RNCS0603DKE7K50
RNCS0603DKE7K50
    SEI
    电阻器 7.5KΩ ±0.5% 1/16W ±25ppm/℃ 0603
RNCS0603DKE7K50 数据手册
RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Features: • • • • • • • • • • • Special passivation for moisture sensitive applications Absolute TCR’s to 15 ppm/ºC Test proven immunity to humidity and moisture corrosion Absolute tolerances to 0.1% Ideal replacement for costly Tantalum Nitride resistors Qualified to AEC-Q200 E196 values are not marked 100% RoHS compliant and lead free without exemption Halogen free REACH compliant For anti-sulfur version, refer to RNCS-AS specification The RNCS/RNCH series employs a special manufacturing process to ensure high power, high precision, ultra-stable performance, and long life in the harshest environments. In moisture comparison testing, the RNCS/RNCH series outperformed conventionally passivated Nichrome chip resistors and demonstrated the anti-corrosive claims characterized by Tantalum Nitride resistor products. Electrical Specifications - RNCS Type/Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 49.9 - 12K 0.1%, 0.25%, 0.5% RNCS0402 0.063 25 50 ±15 ±25 ±50 RNCS0603 0.063 50 100 ±15 ±25 ±50 25 - 332K RNCS0805 0.1 100 200 ±15 ±25 ±50 10 - 1M RNCS1206 0.125 150 300 ±15 ±25 ±50 10 - 1M 0.25 (2) (0.5) ±15 25 - 1M RNCS2010 150 300 ±25 ±50 10 - 1M 0.5 (1)(2) ±15 25 - 1M RNCS2512 150 300 ±25 ±50 10 - 1M 25 - 25K (1) Lesser of √ P*R or maximum working voltage (2) Higher power rating for each package size is valid if ambient temperature ≤ 80ºC and terminal temperature ≤ 105ºC Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Electrical Specifications - RNCH Power Rating (W) @ 70 ºC Type/Code Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) ±15 ±25 ±50 RNCH0603 0.1 75 150 RNCH0805 0.25 150 300 Ohmic Range (Ω) and Tolerance 0.1%, 0.25%, 0.5% 25 - 220K ±15 ±25 25 - 680K ±50 RNCH1206 0.33 200 ±15 ±25 ±50 400 25 - 1M (1) Lesser of √ P*R or maximum working voltage Mechanical Specifications Type/Code Weight (g) (1000 pc.) RNCS0402 0.55 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 1.85 4.76 9.11 RNCS2010 23.82 RNCS2512 38.46 L Body Length 0.039 ± 0.002 1.00 ± 0.05 0.061 ± 0.008 1.55 ± 0.20 0.079 ± 0.008 2.00 ± 0.20 0.120 ± 0.008 3.05 ± 0.20 0.193 ± 0.006 4.90 ± 0.15 0.248 ± 0.006 6.30 ± 0.15 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.008 0.80 ± 0.20 0.049 ± 0.008 1.25 ± 0.20 0.061 ± 0.008 1.55 ± 0.20 0.094 ± 0.006 2.40 ± 0.15 0.122 ± 0.006 3.10 ± 0.15 H Body Height 0.012 ± 0.002 0.30 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.017 ± 0.012 0.42 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 Unit inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Specification 0603, 0805, 1206, 2010, 2512 ≤ ± 0.02% ≤ ± 0.2% for high power rating ≤ ± 0.05% ≤ ± 0.25% for high power rating ≤ ± 0.05% ≤ ± 0.25% for high power rating Test Test Method Short Time Overload JIS-C-5201-1 4.13 Endurance MIL-STD-202 Method 108A Damp Heat with Load MIL-STD-202 Method 103B Solderability MIL-STD-202 Method 208H Resistance to Soldering Heat MIL-STD-202 Method 210E ≤ ± 0.02% ≤ ± 0.1% 260 ± 5°C for 10 seconds Thermal Shock MIL-STD-202 Method 107G ≤ ± 0.02% ≤ ± 0.1% -55°C ~ 150°C, 100 cycles 0402 Test Condition RCWV * 2.5 or Max. overload voltage whichever is lower for 2 seconds 70 ± 2°C, RCWV for 1000 hours with ≤ ± 0.25% 1.5 hours "ON" and 0.5 hour "OFF" 40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 ≤ ± 0.5% hours with 1.5 hours "ON" and 0.5 hour "OFF" ≤ ± 0.1% 95% min. coverage 245 ± 5°C for 3 seconds RCWV (Rated Continuous Work Voltage) = √ P*R or Max. Operating voltage whichever is lower Operating temperature range is -55°C to +155°C Storage Temperature is 15°C to 28°C. Humidity < 80% R.H. Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Power Derating Curve: Percent Rated Power(%) 100 -55ºC 70ºC 80 60 40 20 0 -60 155ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Soldering Condition: (1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds (2) Time of wave soldering at maximum temperature point 260°C: 10 seconds (3) Time of soldering iron at maximum temperature point 410°C: 5 seconds Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Reel Specifications Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 RNCS2010 RNCS2512 A 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 ± ± ± ± ± ± ± ± ± ± ± ± B 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 ± ± ± ± ± ± ± ± ± ± ± ± C 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 ± ± ± ± ± ± ± ± ± ± ± ± W 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.374 9.50 0.374 9.50 0.374 9.50 0.374 9.50 0.531 13.50 0.531 13.50 ± ± ± ± ± ± ± ± ± ± ± ± T 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.453 11.50 0.453 11.50 0.453 11.50 0.453 11.50 0.610 15.50 0.610 15.50 ± 0.020 ± 0.50 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 D0 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.016 0.40 0.024 0.60 0.030 0.75 0.030 0.75 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 inches mm inches mm inches mm inches mm inches mm inches mm ± ± ± ± ± ± ± ± T 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm Unit ± ± ± ± ± ± ± ± 0.001 0.03 0.001 0.03 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm Packaging Specifications - Paper Tape Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 A B W E 0.028 0.70 0.043 1.10 0.063 1.60 0.079 2.00 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P0 0.046 1.16 0.075 1.90 0.093 2.37 0.140 3.55 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P1 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P2 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± 0.061 1.55 0.061 1.55 0.061 1.55 0.061 1.55 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 4 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 ± ± ± ± ± ± ± ± F 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 Unit www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Peel Force of Top Cover Paper Tape The peel speed shall be about 300 mm/min ± 5% The peel force of top cover tape shall be between 8gf to 60gf Packaging Specifications – Embossed Plastic Tape Type/Code RNCS2010 RNCS2512 A 0.112 2.85 0.134 3.40 Type/Code RNCS2010 RNCS2512 ± ± ± ± B 0.004 0.10 0.004 0.10 0.215 5.45 0.262 6.65 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± E 0.004 0.10 0.004 0.10 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 0.004 0.10 0.004 0.10 0.039 1.00 0.039 1.00 D0 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 inches mm inches mm 0.008 0.20 0.008 0.20 inches mm inches mm T ± ± ± ± Unit Peel Force of Top Cover Plastic Tape The peel speed shall be about 300 mm/min ± 5% The peel force of top cover tape shall be between 20gf to 80gf Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Recommended Pad Layout Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 RNCS2010 RNCS2512 a b 0.020 0.50 0.031 0.80 0.039 1.00 0.079 2.00 0.142 3.60 0.193 4.90 0.020 0.50 0.039 1.00 0.039 1.00 0.045 1.15 0.055 1.40 0.063 1.60 c 0.024 0.60 0.035 0.90 0.053 1.35 0.067 1.70 0.098 2.50 0.122 3.10 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNCH RNCS Description Anti-Corrosive Tantalum Nitride Replacement Surface Mount Chip Resistor Anti-Corrosive Tantalum Nitride Replacement Surface Mount Chip Resistor Lead-Free Package / Standard Lead-Free Lead-Free Termination Effective Date Termination Series RoHS Mfg. Effective Date Composition Code Type Compliant (Std Product Series) (YY/WW) SMD YES 100% Matte Sn over Ni Always Always SMD YES 100% Matte Sn over Ni May-04 04/18 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 R N C S 0 8 0 5 D T E 4 K 7 5 Product Series Moisture Resistant RNCS Precision Thin Fim Chip Resistor RNCH High Power Size Code W 0402 0.063 0603 0.063 0805 0.1 1206 0.125 2010 0.25 2010 0.5 (2) 2512 0.5 (2) 2512 1 Tolerance Code Tol Value (1) B 0.1% E192, E96, C 0.25% E24 D 0.5% Packaging Code T K Description Size Quantity 7" Reel 0402 10000 Paper Tape 0603, 0805, 1206 5000 7" Reel 2010, 2512 4000 Plastic Tape 7" Reel All Sizes 1000 TCR Code ppm S 15 E 25 C 50 Resistance Value Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 800 Kohm = 800K 1 Mohm = 1M00 (1) E192 values are not marked, and may be subject to 20K MOQ (2) Higher power rating is valid if ambient temperature ≤ 80°C and terminal temperature ≤ 105°C Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com
RNCS0603DKE7K50
物料型号:RNCS/RNCH系列
器件简介: - 这些电阻器采用特殊制造工艺,确保在恶劣环境下具有高功率、高精度、超稳定性能和长寿命。 - 它们在耐湿性测试中表现优于传统钝化镍铬芯片电阻器,并且具有与钽氮化物电阻产品相当的抗腐蚀特性。
引脚分配:文档中没有提供具体的引脚分配图,但提到了不同类型的封装尺寸,如0402、0603、0805、1206、2010和2512。
参数特性: - 功率额定值、最大工作电压、最大过载电压、温度系数电阻(TCR)、欧姆范围和公差等电气规格。 - 例如,RNCS0402型号在70°C时的功率额定值为0.063W,最大工作电压为25V。
功能详解: - 这些电阻器适用于对湿度和水分敏感的应用,具有出色的耐湿性和抗腐蚀性。 - 它们是昂贵的钽氮化物电阻器的理想替代品,并符合AEC-Q200标准。
应用信息: - 适用于汽车电子、医疗设备、工业控制和其他需要高可靠性电阻器的应用。
封装信息: - 提供了详细的机械规格,包括重量、身体长度、宽度、高度以及顶部和底部终端的尺寸。
性能特征: - 包括短时间过载、耐久性、湿热带负载、焊接性、耐焊接热和热冲击等测试方法和规格。
订购信息: - 提供了如何根据电阻值、尺寸、产品系列、TCR、公差和包装来订购产品的指南。
环保合规性: - 符合RoHS指令,无铅终端组成为100%的Matte Sn over Ni。 - 遵守REACH法规,所有被动元件均不含高度关注物质(SVHC)。
订购示例: - 例如,订购RNCS 0805 DTE 4K 75表示0402尺寸、0.1% TCR、0.5%公差、4K欧姆的电阻器,包装为7英寸卷轴,数量为5000。
RNCS0603DKE7K50 价格&库存
很抱歉,暂时无法提供与“RNCS0603DKE7K50”相匹配的价格&库存,您可以联系我们找货
