning Ⅱ. MLCC or solder joint may be cracked with the vibration of PCB, if ultrasonic vibration is too strong during cleaning. When high pressure cleaning equipment is used, test should be done for the cleaning equipment and its process before the cleaning in order to avoid damages on MLCC. 8 Cautions for using electrical measuring probes   Confirm the position of the support pin or jig when checking the electrical performance of MLCC after mounting on the PCB.   Watch for PCB bending caused by the pressure of a test-probe or other equipment.   If the PCB is bent by the force from the test probe, MLCC may be cracked or the solder joint may be damaged.   Avoid PCB flexing by using the support pin on the back side of the PCB.   Place equipment with the support pin as close to the test-probe as possible.   Prevent shock vibrations of the board when the test-probe contacts a PCB. Test Pin Test Pin Not recommended MULTILAYER CERAMIC CAPACITORS Test Pin Recommended 119 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 9 Printed Circuit Board Cropping   Do not apply any stress to MLCC such as bending or twisting the board after mounting MLCC on the PCB.   The stress as shown may cause cracks in MLCC when cutting the board.   Cracked MLCC may cause degradation to the insulation resistance, thereby causing short circuit.   Avoid these types of stresses applied to MLCC. [Bending] [Twisting] I. Cautions for cutting PCB 10 Check a cutting method of PCB in advance. The high density board is separated into many individual boards after the completion of soldering. If the board is bent or deformed during separation, MLCC may be cracked. Carefully select a separation method that minimizes the deformation of the PCB. Assembly Handling I. Cautions for PCB handling Hold the edges of the board mounted with MLCC with both hands since holding with one hand may bend the board. Do not use dropped boards, which may degrade the quality of MLCC. ‌ Mounting other components Ⅱ. Pay attention to the following conditions when mounting other components on the back side of The board after MLCC has been mounted on the front side. When the suction nozzle is placed too close to the board, board deflection stress may be applied to MLCC on the back side, resulting in cracks in MLCC. Check if proper value is set on each chip mounter for a suction location, a mounting gap and a suction gap by the thickness of components. Nozzle Force MULTILAYER CERAMIC CAPACITORS 120 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice ‌ Board mounting components with leads Ⅲ. If the board is bent when inserting components (transformer, IC, etc.) into it, MLCC or solder joint may be cracked. Pay attention to the following:   Reduce the stress on the board during insertion by increasing the size of the lead insertion hole.   Insert components with leads into the board after fixing the board with support pins or a dedicated jig.   Support the bottom side of the board to avoid bending the board.   Check the status of the height of each support pin regularly when the support pins are used. Not recommended Recommended ‌ Socket and / or connector attach / detach Ⅳ. Since the insertion or removal from sockets and connectors may cause the board to bent, make sure that MLCC mounted on the board should not be damaged in this process. Force ‌Ⅴ. Fastening screw When attaching a shield on a board, the board may be bent during a screw tightening work. Pay attention to the following conditions before performing the work.   Plan the work to prevent the board from bending.   Use a torque driver to prevent over-tightening of the screw.   Since the board may be bent by soldering, use caution in tightening the screw. MULTILAYER CERAMIC CAPACITORS 121 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 11 Adhesive selection Pay attention to the following if an adhesive is used to position MLCC on the board before soldering. I. Requirements for Adhesives   They must have enough adhesive strength to prevent MLCC from slipping or moving during the handling the board.   They must maintain their adhesive strength when exposed to soldering temperatures.   They should not spread when applied to the PCB.   They should have a long pot life.   They should hardened quickly.   They should not corrode the board or MLCC materials.   They should be an insulator type that does not affect the characteristic of MLCC.   They should be non-toxic, not harmful, and particularly safe when workers touch the adhesives. ‌ Caution before Applying Adhesive Ⅱ. Check the correct application conditions before attaching MLCC to the board with an adhesive. If the dimension of land, the type of adhesives, the amount of coating, the contact surface areas, the curing temperature, or other conditions are not appropriate, it may degrade the MLCC performance. ‌ Cautions for selecting Adhesive Ⅲ. Depending on the type of the chosen adhesive, MLCC insulation resistance may be degraded. In addition, MLCC may be cracked by the difference in contractile stress caused by the different contraction rate between MLCC and the adhesive. ‌ Cautions for the amount of applied adhesive and curing temperature Ⅳ.  ‌The inappropriate amount of the adhesive cause the weak adhesive strength, resulting in the mounting defect in MLCC.  ‌Excessive use of the adhesive may cause a soldering defect, loss of electrical connection, incorrect curing, or slippage of a mounting position, thereby an inflow of the adhesive onto the land section should be avoided.  ‌If the curing temperature is too high or the curing time is too long, the adhesive strength will be degraded. In addition, oxidation both on the outer termination (Sn) of MLCC and the surface of the board may deteriorate the solderability. 12 Flux I. T ‌ he excessive amount of flux generates excessive flux gases which may deteriorate solderability. Therefore, apply the flux thin and evenly as a whole. Ⅱ. F ‌ lux with a high ratio of halogen may oxidize the outer termination of MLCC, if cleaning is not done properly. Therefore, use flux with a halogen content of 0.1% max. Ⅲ. S ‌ trong acidic flux can degrade the MLCC performance. Ⅳ. C ‌ heck the solder quality of MLCC and the amount of remaining flux surrounding MLCC after the mounting process. MULTILAYER CERAMIC CAPACITORS 122 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 13 Coating I. C ‌ rack caused by Coating ‌A crack may be caused in the MLCC due to amount of the resin and stress of thermal contraction of the resin during coating process. During the coating process, the amount of resin and the stress of thermal contraction of the resin may cause cracks in MLCC. ‌The difference of thermal expansion coefficient between the coating, or a molding resin may cause destruction, deterioration of insulation resistance or dielectric breakdown of MLCC such as cracks or detachment, etc. ‌ Recommended Coating material Ⅱ.   A thermal expansion coefficient should be as close to that of MLCC as possible.   A silicone resin can be used as an under-coating to buffer the stress.   The resin should have a minimum curing contraction rate.   The resin should have a minimum sensitivity (ex. Epoxy resin).  ‌The insulation resistance of MLCC can be deteriorated if a high hygroscopic property resin is used in a high humidity condition.  ‌Do not use strong acid substances due to the fact that coating materials inducing a family of halogen substances and organic acid may corrode MLCC. Design 1 Circuit design When the board is dropped or bent, MLCC mounted on the board may be short-circuited by the drop in insulation resistance. Therefore, it is required to install safety equipment such as a fuse to prevent additional accidents when MLCC is short-circuited, otherwise, electric short and fire may occur. This product is not a safety guaranteed product.. 2 PCB Design I. U ‌ nlike lead type components, SMD type components that are designed to be mounted directly on the board are fragile to the stress. In addition, they are more sensitive to mechanical and thermal stress than lead type components. ‌ MLCC crack by PCB material type Ⅱ. A great difference of the thermal expansion coefficient between PCB and MLCC causes thermal expansion and contraction, resulting in cracks in MLCC. Even though MLCC is mounted on a board with a fluorine resin or on a single-layered glass epoxy, cracks in MLCC may occur. 3 Design system evaluation I. E ‌ valuate the actual design with MLCC to make sure there is no functional issue or violation of specifications of the finished goods. ‌‌ note that the capacitance may differ based on the operating condition of the actual system since Class 2 MLCC Ⅱ. Please capacitance varies with applied voltage and temperature. ‌‌ resistance must be evaluated since the excessive surge caused by the inductance of the actual system may apply to Ⅲ. Surge MLCC. Ⅳ. ‌Note the actual MLCC size and the termination shape. MULTILAYER CERAMIC CAPACITORS 123 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Reliability Test Conditions High Bending Strength Capacitors Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Normal Capacitors_High Level Ⅱ Component sales offices/manufacturing ‌ Caution/Notice 4 Land dimension The recommended land dimension is determined by evaluating the actual SET and a board. BW T c W L a b Reflow Footprint Chip Size (mm) Chip Tol. (mm) a (mm) b (mm) c (mm) (a+2b) min (a+2b) max 0402 ± 0.02 0.14~0.20 0.14~0.22 0.20~0.26 0.42 0.64 ± 0.03 0.16~0.20 0.24~0.32 0.30~0.35 0.64 0.84 ± 0.05 0.18~0.26 0.24~0.32 0.32~0.37 0.66 0.9 ± 0.07 0.20~0.28 0.25~0.35 0.35~0.39 0.7 0.98 ± 0.09 0.22~0.30 0.25~0.35 0.35~0.39 0.72 1 ± 0.05 0.35~0.40 0.37~0.47 0.50~0.55 1.09 1.34 ± 0.07 0.37~0.42 0.37~0.47 0.52~0.58 1.11 1.36 ± 0.10 0.40~0.45 0.37~0.47 0.55~0.60 1.14 1.39 ± 0.15 0.40~0.45 0.40~0.50 0.60~0.65 1.2 1.45 ± 0.20 0.45~0.50 0.40~0.50 0.65~0.70 1.25 1.5 ± 0.30 0.45~0.50 0.42~0.52 0.70~0.75 1.29 1.54 ± 0.40 0.50~0.55 0.45~0.55 0.75~0.80 1.4 1.65 ± 0.10 0.50~0.55 0.60~0.65 0.80~0.85 1.7 1.85 ± 0.15 0.55~0.60 0.62~0.67 0.85~0.90 1.79 1.94 ± 0.20 0.60~0.65 0.65~0.70 0.90~0.95 1.9 2.05 ± 0.25 0.65~0.70 0.70~0.75 0.95~1.00 2.05 2.2 ± 0.30 0.70~0.75 0.75~0.80 1.00~1.05 2.2 2.35 ±0.10 0.70~0.75 0.75~0.80 1.25~1.30 2.2 2.35 ±0.15 0.75~0.80 0.80~0.85 1.30~1.35 2.35 2.5 ±0.20 0.80~0.85 0.85~0.90 1.35~1.40 2.5 2.65 ±0.25 0.85~0.90 0.95~1.00 1.40~1.45 2.75 2.9 ±0.30 0.90~0.95 1.05~1.10 1.45~1.50 3 3.15 ±0.20 1.70~1.90 0.85~1.00 1.60~1.80 3.4 3.9 ±0.30 1.80~2.00 0.95~1.10 1.70~1.90 3.7 4.2 3225 - 2.00~2.40 1.00~1.40 1.80~2.20 4 5.2 4532 - 2.80~3.20 1.40~1.80 2.40~3.00 5.6 6.8 5750 - 4.00~4.60 1.70~2.30 4.10~4.90 7.4 9.2 Chip Size (mm) Chip Tol. (mm) a (mm) b (mm) c (mm) (a+2b) min (a+2b) max 1608 - 0.60~1.00 0.60~0.80 0.60~0.80 1.8 2.6 2012 - 1.00~1.20 0.80~1.20 0.80~1.20 2.6 3.6 3216 - 2.00~2.40 1.00~1.20 1.00~1.40 4 4.8 0603 1005 1608 2012 3216 Flow Footprint MULTILAYER CERAMIC CAPACITORS 124 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice Others 1 Storage environment I. Recommendation for temperature/humidity ‌Even taping and packaging materials are designed to endure a long-term storage, they should be stored with a temperature of 0~40°C and an RH of 0~70% otherwise, too high temperatures or humidity may deteriorate the quality of the product rapidly. ‌As oxidization is accelerated when relative humidity is above 70%RH, the lower the humidity is, the better the solderability is. ‌As the temperature difference may cause dew condensation during the storage of the product, it is a must to maintain a temperature control environment. Ⅱ. Shelf Life An allowable storage period should be within 6 months from the outgoing date of delivery in consideration of solderability. As for products in storage over 6 months, please check solderability before use. 2 Caution for corrosive environment As corrosive gases may deteriorate the solderability of MLCC outer termination, it is a must to store MLCC in an environment without gases. MLCC that is exposed to corrosive gases may cause its quality issues due to the corrosion of plating layers and the penetration of moisture. 3 Equipment in operation I. Do not touch MLCC directly with bare hands to prevent an electric shock or damage. Ⅱ. T ‌ he termination of MLCC shall not be contacted with a conductive object (short –circuit). Do not expose MLCC to conductive liquid containing acidic or alkaline material. Ⅲ. D ‌ o not use the equipment in the following conditions. (1) Exposure to water or oil (2) Exposure to direct sunlight (3) Exposure to Ozone or ultra-violet radiation. (4) Exposure to corrosive gas (e.g. hydrogen sulfide, sulfur dioxide, chlorine, ammonia gas) (5) Exposure to vibration or mechanical shock exceeding specified limit (6) Exposure to high humidity Ⅳ. I‌f the equipment starts generating any smoke, fire or smell, immediately switch it off or unplug from the power source. If the equipment is not switched off or unplugged, serious damage may occur due to the continuous power supply. Please be careful with the high temperature in this condition. 4 Waste treatment In case of scrapping MLCC, it is incinerated or buried by a licensed industrial waste company. When scrapping MLCC, it is recommended to incinerate or bury the scrappage by a licensed industrial waste company. MULTILAYER CERAMIC CAPACITORS 125 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Level Description Low Acoustic Noise Capacitors Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Reliability Test Conditions Packaging Specifications Caution/Notice Low ESL Capacitors Disclaimer & Limitation of Use and Applications Application Guide sites Array Type Capacitors Component sales offices/manufacturing ‌ Caution/Notice 5 Operating temperature The operating temperature limit is determined by the specification of each models. I. D ‌ o not use MLCC over the maximum operating temperature. Pay attention to equipment’s temperature distribution and the seasonal fluctuation of ambient temperature. Ⅱ. T ‌ he surface temperature of MLCC cannot exceed the maximum operating temperature including self-heating effects. 6 Transportation The performance of MLCC may be affected by transportation conditions. I. M ‌ LCC shall be protected from excessive temperature, humidity and a mechanical force during transportation. During transportation, the cartons shall not be deformed and the inner packaging shall be protected from excessive external forces. Ⅱ. D ‌ o not apply excessive vibrations, shocks or excessive forces to MLCC.   If excessive mechanical shock or stress are applied, MLCC’s ceramic body may crack.  ‌When the surface of MLCC is hit with the sharp edge of an air driver, a soldering iron, or a tweezer, etc, MLCC may crack or become short-circuited. Ⅲ. M ‌ LCC may crack and become non-functional due to the excessive shocks or dropping during transportation. 7 Notice Some special products are excluded from this document. Please be advised that this is a standard product specification for a reference only. We may change, modify or discontinue the product specifications without notice at any time. So, you need to approve the product specifications before placing an order. Should you have any question regarding the product specifications, please contact our sales personnel or application engineers. MULTILAYER CERAMIC CAPACITORS 126 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard Normal Capacitors_High Level Ⅰ Normal Capacitors_High Level Ⅱ High Bending Strength Capacitors Low ESL Capacitors Array Type Capacitors Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications Component sales offices/manufacturing ‌ sites Disclaimer & Limitation of Use and Applications 1 Disclaimer The products listed as follows are NOT designed and manufactured for any use and applications set forth below. Please note that any misuse of the products deviating from products specifications or information provided in this Spec sheet may cause serious property damages or personal injury. ① Aerospace/Aviation equipment ② Automotive of Transportation equipment (vehicles, trains, ships, etc) ③ Military equipment ④ Atomic energy-related equipment ⑤ Undersea equipment ⑥ Any other applications with the same as or similar complexity or reliability to the applications 2 Limitation Please contact us with usage environment information such as voltage, current, temperature, or other special conditions before using our products for the applications listed below. The below application conditions require especially high reliability products to prevent defects that may directly cause damages or loss to third party's life, body or property. If you have any questions regarding this 'Limitation',you should first contact our sales personnel or application engineers. ① Medical equipment ② Disaster prevention/crime prevention equipment ③ Power plant control equipment ④ Traffic signal equipment ⑤ Data-processing equipment ⑥ Electric heating apparatus,burning equipment ⑦ Safety equipment ⑧ Any other applications with the same as or similar complexity or reliability to the applications MULTILAYER CERAMIC CAPACITORS 127 Explanation of Ceramic Capacitors Embedded/LSC Capacitors Reliability Test Conditions Reliability Level Description Low Acoustic Noise Capacitors Caution/Notice Part Numbering Normal Capacitors_Standard High Bending Strength Capacitors Low ESL Capacitors Normal Capacitors_High Level Ⅰ Array Type Capacitors Normal Capacitors_High Level Ⅱ Application Guide Packaging Specifications Disclaimer & Limitation of Use and Applications ‌Component sales offices/manufacturing sites Component sales offices Head Office 150, Maeyeong-ro, Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea Tel  +82-31-210-5114 (Main Number) America Asia San Jose Shenzhen Samsung Electro Mechanics America Inc. (HQ) 3655 N 1st street, San Jose CA 95134, U.S.A. Tel  +1-408-544-5454 Samsung Electro-Mechanics (ShenZhen) Co.,Ltd.(HQ) 14F, Tower A, SCC Building, Junction of Houhai Blvd. and Haide 1st Rd., Nanshan Dist., Shenzhen City, China. Tel  +86-755-8608-5574 San Diego Samsung Electro Mechanics America Inc.(San Diego office) 5405 Morehouse Drive, Suite #220 San Diego CA 92121 USA Te  +1-858-263-3024 Phoenix Samsung Electro Mechanics America Inc.(Phoenix Office) 4505 E Chandler Blvd suite #105, Phoenix, AZ, 85048, U.S.A. Tel  +1-480-592-0184 Detroit Samsung Electro Mechanics America Inc. (Detroit Office) 4121 N Atlantic Blvd Auburn Hills Michigan 48326, U.S.A. Shanghai Samsung Electro-Mechanics Co.,Ltd. (Shanghai Branch) 13F Room 1301-1302, Tower B, SOHO Zhongshan Building, No.1065 Zhongshan West Rd., Changning Dist., Shanghai City, China. Tel  +86-21-2501-5803 Beijing Samsung Electro-Mechanics Co.,Ltd. (Beijing Branch) 21F 2101-3, Samsung Tower, Building 1,Yard31, Jinghui Street,Chaoyang Dist, Beijing City, China. Tel  +86-10-5092-8701 Taipei Samsung Electro-Mechanics Co.,Ltd. (Taipei Branch) 9F-1, No.399 Rueykuang Rd., Neihu Dist., Taipei City, Taiwan. Tel  +886-2-2656-8351 Europe Frankfurt Samsung Electro-Mechanics GmbH. (HQ) Koelner Str. 12, 65760 Eschborn, Germany. Tel ‌+49-6196-66-3300 Singapore Samsung Electro-Mechanics Private Limited(HQ) 3 Church Street Samsung Hub #23-01 Singapore. Tel  +65-6933-2600 Penang Munich Samsung Electro-Mechanics GmbH. (Munich Office) Reichenbachstrasse 2, 85737 Ismaning, Germany. Tel  +49-6196-66-7237 Samsung Electro-Mechanics Private Limited(Penang Office) Unit 9-06, Menara Boustead, 39 Jalan Sultan Ahmad Shah, 10050, Georgetown, Penang, Malaysia. Tel  +60-4-818-3912​ Stuttgart New Delhi Samsung Electro-Mechanics GmbH. (Stuttgart Office) Leitzstrasse 45, 70469 Stuttgart, Germany. Tel  +49-7114-906-6281 Samsung Electro-Mechanics Private Limited(New Delhi Office) G-4, Ground Floor Salcon Aurum Building, Jasola New Delhi-110025, India. Tel  +91-956-005-0310 Helsinki Tokyo Samsung Electro-Mechanics GmbH. (Helsinki Office) Keilaranta 1, 02150 Espoo, Finland. Tel  +35-898-53-1132 Samsung Electro-Mechanics Japan Co., Ltd(HQ) Shinagawa Grand Central Tower 9F, 2-16-4, Kounan, Minato-ku, Tokyo, Japan. Tel  +81-3-6369-6461 Manufacturing sites Suwon Plant (HQ) China Tianjin 150, Maeyeong-ro, Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea Tel  +82-31-210-5114 (Main Number) 80, Xiaqing road, TEDA west district, Tianjin, China Tel  +86-6686-3333 (1120, 3620) Philippines Busan Plant 333, Noksansaneopjung-ro, Gangseo-gu, Busan, Republic of Korea Tel  +82-31-210-5114 (Main Number) MULTILAYER CERAMIC CAPACITORS BLK 5&6 Calamba Premiere International Park Brgy. Batino Calamba, Laguna Philippines Tel  +63-49-508-8300 128 www.samsungsem.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Samsung Electro-Mechanics: CL05A106MP5NUNC CL10B475KQ8NQNC CL21A475KBQNNNE CL31B225KCHSNNE CL21B105KBFNNNE CL31A107MQHNNWE CL32A106KOTLNWE CL32B106KBJN3WE CL02C2R5BO2GNNC CL03A104KQ3NNWC CL32B102KJFNNWE CL32B226KOJNNWE CL21B104KCFNNWE CL32B226MOJNNWE CL31B104KCFNNWE CL31B106KAHNNWE CL32B475KBJN3WE CL32B475KCVZNWE CL05A475KP5NRND CL05B682KB5NNWC CL21A106KQFN3WE CL21B224KCFSNWE CL31B475KOHNNWE CL32A106MOJNNWE CL32A107MPVNNWE CL32B106KMVNNWE CL05A475MQ5NRNL CL21A106KOCL3RC CL32B476KPJNNWE CL03C470JA3NNWH CL10A226MQ8ZUNE CL21A226MAQNNNF CL21B225KOFNHNG CL31B333KCCNNWC CL10B221KB8NNWC CL32B475KBJN3WF CL05A226MQ7ZUN8 CL10B103KC8NHNC CL31B475KBHN3WE CL05B104KP5NNWC CL05A475KP5NRNC CL21A476MR7NVNC CL21A476MR9NVNC CL31C104JAHNNWE CL10B105MO8NNWC CL31B105KCHNNWE CL05B105KQ5NQWC CL32B475KBJNNWE CL10B224MQ6NXNC CL05B222JB5NNWC CL31B225KCHS3WE CL05A475MQ5NRNC CL10A106KP8NQSC CL21B105KOFNNWE CL31B475KAHNNWE CL10B102KB8NNWC CL31A106KOHNNWE CL32B106KAJNNWE CL31A106KPHNNWE CL21B104KBCNNWC CL32B106KBJNNWE CL32B475KBUYNWE CL10B474KA8NNWC CL31A106KQHNNWE CL31B225KOHNNWE CL32A476MQJNNWE CL31B106KPHNNWE CL32A226MOJNNWE CL32B225KCJSNWE CL32B105KCJNNWE CL32B104KCFNNWE CL21A226MAQNNNE CL32B226KAJNNWE CL05A475MP5NRNC CL05A105KP5NNND CL31A106MOHNNWE CL31B106KOHNNWE CL10B225KP8NNWC CL32A106KPINNWE CL05A105KP5NNNC CL10A105MQ8NNNC CL10A225KA5LNNC CL10F225ZP8NNNC CL10B103KA8NNNC CL10B102KA8NNNC CL10B101KB8NNNC CL10A474KB8NNNC CL31C470JIFNNNE CL10C130JB8NNNC CL10C131JB8NNNC CL10C140JB8NNNC CL10C150JC8NNNC CL10C182JB8NNNC CL10C360JB8NNNC CL10C3R6CB8NNNC CL10C470JC8NNNC CL10C4R3CB8NNNC CL10C620JB8NNNC CL10C6R8DB8NNNC CL10C910JB8NNNC
RG1005P-1621-B-T5
物料型号:文档中列出了多种不同尺寸和额定电压的多层陶瓷电容器(MLCC)的型号,包括C0G、X5R、X6S、X7R和X7S等不同的温度补偿类型。
器件简介:多层陶瓷电容器是一种用陶瓷材料作为介质的电容器,具有体积小、电容量大、稳定性好等特点,广泛应用于电子电路中。
引脚分配:文档中未明确提供引脚分配信息,但通常多层陶瓷电容器的引脚分配为两个端点,分别连接电容器的两个电极。
参数特性:文档提供了详细的电容器参数,包括尺寸、额定电压、电容值范围、电容公差、温度系数(TC code)等。
功能详解:多层陶瓷电容器主要功能是储存电荷和能量,在电路中起到滤波、去耦、储能等作用。
应用信息:这些电容器适用于多种电子设备,包括智能手机、平板电脑、笔记本电脑、服务器、网络设备等。
封装信息:文档列出了多种封装尺寸,如0201、0402、0603、0805、1206、1210等,以及它们的厚度和尺寸公差。
RG1005P-1621-B-T5 价格&库存
很抱歉,暂时无法提供与“RG1005P-1621-B-T5”相匹配的价格&库存,您可以联系我们找货
