DATA SHEET
THIN FILM CHIP RESISTORS
General purpose
RJ series
1%, TC50
sizes 0402/0603/0805/1206/
1210/2010/2512
Product specification – Jul 11, 2008 V.2
RoHS compliant
Chip Resistor Surface Mount
RJ
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
RJ0402 to RJ2512 general
purpose chip resistors with leadfree terminations made by thin
film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Converters
Printer equipment
Server board
Telecom
Consumer
2
9
0402 to 2512 (RoHS Compliant)
SERIES
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
RJ XXXX F X E XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512
(2) TOLERANCE
F = ±1%
(3) PACKAGING TYPE
FEATURES
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in electrodes
Resistor element and glass are
exempted by RoHS
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Saving of PCB space
None forbidden-materials used
in products/production
Halogen Free Epoxy
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
E = ±50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) OPTIONAL CODE
L = optional symbol (Note)
number
Resistance code rule
Example
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
ORDERING EXAMPLE
The ordering code of a RJ0603
chip resistor, TC50 value 56 X
with ±1% tolerance, supplied in
7-inch tape reel is:
RJ0603FRE0756R(L).
NOTE
1. All our RSMD products meet RoHS
compliant. "LFP" of the internal 2D reel
label mentions "Lead Free Process"
2. On customized label, "LFP" or specific
symbol printed and the optional "L" at
the end of GLOBAL PART NUMBER /
12NC can be added (both are on
customer request)
www.yageo.com
Jul 11, 2008 V.2
RJ
SERIES
3
9
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
GLOBAL PART NUMBER
( PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC
CODE
2390
XXX XXXXX L
(1)
(2)
(3)
(4)
RJ
START TOL. RESISTANCE
SIZE IN (1)
RANGE
EMBOSSED TAPE ON REEL(2) PAPER TAPE ON REEL (units) (2)
4,000
5,000
10,000
20,000
0402
2390
±1%
10 Ω to 121 kΩ
407 8xxxx
427 8xxxx
447 8xxxx
0603
2390
±1%
5.1 Ω to 681 kΩ
404 8xxxx
424 8xxxx
444 8xxxx
0805
2390
±1%
5.1 Ω to 1.5 MΩ
401 8xxxx
421 8xxxx
441 8xxxx
1206
2390
±1%
5.1 Ω to 1.5 MΩ
411 8xxxx
431 8xxxx
451 8xxxx
1210
2390
±1%
5.1 Ω to 1 MΩ
412 0xxxx
432 8xxxx
412 8xxxx
2010
2390
±1%
10 Ω to 1 MΩ
415 8xxxx
2512
2390
±1%
10 Ω to 1 MΩ
418 8xxxx
(1) The resistors have a 12-digit ordering code starting with 2390.
(2) The subsequent 4 digits indicate the resistor tolerance and
packaging.
50,000
Last digit of 12NC
Resistance decade (3)
Last digit
0.01 to 0.0976 X
0.1 to 0.976 X
1 to 9.76 X
8
10 to 97.6 X
9
100 to 976 X
1
ORDERING EXAMPLE
1 to 9.76 kX
2
The ordering code of a RJ0603 resistor, TC50 value 56 X, with ±1%
tolerance, supplied in tape of 5,000 units per reel is: 239040485609(L)
or RJ0603FRE0756R(L).
10 to 97.6 kX
3
100 to 976 kX
4
1 to 9.76 MX
5
10 to 97.6 MX
6
(3) The remaining 4 digits represent the resistance value with the last
digit indicating the multiplier as shown in the table of “Last digit of
12NC”.
(4) “L” is optional symbol
(Note)
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of
GLOBAL PART NUMBER / 12NC can be added (both are on customer request)
Example:
7
0.02 X
0200 or 200
0.3 X
3007 or 307
1X
1008 or 108
33 kX
3303 or 333
10 MX
1006 or 106
www.yageo.com
Jul 11, 2008 V.2
RJ
SERIES
4
9
MARKING
RJ0805 / RJ1206 / RJ1210 / RJ2010 / RJ2512
Either resistance in E-24 or E-96: 4 digits
00
YNSC004
Fig. 1 Value = 10 kΩ
First three digits for significant figure and 4th digit for number of zeros
RJ0603
E-24 series: 3 digits
ynsc015
Fig. 2 Value = 12 kΩ
First two digits for significant figure and 3rd digit for number of zeros
E-96 series: 3 digits for 0603±1% EIA-96 marking method
Fig. 3 Value = 12.4 kΩ
RJ0402
ynsc007
No marking
Fig. 4
For further marking information, please see special data sheet “Chip resistors marking”.
www.yageo.com
Jul 11, 2008 V.2
RJ
5
9
SERIES
CONSTRUCTION
A metal film layer is deposited on a high-grade ceramic
body (aluminium oxide). It is given the approximate
resistance required and the value is trimmed to within
tolerance by laser cutting of this resistive layer.
OUTLINES
For dimension see Table 1
marking layer
Internal metal electrodes are formed into several layers at
each end as a contact. To guarantee optimum
solderability, the outer layer consists of matte tin.
The resistive layer is covered with a protective coat and
printed with the resistance value. See fig. 5.
protective coat
resistive layer
inner electrode
H
termination (Ni / matte tin)
ceramic substrate
I2
Table 1 For outlines see fig. 5
TYPE
L (mm) W (mm)
H (mm)
I1 (mm)
I1
I2 (mm)
RJ0402 1.00 ±0.10 0.50 ±0.05 0.30 ±0.05 0.20 ±0.10 0.25 ±0.10
RJ0603 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15
W
RJ0805 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20 0.35 ±0.20
RJ1206 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 0.40 ±0.20
YNSC064
RJ1210 3.10 ±0.10 2.60 ±0.15 0.55 ±0.10 0.50 ±0.20 0.50 ±0.20
RJ2010 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20
RJ2512 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20
L
Fig. 5 Chip resistor outlines
ELECTRICAL CHARACTERISTICS
Table 2
RATING
MAXIMUM
WORKING
VOLTAGE
DIELECTRIC
WITHSTAND
VOLTAGE
MAXIMUM
OVERLOAD
VOLTAGE
TEMPERATURE
COEFFICIENT OF
RESISTANCE
–55 °C to +125 °C
1/16 W
25 V
100 V
100 V
±50 ppm/°C
5.1 Ω to 681 KΩ
–55 °C to +125 °C
1/16 W
50 V
100 V
100 V
±50 ppm/°C
5.1 Ω to 1.5 MΩ
–55 °C to +125 °C
1/10 W
100 V
250 V
200 V
±50 ppm/°C
5.1 Ω to 1.5 MΩ
–55 °C to +125 °C
1/8 W
150 V
250 V
250 V
±50 ppm/°C
5.1 Ω to 1 MΩ
–55 °C to +125 °C
1/4 W
150 V
400 V
300 V
±50 ppm/°C
10 Ω to 1 MΩ
–55 °C to +125 °C
1/2 W
150 V
400 V
300 V
±50 ppm/°C
10 Ω to 1 MΩ
–55 °C to +125 °C
3/4 W
150 V
400 V
300 V
±50 ppm/°C
RESISTANCE
RANGE
OPERATING
TEMPERATURE RANGE
RJ0402
10 Ω to 121 KΩ
RJ0603
RJ0805
RJ1206
RJ1210
RJ2010
RJ2512
TYPE
POWER
www.yageo.com
Jul 11, 2008 V.2
RJ
6
9
SERIES
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
RJ0402
RJ0603
RJ0805
RJ1206
RJ1210
RJ2010
RJ2512
7" (178 mm)
10,000
5,000
5,000
5,000
5,000
10" (254 mm)
20,000
10,000
10,000
10,000
10,000
13" (330 mm)
50,000
20,000
20,000
20,000
20,000
7" (178 mm)
4,000
4,000
Paper taping reel (R)
Embossed taping reel (K)
NOTE
1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Packing” document.
FUNCTIONAL DESCRIPTION
OPERATINGTEMPERATURE RANGE
Range: –55°C to +125°C
handbook,
P halfpage
POWER RATING
Each type rated power at 70°C:
RJ0402=1/16 W, RJ0603=1/16 W, RJ0805=1/10 W,
RJ1206=1/8 W, RJ1210=1/4 W, RJ2010=1/2 W,
RJ2512=3/4 W.
50
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V = √(P X R)
MLB206
max
(%Prated )
100
70
100 125
o
Tamb ( C)
Fig. 6 Maximum dissipation (Pmax) in percentage of rated power
as a function of the operating ambient temperature (Tamb )
Where
V = Continuous rated DC or AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (X)
www.yageo.com
Jul 11, 2008 V.2
RJ
SERIES
7
9
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Life/
Operational Life/
Endurance
MIL-STD-202F-method 108A
1,000 hours at 70°C ±5°C applied RCWV
1.5h on, 0.5h off, still air required
±(1%+0.05 Ω)
High
Temperature
Exposure/
Endurance at
upper category
temperature
1,000 hours at maximum operating temperature
depending on specification, unpowered
±(0.5%+0.05 Ω)
IEC 60115- 4.25.3
JIS C 5202-7.11
No direct impingement of forced air to the parts
Moisture
Resistance
MIL-STD-202F-method 106F
IEC 60115- 4.25.1
JIS C 5202-7.10
Tolerances: 125±3 °C
IEC 60115- 4.24.2
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for 10d
with 25 °C / 65 °C 95% R.H, without steps 7a & 7b,
unpowered
±(0.5%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24±2 hours after
test conclusion
Thermal Shock
MIL-STD-202 Method 107
-55/+125 °C
Note: Number of cycles required is 300. Devices
unmounted
±(0.5%+0.05 Ω)
Maximum transfer time is 20 seconds. Dwell time is
15 minutes. Air – Air
Short time
overload
MIL-R-55342D-para 4.7.5
Board Flex/
Bending
IEC60115-1 4.33
IEC60155-1 4.6.1.1
IEC60068-2-21 Ue1
2.5 times RCWV or maximum overload voltage
whichever is less for 5 sec at room temperature
±(1%+0.05 Ω)
Device mounted on PC board as described, only
1 board bending required
±(1%+0.05 Ω)
Bending : sizes ≤ 1206 : 3mm
sizes > 1206 : 2mm
Bending time: 60±5 seconds
Ohmic value checked during bending
www.yageo.com
Jul 11, 2008 V.2
RJ
SERIES
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Solderability
- Wetting
J-STD-002
Electrical Test not required. Magnification 50X.
Well tinned (≥95%
covered)
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155°C dry heat
8
9
2nd step: leadfree solder bath at 245±3°C
Dipping time: 3±0.5 seconds
- Leaching
EIA/IS 4.13B
Leadfree solder, 260 °C, 30 seconds immersion time
No visible damage
Condition B, no pre-heat of samples
±(0.5%+0.05 Ω)
IEC 60115-8 4.18
- Resistance to
Soldering Heat
MIL-STD-202 Method 210
Leadfree solder, 270 °C, 10 seconds immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Jul 11, 2008 V.2
RJ
SERIES
9
9
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 2
- Change to dual brand datasheet that describe RJ0402 to RJ2512 with RoHS
compliant
Jul 11, 2008
- Modify ordering information - global part number & 12NC
- Modify electrical characteristic
- Tests and requirements update
Version 1
May 30, 2005 -
- New datasheet for thin film general purpose chip resistors sizes of
0201/0402/0603/0805/1206/1210/2010/2512 1%, TC50 with lead-free
terminations
www.yageo.com
Jul 11, 2008 V.2
