RHC2512FT32R4
RHC2512FT32R4
    SEI
    32.4Ω ±1% 2W
RHC2512FT32R4 数据手册
RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • • Handles 2W of power Resistances from 0.1Ω to 1MΩ TCR of ± 100 ppm/ºC 1% and 5% tolerances Runs significantly cooler than standard thick film 2512 chip RoHS compliant and halogen free REACH compliant Electrical Specifications Maximum Working Voltage (V)(1) RHC2512 2512 2 200 Note: (1) Lesser of √ P*Ror maximum working voltage Type/Code Package Type Maximum Overload Voltage (V) 400 Power Rating (W) @ 70ºC TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 1%, 5% 0.1 - 1M ±100 Please refer to the High-Power Resistor Application Note (page 5) for more information on designing and implementing high power resistor types. Mechanical Specifications Type/Code RHC2512 L Body Length 0.248 ± 0.008 6.30 ± 0.20 W Body Width 0.126 ± 0.008 3.20 ± 0.20 H Body Height 0.024 ± 0.004 0.60 ± 0.10 Test Moisture Resistance Load Life Resistance to Soldering Temperature Cycling Thermal Shock Short Time Overload Insulation Resistance Operating temperature range is -55°C to +155°C Power Derating Curve: Percent Rated Power (%) 100 a Top Termination 0.028 ± 0.008 0.70 ± 0.20 b Bottom Termination 0.087 ± 0.008 2.20 ± 0.20 Unit inches mm Typical ±1% + 0.05Ω for 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile Heat Rise and Terminal Temperature: Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions Repeated Overload: Test condition: Voltage (Power): 2.0, 2.25, 2.5, 2.75, 3.0, 3.25 times of rated voltage. (8W, 10.1W, 12.5W, 15.1W, 18W, 21.1W) Applied time: Each voltage 5 seconds. As a reference test, the RMCF was tested with the same rated voltage and testing substrate. Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications – Embossed Plastic Tape Type RHC2512 Type RHC2512 A 0.134 ± 0.004 3.40 ± 0.10 P2 0.079 ± 0.002 2.00 ± 0.05 B 0.260 ± 0.004 6.60 ± 0.10 P0 0.157 ± 0.004 4.00 ± 0.10 W 0.472 ± 0.008 12.00 ± 0.20 D0 0.061 ± 0.002 1.55 ± 0.05 F 0.217 ± 0.002 5.50 ± 0.05 t1 0.010 ± 0.002 0.25 ± 0.05 E 0.069 ± 0.004 1.75 ± 0.10 t2 0.039 ± 0.004 1.00 ± 0.10 P1 0.157 ± 0.004 4.00 ± 0.10 Unit Inches mm Unit Inches mm Reel Specifications Type A B C D E W1 W2 Unit RHC2512 7.087 ± 0.118 180.00 ± 3.00 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.827 ± 0.031 21.00 ± 0.80 0.079 ± 0.020 2.00 ± 0.50 0.512 ± 0.012 13.00 ± 0.30 0.606 ± 0.039 15.40 ± 1.00 Inches mm High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohm at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50mΩ. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type High Power Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RHC Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Jul-04 04/27 6 www.seielect.com marketing@seielect.com RHC Series Stackpole Electronics, Inc. High Power Thick Film Chip Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 R H C 2 5 1 2 F T 1 0 K 0 Product Series Series Description RHC High Power Size Code W 2512 2 Code F J Tolerance Tol Value 1% E96, E24 5% E24 Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 Code T Packaging Description Size 7" Reel 2512 Plastic Tape Quantity 4000 Resistance Value Four characters with the multiplier used as the decimal holder. 0.1 ohm = R100 4.75 ohm = 4R75 10.2 Kohm = 10K2 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
RHC2512FT32R4
物料型号:RHC2512
器件简介:RHC系列是高功率厚膜芯片电阻,适用于需要处理高达2瓦特功率的应用。电阻值范围从0.1Ω到1MΩ,具有±100ppm/°C的温度系数(TCR),提供1%和5%的容差选项。
引脚分配:文档中未明确列出引脚分配,但提供了机械规格,包括体长、体宽、体高、上端接点和下端接点的尺寸。
参数特性: - 最大功率:2W - 工作电压:200V - 过载电压:400V - 温度系数:±100ppm/°C - 欧姆范围和容差:0.1-1MΩ,1%和5%
功能详解:RHC系列电阻具有较高的功率处理能力,比标准厚膜2512芯片电阻散热效果更好,符合RoHS和REACH标准,无卤素。
应用信息:适用于需要高功率电阻的应用,例如电源管理、电机驱动等。
封装信息:提供了推荐的焊盘布局和焊接温度曲线,以及无铅电阻的回流焊接曲线。
RHC2512FT32R4 价格&库存
很抱歉,暂时无法提供与“RHC2512FT32R4”相匹配的价格&库存,您可以联系我们找货
