RC1218JK-071R5L
RC1218JK-071R5L
    YAGEO(国巨)
    贴片电阻 1812 1.5Ω ±5% 1W ±200ppm/℃
RC1218JK-071R5L 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – May 15, 2020 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE -= Based on spec. (5) TAPING REEL & POWER 07= 7 inch dia. Reel 10=10 inch dia. Reel 13=13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series YNSC037 Fig. 2 240 = 24 × 100 = 24 88 YNSC038 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 YNSC004 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros YNSC099 Fig. 7 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros YNSC103 Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount SERIES RC_L 4 10 0075 to 2512 Outlines CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE RC0075 L (mm) W (mm) H (mm) I1 (mm) I2 (mm) 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 RC0402 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 RC0805 RC1206 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 RC1218 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE RC0075 -55℃ to 125℃ 1/50 outlines W Fig. 4 Chip resistor RC0100 1/32 W -55℃ to 125℃ MAXIMUM WORKING VOLTAGE 10V 15V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 30V 25V 30V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC1218JK-071R5L
1. 物料型号:文档中提到了YAGEO Phicomp的RC_L系列通用芯片电阻,包括不同的尺寸和公差,例如0075、0100、0201、0402、0603、0805、1206、1210、1218、2010、2512等。
2. 器件简介:RC_L系列是采用厚膜工艺制作的无铅端子的芯片电阻器,符合RoHS标准,无卤素,适用于所有通用应用。
3. 引脚分配:文档中没有明确提到具体的引脚分配,但通常这类表面贴装电阻器有两端子用于连接。
4. 参数特性: - 公差:±0.1%, ±0.5%, ±1%, ±5% - 工作温度范围:不同尺寸的电阻器有不同的工作温度范围,例如RC0402到RC2512的范围是-55°C到+155°C,而RC0075到RC0201的范围是-55°C到+125°C。 - 最大工作电压和最大电压等电气特性在表格中有所列出。
5. 功能详解:文档详细描述了电阻器的构造,包括其在高级陶瓷基板上的构造、内部金属电极、厚膜电阻元件、激光修调至额定电阻值、保护性环氧涂层以及外部端子。
6. 应用信息:适用于所有通用应用,包括节省PCB空间、提高组件和设备可靠性。
7. 封装信息:提供了不同尺寸的详细尺寸数据,包括长度、宽度、高度、内径和外径。
RC1218JK-071R5L 价格&库存
很抱歉,暂时无法提供与“RC1218JK-071R5L”相匹配的价格&库存,您可以联系我们找货
RC1218JK-071R5L
    库存:4000
    RC1218JK-071R5L
    • 1+4.059931+0.52077
    • 10+2.3152310+0.29698
    • 25+1.9227025+0.24663
    • 50+1.6947050+0.21738
    • 100+1.51521100+0.19436
    • 250+1.33341250+0.17104
    • 500+1.22811500+0.15753
    • 1000+1.144531000+0.14681
    库存:2426
    RC1218JK-071R5L
    • 4000+0.967134000+0.12406
    • 8000+0.927448000+0.11897
    • 12000+0.9080912000+0.11648
    • 20000+0.8871120000+0.11379
    • 28000+0.8750928000+0.11225
    • 40000+0.8637140000+0.11079
    库存:2426
