RN12F2943CT5-50
RN12F2943CT5-50
    CAL-CHIP
    薄膜电阻 294KΩ ±1% 125MW
RN12F2943CT5-50 数据手册
THIN FILM PRECISION CHIP RESISTOR - RN SERIES FEATURES - Advanced thin film technology - Very tight tolerance down to ±0.01% - Extremely low TCR down to ±5PPM/°C - Wide resistance range 1ohm - 3Mega ohm - Miniature size 0201 available CONSTRUCTION APPLICATIONS 3 - Medical Equipment - Testing I Measurement Equipment - Printer Equipment - Automatic Equipment Controller - Converters - Communication Device, Cell Phone, GPS, PDA 4 5 DERATIVE CURVE 6 8 7 1 2 9 100 80 Alumina Substrate 4 Edge Electrode (NiCr) 7 Resistor Layer 2 Bottom Electrode (Ag) 5 Barrier Layer (Ni) 8 Primary Overcoat (glass) 1 3 Top Elctrode (Ag-pd) 60 9 Secondary Overcoat (Epoxy) 6 External Electrode (Sn) 40 20 0 0 20 40 60 80 100 120 AMBIENT TEMPERATURE (C°) PART NUMBERING GUIDE SIZE L W T D1 D2 WEIGHT (INCH) (MM) (MM) (MM) (MM) (MM) (G) (1000PCS) RN02 0201 0.58±0.05 0.29±0.05 0.23±0.05 0.12±0.05 0.15±0.05 0.14 RN04 0402 1.00±0.10 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.54 RN06 0603 1.55±0.10 0.80±0.10 0.45±0.15 0.30±0.20 0.30±0.20 1.83 RN10 0805 2.00±0.15 1.25±0.15 0.50±0.15 0.35±0.20 0.40±0.25 4.71 RN12 1206 3.05±0.15 1.55±0.15 0.55±0.15 0.42±0.20 0.35±0.25 9.02 RN14 1210 3.10±0.15 2.60±0.15 0.55±0.10 0.40±0.20 0.55±0.25 10 RN20 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.30 0.55±0.25 23.61 RN25 2512 6.30±0.15 3.10±0.15 0.55±0.10 0.60±0.30 0.55±0.25 38.06 140 160 PART NUMBERING GUIDE RN 06 B 1001 CT5 25 PRODUCT TYPE DIMENSIONS RESISTANCE TOLERANCE RESISTANCE PACKAGING CODE* POWER RATING TCR (PPM˚C) 02 : 0201 04 : 0402 06 : 0603 10 : 0805 12 : 1206 14 : 1210 20 : 2010 25 : 2512 T: ± 0.01% Q: ± 0.02% A: ± 0.05% B: ± 0.1% C: ± 0.25% D: ± 0.5% F: ± 1% 4R70 : 4.7Ω 1001 : 1KΩ 1004: 1MΩ CT1: Tape & 1K Reel CT4: Tape & 4K Reel CTS: Tape & 5k Reel CT10: Tape &10k Reel Blank :Standard X : 1/10W W : 1/8W M : 1/6W P : 1/5W V : 1/4W O : 1/3W U : 1/2W A : 3/4W T : 1W Y: 1/16W Z: 1/32W 2: ±2 3: ±3 5: ±5 10: ±10 15: ±15 25: ±25 50: ±50 *See packaging specifications below for avail reel quantities STANDARD ELECTRICAL SPECIFICATIONS RESISTANCE RANGE TYPE/ ITEM POWER RATING AT 70° OPERATING TEMP. RANGE MAX OPERATING VOLTAGE MAX OVERLOAD VOLTAGE RN02 (0201) 1/32W -55 ~ + 155°C 15V 30V RN04 (0402) 1/16W -55 ~ + 155°C 25V 50V 49.9Ω - 12KΩ 10Ω - 255KΩ 4.7Ω - 511KΩ ±25 ±50 RN06 (0603) 1/16W -55 ~ + 155°C 50V 100V 4.7Ω - 332KΩ 4.7Ω - 1MΩ 1Ω - 1MΩ ±25 ±50 RN10 (0805) 1/10W -55 ~ + 155°C 100V 200V 4.7Ω - 1MΩ 4.7Ω - 2MΩ 1Ω - 2MΩ ±25 ±50 RN12 (1206) 1/8W RN14 (1210) -55 ~ + 155°C 150V 300V 4.7Ω - 1MΩ 4.7Ω-2.49MΩ 1Ω - 2.49MΩ 1/4W ±25 ±50 RN20 (2010) 1/4W -55 ~ + 155°C 150V 300V 4.7Ω - 1MΩ 1Ω - 3MΩ ±25 ±50 RN25 (2512) ±0.05% ±0.1% ±25% TCR ±0.5% - 4.7Ω - 3MΩ ±1% (PPM/°C) 49.9Ω - 4.99KΩ ±25 49.9Ω - 33KΩ ±50 1/2W Lower resistance: 1~10Ω SPECIAL ELECTRICAL SPECIFICATIONS TYPE/ ITEM POWER RATING AT 70° OPERATING TEMP. RANGE MAX OPERATING VOLTAGE MAX OVERLOAD VOLTAGE RN04 (0402) 1/16W -55 ~ + 155°C 25V 50V RN06 (0603) 1/16W -55 ~ + 155°C 50V 100V RN10 (0805) 1/10W RN12 (1206) RN14 (1210) RN20 (2010) RN25 (2512) RESISTANCE RANGE ±0.01% 100V -55 ~ + 155°C 150V -55 ~ + 155°C 150V -55 ~ + 155°C 150V -55 ~ + 155°C 150V 4.7Ω - 1MΩ 4.7Ω - 1MΩ 24.9Ω - 49.9KΩ 300V 4.7Ω - 1MΩ 24.9Ω - 100KΩ 300V 24.9Ω - 499KΩ 1/2W 4.7Ω - 511KΩ 24.9Ω - 49.9KΩ 300V 4.7Ω - 1MΩ 24.9Ω - 100KΩ 300V 24.9Ω - 499KΩ ±1% (PPM/°C) ±2 | ±3 | ±5 24.9Ω - 30KΩ 200V 24.9Ω - 499KΩ 1/4W TCR ±0.5% 49.9Ω - 60KΩ 49.9Ω - 69.8KΩ 24.9Ω - 15KΩ 24.9Ω - 499KΩ 1/4W ±0.25% 49.9Ω - 4.99KΩ 24.9Ω - 200KΩ 1/8W ±0.1% 49.9Ω - 12KΩ 24.9Ω - 100KΩ -55 ~ + 155°C ±0.05% 4.7Ω - 1MΩ ±10 ±15 ±2 | ±3 | ±5 ±10 | ±15 ±2 | ±3 | ±5 ±10 | ±15 ±2 | ±3 | ±5 ±10 | ±15 ±2 | ±3 | ±5 ±10 | ±15 ±2 | ±3 | ±5 ±10 | ±15 ±2 | ±3 | ±5 ±10 | ±15 HIGH POWER RATING ELECTRICAL SPECIFICATIONS TYPE/ ITEM POWER RATING AT 70° OPERATING TEMP. RANGE MAX OPERATING VOLTAGE MAX OVERLOAD VOLTAGE RN06 (0603) 1/10W -55 ~ + 155°C 75V 150V RESISTANCE RANGE ±0.01% ±0.05% ±0.1% ±0.25% TCR ±0.5% ±1% ±2 | ±3 | ±5 24.9Ω - 15KΩ 24.9Ω - 100KΩ 1/16W -55 ~ + 155°C 100V 150V 4.7Ω - 332KΩ 4.7Ω - 332KΩ ±10 | ±15 4.7Ω - 1MΩ ±25 | ±50 ±25 | ±50 10Ω - 332KΩ - ±2 | ±3 | ±5 24.9Ω - 30KΩ RN10 (0805) 1/8W -55 ~ + 155°C 150V 300V 4.7Ω - 332KΩ 4.7Ω - 511KΩ 24.9Ω - 200KΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 1/4W RN12 (1206) RN14 (1210) RN20 (2010) RN25 (2512) -55 ~ + 155°C 150V 300V 1/4W -55 ~ + 155°C 200V 400V 1/3W -55 ~ + 155°C 200V 400V 1/3W -55 ~ + 155°C 200V 400V 1/3W -55 ~ + 155°C 200V 400V 3/4W -55 ~ + 155°C 200V 400V 1W -55 ~ + 155°C 200V 400V 1Ω - 1MΩ 4.7Ω - 1MΩ ±10 | ±15 | ±25 | ±50 ±25 | ±50 10Ω - 1MΩ - ±2 | ±3 | ±5 24.9Ω - 49.9KΩ 4.7Ω - 1MΩ 24.9Ω - 499KΩ ±10 | ±15 | ±25 | ±50 ±2 | ±3 | ±5 24.9Ω - 49.9KΩ ±10 | ±15 | ±25 | ±50 4.7Ω - 1MΩ 24.9Ω - 499KΩ 24.9Ω - 2KΩ 4.7Ω - 2KΩ - 4.7Ω - 100Ω ±15 ±25 | ±50 ±2 | ±3 | ±5 24.9Ω - 49.9KΩ 24.9Ω - 499KΩ ±10 ±25 | ±50 10Ω - 499KΩ - (PPM/°C) 1Ω - 2KΩ ±10 | ±15 | ±25 | ±50 1Ω - 100Ω ±25 | ±50 • Operating Voltage=√(P*R) or Max. operating voltage listed above, whichever is lower. • Overload Voltage=2.5*√(P*R) or Max. overload voltage listed above, whichever is lower. • Cal-Chip is capable of manufacturing the optional spec based on customer's requirement. (Lower Resistance:1~100Ω; High Power Rating) ENVIRONMENTAL CHARACTERISTICS REQUIREMENT ITEM TOL. ≤ 0.05% Temperature Coefficient Of Resistance (T.C.R.) Short Time Overload As Spec. ∆R±0.05% +25/-55/+25/+125/+25°C ∆R±0.2% ∆R±0.2% for high power rating Insulation Resistance >1000 MΩ ∆R±0.05% Endurance Apply 100VDC for 5 seconds >7kΩ ∆R±0.5% ∆R±0.05% 70±2°C, Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” ∆R±0.3% ∆R±0.5% for high power rating ∆R±0.2% Bending Strength ∆R±0.05% Solderability 95% min. coverage Resistance to Soldering Heat ∆R±0.05% Dielectric Withstand Voltage By Type Thermal Shock ∆R±0.05% ∆R±0.25% ∆R±0.05% ∆R±0.2% Low Temperature Operation ∆R±0.5% for high power rating •Reference standards: mil-std-202, jis-c 5201-1 •Storage temperature: 25±3°c; humidity 0.05% 40±2°C, 90~95% R.H. Max working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Bending amplitude 3 mm for 10 seconds 245±5°C for 3 seconds ∆R±0.2% 260±5°C for 10 seconds Max. overload voltage for 1 minute -5°C~150°C, 100 cycles 1 hour, -65°C, followed by 45 minutes of RCWV PACKAGING T PACKAGING QUANTITY & REEL SPECIFICATIONS UNIT=mm ØC EMBOSSED PLASTIC TAPE TYPE ØA ØB ØC W T PAPER TAPE RN02 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 10k / 1k RN04 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 10k / 1k RN06 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 5k / 1k RN10 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 5k / 1k RN12 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 5k / 1k RN14 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 5k / 1k RN20 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 4k / 1k RN25 178.0 ± 1.0 60.0 + 1.0 13.5 ± 0.7 9.5 ± 1.0 11.5 ± 1.0 4k / 1k ØA ØB W PAPER TAPE SPECIFICAIONS BOTTOM TAPE TOP TAPE PAPER TAPE RESISTOR DIRECTION OF UNREELING UNIT=mm TYPE A B W E F P0 P1 P2 ØD0 T RN02 0.40±0.05 0.70±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.55±0.03 0.42±0.02 RN04 0.70±0.05 1.16±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.55±0.05 0.40±0.03 RN06 1.10±0.05 1.90±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.10 2.00±0.10 1.55±0.05 0.60±0.03 RN10 1.60±0.05 2.37±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.10 2.00±0.10 1.55±0.05 0.75±0.05 RN12 2.00±0.05 3.55±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.10 2.00±0.10 1.55±0.05 0.75±0.05 RN14 2.75±0.05 3.40±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.05 2.00±0.10 2.00±0.10 1.50±0.10 0.75±0.05 EMBOSSED PLASTIC TAPE SPECIFICATIONS Ø D0 TOP TAPE Ø D1 1.4Min. RESISTOR DIRECTION OF UNREELING EMBOSSED TAPE UNIT=mm TYPE A B W E F P0 P1 P2 ØD0 T RN20 2.85±0.10 5.45±0.10 12.00±0.10 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50±0.10 1.00±0.20 RN25 3.40±0.10 6.65±0.10 12.00±0.10 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50±0.10 1.00±0.20 RECOMMEND LAND PATTERN C B TYPE A B C RN02 .25 .30 0.40 ± 0.2 RN04 .50 .50 0.60 ± 0.2 RN06 .80 1.00 0.90 ± 0.2 RN10 1.00 1.00 1.35 ± 0.2 RN12 2.00 1.15 1.70 ± 0.2 RN14 2.00 1.15 2.50 ± 0.2 RN20 3.60 1.40 2.50 ± 0.2 RN25 4.90 1.60 3.10 ± 0.2 A SOLDERING CONDITION TEMP (°C) PEAK: 265°C 260°C/10s TEMPERATURE (°C) 260°C/10s ºTYPICAL VALUES (SOLID LINE) ºPROCESS LIMITS (DOTTED LINE) 265°C 245 235°C 220 HEAT-UP RATE ≈ 3K/s COOLING RATE ≈ 6K/s SECOND WAVE FIRSTWAVE 180 ≈5K/s ≈200K/s 150°C 150 PRE-HEATING ≈2K/s 100°C MAX 20s 90s ~ 120s FORCED COOLING ≈2K/s MAX 60s TIME: SECOND NUMBER OF REFLOW CYCLES ALLOWED: 3 TIMES TIME (SEC.) IR REFLOW SOLDERING NUMBER OF FLOW CYCLES ALLOWED: 2 TIMES WAVE SOLDERING (FLOW SOLDERING) - Time of IR Reflow soldering at maximum temperature point 260°C : 10s - Time of wave soldering at maximum temperature point 260°C : 10s - Time of soldering iron at maximum temperature point 410°C : 5s MARKING 0603 3 DIGIT MARKING 14C 3 digit marking for Example 14C = 13K7Ω 13C = 13K3Ω 68B = 4K99Ω 68X = 49.9Ω MARKING MARKING TABLE CODE E96 CODE E96 CODE E96 CODE E96 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 952 24 174 48 309 72 549 96 976 CODE A B C D E F G X Y Z MULTIPLIER 100 10 1 10 2 103 104 105 106 10 -1 10 -2 10 -3 0603 - 3 digit marking in E24 Example: 101 = 100Ω 102 = 1KΩ E24 CODE 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 0805~2512 4 digit marking EX: RESISTANCE 100Ω 2.2KΩ 10KΩ 49.9KΩ 100KΩ MARKING 1000 2201 1002 4992 1003 E-192 values are also available upon request but will have no marking on the part. Please ask sales rep for a quote and lead-time for any E-192 values. 91
RN12F2943CT5-50
物料型号:RN系列薄膜精密芯片电阻
器件简介: - 采用先进的薄膜技术 - 非常紧密的容差,低至±0.01% - 极低的温度系数TCR,低至±5PPM/°C - 广泛的电阻范围,从1欧姆到3兆欧姆 - 提供微型尺寸0201
引脚分配: - 边缘电极(NiCr) - 氧化铝基板 - 电阻层 - 底电极(Ag) - 主覆盖层(玻璃) - 阻挡层(Ni) - 顶电极(Ag-pd) - 外部电极(Sn) - 二次覆盖层(环氧树脂)
参数特性: - 尺寸范围从0201到2512 - 电阻值范围从1欧姆到1兆欧姆 - 容差范围从±0.01%到±1% - TCR范围从±2ppm/°C到±50ppm/°C - 功率额定值从1/32W到1W - 工作温度范围从-55°C到+155°C
功能详解: - 适用于医疗设备、测试/测量设备、打印机设备、自动设备控制器、转换器、通信设备、手机、GPS、PDA等应用
应用信息: - 详细列出了不同尺寸的电阻在不同应用场景下的使用情况
封装信息: - 提供了不同尺寸的封装信息,包括长、宽、高、孔径等尺寸参数 - 包装类型包括纸带、压纹塑料带等 - 提供了包装数量和卷轴规格
RN12F2943CT5-50 价格&库存
很抱歉,暂时无法提供与“RN12F2943CT5-50”相匹配的价格&库存,您可以联系我们找货
