C0603X7R251-103KNP
C0603X7R251-103KNP
    VENKEL
    贴片电容(MLCC) 0603 10nF ±10% 250V X7R
C0603X7R251-103KNP 数据手册
HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS FEATURES: • Capacitance range: 0.5pF to 2.2uF • Voltage range: 200V to 5000V • Ceramic monolithic structure provides excellent reliability • High-speed automated placement capabilities PART NUMBER STRUCTURE C 1808 X7R 202 Ceramic Capacitor Size 0603 0805 1206 1210 1808 1812 1825 2220 2225 Temperature Characteristic (Dielectric) C0G X7R Rated Voltage 1st two digits are significant followed by number of zeroes. 201 = 200V 251 = 250V 501 = 500V 601 = 600V 631 = 630V 102 = 1000V 202 = 2000V 302 = 3000V 402 = 4000V 502 = 5000V — 102 K N E Capacitance (picofarads) 1st two digits are significant, followed by number of zeroes. R denotes decimal e.g: 101 = 100pF R denotes decimal 6R8 = 6.8pF Tolerance *C = ± 0.25pF *D = ± 0.50pF F = ± 1% G = ± 2% J = ± 5% K = ± 10% M = ± 20% N = ± 30% * For values below 10pF only. Termination N = 100% matte Tin (Sn) over nickel. P = Palladium Silver Packaging E = Embossed Tape Example P/N: C1808X7R202-102KNE Standard termination finish is 100% matte Tin (Sn). DIMENSIONS Unit: inch (mm) L W C L W T E/B 0603 0.063 ± 0.0078 (1.60 ± 0.20) 0.0315 ± 0.0078 (0.80 ± 0.20) See Specific Value 0.0158 ± 0.006 (0.40 ± 0.15) 0805 0.079 ± 0.0078 (2.00 ± 0.20) 0.05 ± 0.0078 (1.25 ± 0.20) See Specific Value 0.020 ± 0.0078 (0.50 ± 0.20) 1206 0.130 ± 0.012 (3.30 ± 0.30) 0.063 ± 0.0078 (1.60 ± 0.20) See Specific Value 0.0236 ± 0.0078 (0.60 ± 0.20) 1210 0.130 ± 0.0158 (3.30 ± 0.40) 0.0985 ± 0.012 (2.50 ± 0.30) See Specific Value 0.0295 ± 0.0138 (0.75 ± 0.35) 1808 0.177 ± 0.0158 (4.50 ± 0.40) 0.080 ± 0.0098 (2.03 ± 0.25) See Specific Value 0.0295 ± 0.0138 (0.75 ± 0.35) 1812 0.177 ± 0.0158 (4.50 ± 0.40) 0.126 ± 0.0158 (3.20 ± 0.40) See Specific Value 0.0295 ± 0.0138 (0.75 ± 0.35) 1825 0.177 ± 0.0158 (4.50 ± 0.40) 0.252 ± 0.0158 (6.4 0 ± 0.40) See Specific Value 0.0295 ± 0.0138 (0.75 ± 0.35) 2220 0.225 ± 0.0158 (5.70 ± 0.40) 0.197 ± 0.0158 (5.00 ± 0.40) See Specific Value 0.0335 ± 0.0138 (0.85 ± 0.35) 2225 0.225 ± 0.0158 (5.70 ± 0.40) 0.248 ± 0.0158 (6.30 ± 0.40) See Specific Value 0.0335 ± 0.0138 (0.85 ± 0.35) C T C SIZE C Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 1 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS ELECTRICAL SPECIFICATION C0G (NP0) Typical Capacitance Change vs. Temperature 15% 10% 5% 0% -5% -10% -15% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C 125˚C Operating Temperature Range: -55°C to +125°C Temperature Coefficient: 0 ±30PPM/°C Temperature Voltage Coefficient: 0 ±30PPM/°C Insulation Resistance: >100 Ω-F or 10 GΩ, whichever is less at 25°C, WDCV. (The IR at 125°C is 10% of the value at 25°C) Withstanding Voltage: See below Capacitance Tolerance: C, D, F, G, J, K Dielectric Strength is equal to 1.5 times rated voltage (WVDC) for 500 volt capacitors and 1.2 times (WVDC) for 1,000 through 5,000 volt capacitors. Circuit applications in excess of 1,000 volts may require a surface coating to prevent external arcing. X7R Typical Capacitance Change vs. Temperature 15% 10% 5% 0% -5% -10% -15% -55˚C -25˚C 0˚C 25˚C 50˚C 75˚C 100˚C 125˚C Operating Temperature Range: -55°C to +125°C Temperature Coefficient: 0 ±15%∆°C MAX. Temperature Voltage Coefficient: X7R not applicable Insulation Resistance: >100 ohms F or 10 G ohms, whichever is less at 25°C, WDCV. (The IR at 125°C is 10% of the value at 25°C) Withstanding Voltage: See below D.F. Specification: ≥50V, ≤2.5% Capacitance Tolerance: J,K,M,N TEST PARAMETERS Test parameters for Multilayer Ceramic Capacitors - X7R: 1KHz ± 50Hz at 1.0 ± 0.2 Vrms, 25°C Test parameters for Multilayer Ceramic Capacitors - C0G (NP0): 1MHz ± 50KHz at 1.0 ± 0.2 Vrms ≤ 1000pF, 25°C 1KHz ± 50Hz at 1.0 ± 0.2 Vrms > 1000pF, 25°C Note: To ensure proper capacitance readings, the voltage level must be held constant. The HP4284 and Agilent E4980 has a “ALC” (Automatic Level Control) function and should be switched to the “ON” position for accurate capacitance readings. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 2 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B C0G (NP0) DIELECTRIC Values that are typically available. T 0603 0805 1206 1210 L 0.063 ± 0.0078 (1.60 ± 0.20) 0.083 ± 0.0078 (2.10 ± 0.20) 0.130 ± 0.012 (3.30 ± 0.30) 0.130 ± 0.0158 (3.30 ± 0.40) W 0.0315 ± 0.0078 (0.8 ± 0.20) 0.05 ± 0.0078 (1.25 ± 0.20) 0.063 ± 0.0078 (1.60 ± 0.20) 0.0985 ± 0.012 (2.50 ± 0.30) T (max) 0.0394 (1.0) 0.057 (1.45) 0.075 (1.90) 0.110 (2.80) E/B 0.0158 ± 0.006 (0.40 ± 0.15) 0.020 ± 0.0078 (0.50 ± 0.20) 0.0236 ± 0.0078 (0.60 ± 0.20) 0.0295 ± 0.0138 (0.75 ± 0.35) VDCW (MAX) 200V / 250V 0R5 1R0 1R2 1R5 1R8 2R0 2R2 2R7 3R3 3R9 5R0 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 < ------------------------------------------------------------------------------------------------ CAPACITANCE VALUE -----------------------------------------------------------------------------------------------> < ------------------------------------------------------------------------------------------------ CAPACITANCE CODE -----------------------------------------------------------------------------------------------> All measurements in inches (mm) SIZE 200V / 250V 500V 600V / 630V 200V / 250V 500V 600V / 630V 1KV 2KV 3KV 200V / 250V 500V 600V / 630V 1KV 0.5pF 1.0pF 1.2pF 1.5pF 1.8pF 2.0pF 2.2pF 2.7pF 3.3pF 3.9pF 5.0pF 8.2pF 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1000pF 1200pF 1500pF 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 3 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B C0G (NP0) DIELECTRIC Values that are typically available. T All measurements in inches (mm) SIZE 1808 1812 1825 L 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) W 0.080 ± 0.0098 (2.03 ± 0.25) 0.126 ± 0.0158 (3.20 ± 0.40) 0.252 ± 0.0158 (6.40 ± 0.40) T (max) 0.90 (2.28) 0.118 (3.0) 0.128 (3.25) E/B 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 0R5 1R0 1R2 1R5 1R8 2R0 2R2 2R7 3R3 3R9 5R0 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 < ------------------------------------------------------------------------------------------------ CAPACITANCE VALUE -----------------------------------------------------------------------------------------------> < ------------------------------------------------------------------------------------------------ CAPACITANCE CODE -----------------------------------------------------------------------------------------------> VDCW (MAX) 500V 600V / 630V 1KV 2KV 3KV 5KV 200V / 250V 500V 600V / 630V 1KV 2KV 3KV 200V / 250V 500V 600V / 630V 1KV 0.5pF 1.0pF 1.2pF 1.5pF 1.8pF 2.0pF 2.2pF 2.7pF 3.3pF 3.9pF 5.0pF 8.2pF 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1000pF 1200pF 1500pF 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 4 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B C0G (NP0) DIELECTRIC Values that are typically available. T All measurements in inches (mm) SIZE 1808 1812 1825 L 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) W 0.080 ± 0.0098 (2.03 ± 0.25) 0.126 ± 0.0158 (6.40 ± 0.40) 0.252 ± 0.0158 (5.00 ± 0.40) T (max) 0.90 (2.28) 0.118 (3.0) .122 (3.10) E/B 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 333 VDCW (MAX) 393 473 563 683 104 124 500V 600V / 630V 1KV 2KV 3KV 5KV 200V / 250V 500V 600V / 630V 1KV 2KV 3KV 200V / 250V 500V 600V / 630V 1KV 0.033uF 0.039uF 0.047uF 0.056uF 0.068uF 0.10uF 0.12uF All measurements in inches (mm) SIZE 2220 2225 L 0.225 ± 0.0158 (5.70 ± 0.40) 0.225 ± 0.0158 (5.70 ± 0.40) W 0.197 ± 0.0158 (5.00 ± 0.40) 0.248 ± 0.0158 (6.30 ± 0.40) T (max) 0.128 (3.25) 0.145 (3.68) E/B 0.0335 ± 0.0138 (0.85 ± 0.35) 0.0335 ± 0.0138 (0.85 ± 0.35) 0R5 1R0 1R2 1R5 1R8 2R0 2R2 2R7 3R3 3R9 5R0 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 VDCW (MAX) 200V / 250V 500V 600V / 630V 1KV 5KV 200V / 250V 500V 600V / 630V 1KV 0.5pF 1.0pF 1.2pF 1.5pF 1.8pF 2.0pF 2.2pF 2.7pF 3.3pF 3.9pF 5.0pF 8.2pF 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 5 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B C0G (NP0) DIELECTRIC Values that are typically available. T All measurements in inches (mm) SIZE 2220 2225 L 0.225 ± 0.0158 (5.70 ± 0.40) 0.225 ± 0.0158 (5.70 ± 0.40) W 0.197 ± 0.0158 (5.00 ± 0.40) 0.248 ± 0.0158 (6.30 ± 0.40) T (max) 0.128 (3.25) 0.145 (3.68) E/B 0.0335 ± 0.0138 (0.85 ± 0.35) 0.0335 ± 0.0138 (0.85 ± 0.35) 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 104 124 VDCW (MAX) 200V / 250V 500V 600V / 630V 1KV 5KV 200V / 250V 500V X7R DIELECTRIC 0603 0805 1206 1210 L 0.063 ± 0.0078 (1.60 ± 0.20) 0.079 ± 0.0078 (2.00 ± 0.20) 0.130 ± 0.012 (3.30 ± 0.30) 0.130 ± 0.0158 (3.30 ± 0.40) W 0.0315 ± 0.0078 (0.80 ± 0.20) 0.05 ± 0.0078 (1.27 ± 0.20) 0.063 ± 0.0078 (1.60 ± 0.20) 0.0985 ± 0.012 (2.50 ± 0.30) T (max) 0.0315 ± 0.0078 (0.80 ± 0.20) 0.057 (1.45) 0.063 ± 0.0078 (1.60 ± 0.20) 0.0985 ± 0.0197 (2.50 ± 0.50) E/B 0.0158 ± 0.006 (0.40 ± 0.15) 0.020 ± 0.0078 (0.50 ± 0.20) 0.0236 ± 0.0078 (0.60 ± 0.20) 0.0295 ± 0.0138 (0.75 ± 0.35) VDCW (MAX) 200V / 250V 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 1KV All measurements in inches (mm) SIZE 600V / 630V 1000pF 1200pF 1500pF 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF 0.033uF 0.039uF 0.047uF 0.056uF 0.068uF 0.10uF 0.12uF 200V / 600V / 500V 250V 630V 1KV 200V / 250V 500V 600V / 630V 1KV 2KV 200V / 250V 500V 600V / 630V 1KV 2KV 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1000pF 1200pF 1500pF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 6 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B X7R DIELECTRIC Values that are typically available. T 0603 0805 1206 1210 L 0.063 ± 0.0078 (1.60 ± 0.20) 0.079 ± 0.0078 (2.00 ± 0.20) 0.130 ± 0.012 (3.30 ± 0.30) 0.130 ± 0.0158 (3.30 ± 0.40) W 0.0315 ± 0.0078 (0.80 ± 0.20) 0.05 ± 0.0078 (1.27 ± 0.20) 0.063 ± 0.0078 (1.60 ± 0.20) 0.0985 ± 0.012 (2.50 ± 0.30) T (max) 0.0394 (1.0) 0.057 (1.45) 0.071 (1.80) 0.110 (2.80) E/B 0.0158 ± 0.006 (0.40 ± 0.15) 0.020 ± 0.0078 (0.50 ± 0.20) 0.0236 ± 0.0078 (0.60 ± 0.20) 0.0295 ± 0.0138 (0.75 ± 0.35) VDCW (MAX) 200V / 250V 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 104 124 154 184 224 274 334 394 474 564 684 824 105 155 225 All measurements in inches (mm) SIZE 200V / 600V / 500V 250V 630V 1KV 200V / 250V 500V 600V / 630V 1KV 2KV 200V / 250V 500V 600V / 630V 1KV 2KV 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF 0.033uF 0.039uF 0.047uF 0.056uF 0.068uF 0.10uF 0.12uF 0.15uF 0.18uF 0.22uF 0.27uF 0.33uF 0.39uF 0.47uF 0.56uF 0.68uF 0.82uF 1.0uF 1.5uF 2.2uF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 7 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE L w E/B X7R DIELECTRIC Values that are typically available. T All measurements in inches (mm) SIZE 1808 1812 1825 L 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) 0.177 ± 0.0158 (4.50 ± 0.40) W 0.080 ± 0.0098 (2.03 ± 0.25) 0.080 ± 0.0098 (2.03 ± 0.25) 0.252 ± 0.0158 (5.00 ± 0.40) T (max) 0.090 (2.28) 0.118 (3.0) 0.128 (3.25) E/B 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 0.0295 ± 0.0138 (0.75 ± 0.35) 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 104 124 154 184 224 274 334 394 474 564 684 824 105 155 225 VDCW (MAX) 500V 600V / 630V 1KV 2KV 3KV 4KV 200V / 250V 500V 600V / 630V 1KV 2KV 3KV 200V / 250V 500V 1KV 2KV 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1000pF 1200pF 1500pF 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF 0.033uF 0.039uF 0.047uF 0.056uF 0.068uF 0.10uF 0.12uF 0.15uF 0.18uF 0.22uF 0.27uF 0.33uF 0.39uF 0.47uF 0.56uF 0.68uF 0.82uF 1.0uF 1.5uF 2.2uF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 8 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS VOLTAGE AND CAPACITANCE RANGE w L E/B X7R DIELECTRIC Values that are typically available. T All measurements in inches (mm) SIZE 2220 2225 L 0.225 ± 0.0158 (5.70 ± 0.40) 0.225 ± 0.0158 (5.70 ± 0.40) W 0.197 ± 0.0158 (5.00 ± 0.40) 0.248 ± 0.0158 (6.30 ± 0.40) T (max) 0.122 (3.10) 0.145 (3.68) E/B 0.0335 ± 0.0138 (0.85 ± 0.35) 0.0335 ± 0.0138 (0.85 ± 0.35) 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 104 124 154 184 224 274 334 394 474 564 684 824 105 155 225 VDCW (MAX) 200V / 250V 500V 1KV 2KV 200V / 250V 500V 1KV 2KV 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF 1000pF 1200pF 1500pF 1800pF 2200pF 2700pF 3300pF 3900pF 4700pF 5600pF 6800pF 8200pF 0.01uF 0.012uF 0.015uF 0.018uF 0.022uF 0.027uF 0.033uF 0.039uF 0.047uF 0.056uF 0.068uF 0.10uF 0.12uF 0.15uF 0.18uF 0.22uF 0.27uF 0.33uF 0.39uF 0.47uF 0.56uF 0.68uF 0.82uF 1.0uF 1.5uF 2.2uF Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 9 HVC SERIES HIGH VOLTAGE CERAMIC CAPACITORS TAPE & REEL SPECIFICATIONS G B All tape and reel specifications must A be adhered to per EIA-481-1-A. D N C FULL RADIUS T TAPING SPECIFICATIONS To T D 10 Pitches Cumulative Tolerance 0.008 ( 0.2) REEL DIMENSIONS B min C A (7”) A (13”) D min N mIn G T max 8mm 0.3 (.012) 13 ± .05 (.512 ± .02) 178 ± 2.0 (7± .079) 330 ± 2.0 (13 ± .08) 20.2 (.795) 50 (1.97) 10 ± 1.5 (.394 ± 1.059) 14.9 (.587) 12mm 0.3 (.012) 13 ± .05 (.512 ± .02) 178 ± 2.0 (7± .079) 330 ± 2.0 (13 ± .08) 20.2 (.795) 50 (1.97) 10 ± 1.5 (.394 ± 1.059) 14.9 (.587) 7 IN. REEL QUANTITIES* SIZE 0603 0805 1205 1210 1812 2221 Tape Size 8mm 8mm 8mm 8mm 12mm 12mm Min Qty per Reel 3000 2000 2000 1000 1000 1000 Max Qty per eel 4000 5000 5000 5000 3000 1000 Po Pz A E F W B T Paper Embossed Top Tape P Unit: mm (inch) TAPE * Quantity dependent on thickness Center Of Cavity Direction Of Feed Unit: mm (inch) PAPER TAPE CARRIER DIMENSIONS (8mm) EMBOSSED CARRIER DIMENSIONS (8mm & 12mm) SIZE (inches) SIZE (inches) A B W F E P0 Pz D t P 0603 2.0 ± 0.05 1.10 ± 0.2 1.90 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 - 0.0 1.5 ± 0.1 1.15 MAX (.043 ± .008) (.075 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX) - .000 4.0 ± 0.1 (.157 ± .004) 0805 2.0 ± 0.05 1.16 ± 0.2 2.4 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 - 0.0 1.5 ± 0.1 1.15 MAX (.046 ± .008) (.095 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX) - .000 4.0 ± 0.1 (.157 ± .004) 1206 2.0 ± 0.05 2.0 ± 0.2 3.6 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 - 0.0 1.5 ± 0.1 1.15 MAX (.079 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX) - .000 4.0 ± 0.1 (.157 ± .004) A B W F E P0 Pz D T0 T P 0805 1.5 ± 0.1 1.48 ± 0.2 2.3 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 2.5 MAX (.058 ± .008) (.091 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX) - .000 0.6 MAX (.024 MAX) 4.0 ± 0.1 (.157 ± .004) 1206 1.5 ± 0.1 2.0 ± 0.2 3.6 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 2.5 MAX (.079 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX) - .000 0.6 MAX (.024 MAX) 4.0 ± 0.1 (.157 ± .004) 1210 1.5 ± 0.1 2.9 ± 0.2 3.6 ± 0.2 8.0 ± 0.2 3.5 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 2.5 MAX (.114 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX) - .000 0.6 MAX (.024 MAX) 4.0 ± 0.1 (.157 ± .004) 1808 2.5 ± 0.2 4.9 ± 0.2 12.0 ± 0.3 (.098 ± .008) (.193 ± .008) (.472 ± .012) 1.5 ± 0.1 5.5 ± 0.5 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (.22 ± .002) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) - .000 4.0 MAX (.16 MAX) 0.6 MAX (.024 MAX) 4.0 ± 0.1 (.157 ± .004) 1812 1.5 ± 0.1 3.6 ± 0.2 4.9 ± 0.2 12.0 ± 0.3 5.6 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (.142 ± .008) (.193 ± .008) (.472 ± .012) (.221 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) - .000 4.0 MAX (.16 MAX) 0.6 MAX (.024 MAX) 8.0 ± 0.1 (.315 ± .004) 2220 5.4 ± 0.2 (.21 ± .008) 6.1 ± 0.2 (.24 ± .008) 12.0 ± 0.3 (.472 ± .012) 1.5 ± 0.1 5.5 ± 0.5 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (.22 ± .002) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) - .000 4.0 MAX (.16 MAX) 0.6 MAX (.024 MAX) 8.0 ± 0.1 (.315 ± .004) 2225 6.9 ± 0.2 (.27 ± .008) 6.1 ± 0.2 (.24 ± .008) 12.0 ± 0.3 (.472 ± .012) 1.5 ± 0.1 5.5 ± 0.5 1.75 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 - 0.0 (.22 ± .002) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) - .000 4.0 MAX (.16 MAX) 0.6 MAX (.024 MAX) 8.0 ± 0.1 (.315 ± .004) Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 10
C0603X7R251-103KNP 价格&库存
很抱歉,暂时无法提供与“C0603X7R251-103KNP”相匹配的价格&库存,您可以联系我们找货
