CSRF2010FK4L00
CSRF2010FK4L00
    SEI
    电阻器 4mΩ ±1% 1W 2010
CSRF2010FK4L00 数据手册
Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Features: • • • • • • • • High power rating Wide resistance range Current handling up to 26 amps TCR down to ± 50 ppm/C Other resistance values may be available 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications - CSRF Type/Code Power Rating (W) TCR (ppm/ºC) CSRF2817 5 4 ± 300 ± 200 ± 100 ± 150 ± 75 ± 100 ± 50 ± 100 ± 50 ± 100 ± 50 ± 100 ± 100 ± 75 ± 100 ± 50 ± 100 ± 50 ± 50 ± 50 CSRF4320 5 ± 50 CSRF0402 (2) 0.125 CSRF0603 (2) 0.25 CSRF0805 (2) 0.5 CSRF0508 (2) 1 CSRF1206 (2) 1 1.5 CSRF0612 1 CSRF2010 (1) 1 (2) 2 CSRF2512 Ohmic Range (Ω) and Tolerance 1% and 5% 0.003 - 0.007 0.008 - 0.02 0.002 - 0.004 0.005 - 0.009 0.01 - 0.03 0.003 - 0.01 0.011 - 0.03 0.005 - 0.009 0.01 - 0.062 0.003 - 0.01 0.011 - 0.05 0.002 0.003 - 0.004 0.005 - 0.03 0.003 - 0.009 0.01 - 0.1 0.002 - 0.009 0.01 - 0.56 0.005, 0.006, 0.008, 0.01, 0.015, 0.02 0.033 0.01 - 0.33 (1) For 2010 size, MOQ of 20K pieces per value is required. (2) Qualified to AEC-Q200 Electrical Specifications – CSRF-HP Type/Code CSRF0402…-HP Power Rating (W) (2) TCR (ppm/ºC) ±400 ±300 ±200 ±100 ±100 ±75 ±100 ±50 0.25 CSRF0603…-HP (2) 0.5 CSRF0805…-HP 1 Ohmic Range (Ω) and Tolerance 1% and 5% 0.0025 0.003 - 0.004 0.005 - 0.007 0.008 - 0.02 0.002 - 0.009 0.01 - 0.03 0.005 - 0.009 0.01 - 0.03 (2) Qualified to AEC-Q200 Please refer to the High-Power Resistor Application Note (page 9) for more information on designing and implementing high power resistor types. Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Mechanical Specifications – CSRF0402 Type/Code CSRF0402 0.003 Ω - 0.007 Ω CSRF0402 0.008 Ω - 0.02 Ω L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.039 ± 0.004 1.00 ± 0.10 W Body Width 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 H Body Height 0.018 ± 0.004 0.45 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 T Bottom Termination 0.014 ± 0.004 0.35 ± 0.10 0.010 ± 0.004 0.25 ± 0.10 Unit inches mm inches mm Mechanical Specifications – CSRF0402…-HP Type/Code CSRF0402…-HP 0.0025 Ω CSRF0402… -HP 0.003 Ω - 0.004 Ω Type/Code CSRF0402…-HP 0.005 Ω - 0.007 Ω CSRF0402…-HP 0.008 Ω - 0.02 Ω L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.039 ± 0.004 1.00 ± 0.10 W Body Width 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 H Body Height 0.018 ± 0.004 0.45 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 T Bottom Termination 0.018 ± 0.004 0.45 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.039 ± 0.004 1.00 ± 0.10 W Body Width 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 H Body Height 0.018 ± 0.004 0.45 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 T Bottom Termination 0.014 ± 0.004 0.35 ± 0.10 0.010 ± 0.004 0.25 ± 0.10 Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 Unit inches mm inches mm Unit inches mm inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Mechanical Specifications – CSRF0603 and CSRF0603…-HP L Body Length CSRF0603 0.063 ± 0.004 0.002 Ω - 0.004 Ω 1.60 ± 0.10 CSRF0603 0.063 ± 0.004 0.005 Ω - 0.03 Ω 1.60 ± 0.10 Note: CSRF0603…2L50 has no marking. W Body Width 0.031 ± 0.004 0.80 ± 0.10 0.031 ± 0.004 0.80 ± 0.10 Type/Code H Body Height 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 T Bottom Termination 0.022 ± 0.008 0.55 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 Unit inches mm inches mm Mechanical Specifications – CSRF0805 Type/Code CSRF0805 L Body Length 0.083 ± 0.008 2.10 ± 0.20 W Body Width 0.051 ± 0.006 1.30 ± 0.15 H Body Height 0.028 ± 0.006 0.70 ± 0.15 A Top Termination 0.016 ± 0.008 0.40 ± 0.20 T Bottom Termination 0.018 ± 0.008 0.45 ± 0.20 Unit inches mm Mechanical Specifications – CSRF0805…-HP Type/Code CSRF0805…-HP L Body Length 0.083 ± 0.008 2.10 ± 0.20 W Body Width 0.051 ± 0.006 1.30 ± 0.15 H Body Height 0.028 ± 0.006 0.70 ± 0.15 T Bottom Termination 0.018 ± 0.008 0.45 ± 0.20 Unit inches mm Mechanical Specifications – CSRF0508 Type/Code CSRF0508 L Body Length 0.047 ± 0.010 1.20 ± 0.25 Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W Body Width 0.079 ± 0.010 2.00 ± 0.25 3 H Body Height 0.026 ± 0.008 0.65 ± 0.20 T Bottom Termination 0.017 ± 0.008 0.43 ± 0.20 Unit inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Mechanical Specifications – CSRF1206 Type/Code CSRF1206 L Body Length 0.122 ± 0.008 3.10 ± 0.20 W Body Width 0.061 ± 0.008 1.55 ± 0.20 H Body Height 0.031 ± 0.006 0.80 ± 0.15 A Top Termination 0.020 ± 0.008 0.50 ± 0.20 T Bottom Termination 0.022 ± 0.008 0.55 ± 0.20 Unit inches mm Mechanical Specifications – CSRF2512 Type/Code CSRF2512 L Body Length 0.252 ± 0.012 6.40 ± 0.30 W Body Width 0.126 ± 0.012 3.20 ± 0.30 H Body Height 0.030 ± 0.012 0.75 ± 0.30 T Bottom Termination 0.055 ± 0.022 1.40 ± 0.55 Unit inches mm Mechanical Specifications – CSRF0612 Type/Code CSRF0612 L Body Length 0.063 ± 0.008 1.60 ± 0.20 W Body Width 0.126 ± 0.008 3.20 ± 0.20 H Body Height 0.024 ± 0.008 0.60 ± 0.20 T Bottom Termination 0.012 ± 0.008 0.30 ± 0.20 Unit inches mm Mechanical Specifications – CSRF2010 Type/Code CSRF2010 < 0.005 Ω CSRF2010 ≥ 0.005 Ω L Body Length 0.197 ± 0.008 5.00 ± 0.20 0.197 ± 0.008 5.00 ± 0.20 Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W Body Width 0.098 ± 0.008 2.50 ± 0.20 0.098 ± 0.008 2.50 ± 0.20 4 H Body Height 0.030 ± 0.008 0.75 ± 0.20 0.030 ± 0.008 0.75 ± 0.20 T Bottom Termination 0.063 ± 0.008 1.60 ± 0.20 0.024 ± 0.008 0.60 ± 0.20 Unit inches mm inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Mechanical Specifications – CSRF2817 L Body Length 0.280 ± 0.012 7.10 ± 0.30 Type/Code CSRF2817 W Body Width 0.165 ± 0.012 4.20 ± 0.30 H Body Height 0.031 ± 0.008 0.80 ± 0.20 T Bottom Termination 0.039 ± 0.012 1.00 ± 0.30 Unit inches mm Mechanical Specifications – CSRF4320 L Body Length 0.433 ± 0.008 11.00 ± 0.20 Type/Code CSRF4320 W Body Width 0.197 ± 0.008 5.00 ± 0.20 H Body Height 0.026 ± 0.008 0.65 ± 0.20 T Bottom Termination 0.093 ± 0.012 2.36 ± 0.30 Unit inches mm Performance Characteristics Test Test Method Test Specification Typical Test Condition Load Life MIL-STD-202F-Method 108A ±1% ≤ 0.5% RCWV at 70°C; 1.5 hours "ON"; 0.5 hour "OFF" Total 1000 ± 24 hours Resistance to Soldering Heat MIL-STD-202F-Method 210E ±1% ≤ 0.3% 260ºC ± 5°C for 10 ± 1 seconds Solderability MIL-STD-202F-Method 208H minimum 95% coverage > 95% 245ºC ± 5°C for 2 ± 0.5 seconds Thermal Shock MIL-STD-202F-Method 107G ±1% ≤ 0.3% -55°C to 150°C, 100 cycles JIS-C-5202-5.5 ± 1% + 0.5 mΩ ≤ 0.3% High Temperature Exposure Moisture Resistance MIL- STD-202F-Method 106G ±1% ±1% ≤ 0.2% ≤ 0.5% Insulation Resistance MIL-STD-202F-Method 302 1 MΩ minimum ≥ 1 MΩ Short Time Overload (*) Sizes 0805-HP, 0508, 2512 and 2817: 2.5 X rated power for 5 seconds Size 4320: 3 X rated power for 5 seconds All other sizes: 5 X rated power for 5 seconds 125ºC, 1000 hours Apply 100VDC for 1 minute (*) Sufficient copper size and weight required to maintain component temperature below 100°C Storage Temperature: 5ºC ~ 35°C. humidity: 40% ~ 75% Operating temperature range: 2512 and 2817 = -55°C to + 155°C; all other sizes = -55°C to + 170°C Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Power Derating Curve: Taping Specifications – Paper Tape Type/Code CSRF0402 CSRF0603 CSRF0805 CSRF0508 CSRF1206 CSRF0612 A 0.028 0.70 0.043 1.10 0.063 1.60 0.066 1.68 0.079 2.00 0.079 2.00 Type/Code CSRF0402 CSRF0603 CSRF0805 CSRF0508 CSRF1206 CSRF0612 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 B ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.047 1.20 0.075 1.90 0.094 2.40 0.094 2.38 0.142 3.60 0.142 3.60 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 E ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P1 ± ± ± ± ± ± ± ± ± ± ± ± 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 6 F ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P2 ± ± ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.002 0.05 0.002 0.05 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.061 1.55 0.061 1.55 0.061 1.55 0.059 1.50 0.061 1.55 0.061 1.55 W ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.002 ± 0.05 ± 0.002 ± 0.05 D0 ± ± ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.002 0.05 0.002 0.05 Unit 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± ± ± ± ± T 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.008 0.20 0.008 0.20 Inches mm Inches mm Inches mm Inches mm Inches mm Inches mm Unit 0.024 0.60 0.028 0.70 0.038 0.97 0.034 0.87 0.038 0.97 0.038 0.97 ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.004 0.10 0.004 0.10 Inches mm Inches mm Inches mm Inches mm Inches mm Inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Taping Specifications – Embossed Plastic Tape Type/Code A 0.110 2.80 0.134 3.40 CSRF2010 CSRF2512 Type/Code ± ± ± ± B 0.006 0.15 0.008 0.20 0.217 5.50 0.266 6.75 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 CSRF2010 CSRF2512 ± ± ± ± ± ± ± ± E 0.006 0.15 0.008 0.20 0.069 1.75 0.069 1.75 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 0.002 0.05 0.004 0.10 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± W 0.002 0.05 0.004 0.10 0.472 12.00 0.472 12.00 ± 0.004 ± 0.1 0.10 ± 0.004 ± 0.10 0.033 0.84 0.039 1.00 D0 ± ± ± ± Unit 0.012 0.30 0.012 0.30 Inches mm Inches mm 0.008 0.20 0.008 0.20 Inches mm Inches mm T ± ± ± ± Unit Taping Specifications – Embossed Plastic Tape Type/Code A 0.181 4.60 0.211 5.36 CSRF2817 CSRF4320 Type/Code ± ± ± ± B 0.004 0.10 0.004 0.10 0.295 7.50 0.462 11.74 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 0.315 8.00 0.315 8.00 CSRF2817 CSRF4320 ± ± ± ± ± ± ± ± E 0.004 0.10 0.004 0.10 0.069 1.75 0.069 1.75 0.004 0.10 0.004 0.10 0.059 1.50 0.059 1.50 P2 ± ± ± ± F ± ± ± ± 0.004 0.10 0.004 0.10 0.217 5.50 0.453 11.50 0.004 0.10 0.004 0.10 0.061 1.55 0.059 1.50 D0 ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.472 12.00 0.945 24.00 0.004 0.10 0.010 0.25 0.010 0.25 0.013 0.33 D1 ± ± ± ± ± ± ± ± P0 0.012 0.30 0.012 0.30 0.157 4.00 0.157 4.00 0.002 0.05 0.004 0.10 0.047 1.20 0.077 1.96 T1 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 Inches mm Inches mm 0.004 0.10 0.004 0.10 Inches mm Inches mm T2 ± ± ± ± Unit Recommended Pad Layouts - CSRF Size a b c Unit CSRF0402 0.003 Ω - 0.007 Ω CSRF0402 0.008 Ω - 0.02 Ω 0.012 0.30 0.020 0.50 0.024 0.60 0.020 0.50 0.024 0.60 0.024 0.60 inches mm inches mm Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor Recommended Pad Layouts – CSRF (cont.) Size a b c Unit CSRF0603 0.002 Ω - 0.004 Ω CSRF0603 0.005 Ω - 0.009 Ω CSRF0603 0.01 Ω - 0.03 Ω 0.014 0.35 0.024 0.60 0.035 0.90 0.047 1.20 0.024 0.60 0.087 2.20 0.024 0.60 0.063 1.60 0.106 2.70 0.063 1.60 0.122 3.10 0.165 4.20 0.157 4.00 0.043 1.10 0.035 0.90 0.028 0.70 0.047 1.20 0.043 1.10 0.051 1.30 0.051 1.30 0.093 2.35 0.071 1.80 0.152 3.85 0.122 3.10 0.079 2.00 0.197 5.00 0.039 1.00 0.039 1.00 0.039 1.00 0.055 1.40 0.091 2.30 0.071 1.80 0.142 3.60 0.114 2.90 0.114 2.90 0.141 3.57 0.141 3.57 0.189 4.80 0.276 7.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm CSRF0805 CSRF0508 CSRF1206 CSRF0612 CSRF2010 0.003 Ω - 0.009 Ω CSRF2010 0.01 Ω - 0.1 Ω CSRF2512 0.002 Ω - 0.003 Ω CSRF2512 0.004 Ω - 0.56 Ω CSRF2817 CSRF4320 Recommended Pad Layouts – CSRF-HP Size CSRF0402…-HP CSRF0603…-HP 0.005 Ω - 0.009 Ω CSRF0603…-HP 0.01 Ω - 0.03 Ω CSRF0805…-HP a b c Unit 0.008 0.20 0.024 0.60 0.035 0.90 0.047 1.20 0.031 0.80 0.035 0.90 0.028 0.70 0.047 1.20 0.024 0.60 0.039 1.00 0.039 1.00 0.055 1.40 inches mm inches mm inches mm inches mm Soldering Recommendations: • • • Peak reflow temperatures and durations: o IR Reflow Peak = 260°C max for 10 seconds o Wave Solder = 260°C max for 10 seconds Compatible with lead and lead-free solder reflow process Recommended IR Reflow Profile: Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100ºC for the CSS / CSSH series and 70ºC for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105ºC. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohm at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. The 102ºC heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105 ºC total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72ºC. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, vias through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50mΩ. This should be taken into account when designing. Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. CSRF Series Resistive Product Solutions Foil on Ceramic Current Sensing Chip Resistor RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series CSRF Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Foil on Ceramic Current Sensing Surface Mount Chip Resistor SMD YES 100% Matte Sn over Ni Jul-04 04/27 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 C S R F 0 4 0 2 F T 8 L 0 0 - H P Product Series Code Description CSRF Foil/Ceramic Size Code 0402 0603 0805 0508 1206 0612 2010 2512 2817 4320 W Std 0.125 0.25 0.5 1 1 1.5 1 2 4, 5 5 -HP 0.25 0.5 1 NA NA NA NA NA NA NA Tolerance Code Tol F 1% J 5% Rev Date: 7/21/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Code T Packaging Description Size Quantity 0402 10000 7" Reel 0603, 0805 Paper Tape 0612, 1206 5000 0508 2010 4000 Embossed 2512 Plastic Tape 2000 2817, 4320 10 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier -3 of 10 for any value under 0.1 ohm.. 0.005 ohm = 5L00 0.01 ohm = 10L0 0.1 ohm = R100 Special Code Description -HP High Power www.seielect.com marketing@seielect.com
CSRF2010FK4L00 价格&库存
很抱歉,暂时无法提供与“CSRF2010FK4L00”相匹配的价格&库存,您可以联系我们找货
