CSSK Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Kelvin Termination Metal Alloy Current Sensing Resistor
Features:
Metal element current sensing resistor
Power rating to 3W
Operation temperature range is -55ºC ~ +170ºC
Tolerance available in ± 0.5% to ± 5%
Insulation resistance over 100M Ω
Maximum working voltage (V) is (P*R)1/2
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Power Rating (W)
@ 70ºC
Type/Code
CSSK0612
1
CSSK3637
3
Ohmic Range (Ω) and Tolerance
TCR (ppm/ºC)
0.5%
± 200
± 150
± 50
1%, 2%, 5%
0.0005 - 0.003
0.0031 - 0.005
0.0005 - 0.003
0.001 - 0.003
Mechanical Specifications
Type/Code
CSSK0612
CSSK3637
L
0.065
1.65
0.360
9.14
W
0.008
0.20
0.010
0.25
0.120
3.05
0.378
9.60
H
0.010
0.25
0.010
0.25
0.026
0.65
0.029
0.73
T
0.008
0.20
0.010
0.25
0.016
0.40
0.091
2.30
A
0.010
0.25
0.010
0.25
0.020
0.51
0.059
1.50
B
0.005
0.13
0.010
0.25
0.020
0.51
0.047
1.20
Unit
0.005
0.13
0.010
0.25
inches
mm
inches
mm
Performance Characteristics
Test
Temperature Coefficient of
Resistance
Load Life
Short Time Overload
Moisture no Load
Test Method
Test Specification
CSSK0612
CSSK3637
IEC60115-1-4.8
As per specification
JIS-C5201-4.8
IEC60115-1-4.25.1
∆ R/R1 ≤ ±(2% + 0.0005 Ω)
∆ R/R1 ≤ ±(1% + 0.0005 Ω)
JIS-C5201-4.25.1
IEC60115-1-4.13
∆ R/R1 ≤ ±(0.5% + 0.0005 Ω)
JIS-C5201-4.13
IEC60115-1-4.24.2.1a
JIS-C5201-4.24.2.1a
Biased Humidity
MIL-STD-202
Method 103
CSSK0612
Temperature Cycle
IEC60115-1-4.19
JIS-C5201-4.19
CSSK3637
Temperature Cycle
JESD22
Method JA-104
Resistance to Soldering Heat
IEC60115-1-4.18
JIS-C5201-4.18
< ± 1%
Rev Date: 5/7/2021
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
Test Condition
+25ºC ~ +125ºC
1000 hours at rated power, 70ºC,
1.5 hours "ON", 0.5 hour "OFF".
5 X rated power for 5 seconds
85ºC, 85% RH, 1000 hours
1000 hours; 85ºC/85% R.H., 10%
of operating power. Measurement
at 24 ± 4 hours after test
conclusion.
-55ºC and +155ºC, 300 cycle,
15 minutes per extreme condition.
1000 cycles (-55ºC to + 155ºC).
Measurement at 24 ± 4 hours after
test conclusion. 30 minutes
maximum dwell time at each
temperature extreme.
260ºC ± 5ºC for 10 ± 1 seconds
2 cycles
www.seielect.com
marketing@seielect.com
CSSK Series
Performance Characteristics (cont.)
Test
Solderability
High Temperature Exposure
Low Temperature Storage
Test Method
IEC60115-1-4.17
JIS-C5201-4.17
IEC60115-1-4.23.2
JIS-C5201-4.23.2
IEC60115-1-4.23.4
JIS-C5201-4.23.4
Test Specification
CSSK0612
CSSK3637
At least 95% of surface area of electrode shall be covered with
new solder.
170ºC, 1000 hours
< ± 0.5%
-55ºC, 1000 hours
JIS-C5201-1 4.7
No breakage.
Core Body Strength
JIS-C5201-1 4.15
Terminal Strength
AEC-Q200-006
Moisture Resistance
MIL-STD 202
Method 106
IEC60115-1-4.33
JIS-5201-4.33
IEC60115-1-4.6
Insulation Resistance
JIS-5201-4.6
Operating temperature range is -55ºC to +170ºC
Storage temperature: 25ºC ± 5ºC, Humidity: 60% ± 20%
Percent Rated Power (%)
Applied 500VAC for 1 minute.
Central part pressurizing force: 5N,
10 seconds
Pressurizing force 17.7N for 60
seconds
T=24 hours / cycle, 10 cycles.
Steps 7a & 7b not required.
Unpowered.
Substrate Bending
100
245ºC ± 5ºC, 2 ± 0.5 seconds
Dielectric Withstanding
Voltage
Power Derating Curve:
Test Condition
> 100M Ω
-55ºC
Bending once 2mm for 10 seconds
100VDC for 1 minute
70ºC
80
60
40
170ºC
60
80
100
120
140
160
180
Ambient Temperature (ºC)
Recommended Pad Layouts
Type/Code
A
B
0.091
0.039
CSSK0612
2.30
1.00
0.312
0.130
CSSK3637
7.92
3.30
Note: 1W with total solder pad and trace size of 300 mm2
Rev Date: 5/7/2021
2
C
L
F
Unit
0.031
0.80
0.078
1.98
0.028
0.70
0.157
4.00
0.016
0.40
0.024
0.60
inches
mm
inches
mm
www.seielect.com
CSSK Series
Recommended IR – Reflow Profile
(solder: Sn96.5 / Ag3 / Cu0.5)
Peak: 260ºC ± 5°C, 10 ± 1 seconds
Pre-heat Zone: 150ºC to 180°C, 90 ± 30 seconds
Soldering Zone: 230°C or higher, 30 ± 10 seconds
Iron Solder: 350ºC ± 10°C, 3 ± 1 seconds
Reel Specifications
Type/Code
Reel Type
ΦA
CSSK0612
Paper Tape
CSSK3637
Embossed Plastic
7.008 ±
178.00 ±
7.008 ±
178.00 ±
ΦB
0.079
2.00
0.079
2.00
2.362 ±
60.00 ±
2.362 ±
60.00 ±
ΦC
0.039
1.00
0.039
1.00
0.512 ±
13.00 ±
0.531 ±
13.50 ±
T
0.039
1.00
0.020
0.50
0.453 ±
11.50 ±
0.685 ±
17.40 ±
Unit
0.039
1.00
0.039
1.00
inches
mm
inches
mm
Taping Specifications – CSSK0612 (Paper)
Type/Code
W
P
E
F
P2
D
Unit
0.315 ± 0.004
8.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.138 ± 0.002
3.50 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.059 ± 0.004
1.50 ± 0.10
inches
mm
CSSK0612
D1
P0
A0
B0
K0
t
Unit
0.039 ± 0.004
1.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.070 ± 0.004
1.77 ± 0.10
0.134 ± 0.004
3.40 ± 0.10
0.041 ± 0.004
1.04 ± 0.10
0.009 ± 0.002
0.22 ± 0.05
inches
mm
Rev Date: 5/7/2021
3
www.seielect.com
CSSK Series
Taping Specifications – CSSK3637 (Embossed)
Type/Code
CSSK3637
W
0.630 ± 0.008
16.00 ± 0.20
G
0.157 ± 0.004
4.00 ± 0.10
P
0.472 ± 0.004
12.00 ± 0.10
H
0.079 ± 0.004
2.00 ± 0.10
E
0.069 ± 0.004
1.75 ± 0.10
A
0.378 ± 0.004
9.60 ± 0.10
F
0.295 ± 0.004
7.50 ± 0.10
B
0.394 ± 0.004
10.00 ± 0.10
D
0.059 +0.004/-0
1.50 +0.1 / -0
T1
0.051 ± 0.004
1.30 ± 0.10
D1
0.059 ± 0.004
1.50 ± 0.10
T
0.010 ± 0.002
0.25 ± 0.05
Unit
inches
mm
Unit
inches
mm
Peeling Strength of Top Cover Tape
Test condition: 0.1 to 0.7N at a peel-off speed of 300 mm/min.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSSK
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Kelvin Termination Current
Sensing Resistors
SMD
YES
100% Matte Sn over Ni
Rev Date: 5/7/2021
4
Lead-Free
Lead-Free
Effective Date
Mfg. Effective Date
Code
(Std Product Series)
(YY/WW)
Always
Always
www.seielect.com
CSSK Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
C
S
S
K
1
2
F
T
2
L
Product Series
Kelvin Termination
CSSK
Current Sensing
Resistor
Size
Code
W
0612
1
3637
3
Tolerance
Code
Tol
D
0.5%
F
1%
G
2%
J
5%
Code
T
Packaging
Description
Size
Tape & Reel
0612
Embossed
3637
Resistance Value
Quantity
4000
1000
Four characters with "L"
used as multiplier
of 10-3 for any value
under 0.1 ohm.
0.55 milliohm = L550
2 milliohm = 2L00
Rev Date: 5/7/2021
5
www.seielect.com
很抱歉,暂时无法提供与“CSSK0612FTL750”相匹配的价格&库存,您可以联系我们找货
