RE0402DRE074K7L
RE0402DRE074K7L
    YAGEO(国巨)
    贴片电阻 0402 4.7KΩ ±0.5% 1/16W ±50ppm/℃
RE0402DRE074K7L 数据手册
DATA SHEET THICK FILM CHIP RESISTORS Precision grade RE series 0.1%, 0.5%, 1%, TC 50 sizes 0201/0402/0603/0805/1206 Product specification – June 01, 2017 V.6 RoHS compliant & Halogen Free Product specification Chip Resistor Surface Mount RE 2 7 0201 to 1206 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RE0201 to RE1206 ultra precision chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) RE XXXX X X X XX XXXX L APPLICATIONS  Converters  Printer equipment  Server board  Telecom  Consumer FEATURES  Halogen Free Epoxy  RoHS compliant  Reducing environmentally hazardous wastes  High component and equipment reliability  Non-forbidden material used in products/production  Moisture sensitivity level: MSL 1 (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201 / 0402 / 0603 / 0805 / 1206 (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1% (3) PACKAGING TYPE R = Paper/PE taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for order only (Note) Resistance rule of global part number Resistance code rule Example XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 MΩ) 1M = 1,000,000 Ω O RDERING EXAMPLE The ordering code of a RE0603 chip resistor, TC 50 value 56Ω with ±0.5% tolerance, supplied in 7-inch tape reel is: RE0603DRE0756RL. NOTE 1. All our R-Chip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jun. 01, 2017 V.6 Product specification Chip Resistor Surface Mount RE 3 7 0201 to 1206 SERIES MARKING RE0805 / RE1206 Either resistance in E-24 or E-96: 4 digits 00 Fig. 1 Value = 10 kΩ First three digits for significant figure and 4th digit for number of zeros RE0603 0 1%, 0.5%, 0.1% E24 exception values 10/11/13/15/20/75 of E24 series Fig. 2 Value = 24 Ω 1%, 0.5%, 0.1% E96 refer to EIA-96 marking method, including values Fig. 3 Value = 12.4 kΩ 10/11/13/15/20/75 of E24 series RE0201/0402 No marking Fig. 4 For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION The resistors are constructed out of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive layer. The resistive layer is adjusted to give the approximate required resistance and laser cutting of this resistive layer that achieves tolerance trims the value. The resistive layer is covered with a protective coat and printed with the resistance value. Finally, the two external terminations (matte tin) are added. See fig. 5. OUTLINES For dimension see Table 1 DIMENSION Table 1 For outlines see fig. 5 TYPE L (mm) W (mm) H (mm) RE0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 RE0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05 RE0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 RE0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 I1 (mm) I2 (mm) 0.10 ± 0.05 0.15 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 0.35 ± 0.20 0.35 ± 0.20 RE1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 Fig. 5 Chip resistor outlines www.yageo.com Jun. 01, 2017 V.6 Product specification Chip Resistor Surface Mount RE SERIES 4 7 0201 to 1206 ELECTRICAL CHARACTERISTICS Table 2 RESISTANCE RANGE TYPE (E24/E96) OPERATING TEMPERATURE RANGE MAXIMUM WORKING RATING VOLTAGE POWER DIELECTRIC WITHSTAND VOLTAGE MAXIMUM OVERLOAD VOLTAGE TEMPERATURE COEFFICIENT OF RESISTANCE RE0201 100 Ω to 1 MΩ –55 °C to +155 °C 1/20W 25 V 50 V 50 V ± 50 ppm/°C RE0402 10 Ω to 1 MΩ –55 °C to +155 °C 1/16 W 50 V 100 V 100 V ± 50 ppm/°C RE0603 10 Ω to 1 MΩ –55 °C to +155 °C 1/10 W 75 V 150 V 150 V ± 50 ppm/°C RE0805 10 Ω to 1 MΩ –55 °C to +155 °C 1/8 W 150 V 300 V 300 V ± 50 ppm/°C RE1206 10 Ω to 1 MΩ –55 °C to +155 °C 1/4 W 200 V 500 V 400 V ± 50 ppm/°C NOTE The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8” FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION Paper/PE taping reel (R) RE0201 RE0402 RE0603 RE0805 RE1206 7" (178 mm) 10,000 10,000 5,000 5,000 5,000 10" (254 mm) 20,000 20,000 10,000 10,000 10,000 13" (330 mm) 50,000 50,000 20,000 20,000 20,000 NOTE 1. For Paper/PE tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing” FUNCTIONAL DESCRIPTION POWER RATING Each type rated power at 70°C: RE0201=1/20W, RE0402=1/16W, RE0603=1/10 W, RE0805=1/8 W, RE1206=1/4W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where Fig. 6 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω ) www.yageo.com Jun. 01, 2017 V.6 Product specification Chip Resistor Surface Mount RE SERIES 5 7 0201 to 1206 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Life/Endurance IEC 60115-1 4.25.1 REQUIREMENTS MIL-STD-202 Method 108A At 70± 2 °C for 1,000 hours, RCWV applied for ± (3%+0.05 Ω) 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure IEC 60068-2-2 1,000 hours at 155± 5 °C, unpowered ± (3%+0.05 Ω) Moisture Resistance MIL-STD-202 Method 106G Each temperature / humidity cycle is defined at 8 hours, 3 cycles / 24 hours for 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (3%+0.05 Ω) MIL-STD-202 Method 108A Parts mounted on test-boards, without condensation on parts Measurement at 24± 2 hours after test conclusion Thermal Shock MIL-STD-202 Method 107G -55/+125 °C Number of cycles required is 300. ± (1%+0.05 Ω) Devices mounted Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Short Time Overload IEC60115-1 4.13 Board Flex/ Bending IEC 60115-1 4.33 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (1%+0.05 Ω) Chips mounted on a 90mm glass epoxy resin PCB (FR4) ± (1%+0.05 Ω) No visible damage No visible damage Bending: see table 5 for each size Bending time: 60± 5 seconds www.yageo.com Jun. 01, 2017 V.6 Product specification Chip Resistor Surface Mount RE SERIES 6 7 0201 to 1206 TEST TEST METHOD PROCEDURE REQUIREMENTS Humidity IEC 60115-1 4.24.2 Steady state for 1000 hours at 40 °C / 95% ± (3%+0.05 Ω ) R.H. RCWV applied for 1.5 hours on and 0.5 hour off Solderability - Wetting J-STD-002 test B Electrical Test not required Well tinned (≥95% covered) No visible damage Magnification 50X SMD conditions: 1st step: method B, aging 4 hours at 155°C dry heat 2nd step: leadfree solder bath at 245± 3°C Dipping time: 3± 0.5 seconds - Leaching - Resistance to Soldering Heat J-STD-002 test D Leadfree solder, 260 °C, 30 seconds immersion time No visible damage IEC 60115-1 4.18 Condition B, no pre-heat of samples. Leadfree solder, 260 °C, 10 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (1%+0.05 Ω) No visible damage Table 5 Bending for sizes 0201 to 1206 TYPE Specification (mm) RE0201 RE0402 RE0603 RE0805 RE1206 5 5 3 3 2 www.yageo.com Jun. 01, 2017 V.6 Product specification Chip Resistor Surface Mount RE SERIES 7 7 0201 to 1206 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 6 May 31, 2017 - -Add 10" packing Version 5 Feb 24, 2017 - -Delete 125℃ in derating curve Version 4 May 03, 2016 - -Update 0201 resistor value Version 3 Jan. 26, 2015 - - Update Working Voltage Version 2 May 11, 2015 - - Update test and requirements Version 1 Jan 23, 2014 - - Add RE0201 - Add 0.1% - Update TEST AND REQUIREMENTS, add Humidity test Version 0 Dec 10, 2010 - - New datasheet for thick film ultra precision chip resistors sizes of 0402/0603/0805/1206, 0.5%, 1%, TC50 with lead-free terminations “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com Jun. 01, 2017 V.6
RE0402DRE074K7L
1. 物料型号:文档描述了YAGEO Phicomp生产的高精度厚膜芯片电阻器,型号为RE系列,尺寸从0201到1206,公差为0.1%,0.5%,1%,温度系数为TC 50。
2. 器件简介:这些电阻器采用无铅端接,符合RoHS标准和无卤要求,旨在减少环境污染,并提供高组件和设备可靠性。
3. 引脚分配:文档中没有明确提到具体的引脚分配图,但是提到了电阻器的构造,包括高等级陶瓷体、内部金属电极、电阻层、保护涂层以及外部端接(亚光锡)。
4. 参数特性: - 电阻值范围:100Ω至1MΩ - 工作温度范围:-55°C至+155°C - 功率额定值:1/20W至1/4W - 最大工作电压:25V至200V - 耐压电压:50V至500V - 最大过载电压:50V至400V - 温度系数:±50 ppm/°C
5. 功能详解:文档提供了电阻器的详细功能描述,包括功率额定值、额定电压的确定方法以及环境对电阻器性能的影响。
6. 应用信息:这些电阻器适用于转换器、打印机设备、服务器主板、电信和消费电子产品。
7. 封装信息:文档提供了不同尺寸的电阻器的详细尺寸信息,包括长度、宽度、高度以及相关的公差。
RE0402DRE074K7L 价格&库存
很抱歉,暂时无法提供与“RE0402DRE074K7L”相匹配的价格&库存,您可以联系我们找货
RE0402DRE074K7L
  • 1+1.271681+0.15779
  • 10+0.5858110+0.07269
  • 50+0.3852650+0.04781
  • 100+0.32751100+0.04064
  • 500+0.23028500+0.02858
  • 1000+0.200591000+0.02489
  • 5000+0.150765000+0.01871
库存:19787
RE0402DRE074K7L
  • 10000+0.1257010000+0.01560
  • 20000+0.1153420000+0.01431
  • 30000+0.1101930000+0.01368
  • 50000+0.1045350000+0.01297
  • 70000+0.1012470000+0.01256
  • 100000+0.09808100000+0.01217
  • 250000+0.09134250000+0.01134
  • 500000+0.08730500000+0.01084
库存:19787
