RPC63206JTE
RPC63206JTE
    KAMAYA(釜屋电机)
    贴片电阻 2512 20MΩ ±5% 1W ±200ppm/℃
RPC63206JTE 数据手册
No.: Date: RPC−K−HTS−0002 2017. 4. 21 /8 Data sheet Title: Style: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 AEC-Q200 qualified RoHS COMPLIANCE ITEM Halogen and Antimony Free Note: ・Stock conditions Temperature: +5°C ∼ +35°C Relative humidity: 25% ∼ 75% The period of guarantee: Within 2 year from shipmen t by the company. Solderability shall be satisfied. ・Product specification contained in this data sheet are subject to change at any time without notice ・If you have any questions or a Purchasing Specification for any quality Agreement is necessary, please contact our sales staff. Hokkaido Research Center Approval by: T. Sannomiya Drawing by: M. Shibuya Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 1/12 1. Scope 1.1 This data sheet covers the detail requirements for fixed thick film chip resistors; rectangular type & anti surge, style of RPC16, 20, 32, 35, 50, 63. 1.2 Applicable documents JIS C 5201−1: 2011, JIS C 5201−8: 2014, JIS C 5201−8−1: 2014 IEC60115−1: 2008, IEC60115−8: 2014, IEC60115−8−1: 2014 EIAJ RC−2134C−2010 2. Classification Type designation shall be the following form. (Example) RPC 32 475 J TP 1 2 3 4 5 Style 1 Fixed thick film chip resistors; rectangular type and anti surge 2 Size 3 Rated resistance 475 E24 Series, 3 digit, Ex. 475--> 4.7MΩ, 4 Tolerance on rated resistance J ±5% K ±10% M ±20% 5 Packaging form B Bulk (loose package) TP Paper taping TE Embossed taping Style 3. Rating 3.1 The ratings shall be in accordance with Table−1. Table−1(2) Style Rated dissipation (W) RPC16 0.25 RPC20 0.25 RPC32 0.33 RPC35 0.5 RPC50 0.75 RPC63 1.0 Temperature coefficient of resistance ( 10−6 / °C) Rated resistance range(Ω) ±100 ±200 ±200 ±100 ±200 ±200 ±100 ±200 ±200 ±100 ±200 ±200 ±100 ±200 ±200 ±100 ±200 10∼1M 1.0∼9.1 1.1M∼22M 1.0∼1M 0.27∼0.91 1.1M∼22M 1.0∼1M 0.27∼0.91 1.1M∼22M 1.0∼1M 0.27∼0.91 1.1M∼22M 1.0∼1M 0.27∼0.91 1.1M∼22M 1.0∼1M 0.27∼0.91 Preferred number series for resistors Tolerance on rated resistance E24 J(±5%) E24 J(±5%), K(±10%), M(±20%) E24 J(±5%), K(±10%), M(±20%) E24 J(±5%), K(±10%), M(±20%) E24 J(±5%), K(±10%), M(±20%) E24 J(±5%), K(±10%), M(±20%) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 2/12 Title: Style RPC16 RPC20 RPC32 RPC35 RPC50 RPC63 Limiting element voltage (V) 150 150 Isolation voltage (V) 150 Table−1(2) Category temperature range (°C) −55∼+155 500 200 3.2 Climatic category 55/155/56 − 55 °C +155 °C 56days Lower category temperature Upper category temperature Duration of the damp heat, steady state test 3.3 Stability class 5% Limits for change of resistance: −for long−term tests ±(5%+0.1Ω) −for short−term tests ±(1%+0.05Ω) 3.4 Derating The derated values of dissipation at temperature in excess of 70 °C shall be as indicated by the following curve. 100 Percentage of the rated dissipation Area of recommended operation (%) 0 −55 70 155 Ambient temperature (°C) Figure−1 Derating curve 3.5 Rated voltage d. c. or a. c. r. m. s. voltage calculated from the square root of the product of the rated resistance and the rated dissipation. E : Rated voltage (V) E = P · R P : Rated dissipation (W) R : Rated resistance (Ω) Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical resistance value. At high value of resistance, the rated voltage may not be applicable. 4. Packaging form The standard packaging form shall be in accordance with Table−2. Table−2 Symbol B TP TE Packaging form Bulk (loose package) Paper taping 8mm width, 4mm pitches 8mm width, 4mm pitches Embossed taping 12mm width, 4mm pitches Standard packaging quantity / units 1,000 pcs. 5,000 pcs. 4,000 pcs. Application RPC16, 20, 32, 35, 50, 63 RPC16, 20, 32 RPC35 RPC50, 63 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 3/12 5. Dimensions 5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3. W L c d d H c Figure−2 Table−3 Style RPC16 RPC20 RPC32 RPC35 RPC50 RPC63 L 1.6±0.1 2.0 ± 0.1 3.1 ± 0.1 3.1 ± 0.15 5.0 ± 0.15 6.3 ± 0.15 W 0.8 +0.15 −0.05 1.25 ± 0.10 1.6 ± 0.15 2.5 ± 0.15 2.5 ± 0.15 3.2 ± 0.15 H 0.45±0.10 0.55 ± 0.10 0.55 ± 0.15 c 0.3±0.2 0.3 ± 0.2 0.3 ± 0.15 Unit: mm d 0.3±0.1 0.4 ± 0.2 0.5 ± 0.25 0.6 ± 0.2 5.2 Net weight (Reference) Style Net weight(mg) RPC16 2 RPC20 5 RPC32 9 RPC35 16 RPC50 25 RPC63 40 6. Marking The Rated resistance shall be marked in 3 digits (E24) and marked on over coat side. Marking example Contents Application 123 E24 12×10 3 [Ω] → 12 [kΩ] E24 2R2 2. 2 [Ω] Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 4/12 7. Performance 7.1 The standard condition for tests shall be in accordance with Sub−clause 4.2, JIS C 5201−1: 2011. 7.2 The performance shall be satisfied in Table−4. Table−4(1) Test items Performance requirements No. Condition of test (JIS C 5201−1) 1 Visual examination As in 4.4.1 Sub−clause 4.4.1 The marking shall be legible, as Checked by visual examination. checked by visual examination. 2 Dimension Sub−clause 4.4.2 As specified in Table−3 of this specification. Resistance As in 4.5.2 Sub−clause 4.5 The resistance value shall correspond with the rated resistance taking into account the specified tolerance. 3 Voltage proof Sub−clause 4.7 No breakdown or flash over Method: 4.6.1.4(See Figure−5) Test voltage: Alternating voltage with a peak value of 1.42 times the insulation voltage. Duration: 60 s ± 5 s R≥1GΩ Insulation resistance Test voltage: Insulation voltage Duration: 1 min. 4 Solderability As in 4.17.4.5 Sub−clause 4.17 The terminations shall be covered Without ageing Flux: The resistors shall be immersed in a with a smooth and bright solder coating. non−activated soldering flux for 2s. Bath temperature: 235 °C ± 5 °C Immersion time: 2 s ± 0.5 s 5 Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−3 Sub−clause 4.13 Overload The applied voltage shall be 2.5 times the rated (in the mounted state) voltage or twice the limiting element voltage, whichever is the less severe. Duration: 2 s No visible damage Visual examination ∆R ≤ ± (1%+0.05Ω) Resistance Solvent resistance of the Sub−clause 4.30 Legible marking marking Solvent: 2−propanol Solvent temperature: 23 °C ± 5 °C Method 1 Rubbing material: cotton wool Without recovery Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No 6 7 No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 5/12 Table−4(2) Condition of test (JIS C 5201−1) Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−4 Bound strength of the end Sub−clause 4.33 face plating Bent value: 3 mm (3225 size max.) 1 mm (5025 size min.) Resistance Final measurements Sub−clause 4.33.6 Visual examination Resistance to soldering heat Sub−clause 4.18 Solder temperature: 260 °C ± 5 °C Immersion time: 10 s ± 0.5 s Visual examination Test items Resistance solvent Sub−clause 4.29 Solvent: 2−propanol Solvent temperature: 23 °C ± 5 °C Method 2 Recovery: 48 h Visual examination Resistance Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−3 Adhesion Sub−clause 4.32 Force: 5 N Duration: 10 s ± 1 s Visual examination Rapid change temperature Sub−clause 4.19 Lower category temperature:−55 °C Upper category temperature:+155 °C Duration of exposure at each temperature: 30 min. Number of cycles: 5 cycles. Visual examination Resistance Performance requirements ∆R ≤ ± (1%+0.05Ω) No visible damage As in 4.18.3.4 No sign of damage such as cracks. ∆R ≤ ± (1%+0.05Ω) Component resistance 8 No visible damage ∆R ≤ ± (1%+0.05Ω) No visible damage No visible damage ∆R ≤ ±(1%+0.05Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No 9 No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 6/12 Test items Climatic sequence −Dry heat −Damp heat, cycle (12+12hour cycle) First cycle −Cold −Damp heat, cycle (12+12hour cycle) Remaining cycle −D.C. load 10 Mounting Endurance at 70 °C Table−4(3) Condition of test (JIS C 5201−1) Sub−clause 4.23 Sub−clause 4.23.2 Test temperature: +155 °C Duration: 16 h Sub−clause 4.23.3 Test method: 2 Test temperature: 55 °C [Severity(2)] Sub−clause 4.23.4 Test temperature −55 °C Duration: 2h Sub−clause 4.23.6 Test method: 2 Test temperature: 55 °C [Severity (2)] Number of cycles: 5 cycles Sub−clause 4.23.7 The applied voltage shall be the rated voltage or the limiting element voltage whichever is the smaller. Duration: 1 min. Visual examination Resistance Sub−clause 4.31 Substrate material: Epoxide woven glass (RPC63 may use Alumina substrate.) Test substrate: Figure−3 Sub−clause 4.25.1 Ambient temperature: 70 °C ± 2 °C Duration: 1000 h The voltage shall be applied in cycles of 1.5 h on and 0.5 h. The applied voltage shall be the rated voltage or the limiting element voltage whichever is the smaller. Examination at 48 h , 500 h and 1000 h: Visual examination Resistance Performance requirements No visible damage ∆R ≤ ± (5%+0.1Ω) No visible damage ∆R ≤ ± (5%+0.1Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No 11 12 13 No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 7/12 Table−4(4) Performance requirements Condition of test (JIS C 5201−1) Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−3 Variation of resistance with Sub−clause 4.8 As in Table−1 temperature −55 °C / +20 °C +20 °C / +155°C Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−3 Damp heat, steady state Sub−clause 4.24 Ambient temperature: 40 °C ± 2 °C Relative humidity : 93 +2 −3 % a) 1st group: without voltage applied. b) 2nd group: The d. c. voltage shall be applied continuously. The voltage shall be accordance with Sub−clause 4.24.2.1 b). without polarizing voltage [4.24.2.1, c)] No visible damage Visual examination Legible marking ∆R ≤ ± (5%+0.1Ω) Resistance Test items Dimensions (detail) Sub−clause 4.4.3 As in Table−3 Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Test substrate: Figure−3 Endurance at upper category Sub−clause 4.25.3 temperature Ambient temperature:155 °C ± 2 °C Duration: 1000 h Examination at 48 h, 500 h and 1000 h: Visual examination Resistance No visible damage ∆R ≤ ± (5%+0.1Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 8/12 Title: 8. Test substrate c Unit: mm :Copper clad b 40 a :Solder resist d Style RPC50 RPC63 a 4.0 5.0 b 7.5 9.0 c 2.0 4.5 d 7.5 7.5 c 1.5 2.9 d 4.3 3.3 10.16 60.96 RPC50, 63 TEST SUBSTRATE c Soldering land :Copper clad a :Solder resist 5.5 b 25 d 3.5 3 Unit: mm 7.5 Style RPC20 RPC35 5.08 5.08 2.5 a 1.2 2.2 b 4.0 5.0 3 58.5 RPC20, 35 TEST SUBSTRATE Soldering land Unit: mm :Copper clad :Solder resist 2.5 7.5 5 30 5 4 3.5 2 2.5 2.5 8 1.5 1.5 2 2 2 4 2.5 49 RPC32 TEST SUBSTRATE Figure−3(1) Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.035mm 2). In the case of connection by connector, the connecting terminals are gold plated. However, the plating is not necessary when the connection is made by soldering. Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 9/12 c e :Solder resist 6 e b 27.6 6 :Copper clad d a b Unit: mm 9 1.6 72 Style RPC16 a 0.6 b 0.8 c 0.9 d 2.2 e 6.2 RPC16 TEST SUBSTRATE Figure−3(2) Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.07mm 2). In the case of connection by connector, the connecting terminals are gold plated. However, the plating is not necessary when the connection is made by soldering. Unit: mm c 1 a 40 :Copper clad :Solder resist Style RPC50 RPC63 b 100 a 4.0 5.0 b 7.5 9.0 c 3.0 4.0 RPC50, 63 BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE Unit: mm d 1 :Copper clad 4.5 40 d c a b 70 100 Soldering land :Solder resist Style RPC16 RPC20 RPC32 RPC35 a 1.0 1.2 2.5 2.2 b 3.6 4.0 5.0 5.0 c 1.2 1.65 2.0 2.9 d 3.0 3.0 2.5 2.5 Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.035mm RPC16,20,32,35 BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE Figure−4 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 10/12 Insulation plate Metal block measurement Point A Metal plate R0.5mm Measurement point B Insulation surface Component Pressure by spring (1±0.2N) Figure−5 9. Taping 9.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010 9.2 Taping dimensions 9.2.1 Paper taping (8mm width, 4mm pitches) Taping dimensions shall be in accordance with Figure−6 and Table−5. Unit: mm 4±0.1 t 1 φ1.5 Sprocket hole +0.1 0 2±0.05 1.75±0.1 B 8±0.2 A t 2 Carrier cavity 4±0.1 3.5±0.05 Direction of unreeling Style RPC16 RPC20 RPC32 Figure−6 Table−5 A B 1.15 ± 0.15 1.9 ± 0.2 1.65±0.15 2.5±0.2 2.00±0.15 3.6±0.2 t1 0.6 ± 0.1 Unit: mm t2 0.8max. 0.8±0.1 1.0max. Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 11/12 9.2.2 Embossed taping dimensions shall be in accordance with Figure−7 and Table−6. Unit: mm 0.3 max. 2±0.05 Sprocket hole φ1.5+0.1 0 1.75±0.1 4±0.1 Carrier cavity t1 W B E A Direction of unreeling 4±0.1 Figure−7 Table−6 Style RPC35 RPC50 RPC63 A 2.85±0.2 3.1±0.2 3.6±0.2 B 3.5±0.2 5.5±0.2 6.9±0.2 W 8.0±0.3 E 3.5±0.05 Unit: mm t1 1.0±0.2 12.0±0.3 5.5±0.05 1.1±0.15 1). The cover tapes shall not cover the sprocket holes. 2). Tapes in adjacent layers shall not stick together in the packing. 3). Components shall not stick to the carrier tape or to the cover tape. 4). Pitch tolerance over any 10 pitches ±0.2mm. 5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the following RPC16, 20, 32: Figure−8, RPC35, 50, 63: Figure−9. 6). When the tape is bent with the minimum radius for RPC16, 20, 32, 35: 25 mm, or RPC50, 63: 30 mm, the tape shall not be damaged and the components shall maintain their position and orientation in the tape. 7). In no case shall there be two or more consecutive components missing. The maximum number of missing components shall be one or 0.1%, whichever is greater. 8). The resistors shall be faced to upward at the over coating side in the carrier cavity. Top cover tape Carrier tape 165°to180° Peel−off ( About 300mm/ min) Direction of unreeling Figure−8 Top cover tape Carrier tape 165°to180° Peel−off ( About 300mm/ min) Direction of unreeling Figure−9 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 Title: No: RPC−K−HTS−0002 /8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND ANTI SURGE RPC16, 20, 32, 35, 50, 63 Page: 12/12 9.3 Reel dimension Reel dimensions shall be in accordance with the following Figure−10 and Table−7. Plastic reel (Based on EIAJ ET−7200C) Unit: mm 0     +1 φ60      0 φ13±0.2 2±0.5 φ180 −1.5 Marking A φ21±0.8 Marking B A B Figure−10 Table−7 Unit: mm A B Note Style Injection molding 11.4±1.0 RPC16,20,32,35 9 +1.0 0 13±1.0 Vacuum forming RPC50,63 17±1.0 Vacuum forming 13 +1.0 0 Note: Marking label shall be marked on a place of Marking A or two place of Marking A and B. 9.4 Leader and trailer tape. 400mm min. 100mm min. 160mm min. End Start Trailer Leader Direction of unreeling Figure−11 10. Marking on package The label of a minimum package shall be legibly marked with follows. 10.1 Marking A (1) Classification (Style, Rated resistance, Tolerance on rated resistance, Packaging form) (2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark (5) Others 10.2 Marking B (KAMAYA Control label) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21
RPC63206JTE 价格&库存
很抱歉,暂时无法提供与“RPC63206JTE”相匹配的价格&库存,您可以联系我们找货
