HGCB0603FTC180M
HGCB0603FTC180M
    SEI
    贴片电阻 0603 180MΩ ±1% 60mW ±50ppm/℃
HGCB0603FTC180M 数据手册
HGC Series Stackpole Electronics, Inc. Thick Film Precision High Resistance Chip Resistor Resistive Product Solutions Features: • • • • • • • Ultra-high stability Very low noise Tolerances to 0.1% TCR down to 25 ppm/ºC 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) 0402 0.04 50 0603 0.06 100 0805 0.2 125 1206 0.33 2010 1 2512 2 3512 3 200 300 350 600 Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) 0.1% ± 50 ± 100 ± 200 ± 50 ± 100 ± 200 ± 50 ± 100 ± 200 ± 25 ± 50 ± 100 ± 200 ± 25 ± 50 ± 100 ± 200 ± 25 ± 50 ± 100 ± 200 ± 25 ± 50 ± 100 ± 200 0.25% 0.5% - - 10K - 10M - 10K - 10M 1M - 10M 100K - 10M 100K - 100M 10K - 10M 10K - 100M 1M - 10M 100K - 10M 100K - 100M 10K - 10M 10K - 100M 1M - 100M 100K - 100M 100K - 500M 10K - 100M 10K - 500M 1M - 100M 100K - 100M 100K - 500M 10K - 100M 10K - 500M 10K - 500M 10K - 500M 10K - 1G 10K - 1G 1% 2% 5% 10% 20% 10K - 100M 10K - 500M 10K - 500M 10K - 1G 10K - 100M 10K - 500M 10K - 1G 10K - 500M 10K - 1G 10K - 10G 10K - 50G 10K - 500M 10K - 1G 10K - 1G 10K - 10G 10K - 50G 1M - 100M 100K - 500M 10K - 1G 10K - 1G 10K - 10G 10K - 50G 1M - 100M 100K - 500M 10K - 1G 10K - 1G 10K - 10G 10K - 50G 1M - 500M 100K - 1G 100K - 10G 10K - 10G 100K - 50G 1M - 500M 100K - 1G 100K - 10G 10K - 10G 100K - 50G Mechanical Specifications Type / Code L Body Length W Body Width H Body Height (Max.) a Top Termination b Bottom Termination Unit 0402 0.040 ± 0.005 1.02 ± 0.13 0.020 ± 0.003 0.51 ± 0.08 0.020 0.51 0.008 ± 0.004 0.20 ± 0.10 0.010 ± 0.004 0.25 ± 0.10 inches mm 0603 0.063 ± 0.010 1.60 ± 0.25 0.031 ± 0.005 0.79 ± 0.13 0.020 0.51 0.010 ± 0.005 0.25 ± 0.13 0.012 ± 0.008 0.30 ± 0.20 inches mm 0805 0.079 ± 0.010 2.01 ± 0.25 0.050 ± 0.005 1.27 ± 0.13 0.025 0.64 0.010 ± 0.005 0.25 ± 0.13 0.013 ± 0.008 0.33 ± 0.20 inches mm 1206 0.126 ± 0.010 3.20 ± 0.25 0.063 ± 0.005 1.60 ± 0.13 0.030 0.76 0.010 ± 0.005 0.25 ± 0.13 0.020 ± 0.010 0.51 ± 0.25 inches mm Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com HGC Series Stackpole Electronics, Inc. Thick Film Precision High Resistance Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type / Code 2010 2512 3512 L Body Length 0.200 ± 0.010 5.08 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.350 ± 0.010 8.89 ± 0.25 W Body Width 0.100 ± 0.005 2.54 ± 0.13 0.125 ± 0.005 3.18 ± 0.13 0.125 ± 0.005 3.18 ± 0.13 H Body Height (Max.) 0.030 0.76 0.030 0.76 0.030 0.76 a Top Termination 0.018 ± 0.010 0.46 ± 0.25 0.020 ± 0.010 0.51 ± 0.25 0.020 ± 0.010 0.51 ± 0.25 b Bottom Termination 0.020 ± 0.010 0.51 ± 0.25 0.024 ± 0.010 0.61 ± 0.25 0.024 ± 0.010 0.61 ± 0.25 Unit inches mm inches mm inches mm Performance Characteristics Test Short Time Overload Load Life Temperature Cycle Moisture Resistance Shock Vibration Dielectric Withstanding Voltage Resistance to Soldering Heat Operating temperature range is -55ºC to +150ºC Typical Delta R 0.1% 0.1% 0.1% 0.1% 0.05% 0.05% 0.05% 0.05% Power Derating Curve: Percent Rated Power (%) 100 -55ºC 75ºC 80 60 40 20 0 -60 150ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com HGC Series Stackpole Electronics, Inc. Thick Film Precision High Resistance Chip Resistor Resistive Product Solutions Wave Soldering Description Maximum Recommended Minimum Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Thick Film Precision High Resistance Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. HGC Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) SMD YES(1) 100% Matte Sn over Ni Always Always Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HGC Series Stackpole Electronics, Inc. Thick Film Precision High Resistance Chip Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 H G C B 1 2 0 6 F K C 2 M 0 0 Product Series HGC Code B Description Solderable wraparound (100% matte tin) Power Size 0402 0603 0805 1206 2010 2512 3512 Rating W 0.04 0.06 0.2 0.33 1 2 3 Tolerance Code Tol B 0.1% C 0.25% D 0.5% F 1% G 2% J 5% K 10% M 20% Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Code T K D B Packaging Description Size Quantity 7" Reel - Paper Tape 0402, 0603, 0805 5000 1206, 2010 4000 7" Reel - Plastic Tape 2512 2000 7" Reel - Paper Tape 0603, 0805, 1206 1000 7" Reel - Plastic Tape 2010, 2512, 3512 7" Reel - Paper Tape 0603, 0805, 1206 500 7" Reel - Plastic Tape 2010, 2512, 3512 Bulk All Sizes 1000 4 TCR Code ppm E 25 C 50 D 100 L 200 Resistance Value Four characters with the multiplier used as the decimal holder. 10 Kohm = 10K0 1 Mohm = 1M00 10 Gohm = 10G0 www.seielect.com marketing@seielect.com
HGCB0603FTC180M 价格&库存
很抱歉,暂时无法提供与“HGCB0603FTC180M”相匹配的价格&库存,您可以联系我们找货
HGCB0603FTC180M
  • 1+34.144161+4.41707
  • 10+24.9410610+3.22651
  • 25+22.8370425+2.95432
  • 50+21.6224350+2.79719
  • 100+20.65465100+2.67200
  • 250+19.67196250+2.54487
  • 500+19.10198500+2.47114
  • 1000+18.648301000+2.41245
库存:8351
HGCB0603FTC180M
    HGCB0603FTC180M
    • 5000+17.919165000+2.31812
    库存:8351
    HGCB0603FTC180M
