100B241JT200XT
100B241JT200XT
    ATC
    贴片电容(MLCC) 1111 P90 240pF ±5% 200V
100B241JT200XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors FEATURES • • • • • • • • • GENERAL DESCRIPTION KYOCERA AVX, the industry leader, offers new improved ESR/ESL performance for the 100 B Series RF/Microwave Capacitors. This Series is now available with extended operating temperatures up to 175°C. High Density porcelain construction provides a rugged, hermetic package. Case B Size (.110" x .110") Capacitance Range 0.1pF to 1000pF Extended WVDC up to 1500 VDC Low ESR/ESL High Q Low Noise Ultra-Stable Performance High Self-Resonance Established Reliability (QPL) PACKAGING OPTIONS Tape & Reel FUNCTIONAL APPLICATIONS • Bypass • Coupling • Tuning • Impedance Matching • DC Blocking Cap Pac® (100 pcs) ELECTRICAL SPECIFICATIONS CIRCUIT APPLICATIONS • UHF/Microwave RF Power Amplifiers • Oscillators Vertical Orientation Tape & Reel • Low Noise Amplifiers • Filter Networks • Timing Circuits ENVIRONMENTAL CHARACTERISTICS Thermal Shock Mil-STD-202, Method 107, Condition A Moisture Resistance Mil-STD-202, Method 106 Low Voltage Humidity Mil-STD-202, Method 103, condition A, with 1.5 VDC applied while subjected to an environment of 85ºC with 85% relative humidity for 240 hours Life Test MIL-STD-202, Method 108, for 2000 hours, at 125°C. Voltage applied. 200% of WVDC for capacitors rated at 500 volts DC or less. 120% of WVDC for capacitors rated at 1250 volts DC or less. 100% of WVDC for capacitors rated above 1250 volts DC Termination Styles Available in various surface mount and leaded styles. See Mechanical Configurations Terminal Strength Terminations for chips and pellets withstand a pull of 5 lbs. min., 15 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Temperature Coefficient (TCC) +90 ±20 PPM/°C (-55°C to +125°C) +90 ±30 PPM/°C (+125°C to +175°C) Capacitance Range 0.1pF to 1000pF Operating Temperature -55ºC to +125ºC* Quality Factor greater than 10,000 at 1 MHz Insulation Resistance (IR) 0.1 pF to 470 pF: 106 Megohms min. @ +25°C at rated WVDC. 105 Megohms min. @ +125°C at rated WVDC. 510 pF to 1000 pF: 105 Megohms min. @ +25°C at rated WVDC. 104 Megohms min. @ +125°C at rated WVDC. Working Voltage (WVDC) See Capacitance Values table Dielectric Withstanding Voltage (DWV) 250% of WVDC for capacitors rated at 500 volts DC or less for 5 seconds. 150% of WVDC for capacitors rated at 1250 volts DC or less for 5 seconds. 120% of WVDC for capacitors rated above 1250 Volts DC for 5 seconds Aging Effects None Piezoelectric Effects None Capacitance Drift ± (0.02% or 0.02 pF), whichever is greater Retrace Less than ±(0.02% or 0.02 pF), whichever is greater. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032421 – rf microwave products – 455 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors CAPACITANCE VALUES Rated Rated Cap. Cap. Cap. Cap. WVDC WVDC Tol. Code (pF) Code (pF) STD. EXT. STD. EXT. 0.1 2R4 2.4 200 20 B 0.2 2R7 2.7 220 22 0.3 3R0 3.0 240 24 B, C 0.4 3R3 3.3 270 27 0.5 3R6 3.6 300 30 B, C, 0.6 3R9 3.9 330 33 D 0.7 4R3 4.3 360 36 0.8 4R7 4.7 390 39 0.9 5R1 5.1 430 43 1.0 5R6 5.6 470 47 1.31 6R2 6.2 510 51 500 1500 500 1500 560 56 1.2 6R8 6.8 B, C, 7R5 7.5 620 62 1.3 B, C, J, K, D 1.4 8R2 8.2 680 68 M 1.5 9R1 9.1 750 75 820 82 1.6 100 10 1.7 110 11 910 91 1.8 120 12 101 100 F, G, J, 1.9 130 13 111 110 K, M 2.0 150 15 121 120 2.1 160 16 131 130 2.2 180 18 Rated WVDC CAP. STD. EXT. VOLTAGE EXTENDED VOLTAGE Tol. 500 1500 EXTENDED F, G, J, K, M EXTENDED VOLTAGE EXTENDED VOLTAGE 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 EXTENDED VOLTAGE Cap. Cap. Tol. Code (pF) 300 1000 CODE CAP. (pF) 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 1000 TOL. RATED WVDC STD. EXT. EXT. 300 1000 VOLT. EXT. 200 F, G, J, K, M 600 VOLT. EXT. 100 300 50 VOLT VRMS = 0.707 X WVDC • SPECIAL VALUES, TOLERANCES, DIFFERENT WVDC AND MATCHING AVAILABLE. • ENCAPSULATION OPTION AVAILABLE. PLEASE CONSULT FACTORY.NOTE: EXTENDED WVDC DOES NOT APPLY TO CDR PRODUCTS. HOW TO ORDER 100 B 910 J W 500 X T Series Packaging Case Size T = Tape and Reel, 500 pc qty TV = Vertical Tape and Reel, 500 pc qty See mechanical dimensions below Please see last column of mechanical configuration table for other options. Capacitance Laser Marking (Optional) EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Voltage Rating Termination Style Code Capacitance Tolerance Code Code Tol. B C D F G J K M ±.1 pF ±.25 pF ±.5 pF ±1% ±2% ±5% ±10% ±20% Please see 2nd Column Mechanical Configuration Table The above part number refers to a 100 B Series (case size B) 91 pF capacitor, J tolerance (±5%), 500 WVDC, with W termination (Tin /Lead, Solder Plated over Nickel Barrier), laser marking and Tape and Reel packaging. 456 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070721 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors MECHANICAL CONFIGURATION Series Term. MIL-PRF& Case Code 55681 Size Case Size & Type B 100B W Y CDR14BG W Solder Plate P Y CDR14BG W Pellet T N/A Y Solderable Nickel CA T L Y CDR13BG T L B 100B MS WL WL T1K or T TV1K or TV C100 RoHS Compliant Gold Plated over Nickel Barrier Termination T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T1K or T TV1K or TV C100 Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 .015 (0.38) ±.010 (0.25) Length (LL ) .250 (6.35) min. .110 ±.015 (2.79 ±0.38) WL L T Width (WL ) Thickness (TL ) .093±.005 .004 ± .001 (2.36 ±0.13) (.102±.025) N/A .102 (2.59) max. LL CDR23BG T L W B AW T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs LL W Radial Wire 100B RoHS Compliant Tin Plated over Nickel Barrier Termination .102 (2.59) max. .135 ±.015 (3.43 ±0.38) T L B RW T1K or T TV1K or TV C100 .120 (3.05) max. W CDR24BG Radial Ribbon 100B T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs TL B RR Heavy Tin/Lead Coated, over Nickel Barrier Termination T LL CDR22BG Axial Ribbon 100B .110+ .035 - .01 .110 ±.015 (2.79 + 0.89-0.25) (2.79 ±0.38) W L B AR T1K or T TV1K or TV C100 TL Microstrip 100B .145 ±.020 (3.68 ±0.51) .500 (12.7) LL CDR25BG W Axial Wire Pkg Code T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs LL CDR21BG Pkg Type Tin / Lead, Solder Plated over Nickel Barrier Termination .110+.020 - .010 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) W Gold Chip Lead and Termination Dimensions and Material Overlap Materials (Y) .110+ .020 - .01 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) .110+ .035 - .01 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) W B 100B T L B 100B T L B 100B Body Dimensions inches (mm) Length Width Thickness (L) (W) (T) Outline W/T is a Termination Surface L #26 AWG., .016 (.406) dia. nominal • T Additional lead styles available: Narrow Microstrip (NM), Narrow Axial Ribbon (NA) and Vertical Narrow Microstrip (H). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 072121 – rf microwave products – 457 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors NON-MAGNETIC MECHANICAL CONFIGURATION Series Term. & Case Code Size 100B WN MIL-PRF55681 Meets Requirements Case Size & Type Outline W/T is a Termination Surface B Y B 100B 100B PN TN Meets Requirements Meets Requirements T L Y .110+ .035 - .01 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) W Solderable Nickel T L B Y T L B 100B MN Meets Requirements TL W Microstrip B 100B AN 100B FN RN Meets Requirements WL BN Heavy Tin / Lead, Coated over Non-Magnetic Barrier Termination RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination Length (LL ) Width (WL ) Thickness (TL ) Meets Requirements .110 ±.015 (2.79 ±0.38) WL L T LL L W N/A .102 (2.59) max. .145 ±.020 (3.68 ±0.51) LL W Axial Wire T1K or T TV1K or TV C100 T1K or T TV1K or TV C100 Cap Pac, 20 pcs C20 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 Box, 20 or 100 pcs B20 or B100 L .500 (12.7) Box, 20 or 100 pcs B20 or B100 #26 AWG., .016 (.406) dia. nominal • T Additional lead styles available: Narrow Microstrip (NM), Narrow Axial Ribbon (NA) and Vertical Narrow Microstrip (H). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. 458 T1K or T TV1K or TV C100 .250 (6.35) .093±.005 .004 ± .001 (6.35) min. (2.36 ±0.13) (.102±.025) T Radial Wire B 100B T LL Meets Requirements .015 (0.38) ±.010 (0.25) .135 ±.015 (3.43 ±0.38) W L W Radial Ribbon B .102 (2.59) max. T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac,100 pcs T&R, 1000 or 500 pcs Vertical T&R, 1000 or 500 pcs Cap Pac, 100 pcs Pkg Code TL LL Meets Requirements Axial Ribbon B 100B T L Pkg Type Materials Tin / Lead, Solder Plated over Nickel Barrier Termination .120 (3.05) max. LL WL Overlap (Y) .110+.020 - .010 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) W Gold Chip Lead and Termination Dimensions and Material .110+ .020 - .01 .110 ±.015 (2.79 + 0.51-0.25) (2.79 ±0.38) W Non-Mag Body Dimensions inches (mm) Length Width Thickness (L) (W) (T) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors SUGGESTED MOUNTING PAD DIMENSIONS W L T L Case B Vertical Mount Cap Value W 39 391k 1k T Horizontal Electrode Orientation A Normal High Density Normal 0.2 pF High Density 0.3 to Normal 510 pF High Density Normal > 510 pF High Density 0.1 pF Vertical Electrode Orientation B Pad Size B A Min. B Min. C Min. D Min. .065 .045 .090 .070 .110 .090 .120 .100 .050 .030 .050 .030 .050 .030 .050 .030 .075 .075 .075 .075 .075 .075 .075 .075 .175 .135 .175 .135 .175 .135 .175 .135 .075 .075 .175 .135 Case B Vertical Mount C Normal All Values High Density D .130 .110 .050 .030 PERFORMANCE DATA ESR VS. CAPACITANCE SERIES 100, CASE B Q VS. CAPACITANCE SERIES 100, CASE B 1 100000 10000 150 MHz 0.1 Q Q 1000 MHz 1000 500 MHz 500 MHz 1000 MHz 100 150 MHz 0.01 (Typical) 1 10 100 10 (Typical) 1 100 10 CAPACITANCE (pF) (1.0 pF to 51 pF) CAPACITANCE (pF) (1.0 pF to 51 pF) ESR VS. CAPACITANCE SERIES 100, CASE B Q VS. CAPACITANCE SERIES 100, CASE B 1 10000 ESR (Ohms) 150 MHz 0.1 100 1000 MHz 500 MHz 500 MHz 150 MHz 0.01 1000 MHz (Typical) (Typical) 1 10 CAPACITANCE (pF) (56 pF to 1000 pF) 10 100 1 10 CAPACITANCE (pF) (56 pF to 1000 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 020321 – rf microwave products – 100 459 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors PERFORMANCE DATA SERIES RESONANCE VS. CAPACITANCE SERIES 100, CASE B CAPACITANCE CHANGE VS. TEMPERATURE SERIES 100, CASE B 100 2 FREQUENCY (GHz) FREQUENCY (GHz) 1.5 10 1000 MHz 500 MHz 1 150 MHz 0.1 (Typical) (Typical) 0.1 1 10 100 0 -0.5 10 25 45 65 85 105 125 145 1000 MHz 500 MHz 150 MHz 30 MHz Dotted Line = Power dissipation limited Solid Line = Voltage limited (Vrms) 1 10 10 150 MHz 500 MHz 1000 MHz 30 MHz 1 10 1000 165 The current rating is based on a 65°C mounting surface and a device thermal resistance (ϴ) of 20°C/W. A power dissipation of 3W will result in a case temperature of 125°C CAPACITANCE (pF) (0.1 pF to 51 pF) 460 5 CURRENT RATING VS. CAPACITANCE SERIES 100, CASE B 100 0.1 -15 CURRENT RATING VS. CAPACITANCE SERIES 100, CASE B The current rating is based on a 65°C mounting surface and a device thermal resistance (ϴ) of 20°C/W. A power dissipation of 3W will result in a case temperature of 125°C 1 -35 TEMPERATURE (°C) FREQUENCY (GHz) RMS CURRENT (Amps) 0.5 CAPACITANCE (pF) 100 0.1 1 -1 -55 1000 TC = +90 ± 20 PPM/°C (-55°C to +125°C) TC = +90 ± 30 PPM/°C (+125°C to +175°C) Dotted Line = Power dissipation limited Solid Line = Voltage limited (Vrms) 100 CAPACITANCE (pF) (56 pF to 1000 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 020321 – rf microwave products – 1000 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100B Series Porcelain Superchip® Multilayer Capacitors PERFORMANCE DATA CURRENT RATING VS. CAPACITANCE SERIES 100, CASE B 100 The current rating is based on a 65°C mounting surface and a device thermal resistance (ϴ) of 20°C/W. A power dissipation of 3W will result in a case temperature of 125°C RMS CURRENT (Amps) 10 1000 MHz 500 MHz 1 150 MHz 30 MHz 0.1 Dotted Line = Power dissipation limited Solid Line = Voltage limited (Vrms) 0.01 0.1 1 10 100 1000 CAPACITANCE (pF) (56 pF to 200 pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 020321 – rf microwave products – 461
100B241JT200XT 价格&库存
很抱歉,暂时无法提供与“100B241JT200XT”相匹配的价格&库存,您可以联系我们找货
