CR2512-1W-1404FT
CR2512-1W-1404FT
    VENKEL
    电阻器 1.4MΩ ±1% 1W ±200ppm/℃ 2512
CR2512-1W-1404FT 数据手册
CR SERIES GENERAL PURPOSE THICK FILM RESISTORS FEATURES: • TCR as low as ±100ppm • Available Sizes 01005 to 2512 • Stable over temperature range • Good power dissipation capabilities (Rated power is conservatively rated) • 100% matte Tin over Nickel with wrap around termination for excellent solderability • Some values available for conductive epoxy application (suitable for MRI applications) PART NUMBER STRUCTURE CR 1206 Series Size 01005 0201 0402 0603 0805 1206 1210 2010 2512 - 8W - Power Rating 32W = 0.031W 20W = 0.05W 16W = 0.063W 10W = 0.10W 8W = 0.125W 4W = 0.25W 2W = 0.50W W = 0.75W 1W = 1W 2W =2W 103 J ☐ T ☐ Resistance Tolerance D = ± 0.5% F = ± 1% J = ± 5% Terminaton Leave blank for standard termination. Packaging T = Tape & Reel Optional Reel Identifier Leave blank if standard Reel size. 3 DIGIT (J TOL.) 2R2=2.2Ω 103=10KΩ 4 DIGIT (D & F TOL.) 10R2=10.2Ω 1002=10KΩ Jumper 3 zeros P = Palladium Silver Termination (PdAg) No tolerance specified for the zero ohm Note: 1% E24 values may be marked with a 3 digit code. Add "-13" if 13" Reel is required Leave blank for zero ohm value Example P/N: CR1206-8W-103JT Standard temination finish is 100% matte Tin (Sn) over Nickel. DIMENSIONS Unit: inches (mm) SIZE L W T C1 C2 01005 0.016 ± 0.0008 (0.4 ± 0.02) 0.008 ± 0.0008 (0.2 ± 0.02) 0.005 ± 0.0008 (0.13 ± 0.02) 0.003 ± 0.001 (0.08 ± 0.03) 0.003 ± 0.001 (0.08 ± 0.03) 0201 0.024 ± 0.002 (0.6 ± 0.05) 0.012 ± 0.001 (0.3 ± 0.02) 0.010 ± 0.002 (0.25 ± 0.05) 0.020 ± 0.008 (0.50 ± 0.20) 0.006 ± 0.002 (0.15 ± 0.05) 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.020 ± 0.002 (0.5 ± 0.05) 0.014 ± 0.002 (0.35 ± .05) 0.008 ± 0.004 (0.2 ± 0.1) 0.008 ± 0.004 (0.2 ± 0.1) 0603 0.063 ± 0.004 (1.6 ± 0.1) 0.031 ± 0.004 (0.8 ± 0.1) 0.018 ± 0.004 (0.45 ± 0.1) 0.012 ± 0.006 (0.30 ± 0.15) 0.012 ± 0.006 (0.30 ± 0.15) 0805 0.079 ± 0.006 (2.0 ± 0.15) 0.050 ± 0.006 (1.25 ± 0.15) 0.018 ± 0.006 (0.45 ± 0.15) 0.014 ± 0.006 (0.35 ± 0.15) 0.014 ± 0.006 (0.35 ± 0.15) 1206 0.126 ± 0.006 (3.2 ± 0.15) 0.063 ± 0.006 (1.6 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.020 ± 0.008 (0.50 ± 0.20) 0.020 ± 0.008 (0.50 ± 0.20) 1210 0.126 ± 0.006 (3.2 ± 0.15) 0.098 ± 0.006 (2.50 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.020 ± 0.008 (0.50 ± 0.20) 0.020 ± 0.008 (0.50 ± 0.20) 2010 0.197 ± 0.006 (5.0 ± 0.15) 0.098 ± 0.006 (2.50 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.026 ± 0.008 (0.65 ± 0.25) 0.024 ± 0.008 (0.60 ± 0.20) 2512 (1W) 0.248 ± 0.006 (6.3 ± 0.15) 0.126 ± 0.006 (3.2 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.026 ± 0.008 (0.65 ± 0.25) 0.024 ± 0.008 (0.60 ± 0.20) 2512 (2W) 0.248 ± 0.006 (6.3 ± 0.15) 0.126 ± 0.006 (3.2 ± 0.15) 0.024 ± 0.008 (0.60 ± 0.20) 0.024 ± 0.008 (0.60 ± 0.20) 0.020 ± 0.008 (0.50 ± 0.20) STRUCTURE 3 1 Alumina Substrate 6 Tin Plating 2 Backside Electrode 7 Primary Coating 3 Topside Electrode 8 Secondary Layer 4 Edge Electrode 9 Resistive layer 5 Nickel Plating 10 Marking 5 4 1 7 8 6 9 2 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 9/2021 1 CR SERIES GENERAL PURPOSE THICK FILM RESISTORS ELECTRICAL SPECIFICATIONS & RANGE Zero Ohm (Jumper) Zero Ohm (Jumper) Tolerance ±0.5% (D) ±1% (F) ±5% (J) Zero Ohm (Jumper) Zero Ohm (Jumper) Tolerance ±0.5% (D) SIZE 01005 0201 Power Rating at 70°C (W) 0.03W (1/32W) 0.05W (1/20W) Max. Working Voltage √—PR or 15V whichever is less √—PR or 25V whichever is less 0603 0.10W (1/10W) 0.063W (1/16W) √—PR or 50V whichever is less 0805 0.10W (1/10W) √—PR or 75V whichever is less 0.10W (1/10W) 0.125W (1/8W) √—PR or 150V whichever is less *Max. Overload Voltage 30V 50V 100V 150V 300V Operating Temp. Range -55°C to +125°C -55°C to +125°C -55°C to +155°C -55°C to +155°C -55°C to +155°C Current Rating 0.5A 0.5A 1A 1A 2A Resistance 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±100ppm - - 10Ω - 1MΩ - 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm - - 1.02MΩ - 10MΩ - 1.02MΩ - 10MΩ 1.02MΩ - 10MΩ ±100ppm - - 10Ω - 10MΩ 10Ω - 1MΩ 10Ω - 10MΩ 10Ω - 10MΩ 1Ω - 9.76Ω; 1.02MΩ - 10MΩ 1Ω - 9.76Ω; 10.2MΩ - 21.5MΩ 1Ω - 9.76Ω; 10.2MΩ - 21.5MΩ ±200ppm - 10Ω - 10MΩ 1Ω - 9.76Ω; 10.2MΩ - 20MΩ ±250ppm 100Ω - 1MΩ - - - - - ±300ppm 10Ω - 99Ω - - - - - ±100ppm - - - - - - ±200ppm - 1Ω - 10MΩ 1Ω - 10MΩ 1Ω - 10MΩ 1Ω - 10MΩ 1Ω - 10MΩ ±250ppm 100Ω - 1MΩ - - - - - ±300ppm 10Ω - 99Ω - - - - - ±350ppm - - - - 10MΩ - 22MΩ 10MΩ - 22MΩ SIZE 1206 Power Rating at 70°C (W) 0.125W (1/8W) 0.25W (1/4W) Max. Working Voltage √—PR or 200V whichever is less √—PR or 200V whichever is less √—PR or 200V whichever is less √—PR or 200V whichever is less *Max. Overload Voltage 400V 400V 400V 500V Operating Temp. Range -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C Current Rating 2A 2.5A 3.5A 4A 1210 0.25W (1/4W) 2010 0.50W (1/2W) 0.50W (1/2W) 0.75W (3/4W) 2512 1.0W 1.0W 2.0W Resistance 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) TCR Resistance Range Resistance Range Resistance Range Resistance Range ±100ppm 10Ω - 1MΩ - - - ±200ppm 1.02MΩ - 10MΩ - - - ±100ppm 10Ω - 10MΩ 10Ω - 1MΩ ±200ppm 1Ω - 9.76Ω; 10.2MΩ - 21.5MΩ 1Ω - 9.76Ω; 1.02MΩ - 20MΩ ±250ppm - ±1% (F) ±5% (J) 0402 0.063W (1/16W) ±300ppm - ±100ppm - ±200ppm 1Ω - 10MΩ 10Ω - 1MΩ 1Ω - 9.76Ω 10Ω - 1MΩ - 20.5MΩ 21.5MΩ 10Ω - 1MΩ ±250ppm - - ±300ppm - 20.5MΩ - 21.5MΩ ±350ppm 10MΩ - 22MΩ 10Ω - 1MΩ - 20.5MΩ - 21.5MΩ 1Ω - 9.76Ω; 1.02MΩ - 20MΩ 10Ω - 1MΩ 20.5MΩ 21.5MΩ - 1Ω - 9.76Ω; 1Ω - 9.76Ω; 1Ω - 9.76Ω 1.02MΩ - 20MΩ 1.02MΩ - 20MΩ 20.5MΩ - 22MΩ 20.5MΩ - 22MΩ - 10Ω - 1MΩ - 10Ω - 1MΩ - 10Ω - 1MΩ 1Ω - 9.76Ω 10Ω - 1MΩ 1Ω - 9.76Ω; 1Ω - 9.76Ω; 1Ω - 9.76Ω; 1Ω - 9.76Ω 1Ω - 9.76Ω 1.02MΩ - 20MΩ 1.02MΩ - 20MΩ 1.02MΩ - 20MΩ 1Ω - 9.76Ω 1.1MΩ - 20MΩ 1Ω - 9.76Ω - - - * Note: Max OverLoad Voltage = 2.5 * ( P x R )1/2 or Max. overload voltage listed above, whichever is lower. Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 9/2021 2 CR SERIES GENERAL PURPOSE THICK FILM RESISTORS MARKING CODE • 1 % E-24 values for 0603 size and larger are typically marked with the standard 3 digit marking code. • 1% E-96 values for 0805 size and larger may or may not be marked with the standard 4 digit marking code. • 5% E-24 values for 0603 size and larger, will be marked with standard 3 digit marking code. • 0603 -1% E-96 values will be marked with a standard 3 digit alpha numeric code (Please see page 5 for alpha numeric codes). • 01005, 0201 and 0402 cannot be marked. • 5% E-24 values for 1210~2512, may be marked with 4 digit marking code. • E-192 values will not typically be marked. DERATING CURVE Rated power (%) 120 100 80 60 40 20 0 -50 -55 -25 0 25 50 75 70 100 125 150 175 Ambient temperature (˚C) 01005 & 0201 size Email: sales@venkel.com 0402 to 2512 Size | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 9/2021 3 CR SERIES GENERAL PURPOSE THICK FILM RESISTORS TAPE & REEL SPECIFICATIONS REEL F Label H Unit: mm (inch) M C E C E F G H M 13.0 ± 0.2 (0.51 ± 0.008) 60.0 ± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0.45 ± 0.04) 9.0 ± .3 (0.35 ± 0.012) 1.5 ± .3 (0.06 ± 0.012) 180 ± 2.0 (7.09 ± 0.08) Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G TAPE T G B A W F T J Dø TAPE Paper H Embossed E Paper All dimensions in mm. SIZE A B W E F T G H J DØ 01005 0.45 ± 0.03 0.25 ± 0.03 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.40 ± 0.10 2.0 ± 0.05 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0201 0.7 ± 0.08 0.4 ± 0.08 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.42 ± 0.20 2.0 ± 0.05 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0402 1.15 ± 0.1 0.65 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.45 ± 0.10 2.0 ± 0.05 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0603 1.9 ± 0.1 1.1 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.70 ± 0.10 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0805 2.4 ± 0.1 1.65 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.10 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 1206 3.5 ± 0.1 1.9 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.10 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 1210 3.5 ± 0.1 2.8 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.10 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 2010 5.4 ± 0.2 2.9 ± 0.2 12.0 ± 0.1 1.75 ± 0.1 5.5 ± 0.5 1.2 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 2512 6.9 ± 0.2 3.6 ± 0.2 12.0 ± 0.1 1.75 ± 0.1 5.5 ± 0.5 1.2 8.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 Embossed PEEL BACK FORCE & DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 9/2021 4 CR SERIES GENERAL PURPOSE THICK FILM RESISTORS MARKING CODES FOR 0603, 1% RESISTORS As the chart shows, a Two-Digit Number Code is assigned to each standard Resistance Value per E96 guidelines (Decade value listings). This is followed by an Alpha Code System which is a multiplier for the value table. Each letter, from "A” — "Z”, represents a specific multiplier. STANDARD RESISTANCE VALUES FOR THE 10 TO 100 DECADE (also usable in decade multiples or sub-multiples) MARKING CODES FOR RESISTANCE VALUES E96 E96 E96 E96 E96 E96 DECADE CODE DECADE CODE DECADE CODE DECADE CODE DECADE CODE DECADE CODE 100 01 147 17 215 33 316 49 464 65 681 81 102 02 150 18 221 34 324 50 475 66 698 82 105 03 154 19 226 35 332 51 487 67 715 83 107 04 158 20 232 36 340 52 499 68 732 84 110 05 162 21 237 37 348 53 511 69 750 85 113 06 165 22 243 38 357 54 523 70 768 86 115 07 169 23 249 39 365 55 536 71 787 87 118 08 174 24 255 40 374 56 549 72 806 88 121 09 178 25 261 41 383 57 562 73 825 89 124 10 182 26 267 42 392 58 576 74 845 90 127 11 187 27 274 43 402 59 590 75 866 91 130 12 191 28 280 44 412 60 604 76 887 92 133 13 196 29 287 45 422 61 619 77 909 93 137 14 200 30 294 46 432 62 634 78 931 94 140 15 205 31 301 47 442 63 649 79 953 95 143 16 210 32 309 48 453 64 665 80 976 96 LETTER MULTIPLIER CROSS REFERENCE A – 100 B – 101 C – 102 D – 103 E – 104 F – 105 G – 106 H – 107 X – 10-1 Y – 10-2 Z – 10-3 ( Letter multipliers may also come in lower case.) By combining a specific two-digit code and a letter multiplier, you have a series of Numeric/Alpha digits that give you the complete E96 Resistance Value Codes for parts marking. 0603, ±1% Chip Marking 01A 25C 93D EXAMPLE: Explanation 01 means 100 and A = 1 25 means 178 and C = 100 93 means 909 and D = 1000 Email: sales@venkel.com | Value: 100 x 1.0 = 100 Ohm 178 x 100 = 17.8K Ohm 909 x 1000 = 909K Ohm Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 9/2021 5 CR SERIES GENERAL PURPOSE THICK FILM RESISTORS ENVIRONMENTAL CHARACTERISTICS REQUIREMENT ITEM ±1% and Below ±5% Temperature Coefficient of Resistance (T.C.R.) Short Time Overload TEST METHOD Jumper JIS-C-5201-1 4.8 IEC-60115-1 4.8 -55˚C~+12˚C, 25˚C is the reference temperature As Spec. ±(1.0%+0.05Ω) ±(2.0%+0.05Ω)
CR2512-1W-1404FT
物料型号:CR系列 器件简介:通用厚膜电阻器 引脚分配:文档中未明确提供引脚分配信息 参数特性: - TCR(温度系数)低至±100ppm - 尺寸从01005至2512 - 良好的功率耗散能力 - 100%镍上覆盖锡,提供优良的焊接性 - 符合RoHS、REACH标准,无卤素、无冲突矿产 功能详解:文档中未明确提供功能详解 应用信息:适用于MRI应用的某些值可用导电环氧树脂 封装信息:提供多种尺寸,包括01005至2512,以及不同的功率等级
电气规格和范围详细列出了不同尺寸的电阻器的功率等级、最大工作电压、最大过载电压和工作温度范围。此外,还提供了电阻值的公差、温度系数、电流额定值和电阻范围。
标记代码部分解释了0603尺寸及以上的1% E-24值通常使用标准的3位数字标记代码,而5% E-24值则使用标准的3位数字标记代码。01005、0201和0402尺寸无法标记。
环境特性部分列出了电阻器的电气特性,如温度系数、短时间过载、绝缘电阻、耐久性、湿热负载、干热、弯曲强度、焊接性、耐焊热、电压证明、浸出和快速温度变化等。
CR2512-1W-1404FT 价格&库存
很抱歉,暂时无法提供与“CR2512-1W-1404FT”相匹配的价格&库存,您可以联系我们找货
