CRG0805-R-4020FT
CRG0805-R-4020FT
    VENKEL
CRG0805-R-4020FT 数据手册
CRG SERIES GENERAL PURPOSE RoHS 10/10 GREEN RESISTORS FEATURES: • TCR as low as ±100ppm • Available Sizes 01005 to 2512 • 100% matte Tin over Nickel with wrap around termination for excellent solderability PART NUMBER STRUCTURE CRG 1206 Series Size 01005 0201 0402 0603 0805 1206 1210 2010 2512 — T — Power rating M = 1/32W (0.03W) N = 1/20W (0.05W) P = 1/16W (0.063W) Q = 1/10W (0.10W) R = 1/8W (0.125W) T = 1/4W (0.25W) U = 1/3W (0.33W) V = 1/2W (0.5W) X = 1W (1.0W) 103 J T ⎕ Resistance Tolerance F = ± 1% J = ± 5% Packaging T = Tape & Reel Optional Reel Identifies Leave blank if standard Reel size. 3 DIGIT (J TOL.) 2R2=2.2Ω 103=10KΩ 4 DIGIT (F TOL.) 10R2=10.2Ω 1002=10KΩ Jumper 3 zeros No tolerance specified for the zero ohm Add “-13” if 13” Reel is required Leave blank for zero ohm value Example P/N: CRG1206-T-103JT Standard temination finish is 100% matte Tin (Sn) over Nickel. DIMENSIONS Unit: inches (mm) SIZE L W T C­1 C­2 01005 0.016 ± 0.0008 (0.40 ± 0.02) 0.008 ± 0.0008 (0.20 ± 0.02) 0.005 ± 0.0008 (0.13 ± 0.02) 0.003 ± 0.0012 (0.08 ± 0.03) 0.004 ± 0.0012 (0.10 ± 0.03) 0201 0.023 ± 0.0012 (0.60 ± 0.03) 0.012 ± 0.0012 (0.30 ± 0.03) 0.009 ± 0.0012 (0.23 ± 0.03) 0.004 ± 0.002 (0.10 ± 0.05) 0.005 ± 0.002 (0.15 ± 0.05) 0402 0.039 ± 0.002 (1.00 ± 0.05) 0.0191 ± 0.002 (0.50 ± 0.05) 0.013 ± 0.002 (0.35 ± 0.05) 0.007 ± 0.004 (0.20 ± 0.10) 0.010 ± 0.004 (0.25 ± 0.10) 0603 0.062 ± 0.004 (1.60 ± 0.10) 0.031 ± 0.004 (0.80 ± 0.10) 0.017 ± 0.006 (0.45 ± 0.15) 0.012 ± 0.003 (0.30 ± 0.10) 0.012 ± 0.006 (0.30 ± 0.15) 0805 0.078 ± 0.004 (2.00 ± 0.10) 0.049 ± 0.004 (1.25 ± 0.10) 0.019 ± 0.006 (0.50 ± 0.15) 0.0151 ± 0.008 (0.40 ± 0.20) 0.015 ± 0.008 (0.40 ± 0.20) 1206 0.122 ± 0.003 (3.10 ± 0.10) 0.063 ± 0.004 (1.60 ± 0.10) 0.0236 ± 0.006 (0.60 ± 0.15) 0.019 ± 0.008 (0.50 ± 0.20) 0.017 ± 0.008 (0.45 ± 0.20) 1210 0.122 ± 0.003 (3.10 ± 0.10) 0.102 ± 0.004 (2.60 ± 0.10) 0.0215 ± 0.004 (0.55 ± 0.10) 0.019 ± 0.007 (0.50 ± 0.20) 0.019 ± 0.008 (0.50 ± 0.20) 2010 0.20 ± 0.004 (5.0 ± 0.20) 0.098 ± 0.008 (2.50 ± 0.20) 0.0215 ± 0.004 (0.55 ± 0.10) 0.0256 ± 0.01 (0.65 ± 0.25) 0.0236 ± 0.01 (0.60 ± 0.25) 2512 0.252 ± 0.008 (6.4 ± 0.20) 0.126 ± 0.008 (3.20 ± 0.20) 0.24 ± 0.008 (0.60 ± 0.10) 0.0256 ± 0.008 (0.65 ± 0.25) 0.0354 ± 0.01 (0.90 ± 0.25) L W C1 C1 T C2 C2 STRUCTURE 7 6 4 9 1 8 2 3 5 Email: sales@venkel.com | Phone: 512.794.0081 | 1 Alumina Substrate 6 Primary Coating 2 Backside Electrode 7 Protective Coating 3 Topside Electrode 8 Barrier Layer (Ni) 4 Edge Electrode 9 Termination-100% matte Tin 5 Resistive Layer Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 06/2020-A 1 CRG SERIES GENERAL PURPOSE RoHS 10/10 GREEN RESISTORS ELECTRICAL SPECIFICATIONS & RANGE SIZE 01005 0201 0402 0603 0805 1206 1210 2010 2512 Power Rating at 70°C (W) 0.03W (1/32W) 0.05W (1/20W) 0.063W (1/16W) 0.10W (1/10W) 0.125W (1/8W) 0.25W (1/4W) 0.33W (1/3W) 0.5W (1/2W) 1W Max. Working Voltage √PR or 25V whichever is less √PR or 25V whichever is less √PR or 50V whichever is less √PR or 50V whichever is less √PR or 150V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less √PR or 250V whichever is less Operating Temp. Range -55 to +125°C -55 to +125°C -55 to + 155°C -55 to +155°C -55 to +155°C -55 to +155°C -55 to +155°C -55 to +155°C -55 to +155°C 0.5A 0.5A 1A 1A 1.5A 2A 2.5A 3.2A 4.5A TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ± 100 - - 10.2Ω - 976KΩ 10.2Ω - 976KΩ 10.2Ω - 976KΩ 10.2Ω - 976KΩ 10.2Ω - 976KΩ 10Ω - 10MΩ 10.Ω - 10MΩ 1Ω - 10Ω Zero ohm Current Rating (Jumpers) Tolerance ±1% (F) ±5% (J) ± 200 100Ω - 1MΩ 100Ω - 1MΩ - 1MΩ - 10MΩ 1MΩ - 10MΩ 1MΩ - 10MΩ 1MΩ - 10MΩ 1Ω - 10Ω ± 300 - - 1MΩ - 10MΩ - - - - - - -300/+ 500 - - 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω - - +600/-0 10Ω - 97.6Ω 10Ω - 97.6Ω - - - - - - +800/-100 - 1Ω - 9.76Ω - - - - - - - ± 100 - - - - - - - 10Ω - 10MΩ 10Ω - 10MΩ 1Ω - 10Ω ± 200 100Ω - 1MΩ 100Ω - 10MΩ 10.2Ω - 910KΩ 11Ω - 10MΩ 11Ω - 10MΩ 11Ω - 10MΩ 11Ω - 10MΩ 1Ω - 10Ω ± 300 - - 1MΩ - 10MΩ - - - - - - -300/+ 500 - - 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω 1Ω - 10Ω - - +600/- 0 10Ω - 91Ω 10Ω - 91Ω - - - - - - - +800/-100 - 1Ω - 9.1Ω - - - - - - - NOTE: Overload Voltage=2.5*√(P*R). DERATING CURVE DERATING CURVE (CR Only) Rated power (%) 120 100 80 60 40 20 0 -50 -55 -25 0 25 50 75 100 70 Ambient temperature (˚C) 01005 & 0201 Size Email: sales@venkel.com 125 150 175 0402 to 2512 Size | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 06/2020-A 2 CRG SERIES GENERAL PURPOSE RoHS 10/10 GREEN RESISTORS TAPE & REEL SPECIFICATIONS REEL I F Label Unit: mm (inch) H M C C E F G H M 13.0 ± 0.20 (0.51 ± 0.008) 60.0± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0345 ± 0.04) 9.0 ± 0.30 (0.35 ± 0.012) 1.5 ± 0.30 (0.06 ± 0.012) 178.0 ±2.0 (7.00 ± 0.08) E Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G T G B TAPE A F W T J Dø H Embossed E Paper All dimensions in mm TAPE Paper SIZE (INCHES) A B W E F T G H J DØ 01005 0.45 ± 0.03 0.24 ±0.03 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 0.40 ± 0.05 2.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 0201 0.67 ± 0.05 0.37 ±0.05 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 0.45 ± 0.05 2.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 0402 1.20 ± 0.10 0.70 ± 0.10 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 0.40 ± 0.05 2.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 0603 1.90 ± 0.20 1.10 ± 0.20 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 0.65 ± 0.05 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 0805 2.40 ± 0.20 1.65 ± 0.20 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 1.0 ± 0.20 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 1206 3.60 ± 0.20 2.00 ± 0.20 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 1.0 ± 0.20 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 1210 3.60 ± 0.20 3.00 ± 0.20 8.00 ± 0.30 1.75 ± 0.10 3.50 ± 0.20 1.0 ± 0.20 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 2010 5.50 ± 0.20 2.80 ± 0.20 12.00 ± 0.30 1.75 ± 0.10 5.50 ± 0.10 1.0 ± 0.20 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 2512 6.90 ± 0.20 3.60 ± 0.20 12.00 ± 0.30 1.75 ± 0.10 5.50 ± 0.10 1.0 ± 0.20 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.50 + 0.1 - 0.0 PEEL BACK FORCE AND DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 06/2020-A 3 CRG SERIES GENERAL PURPOSE RoHS 10/10 GREEN RESISTORS ENVIRONMENTAL CHARACTERISTICS REQUIREMENT TEST RESISTOR DC resistance Clause 4.5 Within the specified tolerance Temperature Coefficient of Resistance (T.C.R) Clause 4.8 TEST METHOD 0Ω
CRG0805-R-4020FT 价格&库存
很抱歉,暂时无法提供与“CRG0805-R-4020FT”相匹配的价格&库存,您可以联系我们找货
