KRL11050-C-R004-F-T1
    SUSUMU
    电阻器 4mΩ ±1% 5W ±50ppm/℃ 2043
KRL11050-C-R004-F-T1 数据手册
Precision current sensing low resistance chip resistors Metal foil, long-side terminal/ short- side terminal, face down. KRL series Two types are available: for high temperature application (up to 170C) and for low thermal emf application. Excellent TCRs: +/-150ppm/C for 1mΩ, +/-100ppm/C for 2mΩ, +/-50ppm/C for 3mΩ. Face down mounting offers accurate sensing. Depending on customers’ applications, we offer long-side terminal type and short-side terminal type ranging from 1/3W to 5W power rating. Protective coating used is halogen free showing our commitment to environment. RoHS compliant Completely lead free SPECIFICATIONS Short-side terminal Long-side terminal Mechanical Mechanical W L W L T A T A Dimensions (mm) KRL1220 KRL1632 KRL3264 Dimensions KRL2012 KRL3216 KRL6432 KRL7638 KRL9045 KRL11050 (mm) L 2.00.20 3.20.20 6.30.20 L 2.00.20 3.20.20 6.30.20 7.60.20 8.90.20 11.00.20 W 1.250.20 1.60.20 3.10.20 W 1.250.20 1.60.20 3.10.20 3.80.20 4.50.20 5.00.20 T 0.50.20 A (5.07.0m) A (8.0m) 0.40.20 0.50.20 0.50.20 1.100.20 1.900.20 0.40.20 1.00.20 Electrical Type Power Resistance Range() 0.50.20 0.50.20 0.50.20 0.50.20 0.50.20 0.50.20 T A (1m) 0.550.20 0.600.20 1.200.20 1.350.20 1.600.20 1.800.20 A (2m) 0.400.20 0.400.20 0.500.20 0.600.20 0.700.20 0.800.20 A (3m) 0.300.20 0.300.20 Electrical KRL1220 KRL1632 KRL3264 0.3W 0.5W 1.0W Type 5m100m 10m100m Tolerance % (code) 59m : 2.0 (G) 10m : 1.0 (F) TCR ppm /C 59m : 100 10m : 50 Operating Temp. Range C : 55170C M : 55155C KRL2012 KRL3216 KRL6432 KRL7638 KRL9045 KRL11050 0.66W 1.0W Power Resistance Range() 1m50m • Contact our sales office for wrap around terminal ERL series. 2.0W 3.0W 4.0W 1m100m Tolerance % (code) 1m : 5.0 (J) 2m : 2.0 (G) 3m : 1.0 (F) TCR ppm /C 1m : 150 2m : 100 3m : 50 Operating Temp. Range C : 55170C M : 55155C PART NUMBER KRL 6432 - C - R010 - F - T1 Package (T1:1000pcs/reel, T5:5000pcs/reel) Resistance Tolerance Resistance Value Operating Temperature : C (high temperature application) M (low thermal emf application) Dimensions Part Code susumu group catalog 5.0W
物料型号:KRL系列,包括KRL1220、KRL1632、KRL3264、KRL2012、KRL3216、KRL6432、KRL7638、KRL9045和KRL11050。
器件简介:这些电阻器具有高精度电流感应和低电阻特性,适用于高温环境(高达170°C)和低热电势应用。它们具有优异的温度系数(TCR),例如1mΩ的±150ppm/°C,2mΩ的±100ppm/°C,3mΩ的±50ppm/°C。面朝下安装提供精确的感应。
引脚分配:提供长边端子和短边端子两种类型,功率范围从1/3W到5W。
参数特性:包括尺寸、功率、电阻范围、容差、TCR和工作温度范围。
功能详解:电阻器采用无卤素的保护涂层,符合RoHS标准,完全无铅。
应用信息:适用于需要精确电流感应的应用,具体应用需联系销售办公室。
封装信息:提供不同的封装选项,如T1(1000pcs/卷)和T5(5000pcs/卷)。
KRL11050-C-R004-F-T1 价格&库存
很抱歉,暂时无法提供与“KRL11050-C-R004-F-T1”相匹配的价格&库存,您可以联系我们找货
